查看: 1096|回复: 11
请问各位Skill大神,为什么我写的skill程序在一个打开的板子里面只能运行一次。
发表于 2019-8-26 12:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
各位大神,我自己写了一个skill,用procedure来定义的函数,但是我发现,如果我在当前板子里面运行一次过后,就不能运行第二次,必须重新关闭allegro后,然后再次打开这个板子才能运行,请问各位大神,这个是怎么回事啊。跪求答案,多谢多谢了。
发表于 2019-8-26 14:02 | 只看该作者
有源码么,看看
请大师帮忙看看啊。也请指导一下,多谢了  详情 回复 发表于 2019-8-26 14:20
axlCmdRegister("releasefile" 'releasefile ?cmdType "General") procedure( releasefile() designnameandpath=axlDMFileParts(axlGetDrawingName()) designpath=nth(0 designnameandpath) designname=  详情 回复 发表于 2019-8-26 14:19
 楼主| 发表于 2019-8-26 14:19 | 只看该作者
designname=nth(1 designnameandpath)
rexComplie("_PCB_")
gerbername=rexReplace(designname "_GERBER_" 0)
stencilname=rexReplace(designname "_STENCIL_" 0)
releasefile=createDir("Releasefile")
gerberfilename=strcat("./Releasefile" "/" gerbername)
stencilfilename=strcat("./Releasefile" "/" stencilname)
gerberfile=createDir(gerberfilename)
stencilfile=createDir(stencilfilename)
drcerror=axlDBGetDesign()->drcs
if((drcerror!=nil) then
        yesnocancel=axlUIYesNo("DRC exist in this design, Wouldyou like to clear them all?")
        if((yesnocancel!=1) then
                axlShell("replay artwork.scr")
                axlShell("replay componentreport.scr")
        else
                print("Please Check the DRCs.")
if((drcerror==nil) then
filename=getDirFiles("./GBR")
filename1=remove("." filename)
filename2=remove(".." filename1)
filenamelength=length(filename2)-1
for(
        i 0 filenamelength
        name=nth(i filename2)
        fileorigpath=strcat("." "/" "GBR" "/" name)
        filedestpath=strcat("." "/" gerberfilename "/" name)
        axlOSFileCopy(fileorigpath filedestpath t)
currentpath=getWorkingDir()
stencilpath1=strcat(currentpath "/" stencilfilename "/" "silk_top.art")
axlOSFileCopy("./GBR/silk_top.art" stencilpath1 t)
stencilpath2=strcat(currentpath "/" stencilfilename "/" "silk_bottom.art")
axlOSFileCopy("./GBR/silk_bottom.art" stencilpath2 t)
stencilpath3=strcat(currentpath "/" stencilfilename "/" "pmask_top.art")
axlOSFileCopy("./GBR/pmask_top.art" stencilpath3 t)
stencilpath4=strcat(currentpath "/" stencilfilename "/" "pmask_bottom.art")
axlOSFileCopy("./GBR/pmask_bottom.art" stencilpath1 t)
redmefilepath=strcat(currentpath "/" stencilfilename "/" "README.txt")
axlOSFileCopy("D:/README.txt readmefilepath t)
brdpath=strcat("./" designname ".brd")
brdtoreleasefile=strcat("./Releasefile" "/" designname ".brd")
axlOSFileCopy(brdpath brdtoreleasefile t)
 楼主| 发表于 2019-8-26 14:20 | 只看该作者
请大师帮忙看看啊。也请指导一下,多谢了
我不是大师 看了一下,有以下几个地方 axlCmdRegister("releasefile" 'releasefile ?cmdType "General") procedure( releasefile() designnameandpath=axlDMFileParts(axlGetDrawingName()) des  详情 回复 发表于 2019-8-26 17:12
发表于 2019-8-26 17:12 | 只看该作者
Nick740492 发表于 2019-8-26 14:20
请大师帮忙看看啊。也请指导一下,多谢了
我不是大师
看了一下,有以下几个地方
rexComplie("_PCB_")  ; 函数改为rexCompile
        if((yesnocancel!=1) then ; YesNo只返回t和nil。改为if(!yesnocancel)不理会DRC继续导出光绘
        else
                print("lease Check the DRCs.")
  ) ;这一部分可以和上面合并
filename=getDirFiles("./GBR") ;没看懂这个GBR文件夹哪里来的,还是原来就存在的?
for(
        i 0 filenamelength
axlOSFileCopy("D:/README.txt readmefilepath t) ;缺少双引号
另外,如果要运行第二次,最好在创建文件夹和文件之前做一下文件夹和文件是否存在的判断。程序第二次运行,建议把第一次产生的gerber删除掉。
好的,多谢了啊,我这边其实已经改掉了和你上面检查的东西,就是没有进行判断文件是否存在 现在又发现strcat那边有问题,好像strcat起来的string会多一个./,请帮忙一并看看啊。谢谢大师了  详情 回复 发表于 2019-8-26 17:42
 楼主| 发表于 2019-8-26 17:41 | 只看该作者
 楼主| 发表于 2019-8-26 17:42 | 只看该作者
放飞自我 发表于 2019-8-26 17:12
我不是大师
看了一下,有以下几个地方
 楼主| 发表于 2019-8-26 20:40 | 只看该作者
请问skill大师们,为什么我第二次load 这个skill程序的时候出现function redefined啊。这个是怎么回事啊。请大师指导下,非常感谢
redefined,就是你的procedure重新加载并定义了,也就是更新过了  详情 回复 发表于 2019-8-27 10:19
 楼主| 发表于 2019-8-27 07:47 | 只看该作者
找到原因了,大神们的指导与浏览,谢谢
 楼主| 发表于 2019-8-27 07:49 | 只看该作者
请问大师们,为什么这个程序只能在板子里面运行一次啊,第二次就不行了,必须重新关闭PCB再次打开才能运行。请各位大神帮忙看看,多谢多谢了
 楼主| 发表于 2019-8-27 08:23 | 只看该作者
找到原因了,多谢各位大神的指导
    2022-5-6 15:29
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2019-8-27 10:19 | 只看该作者
    Nick740492 发表于 2019-8-26 20:40
    请问skill大师们,为什么我第二次load 这个skill程序的时候出现function redefined啊。这个是怎么回事啊。 ...
    GMT+8, 2025-8-20 21:55 , Processed in 0.156250 second(s), 34 queries , Gzip On.
