查看: 799|回复: 2
Design Entry HDL
发表于 2019-8-23 14:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        Schematic instance: @02_043758B_LIB.02_043758B_TOP(SCH_1)AGE6_I23@CA~) x; _4 N2 x' f. G5 f
PACITORS.CAP(CHIPS)
% C- E: Q' i+ m1 a        Physical Path: @\02_043758b_lib\.\02_043758b_top\(sch_1):page6_i23@cap~
+ }& V( `" W; J4 xacitors.cap(chips), W; {0 \# N. h. D. o( Z5 ?
        Check the PACK_TYPE or PART_NAME property assigned to the instance and~- u+ W/ p! K3 x4 q, \
ensure that the part exists in the part table file.
! }" }  G" b- R, V) E2 i #738 ERROR(SPCOPK-1051): Cannot find the physical part CAP for
. a  F8 [+ O$ @* r        Schematic instance: @02_043758B_LIB.02_043758B_TOP(SCH_1)AGE6_I24@CA~
8 f: |7 I% z- f6 }PACITORS.CAP(CHIPS)
' h  @. z; e6 R4 b        Physical Path: @\02_043758b_lib\.\02_043758b_top\(sch_1):page6_i24@cap~
+ {& J2 L4 ]0 j  n; E* E8 D& ?& I2 x) ]" @% o, _
9 o' B4 O! e& `( S& a
这种错误是怎么意思?! y9 l  z) \7 K; b3 n0 G
6 e0 t" H; T: p9 K
发表于 2019-8-25 21:48 | 只看该作者
添加器件的时候选器件之后再add试试看
“来自电巢APP”
发表于 2019-8-26 14:43 | 只看该作者
1.排除PFT文件中没有包含这个器件
+ y- ?9 v3 S% {* K! p1 \2.排除器件是否没有指定pack type
GMT+8, 2025-9-10 05:48 , Processed in 0.109375 second(s), 24 queries , Gzip On.
