查看: 598|回复: 2
请教这段代码的含义?
发表于 2019-8-6 09:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
procedure(CreateCrossSectionCall(form)
case(form->cuRField
("close" axlFormClose(form)
axlCancelEnterFun( ) )
("layerSum" num=form->curValue
if(num==6 || num==8 then
axlFormSetFieldEditable(form "rule1" t)
axlFormSetFieldEditable(form "rule2" t)
else
axlFormSetFieldEditable(form "rule1" nil)
axlFormSetFieldEditable(form "rule2" nil)
("enter" num=axlFormGetField(form "layerSum")
case(num
(10 lay= '( "GND" "IN1" "IN2" "VCC" "VCC1" "IN3" "IN4" "GND1" )
foreach(elm lay
if(index(elm "GND") || index(elm "VCC") then
axlLayerCreateCrossSection("BOTTOM" "Plane" "Copper" elm "Negative")
axlLayerCreateCrossSection("BOTTOM" "Dielectric" "FR-4")
else
axlLayerCreateCrossSection( "BOTTOM" "Conductor" "Copper" elm " Positive")
(6 if(axlFormGetField(form "rule1") then
lay= '( "GND1" "IN1" "VCC" "GND2" )
else
lay= '( "GND" "IN1" "IN2" "VCC" )
foreach(elm lay
else
Positive")
请教下各位大神,这段代码是干嘛用的呀?尤其是标红的那两行,代表啥含义?还请各位不吝赐教,感激不尽
    2022-5-6 15:29
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2019-8-7 10:56 | 只看该作者
    输入层面的数量,自动创建叠构
    2022-5-6 15:29
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2019-8-7 11:00 | 只看该作者
    如果输入的层面数量是10,那么层面依次是 "GND" "IN1" "IN2" "VCC" "VCC1" "IN3" "IN4" "GND1"
    创建叠构,层面是BOTTOM,类型是Plane,材质是Copper,名称是elm的内容,类型是负片
    创建叠构,层面是BOTTOM,类型是Conductor,材质是Copper,名称是elm的内容,类型是正片
    GMT+8, 2025-8-21 03:03 , Processed in 0.109375 second(s), 23 queries , Gzip On.
