$ A. v, A3 X% E* w' |
6 G6 k. p4 t5 F; {' w各位好,小妹最近因为课程设计刚开始学仿真,用得是orcad的仿真(版本貌似是9.1)。6 Y: v! [9 ^* u2 a9 _0 o
但是在仿真中碰到一些问题,百度、google都没找到答案,所以希望能有人帮帮忙。
- t9 @) X( D c, P0 w. `# q) S- S9 q) ~9 K0 r( Y5 D4 P
1、这个软件是不是不能仿真比较简单的电路?& x2 m1 n( D8 g! n- l( }4 ^
我之前仿真整流电路以及看的教程上的简单直流交流电路都没问题,但是后面分别画了带三极管、带芯片的就总仿真不出来。
+ T# L) @8 f- r% k7 I不知道是不是我画得不对。。(见图)& M2 Y8 L. L9 X1 q$ m+ r, X
带三极管的 G/ z- D7 l5 C: x
, y' X& c2 m. v9 n. a1 U c, `7 }
带芯片的. [& p) z7 F3 i$ J% X: W8 x9 u
% y G6 `2 q2 j3 u& \9 O Z
5 ^3 e+ d2 _3 f! h) a2、元件问题
# c, K3 x! F$ Q是不是后来自己加的元件没有定义就无法用?因为后来经过一些改动,报错就变成一样的,就是XXX is undefined# \0 k) K" S7 ]4 f$ y4 g; x, G
以下是运行某电路仿真出现的报错- ERROR -- Model MUR460 used by D_D19 is undefined
4 [, a! H/ D4 ]; X+ t5 L - ERROR -- Model MUR460 used by D_D20 is undefined
0 `/ y7 X0 L! X8 c - ERROR -- Model MUR460 used by D_D21 is undefined* j8 t! i& t3 l/ [* S- G+ s$ l
- ERROR -- Model MUR460 used by D_D22 is undefined
7 @7 d' `0 B0 ^+ d# S% l/ F - ERROR -- Model MUR460 used by D_D23 is undefined
* x# Z7 }6 H' G: E - ERROR -- Model MUR460 used by D_D24 is undefined5 J& u y4 M; M2 |
- ERROR -- Model MUR460 used by D_D25 is undefined5 g$ \7 _" J. m; Q0 D! ?
- ERROR -- Model MUR460 used by D_D26 is undefined
S- J+ o6 x8 S$ G5 u - ERROR -- Model TN33_20_11_2P90 used by K_TX1 is undefined* _' I$ l( W4 n& }
- ERROR -- Model TN33_20_11_2P90 used by K_TX2 is undefined/ T4 u% S( K; G/ u( |- ^
- ERROR -- Model TN33_20_11_2P90 used by K_TX3 is undefined
* {; H- l& w0 t% r3 {3 x - ERROR -- Model TN33_20_11_2P90 used by K_TX4 is undefined
* b1 ?$ P6 U" a8 R6 D! D4 [ - ERROR -- Model IRFP450 used by M_M5 is undefined( ~5 C0 P# }% N0 ~) u% o$ ]
- ERROR -- Model IRFP450 used by M_M6 is undefined6 y x* Q* L8 W* g6 b
- ERROR -- Model IRFP450 used by M_M7 is undefined, |! |6 t# _4 k
- ERROR -- Model IRFP450 used by M_M8 is undefined
6 M7 T3 O& m; h2 h1 W# e - ERROR -- Model Q2N5551 used by Q_Q1 is undefined
, B$ P& w7 [3 Q - ERROR -- Model Q2N5551 used by Q_Q2 is undefined& Y ]& L9 } N0 A" i# @8 Y+ ]
- ERROR -- Model Q2N5401 used by Q_Q3 is undefined$ p } \: @# C5 t" p
- ERROR -- Model Q2N5401 used by Q_Q4 is undefined
复制代码 其他还有些都是类似的
0 Z! X( ^ ^5 ~ g. @4 F以上各种model后面的都是我另外找的库放进去直接用的2 t& [3 e. _2 b) o5 q
; z2 A% X+ x' K2 H( m% u- i: t( U4 z2 O
3、PWM波的仿真
. f! N8 f8 F, i( _下图是我根据别人的图画的,但有右上部分互感报错,我也不太会用。。
8 L; Z. H+ l( _( c6 v6 } }, u
$ z2 j+ w# Z5 K2 I/ l我们这个课程设计是DC-DC开关设计,其他问题都不大,就是PWM波的问题6 f& T6 ]$ ^- O
如果这个图中的不行,不知道有没有其他简单的方法可以生成PWM波?
. U, E- Z1 k0 O# U7 u! L因为对这个软件不熟,电力电子课上得也不是很好,所以不知道有没有可以替代的
( [: Q) ~8 p6 t3 W7 _* W8 P3 M1 }% d* g' R. `" z l; {6 p
+ R- M; Q4 Z3 b+ B* @# f小白新上手,可能有很多弱的问题,还请各位不吝赐教。* W" G! F7 _2 Q% \3 {
不一定肯定得解决,能给些建议、意见或想法都可以: o: ?7 e# G% ]8 b3 y
毕竟小妹也刚开始学,能得到任何一点经验都好的,非常感谢!!! |
