我觉得没有成功的朋友,多半是因为没有修改安装在X盘完成后直接运行.bat这个文件中的路径吧; K7 U; V0 p& V- x
@echo off
/ I* W9 s( Z7 |. b8 s, p; n@TITLE 馒头PADS2007.4 请稍等!
' a" N0 H" i# c; N@echo 置换mgls.dll5 ?) B) b R/ j9 _9 T1 C
@copy mgls.dll C:\MentorGraphics\2007.4PADS\MGC_HOME.ixn\lib
* k! o- k; c$ C: B@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\hyperlynx, {% y1 k. n, u; E7 F. f1 y
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\Programs
' `4 s' z+ K3 j+ t1 }, M@copy mgls.dll C:\MentorGraphics\2007.4PADS\MGC_HOME.ixn\lib\lib4 V, P1 {9 W/ H8 [' ?
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog
+ r D7 P; o; b3 m3 @% k2 n@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\common\win32\lib
* [! Z2 y; ~- c. A [4 f@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\common\win32\_bin: \0 }3 Y- F) w- X Q) ]0 I) L% n
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\in
" j! s0 @. R1 W# z' W@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\is% l H; U# x3 m. @! [6 X
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\pr
8 `% d7 K' u* w@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\sm& Q$ i8 }. [ p" t& }, v0 U
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\sn
+ L6 [' y5 e7 P@copy mgls.dll C:\MentorGraphics\2007.4PADS\MGC_HOME.ixn\pkgs\icwave.ixn\lib\lib F! i/ t, V( ~0 M5 H- j, k9 K: f
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\fusion\win32\bin
, R9 M5 @% E+ X: c@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\van_vss\win32\pgm\dir
( p; E/ p! ?6 u0 Y" Z9 d6 y! n: u@echo mgls.dll置换完毕!: e' f* y1 P: f' D0 Z( C% m
@cls) }* F2 Z2 r9 l& Y* q% k
@echo 破解中,请稍等!! F6 N: \: U0 ~0 w$ _. G* s, ^& P
@echo off# f; M: k; m( k. T9 j
@copy license.src C:\MentorGraphics\2007.4PADS: E3 b& V) i: [. _& P) F0 P5 { }
@copy LICENSE.TXT C:\MentorGraphics\2007.4PADS
# ?" [) Z$ N2 v2 v@copy MakeLic.bat C:\MentorGraphics\2007.4PADS
0 P1 }0 _+ E/ b! @) X@copy MGLS.DLL C:\MentorGraphics\2007.4PADS* f8 v) Z( S4 L: Y" _' T' h8 P
@copy MentorKG.exe C:\MentorGraphics\2007.4PADS7 {! |# u% K, ~! k7 c' Y
@copy Environment.reg C:\MentorGraphics\2007.4PADS: `! D7 X% S: ~- ~" K& _+ n% G
cls) v3 I% t, s8 R+ m, y9 \6 H }
@cd/d c:\MentorGraphics\2007.4PADS\
$ \, ]7 T/ a; n5 Z: w@MentorKG.exe1 W1 I$ ^! z9 y) }2 t0 f
@call MakeLic.bat) s7 w8 F: l( Q' x, U5 c
@cls8 G3 ^$ X8 g y/ a* v# y/ i
@echo 导入注册表信息窗口请选择“Yes”+ I4 k; T4 F! Z/ ]9 N
@pause
P0 `7 J6 [7 o) E, ^! S! F$ X0 R@regedit Environment.reg7 h9 Q" a( I. J3 @+ S- A
@cls
* p8 ?* d. r& ~! o+ f@echo 如果没有成功,请自设环境变量,MGLS_LICENSE_FILE=
# ?% E- Z( t4 k, }! v@echo C:\MentorGraphics\2007.4PADS\licensefile.dat
8 r. }% I3 ] f$ p P: n, c@echo 然后运行 「开始」菜单\程序\Mentor Graphics SDD\*- I6 Z2 @0 v- Q
@echo Licensing Tools\Install License.lnk4 O: q( U# b) Z( u2 E! y. B
@echo 设置LICENSE文件为你的"licensefile.dat"+ B; A$ U7 t: q) X
@echo ~~祝你好运!~~/ O1 E, B2 U6 j
PAUSE" `# R1 T i* G
+ U: M# `$ g3 G8 _ P8 ^我修改成了9.0PADS,但是也不成功,不知道为什么呢,楼上的朋友说是地址不完全相同,那么能否麻烦列一个地址呢,谢谢 |
