查看: 1568|回复: 5
求助!!开关电源仿真出错怎么解决!!
发表于 2019-6-19 11:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
9 c0 L& D* F2 [- ]6 K; k**** 06/19/19 11:44:29 ****** Pspice 17.2.0 (March 2016) ****** ID# 0 ********: p4 q" o% r7 [# n6 u
** Profile: "TRANsient Analysis-TRAN Flyback"  [ c:\users\administrator\desktop\pspice仿真实例\2\ncp1216-pspicefiles\transient analy' @/ ]1 [  z# {7 k, e( S" m2 y
0 k! A8 J6 t/ x& }# a- U% ]
****     CIRCUIT DESCRIPTION( ^) d' v7 @* x# |  u
3 b% O' K% O! x2 n
******************************************************************************( ~5 U3 C! c$ f6 P8 G
6 t) ^) Q, }7 v$ u1 X
+ R! D, j! v- v. D0 C6 u/ T" c$ S: M
** Creating circuit file "TRAN Flyback.cir" $ `9 w1 F/ }% T$ \" _
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
: n+ D( m8 g0 F1 B  v; i. o. O8 ^*Libraries:
3 j6 i# J$ @" J; B9 A4 P* Profile Libraries :8 A2 |! u, M8 [3 K, _+ f
* Local Libraries :
7 u) V- o% G3 x+ \! Q.LIB "c:/users/administrator/desktop/pspice/application.lib" . g$ r8 G/ V- t* v( H
/ _/ j$ s1 ^3 O- }" S  `ERROR(ORPSIM-16276): Can't find library
6 n  m( k: Q. U0 I0 X.LIB "../../../ncp1216-pspicefiles/ncp1216.lib" # ~0 k" w; m7 t/ c% n2 ?; l6 ^1 p3 E
* From [PSPICE NETLIST] section of C:\cadence\SPB_Data\cdssetup\orcad_PSpice\17.2.0\PSpice.ini file:
, u( W) [. o; l% j( @2 u! |/ K.lib "nom.lib" 3 p8 p0 t. G) {: }( Q0 n; M1 d) I
*Analysis directives:
* U( k1 H9 b4 `) A.TRAN  0 2m 0 100n SKIPBP
. |" L9 U) u1 L; r5 Y3 O6 L; h.OPTIONS ADVCONV2 w" ~6 S) u9 u1 s! l
.OPTIONS ABSTOL= 1.0n
+ @8 K: g( p, \' o.OPTIONS GMIN= 100p
  F2 w* R- Y% [% E8 D( l0 p.OPTIONS ITL1= 100+ N6 J" d  c( e1 x+ e3 ^
.OPTIONS ITL4= 150
' E; `  d. _. n! [& C9 ]5 h6 w.OPTIONS RELTOL= 0.01$ O* {7 t- n% J4 v; G1 ~2 v
.OPTIONS VNTOL= 1.0m
6 I+ y. v5 c0 m0 n, Y7 [2 S.PROBE64 V(alias(*)) I(alias(*))
( M3 l# a& D& l! v* ^.INC "..\TRANsient Analysis.net" + g5 U( C5 `; V- J1 Y
: u# U  w% l4 I4 l& Q
**** INCLUDING "TRANsient Analysis.net" ****# E+ ?5 s& r$ _+ D, b
* source NCP1216" W3 G' O% L  E1 \
R_RESR1         N74887 VINT  60m
3 J" A9 _4 }; c, Q2 I2 q& _( eC_Cout1         N74887 0  3mF IC=16.5
" g& O3 I$ Y5 _) g+ nL_Lout         N75019 VINT  2.2u
  ~  T; \& h: eR_Rseries         OUT N75019  10m
  H/ O6 p/ M5 `3 {# a! C2 u) dX_U12         N75043 0 N75035 TL431
; D# F# D$ G/ G" \8 \# _2 kR_Rlower         0 N75035  6.8k
8 \$ q' v3 V7 Z" W0 WC_Cf         N75043 N75035  100nF IC=13.3
/ y$ @& y5 E' e: q* Q) j$ HR_Rupper         N75035 OUT  39k  * F2 e  ]% |) V& {6 H5 o
C_CVcc         VCC N78817  22uF IC=13
/ a' p6 k+ x) X- Q& Q9 u* KC_Cfb         0 FB  10n
4 F  p" s) X+ H" p0 |* CR_Rclp         N75573 N75253  22k  . U0 \) U" I2 A- A8 B5 T* s8 \! U
C_Cclp         N75573 N75253  100n  ' g9 m, b* Z6 p+ Z; y, W+ a) P, H( `
R_R9         N76327 VINT  1k
( q4 k% A& X" G+ n& H, VX_U5         N76327 N75043 FB 0 MOC8101
. _$ G1 ]3 l# ]$ T  RV_Vinput         N75253 0 120
4 R. T8 i  G7 C  b1 T. z/ H7 kR_RESR2         N75613 OUT  150m
: K% \+ t" z- H' O9 V" {R_Rload         0 OUT  4  1 c- q% y& p/ i& l* Q1 ^
R_Rsense         SENSE 0  0.28  . I5 _$ Z% G- a) C& n" M. c! D) f
C_Cout2         N75613 0  470u IC=16.5
' e$ ?3 T" s% v2 s. q1 o7 O% UL_Lleak         DRAIN N76053  6u  & I2 n; {3 A. }% s0 k$ P
L_Lp         N75583 N76053  770u  + m8 u3 l, n& e! W9 o' V
D_D4         DRAIN N75573 MUR160
+ m% g7 x: N* O  kD_D1         N75653 VINT MBR20100CT
6 R; C7 G! o/ ^2 }R_RP1         N75583 N75253  200m
1 p. }7 k# ~8 Q7 OX_X2         DRAIN GATE SENSE MTP6N60m
# W. M4 s5 D9 }/ U, _: W- MR_Rramp         SENSE N75201  1k
* F% @$ s1 h5 e8 u, w" h# ~/ dC_Cleb         0 N75201  100p  , {- u/ s0 K' j) Q$ ^5 J
R_Rtlbias         N75043 N76327  4.7k
4 s) B5 D! I: o8 F( o. @X_U1         N75583 N76053 N75653 0 XFMR1 PARAMS:  RATIO=-0.166
! n9 h: g" }. c8 a8 `' ?R_ResrVcc         N78817 0  250m  % A1 e  a6 K6 E3 q. v# c
X_U9         SKIP FB N75201 0 GATE VCC N75253 NCP1216P065- E" \% X8 m& Q
**** RESUMING "TRAN Flyback.cir" ****1 E2 D5 K1 \; T9 J; E
.END: k7 Y: M0 x) n9 _0 c
' N5 f, p, ~# ?  c8 y$ K
$ d9 C7 L6 r" ]
 楼主| 发表于 2019-6-19 18:21 | 只看该作者
论坛没有人吗:L
GMT+8, 2025-6-26 09:07 , Processed in 0.093750 second(s), 26 queries , Gzip On.
