查看: 2622|回复: 1
菜鸟提问
发表于 2009-5-23 21:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问以下的WARNING是什么意思啊
. R" Y: {$ H( Q5 ]! q8 D/ T' {2 u- y/ Q7 c$ k# J3 z! r& F! f' y# W
2 c8 u( S! x; w7 }6 M2 }**warning** the following singular supplies were terminated to 1 meg resistor " A& J: y  I8 ~# V
   supply       node1            node2
7 w5 z. ~  r7 m# ]5 F  v1                      0:vcc              defined in subckt 0                     0:0                defined in subckt 0               ) e* d  J# h! R' d$ t
  v2                      0:vss              defined in subckt 0                     0:0                defined in subckt 0               9 d- u/ E: j  V7 z
  v8                      0:x15              defined in subckt 0                     0:0                defined in subckt 0               0 J+ j, W9 [7 u. ?
  v5                      0:y11              defined in subckt 0                     0:0                defined in subckt 0
% Z1 u- N6 b8 r# o; a5 S1 K) M  v6                      0:y12              defined in subckt 0                     0:0                defined in subckt 0               : s& Q0 I$ r% k$ W, L
  v3                      0:y5               defined in subckt 0                     0:0                defined in subckt 0
9 R* v: u) D% C+ H: S  v4                      0:y6               defined in subckt 0                     0:0                defined in subckt 0               0 {  s7 z+ A* M- q) Y
  v7                      0:z0               defined in subckt 0                     0:0                defined in subckt 0
发表于 2009-6-7 07:16 | 只看该作者
能否把你的图贴一下
GMT+8, 2025-8-24 11:31 , Processed in 0.109375 second(s), 24 queries , Gzip On.
