TA的每日心情 | 擦汗 2020-1-14 15:59 |
签到天数: 1 天 [LV.1]初来乍到
siwave里面进行安全检查的时候第一项的错误!导致不能仿真!如何解决?
- I5 H6 G8 w; w* S% F8 K; \1 f1 Y3 V6 e `/ O( w% P! r0 y" }7 n3 p
6 b& \+ j% \% S1 d/ G# t
Detected: net "AGND" has a plane which self-intersects on the layer Top.- v' U" M- h+ n* r# M
Detected: net "AGND" has a plane which self-intersects on the layer Top." Q7 @( f; ~* V, `
Detected: net "AGND" has a plane with a void which self-intersects on the layer Top.# g! j* V$ k2 v+ z9 q
1 r; ]- p" g1 T2 G1 nDetected: net "AGND" has a plane with a void which self-intersects on the layer Top.
: D* n t4 L5 @( iDetected: net "AGND" has a plane which self-intersects on the layer Top.
; S/ D( ^& \' b9 `1 ~9 SDetected: net "AGND" has a plane which self-intersects on the layer Top.% c( V& e; W& n# K
' q: Q1 P, L- c1 fDetected: net "AGND" has a plane which self-intersects on the layer Top.
% |' o2 t0 O) J7 d2 N/ o! JDetected: net "AGND" has a plane which self-intersects on the layer Top.
) K$ d; Q/ [. }( X/ oDetected: net "AGND" has a plane which self-intersects on the layer Top.
/ I; q* a9 K# \; A- GDetected: net "AGND" has a plane which self-intersects on the layer Top.
& r$ x; W+ s6 p2 yDetected: net "AGND" has a plane with a void which self-intersects on the layer Top.. t5 ]0 Z, Y+ n5 ^' o
7 j& Z! x" n9 ~3 l6 V5 S: eDetected: net "AGND" has a plane with a void which self-intersects on the layer Top.
+ [& S/ @' k( g9 Z7 n/ YDetected: net "AGND" has a plane which self-intersects on the layer Bottom.# j: s) t3 s+ X. l3 G% y6 S' G
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
+ d p+ J/ h r! c1 j5 aDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
% L0 P( s( L# t; i% fDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
( k z1 G% k& R. w; }Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom./ \3 Y( S }# g& V
+ {7 r* b8 o0 u3 |Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
4 k' B' n( F# m( O1 DDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
- h. ], W4 G) ~5 c4 mDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.9 h2 p: O# A# _$ F' D
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.; z; A. U i3 y4 x$ [
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.1 A2 E7 |) p3 `# a! _, d
' {) u# y; h- L# g. r' B' }+ FDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
9 a! p7 w/ L; t& @8 NDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
5 S6 B v, @. {/ H. w1 y; M sDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.( L# s" H, a5 m
, t* l' I/ y) A4 O5 n7 y7 c2 ]8 uDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom." r* e2 b7 \" m! j
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.& {2 _# @" q$ ~: g7 w) I
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.' Y- Z9 g! I$ C P0 x2 Z
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.% L f" E; x5 Q$ F/ {$ v& ^
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.7 z6 W6 v, H$ o
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom./ Q% ]( ?3 u" h! f! X+ g8 g, t% g
- `! K s6 K/ v" ^Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
! W# l) ]/ l4 u$ CDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.) F q5 s8 x6 }
8 \- x. V- `% h: X+ L8 vDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
3 S- d; ]" m4 NDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.% @% F* b8 ^( p+ w( H+ R+ N; r
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.0 j% N5 Q' E& B5 O
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.# f! U8 X! |- D: W+ A1 X1 B
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.0 t& u* Q( p! _7 Z4 |, Y6 w8 q
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.+ }/ a8 J9 B# }
1 X- t+ z: W8 `* e2 VDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.8 j3 O' r. B: S: U+ t# ~
! k8 f- h. c2 W; Y9 TDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.1 m5 T5 @/ @) R2 p
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.) w! {( n- Z! o+ ?* O4 p
, V: O/ L, w1 v% dDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
4 `/ \+ y+ k6 F. X& ^Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.( P8 n- J% e. q. j
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom., `* q8 r8 L# [! h5 p% R( J
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.+ q" Y' a2 K- t9 {# o0 k
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.* X- J9 O" N: E D- c b
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.6 a0 K8 {* p1 h
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.0 u2 f! P( |5 {) C# }
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom." B ^- A$ |# a! h
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom./ o$ t$ Y4 H$ T
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom." ~9 e7 ?0 _* ?5 o" g
- K$ q, @) }% eDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
: o+ ]# M, U5 ^! c) Y! k% ZDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
7 L8 p7 j* U, j: U. y& P1 z: sDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.7 r, _3 x0 Z" `0 ^: n4 I! P- [/ f
; q- y' f2 d7 R! }1 y) oDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.+ K/ U% ]1 L8 ^( W* N/ S6 h
6 X6 Q, P% u$ k- t$ wDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
E7 C1 Z' [! u" a% L0 ^Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
]) l6 `: q/ v" ] HDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.3 ?* {- |( r+ G( f! [+ ^4 a
5 X6 i+ x6 W: ADetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
: n4 {6 v9 K* B) g! VDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.9 q. x) h# X: Y
0 _, [/ w+ \! r! s yDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
; M/ U2 w; A7 t- z& lDetected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.; D! r( _5 N& C+ G* h
Detected: net "+5V_SW" has a plane which self-intersects on the layer VCC.
P, ~7 u/ J0 S3 e) g0 QDetected: net "+5V_SW" has a plane which self-intersects on the layer VCC.
! r7 @, l* a) ^- hDetected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.
# y: X0 A R6 W% y @, o5 k/ i% n" KDetected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.! a: C3 e5 R+ O: K/ Y
' l8 E. K6 e+ x8 IDetected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.
8 x( j. J( [4 z% E; [5 }& IDetected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.) i8 F# `! Z" _; x! H' d! a, w
Detected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.6 V2 N2 H2 w, _% _
) [: K Q! g4 u6 F J1 x- `Detected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.2 W0 P' l3 j' u! h% ~
Detected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.0 }! H; ?9 ^9 L) ]4 `9 o. p
4 C* a9 j+ o! G, o8 N2 F# qDetected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.
# ?8 J! n! o9 ]1 V4 {$ a2 W2 ^Detected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC. M! h3 j4 `- N& V4 u; ?/ m
Detected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.2 s& u' T8 G7 K$ G
; @/ j8 [' F, [Detected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.) [4 C. B# D: b U: e* V$ |
; Z! V8 x5 j5 NDetected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.
" D- A# [" D5 \! |4 {Detected: net "+5V_SW" has a plane with a void which self-intersects on the layer VCC.
" a% C' E& | f' E3 ]7 m5 n& JDetected: net "+12V" has a plane which self-intersects on the layer Top.
* H2 H" N9 ]" z7 V& {$ }, l6 FDetected: net "+12V" has a plane which self-intersects on the layer Top.
' t: i4 L/ [( a/ JDetected: net "+12V" has a plane which self-intersects on the layer VCC.
2 S7 v8 g% F! A* \- J8 s, aDetected: net "+12V" has a plane which self-intersects on the layer VCC.
2 ]+ J% l. i6 @4 r6 ^# yDetected: net "+12V" has a plane with a void which self-intersects on the layer VCC.2 j3 u- c' z5 X) D
Detected: net "+12V" has a plane with a void which self-intersects on the layer VCC.9 P9 l8 \) U$ p' j0 E8 z$ U# r
Detected: net "+12V" has a plane with a void which self-intersects on the layer VCC.( ~" R$ z' f' O! O$ [$ ^+ q
# ]2 t' ^' H3 @3 SDetected: net "+12V" has a plane with a void which self-intersects on the layer VCC.
4 Q6 B6 i5 f$ P0 Y* S8 s5 O3 i) q8 {Detected: net "+12V" has a plane with a void which self-intersects on the layer VCC.' L. [' j, q) z2 V4 V2 M
Detected: net "+12V" has a plane with a void which self-intersects on the layer VCC.& j5 P1 ~0 |1 Y3 D
2 K! I, R/ F; d: kDetected: net "FGND" has a plane which self-intersects on the layer GND.
2 `. m( r3 l, }# rDetected: net "LOUTN" has a plane which self-intersects on the layer Top.
3 u) }9 F1 Q4 NDetected: net "+12V_AMP" has a plane which self-intersects on the layer Top.
7 q' I, T. P% @# pDetected: net "+12V_AMP" has a plane which self-intersects on the layer Top.; {' e3 i! j6 _
Detected: net "+12V_AMP" has a plane which self-intersects on the layer VCC.
: U* B/ P+ t& `& P( e5 [, NDetected: net "+12V_AMP" has a plane with a void which self-intersects on the layer VCC.3 a% Q5 P. k {9 G( X' U
5 Q. K7 b# Z5 ?) _2 B) r- M3 ?7 D3 QDetected: net "+12V_AMP" has a plane with a void which self-intersects on the layer VCC." h5 C) ^( `- I5 x; t9 U
' y9 a1 D) @; ~' c W6 ODetected: net "$$$177" has a plane which self-intersects on the layer Top.1 k( m5 ]7 I' E- ~: b
Detected: net "$$$154" has a plane which self-intersects on the layer Top.
1 {. l) K* X; ]Detected: net "ROUTN" has a plane which self-intersects on the layer Top.
/ q+ ?4 m; T) b! ], T6 L$ lDetected: net "$$$155" has a plane which self-intersects on the layer Top.: p$ @5 h# B# H; p! E! V
Detected: net "$$$185" has a plane which self-intersects on the layer Top.7 P8 w- M" O4 F
Detected: net "$$$21401" has a plane which self-intersects on the layer VCC |
