楼主: yangquan3
cadence 17.20最新补丁Hotfix_SPB17.20.055_wint_1of1.exe
17#
发表于 2019-5-30 06:39 | 只看该作者
+ @$ [/ `  ]2 K, U  {: U- B& k2 [# `& T9 L
Fixed CCRs: SPB 17.2 HF055
6 \" O& S# T$ P; d: [05-24-20194 G2 Q4 z. g: \" Q  h' x
========================================================================================================================================================. |% A. K4 j# A, P0 ~
CCRID   Product            ProductLevel2 Title  m* t! [5 ~* M6 L) F+ \7 s/ B
========================================================================================================================================================( k# j: l8 d3 W* Q0 ?+ o0 @6 J
2078057 ADW                PART_BROWSER  Symbol Graphics preview is not available in the Designer Server$ e8 f7 u5 {5 r" H& p3 i
2092863 ADW                PART_BROWSER  Component Browser is not displaying the symbol & footprint preview" [" ?( H# f- w1 [( I
2076339 ALLEGRO_EDITOR     3D_CANVAS     Floating parts on bending a board in 3D Canvas with HotFix 053, N/ R" F4 x( B: k- `0 d
2051075 ALLEGRO_EDITOR     ARTWORK       Incorrect Gerber import in Allegro PCB Editor, J  a3 ]3 ]4 n, r# R0 X
2073407 ALLEGRO_EDITOR     DATABASE      axlDeleteByLayer deletes fixed shapes* x8 t1 `7 q. w: i: ~2 [. \
2079117 ALLEGRO_EDITOR     DATABASE      Release 17.2-2016: Board file saved in HotFix 049 cannot be opened in HotFix 014
% K" g2 L( X; q( ?4 |/ s6 O2079204 ALLEGRO_EDITOR     DFM           Enabling option to update analysis mode and run DesignTrue DFM wizard causes PCB Editor to exit3 ~+ i# o  R4 h( U% H4 h- H
2082394 ALLEGRO_EDITOR     DRAFTING      Angular dimension not owned by the same parent symbol in the layout are not deleted on moving object
  O. t# V2 M  \2067916 ALLEGRO_EDITOR     INTERACTIV    Place replicate module bounding box does not move with circuit after module is updated
0 `  I' Q2 y2 d9 a8 D) O2068449 ALLEGRO_EDITOR     MANUFACT      Stackup chart and table shift slightly from original location on re-generation in Allegro PCB Editor release 17.2-2016
) @# C% H8 y1 b2 P8 N* {! l6 X2065820 ALLEGRO_EDITOR     MCAD_COLLAB   Selected objects deleted from the design on clicking Cancel in IDX Flow Manager Import
0 m; Y8 ~$ g+ O! i4 m' ~2080164 ALLEGRO_EDITOR     MCAD_COLLAB   IDX outputs two sets of masks" z' |2 M' I* H6 p# e, ?
2081955 ALLEGRO_EDITOR     NC            Artwork file error for via size) _, g4 w1 c4 m& q' w; ~* Q7 o+ v
2045061 ALLEGRO_EDITOR     PLACEMENT     Setting PSMPATH: axlSetVariableFile() does not update Place Manual but User Preference Editor does
* j( l% D" W0 W3 J# ]2049949 ALLEGRO_EDITOR     PLACEMENT     Get import errors and cannot place some parts if user-defined option is turned on for netlist import
# _( x6 B0 Z6 z0 B2069289 ALLEGRO_EDITOR     PLACEMENT     Cannot place part because attribute definitions are incompatible for the 'DESCRIPTION' attribute (SPMHDB-154)
9 ]% z* p  `( n9 l! S- Y: S" X- `2056573 ALLEGRO_EDITOR     SCHEM_FTB     Import Logic takes a long time when checks are turned on
' X0 G# c7 S" z2 ^4 n9 y4 u: d2076452 ALLEGRO_EDITOR     SHAPE         Shape Degassing crashes if 'Inside Shape' is selected
6 A8 I2 A6 Y1 E, D5 y5 h+ f4 _$ D( v2076873 ALLEGRO_EDITOR     SHAPE         Symbol Editor stops responding on editing shape with a .dra file5 u: f4 r  G! G9 M
1788703 ALLEGRO_EDITOR     SKILL         axlPadSuppressSet does not work when 'none' switch is used
6 M# |9 p5 L, a# A9 q  n2 e1 @1955127 ALLEGRO_EDITOR     SKILL         axlPadSuppressSet( 'off 'none ) returns a warning message and does not work per the documentation
' S+ Q8 {- E9 A# |2031711 ALLEGRO_EDITOR     SKILL         Syntax error related to allegro.ini shown if allegro.ilinit loads INI on startup
& ^+ e2 E" a' ~5 T. F+ \2 X2062527 ALLEGRO_EDITOR     SRM           RF elements are shown in Symbol Revision Manager
# r  J, K1 @# G/ p; h$ p2074249 ALLEGRO_EDITOR     TESTPREP      Testprep re-sequence causes PCB Editor to crash if 'Labels with Net Name' is selected" U4 v9 d0 T. F  k
2070534 ALLEGRO_PROD_TOOLB CORE          Productivity Toolbox bar code generator is creating corrupted shapes in the database
# q& _" H7 L- V2046278 ALTM_TRANSLATOR    CAPTURE       Third-party import fails' H/ L% H2 v& [# [8 p7 l
2052399 ALTM_TRANSLATOR    CAPTURE       Third-party CAD translation stopped with error message
# t6 s! E, n: |7 J# S7 S% X/ }* A2005087 ALTM_TRANSLATOR    DE_HDL        Cannot translate third-party to Allegro Design Entry HDL
& i- ~8 d' N* P4 @9 V; ?% _3 U1922222 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translation converts to board with unconnected nets$ A! n& f) L5 B+ x" y
1987263 ALTM_TRANSLATOR    PCB_EDITOR    Third-party board file: copper not imported( z' ?: S7 `3 a$ h
2017988 ALTM_TRANSLATOR    PCB_EDITOR    Third-party to Allegro PCB Editor import issues with routes, constraints, size, and accuracy+ F* W& D  p/ _5 }9 f3 f
2021300 ALTM_TRANSLATOR    PCB_EDITOR    Third-party translator does not show any results on PCB Editor canvas
7 x( `3 \" G; J3 N5 t  u( n1890675 APD                DIE_EDITOR    Mirror Geometry is Mirroring the symbol from TOP to BOTTOM Layer in SIP file1 g( d: q( K8 @# l: |, D( u7 N
2064219 APD                DIE_EDITOR    Applying mirror geometry results in mirroring: moved from TOP to BOTTOM layer! w& X3 P# |0 Y3 {6 y
2086574 APD                OTHER         Duplicate layer text shown on the vias9 Q) i# ]$ h! M5 z4 t( P
1948169 CIS                CONFIGURATION Auto Symbol Refresh Checking not working for shared folders7 h2 P0 O" p/ _" V% R; {5 A
2025385 CONCEPT_HDL        CORE          Hierarchy Viewer expands/collapses randomly after clicking the '+' or '-' symbols; z4 Q& b, r- [2 ]  l9 d* i
2050010 CONCEPT_HDL        CORE          Copyproject does not properly copy the variant files
2 y' e% {- v* G1 {+ z: U6 D: t2063457 CONCEPT_HDL        CORE          DE-HDL: very slow rendering on some systems
$ H& h9 }. Y! i. }, o  M! \6 e2076312 CONCEPT_HDL        CORE          Getting 'Variant out of sync' warning when creating BOM for a design with no variants0 Y# X+ [, \: o7 g* Q) K$ G( v" m
2083650 CONCEPT_HDL        CORE          Lower-level signals are appended with _1, _2, and so on5 Q4 j& c% F5 m* ~" l1 b# c
2083651 CONCEPT_HDL        CORE          The physical net names still do not sync with the assigned signal name
; u4 x! x2 x0 K2056736 CONCEPT_HDL        GLOBALCHANGE  Global Property Delete does not operate on the entire design unless the top-level page 1 is open6 ?8 W1 d' F4 e  D0 H' f- H( ^1 G  t
1955357 SIG_EXPLORER       OTHER         Signal explorer invocation with OrCAD PCB Expert Suite license
7 r( s  x" s0 \! O: i3 |2 b2079071 SIP_LAYOUT         SYMB_EDIT_APP Response very slow after Show IC Details on a very large co-design die! e$ c$ E! S4 N: U# \6 y+ G# S
2081884 SYSTEM_CAPTURE     CANVAS_EDIT   Symbols take a long time to move, and results in DRCs and broken connections
# U6 V  _7 \7 U: J# ^1942542 SYSTEM_CAPTURE     IMPORT_PCB    System Capture - TDO backannotation overwrites net names with stale data in lower-level blocks# y0 _- ]3 s9 F# ~
2071303 SYSTEM_CAPTURE     MISCELLANEOUS cds.lib file is picked up from wrong location7 Z7 v& x* s" l
2058979 SYSTEM_CAPTURE     OPEN_CLOSE_PR System Capture prevents a project from opening by putting a single quote at the end of a line in CPM file! S2 \4 j; c3 |
2088210 SYSTEM_CAPTURE     OPEN_CLOSE_PR The 'enable pspice' entry in CPM file is occasionally corrupted
$ j+ \6 o3 A$ K
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    19#
    发表于 2019-5-30 08:27 | 只看该作者
    樓主大大,這是一定要的啦!!!6 |. ?9 ]. k+ v/ u' a: B; t. ?
    謝謝囉!!
    * v2 T6 ], u3 b7 T1 D
    2025-11-3 15:00
  • 签到天数: 723 天
    [LV.9]以坛为家II
    20#
    发表于 2019-5-30 08:31 | 只看该作者
    of course need.
    2025-11-3 15:55
  • 签到天数: 1075 天
    [LV.10]以坛为家III
    21#
    发表于 2019-5-30 08:52 | 只看该作者
    那是必须要下载升级的!, }' b5 h( G1 E) K( k3 c& {$ a1 s, i: \1 s
    2019-11-20 15:05
    22#
    发表于 2019-5-30 08:53 | 只看该作者
    没看到链接啊
    23#
    发表于 2019-5-30 09:01 | 只看该作者
    感谢分享啊
    24#
    发表于 2019-5-30 09:23 | 只看该作者
    这……2 U0 G5 |3 X9 C2 S6 |
    还用征求意见?
    25#
    发表于 2019-5-30 09:35 | 只看该作者
    非常需要的. 非常感谢分享.
    28#
    发表于 2019-5-30 11:00 | 只看该作者
    当然放上来啊
    GMT+8, 2025-11-4 23:18 , Processed in 0.156250 second(s), 19 queries , Gzip On.
