查看: 15484|回复: 16
求助ERROR -- Convergence problem in transient bias point calculation
发表于 2008-3-4 15:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* g. k" h% l% E2 H
1 c, @& Z! \: `0 H
+ \) u4 x) T% X5 R  Last node voltages tried were:' H2 s: Q2 ?! `+ I+ i9 P
. X+ `6 n; w$ H- P# E
NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE% Y' k( D- s6 I
/ O/ J, j7 x6 l
# d6 P7 C7 i5 @; t+ ?4 q
(  VCC)    1.3324  (PULSE)    1.7343  (DRIVER)   99.5060 (N00297)     .5884
2 O( A. k4 p+ c* H
  H# V7 i* E( e+ ~' [2 J* o: W(N00399)   15.9890 (N01146)    6.5762 (N01335)    6.2369 (N02038)   10.2950     ( E9 `! ~8 y; w
- w1 J* g6 J) B7 U- |% B
(N02317)   10.2340 (N03099)   12.7660 (N03134)   12.7360 (N04996)     .1681
4 Y" J& l# `3 k0 g
/ [: p$ u/ O$ W- @. Z2 E. C; x(N05104)     .1666 (N12141)     .5884 (N13250)    6.2369 (N17746)     .2665
  m' ~, W3 X' H" e8 i, [! P6 \6 B% ^8 l+ N- p
(N17862)     .2665 (N18766)    1.7343 (N19382)    5.3890 (N19798)    5.3890     9 ^5 N$ |' c0 j; ^1 C
" M9 ~6 ?/ X4 T
(N20442)    5.3890 (N20665)     .2665 (N21136)     .2667 (N21824)    -.6273     5 D5 E4 G* @9 n& U' G3 z, @
+ K) Q, S0 {' _3 @1 K7 T$ L1 A& p% G
(X_Q1.4)   10.3070 (X_U2A.x_lm358.6)    -.1045                                  4 Q% a/ q  W. s2 J9 Q
6 J7 H! z9 H- J! g, Y4 ?
(X_U2A.x_lm358.7)    2.3393           (X_U2A.x_lm358.8)    2.3393               4 W5 f- P2 p" [4 R$ K- v
$ v6 i8 i4 r. X9 v/ |" o4 }) G(X_U2A.x_lm358.9)    0.0000           (X_U2A.x_lm358.a)    1.3292
9 J" U" d/ B0 A* b( {, u% l
0 m* m; z2 g  m1 a% U$ r(X_U2A.x_lm358.b)    -.0032           (X_U2B.x_lm358.6)    -.1041
$ g+ c. V: [6 p9 y3 R- J, L% o, ~- o& C$ l' P9 N8 O% r
(X_U2B.x_lm358.7)    6.4426           (X_U2B.x_lm358.8)    6.4426
2 f0 X* L- w4 y& F6 Y0 k& g  x1 [# W) _% F3 H! I
(X_U2B.x_lm358.9)    0.0000           (X_U2B.x_lm358.a)-10.00E+09
" d/ h1 a+ s' n4 \. ^/ a1 D0 G- [: o8 m/ f0 I) l2 Y3 T) [, N# z
(X_U2B.x_lm358.b) 10.00E+09           (X_U3B.x_lm358.6)    -.1041
) F- N" e4 W; ]+ F+ m; R/ K; e& p. [' K' T! r  [
(X_U3B.x_lm358.7)   -2.7493           (X_U3B.x_lm358.8)   -2.7493
2 a8 w" ]: N" X) i0 O! }( X6 j+ E3 s, K# v/ a
(X_U3B.x_lm358.9)    0.0000           (X_U3B.x_lm358.a) 10.00E+09               + C7 `, Z0 c6 O- g
  y3 k+ e0 ^4 e5 X(X_U3B.x_lm358.b) 10.00E+09           (X_U2A.x_lm358.10)     .7528
/ j8 g/ d* S, ]# u' I5 e3 j' j) H0 f% A
(X_U2A.x_lm358.11)     .0210          (X_U2A.x_lm358.12) 9.565E-09
9 R, H- ^- B! g$ f+ `' x' `: a$ i
' j  K/ z3 G& A& {* i) S2 }(X_U2A.x_lm358.13)     .7455          (X_U2A.x_lm358.14)     .7528              ! C* z, `; d/ t! P
) V) i! e) I. u+ K1 a+ q
(X_U2A.x_lm358.53)     .9327          (X_U2A.x_lm358.54)     .2190
5 Q& K% [) D( ]1 L! G
" b7 V/ G$ k( }8 i0 y# Y(X_U2A.x_lm358.90)    3.2243          (X_U2A.x_lm358.91)   10.6590
) b$ h- s7 D- Z; S' b2 X$ [" g8 Y5 k- ~+ ?9 ~9 M3 q
(X_U2A.x_lm358.92)  -10.6590          (X_U2A.x_lm358.99)     .1775              9 q% l2 n! t3 Q" R: Q
5 O0 Z# Q+ P: |+ b4 n( q: K. w
(X_U2B.x_lm358.10)     .8512          (X_U2B.x_lm358.11)     .0209              * y: j0 C2 S- ~2 K9 ?- `$ d
# Y: V$ B7 ~- r- b- m
(X_U2B.x_lm358.12) 13.72E-09          (X_U2B.x_lm358.13)     .8438              3 Z- q) O9 z7 w! m# v
5 C. M6 @: s$ ?2 p% t( K6 ?
(X_U2B.x_lm358.14)     .8512          (X_U2B.x_lm358.53)     .9327              2 O' M0 q* Z; i
0 E1 t7 a- a" E0 ^. m
(X_U2B.x_lm358.54)     .2190          (X_U2B.x_lm358.90)    5.6148
6 Z" t( k; c9 J, X. X, {2 B
7 g9 F7 R- {* ?# g: R(X_U2B.x_lm358.91)   10.6590          (X_U2B.x_lm358.92)  -10.6590              0 ]6 O; C& ~/ K( Y. T
  p2 o+ V4 b: r, ^
(X_U2B.x_lm358.99)     .1775          (X_U3B.x_lm358.10)     .8513
& t% b$ K" S# \$ U# D2 X
' B" v% Z  H) l5 `& Q4 {(X_U3B.x_lm358.11)     .0209          (X_U3B.x_lm358.12) 33.11E-09              ! x2 j& e& \9 t9 `3 P3 Z
- O) Z1 ?8 g" j6 u. j
(X_U3B.x_lm358.13)     .8440          (X_U3B.x_lm358.14)     .8513              ( W8 O/ Z& @7 @9 Y1 R
( `# {- H6 b# g; z* D(X_U3B.x_lm358.53)     .9327          (X_U3B.x_lm358.54)     .2190
+ i7 Q1 ?7 _4 d7 v
6 X0 F  v/ g1 r2 W% ~(X_U3B.x_lm358.90)  -11.3090          (X_U3B.x_lm358.91)   10.6590
) o% [- ^8 [$ _# \: ]/ ]. W$ ~# ]8 q# N( _( }- }% ~
(X_U3B.x_lm358.92)  -10.6590          (X_U3B.x_lm358.99)     .1775
8 U7 v/ X- [. j! G& p! e- S
1 [9 R. ~: Q( b" Y) m
( w" l/ ^% h) c6 n' c0 `5 I  These voltages failed to converge:
! Y: E; l. L9 {
, O  K/ O. [/ h( P8 w) X    V(DRIVER)                 =     99.23V  \     99.51V: O, `8 C; J5 D+ `, F
    V(N19382)                 =     1.733V  \     5.389V! c9 Y: J  O( G( R/ l
    V(N19798)                 =     1.733V  \     5.389V
4 V6 g7 ^2 p/ _: U; s2 N    V(N13250)                 =     6.131V  \     6.237V
# T3 y& l! S- ^/ F% D! H    V(N01335)                 =     6.131V  \     6.237V
( B1 E1 c! e, j" E    V(N21824)                 =  -638.23mV  \  -627.33mV2 N" h, f" u* ]6 F  d0 P) D: {
    V(N00297)                 =   578.36mV  \   588.38mV9 ]+ c' j( {* h" [/ Q8 |8 a  S6 q
    V(N20442)                 =     1.733V  \     5.389V
! Z+ }7 Q4 F' }    V(N03099)                 =    -13.45V  \     12.77V
# U) k" k- q  i2 A    V(N02317)                 =     10.13V  \     10.23V3 ^# E+ z+ w2 h# v( `2 p( V6 Y, I2 x+ H
    V(N03134)                 =    -13.17V  \     12.74V
6 t2 h' w$ r; l. j+ ?; k: [5 k    V(N12141)                 =   578.36mV  \   588.38mV
% `) L2 l3 @2 ~( b4 \    V(N02038)                 =      9.56V  \     10.30V
( H* b* K. @2 ]& M, x  [9 t* Y4 \    V(N01146)                 =     6.721V  \     6.576V
  m1 z/ U9 y) Z- D" R9 {: d    V(X_Q1.4)                 =     9.449V  \     10.31V- Q/ E, L6 B+ p1 u
    V(X_U3B.x_lm358.7)        =    -2.755V  \    -2.749V
9 Z: Y( |+ \, D- d, h    V(X_U3B.x_lm358.90)       =    -11.28V  \    -11.31V8 J% ~- S1 `0 L) x! T
    V(X_U3B.x_lm358.a)        =    10.00GV  \    10.00GV& C) C6 L6 ^% N- V( s
    V(X_U3B.x_lm358.b)        =    10.00GV  \    10.00GV
& T' p* W+ F& H/ N    V(X_U3B.x_lm358.8)        =    -2.755V  \    -2.749V- {6 y& C+ F9 e, t, F1 i' N
    V(X_U2B.x_lm358.7)        =     2.813V  \     6.443V8 D8 A2 z2 |3 ~: J' W  S6 f
    V(X_U2B.x_lm358.90)       =     5.759V  \     5.615V: g' U+ g0 A1 U2 l% T! {1 i$ o$ \- h
    V(X_U2B.x_lm358.a)        =     1.327V  \   -10.00GV
6 U' N8 t& q& G    V(X_U2B.x_lm358.b)        =   -5.759mV  \    10.00GV
2 U0 t4 q) }, y: I5 T8 z    V(X_U2B.x_lm358.8)        =     2.813V  \     6.443V
+ V7 Y1 v- C/ S+ S    V(X_U2A.x_lm358.90)       =     3.232V  \     3.224V  P. X+ G; A! p* v
    V(X_U2A.x_lm358.b)        =   -3.232mV  \   -3.224mV
' H4 B7 N, i: c" a/ X; m# k! m6 q- y" s; n% n8 {+ `) W
  These supply currents failed to converge:) ?- n5 Y( q- K
7 F. l- [% O/ X) v1 A- }    I(X_U3B.x_lm358.egnd)     =    42.33mA  \    42.44mA1 k& _0 L+ Z) w8 j3 M+ N9 U6 ?4 A# V
    I(X_U2B.x_lm358.egnd)     =   -21.61mA  \   -21.07mA# c8 v" Z# b- h
    I(X_U2A.x_lm358.egnd)     =   -12.13mA  \   -12.10mA
+ W# n2 K8 C$ P; B5 l( `    I(L_L1)                   =    -1.851A  \    -1.883A
8 s; F, A) }# ]% y; b0 A% q% j9 N1 @/ C    I(V_V5)                   =   -2.828mA  \   303.48uA& d; \' W; i  I3 H/ I
    I(V_V1)                   =    -1.857A  \    -1.883A
; \  A4 g+ Z, j8 A! ^9 W3 e+ @    I(V_V4)                   =   -10.00GA  \   -10.00GA0 ^; Z% h/ F+ K$ O9 X8 E
    I(X_U3B.x_lm358.ve)       =  -184.16mA  \   -53.24mA! `8 \: E3 {6 n% A# q: F
    I(X_U3B.x_lm358.vlim)     =   -42.33mA  \   -42.44mA
$ W  L/ D0 u! M0 `4 p# J    I(X_U3B.x_lm358.vln)      =   -10.34uA  \   -3.797uA. \6 ~. M8 G7 M0 ~; S! B
    I(X_U2B.x_lm358.vc)       =   -21.61mA  \   -21.07mA
$ @, N. p7 n- B) o2 J4 y    I(X_U2B.x_lm358.ve)       =    1.505pA  \    5.162pA( g" i! b3 p! u5 S1 H! j& `
    I(X_U2B.x_lm358.vlim)     =    21.61mA  \    21.07mA6 C$ K/ r& Z( {( R6 g2 K& ~
    I(X_U2A.x_lm358.vlim)     =    12.13mA  \    12.10mA
1 P! }  L+ t. T  O5 v4 x' j    I(X_U3B.x_lm358.hlim)     =   -10.34uA  \   -3.796uA
& N: W+ C1 _. H% M3 A2 F. K. H5 E; Y
  These devices failed to converge:
  u3 R( r+ W, W! ~    D_D3      D_D1      X_Q1.D1   X_U3B.x_lm358.de X_U3B.x_lm358.dln $ W: W' U1 ^' v7 y9 f
    X_U2A.x_lm358.dc X_U2B.x_lm358.fb M_M1      Q_Q2      X_Q1.Q1   X_Q1.Q2   0 `, G/ U) ?$ ]" d0 G
, }* c2 g) y- y1 J- t- x**** Interrupt ****
推荐
发表于 2014-5-21 08:58 | 只看该作者
** INCLUDING SCHEMATIC1.net ****# U5 @) p0 k& H4 c" |+ K
* source 20140520002( ?. s5 N$ x, d
L_L1         N16443 N14518  6.8uH  " s- f. K$ E. Y. e& E' |: n0 b
R_R1         N14706 N14518  3500K TC=0,0 3 R7 g2 M+ h; V6 a
R_R2         N14852 N14909  1600K TC=0,0
! R0 Z( y0 d. R, [3 A7 P9 RC_C1         0 N14909  4.7U  TC=0,0
! b8 h+ @# w1 I0 G# e" Z7 hR_R3         0 N14706  1 TC=0,0
- _" j9 H% i# ER_R4         0 N14852  100k TC=0,0
- L) E; c  q  j. G" P1 |# lR_R5         N15507 N14909  100K TC=0,0
  [& [- p7 v6 }# H6 D; q. ^& @V_V1         N14518 0 5Vdc
( o3 J" E, B7 G, _R_R6         0 N14909  100K TC=0,0
7 w8 s" q$ o- ?C_C2         0 N14518  10U  TC=0,0
+ Y! F3 R7 q% E9 j# k# lC_C3         0 N14909  22U  TC=0,0 - u! S) o  R  q& [3 d# E
X_U1         N16443 N14518 N14518 N14706 0 0 N14909 N14852 N15507 0 TPS61032' J% p, t! P7 e  V2 k
' B8 G' M4 ~. L( r. h4 X
**** RESUMING 20140520005.cir ****
% R: I% @0 b$ |. f: f% S5 o.END
+ l* F1 ]) y, q$ [* z0 p, K  r/ |$ I! s, h
ERROR -- Convergence problem in transient bias point calculation( d: C# w1 g* ^- X
, V4 G8 j3 F% ^' o! j" I, Y: |+ B3 a0 ^% Z
  Last node voltages tried were:0 g+ S" p: K8 A/ e5 E5 p
. w7 T8 d! |9 k! Q NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE
# k& V  O$ g) e6 K  c7 E4 X: W  求助啊   # m8 z5 i9 v( [8 M( P
( f! [6 D( a# j% R
' V" }( X" p2 h打开Simulation Settings对话框,找到Option标签页。5 P' u) Y1 B( ?
  b6 Q3 P) l- i- l/ Q0 m修改ILT1为500- x1 t6 r6 d6 i. X- t" C* x% x' [) s- @4 p% y. z) o. ^7 z0 H
ABSTOL修改为1n) `4 m2 E; Y) d: x# b  z
+ Q% x. I0 ^. s) p  L. DVNTOL修改为10u4 Y; W0 B  `$ T1 u
5 A$ [) h! b: q" J如果不能够解决问题,那么看一下所使用的模型是不是存在不连续点。6 C3 S( C# @' P* m9 l$ {
, f9 I. h5 A: ~& \/ l如果是这样的话,就需要改进模型了。
- U9 ]: X) H4 [8 y5 X- T. Z没用啊  !!!!!
推荐
发表于 2013-9-16 21:09 | 只看该作者
我是修改Simulation Settings-source combine test 裡面的option --> AutoConverge-->點選AutoConverge。不知道有沒有幫助到你。
推荐
发表于 2014-4-3 16:16 | 只看该作者
改了option里的值也没用,是电路原因吗。
发表于 2008-3-4 21:07 | 只看该作者
能具体点吗?最好有图,大家一起来研究!!!
发表于 2008-10-23 14:28 | 只看该作者
我也遇到了这种问题,有没有人有解决方法啊,不吝赐教!!
发表于 2008-12-3 23:32 | 只看该作者
关注中!今天我也出现着问题了,不知怎么解决
发表于 2008-12-6 16:45 | 只看该作者
不收敛
发表于 2009-1-14 13:47 | 只看该作者
求静态工作点的时候不收敛,如果电路没问题,可以通过设置初始条件来解决
发表于 2009-8-4 16:45 | 只看该作者
不收敛的问题,把TL4里面的值从10该到50或100试试,lucky
头像被屏蔽
发表于 2009-8-23 15:40 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-9-27 20:37 | 只看该作者
赞,顶一个。2 f# u% q1 s7 m
  ?" k7 I+ ^2 i
+ e( n! M7 b7 V$ P
/ ?5 B  P2 f: Q3 U& O  b
9 o3 T% j% b& r/ M9 _
7 W0 z' I$ `- z% q( `+ _5 G$ H* x: D# J' m* B
# V5 Q4 {9 k# G# `" e% E
+ N1 @, Q& X% x4 Q5 I: m5 n6 R8 C8 v6 F
$ q  j! |; h. i1 @
" S. V: I% R; Q) K: S
( b$ c+ |  H4 d% \
+ r) s3 x- L, E0 H+ [) ?- |; M* k8 c
  ^4 T6 ^; v& ^# ]( f2 Q/ ^$ z1 }$ ?, c; ?# r: b4 Q. S) @$ U* |
13#
发表于 2009-10-8 14:45 | 只看该作者
打开Simulation Settings对话框,找到Option标签页。* A: H. K* a( H3 S. S& @) V; Y
修改ILT1为500
( r1 ?8 e/ L3 E8 k) vABSTOL修改为1n0 c2 B$ O, H7 A4 N
VNTOL修改为10u
  V$ Q- c) x% L! w" {# L+ G8 N如果不能够解决问题,那么看一下所使用的模型是不是存在不连续点。
/ j, O4 T( M. K6 e) p4 u如果是这样的话,就需要改进模型了。
14#
发表于 2010-10-9 00:04 | 只看该作者
楼上的解决方法可行吗?这个问题是怎么造成的呢?
15#
发表于 2013-7-17 11:09 | 只看该作者
顶下,等大侠解决,
16#
发表于 2013-9-2 16:54 | 只看该作者
求好心人帮忙解决。。我也遇到这种问题了
GMT+8, 2025-9-30 14:37 , Processed in 0.140625 second(s), 26 queries , Gzip On.
