查看: 691|回复: 0
[skill]-Share skill
发表于 2019-5-23 11:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
I have skill for align.
axlCmdRegister(
        "align_sym"
        'align_sym
procedure( align_sym( )
(prog ()
when( axlOKToProceed()
_ASInitVar()
_ASCreateFormFile()
_ASInitPARMForm()
while( fini == nil
        _ASsetsymmaster()
        if( _ASFormData->group == t && fini == nil then
                _ASselectGrp()
                if( _ASFormData->horizontal == t then
                        _ASMoveHorzComp( cmpgrp)
                else
                        _ASMoveVertComp( cmpgrp)
        if( _ASFormData->tolerance == t && fini == nil then
                        _ASHorzSelTol()
                else
                        _ASVertSelTol()
        if( _ASFormData->window == t && fini == nil then
                _ASWindSel()
                else
        cmpgrp = nil
);end-while
axlUIPopupSet( nil)
);endwhen
);end-prog
);endprocedure
;-----------------------define master component location-------------------
(defun _ASsetsymmaster ( )
(prog ()
        _ASPopUpA()
        setq( efound  nil)
while( (efound == nil) && (fini == nil)
        axlMsgPut("Select Key Component.")
        good = nil
        mpinl = nil
        pnloc = nil
        axlSetFindFilter( ?enabled (list "symbols" )
                          ?onButtons (list "symbols"))
        axlOpenFindFilter()
        if( fini ==  nil && axlSingleSelectPoint( ) then
                elem = axlGetSelSet()
                axlMsgPut( "Key Component %L Selected." car(elem)->refdes)
        else
                 if( fini == nil then axlMsgPut( "Nothing Found, Select Again."))
        );end-if
                axlHighlightObject( elem)
                if(_ASFormData->top == t && (car elem)->isMirrored == nil then
                        good = t
                );endif
                if(_ASFormData->bottom == t && (car elem)->isMirrored == t then
                        good = t
                );endif
                if(_ASFormData->both == t then good = t)
                if(good == t then
                        ;---------stor current data
                        setq(locat (car elem)->xy)
                        setq(cmpid (car elem)->refdes)
                        setq(cmpname (car elem)->name)
                        setq(cmptype (car elem)->type)
                        setq(cmprot (car elem)->rotation)
                        setq(cmpmir (car elem)->isMirrored)
                        efound = t
                        if( _ASFormData->pin == t then
                                r = 1
                                setq( mpinl car(elem)->pins)
                                while( nthelem( r mpinl) != nil
                                        if( nthelem( r mpinl)->number == "1" then
                                                setq( pnloc nthelem( r mpinl)->xy)
                                ++r
                                if( pnloc == nil then
                                        efound == nil
                                        axlMsgPut("Component Selected Has No Pin 1.")
                                        axlMsgPut("Reset Parameters And Try Again.")
                else
                        axlDehighlightObject( elem)
                        axlMsgPut( "Selected Component is not on Selected Layer.")
                        axlSubSelectAll()
                );endif
        );endif
);end-while
axlCancelEnteRFun()
);end-prog
);end-defun
;-------------------select components by group-----------------------
(defun  _ASselectGrp ()
(prog ()
if( efound == t && cmpgrp == nil then
        grsel = nil
              _ASPopUpB()
              axlOpenFindFilter()
        while( (grsel == nil && efound == t)
                       axlMsgPut("Select Component to be Aligned.")
                       good = nil
                if( grsel == nil then
                               if( axlSingleSelectPoint( ) then
                                       setq( gelem axlGetSelSet())
                                       axlMsgPut( "Component %L Group Selected." car(gelem)->refdes)
                               else
                                       if( grsel == nil then axlMsgPut( "Nothing Found, Select Again."))
                               );end-if
                       );end-if
                       if(_ASFormData->top == t && (car gelem)->isMirrored == nil then
                                good = t
                       );endif
                       if(_ASFormData->bottom == t && (car gelem)->isMirrored == t then
                                good = t
                       );endif
                               if(good == t then
                                if( (car gelem)->type == "PACKAGE" then
                                        cmpgrp=cons( nthelem( 1 gelem) cmpgrp)
                                        axlHighlightObject( cons( car(elem) cmpgrp))
                                else
                                        axlMsgPut( "Component Not A PACKAGE Type")
                                        axlDehighlightObject( gelem)
                                );end-if
                         else
                                axlMsgPut( "Component Is Not On Appropriate Layer")
                        );endif
                );endif
        );end-while
        return( cmpgrp)
);end-if
axlCancelEnterFun()
);end-prog
);end-defun
;-------------------select by vertical orientation------------------
(defun _ASVertSelTol ()
(prog ()
if( efound == t then
        i = 1
        good = nil
                mlocat = pnloc
        else
                mlocat = locat
        setq(allsym axlDBGetDesign()->symbols)
        setq(allcmp axlDBGetDesign()->components)
        while( nthelem( i allsym) != nil
                if( nthelem( i allsym)->type == "PACKAGE" && nthelem( i allsym)->refdes != car(elem)->refdes then
                                r = 1
                                setq( tpinl nthelem( i allsym)->pins)
                                while( nthelem( r tpinl) != nil
                                        if( nthelem( r tpinl)->number == "1" then
                                                setq( tlocat nthelem( r tpinl)->xy)
                                        ++r
                        else
                                setq( tlocat (nthelem(i allsym)->xy))
                        if( (car tlocat) <= ( car mlocat)+_ASFormData->tol && (car tlocat) >= ( car mlocat)-_ASFormData->tol then
                                                good = t
                                        );endif
                                                        good = t
                                        );endif
                                setq( srefdes (nthelem(i allsym)->refdes))
                                h = 1
                                while( nthelem( h allcmp) != nil
                                        if( (nthelem( h allcmp)->name) == srefdes && good == t then
                                                if( _ASFormData->class == "Any" || nthelem( h allcmp)->class == _ASFormData->class then
                                                        cmpgrp=cons(nthelem( i allsym) cmpgrp)
                                                        axlMsgPut( "Component %L Selected." srefdes)
                                                );end-if
                                        );endif
                                        ++h
                                );end-while
                        );end-if
                        good = nil
                );end-if
                ++i
        );endwhile
        efound = nil
        fini = nil
);end-if
return( cmpgrp)
);end-prog
);end-defun
;-------------------select by horizontal orientation------------------
(defun _ASHorzSelTol ()
(prog ()
        i = 1
        good = nil
                mlocat = pnloc
        else
                mlocat = locat
                if( nthelem( i allsym)->type == "PACKAGE" then
                                r = 1
                                        ++r
                        else
                        if((cadr tlocat) <= ( cadr locat)+_ASFormData->tol && (cadr tlocat) >= ( cadr locat)-_ASFormData->tol then
                                                good = t
                                        );endif
                                                        good = t
                                        );endif
                                h = 1
                                        if( ( nthelem( h allcmp)->name) == srefdes && good == t then
                                                        axlMsgPut( "Component %L Selected" srefdes)
                                                );end-if
                                        );end-if
                                ++h
                                );end-while
                        );end-if
                );end-if
                ++i
        );end-while
        efound = nil
        fini = nil
        return( cmpgrp)
);end-prog
);end-defun
;-------------------select by window ---------------------------------
(defun _ASWindSel ()
(prog ()
        i = 1
        good = nil
        axlOpenFindFilter()
        axlSingleSelectBox()
        allsym = axlGetSelSet()
        if( allsym == nil then axlMsgPut( "No Elements Found."))
                                       good = t
                                );endif
                                                good = t
                                );endif
                        h = 1
                                                axlHighlightObject( nthelem( i allsym))
                                                axlMsgPut( "Component %L Window Selected." srefdes)
                                        );end-if
                                );end-if
                        ++h
                        );end-while
                );end-if
                good = nil
        ++i
        );end-while
);endif
        efound = nil
        return( cmpgrp)
);end-prog
);end-defun
;-------------------relocate vertical position -----------------------
(defun _ASMoveVertComp (cmpgrp)
(prog ()
        i = 1
        tmpnew= nil
        ocmpdata=nil
        ocmpmir=nil
        ocmprot=nil
        olocat=nil
        while( nthelem( i cmpgrp) != nil
                if( nthelem( i cmpgrp)->refdes != cmpid then
                        cmpdata=nil
                        tlocat = nil
                        setq(tlocat nthelem( i cmpgrp)->xy)
                        setq(tcmpid nthelem( i cmpgrp)->refdes)
                        setq(tcmpname nthelem( i cmpgrp)->name)
                        setq(tcmptype nthelem( i cmpgrp)->type)
                        setq(tcmprot nthelem( i cmpgrp)->rotation)
                        setq(tcmpmir nthelem( i cmpgrp)->isMirrored)
                        cmpdata=cons(tcmpid cmpdata)
                        cmpdata=cons(tcmptype cmpdata)
                        cmpdata=cons(tcmpname cmpdata)
                        ocmpdata = cons( cmpdata ocmpdata)
                        ocmpmir = cons( tcmpmir ocmpmir)
                        olocat = cons( tlocat olocat)
                        ocmprot = cons( tcmprot ocmprot)
                        nlocat=nil
                        plocat = nil
                        npinl = nil
                        axlMsgPut("%L " npinl)
                        ;-------------define the new vertical orientation
                                r = 1
                                npinl=nthelem( i cmpgrp)->pins
                                while( nthelem( r npinl) != nil
                                        if( nthelem( r npinl)->number == "1" then
                                                plocat= nthelem( r npinl)->xy
                                                nlocat=cons(nthelem( 2 tlocat) nlocat)
                                                voffs = (nthelem( 1 tlocat) - nthelem(1 plocat))
                                                nlocat=cons(( car(pnloc) + voffs) nlocat)
                                        ++r
                        else;
                                nlocat=cons(nthelem( 1 locat) nlocat)
                        ;-------------delete present stuff
                        z = 1
                        setq( pindat nthelem( i cmpgrp)->pins)
                        while( nthelem( z pindat) != nil
                                h=1
                                setq(pinsel nthelem( z pindat)->branch->children)
                                while( nthelem( h pinsel) != nil
                                        if( nthelem( h pinsel)->objType == "via" then
                                                dellst = cons( nthelem( h pinsel) dellst)
                                        if( nthelem( h pinsel)->objType == "path" then
                                        ++h
                                );endwhile
                                axlDeleteObject(dellst)
                                dellst = nil
                                ++z
                        );endwhile
                        axlDehighlightObject(nthelem( i cmpgrp))
                        axlDeleteObject(nthelem( i cmpgrp))
                                r = 1
                                        axlDBRefreshId( nthelem( r npinl))
                                        ++r
                                );end-while
                        ;-------------add newer symbol
                        tmpnew = cons( car(axlDBCreateSymbol( cmpdata nlocat tcmpmir tcmprot)) tmpnew)
                );endif
                ++i
        );endwhile
        setq( elem nil)
        setq( grsel nil)
        setq( cmpgrp nil)
);end-prog
);end-defun
;-------------------relocate Hoizontal position ----------------------
(defun _ASMoveHorzComp (cmpgrp)
(prog ()
        i = 1
        tmpnew= nil
        ocmpdata=nil
        ocmpmir=nil
        ocmprot=nil
        olocat=nil
                        cmpdata=nil
                        nlocat=nil
                        ;-------------define the new horizontal orientation
                                r = 1
                                setq( npinl nthelem( i cmpgrp)->pins)
                                                setq( plocat nthelem( r npinl)->xy)
                                                voffs= nthelem( 2 tlocat) - nthelem(2 plocat)
                                                nlocat=cons( ( cadr(pnloc) + voffs ) nlocat)
                                                nlocat=cons( nthelem( 1 tlocat) nlocat)
                                        );endif
                                        ++r
                                );endwhile
                        else
                                nlocat=cons(nthelem( 2 locat) nlocat)
                                nlocat=cons(nthelem( 1 tlocat) nlocat)
                        );endif
                        z = 1
                                h=1
                                        ++h
                                dellst = nil
                                ++z
                                r = 1
                                        ++r
                                );end-while
                );endif
                ++i
        );endwhile
        setq( elem nil)
        setq( grsel nil)
);end-prog
);end-defun
;-------------------Parameter form data ------------------
defun( _ASInitParmForm  () ;
(prog ()
(let ( form)
        form = axlFormCreate( (gensym) "align_sym.form" '(se outer) '_ASParmCallBk t )
        _ASFormPtr = form
        if( ( _ASFormData == nil ) then
                setq( _ASFormData  t)
                (axlFormBuildPopup form "class" '(("Any" "Any") ("IC" "IC") ("IO" "IO") ("DISCRETE" "DISCRETE")))
                (axlFormSetField form "class" "Any")
                putprop( _ASFormData  "Any" 'class)
                (axlFormSetField form "horizontal" t)
                putprop( _ASFormData t 'horizontal)
                (axlFormSetField form "vertical" nil)
                putprop( _ASFormData nil 'vertical)
                (axlFormSetField form "pin" nil)
                putprop( _ASFormData nil 'pin)
                (axlFormSetField form "origin" t)
                putprop( _ASFormData t 'origin)
                (axlFormSetField form "top" t)
                putprop( _ASFormData t 'top)
                (axlFormSetField form "bottom" nil)
                putprop( _ASFormData nil 'bottom)
                (axlFormSetField form "both" nil)
                putprop( _ASFormData nil 'both)
                (axlFormSetField form "group" t)
                putprop( _ASFormData t 'group)
                (axlFormSetField form "window" nil)
                putprop( _ASFormData nil 'window)
                (axlFormSetField form "tolerance" nil)
                putprop( _ASFormData nil 'tolerance)
                (axlFormSetField form "tol" 250.000 )
                putprop( _ASFormData 250.000 'tol)
        axlFormDisplay( form)
        );end-if
);end-let
);end-prog
);end-defun
;---------------Form Call Back-----------------------------------------------
defun( _ASParmCallBk (form)
case( get(_ASFormPtr 'curField)
        ( "class" putprop( _ASFormData get(_ASFormPtr 'curValue) 'class))
        ( "horizontal" putprop( _ASFormData get(_ASFormPtr 'curValue) 'horizontal))
        ( "vertical" putprop( _ASFormData get(_ASFormPtr 'curValue) 'vertical))
        ( "pin" putprop( _ASFormData get(_ASFormPtr 'curValue) 'pin))
        ( "origin" putprop( _ASFormData get(_ASFormPtr 'curValue) 'origin))
        ( "top" putprop( _ASFormData get(_ASFormPtr 'curValue) 'top))
        ( "bottom" putprop( _ASFormData get(_ASFormPtr 'curValue) 'bottom))
        ( "both" putprop( _ASFormData get(_ASFormPtr 'curValue) 'both))
        ( "group" putprop( _ASFormData get(_ASFormPtr 'curValue) 'group))
        ( "window" putprop( _ASFormData get(_ASFormPtr 'curValue) 'window))
        ( "tolerance" putprop( _ASFormData get(_ASFormPtr 'curValue) 'tolerance))
        ( "tol" putprop( _ASFormData get(_ASFormPtr 'curValue) 'tol))
        ( "done" _ASDone() )
        ( "cancel"  _ASCancel() )
);case
);end-defun
;--------------- Pop up while selecting but not by group --------------------
defun( _ASPopUpA ()
        popupA = axlUIPopupDefine( nil
                        (list (list "Done" '_ASDone)
                                (list "Oops" '_ASoops)
                                (list "Cancel" '_ASCancel)))
        axlUIPopupSet( popupA )
);end-defun
;--------------- Pop up for group selection --------------------------------
defun( _ASPopUpB ()
        popupB = axlUIPopupDefine( nil
                (list (list "Complete" '_AScomplete)
        axlUIPopupSet( popupB )
);end-defun
;--------------- Cancel Call--------------------------------
defun( _ASCancel ()
(prog ()
        i=1
        pindat = nil
        pinsel = nil
        dellst = nil
        while( nthelem( i tmpnew) != nil
                z = 1
                setq( pindat nthelem( i tmpnew)->pins)
                        h=1
                                ++h
                        dellst = nil
                        ++z
                );endwhile
                axlDeleteObject(nthelem( i tmpnew))
                        r = 1
                                ++r
                        );end-while
                ++i
        );end-while
        i = 1
        while( nthelem( i ocmpdata) != nil
                        axlDBCreateSymbol(
                        nthelem(i ocmpdata)
                        nthelem(i olocat)
                        nthelem(i ocmpmir)
                        nthelem(i ocmprot)
                        ++i
        );end-while
        elem = nil
        cmpgrp = nil
        _ASDone()
);end-prog
);endfun
;----------------- DONE Call--------------------------------
defun( _ASDone ()
(prog ()
        setq( grsel t)
        if( elem != nil then axlDehighlightObject( elem))
        if( cmpgrp != nil then axlDehighlightObject( cmpgrp))
        setq( grsel t)
        setq( fini t)
        if(isFile("align_sym.form") then
                deleteFile("align_sym.form")
        setq( elem nil)
        setq( cmpgrp nil)
        axlFormClose(_ASFormPtr)
        axlCancelEnterFun()
        axlClearSelSet()
        axlCloseFindFilter()
        axlUIPopupSet( nil)
);end-fun
;--------------- Complete Picks ----------------------------
defun( _AScomplete ()
(prog ()
        setq( grsel t)
        axlCancelEnterFun()
        _ASPopUpA()
        setq( efound nil)
);end-defun
;--------------- Oops command-------------------------------
defun( _ASoops ()
(prog ()
                axlDehighlightObject( car( cmpgrp))
                cmpgrp = cdr(cmpgrp)
                good = nil
                gelem = nil
        else
                elem = nil
                efound = nil
        );end-if
        if( elem == nil then axlMsgPut( "Nothing In Buffer To Oops."))
        axlCancelEnterFun()
        return( cmpgrp)
);endprog
);end-defun
;--------------- initialize variables -------------------
defun( _ASInitVar ()
(prog ()
elem = nil
mpinl = nil
pnloc = nil
plocat = nil
mlocat = nil
gelem = nil
dellst = nil
pindat = nil
pinsel = nil
tmpnew = nil
ocmpdata=nil
ocmpmir=nil
ocmprot=nil
olocat=nil
_ASFormData = nil
_ASFormPtr = nil
fini = nil
tol = 0
axlUIPopupSet( nil)
fini = nil
cmpgrp = nil
);end-prog
);end-defun
;-----------------create form file -------------
defun( _ASCreateFormFile ()
        frmfle = outfile("align_sym.form")
        fprintf( frmfle "FILE_TYPE=FORM_DEFN VERSION=2\nFORM\nFIXED\n")
        fprintf( frmfle "PORT 67 13\nHEADER \"Component Alignment Form\"\n")
        fprintf( frmfle "POPUP <CURSPOP>\"Any\"\"1\",\"IC\"\"2\",\"IO\"\"3\",\"DISCRETE\"\"4\".\n")
        fprintf( frmfle "POPUP <PRINTP>\"to File\"\"0\",\"to Printer\"\"1\",\"to Script\"\"2\".\n")
        fprintf( frmfle "\nTILE\n\n")
        fprintf( frmfle "TEXT \"Class:\"\nTLOC 32 18\nTGROUP \"Select Mode\"\nENDTEXT\n")
        fprintf( frmfle "FIELD top\nFLOC 3 12\n FGROUP\"Alignment Layer\"\nCHECKLIST\"Top\" \"alg\"\n ENDFIELD\n\n")
        fprintf( frmfle "FIELD bottom\nFLOC 3 14\nFGROUP \"Alignment Layer\"\nCHECKLIST \"Bottom\" \"alg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD both\nFLOC 3 16\nFGROUP \"Alignment Layer\"\nCHECKLIST \"Both\" \"alg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD horizontal\nFLOC 3 5\nFGROUP \"Direction\"\nCHECKLIST \"Horizontal\" \"dirg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD vertical\nFLOC 3 7\nFGROUP \"Direction\"\nCHECKLIST \"Vertical\" \"dirg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD origin\nFLOC  35 7\nFGROUP \"Alignment Point\" \nCHECKLIST \"Origin\" \"alpg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD pin\nFLOC  35 5\nFGROUP \"Alignment Point\" \nCHECKLIST \"Pin 1\" \"alpg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD group\nFLOC  25 12\nFGROUP \"Select Mode\"\nCHECKLIST \"Group\" \"slmg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD window\nFLOC  25 14\nFGROUP \"Select Mode\"\nCHECKLIST \"Window\" \"slmg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD tolerance\nFLOC  25 16\nFGROUP \"Select Mode\"\nCHECKLIST \"Tolerance\" \"slmg\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD tol\nFLOC  40 16\nFGROUP \"Select Mode\"\nREALFILLIN 10 10\n DECIMAL 4\nENDFIELD\n\n")
        fprintf( frmfle "FIELD class\nFLOC 40 18\nFGROUP \"Select Mode\"\nENUMSET 12\nPOP \"CURSPOP\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD done\nFLOC 2 22\n MENUBUTTON \"Done\" 9 3\nENDFIELD\n\n")
        fprintf( frmfle "FIELD print\nFLOC 28 22\n MENUBUTTON \"Print\" 9 3\n POP \"PRINTP\"\nENDFIELD\n\n")
        fprintf( frmfle "FIELD cancel\nFLOC 55 22\n MENUBUTTON \"Cancel\" 9 3\nENDFIELD\n\n")
        fprintf( frmfle "GROUP \"Alignment Layer\"\nGLOC 2 10\nGSIZE 20 11\nENDGROUP\n\n")
        fprintf( frmfle "GROUP \"Direction\"\nGLOC 2 2\nGSIZE 30 8\nENDGROUP\n\n")
        fprintf( frmfle "GROUP \"Alignment Point\"\nGLOC 34 2\nGSIZE 30  8\nENDGROUP\n")
        fprintf( frmfle "GROUP \"Select Mode\"\nGLOC 24 10\nGSIZE 40 11\nENDGROUP\n\n")
        fprintf( frmfle "\nENDTILE\n\nENDFORM\n")
        close(frmfle)
);end-defun
GMT+8, 2025-8-21 05:08 , Processed in 0.140625 second(s), 24 queries , Gzip On.
