DIRECTIONS TO USE COMPARATORS
orcad CAPTURE LIBRARY
( {- y: K9 E& e' p
( b a, b) X' O1 @& B# w7 rThe COMPARATORS Orcad Capture Library archive contains the following files
! M' ]. E) {( K1 \7 n2 D5 ]1. COMPARATORS.olb file, which is the symbol library file containing Orcad Capture5 h y3 S+ B8 }' t
symbols of all the devices in the library.
z( J/ f" H. f( O2 g2 R7 u
2. Orcad Capture/
Pspice A/D compatible spice subcircuit files for all the devices in the symbol library.
' R; N% m( [: c& P
For each device there will be a separate subcircuit file named after the device part number
5 x$ |$ M/ y5 V8 t4 n: @( c' s and with a .lib extension.
( k! ?- k& o. f* M% T
3. This README.txt file.
, A/ f5 l% D# o- R8 D
HOW TO USE SYMBOLS AND SUBCIRCUIT FILES IN ORCAD CAPTURE/PSPICE A/D ENVIRONMENT.7 ^0 R8 `& n. u: q U5 J- H8 M7 a
0 O7 U% r9 l7 y/ t0 i7 f1. Save the Symbol file and the subcircuit files to any convenient location.
1 p2 k9 Z' Z- d z& P Q! J2. COMPARATORS.olb symbol library file is like any other Orcad Capture library
; ?5 `8 x! h1 X file which can be edited by opening it in Orcad Capture from menu File->Open->Library. 3 J% v3 _# z5 J
+ J! K3 m8 g7 m Q# U1 U
3. Symbols in the library can be used to draw circuit schematic in Orcad Capture environment.
$ j9 S" | C* I( E5 _( S& z To use symbols in the symbol library use menu Place->Part. Use the Add Library button in the
( Y y( W+ T$ {( ~9 u Place Part dialog box. Browse and open the COMPARATORS.olb file from where
7 F0 z# } `$ z% i it has been stored. All the devices in the library will be listed in the parts list. Select 4 K7 J2 n j+ k' j0 B& W, s% ^
the device to place it into the schematic.
^7 `. P# ^! V4. Before running the Pspice A/D simulation, .lib subcircuit files of the devices used from the 6 D! V8 ?5 J3 Z% u1 e
COMPARATORS symbol library should be included in the simulation profile of the
$ k& t) J! }) w/ s8 Q; \2 @ design. For including the subcircuit files use menu PSpice->Edit Simulation Profile. In the ; p* L( B2 S8 y3 P }5 P- E
simulation setting dialog box choose Configuration Files section. Select the library category, 4 s5 l' K5 ~$ _0 K p* E- p3 s8 l
browse for the subcircuit files, click Add to Design and Apply. Normal procedure for simulation
3 H0 H9 J) y# w" a: L. b' n can be now followed for simulating the design. For more details refer to the Orcad Capture or + N" ^) s' @0 r% q K
Pspice A/D manuals.
