TA的每日心情 | 奋斗 2019-11-20 15:07 |
签到天数: 1 天 [LV.1]初来乍到
部分命令可以参考. A4 k) w" ]3 ^2 v" I a
" h; O1 j1 g5 J8 G2 g
' C) ~ r+ d) T3 u @( ]' UBindMenu = 0
+ F3 i) Q" x3 H, Z6 ?5 ABindAccelerator = 1
$ y, j1 ` |5 }! B" [5 n8 MBindCommand = 12 s8 j$ o5 x8 W
# `8 {% T+ F4 N
Set keyBindTables = Gui.Bindings("Document")
& X2 @6 `; F% X8 u7 q. G. ~
8 O+ m, b% U& a- |% I' Bind the menu command to a key
. _% j2 i$ V6 Q* m. n, C& g. j1 d/ l2 d
keyBindTables.AddKeyBinding "Z", "Edit->FixLock->Fix", BindMenu, BindAccelerator
( Q1 q; @# M& Y/ x' i- `0 F& skeyBindTables.AddKeyBinding "SPACE", "Route->Edit Routes->Change Width", BindMenu, BindAccelerator
9 D% T O2 n! ekeyBindTables.AddKeyBinding "D", "Edit->FixLock->Unfix", BindMenu, BindAccelerator, N8 [* \" e9 H
keyBindTables.AddKeyBinding "Q", "Edit->FixLock->Lock", BindMenu, BindAccelerator
. \, X4 [, R, k1 @keyBindTables.AddKeyBinding "W", "Edit->FixLock->Unlock", BindMenu, BindAccelerator7 j" c# ?) _% G% \, `
keyBindTables.AddKeyBinding "S", "Edit->FixLock->Semi Fix", BindMenu, BindAccelerator. u6 ?1 n. B, k# J. @, h/ d2 ? O3 N
'keyBindTables.AddKeyBinding "Space", "Route->Edit Routes->Change Width", BindMenu, BindAccelerator% a3 J: @7 E0 B1 N3 ~. X. w, a' N
keyBindTables.AddKeyBinding "G", "Route->Edit Routes->Gloss", BindMenu, BindAccelerator2 \. g* ^, l, {' Q
keyBindTables.AddKeyBinding "P", "Planes->Plane Shape", 0 , 1
' Q3 U7 U8 P& z( `; d* M H+ s& } `- EkeyBindTables.AddKeyBinding "X", "run c:\iAT\ChangeMode.vbs", BindCommand, BindAccelerator
" z/ r X8 b3 S" y4 ^: t- {8 ^8 q0 _keyBindTables.AddStrokeBinding "357", "Route->Edit Routes->Change Width", BindMenu, BindAccelerator# U) N) L# U8 Q! Z# S
keyBindTables.AddKeyBinding "F4", "run c:\iAT\testkey.vbs", BindCommand, BindAccelerator; J) a0 r: p2 q( _ Q9 V5 d
keyBindTables.AddKeyBinding "R", "run c:\iAT\plow.vbs", BindCommand, BindAccelerator7 }2 {0 ^% J k/ ~
keyBindTables.AddStrokeBinding "1236987", "Draw->Rule Area", BindMenu, BindAccelerator
% z, f1 \$ J: I$ L& ^+ E8 v2 \7 i6 ykeyBindTables.AddKeyBinding "U", "SmartUtilities->FatTrace->FatTrace Edit", BindMenu, BindAccelerator1 z9 \* ]- L2 u% Q
keyBindTables.AddKeyBinding "M", "Edit->Move", BindMenu, BindAccelerator$ @) j2 d A( S1 b8 C8 U2 ?
keyBindTables.AddKeyBinding "c", "Edit->Delete", BindMenu, BindAccelerator
2 N/ S3 R: H! ?7 ~7 P0 E6 `, Q; D: _2 s& J4 i* ~; {& |3 N& z
