查看: 357|回复: 1
一道考题,求解,非常感谢!
发表于 2019-1-22 15:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个异步FIFO 为N*64. ^) {- Y1 k+ O+ i3 k, D; j* B2 e' G
$ X/ _# ?6 F1 `, C! E题干为:
4 S! v7 f4 b) \9 X5 T8 ]- _$ Z$ z# j! k# c& u% l" {2 T4 P
parameter:
3 `$ U/ g3 f2 W8 I, J2 W2 O( W
* x8 s' d. _# [2 A) }! ^$ L1)Bus's clock is 500Mhz,width is 16 bit.
. _- m* u7 C1 O# q; _; P0 L3 P& U5 _1 n, g$ f; L: J  G1 I
2)The tipycal data payload packet is 8QW,the ACK packet is 2 DW., Y; r# N$ x( w( R, v( i! e8 j
5 X5 V6 }) i6 ]% M
3)The latency from receiver receiving the complete data packet to send out the ACKpacket is 20ns.1 u9 B; q5 e8 s2 j
3 O0 N* o1 ~4 L+ K, `" z4)The throughput of transmitter FIFO's input and output is equaled.
/ I) O, H" k% w1 J5 F: R2 T
2 s6 t3 F4 ^* G0 }+ c) \5 fCaculate the optimized FIFO depth N?
7 }* j0 n9 D  B7 L7 g# ~$ R! m: y" ]; Y
怎么算深度N啊???    参数8QW和2 DW是什么意思?  请好心人仔细的指点一下!!!!
2 I0 I) Q! _" L  S+ }2 u" ?5 M" E5 i4 Y+ q
GMT+8, 2025-7-27 16:19 , Processed in 0.109375 second(s), 23 queries , Gzip On.
