多功能电子时钟仿真及代码$ i' b4 i" [, J
; ]+ Q x u9 _2 h
$ w( S1 U9 J0 W& p多功能电子时钟仿真原理图:1 o0 J5 k2 \7 d& J
8 n+ @, h6 l \/**************************/
; ~0 H# ^9 u9 t( I$ q/**************************/
+ L; H, {% ~- @8 E/ P$ r0 Q/**** 电子时钟 ****/. r8 `, P* I! b6 T, D
/**************************/4 g$ f1 ~* F# t0 p1 C
J, e5 Z6 t/ n# c2 Q- Q8 Y4 l+ D% m9 ] u0 L4 L9 s( ^& r5 l
, j6 `; e5 K2 T! A) e& {/ X% o5 b
#include" O; q8 z1 I; y
#define uint unsigned int
; I4 `9 `* W M) I- F3 z) `9 i8 I! A#define uchar unsigned char/ E$ o% q3 q2 e# H L
char miao,fen,shi;
" [! @9 R8 h/ f9 S! o- G3 }bit flag, flag_time;, R8 h \, F2 M5 M, N& S
char set_miao=0,set_fen=0;set_shi=12; //闹钟初始化3 F: H3 `0 K, e( M
uchar slnum;$ \4 ]- Y7 b4 b! l, k8 V% Q
2 V( L; M, o K6 h
& t7 w0 g$ f0 i1 @3 ?+ i @+ ~sbit s1=P3^0; //功能键
7 M7 v- h6 I3 L+ m) A4 Ssbit s2=P3^1; //加键) O* A/ Y C' p! n
sbit s3=P3^2; //减键) j2 G, L1 ]/ q1 ?& Z
sbit s4=P3^3; //闹钟设置) |2 ]5 O4 h& n' Z# n
6 _( e7 M" F$ ]- o+ j3 v M3 C4 L# _: `1 q) ], G$ Y9 P
( O( _5 a, E1 `: a9 ^) f5 |4 O
% P$ O6 t+ C& O% k+ R3 Z0 w6 d) Ysbit led1=P1^0; //调整秒钟的指示灯2 x0 u6 i! ^, Z
sbit led2=P1^1; //调整分钟的指示灯
; \+ n5 l" ]! \" Xsbit led3=P1^2; //调整时钟的指示灯
# j& O+ l, E1 [7 t2 ^6 n5 }sbit led4=P1^3; //闹钟设置指示灯
! M5 s1 x( \+ R6 ]sbit BUZZ =P1^4; //报警
$ y2 R4 ]- N$ z2 M
6 ]( \9 q9 j( l* n; b( ?0 S* v5 T8 ?3 K
sbit wei0=P2^0; //定义8个数码管段选
9 M0 k1 H: e) Y; |. u+ L2 Msbit wei1=P2^1;
: ?' @4 j1 ?* X% O' zsbit wei2=P2^2;, o0 Y3 O2 F" Y) b0 C1 l5 Z
sbit wei3=P2^3;% \; t* ~* t& \
sbit wei4=P2^4;* r: B/ n# N0 H
sbit wei5=P2^5;
- @$ M6 q/ f; H' r# a) L) xsbit wei6=P2^6;* S! t, }/ Y: H# i' Y
sbit wei7=P2^7;8 w& ~ C+ v8 l* J4 v1 a/ @
$ _# \( ^: [/ G r, S; h
9 U7 i4 W6 g, K7 O- z9 c
uchar code table[]={
7 j, k2 U+ \$ i+ \ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,' m0 p# b F) b0 t% z4 s, u
0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40}; //共阴数码管编码
) }/ I6 Y3 I# P) o- X
$ W: @' r1 a9 t' ^) }0 n C# p9 ?$ u& E( N2 r6 _! E; T
void delay(uint z) //延时函数! j4 G% G- Q, `. s7 ~" w. y
{+ e0 A, n; ?2 h& h! u& l0 m
uint x,y;
+ Y$ e3 w1 _3 c# h* a) C$ K for(x=z;x>0;x--)1 b" T/ @7 \& P1 i! [. N
for(y=125;y>0;y--);
% `" g9 T0 I) r% z! r9 [1 O4 V+ B2 X. F: Q9 A8 F" K- X3 J6 |* o
+ }* @" M' X+ Z6 r- r7 a$ \
$ G% z% G) f4 P) q' @
/ n/ v1 R, E( ~$ H
$ h- x1 y x' H: h- U, d8 ~void start() //定时器初始化
' D: c2 ?! f* g& J8 |; m- Z/ v# g{! D6 M8 i( c+ U" s/ ?' d1 U
TMOD=0x11;
4 G+ X8 O; s2 O% b- }, B( E TH0=(65536-50000)/256; //时间累加
# }% z- g8 L J TH0=(65536-50000)%256;5 S0 h' ~$ Q d) r0 l
TH1=(65536-50000)/256; //闹钟设置
1 h c/ J. C3 G6 f# V1 v4 ] TH1=(65536-50000)%256;
8 K- F3 N: \4 I: n EA=1;3 T* k$ ? b; J; E9 o V5 C2 D
ET0=1;8 R2 V5 t7 M- x2 K9 P0 f7 m1 h
ET1=1;1 u1 o) L3 z5 _) n, ?% ]
TR0=1;
M3 n4 j. @* l, f7 t% o5 @ TR1=0; //关闭定时器, P& e; s) w. W- d3 A2 H! o
}: h3 z$ Q9 V! B# c% ^
( N* z* N, h& _2 C0 k. S3 f. a1 C* F; V$ f1 G ]% O: B8 B
void display(char miao,char fen, char shi) //显示子程序,分别显示时,分,秒( c$ n" F5 }5 N s) i9 O5 @
7 U; w; P0 f# V7 x W( u+ U: C P0=table[miao%10];
; n* c& c0 l8 Y0 u9 ? wei7=0;
3 b5 Z' V! U& [3 P) E% g delay(1);6 M9 A2 @ R/ x- N' ^" h" ^# R
wei7=1;! @6 n/ C! j" W# I0 o) f* j4 V
P0=0xff;
: D' Z# a6 J! P0 }# i6 I( p+ y/ _) c) F# o
' F' D1 [8 f9 h" s3 l
P0=table[miao/10];% x1 u( a4 D0 c6 f- X2 h2 E( O
wei6=0;
/ x1 u: U" b0 u delay(1);. P4 s4 L; |/ O8 f# U! o% Q3 i
wei6=1;$ S8 _* ?. D' v$ z% @ U
P0=0xff;
6 W; ~" ~( E3 f1 n* L
* N5 Q* M( t9 T/ x; e
1 Z" w0 M7 Y' V, z N( n$ L P0=table[16];
7 b% _( J/ h/ j7 D0 q6 d' G7 h9 R' e wei5=0;
% [& c- ]. ^/ ^) E delay(1); U1 o! g: q: {$ |, ~
wei5=1;+ @! X& \0 ?3 g8 w/ O" ]
P0=0xff;8 b- ]6 E: Z/ v/ Z
. c8 J/ I" d- @% C- i
: N5 z# m2 n, R+ |4 u; T P0=table[fen%10];
" Z. f9 U: e6 D wei4=0;7 N" L- E. _( F+ @) [% B+ I6 `
delay(1);
! k X% U9 z1 }) c* r7 r3 _ wei4=1;
$ L# T+ ]( n9 R0 G: l; r, O8 m" q3 c P0=0xff;6 W" W9 k2 b" _; }
# Q' S' \+ f$ b! g5 M* K& c) R2 E2 @/ U6 U4 r( I
P0=table[fen/10];" g" ~/ c& O9 o2 v4 P: g& [$ {
wei3=0;! X5 b! y! y7 d( {' q" ~
delay(1);
1 m ^% N; X0 q+ L$ `# N1 K: x# O wei3=1;1 d I5 E, d# d; Y7 `' X! i
P0=0xff;
' c$ F& h4 s5 h7 q7 I. ?( L q$ T; ~3 P, A9 M0 Y: X) e+ H; V0 }
4 N/ t5 t6 ]# p+ c; R# S4 P! k P0=table[16];$ T6 y( y5 \' ^
wei2=0;. k- H* A8 @. l
delay(1);: s. o- @, o M, ^8 H7 q$ h! T
wei2=1;
, o* i* W, o, R9 v, [, r! S P0=0xff;9 g2 c# j$ i( y
+ V' `& s9 a" i$ v9 Y
; S3 m- |5 D; r2 t* v6 I" E
P0=table[shi%10];
' _6 s' m: k. M; V5 M1 {: o/ N wei1=0;7 T8 e9 P) F5 q( U- ]0 X
delay(1);
# e$ q, t, R$ g. A6 p& D, `2 n wei1=1;2 ]% [8 v/ z3 O) d1 s6 M
P0=0xff;
9 H0 T* d. r/ f. J8 P8 U$ Z; Q9 O1 ]: [' }$ K
* u# F" E( \. p" D, J7 H9 r2 I P0=table[shi/10];6 y* w5 h1 C$ E* l3 A- J9 q$ i
wei0=0;
( f8 T7 h; M5 S7 ?* [" \ delay(1);
$ \' S: \7 G7 |9 W' p4 W+ w' E, ? wei0=1;
/ @6 w5 Q! V% n8 Y9 R7 e% j P0=0xff;
9 Q: }8 v; J, U! I}
% Y T5 A. ?2 g8 T$ z' c8 x
* ~$ U3 K* {/ X0 K. _
# ~6 F5 A& ?; \void keyscan() //功能键) {' M- g5 p+ W3 e
9 F# Q. C$ w4 k# ?1 |' S( g if(s1==0), F5 G4 } n, J
{( V o, T8 c0 F( K: O/ E+ w/ e
delay(5);
& t V- `7 D( ? if(s1==0) //确认功能按下1 m$ w4 K. R# {: @9 x. K
" Z0 \% [$ G/ | P; | while(!s1); # H- [+ {/ T7 @/ u" z3 S' n: I* _3 M) p
slnum++; //功能键按下次数记录4 z% l3 `$ G) P
if(slnum==1) //功能键第一次按下调整“秒钟”
8 c" x* }# {8 Q8 i0 ~- e {8 d2 i7 v! X! E1 r
if(flag)5 B3 V, A2 p7 D* M+ u9 b- E. d
TR0=1; //开定时器
2 c; {! `' t: w: W else6 U. K* m% I3 s. ?9 @8 H, I6 B
TR0=0; //关闭定时器
( o& D5 l7 y* Z led1=0;) M( U4 Z/ \: y# X( b1 B X8 [' T
}5 H+ S3 t; e. l8 ?' g# k4 a% r& m
( U% b6 b8 v- y4 [3 _( w ]! l. G7 K
/ E: ?+ P. c/ U
U! B) d$ g/ o9 [
Z& T& J6 q& v t6 d0 A- F+ q% ~1 v if(slnum==2)
; T8 t$ Z( g( t8 E; h( T! m {
) o& Q7 g" K$ O0 b led2=0;
- R6 Y3 q* _ f led1=1;8 v( w% S; H8 }% l4 B% G
}, D6 l% \. T* i
* l; v7 O' Y, {% F$ L0 F* [
% a9 k3 I% Q I, i7 ^( ~
if(slnum==3)
8 B% V0 x( ~$ C8 z# q+ z9 M {
3 y, O) Z0 `* M$ y8 ` led3=0;
8 v) u9 q: P% x) u& D led2=1;: E! c! ]0 p" u! D$ K
led1=1;7 {1 b Y: a, [' |! V
- w) E0 ]: K( f2 i3 @# l0 ?. n7 Z% Z, E: E) s! y
: K. C) X$ P5 u# A- l4 L# K8 M# Y; e
if(slnum==4)' s1 m) P, {: y0 d$ j d; m
F4 c; k" D% _9 f4 X; m led3=1;
% x' w0 W+ _0 Y1 u3 e1 t: V/ Z led2=1;" A1 R1 l; }( }& {
led1=1;
/ H4 k2 d& F* V% p* P slnum=0;; q" o( L: n' o# r* s
TR0=1;0 w4 \8 U# _0 J9 _ @
; t! b# h+ g7 ^ } J) x9 H% G `5 e; U4 Y0 c" Q( T6 l
0 ?1 O: z% R$ \9 I; f! N' A; s; B}
+ l) p% q1 j# x7 i. j# P9 {. U) _6 d
1 n# H$ Y' r* l# ^4 A: b
+ s, ^1 l) z6 h% G# U# Tvoid time(): o8 q; f) e5 u6 c |% N
: ? W. {1 Z( m4 l5 a% w if(slnum!=0)* P# H3 { z& b/ B) W7 {
{1 V) ] R; E* w: j7 {
if(s2==0)% I, o+ [" r% r- l$ Z
, ]: |! |/ a2 u$ Z4 b, b+ } delay(5);' U2 q; i3 @. h, P7 L7 m0 l
if(s2==0)
4 Z% C3 }' ^. A; _5 P& o4 `1 b {
9 P' M3 H$ R1 V while(!s2);1 s5 d; u* x) P7 K/ y% `
switch(slnum)
, n! \' P; h! q' Q; S8 l* r4 k5 u {
" i' U' ?! I; F; ^* C case 1:
+ N4 [, U, E) H1 \* ]4 I+ T miao++;5 x% D% d% B- I7 \9 t
if(miao==60)0 i' ] e1 f! K' J0 t9 U0 D/ r V- x; C
miao=0;
3 y; x/ P& b) v. n# [, l break;8 p7 P9 _! I0 s: i6 y
case 2:8 d7 ~7 Q$ K6 A' c' B. D+ I" h4 }
fen++;, ?7 Q& h# G% N8 T6 w1 `/ @3 V3 e
if(fen==60)
" M% F" g$ ? I& U7 r3 q u fen=0;5 }4 t4 \6 t. E- Z( @. K Z
break;0 q: F+ I% w8 X$ m. E# g* f& T
case 3:
+ [: a* g9 l. [ shi++;
3 Q G' \) U8 A# N if(shi==24)' A3 d7 p& Q+ f/ Q5 g1 n2 \% c9 \
shi=0;2 _5 S" q: n9 G% c% }# i: R* x. G% N
break;; f5 b/ x2 P. o8 T
! w/ e8 }! A/ V' W }5 G- K! a4 x i1 T% w
1 e+ h" O. X2 |' C+ X1 t( k7 L) ?
1 E+ H2 j& m; Y- H1 |) b; V5 m4 _% H) D3 ?8 q1 p
if(s3==0)1 q* _0 m7 C0 t9 f8 E7 K
{& i, `' F( C. h$ Q* C
delay(5);
4 S( N, S' Z5 F if(s3==0)' |1 D( F5 m) ^8 V! s4 J% q
! y# ]! x0 V2 {. @# a# g while(!s3);, P! Y+ W) D W2 \0 l
switch(slnum)+ H& H5 z3 Z+ b4 P; x6 i
+ k% }( D7 s' ]: F. H5 G: A case 1:
5 K' [/ k5 A9 V* h6 Y6 G. e miao--;# t f5 G- _+ b; e; e6 _0 D$ A$ K
if(miao<0)3 Q' e w2 d; ]2 ]2 M. A
miao=59;! R+ t" N" @ }& m3 z) l
break;" ^$ k) n+ |! f3 W2 }0 Z" ?1 V) g( u
case 2:+ r/ {, z/ [1 N3 @/ C3 O& L
fen--;4 y r. g/ G. p5 P% ^
if(fen<0)
' h+ M1 q, z/ a. a5 C fen=59;! W4 n; b& I: t$ }) A9 Y
break;
5 V% W2 \6 f3 J% p+ v2 ^ case 3:
; `; H- F3 i9 G' w$ N: T, d shi--;
/ T+ l" N8 I$ }; k1 i if(shi<0)
' f# ~/ C9 B* E9 G! e0 g1 W9 Z shi=23;
1 B2 G' N$ S# w8 _1 m# k4 e; o x& z$ f break;2 L, n2 u L& P' P+ R6 Q s
}8 U' W% x! u5 q+ C; p( D$ R9 ]
}; u; n6 T7 p0 O7 u
5 T) o) v8 Y& I( C8 {6 ~ }
' p: p( ^7 s/ _- @2 K( ~ }
0 `) ?) ~6 i' H Q void set_time()* F' g6 e6 j6 o- Y
{6 {: d; A, ^1 D2 U
if(slnum==0)
0 U1 D/ Y; z! y4 d$ B {
2 D$ _5 }4 g* S( o/ q" A) d if(s4==0)% j/ j7 t: x" |( t! X# ^6 y% |: U( }
( G6 N. H- {$ x% J3 g delay(5);
. k/ N+ {5 w3 D, t# n2 ^ if(s4==0)4 M8 I7 \ @/ o% Y- L8 U( f
{/ Z' j: R6 \! R
while(!s4);' I$ K) Y) W5 P; y/ Z
led4=~led4;
# Z+ \" |( Z0 N& _+ ?* W9 [, k flag=~flag;
* ^+ V2 y: p6 I8 m- S9 { P }1 [9 e) r3 L6 [( v7 ^* R
}% K1 @* }0 k2 J3 O1 u2 a- d! ^
}, a. M- ? D0 A& {: E* A
if(flag)
- u' U. U2 C- V4 b$ }! { {, s3 l6 g5 V( i. f
if(slnum!=0)" o+ d' U! g* K7 f; l. a
& }6 ~' C( ~$ P | if(s2==0)
2 f8 P2 e9 Z1 I% G3 o. h! ] {5 t- b' w! z( N6 H8 S9 N
delay(5);& |, I3 Z! ?0 U( m2 ~
if(s2==0)
* [* e1 t1 I# E* C {% e- w- p( l* p1 s: h3 r5 p1 [
while(!s2);: a7 p6 X1 G1 S; |" ]6 X/ ?0 F
switch(slnum)& g& u1 N, b5 b3 x5 O M
{# U) z( D0 L7 ~
case 1:
W) H5 j, e1 j) j set_miao++; y5 [& D1 D# r% { l
if(set_miao==60)
* ~4 E; Q/ ~8 e s7 q" H. S set_miao=0;
9 u' [0 {6 M$ E/ K+ ~" O- [& v* N break;- _, d3 [' L/ n
case 2:$ \1 I# M' ^' D' z; S
set_fen++;1 L7 z5 f2 t2 @
if(set_fen==60)
- p$ R4 V% x$ G; E1 ?& v set_fen=0;
# H9 p8 L/ O* }$ I break;- \9 k$ |$ D5 h6 q* V& ?; ^
case 3:! U) e3 {9 l6 F; v
set_shi++;
" h" H5 z# p/ A' C6 N& H5 ^9 | if(set_shi==24)& X' G' R& ~. P" L
set_shi=0;
& n: l# [: ]4 l. P break;0 K6 L: z+ {$ _ | _% u. O) ?7 ]" r
! G3 }8 u- a; N" i( A2 e }
5 Q0 _6 ^2 I3 S* e+ J }
5 M! x/ u d- _ if(s3==0)3 F6 z' V5 E: c! p
{7 J# s n+ i0 p+ _
delay(5);
* _$ {5 u. W. p7 W8 J if(s3==0)
: ` a0 h" i1 r9 p {
E2 K7 [, s: f y) } while(!s3);" i: v8 r0 i. P4 f0 w& U
switch(slnum)- N& ^1 ^0 J0 I" W& H
{3 S0 W" ~7 M8 Y7 i
case 1:
( `# @3 p8 G B set_miao--;* L! X/ j8 C) S& Z g6 c& `8 [
if(set_miao<0)
# U) m0 ?5 I; {5 \ set_miao=59;
( x' _& n# d0 {! y) e/ G2 V+ C break;$ r C5 M" y& e d2 d
case 2:
% w. Q& Z( O/ C+ E) C: E; y set_fen++;' ?' r- m% W( L' P ]2 K0 d Q
if(set_fen<0)7 M: `7 j3 U8 {* y
set_fen=59;0 T9 U: D' j9 J# c! T9 z$ o1 O0 ?
break;
( t9 e/ G3 q& ^7 _ V( ~; N case 3:
* B, Q* k+ O, ^2 t set_shi--;
9 g/ p8 ^) ^! D4 W4 c if(set_shi<0)
6 ^! [* H6 O3 l% B set_shi=23;* _7 J5 X( a5 K7 \1 S5 u3 f
break;, Q# z. b& s6 i$ L' J
) C$ x2 Z- x# L5 q E* a) o p }# W* z) H. I- A. R
}' v' r+ y- v8 k! x( d* G5 U
8 d6 w9 _3 L m1 L% v# U }! B% v/ r" v$ e% H& N
}9 ^2 o! x2 R4 R
void main()" T) H8 }0 j0 b$ c6 {
1 L7 r/ W1 r( z( b3 l' e start();. N6 G( m2 Q) S/ v2 v6 E
while(1)/ h' t+ G2 U/ ?; M9 _& p
{3 A- k; V. r" ~4 c& h
keyscan();
0 m. o+ f7 u" J' p+ C time();
7 x. X8 r; b/ P+ \0 Y e* F b5 h2 R% S if(!flag)
7 C9 b2 r9 i: M {
2 `( U/ Z+ \/ v. R1 W3 Z" G4 t display(miao,fen,shi);3 x/ q6 d. @+ n! J/ h
1 ]) Z. G- i' ~( x$ S. U- k else" ?+ c9 t2 `" |. X- ^1 T; u
{2 |) {8 P# s% Y: u
display(set_miao,set_fen,set_shi);1 P* g; \3 F3 u# `$ X u
6 ^, e0 X! ~/ j if(miao==set_miao&&fen==set_fen&&shi==set_shi), l9 P/ p9 x R
{ q/ M, o% j6 _/ i0 A. F5 f
TR1=1; w* k2 U9 A3 {5 \9 N
6 p6 \' f+ K1 S# K- ^/ F if(flag_time)" ?) r2 ]$ W, d s# Y
( ]% b: w; _/ `2 F' \; W TR1=0;
, u' ^7 k2 z3 [5 C# k, G+ M$ a BUZZ=1;
" W% J& m0 O* d5 o- c. G+ Q flag_time=0;# \! @% o6 [$ w( F, h
}7 E h- \* i7 Y& x# |# A1 B" z
set_time();: A9 V0 T& i2 L F' Q) I
2 l* Z" s6 ?* F$ s }
5 J: y8 D0 {! V: k Z: E8 k2 h y void time_0()interrupt 1& o$ ]- ?- O+ T) B
' \( ]/ B+ ~& q D4 P2 g5 Y/ A uchar aa;4 D% L7 @" ?4 J! G6 \3 s& Q4 [8 O
TH0=(65536-50000)/256;& f/ f' V2 X7 l5 v6 ?9 g
TL0=(65536-50000)%256;
/ U* }$ ]- I0 { aa++;$ v2 k$ X6 I' F
if(aa==20)8 F" q A. z3 y0 _* S* A$ u
% b( g5 ^: k8 p& n8 f! T0 R/ S aa=0;
" D) ]' P3 Y* R5 e2 D) ^: F miao++;4 `/ B! X+ v" q! |: t
if(miao>=60)4 @3 H, m) F9 b( k" n1 M, w B
0 K3 A: Z6 u1 e5 G, A) D; | a7 H miao=0;
' L* p( q) r% X! l' N fen++;
2 f1 i @1 r( O' n0 y if(fen>=60)# p2 V" b' ^" _ z2 }
{0 f# ]+ c _" Z9 \
fen=0;) @* T7 W2 B; F! W2 E
shi++;+ |5 b$ m) a4 M$ D4 u; x$ h' v
if(shi>=24)" ]3 v, {0 X* k$ k
' H. X& C0 S( M% O6 ^8 W. p/ p$ c shi=0;7 V) O* O7 `3 s0 P) `5 K: J
}7 C5 p/ P+ M! w1 U6 W5 ]& A9 y
}$ ?. R8 l/ h" D! w5 o i
}$ m" w# D a, t2 R) X
}2 b: @* W5 H7 z% T* E* s+ m
8 S/ a; T$ N& P1 z void time_1()interrupt 3 ' o. N" x2 [+ L }. ~2 J3 R8 m
{. p# Q- A% ~0 l4 z/ z: e! N" Y
uchar bz_time;
: S; _! r, ^2 `& g TH1=(65536-50000)/256;3 Z& |$ ~6 N& J0 d, e
TL1=(65536-50000)%256;
. k* L Z) D; z2 e9 \1 D bz_time++;( k0 ^9 L& ?! `7 j
if(bz_time==200)5 [ B+ s, ?- v0 S
2 A3 L! U' K$ A4 F" { bz_time=0;
3 ?. [$ \! K. O: Z7 ]$ c2 h8 g flag_time=1;
! x: Y* {: Z' @+ [8 y* o }0 x: z I( j# ^3 F y
BUZZ=~BUZZ;
% h' U! n% i1 A8 l6 C8 s" ? }
/ `& W2 h/ s' ]3 |9 Q/ G / t. ]& s- q7 G3 D C) H/ B% _
- t4 x# A7 G, c% G
) O/ e4 u5 j. a% e, M8 r3 ?
9 a2 c" n! n: P, g! q下载:
* t! h- _8 B, F5 |/ |, m& N1 B1 L8 ~6 M3 Y
' {( w0 q% S$ s# y4 g
