LCD1602+原理图+PCB(AD画的)+单片机源程序9 [5 b3 T3 e+ s
; ^; \9 _2 Q8 w9 Z1 o3 }
lcd1602的pcb图和原理图:4 j7 ~) K9 P* |6 p2 D' }& {. ?& R- K
4 i8 D$ K* S2 S( M& @4 r4 F
9 M e" x1 ]; [/ X! H3 z8 \1 N下载:. }' i4 Q7 K6 ?9 b6 n
" u; ]) c# s$ D H% W% N/ b0 w
# F8 I) P8 [( n- q. r) j
E" I/ k: f& {0 V0 C$ T+ x( U/ v+ v" r$ q1 K
; ^: h9 ^! a7 ~8 I8 n4 o7 V: }1 \
源程序:+ a9 `2 Y1 l& i' A9 I) K: _: @1 D
#include - x* V4 v0 m4 T" R0 h& G) A/ M
#include
/ W# W: B6 c! J Z# S/ X; h( H//#include "LCD1602.h"# C5 k$ B. k- {; \' S' j. A" k: X
//#include "DS1302.h"8 ]( E/ n* e0 i* H
#define uint unsigned int0 p/ {8 C i3 x
#define uchar unsigned char& y, h; A' W; y5 S
sbit DS1302_CLK = P1^2; //实时时钟时钟线引脚
9 s) R, P) s+ i* R% Fsbit DS1302_IO = P1^1; //实时时钟数据线引脚 + X9 N5 B3 V; J- v" k9 a, G
sbit DS1302_RST = P1^0; //实时时钟复位线引脚3 N# a( v. w5 E" K$ c
sbit wireless_1 = P3^0;- ]1 ]) }% x1 x2 x9 ~0 w( {" V
sbit wireless_2 = P3^1;6 z& H& I/ Z7 a5 J M5 @
sbit wireless_3 = P3^2;) G- Z% v" e$ R' M
sbit wireless_4 = P3^4;
% A+ }, d7 X( P* [# Hsbit ACC0 = ACC^0;' }. b* F: G7 K* m g
sbit ACC7 = ACC^7;
: Y5 Z% g6 Y5 D( \; N4 o4 x5 g1 bchar hide_sec,hide_min,hide_hour,hide_day,hide_week,hide_month,hide_year; //秒,分,时到日,月,年位闪的计数
* u* ^1 o1 ^7 [0 @( j" Tsbit Set = P1^4; //模式切换键
# P7 |" ~5 P9 {0 w$ e7 i7 @5 [sbit Up = P1^5; //加法按钮
. u4 n/ p% r+ `. `7 d" _sbit Down = P1^6; //减法按钮
+ b6 k( ?& i" q u# s. p$ ]/ G! i) Nsbit out = P1^7; //立刻跳出调整模式按钮
7 l: |; u' M6 d/ Psbit DQ = P3^3; //温度传送数据IO口# a) j* K0 S- H3 M
char done,count,temp,flag,up_flag,down_flag;
! g6 J. A8 d( M! d) @uchar temp_value; //温度值2 S0 L, }! e9 g$ I1 R8 ^
uchar TempBuffer[5],week_value[2];1 }4 }3 Z- [4 ~
4 C7 K& c1 |& h* }5 _2 t' m8 w/ [+ T! O" _
& b* ]) S' Y! C7 \* U- F5 a3 n8 M
& z# b5 N+ a# Rvoid show_time(); //液晶显示程序$ ?2 Y' o- T* j) R
/***********1602液晶显示部分子程序****************/
$ F$ s# S! `$ W/ R* g8 e0 _$ H
+ ~( |! U& B v( E" ` H7 Y; q' z, h/ l( v; M2 P
; h3 U1 x" M% ?. B4 k& X2 `
9 O6 I3 B! _5 I c8 {) M! P
//Port Definitions**********************************************************& w7 y9 A2 F2 @3 W+ A) ]" C5 u. J
sbit LcdRs = P2^0;
/ c3 l- J4 L& p- Y) qsbit LcdRw = P2^1;
- G& C w& P* j4 e# d7 ?2 fsbit LcdEn = P2^2;; @5 x; [) M3 h6 W$ G
sfr DBPort = 0x80; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.数据端口
$ T! P) }! b/ G
& G/ B8 C3 m5 v5 u2 X' R! W! o' B: E* [$ g5 c+ l3 X, v7 y
//内部等待函数**************************************************************************9 b K& J. z9 U/ E6 M+ T# I. R
unsigned char LCD_Wait(void)
6 `- ]1 D* O6 @+ i/ F{* m1 l3 e# k' g8 Q$ t+ q
LcdRs=0;1 B5 v: B4 g2 |' _5 b' ?& B5 n
LcdRw=1; _nop_();2 W' ]2 k9 [: Y; e/ {! x3 q: V
LcdEn=1; _nop_();
0 R' z1 S) |4 g ~8 P# V9 `' k3 V
2 d9 u) `2 r$ i' i; B9 g' G% | LcdEn=0;5 }( v* `- @8 C/ N2 u
return DBPort; & M( I& D0 R4 o: t
. _- f# y* M. K% ?- ^: F4 J//向LCD写入命令或数据************************************************************
& I3 x$ g' Q; U5 q2 c#define LCD_COMMAND 0 // Command4 h! l, v4 G4 w' u
#define LCD_DATA 1 // Data; s' I' w$ r, b* i, S
#define LCD_CLEAR_SCREEN 0x01 // 清屏# c) L7 s9 F% T1 p
#define LCD_HOMING 0x02 // 光标返回原点% V6 a4 X/ H2 Q6 _1 v- m4 ]
void LCD_Write(bit style, unsigned char input)5 N6 s% B+ f' z
& \; K; G$ p0 {3 f" \3 K" ~ LcdEn=0;
1 y; T8 h! w* `6 Z LcdRs=style;6 {$ U: c- F; r) y
LcdRw=0; _nop_();
+ u! j+ J, M/ C DBPort=input; _nop_();//注意顺序
8 P8 f3 |* ^" o8 n+ G LcdEn=1; _nop_();//注意顺序
+ a9 m3 p' k; Q8 c3 G) v LcdEn=0; _nop_();
2 I' W! c8 s: ] LCD_Wait(); ' P& n8 d2 L$ A+ G5 Y8 a( I6 r
}# ] ?" f7 W+ b, N6 M+ y0 e$ q* B
$ K2 \' n3 A9 s. ~3 d+ A p* d4 F$ R* H1 S
//设置显示模式************************************************************& v5 i" Y6 d% ]+ K. d
#define LCD_SHOW 0x04 //显示开% H9 o. c- q6 d) S+ ]' v& B9 Q
#define LCD_HIDE 0x00 //显示关
" r8 p' f9 J: h/ `5 T: B0 C3 c0 c( g& x1 a, L) c
, v% G Y6 A1 e9 ^#define LCD_CURSOR 0x02 //显示光标: Z) Z' j; `/ n" R7 R! u- R
#define LCD_NO_CURSOR 0x00 //无光标
7 w6 X- {5 |4 [. \2 H0 W$ F+ a
5 t3 p8 |' o3 U0 F, V# n. @* \' K% ?* V% c+ S( i
#define LCD_FLASH 0x01 //光标闪动
! J0 i6 Y3 C7 I7 E#define LCD_NO_FLASH 0x00 //光标不闪动' ]( A i+ n( o0 t1 a3 O) q, Z
: M0 B, ]- d! b2 T. h- v3 S( _" S0 W8 e2 C
void LCD_SetDisplay(unsigned char DisplayMode)3 F) k+ N: u% V
{& w* ]3 a& P1 Z" @& j; Q+ [
LCD_Write(LCD_COMMAND, 0x08|DisplayMode); , y7 y, M7 i% }
}/ v3 V6 w+ f0 z$ w) l" j/ T
5 k: s' @$ {: |8 _; K& t
; k( v) D* h6 c! R; |6 X# y//设置输入模式************************************************************
! v( {0 H- k" \ l) @& G#define LCD_AC_UP 0x025 W( n2 }/ ^5 A# g k
#define LCD_AC_DOWN 0x00 // default4 J3 M1 R; e8 S, j+ F. w1 F
Q5 R8 L8 x, t/ u9 R: D6 J! n, K& ^$ c; h
#define LCD_MOVE 0x01 // 画面可平移
& s$ v$ |0 C! k3 y3 O9 {5 W#define LCD_NO_MOVE 0x00 //default
1 e1 X) _0 n5 q& {, z1 N8 L8 O+ I: s1 H# \; e
9 p" Y) b4 N5 Y8 M4 C" B2 L7 k6 v% v
void LCD_SetInput(unsigned char InputMode)
; A+ R0 B' K: |{; o: x/ _+ k/ V( S! I" c
LCD_Write(LCD_COMMAND, 0x04|InputMode);
3 e$ o2 T2 c/ ^! U/ Z- ^}
/ x. G! \! E4 x. E9 d+ g
% o& S4 B0 n& h5 I0 s9 m; M# m! B, i- X& ^6 M1 G
//初始化LCD************************************************************6 e$ d! g5 j( V. E& [* g- C
void LCD_Initial()( {8 I( z' a" F0 T! Q& w
{8 w3 Z- b2 ]% M+ T
LcdEn=0;, ?+ A5 [; j9 o$ K, a0 H, W
LCD_Write(LCD_COMMAND,0x38); //8位数据端口,2行显示,5*7点阵' U: h% X9 F2 x, t
LCD_Write(LCD_COMMAND,0x38);8 e' k/ M: l1 Y: W8 j
LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR); //开启显示, 无光标
4 H8 A# a/ u+ F9 m! n LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏' @$ G' M3 B' O
LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE); //AC递增, 画面不动& L* t: |' ]- p9 V
}# |/ ^& g0 }6 Q* @
8 Q5 `9 w0 U7 N
& `0 B0 V8 ?2 _2 a//液晶字符输入的位置************************9 N6 m2 s4 a4 S6 x w7 ?
void GotoXY(unsigned char x, unsigned char y)
" e; }3 D; N1 I' L+ `) Y' ^{
- e) R$ p, g0 l) C! F5 ~ if(y==0)1 F! s' v* _7 ~1 d
LCD_Write(LCD_COMMAND,0x80|x);! G& z V! m, r' T* w
if(y==1)
; {6 O& L ^& ~+ }$ m LCD_Write(LCD_COMMAND,0x80|(x-0x40));$ o9 Q) h" ^; X/ j0 I
} G- P- N5 \9 a- ]) U" i8 A& F
3 o/ Z6 ~2 {- X( n
# m4 M# D* B6 u* ], ?//将字符输出到液晶显示/ G5 y, V1 r% j& g4 E A7 I% @, R
void Print(unsigned char *str)
: C* P) H8 o" ~/ l{9 q/ H. z6 l% f* l) Q K" B+ T- w
while(*str!='')! e, V9 p3 L2 J% G
{( _2 D% ^! I2 S7 M% Y! R7 ^$ J
LCD_Write(LCD_DATA,*str);
' \: |3 ], c6 k0 T) _6 }$ F2 t/ I str++;
# G# b3 r: G1 U. S: Y$ Z8 i }9 ?0 u9 t9 I4 q5 L+ x2 }& v
: [ Y8 I; f E* v. j
7 h2 y) j3 G4 A( Q
/ {* O. \) E5 x+ o. a, k/ k) o) l6 C4 ~) _# h! t- i4 r* u- V% K
2 v4 \ V( d* F3 p9 ^
. w" L" [6 m& C( l# B C2 B
* [+ v% q5 ~- Y/ U
6 R+ H( ]; G6 ]. i3 y
: `8 _" }8 ^& L5 i! l0 t3 H
: R2 U3 z# S/ r: o$ V3 D
" u2 n$ Y4 Z9 m0 c4 d: L* k- ^. r% _1 ?6 p6 o9 B2 C# D( t
: V) ]7 P+ O9 M5 Z- W* ]8 g
/***********DS1302时钟部分子程序******************/
$ l4 F6 O+ _' Q6 F) f% k" b% Ztypedef struct __SYSTEMTIME__
5 Y2 \9 w2 P+ t7 P{
/ b& u- p" e, H# ?( A, c! e6 A unsigned char Second;
' I5 q6 k3 n! e9 K unsigned char Minute;# D- `2 K3 x" j9 q3 X
unsigned char Hour;# q0 ~% B- y, H+ ]2 D' u
unsigned char Week;( V+ [4 c# |4 w6 E
unsigned char Day;
y- Q l/ Z" I6 ] unsigned char Month;$ r4 `( W% i; H: a# [
unsigned char Year;, c8 J. U+ G# Y# m
unsigned char DateString[11];
/ F5 J" R8 z& c0 i( C0 W8 R h- Z unsigned char TimeString[9];
& X" X1 K+ r& Y+ T. C}SYSTEMTIME; //定义的时间类型3 A2 i% k" X0 r( c) p, v: s# ~+ S
SYSTEMTIME CurrentTime;# z' i- v; P$ Z! S+ o4 a' E
5 ?1 L" [5 ]) G) e5 Q0 M- W9 [, ~. {
; L% M1 U$ t+ \9 X
) S" C1 b/ z+ k7 N7 I1 j" @#define AM(X) X
' W- M! D9 I% C! S/ Y#define PM(X) (X+12) // 转成24小时制
" n( q; x- m* `* u2 j#define DS1302_SECOND 0x80 //时钟芯片的寄存器位置,存放时间: }0 ?3 T, M% l0 h1 F$ E+ w4 c8 O
#define DS1302_MINUTE 0x82# R2 B& o2 z5 ?' a) }& R0 t1 Y
#define DS1302_HOUR 0x84 1 t( r% Z) u$ {
#define DS1302_WEEK 0x8A
1 C6 Z. r( p @7 @1 n& b" j#define DS1302_DAY 0x86+ P: ^4 E0 l1 o! k( i$ F; V, v
#define DS1302_MONTH 0x88
& }. k& i& O- y1 M+ N: s#define DS1302_YEAR 0x8C
$ Q% h1 f( i% i: ^6 y/ W
7 O& ~" M% j. Q) n+ k. K0 ]5 l) m; z4 ^7 N/ ?! x7 A+ Y" \! f
void DS1302InputByte(unsigned char d) //实时时钟写入一字节(内部函数)' E$ U3 |8 `5 Y4 o$ ]6 J) t- s
{ . g! E$ G4 {1 b Y/ m* M
unsigned char i;3 o" N! \6 A. C" m
ACC = d;% g- c8 C& h x! J
for(i=8; i>0; i--)
* z+ [! h8 n) q; ?/ D2 F {) ~5 z; S1 o. R! `- v. N. j! _# n0 b
DS1302_IO = ACC0; //相当于汇编中的 RRC9 N8 P# e1 h d+ C7 Z( W
DS1302_CLK = 1;
0 _* B3 ~$ D- W DS1302_CLK = 0;' H/ ~3 G/ R" Q. }+ n n
ACC = ACC >> 1; ; m$ Z- R* B5 v% G
} / Z- ?. b2 @( e; [
7 n9 ]- i/ a# L8 }' C* l
; E: T$ g1 L* q n1 e
: E# z- T* l+ Hunsigned char DS1302OutputByte(void) //实时时钟读取一字节(内部函数)
4 |5 y" e; r) I% z{ ; c/ e) v( I" Y& Z
unsigned char i;0 I$ x4 O7 N4 U" S6 W- S
for(i=8; i>0; i--)/ E& ?1 y; L2 p0 I% u1 G. e# a
4 j; I/ x- j! c7 l. i, I& K ACC = ACC >>1; //相当于汇编中的 RRC
$ }2 [! w% I" \: i ACC7 = DS1302_IO;; J; S$ h" l6 }. V) H b. n1 o
DS1302_CLK = 1;- C2 o; ^3 h, N4 I$ n+ Q
DS1302_CLK = 0;
8 q& i7 S8 J8 ]5 b; v }
3 i' X1 ?# l+ G return(ACC);
, T8 m, s6 N0 k/ E2 r}
9 D3 N( h- ?) A& C. n5 _8 {7 H# e; K3 k4 h& H9 d* A$ e V7 p# ^
" |7 `- I% `" R& Q: b
void Write1302(unsigned char ucAddr, unsigned char ucDa) //ucAddr: DS1302地址, ucData: 要写的数据, \+ O7 f6 j; u
" v1 U: O8 U4 `0 P DS1302_RST = 0;
5 Z9 j( Z8 y/ u, g9 w0 E DS1302_CLK = 0;
8 C# w, I7 n' D# I* \ DS1302_RST = 1;
2 ~& F0 J6 z* y9 P" t DS1302InputByte(ucAddr); // 地址,命令
: M3 v+ C% b$ @4 K- F; L; L DS1302InputByte(ucDa); // 写1Byte数据$ l0 u2 A/ n2 h" V7 }8 ^
DS1302_CLK = 1;
/ A' L$ Y1 @ [& z7 Y3 d DS1302_RST = 0;
# ~! i O: m4 a6 I} 3 ~: t8 \- [9 _# t) s
! ?) D; E" C8 q* ]$ [& t' x0 x9 Z m& I3 w0 f J; e3 v/ |5 {
unsigned char Read1302(unsigned char ucAddr) //读取DS1302某地址的数据$ k; r; k' V# L5 l( a
- q6 R5 o9 x% M/ Y unsigned char ucData;
' F* k+ P( @2 X- i5 P$ d DS1302_RST = 0;' }! z J* P" R8 @
DS1302_CLK = 0;
P5 ~* ^6 L. _! ]+ B) D2 L4 ?! a DS1302_RST = 1;
3 A9 }/ ~% b4 |- F5 z) Y DS1302InputByte(ucAddr|0x01); // 地址,命令
. \" {7 H- v, D2 t6 z# P& x) U ucData = DS1302OutputByte(); // 读1Byte数据* N; A3 p% j+ Y2 \: D$ D8 x! Z2 e5 u
DS1302_CLK = 1;7 V% A# }/ q9 Z% @$ d
DS1302_RST = 0;% q9 _4 v" G r" y
return(ucData);, l) o2 q" K) @4 |+ j- `& `2 I2 b: |
}+ J! \! F% v9 [: X
8 ~8 [0 y; F# J: p B
+ n7 T- Y# E& q" _ J& s& D" w3 L9 o4 h$ L# ]7 ]5 N
% p6 S& F- j& Q! E6 E V1 _0 t- f
% o- Y/ ]5 Q! m" o% S. T9 g- G; P0 L; v6 y
void DS1302_GetTime(SYSTEMTIME *Time) //获取时钟芯片的时钟数据到自定义的结构型数组
& h6 _9 P1 s8 r6 v0 K{, ?! t ?! E, s0 x- X; [8 `
unsigned char ReadValue;
6 B7 ^! L( x0 Q- V% w7 q3 ` L$ q ReadValue = Read1302(DS1302_SECOND);5 ?- Z8 n, I5 ?7 r7 \4 ^
Time->Second = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
" {, l; U& W* v0 Z ReadValue = Read1302(DS1302_MINUTE);
0 l( S5 G) K! E% d. n4 c* P4 s Time->Minute = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);" a5 d* D& g3 ~6 f( H0 m
ReadValue = Read1302(DS1302_HOUR);
1 a/ K9 ?3 g$ Z/ ?7 z8 X7 K Time->Hour = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);3 M9 c; u) }' {$ k3 ]7 v
ReadValue = Read1302(DS1302_DAY);
8 E4 E( P8 X; i" F$ v" Z Time->Day = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F); / C% K# b% {0 P+ W- l+ o
ReadValue = Read1302(DS1302_WEEK);5 D5 m4 m% I! u$ c' v
Time->Week = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);0 V0 O/ X3 J! k5 T4 Q
ReadValue = Read1302(DS1302_MONTH);5 f0 U& | Q. ^% X( M8 t" t
Time->Month = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);3 |4 W* }1 O+ c7 _7 ~8 S9 J
ReadValue = Read1302(DS1302_YEAR);: |' C0 ^: H" v! ?8 Q
Time->Year = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F); & b; N4 j5 A3 Q7 m
}0 e" g. H6 `$ t( C2 _- u0 e: N' \) @
! R! s/ e! ]5 C# `0 |$ B2 s0 G* w3 S, Y
void DateToStr(SYSTEMTIME *Time) //将时间年,月,日,星期数据转换成液晶显示字符串,放到数组里DateString[]
" J9 S6 S% e6 _) X u{ if(hide_year<2) //这里的if,else语句都是判断位闪烁,<2显示数据,>2就不显示,输出字符串为 2007/07/22
5 |: _. @3 p- G8 Y { - E: B' ^2 S% n: q
Time->DateString[0] = '2';* c( w' X6 Z, ]5 {! z0 Q& x# }
Time->DateString[1] = '0'; , p! q6 ^1 N$ L. T! Y- A& x2 C2 X
Time->DateString[2] = Time->Year/10 + '0';! m+ l3 ~2 V2 o' ], l! n4 ?
Time->DateString[3] = Time->Year%10 + '0';
3 }$ M+ M" l, c/ ] V }
! j4 K: Z0 K3 b0 r else
! ^0 Q! I/ p9 F: W/ ~$ l { % R( q/ M0 u* \% Z0 t, U
Time->DateString[0] = ' ';7 j/ ]( R8 _1 G
Time->DateString[1] = ' ';
/ v4 r" {; E/ k$ ^) m2 H- C Time->DateString[2] = ' ';( v8 T; U2 J: s" y3 c
Time->DateString[3] = ' ';9 i' T' [$ R$ |. K& X
}( r8 n) K. A; N6 e( M- u, p0 F
Time->DateString[4] = '/';
4 B, ^; r$ B6 p3 V( r if(hide_month<2)
3 ]3 @. C$ E0 x* i {2 ]* E! N: n/ ?1 J/ H; D
Time->DateString[5] = Time->Month/10 + '0';6 N5 g+ H! R4 x! ~! o
Time->DateString[6] = Time->Month%10 + '0';
/ ^2 ]& [3 P0 Y2 q9 y }
5 Q% Y+ E4 _5 R else0 {; m) W8 m$ H, Y- Q2 ]
5 V% D# J" e2 }- n) t2 R Time->DateString[5] = ' ';
% v- A) L' T7 o/ _6 ^: E Time->DateString[6] = ' ';
8 x( S, _; e- K3 }3 C9 \# {2 O }/ A# N8 L( {0 }0 ~
Time->DateString[7] = '/';. ~% j. Q6 m% w. _
if(hide_day<2)
; @! ?* O% K+ P d {
& O3 L6 U3 I. P( S( F( T Time->DateString[8] = Time->Day/10 + '0';
, \5 a0 B+ W7 l! k" o7 C# c$ O Time->DateString[9] = Time->Day%10 + '0';: ^( Y( K1 w* G
) D" w( [& Z) s0 y0 J else b# A/ c: `7 ^( L
{. `) e" O: N' T {( u3 K" {
Time->DateString[8] = ' ';
8 O+ p& ]! S- P Time->DateString[9] = ' '; + z7 c' t6 |) O5 A1 G: p, O0 `
" ?( D/ ~2 o9 |! h: D3 { if(hide_week<2)4 @. ?9 m5 V( h+ K: N$ {6 ], n+ ~0 z
{5 }: P1 {$ C$ V2 P, x2 e9 o- q/ r
week_value[0] = Time->Week%10 + '0'; //星期的数据另外放到 week_value[]数组里,跟年,月,日的分开存放,因为等一下要在最后显示
+ S6 m# B3 ?5 y" m: M! j }% o5 \ ]+ \0 i1 k3 t6 }0 R
else
; c2 L+ M$ L* z3 b8 O {
6 l. Y- J" r+ [% p& R4 w. n week_value[0] = ' ';
7 d; r% x' l' z4 U* Z; g! c8 _; E* c* w+ O }( f" K8 J7 e4 v$ W
week_value[1] = '';" T5 Y7 b& {1 v. m E5 ^0 ~3 `
}" @2 G6 w4 A) r3 ~
& z. g, s0 U; |9 t5 | Time->DateString[10] = ''; //字符串末尾加 '' ,判断结束字符
6 a- N5 u; o6 y/ P W% I+ m}3 Z; z1 M$ @, T
; F' c# o7 T4 `: q
7 L9 Y8 y! `* u& d9 F* Bvoid TimeToStr(SYSTEMTIME *Time) //将时,分,秒数据转换成液晶显示字符放到数组 TimeString[];
: p2 f+ u/ h* O{ if(hide_hour<2)4 l; r5 R8 o5 G. P3 N
1 ]9 }3 ]0 t; q Time->TimeString[0] = Time->Hour/10 + '0';
! Y& x$ B l3 s* C2 i Time->TimeString[1] = Time->Hour%10 + '0';' J6 A% H& r; U# t9 m: U
}# E" B! \3 I. y
else$ |4 \) n2 `/ E
{3 E- _; y( Z2 N4 y
Time->TimeString[0] = ' ';
+ r5 _6 p$ S& V Time->TimeString[1] = ' ';
, T2 L4 a' N2 p6 v0 k# e" s" V }; v6 ~) d/ o1 R1 J d' Y
Time->TimeString[2] = ':';
_; o7 ~9 f6 r, X1 }' Z1 J; j if(hide_min<2)
' T4 `, E/ M' @% P6 ?: B {; T- n. T! Y' z& T2 p
Time->TimeString[3] = Time->Minute/10 + '0';
# y# `( Z' X5 ^4 m Time->TimeString[4] = Time->Minute%10 + '0';
: a1 J5 k! j$ O& Y, y% ] }
) i/ q' j0 p5 X1 l$ @- \ else& @7 t; I( `/ V/ I! K$ e5 ]' v K: k
: \+ ~6 C' O4 ^4 r7 v Time->TimeString[3] = ' ';
) p8 e0 Z" H1 W p8 h) l Time->TimeString[4] = ' ';
* S: E3 B4 C; m& k" y# Q }7 L3 k. x* S, E' W) P+ l# P- Y6 u, i
Time->TimeString[5] = ':';
( j- m6 J4 m7 z" a' X+ Y if(hide_sec<2) _# t2 ~0 m8 m, S5 N, n- p
{- u2 w }* W$ c0 x" R/ a0 x2 H
Time->TimeString[6] = Time->Second/10 + '0';
/ u9 I0 D9 \- y1 V7 m Time->TimeString[7] = Time->Second%10 + '0';) y8 p. c/ S# W" B+ s4 T$ R
}. _7 {* q9 U! i+ J/ |( ?
else# F% {7 K9 T$ ^% ~2 J
* \1 y5 p' i2 S, _+ C8 x Time->TimeString[6] = ' ';" T* J, [3 c$ S/ e- ?+ |2 S1 f+ d
Time->TimeString[7] = ' ';3 r' q$ ^" E) Z& P% k5 |7 x- r
}( g* p/ m5 l* {
Time->DateString[8] = '';5 S( S' Q' L& S
+ s8 Z: o- r0 ~* Y; ^/ @. p" Z: u; g
( r# z& c0 t. x8 G( }! x- h" z W8 n1 p* T8 i; O
" ]' M b3 ?, ~' m( |# C: ]
* L& @6 y3 M' c& ~. K& ~void Initial_DS1302(void) //时钟芯片初始化
. c3 Z6 a; A9 I/ S{ b; W% k2 Z6 T9 w- K( f
unsigned char Second=Read1302(DS1302_SECOND);$ I& D' ^5 `+ ?* _# H+ V& W
if(Second&0x80) //判断时钟芯片是否关闭
. I' c/ j- y0 S4 x* v. z: S {
# v4 f' }' Z* T) R Write1302(0x8e,0x00); //写入允许" M1 N! i/ X0 A- O6 f
Write1302(0x8c,0x07); //以下写入初始化时间 日期:07/07/25.星期: 3. 时间: 23:59:55
0 F: e9 T) y$ D# r) l5 C- ` Write1302(0x88,0x07);
3 t4 h y0 m% N9 K+ H% m0 v; c Write1302(0x86,0x25);% o ]: e; d# E4 Y
Write1302(0x8a,0x07);
" v4 I: I. y# W) V) g9 G L Write1302(0x84,0x23);( s4 A' H s* a
Write1302(0x82,0x59);! R& X9 ], Z+ r2 c t' O
Write1302(0x80,0x55);% C2 e8 ^: G; F% g* _
Write1302(0x8e,0x80); //禁止写入
9 \. m9 i/ O2 j: P9 H, w }, _0 [3 q) E% |
" e4 [; [: h/ a2 l* t$ Y! U4 _; v [8 n* M) c4 [
}% L- W6 n e. F% v n& ~
: K( ]9 \/ W! V w! c) i, H
' b7 I8 T9 M/ }) J/***********ds18b20子程序*************************/
4 A) ?6 n( m+ h; f- c/ u2 Y3 ?
' h% j/ E8 k. ^: y! E- l6 p4 V# r6 p A; w
/***********ds18b20延迟子函数(晶振12MHz )*******/ , z1 A* ~8 n/ Y3 K. @' ~9 r
# e6 Z: `4 H% c3 D1 ^6 K
4 P3 X) K, Y- Y0 k! e. Dvoid delay_18B20(unsigned int i)* p& r, [7 H' {9 E u
2 ^) Z, _& i7 H8 }$ e while(i--);+ A$ B3 ^1 _! g( R0 l' |8 J
8 J/ Z, Z- f1 K+ r2 v' z, ~
! s% B" j5 Z) R! x/ I8 I9 Z- h. G7 S2 A2 |) {( {
/**********ds18b20初始化函数**********************/. b: {. A% z2 d5 X' @
8 Q4 ^% H- J* x9 D
( l# n9 a) D9 {, O
void Init_DS18B20(void) 0 u: i4 ]$ H b
6 Y' @: }! I" `4 ?+ F& }* P unsigned char x=0;
- ~7 F' f( H9 m: Q5 x DQ = 1; //DQ复位2 }$ B( H- M# d0 B$ P6 G* f! P9 n
delay_18B20(8); //稍做延时6 v7 D/ x( W1 f/ d* p
DQ = 0; //单片机将DQ拉低6 f2 n; O4 G6 V' t
delay_18B20(80); //精确延时 大于 480us
$ k+ W5 n) w* b$ a DQ = 1; //拉高总线. I7 K1 ~0 h, Q* {$ @: b6 ~) [
delay_18B20(14);
: f# {' r3 N( q2 x% B x=DQ; //稍做延时后 如果x=0则初始化成功 x=1则初始化失败2 F" M5 q, W6 e3 Y
delay_18B20(20);- T- T" ~1 Z% h. H( K1 [; ]
}2 W" h& i/ o7 a# K
& A/ I7 }' s$ l' L I! ~/ f. P4 n, \& u" M# i
/***********ds18b20读一个字节**************/
# U: R8 j+ H; c# D& |6 |& A
! c& P) p0 X8 }: E
' I8 U$ J$ c3 ~) E; qunsigned char ReadOneChar(void)2 h) P% Q7 a' k6 d; g
{9 b* [7 k- Q6 J6 ~0 o, e, K7 d
uchar i=0;* g# T; R* J' } X, T
uchar dat = 0;0 Y4 m" l9 B7 b6 s9 |2 @. l5 P
for (i=8;i>0;i--)
4 _5 |5 d& i; I' Z5 T4 H9 C {, P" p3 `/ f; D. R( T: Z( D
DQ = 0; // 给脉冲信号
P, p$ {# Y3 j+ y' D dat>>=1;' F) H9 l2 K8 ? j' Y$ F
DQ = 1; // 给脉冲信号
. y1 C8 q1 P# m% C if(DQ)
. w x. {* p5 {4 Z! l' F dat|=0x80;- @- S" \; S7 o
delay_18B20(4);
, r7 c; d7 [2 W }6 c* y# m" z6 ^7 J% U5 B( b/ v
return(dat);* T& ]6 K4 {$ f1 T) L
}8 k C' X* j% @) \! W
$ X( Z5 V& f3 X/ {) J
+ E2 H9 \8 H3 ?% k' X" g; g' i/*************ds18b20写一个字节****************/ % `/ c0 C, o) R3 P9 ^ M% ^
& j2 M& V/ B2 f
2 i( `0 s8 {* b2 S+ hvoid WriteOneChar(uchar dat)1 r: |& ^1 e O9 l* e2 i
{( S7 K. @$ [) I! @$ F
unsigned char i=0;6 ?' H9 h# t; e
for (i=8; i>0; i--)
3 }8 V! H, m! M {3 y9 d+ D/ W% o- p) c
DQ = 0;
2 ^6 _" ?: T* r7 c DQ = dat&0x01;" v; ], v" v w: F! ~* h9 }
delay_18B20(5);
8 }8 `2 a( \, i* ~* X! s DQ = 1;6 H5 F* C0 U! x2 v" L& d* S" P
dat>>=1;8 x* f6 b6 d2 m) a3 f0 Y1 E. ~- Z
2 n$ j7 M* q1 Y) @. w}4 Z9 j1 X2 L4 u: B% P6 Z
* @4 G9 T* L& y! b3 X" ^5 P
3 p) z8 ^: ~/ g; e/**************读取ds18b20当前温度************/0 m8 u& A D2 K$ K/ i
o/ |' d( w' f2 q$ }/ D# F9 r
" q( I6 R L4 Q* uvoid ReadTemp(void)* i! `+ `4 [9 s' L7 V
+ D _. i4 W; q, y. I unsigned char a=0;/ @9 Z) c& ^" {, ]
unsigned char b=0;
1 g0 u2 t3 L, o! R; w: n$ g% h0 Y unsigned char t=0;; B, i6 E1 O- a j
& e% C# G- k: Q, T8 M: V4 K
5 [4 r" _0 [* z3 K, F8 P* ^ _ Init_DS18B20();* c# \$ ?2 c$ S5 B8 V7 \7 l+ Y
WriteOneChar(0xCC); // 跳过读序号列号的操作
* B3 _( j; z, @: K0 t1 B1 x- S2 q WriteOneChar(0x44); // 启动温度转换5 \! E- ]# _/ e- m m% j
* \0 l6 I/ a2 B: ^; d# d' M
( T d' m1 y- y' W6 Z5 C8 p' s' v
delay_18B20(100); // this message is wery important C$ ?8 b; M& I
' v6 [/ l. r3 X) a/ B k* P" K5 c( i" B9 d
Init_DS18B20();* X6 o9 w0 x" z7 w+ I; r
WriteOneChar(0xCC); //跳过读序号列号的操作" B5 h- ?: Q6 x" |7 K8 ^
WriteOneChar(0xBE); //读取温度寄存器等(共可读9个寄存器) 前两个就是温度
. T; z3 p+ I6 j+ _$ y2 |
' ]4 u2 r [ E. o C9 C e$ b- \( i# m4 m; H: j- E
delay_18B20(100);0 H" s: R' B0 E1 |" K) ^5 A
2 V) v! W4 l! v
* o9 c3 _8 j1 {4 \) t" E a=ReadOneChar(); //读取温度值低位
4 L9 E% g$ Y- C% w b=ReadOneChar(); //读取温度值高位. \2 k' o% ]! A- C7 j* w
temp_value=b<<4;
7 Z& h" O$ X3 e) y temp_value+=(a&0xf0)>>4; 7 x h1 j; u* J2 R
}5 N- x: E7 G% }; i( l
void temp_to_str() //温度数据转换成液晶字符显示8 b8 M, Q8 f# \" U
3 H4 g% a; E' y0 }! B TempBuffer[0]=temp_value/10+'0'; //十位
: J- }. {0 ~3 i TempBuffer[1]=temp_value%10+'0'; //个位
: d) `' a# Q1 o9 v+ K TempBuffer[2]=0xdf; //温度符号7 F! ~( v7 Y3 v* y9 P
TempBuffer[3]='c';
: b6 k% |( R+ a% `. O1 h TempBuffer[4]='';5 d6 y) r$ ]0 }% P; q/ U6 ]1 X
3 p( |+ p) e0 S/ d4 I+ W, o, Q7 kvoid Delay1ms(unsigned int count)
4 y7 [. ]" z# B6 k{1 j9 V! G9 G; O! |( N# h
unsigned int i,j;) n( `/ P+ {. q* s. @
for(i=0;i<count;i++)
5 g, D- b8 s: ^ for(j=0;j<120;j++);
' d, G, ^: ?( l}+ _" y! F) G4 V; O7 G% w
0 |1 M- W1 _& |7 P& z, y7 V
' W6 F0 Q. O7 H5 B
/*延时子程序*/
& e7 R8 P" Z) M& A% V+ Y+ F, ?* r* `void mdelay(uint delay)9 _- D, R! ^' x( p( l8 h2 l& S
{ uint i;
. M! K6 c; N1 } for(;delay>0;delay--)
6 M% }, f* r5 ?, {& s {for(i=0;i<62;i++) //1ms延时.' N: O5 l+ s7 [( ~6 z5 a
P3 q/ d5 O/ d- D" [ }: h% O$ h7 z5 J6 P( k v( w4 w" \
0 h9 v; t* o' f( i3 n3 R1 Z {
( u! W0 t: g7 L4 ~- t2 H
|5 p1 H' x: C: c8 O+ B: e" J) o# K% s: [# v
+ v6 ?2 [: c5 X0 R; P6 d/ ovoid outkey() //跳出调整模式,返回默认显示
3 n C0 m7 J" T6 K7 d! V- N{ uchar Second;, k5 h* i" i# b. X, ]
if(out==0||wireless_1==1) - `! r u: {/ o' | o$ g5 T
{ mdelay(8); * d" x* I' h/ Q' _% |9 A* _% G
count=0;
6 T( T; b* C$ S+ ?/ B( f. h hide_sec=0,hide_min=0,hide_hour=0,hide_day=0,hide_week=0,hide_month=0,hide_year=0;; c, C. K9 ^' x1 ^
" I" V6 n$ [* g* x9 [ Write1302(0x8e,0x00); //写入允许
3 l) @0 z) B, g6 D3 w7 Z: q Write1302(0x80,Second&0x7f);5 d" L: K$ n" b' |8 [$ t
Write1302(0x8E,0x80); //禁止写入3 G% ]" e5 |0 y' z
done=0;
* y% w! C/ q) N while(out==0);
& [3 U, a6 Q- l* k2 r while(wireless_1==1);
! Y6 @/ ?& \* M5 y6 ~% u }) A5 z/ x! Z2 r1 L
}& m! R4 |1 u+ v: l, G
////////////////////////////////////////////////////////////////////////////////////////////////////////////: h0 @- t q! z8 Z3 Q" S6 ?
void Upkey()//升序按键
3 \, V6 M" g6 v6 {* w; B( T- W{
; d% v( Y% a. U5 y( p: f Up=1;% T+ \) U7 |, d8 q7 K) k
if(Up==0||wireless_2==1)
- @0 L# f6 }9 S# V) G7 C {
" {1 u1 d. m$ P$ {4 e; H mdelay(8);. B1 Y4 i6 n" n
switch(count)2 s$ C1 f# R q% e9 e
{case 1:
' f9 U1 G/ n" N! z0 p temp=Read1302(DS1302_SECOND); //读取秒数
^: u+ u0 c0 A+ o0 p temp=temp+1; //秒数加1( v9 d5 [6 Q7 I! b- ]
up_flag=1; //数据调整后更新标志
8 ^6 s) ~( V- n3 p if((temp&0x7f)>0x59) //超过59秒,清零
) e! R3 a, K- v8 [ ]% D temp=0;
6 [) i, t& M! L1 q3 |5 e break;
' B3 u, [8 o! I; }" v case 2:, V0 d# W) P; z% k
temp=Read1302(DS1302_MINUTE); //读取分数
; }2 `0 S/ E" d7 `! z' } temp=temp+1; //分数加13 O& ~9 Z1 n$ m; \
up_flag=1;
: I9 e4 U2 _, c3 T if(temp>0x59) //超过59分,清零
8 I h. Q; g( d' v5 T r% p temp=0;
/ n8 U9 Q9 h0 ^/ p: K; ^ break;
" B& d$ l! k: ?5 K t% M4 L case 3:/ C, T6 c0 a5 r0 ^5 a
temp=Read1302(DS1302_HOUR); //读取小时数
* e% X4 e1 ~, o# a" j0 l temp=temp+1; //小时数加1
5 y( o( I* B2 ] up_flag=1;# D. V$ A+ Y; P5 H# G/ p* s& I
if(temp>0x23) //超过23小时,清零$ d, c5 z* q- i% `0 e
temp=0;
% w# R& M1 c3 l8 r6 v break;$ Q4 k4 A- ^, l, l) @$ h8 ]) ~3 L
case 4:
- M6 I) r7 B- p- v. k2 ^! M& d& _2 o8 m temp=Read1302(DS1302_WEEK); //读取星期数* [# g* Z6 z/ W- b0 @9 m6 s6 ?
temp=temp+1; //星期数加1
! K N1 J7 c2 R: q up_flag=1;$ {1 w- f6 J# c0 S; ^6 @# J
if(temp>0x7) 2 s: W, R; z( F" T" q3 F
temp=1;1 H M% f& o6 F& I9 D' w! R
break;
# X2 E1 \ U T0 I3 X case 5:
" a% Z% p9 ~* n; Q6 \# |& p temp=Read1302(DS1302_DAY); //读取日数
3 F# ~4 ~4 t* n. a$ d* e1 | temp=temp+1; //日数加1& m8 ^! @8 F V% G; r
up_flag=1;. a9 Z% L9 O9 G9 {7 Q& J" M) U7 @( }
if(temp>0x31)
7 L Q5 J% |; W7 K2 W- K' Y temp=1;1 k2 F$ v6 k& X7 o* Y3 y
break;
% K& ]6 v1 Q# A7 ^( ^ case 6:
Z9 S4 y$ c+ X1 n5 {8 Q7 z/ B temp=Read1302(DS1302_MONTH); //读取月数8 B. h; l8 ^ ?& H3 x* ^3 A4 f# j
temp=temp+1; //月数加1/ f* ?: Z6 |' L! v7 ^8 d
up_flag=1;' C* G( D w9 T0 w) y) x
if(temp>0x12)
* u+ A7 v( k4 H% s { temp=1;0 o Z" b. w' ~% J. `9 q$ U
break;
/ v$ }% h# m/ s* j case 7:
0 a; ]! f1 A2 I2 r temp=Read1302(DS1302_YEAR); //读取年数3 I5 f/ c v$ W% j/ c* F2 ~
temp=temp+1; //年数加1
, h/ Q) x! g- T7 c6 |& K up_flag=1;
5 | K6 p1 I- y& f if(temp>0x85)
$ |0 `6 g* B: |' l* r! g$ Q temp=0;
p8 t1 c2 | F/ w( F5 f8 } break;
0 {: ^( r+ ^- r1 ~ default:break;9 D7 e9 Q. R+ ]$ g0 z
* r% ^$ J, @$ V4 }
1 C4 `% @9 [) W: o- K1 B while(Up==0);! M3 B7 J4 y* n
while(wireless_2==1);+ C) H* ~& e7 }& f5 K8 ~0 h7 `) ^
% i ^/ x/ `$ D/ M}' b5 t& I( P+ N; y( h( B. n- |
' b# Y7 K6 ^% @: w; U: c
5 f* E! J- e/ M V c////////////////////////////////////////////////////////////////////////////////////////////////////////////
+ G2 T% `% U- Y' g6 ]) Xvoid Downkey()//降序按键$ q: s/ ?, J8 L4 `# h( D7 ?
6 Q! b' o# W2 r) K6 E- W5 G Down=1;
. k* ~. O7 R2 } if(Down==0||wireless_3==1)8 Q' s- M2 D0 c) G$ M% f- `" b' D( x
. _+ s" F( d* _" u5 A mdelay(8);9 U0 h$ e2 ~ |
switch(count)
, v$ V* @# R' e9 S$ f, k {case 1:$ \4 x( u8 a2 L
6 p3 N) \3 J; Z! g: Y/ T$ Z temp=temp-1; //秒数减1* E$ Z/ M3 u% q6 o! @
down_flag=1; //数据调整后更新标志
' O* b8 E' i+ |8 ^ R! @ if(temp==0x7f) //小于0秒,返回59秒
6 K8 m% b6 w) K temp=0x59;0 G5 P r8 x4 ]+ U% U! W$ w
break;
8 {: Z7 z3 B) j' g9 B1 \+ m case 2:; ^" x: F, s# r; Q- y2 s
; q# c7 P' U2 B" e. b temp=temp-1; //分数减1- `7 j- W& D( u- N7 t2 R4 M
down_flag=1;
: [; l, j; s2 Q. F. X if(temp==-1)
3 a: \% M8 U( P temp=0x59; //小于0秒,返回59秒3 N5 S: w+ c+ \
break;: d( \& R% n1 y( U) \
case 3:$ V$ @8 m( Y' L9 K+ s {
temp=Read1302(DS1302_HOUR); //读取小时数/ p+ O- P0 q7 X0 D2 f; x
temp=temp-1; //小时数减1
# k6 Y' y4 R) E& y5 t3 l down_flag=1;" D" [2 h: ^. e" g3 s9 b
if(temp==-1)- B6 S; |5 }9 `
temp=0x23;4 p. p8 w9 @# x0 g
break;
" s+ h+ |6 q. I: j, @ case 4:
6 c* v6 f& Y3 J8 n5 j4 C temp=Read1302(DS1302_WEEK); //读取星期数
$ ?% w c9 p# m9 b% u temp=temp-1; //星期数减1
/ U& x( Y' }% V8 r$ I( A. x down_flag=1;
( s6 U0 n0 W, q! }. _1 o. T if(temp==0)
2 M5 k3 E( f+ Z3 G' i* q temp=0x7;;
5 r# k4 w1 |: \# T) }; S, W$ S8 b break;: R9 _2 y7 g6 O) P4 r* ?- A: y9 |
case 5:
9 w( s% ~5 q6 l7 ^) h2 l" ]- @ temp=Read1302(DS1302_DAY); //读取日数
0 z8 S$ y* M/ j; x$ d( F/ O8 z temp=temp-1; //日数减1
6 s- _( z% Q3 D% ?- F' ] down_flag=1;
. a2 P5 K' _$ b* L4 x* E if(temp==0)
% {5 ]8 C7 p, E$ { temp=31;
1 ]6 x2 \ g2 D7 W0 \1 _/ j break;
' y/ J1 A# u6 A case 6:
8 O; w+ V2 _, E. ?- z U7 @8 Y" A temp=Read1302(DS1302_MONTH); //读取月数* V6 X. D8 u& D4 I" ]
temp=temp-1; //月数减1$ J8 E/ J6 Q ]. O2 e- v# J6 l' r
down_flag=1;. j; m! F5 B7 \) A! Y7 T
if(temp==0)
( i9 E f+ ?+ c/ e" H5 T& t temp=12;# M6 o" l- p- ~9 S5 \6 k' ], a
break;$ D% ~2 z; B/ N M* j% ^
case 7:
1 I! r& F- f4 Q5 L& X8 j* | temp=Read1302(DS1302_YEAR); //读取年数
3 Q4 Q, w0 c' h temp=temp-1; //年数减1
& j- F$ R* h! Z# `, Q0 P N# E3 N& W% d down_flag=1;
- A$ v: S% i/ R# ^ if(temp==-1)
2 Z. F9 U8 k- n- S temp=0x85; Q2 c( E! e; M3 ~
break;: p1 C) n. I, Z3 z) O' w) k9 W
default:break;
- }, X Z. P/ k; U. m5 K }
4 y$ T( s/ g8 J% i/ t/ R
! _; a v6 N$ _3 D. {$ y while(Down==0);
8 [, }; ?' _% Z9 a7 r while(wireless_3==1);" a, ?3 D* d% J' X- ?' t Q; I4 P
}$ G' t7 ^3 k) P9 Z8 }7 O- L
& x$ @# ?8 f, W$ p8 {! [* r% p* t9 v
0 c7 U- ~+ S/ n5 z) Z
void Setkey()//模式选择按键
6 c7 _0 Q: m: T8 o{
4 @, Q2 U- c; E) p8 }: z4 p+ f+ J Set=1;
' K+ |5 j1 j4 A( ? if(Set==0||wireless_4==1)
I& `( u9 a6 f {0 X3 j3 k% y- _7 H. T
mdelay(8);, ?* H3 {: B. d0 E% _0 ^, ^
count=count+1; //Setkey按一次,count就加14 U; [# E3 P) M6 p. d9 e4 \" h& w
done=1; //进入调整模式 ]$ i/ e: }+ l( O) c! m* t
while(Set==0);
! g, B9 c% G9 L( o3 Y while(wireless_4==1);6 K$ F* t' j2 d1 e
. V3 L' ^1 N/ f; _6 z Q$ r
% g2 t5 T0 |$ M( N2 f; t @3 c8 v! ~0 @1 Y& Y
}) {4 @0 N* O& c3 _( V2 I) X+ |
/ E3 B+ ?0 @6 X `* Y' y, d5 q% w% S. t* c/ W/ v
void keydone()//按键功能执行
7 g2 O( G+ l% l# m3 Q1 r' U( J{ uchar Second;$ O8 K) |) Q7 b: w
if(flag==0) //关闭时钟,停止计时
9 Y7 G4 Q3 i @; K/ H { Write1302(0x8e,0x00); //写入允许
( a: \' F4 p# W" ~7 h. a* b temp=Read1302(0x80);0 g6 m' c: G% z' s% F
Write1302(0x80,temp|0x80);3 D. Z3 F7 C7 c+ ?/ L7 M. ~
Write1302(0x8e,0x80); //禁止写入) g, O' A6 a8 \
flag=1;
6 Q9 S* t3 _, }0 k }, Y2 H0 U: i% {: D
Setkey(); //扫描模式切换按键
8 b6 G* h% `; [; s switch(count)
; W% |* r- w9 T! j' L, m {case 1:do //count=1,调整秒
+ _- H- Z+ H* c {( f0 A4 X5 w/ N) k7 B
outkey(); //扫描跳出按钮" W! m7 v* I% x( K. ?8 [
Upkey(); //扫描加按钮2 u8 K7 C9 q% x( V
Downkey(); //扫描减按钮3 l2 ^+ k. {+ D1 W' z o% r
if(up_flag==1||down_flag==1) //数据更新,重新写入新的数据
! q7 D6 v ^- B1 F3 \" E {* a- V' L. H) l9 X7 _0 r
% Y3 |7 N8 Y4 Q Write1302(0x80,temp|0x80); //写入新的秒数
R" H8 ]" ]" E Write1302(0x8e,0x80); //禁止写入
. `+ ^4 o' |) U& h5 H up_flag=0;, N1 v. C. p0 w, a
down_flag=0;8 B& C; s# g( E7 A
, k6 d( \1 F7 M
7 n7 {- @5 h' T) V( E, @6 w. P( D9 N0 i$ F& Q8 q: l4 o
hide_sec++; //位闪计数
% M) h- r- S& @ F5 p4 Q if(hide_sec>3)) N. f3 G+ O o& v$ g% v* `
hide_sec=0;" }0 _/ w# S: J" x$ K
show_time(); //液晶显示数据
4 }; F4 x* M' U$ w }while(count==2);break; . j, Z' O* {" x+ Z% j
case 2:do //count=2,调整分7 ]+ ]2 j. I6 l2 f: v
, a5 |8 g! O' s! [% I( y hide_sec=0;9 L) J9 `) U0 y" |3 g8 [+ _$ g
outkey();
; q3 m, `' Q) R$ O! T+ V) q( W# h Upkey();. E8 [& n% J0 f' S
Downkey();
/ h6 m( B5 }6 s2 V if(temp>0x60). c. P4 @6 ^8 T7 A. D
temp=0;
/ K- a! K! J2 ~: Q/ C: M if(up_flag==1||down_flag==1)( D4 i) L3 k, Q% _4 V$ n7 x: B
4 |! t$ x& L. P9 h6 C Write1302(0x8e,0x00); //写入允许2 h# u) i- I- ]+ C2 z6 Y; l% S& z
Write1302(0x82,temp); //写入新的分数& z4 v. s0 [5 A* N" |. {6 S
Write1302(0x8e,0x80); //禁止写入, u+ P( q+ ]/ Y5 b+ {+ j
up_flag=0;" M% r% u. H6 h- D1 q( n
down_flag=0;' K: t1 }1 }, n! ?* X2 i2 J
( d! ~( v. y- d* H A# r7 o hide_min++;' u0 {* D& {& J# {# v
if(hide_min>3)
; v' g9 J4 i8 _! _6 ` hide_min=0;
5 [8 Q. J0 l' i$ U6 P/ C% l9 a( B show_time();1 u" d& v) a! O9 {
}while(count==3);break;
" c" {, ~8 ?( a ~ case 3:do //count=3,调整小时" b% S: g0 ^& }! e& n# o
& t- x1 {$ @# @4 Z3 e% V) Z; z hide_min=0;
" d* s8 N! X& q/ v2 D outkey();
* `: O$ a- I/ P2 l$ P8 H5 F3 H7 @ Upkey();
( z8 H3 Q* l; g* Z" w6 h Downkey();' i% f* e( E) d, h8 v5 n
( L- A* W# _9 ?' J$ U {7 _0 a; d5 t6 v A6 B7 x* c+ @8 q
8 a( |2 w+ n `* u7 [! M Write1302(0x84,temp); //写入新的小时数* v" S* P* f! C8 P9 Z
! @4 {( s h& G, y3 R- T up_flag=0;& {+ ~9 K4 z. Z' W
down_flag=0;
. }- z1 N. {, Z& U6 \3 a. ?. [# E }
3 y, l/ ~& v1 Z! G hide_hour++;! a2 g0 k$ ~4 G; u2 x( Y
if(hide_hour>3)' K5 Y' b& M9 |' D1 d
hide_hour=0;5 ~8 w8 a3 _* b j, l3 \- s$ B) h
show_time();
$ l% h# s2 o1 }& J' d }while(count==4);break;
4 D+ s8 C$ a9 ]4 r* v case 4:do //count=4,调整星期& N7 `1 d% ]) ^4 I ~
& W, Y5 y- U7 \9 \ hide_hour=0; 3 v* z5 v% s9 s& D' f% M" B1 {0 V$ }
outkey();& H3 U: @$ r$ ?3 ^( o
Upkey();! K3 s0 X |& Y
Downkey();/ J0 y& g- k" ?
6 S" A' Y; Y. I' C- } {: j7 C0 c4 E% p) }" f. h+ p
6 p# D2 t' A* t# @ Write1302(0x8a,temp); //写入新的星期数0 a7 C4 ]/ N. T3 a. V
Write1302(0x8e,0x80); //禁止写入+ L; J9 e& w0 y" i
up_flag=0;$ ?) G" o/ ~# g0 y, h& {
down_flag=0;
- ~# e1 s3 ?7 C1 U }
, v r- I6 M( o9 w& \- B: i hide_week++;
. o9 }8 ^6 o3 r' b# A if(hide_week>3)
/ h+ ^- {% b# Q: l$ W; s hide_week=0;6 Y# c- ]) c7 I1 X7 r5 K$ m
show_time();
0 O( @) b: s7 I) O) k, v }while(count==5);break;
( N$ N& s0 C$ q+ f7 w/ l case 5:do //count=5,调整日
# O/ d' `: M* x! \5 L" G& k { ~8 P/ s* e; u
hide_week=0;
8 P& C( A( v4 @' e% ] outkey();) S5 z2 A+ b8 Y
Upkey();
) H. c/ j6 N o% \2 B Downkey();
- v! M7 t" ~% \( d" n O( _ if(up_flag==1||down_flag==1)
& U2 }; G0 t1 g/ ~) R$ J {" x$ `: }9 q# h$ A
# e( o1 a4 p( q- D Write1302(0x86,temp); //写入新的日数
+ V- z* m( j2 O- m+ Y( R. r& [( j Write1302(0x8e,0x80); //禁止写入
7 G$ o/ |0 ]( B4 y7 u+ D up_flag=0;) `: l4 S* d6 d* h+ G2 y
down_flag=0;
$ }- K* K, n. W! N2 Y4 v( X8 d }) f( h C% g3 p* j6 x8 h+ Q9 e
hide_day++;% X6 l- e, l+ l+ ?8 w
if(hide_day>3)1 K0 Z+ H0 g; R
hide_day=0;" H6 w3 e$ W) s8 r. d. [! D
show_time();
! [8 @, d& K- B3 g9 c6 }) U }while(count==6);break;0 w% N S) ^7 e' P( C$ S# M
case 6:do //count=6,调整月/ M3 n5 j$ d4 `. G
3 @. c$ ~/ f `4 F9 u6 h6 d j hide_day=0;
! c8 k3 j3 `/ N8 L outkey();+ `" F/ n* B6 q7 l) @) s
Upkey();
, X( e. b5 K- A2 G0 }! j" s$ \3 T Downkey();
& {! ?9 w" O: T& E h if(up_flag==1||down_flag==1)- c1 @1 n: h/ c" r1 @% w4 C
{! n7 u) e- n: [' \3 z) e
Write1302(0x8e,0x00); //写入允许) j- X N; r3 Q* Q
Write1302(0x88,temp); //写入新的月数" S. \2 _2 q" l8 `! B- G' G% U# g
Write1302(0x8e,0x80); //禁止写入+ N/ z, E5 F7 ?9 ?0 [2 {4 t: Z
up_flag=0;
+ r4 J; W. N0 j& z' N0 D0 Z+ ^! [ down_flag=0;' {3 ?6 F; E1 P, n) e/ `
}7 h0 p# {: k- e2 _6 k
hide_month++;+ N* F3 p1 N4 g% x
if(hide_month>3)
( V% d+ R* j/ r) k: M hide_month=0;
t: _1 U9 `- g1 z8 o) [$ P show_time();* `( N9 `$ V5 X( T. m) s3 O1 X
}while(count==7);break;9 w' U5 o' O" e6 a% j- f Y
case 7:do //count=7,调整年! _! D. ?# p, q: ]6 @/ }9 `
{' w5 l$ q7 _. Y/ Q: b
hide_month=0; . ?) m6 G/ T/ g8 t4 d
outkey();
9 L, s C8 |% G7 o) N' V0 o Upkey();' M( w: | a5 y0 ]
Downkey();
% l, I; [) e% j4 P if(up_flag==1||down_flag==1)
# w8 x6 p% s9 w. Q3 @/ j D) F {
6 D; r2 y- B8 |2 l. r Write1302(0x8e,0x00); //写入允许9 l& F- Y/ Q) t: \
Write1302(0x8c,temp); //写入新的年数; S: R' \; J% x g7 c5 B- M
- ~% k, f c( I* T& C, n- |9 | up_flag=0;
: Q `0 F. t: s% ~7 e down_flag=0;/ a" p4 T) v( q5 V$ {
+ F/ [# B8 n9 V" F5 K2 f7 e hide_year++; I* j2 H, R8 j. b: t
if(hide_year>3)
+ c# Z" N# W) s hide_year=0;- a, J5 i+ F( q+ {8 A
show_time();- t( a4 \2 h ~1 T/ l
}while(count==8);break;
+ {* j. `9 v8 v% G | case 8: count=0;hide_year=0; //count8, 跳出调整模式,返回默认显示状态" B" F! p# q# u* c% ^- z3 p2 w
, G) Y: E* Y0 B Write1302(0x8e,0x00); //写入允许& H5 r+ d8 Y: c4 T
Write1302(0x80,Second&0x7f);$ L0 b7 t+ p0 R6 E
, w" Z: G' s2 s done=0;. O- [7 T4 B- H* T3 O
break; //count=7,开启中断,标志位置0并退出0 Y" n0 ], r$ ~9 x6 g
default:break;7 |$ ^: t( {8 t) G: l& }
' E9 a9 L* l0 j1 T
0 w' \# U9 u! p) N$ y5 V
}' R5 X! Z% w# [% l7 c
3 x! f* I1 d- @9 S b" Q7 k( ~* H& R: D; _, q l+ B9 B
( B F% m- d" g3 e! J3 l+ s+ |6 C+ K8 e3 d4 s
* j/ E: _ A: c5 \
. Y/ i9 f* {1 `$ t% A' D
& }' ]8 S; h' v9 Qvoid show_time() //液晶显示程序
7 e( Q) S F6 F/ S- }& U{
$ R4 ?& _6 k# |* M2 R+ [ DS1302_GetTime(&CurrentTime); //获取时钟芯片的时间数据1 V4 O" v! R& h7 d; i1 U4 q
TimeToStr(&CurrentTime); //时间数据转换液晶字符7 b+ r" V% h! x% W P
DateToStr(&CurrentTime); //日期数据转换液晶字符: m4 t; _; w+ v' `1 l
ReadTemp(); //开启温度采集程序9 Y" u3 S7 C) J0 [: M& f& f4 o
temp_to_str(); //温度数据转换成液晶字符2 k! s/ w* _& [. e* S, g( a2 n
GotoXY(12,1); //液晶字符显示位置# V ^+ C3 p% }: N+ h
Print(TempBuffer); //显示温度
) i8 D) v" D: W+ B GotoXY(0,1);. K9 Y- z, j/ Y1 T, D4 N& E4 e+ ~
Print(CurrentTime.TimeString); //显示时间2 u( l6 }* n3 c) H
GotoXY(0,0);& z6 f9 x' q. O9 @% h" M
Print(CurrentTime.DateString); //显示日期
) [' v+ i. }* S' c. Q1 d5 T GotoXY(15,0);, F9 e3 S. u+ U- R# L L5 R [
Print(week_value); //显示星期: p3 B+ W5 E1 T. T4 R
GotoXY(11,0);
, l. d \' t3 h W& H2 a4 X5 | Print("Zhou"); //在液晶上显示 字母 week
+ |( r4 L$ I" ~. d% y0 c2 n Delay1ms(400); //扫描延时
. X3 I( `4 K% }& d}
E2 ?% F1 \$ l7 C' g9 I, F( P8 A3 J
- F. L% Y' H. {$ F0 }
) T& P2 ^& m# R- j! P( ?6 S% D1 @, ]! j$ g: H: b; _' x
' u! M3 L1 v( I
- B2 g( I) c( ]( D1 {' jmain()0 w2 Z! g9 ?4 R& R1 G, J7 ]' o% g5 V
{; o+ `2 K F4 X+ w+ N' Q
flag=1; //时钟停止标志: w8 p+ Y0 l: ~6 L2 G
LCD_Initial(); //液晶初始化4 I/ a8 d! { @: X/ S- I% x; }
Init_DS18B20( ) ; //DS18B20初始化% t6 f/ k& r2 y
Initial_DS1302(); //时钟芯片初始化) ~, A$ P7 x4 b. P: D8 i
up_flag=0;
; E+ C- d5 R P' c+ N0 H3 } down_flag=0;
4 `) Q2 K i4 j done=0; //进入默认液晶显示" N5 S4 U8 G/ ?/ W; y: g! d
wireless_1=0;
+ C5 ?9 }( k) f1 q% c% g wireless_2=0;
1 H5 y0 A4 |# D* U- _ wireless_3=0;: P1 ^" M$ X, Z) L
wireless_4=0;& n: }. `8 ]0 y, Z! P: L3 B
while(1)# C2 m' T; C# P7 W
{ + A0 [% z- }3 B
while(done==1)
. {) U) w8 }$ W" H' {1 m; A8 Y$ C keydone(); //进入调整模式& n" S# g+ u% N! G, V M! U
while(done==0)
( W! {6 l$ h( m! ?0 f { 0 n6 v: K* `+ V
/ P0 F% [- y1 U+ c) Z flag=0; 8 d) k) U, |+ g
Setkey(); //扫描各功能键
+ s9 m& f6 `* D1 S }' \# |5 b' u" k( ^6 W/ f
# N% M! G9 Z3 S! C0 l: a% ~} [ u$ S3 f6 O% D* }
& S. c& y- Z- i8 L' Z
B3 n: a+ t4 e" J
