外部中断计数,源码
& ?2 ?+ ^ P U
2 z% W V( W, l0 K& R* T) r: i/ @( p4 Y4 |4 z
这是做的外部中断计数,用了好几天终于完成,谢谢指教1 f( O) D7 J M" x/ g
+ c d( X o9 ~+ H4 [, m9 O, r% Y: J* V
#include < reg51.h >
# T5 v! s9 @( N#include <intrins.h>, D4 E) }8 E) [3 a
. z4 W2 U2 a, f" k% z( F6 n
# u/ G5 d& B. z1 E a4 ]; w5 q; z, ]
sbit LS138A=P2^2;
+ ?+ a6 r$ B: a2 K; a4 K8 j/ o7 Qsbit LS138B=P2^3;
; ?2 \! G2 z* Ssbit LS138C=P2^4;
3 h5 J6 h$ Y3 i" b; L* B0 h+ B
" D: i' T1 C$ ^; a% c6 D, h7 i3 v$ u1 `. l2 B
unsigned int LedNumVal_1,LedNumVal_2,LedOut[8];
& ~! ~1 ~0 {- u, |$ i$ ~. \9 V2 {/ e/ C2 n
& A; V7 j- H' T. u% u7 l0 B//此表为 LED 的字模, 共阴数码管 0-9 - : Y; J. c4 \2 b# c4 X
unsigned char code Disp_Tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40}; ) w2 ~8 r5 v% O
; b, F$ K9 U$ I# w
2 E8 Z k1 F0 h! C) Y
7 d, z( G2 k1 X e$ ~9 E4 ~7 W: H6 l3 G6 [, F; k3 t
void delay(unsigned int i)
6 y1 k7 O4 R- J& j% y{* @5 T5 Y; U3 w' b, }, y
char j;
' |& z2 {: ?- E; ~% D/ Z for(i; i > 0; i--)
7 E* V- Q- k6 N$ d for(j = 200; j > 0; j--);
3 @# b, G4 I" W}
4 N. K/ _! t$ o1 @6 F" G4 q, l
`* L" y' y' v
- l3 ~" j3 d' o( ?! ?) ` E2 |
* U& O1 P3 n6 j6 @" dvoid main(void)4 J) l( q# K. |( Y
{ unsigned char i;6 m+ Y) L) `, I! }* V$ e" P
7 p9 _/ ^* M+ k$ y) a9 M
0 |3 S, ~$ G# a3 R. \& p( b/ B
P0=0xff;
6 z) K( s8 d9 r) X7 K P1=0xff;8 d* N# q4 I4 @! y% y* e
P2=0xff;1 t9 o1 d0 X y; h# y
9 W/ {. O& o+ N
. r1 w, P# I9 U" E; z0 a, b0 E8 M% z/ R4 E2 t6 @
# n4 r; V9 Y. h3 c
// IT0=0; //低电平触发+ s. z4 H! Q! v. C
IT0=1; //下降沿触发
4 E- G& {2 L* u; X0 K* i& l! u EX0=1;
% U0 h; \8 K7 c: M1 }
1 L% W9 t8 i4 x5 }: @$ N0 i; q
2 ?' V$ B& i4 i$ P
7 f( G$ Q; Y L' g; m8 K + K" M* I, m* `; [8 E% c4 i
// IT1=0; //低电平触发
( [; y! H1 g; l( X) H4 X IT1=1; //下降沿触发
; w6 Q, D8 A: T/ w2 b2 s/ A EX1=1;; ]( X) r6 j/ L. w* c, w/ N! [7 U! G
EA=1;! n; S8 e- M7 v3 L% B; S+ ^/ H1 t ]
( Y6 e3 C; N9 {) D4 D* A1 `: d3 f n5 O6 A- }6 [5 J! i$ E' D
* Y- x9 V1 B" X
9 G7 a3 Z. r$ f3 z% Z
while(1)
' r# x9 D v: [: A' {$ Q { , L$ h) A8 w+ @/ W
LedOut[0]=Disp_Tab[LedNumVal_1%10000/1000];
" [! S( H0 S# r LedOut[1]=Disp_Tab[LedNumVal_1%1000/100]|0x80; //0x7f小数点" ^) n `& O3 w$ P
LedOut[2]=Disp_Tab[LedNumVal_1%100/10];; U2 b O& y; b! M
LedOut[3]=Disp_Tab[LedNumVal_1%10];
; ]3 g% {% G' |' u
% J! u* R- M/ Q) c3 [2 f; A- e1 X! K/ i# K/ w3 |
LedOut[4]=Disp_Tab[LedNumVal_2%10000/1000];
8 M0 Z$ K7 u) U1 Y7 \ LedOut[5]=Disp_Tab[LedNumVal_2%1000/100];! I) I g7 ~- m6 X* s E3 I* ?
LedOut[6]=Disp_Tab[LedNumVal_2%100/10];
: }0 l# c% d0 p- T3 V4 m4 I LedOut[7]=Disp_Tab[LedNumVal_2%10];
3 ?0 z; ^% b. u! B) o4 y) v6 A" F0 V! s
( V5 P. [$ G; X) W2 S. _) s* y
' }" J. a" z; `& k7 l+ ~' J: _- j, U( X
for( i=0; i<8; i++)
7 U" W2 A) Q( B# T { P0 = LedOut;
5 f# \+ Y2 F# A1 {6 G , B6 K4 M7 `( ~5 ^0 Y
switch(i)
, a/ A) _- s; r { ) B0 V! A D2 L8 @
case 0 S138A=0; LS138B=0; LS138C=0; break;
2 d: N0 A5 y5 ]0 w! \ case 1 S138A=1; LS138B=0; LS138C=0; break;
* N6 X1 m; U9 M! @- c case 2 S138A=0; LS138B=1; LS138C=0; break;
2 E* z- m( \$ H0 V8 z: L case 3:LS138A=1; LS138B=1; LS138C=0; break; 2 N' d: @: N9 E% m7 B* A! s
case 4:LS138A=0; LS138B=0; LS138C=1; break;
# w* j" x, s6 o& u8 o case 5:LS138A=1; LS138B=0; LS138C=1; break;
0 Q! z5 m8 A; m Q( w" l) Y( I case 6:LS138A=0; LS138B=1; LS138C=1; break;
, l8 `6 X9 ?4 Z) r! T6 W( } case 7:LS138A=1; LS138B=1; LS138C=1; break;
9 I% F5 R: `' \" t4 N
?6 K9 X! f7 Q/ F }9 i8 S9 B/ O8 k8 u5 k9 i# [
8 g r4 Q8 h1 x: a; g, K) c: P- h/ T" N2 X4 P
delay(5);6 o/ ?5 \4 F: X3 a: i: }9 R) m
* j) X a: l6 g6 m$ C - g: A8 }7 _' l4 f$ c( ` x) O
4 ?; S' R8 ^+ t! o* v+ O: [5 f- k( P! r: C7 D- e8 |
}+ v; M' N$ e, I* m# X. L
! q( x, R/ j0 w
1 i( {3 Y: e0 f% u8 b* l}! k3 |3 H+ x5 {! e/ H
6 u# n3 s8 p7 D' e# ^- ^& V+ g% U8 g7 y
$ }, n$ h, M4 h+ }
3 I8 Q+ y1 E/ b8 W$ S! M+ L2 A1 R/ X, e9 b5 g
4 V9 B% h, [; E3 u7 u/********************************************************: j( L) y5 r3 g' X
* INT0中断函数 *% ?2 u% Z5 P6 \2 _6 o0 C' M
********************************************************/1 c% I3 B; h* m% M k
void counter0(void) interrupt 0 using 10 j2 p, a6 r) j3 k, [# ^; z* T% Y
{; K5 |! D) T) |& @5 ^ ~% N
7 r; O2 o* w1 m+ o3 o
EX0=0; 3 {. Y ` M% R: s7 T* v
LedNumVal_1++;) ^( o1 d1 t. C( n: a, X' Q. W
EX0=1;! T" O* v& z3 {& v2 g% W
}9 f* X4 ]: U4 H; f; W
/********************************************************1 N0 K5 n9 q+ B& F, t& h
* INT1中断函数 *
7 \! y8 N* ]- q9 b********************************************************/6 w# b% S5 N; T9 a% }' K
void counter1(void) interrupt 2 using 2
6 E% f" _7 N6 R" j, \{" M9 J! \ z5 j
. p( w4 m/ V! y4 H$ F! \3 G EX1=0;
+ Y5 d) \# b8 n$ x' J9 U; d LedNumVal_2++;
& A+ O5 z9 p% n0 t, }/ [9 | EX1=1;
; z6 j" M+ H- Y L5 E' S0 e}/ y/ }' i: g/ `+ _4 ^5 @" t+ a
' a4 Y2 N4 s' E% M& T% ~3 f2 a* }$ [$ p
2 w# t# D* s0 \下载:0 L0 Q) J8 f" K/ m7 B: g
& s) Q4 Y( L1 Z9 V
* K7 w0 Y& L. g- @ |
