查看: 328|回复: 2
LED Flasher for the Keil MCB950 Evaluation Board有关单片机的一个例子
发表于 2019-1-13 06:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
LED Flasher for the Keil MCB950 Evaluation Board有关单片机的一个例子; D2 c4 n& ?7 ~- A% X
1 f, z; r+ o9 t: x0 y9 L3 d
) j9 ~( P9 |/ D7 Q& S- M, \0 C
( R! e" a' Q! b( W; A
! A4 X  w' u# p% s+ V3 j  z
The BLINKY program is a very simple program that blinks the LED's on
% |/ H9 c  k6 M. P2 Qconnected to Port 5 of the MCB950.  When you can successfully build
; F: d( G- Z; N, jand run this program, you have used the entire toolset including:% ^3 x+ G& {  K1 U. N
The uVision integrated development environment., l; Z+ t6 ]& W9 c
The C51 compiler, linker and the uVision simulator/debugger.
9 h; \- ^: c6 m1 S/ R) O. K  A8 x( XThis BLINKY program is available in several targets:
3 o+ t( q" R- k1 j  Simulator:           for uVision Debugger testing with simulator
! X9 J& d: ^/ T& g5 e  ULINK2 NXP 95x:      for Debugging with Keil ULINK2 JTAG adapter
4 w% n' u9 [2 ]' C/ J8 i8 C) I1 `# ]  FS2 System Navigtor: for Debugging with the FS2 System Navigator
, S0 Y7 P& L# Y: d' `Use the following jumper settings on the MCB900 board:0 |7 Q9 j/ s8 A) F' T: U! v
  RUN: OFF   RESET: ON      for Download with Flash Magic
1 U3 H- q, W: ~# R+ {0 S; e( H  RUN: ON    RESET: OFF     for Program Run
/ h' [" v/ X( N8 s
+ `4 s7 F5 n( v; R* r" I8 I4 w! F
! i) W6 m7 E) n! b9 F2 Q& t# n* `  G1 r
游客,如果您要查看本帖隐藏内容请回复
, e: V2 W: r" o
GMT+8, 2025-7-22 03:07 , Processed in 0.109375 second(s), 26 queries , Gzip On.
