TA的每日心情 | 衰 2020-4-15 15:20 |
签到天数: 1 天 [LV.1]初来乍到
/ W S1 E2 A( `/ g2 n
把原理图生成的网表去掉,一样报错,是不是不能用网络标号,只能直接连的线才可以从PCB更新到SCH
% v1 C1 U1 L. k8 L{ Using PSTWRITER 16.6.0 d001Jan-07-2019 at 14:02:47 }
. }3 _) r% C* ], y" [ @; A
4 I- ]; r) _7 M# N% }INFO(ORCAP-36108): Starting the Swp file dumping process ...! y; p- g4 [& Q
Loading netlist files ...
7 G+ R6 o' ?/ ?Loading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/pstchip.dat) \7 X# Q% k/ W' u, _0 t, d
6 ~6 {5 e( E, q* j3 l: J0 t* BLoading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/pstxprt.dat/ v. r8 V* @/ J) a
, Z1 S( {8 E* ^/ d1 @" ]5 [Loading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/pstxnet.dat
l& L: D& A, L' r+ q& q" jpackaging the design view...Loading physical design view ...Loading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/funcview.dat
$ x% r* |3 G3 h#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN SOCKET 40X2_2_DIP80_CONN S, regenerate the netlist to sync with Allegro board.
; b- ^& M: c- E: |) q Z, B/ s ERROR(SPCODD-516): Line Number: 4! g) E7 v0 F9 W7 l
#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN SOCKET 32_5_DIP32_CONN SOC, regenerate the netlist to sync with Allegro board.
# W/ Q B7 Y+ |2 v: P; T6 E/ l: E8 v ERROR(SPCODD-516): Line Number: 5/ r4 U1 M3 t5 j' R. a2 H X, T. m
#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN SOCKET 32_5_DIP32_CONN SOC, regenerate the netlist to sync with Allegro board.1 G5 W) `6 l) f/ ?. i* m# ?
ERROR(SPCODD-516): Line Number: 6; w5 L; p5 X" K" P: @
#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN RCPT 40X2_1_DIP80_CONN RCP, regenerate the netlist to sync with Allegro board.5 F C! U$ B. d2 _4 \) l
ERROR(SPCODD-516): Line Number: 7' A& w' a( b+ M& `# ~
#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN SOCKET 64X2/SM_2_DIP128_CO, regenerate the netlist to sync with Allegro board.
/ U" _$ ]+ G( X+ k. J# A/ e ?8 v ERROR(SPCODD-516): Line Number: 8
" k P) L* @; l4 S#1 ERROR(ORCAP-36027): Unable to read physical netlist data./ A. M* W1 w* I* f
#2 ERROR(ORCAP-36025): Aborting Swap file creation... Please correct the above errors and retry.' _2 D- V% J' q0 @5 H1 h
1 g. D3 O) n V) X) @
