目录在:FTP /资料类/ad6 video/( E% {" n6 m& ?2 } c* V
文件大小470M。
. a0 O7 A& u! r" V目录下的文件是8个.exe安装文件( altium Designer Introduction;
$ c( p, x. ^ I4 j& [1 t1 o Altium Designer overview;
& v) ~! l% \9 X2 ? Moving from orcad to Altium Designer;; m( w. J* [7 z
Moving to Altium Designer from P-CAD;
1 T( {, c* O1 S9 K4 Y0 P- R6 @ See what's in Altium Designer 6.0;
. e; I1 u8 g5 J3 ~ S1 x! i Upgrade to the full Altium Designer system;" A: M5 @' K/ U- d) z/ {
What's new in Altium Designer 6.3;2 b3 W+ ]* T0 t2 A3 j4 o
What's new in Altium Designer 6.6)
+ c2 V9 o# M* N! t2 O: f安装后有.swf格式视频文件,下面有具体的.swf文件列表,这是我看的最全的AD6视频文件了,虽是英文的,单内容简单易懂,不用听懂英文说什么就能明白讲的是什么,适合protel新手和老手,里面讲的有些功能你肯定没用过的。
1 G0 I" x9 y, j3 m截两个图个大家伙看看,觉得好的话就去看看吧。
! K' H: G. e+ C6 n$ T1 b5 Z<AD6 Video>& f) {3 L( E& k' {- M
├<Altium Designer Introduction>- [' m+ i6 O- w" o$ a- Q' y
│ ├inteRFace2.swf
6 r, L& ?8 `- c4 d! s! i│ ├unified1.swf
, X. D: ^( \: F. B0 D; f) ]# t│ ├unified2.swf H4 S* E: h/ u6 f' ]! O
│ └unified3.swf1 g1 b6 ?2 S6 r" f7 F* Z" N, a: M" ^
├<Altium Designer overview>
* R+ h' r X; t9 j- G│ ├Storage Manager.swf2 [/ B2 Y/ s- S% J$ @
│ ├Version Control.swf
- j2 j. w# C" Z, U _│ ├Component-to-document linking.swf
( P0 Z+ x2 {4 F* l, s) I. o│ ├Automatic File Locking.swf
. \* q: c' J- j: C7 e4 B│ ├Project Archiving.swf# k- P+ R6 O/ b1 O8 g; I3 x
│ ├Database Linking.swf# Q5 h1 ?+ N/ ^# j; f; r8 d' s0 c+ [
│ ├Output Generation.swf. c. U, X4 e6 E
│ ├Full control over document defaults.swf/ \. c: p* v0 a) d9 V
│ ├Protel 99SE Import Wizard.swf
6 v3 ~/ Z+ g/ p/ G, c# `( b│ ├Fully-editable channel structure.swf( @; A' [- @6 e( v; t- {5 k
│ ├Definition of assembly variants.swf
3 b* m3 ~) d4 }6 U7 F, s│ ├Annotation options.swf6 P" }1 w! W+ l, l( ]
│ ├Annotation of multi-part components.swf
, w! k. |# |- i) i( c2 A" H│ ├Component selection.swf% ^1 @1 J8 u" d' `, E H) D+ V
│ ├Fully modeled components.swf) i" h& e5 u3 u( `- J F
│ ├Integrated Library Management.swf
$ {" X% X- Z* L0 F! W& Q. K│ ├Flexible component types.swf
! `8 _2 y- r; R) A# E│ ├Component searching.swf. r. {- W5 w* A+ S
│ ├Updating components on the schematic.swf
' h/ e& R t2 R9 u& h) g9 b│ ├Direct component editing.swf
. {5 [- r. i9 m4 B/ m0 u│ ├Library Editing environment.swf
$ R5 s9 |8 v. q' O) R- t4 T│ ├Manage component models.swf+ c; Q9 d- S9 J9 i- O- t7 K1 ?- p
│ ├List-based editing.swf) ?8 s2 Y+ Y/ I; f( _ t- L
│ ├Library import.swf& D* L; z6 N, P; }& X
│ ├Library development.swf
. A% D3 A1 O( P1 ^5 Q+ B│ ├Library report generator.swf! V$ Q! y" I8 K- Y" a& n
│ ├Inspector panel.swf/ w9 l% `3 l( Q
│ ├Parameter Manager.swf$ t0 S0 q% B8 s* E5 S9 `
│ ├Schematic-level class generation.swf
* ?- }* q# J9 Z" U│ ├Documentation and printing control.swf0 b# v# d g! i4 y
│ ├Print preview modes.swf+ e# i6 H3 } ?( [4 x
│ ├Configurable reporting.swf
* ~# [2 f: i" t; p7 z+ d│ ├PCB Dimensioning.swf
s! k8 c2 \2 B3 V, c0 |│ ├Windows clipboard support.swf
Q8 P/ ]- o7 n" }' r( _& l│ ├Inspector.swf- X5 h, d& B X& _# L
│ ├Find Similar Objects.swf
3 N8 c. z! a1 W. ?9 v1 e* u, E+ W│ ├List View.swf6 w8 A+ K5 n+ }
│ ├Language Filtering.swf! m7 _0 G7 k+ ~) C @
│ ├Schematic editing.swf& q6 e0 C/ g2 I& }
│ ├Graphical compile masks.swf$ p$ y: [( v4 i- p% h
│ ├Sheet to sheet symbol synchronization.swf* n# E y3 K F9 e" I3 Q$ a& q) x
│ ├Editing of sheet entries.swf
8 T) V) {' K) {2 z$ F$ P6 ?│ ├Schematic wiring.swf
* M$ D- x* ~4 i0 U- U* E3 @│ ├Flat designs support.swf5 T8 E, c/ O$ ~# q) q% o
│ ├Context menus.swf; ^/ L/ R2 o3 F( d9 Y) ~4 V. V
│ ├Project navigation shortcuts.swf8 k0 t5 B! E, f4 G2 x9 |; Q2 w
│ ├New schematic hierarchy management features.swf) m m. y$ t% E1 h0 ^
│ ├Cross Probing.swf
0 I/ V* G+ i/ Q4 _1 j$ N) c$ h2 ~5 M│ ├Cross Select Mode.swf
5 h2 A `( D0 ?( N# ]│ ├Dual schematic/PCB navigation.swf
( e% \/ W; R$ ~5 }$ _4 j, E│ ├Error Checking.swf
5 I: t+ E# L/ I. k {│ ├Logical Comparator.swf6 E9 k, I5 \5 D A
│ ├Physical Comparator.swf7 i+ i* n) K5 z O; [5 n
│ ├Engineering Change Order System.swf
6 B& K+ R# j% G% X$ A4 V% U│ ├Board outline definition.swf
- L. s- I1 L$ L6 c) N' Z' Q│ ├PCB Rooms.swf6 e( U! n5 \ a6 I8 U9 }6 X
│ ├3D Component clearance checking.swf
2 ~* m( Z5 p6 t3 s2 _│ ├Enhanced PCB editing.swf
0 Q3 P' e% K& I5 L5 I; e1 k│ ├Layer stack up.swf) i4 e4 q$ {' N* z2 O4 q6 z6 @0 v
│ ├Pad Stacks and Mechanical Layer Pairs.swf# o5 S% m7 z' T2 f' k I
│ ├New Solid Polygon Pour.swf' V: w, z3 z, D: K9 q
│ ├Polygon Pour Cutouts and Regions.swf7 S3 v7 Y2 n. B! V' d! ]0 t9 Z
│ ├Split Plane Support.swf- }, w# |$ ]- o& {
│ ├Track impedance design rule.swf
w8 I. A ?5 E1 h│ ├Pre-routing setup report.swf0 m7 G' C) p7 f
│ ├Autorouting modes.swf
) w0 g) |3 z+ B│ ├Custom routing strategies.swf
: ]# F& `, I5 e│ ├Support for packaging and fabrication technologies.swf* c6 W( o: N' G: ~1 \) @: ~
│ ├Embedded board arrays.swf
7 ]/ P( S7 } X' o3 R6 E: _5 F│ ├IDF import and export.swf
( }% q4 k* E' h. a! A! j│ ├3D file support.swf
& m: x( j3 S \8 V, h│ ├Defined component height property for components.swf |/ Y7 D& l2 G$ Y" U9 O' f
│ ├CAM Integration.swf" n/ T1 d1 p! c- {
│ ├Automatic loading and fix features.swf
2 K6 a5 Q5 t3 f9 W S. R2 z│ ├CAM file loading.swf. A6 e; w4 t) z/ A
│ ├Aperture management.swf& [) q0 G1 z9 } `$ V# n' `
│ ├Editing and modification.swf
& [& J8 Y9 E8 D0 m2 j5 V│ ├NC Drill and rout configuration.swf
" l- y5 }/ ^1 a/ x│ ├Component-based FPGA design.swf
( ?0 r V- R+ ~+ F6 o& s│ ├Interactive FPGA development.swf, B4 S7 ]# G8 s6 X
│ ├PCB-FPGA co-design and synchronization.swf9 C9 |$ o6 v q' `7 j) O) o; ?, M/ _
│ ├Free Viewer Version.swf \9 D. _7 P4 W+ }, \
│ ├Smart PDF.swf
7 J9 S3 i, H( a% j% g9 o4 Q│ ├Native multi-monitor support.swf
; P7 O9 T3 ~ I1 C6 w│ ├Click and drag component toolbar building.swf$ i4 M+ ?* p: B Q# E
│ ├Localization for Foreign Languages.swf6 z1 S) m \3 A- y. p7 |7 |
│ └Help capabilities in Altium Designer.swf
* L: M* @- m7 Y├<Moving from OrCAD to Altium Designer>9 x" ~6 Z, J6 m( V
│ ├OrCAD and pads Designs and Libraries Importer.swf
6 c6 S9 K' m# k1 z│ ├Moving to Altium Designer Intro.swf9 F( a$ [' R9 W4 ^+ i
│ ├Migrating from OrCAD.swf
5 v$ \, q9 u: K* B; x- L N│ ├Design Documentation part 4.swf6 n3 v+ b: V. H% C% Y
│ ├Integrated system.swf5 S* X: v# M6 j2 c
│ ├Schematic Capture.swf
4 N( @2 ^ T/ o' t│ ├PCB Layout.swf$ ]4 N3 ]0 B5 N" c& w9 i
│ ├Routing.swf
l- b( r) N6 P+ T7 T5 R. |0 c│ ├Rules.swf
/ d5 t0 k' G$ {8 g" `. _2 m│ ├Integrating Programmable Devices.swf
/ a( B, J* Q; f# H- V│ └Making Design Changes.swf
! @# v! a. F4 h6 z( J+ e├<Moving to Altium Designer from P-CAD>0 _( V5 I1 Z5 j Q( w
│ ├Introduction.swf
2 x: T' Z$ W6 R4 j2 I4 F, Q│ ├Routing.swf
& r, C/ g/ T5 m" U3 z" J│ ├Managing design changes.swf/ c1 L4 B3 C5 y9 {; E' p
│ ├Design documentation.swf
6 D5 o- R* H" t! n0 w│ ├Selecting and Editing.swf
+ n2 H/ d$ |% X: U8 s- m$ T6 Y, l q& a│ ├Managing projects and documents.swf
( b$ X$ i' X _# l+ X& m/ ^, T│ ├Tuning the Environment.swf; e6 ?- r* d0 g. x6 U- p
│ ├Finding your way around.swf `! f2 C7 | d6 I' f% b
│ ├Schematic capture and migrating.swf! x% |3 I; `2 o1 M" x' c S8 T
│ ├PCB layout and migration - Part 1.swf9 T" W( C1 L) H
│ ├PCB layout and migration - Part 2.swf2 M. l$ a" F# ]' N
│ ├PCB layout and migration - Part 3.swf
; g8 x3 y; Y0 L0 Z3 L│ ├PCB layout and migration - Part 4.swf% ]% h8 \1 n5 V/ V+ Y! i
│ ├PCB layout and migration - Part 5.swf; d0 y R0 {1 c
│ └PCAD-Library Migration and Setup.swf
: y3 e1 x6 ], k: x├<See what's in Altium Designer 6.0>
$ j L+ ~. u* n: m; q. S9 s0 i│ ├Board InSight 1.swf3 ]6 p- _" j+ D: P3 F( y
│ ├Board InSight 2.swf; p3 T+ \. T+ E4 O* c
│ ├DBLib.swf( b: b7 A3 ?% C4 V3 q0 T
│ ├Diff Pairs 1.swf
4 z% n, }. \1 W' ?$ P6 K│ ├Diff Pairs 2.swf! K j, ]* ?4 b4 S, w
│ ├Footprint Manager.swf
' N: f. Q6 O- o9 E│ ├Import Wizard.swf
' X B3 e: A, A+ N5 x│ ├In Place Editing.swf
$ ]5 W& X$ @& C- v6 ^+ [# H$ C│ ├Knowledge Center.swf
. m8 h2 x. e- }5 H1 C│ ├Move By Offset.swf
- G5 {( m7 V# T│ ├Pspice.swf7 C7 y: H+ d% p8 S# L/ b) k! I3 D
│ ├Schematic Arrows.swf+ Q1 M( w6 A/ T6 H- J5 U+ k
│ ├Smart Paste.swf
- L' S2 ]( G2 C4 k; d- E, K│ └True Type Fonts.swf u! E f0 k& d
├<Upgrade to the full Altium Designer system>
" l H M% {+ _% |& f│ ├Familiar design paradigm and methodology.swf
3 D, F a$ F' ~1 n% ^& i) b│ ├Interactive design implementation.swf1 K2 a$ ?0 A0 V: g S' z; J0 l9 n
│ ├Hands-on design verification.swf
7 U$ _3 [$ a& b8 s) A│ ├Integrated software development.swf
' ~ o2 a" U$ }& x1 P5 }% P+ Q* R5 s# ]│ ├Vendor independent solution.swf P8 e5 \# p o9 U2 m
│ ├Vendor tool knowledge not required.swf7 m2 W9 e4 f3 C0 |
│ ├Future proofed for newer devices.swf! x. g C1 ^" K( i
│ └Fully integrated with the PCB design environment.swf. R3 P* c9 z: B+ r6 y- X
├<What's new in Altium Designer 6.3>
5 S' V; d" p4 R5 g! S│ ├AD6 Hardware Accelerated.swf- Q B$ N0 m' c g5 g8 E; k
│ ├AD6 Interactive Bus (multi-wire) Router.swf/ o2 Y, I4 |) V0 ]2 S
│ ├AD6 LatticeXP.swf
4 p. t5 Y1 ^. [│ ├AD6 Layer Sets.swf
4 V9 [* N* ?; O/ X│ ├AD6 NiosII.swf; O6 C' i3 W& J" s: L$ I/ P
│ ├AD6 PCB Selection Tools.swf! n* M- F2 z+ N4 w5 \
│ ├AD6 Polygon Manager.swf; ?8 e+ N" D3 n6 a
│ ├AD6 Slice Track.swf
9 Q$ r/ Y5 ]7 l% G0 f4 v7 S│ ├AD6 Slotted holes in pads.swf9 n/ x5 G# x) X# J
│ ├AD6 Version Controlled Libraries.swf
" w; L8 T4 b+ s% T8 a5 c$ O│ ├OrCAD and PADS Designs and Libraries Importer.swf
, a2 D# e4 B3 K│ ├SDRAM.swf. K& Z' ]9 x, ~
│ └Subnet Jumpers.swf1 Y4 R3 U$ F# \' {; l1 h
├<What's new in Altium Designer 6.6>; Y" E" e: |# E6 e
│ ├3DStepInterface.swf
0 ^( B1 ~, x2 j9 C6 W5 m4 O1 i│ ├AssemblyVariants.swf* x9 x- g- h* }1 \, u; I
│ ├RoundedRectanglePads.swf
/ P+ G! N% b @1 G. x2 \│ └SignalIntegrityOnAnFPGADesign.swf |
