1602lcd.H头文件分享 t6 @* ?& g5 K/ v
/ ~7 u" s k- ]) p2 M, h3 M2 k
! C1 r; B3 k* N3 C! q0 j" M
#include < reg51.h >
4 `1 h8 S7 M1 D8 F; V#include < intrins.h >+ O9 }1 N/ D7 Q* U
#define uchar unsigned char
: p4 E: _4 x' g+ G" v#define uint unsigned int& w% Q; a" ~% t
sbit LCD_RS = P2^0;
+ m' G7 o# j, h# l* o8 nsbit LCD_RW = P2^1;
1 w2 w5 |* ^4 ^" Esbit LCD_EN = P2^2;# ?6 n H5 q; @$ P+ z4 F
9 u& ^1 _, h0 d3 c" p* i4 H) R- K2 @% b
* 5us 延时子程序
) I7 r6 ~% H( D# `+ W: C+ T" W. A7 P8 R/ @
: b& Z3 O d( _0 N; `$ pvoid lcd_delayNOP()
. f$ T0 L; R, G" L{
7 d4 e; S9 Z$ x5 e% x/ y% ` _nop_();
! F( ?2 H$ d" j) q _nop_();
+ t, U" w0 }: @# X. o5 Y _nop_();- b1 d4 ?- P5 L1 g5 i' K5 k
_nop_();
% f% S& ~% j8 t9 R2 w1 Z _nop_();0 k3 {& p6 P! S& |' E
2 P" e: |: y! y- P, g2 U' {$ h8 K' X5 s8 p3 b- a
/**********************************************************0 m2 N# d! H$ y& c& S8 V- P4 c
. z, T7 [6 }" C/ g1 T' Y- G
* 延时子程序! Z- w. l7 l/ @& ~- b( h
3 |. i8 u7 c) b) I+ }; w1 L
**********************************************************/3 w2 x5 \8 ]3 s; ^) ]/ |
void lcd_delay(uint ms)
/ } C' A8 A8 L8 {2 B# b9 t
5 i- X! a1 Y3 a; H8 f0 `8 b{# t5 h) l' y( P+ l; t9 K( e, x
uchar t;# W6 y: e, B& n, Z6 u5 I& V
while(ms--)
# W1 w: N& s) M$ o {
- p6 B7 K( h0 O) E for(t = 0; t < 120; t++);
8 g* }; u( T4 R. }7 l }
9 P6 [# y; X/ r4 C$ ~}
" }: F" ^0 B4 I+ \3 m$ W, Q* M: o/ l
; o( h7 i" G$ i, T" C! j" v4 b: d
/**********************************************************1 g& w, \2 [4 I! b! D( M* b+ i
3 H8 N0 p5 y; [( v* 检查LCD忙状态 u. [. g) G; z* c3 W0 P
* lcd_busy为1时,忙,等待。 2 U0 M' e" S6 C4 r. Y
* lcd-busy为0时,闲,可写指令与数据
/ ^9 k+ e: [6 J& C7 Z | o* Y7 N! |4 y* V' B( k8 O
**********************************************************/ 3 G6 _0 c. K0 G6 u: U5 N
bit lcd_busy()
. Y' p- C1 K3 `0 U) A/ N! F2 Q{ 9 u- ^/ A4 n! V1 p( A7 W
bit result;
% J, y7 ?. s; S7 E5 y LCD_RS = 0;2 t. z/ t" W0 |3 \3 Y
LCD_RW = 1;1 b( p. b' W& a9 o
LCD_EN = 1;; d( |7 @9 `- x
lcd_delayNOP();
% Z$ C5 {1 Y# L$ o9 e! K l result = (bit)(P0&0x80);/ S: Q" w& `/ C6 E# M
LCD_EN = 0;- ~# R3 }# ]8 I7 D4 L
return(result); * `# a( o. b& L( x2 q% y# \- P
}/ k* l6 t; u4 V' o
- C" D8 q2 _* u7 ]: e: x/*********************************************************
# S# i' M, U$ a& s2 {! W( U: P' n2 o! u+ J1 p' M6 Q
* 写指令或数据% {* T2 h- E$ M6 i
. F0 M3 U' W5 J* start=0, 写入命令; start=1, 写入数据) ^& B7 D1 V" H" Z8 J6 \% I
9 x ~1 I4 {9 Y/ P9 c*********************************************************/
4 {* l) ^, j- E. K0 ~
$ [4 f( r( j( T7 g) ^$ p7 {void lcd_write(bit start, uchar in_data) ! X* r' m, S0 w* P% b
1 O8 ?5 \- u7 R" B+ y
2 C# _9 E- J8 p5 y. O/ l8 a4 j3 p while(lcd_busy());8 g9 F- p+ o* U& Z" t {: v
$ F* m1 x* F& m( d$ o if(start==0)
1 X- Y# r( n$ N/ @: t/ r0 K1 c LCD_RS = 0; //写入命令
* n t, W8 {8 n# H1 g7 q" S9 H4 \1 n else
3 s4 o! X S Q, X4 n LCD_RS = 1; //写入数据
0 x0 L3 `6 V% O4 X( @+ f7 N, m1 X' t- \* H
LCD_RW = 0;
# k% M: z3 }7 n Q9 F* d LCD_EN = 0;
( V8 G2 E0 w( l# ]! r" U lcd_delayNOP();" W5 h' G+ z4 s5 \
7 c* c6 E9 j9 H1 A P0 = in_data; //发送8位, H* M+ u& p+ T: [
lcd_delayNOP();
2 b1 R5 l1 ?" |0 l. {8 d LCD_EN = 1;6 e# Y9 a8 M+ }+ F
lcd_delayNOP();, ~" Q4 M, U5 t* W$ ?+ s4 @: D ]
LCD_EN = 0;1 N; ]- `0 R1 [# V* o$ p
}6 Z$ S, E/ u) D/ T" S! {
, W7 W0 V& V1 J. [/*************************************************************
9 T H0 ?& [7 {8 K5 q# P8 X5 D! c- C, T2 w6 U0 q, E
* LCD初始化设定 * ?" S- G7 C6 o
- X4 j: W/ c6 E9 | `6 Q9 O
*************************************************************/" F. d8 t2 H2 Z5 `
void lcd_init()' o$ a/ A2 F* ~
" ]. P3 [( }. H& l lcd_delay(15);' B( c% p" H1 h8 z# f0 p
lcd_write(0,0x38); //16*2显示,5*7点阵,8位数据
& Y$ P8 T1 z, Q7 W6 Q lcd_delay(5);
# i9 E1 [ m7 o, n lcd_write(0,0x38);
, }/ o+ e y# O' t) c& f lcd_delay(5);( g5 C" J7 H6 _0 y; R6 ^2 g
lcd_write(0,0x38);
5 e0 i( x( ~# h) B4 ~
1 d# H, ]/ T3 @5 D+ \8 ^6 C lcd_delay(5);
, H8 Q8 b( V/ g1 d4 }8 A! q lcd_write(0,0x0c); //显示开,关光标
; y# c# n1 p# X Z- N9 H& T lcd_delay(5);
2 x1 g0 |* }2 ?, e lcd_write(0,0x06); //移动光标7 ~# p5 Y9 ~, s- P& ]! J& i
lcd_delay(5);7 L& _4 `( G5 b6 x2 @# S/ W
lcd_write(0,0x01); //清除LCD的显示内容0 S: r& i X" R f0 m
lcd_delay(25); //延时
+ S: H; p0 U- }& O2 O d3 O( u}
! a- n, j3 r$ `% P3 }7 R& Z
/ C8 R( J& i" [; Y/**********************************************************6 Z) z, ]) r4 A l4 \* A
* g9 }( S: b: X0 T: n' [2 O, I* 设定显示的行、列位置 (行的范围:1——2, 列的范围:1——16)
K0 t- q, \% l7 D
9 }2 z* V% i; r* i6 y**********************************************************/! B; \9 W+ g, A$ C+ H0 ?) ^# a* [
void lcd_pos(uchar hang,uchar lie)
: V% a3 K4 |9 O7 j* U5 J{ 0 F) B# F# C' U8 ?7 D. n
if(hang==1&&(lie-1)<=16&&(lie)>0) ! V0 E6 E( L1 D9 l! b3 V& |7 i+ ~
lcd_write(0,(lie-1)|0x80); //数据指针=80+地址变量 ~$ I, M2 W/ i( D$ |, O
else if(hang==2&&(lie-1)<=127&&(lie)>0)
& O5 u& ?: S3 T lcd_write(0,(lie-1)|0xC0); //数据指针=C0+地址变量- H4 Q' p! N* j2 @2 H1 @& g
8 |' n8 q2 Q4 ?7 a/*********************************************************
) J7 y. @! N6 u8 {/ c; s6 M% i) e7 l
, ?5 ^; m" ^7 q/ v 专门写单个数字. J3 T) y% N9 T# x; G
# m3 K' }1 n& f*********************************************************/
1 Q/ c) ?4 n- W z4 }- F' P1 d* ]/ b' _$ I# ?! Y# `
void lcdwrite_sz(uchar in_data)
/ {& a2 u9 @* Q/ q0 S3 p{
3 @6 M4 H: b* n' y" I4 |3 Y( U# ?2 b w
while(lcd_busy());% R2 i _8 e) F" f
if(0<=in_data<=9)
" H/ X1 @! R. |5 H" y M8 t( ~ {
3 i; I# @3 b: x( Q6 p LCD_RS = 1; //写入数据3 J+ k4 {, D" u" Z0 r0 S: Q
/ H7 E& w1 z( O8 C2 o- ?. i
LCD_RW = 0;
) J& D3 w5 ]/ I- A9 x; J% i4 d; s LCD_EN = 0;" M& j+ d$ n0 m
lcd_delayNOP();* L, R3 J9 K, s- \+ O( d
0 s/ m1 D* `) u# A; g9 K# K' D P0 = in_data+0x30; //发送8位
0 K$ u) h" b7 E4 i( O V8 V lcd_delayNOP(); ; O% w$ e6 i( u5 }9 o! J
LCD_EN = 1;
% y4 j! k$ {* @# V( M lcd_delayNOP();2 Y- @' n" J0 X) Z# C
LCD_EN = 0;
# s$ N) S: K5 d" U1 X' p0 z: U }
; M1 I+ {. M: r a& }}/ @2 t ~7 v$ m( v6 {
/ j# N3 @/ t7 P$ W- `
' i& Q: Y& Q& B 专门写单个字母(大小写的“a-z”)- R- S1 P V6 R7 P4 M
* A O/ s- e' g# d2 e U
*********************************************************/! |& t; L/ N" @0 j9 n' A, j
void lcdwrite_zm(uchar in_data)
# n! _4 I4 K1 S0 @{
) d# U( N! p$ ]1 }( R F U6 j( s+ A% m1 c
while(lcd_busy());
& ^9 V7 e% Q( P+ {7 D5 ?; C# U if(0x20<=in_data<=0x7f)
; \" b" ^3 a' {* ? {! F: i7 `7 c; w- e# V
LCD_RS = 1; //写入数据( c- X( N3 T# r5 r$ b' v( X
7 X2 t* a ^4 w* o6 d* u( h LCD_RW = 0;
! {" \* t3 o& F; z" L; Z. k2 Q& F LCD_EN = 0;
4 F0 _, P0 }% [8 ?# s0 z! R lcd_delayNOP();
& F8 _9 [- x" l8 W2 V5 c* _: W, `
! t3 V7 t$ T# W: m% t% a& M; [6 G P0 = in_data; //发送8位8 c0 ~( \+ S- a ?8 w
lcd_delayNOP(); 1 w5 I5 ~1 i% W* @! Z# t
LCD_EN = 1;
7 ^. k% ^' T6 k6 _7 w* ^1 r lcd_delayNOP();2 w& c) [: v$ S* G% x) R8 r( M
LCD_EN = 0;
2 z& r6 P5 N6 {% R4 a }
' M" \9 K; `$ ]' }: h0 J}
6 ]4 [' E& j" ]8 A, P0 ~7 x$ R
* j9 P9 ]1 Q5 a @5 q bvoid lcdwrite_string(unsigned char *str)7 w5 q: c" p" y% M" b/ S I' `3 c0 k
{. |0 x+ B: s( ^
while(*str!='\0')
7 A) u" \* ], Q3 T {0 w( m C, R) u; s* b9 c
lcdwrite_zm(*str);' a4 [' P6 ]0 w/ g! N) Z0 ^
str++;
4 ?5 f* X. L5 P" \. U! E6 Q# e }
+ a* p) L* `: A$ i* m, }}
1 y8 X& R, O( O" }" M) ?+ e: G. Y; m3 z
void lcd_clear()
: ]' [2 P, x4 Z2 ]{1 }4 w% E+ |& ]! W) c
2 V/ Q; {* f: O, P: K+ U& Z lcd_delay(25); //延时$ l9 \* e; D. v i
}1 X: z) z! W B' y) m2 K) c1 D( W
9 H+ K3 B" F% l' ]( m9 ~
# R/ L8 t s7 _, R4 w; V5 c$ ?
) p# n1 Q! i2 W7 i8 {4 f' F
