TA的每日心情 | 衰 2020-4-15 15:20 |
签到天数: 1 天 [LV.1]初来乍到
2 t0 f- z: W) r E% G' T
' T" [. N6 w+ u" I6 v" b
ERROR: 3D data has been found in this dxf file.3 ^' Z# l1 _* h0 V
Most 3D data is not supported by dxf2a.$ Q- k8 D! ~+ Q1 A7 ?
For the special case of DXF code 230 = -1.0, ARC, CIRCLE - H# A. ]' n6 c
and SOLID entities will be mirrored about the Y axis.
1 A j1 [" P+ a; Y; u d ~ERROR: 3D data (DXF code 230, value = -1.0000) detected on SOLID at line 196706 {) z5 s4 T- D- Z, H' B& h
ERROR: 3D data (DXF code 230, value = -1.0000) detected on SOLID at line 19710" g( a4 C& X7 c @3 {
done.
' q0 [7 X& z/ @6 p
" N+ Q( a6 D+ V: P* } |
