由LOGIC发送到LAYOUT时padsnet的错误提示如下: G- A! c2 L/ t
Single/Zero Pin Net Warnings . b+ n6 O2 ]- i) g* A* x# T; e) |8 h---------------------------- ) h8 z3 w; |; w6 ^8 r6 PNet ARM_D16 has less than two pins in PCB net list file. ( z/ e& \& _7 _! z b* J5 }5 NNet ARM_D17 has less than two pins in PCB net list file.; y0 T" e3 k0 m% w* |2 A+ |
Net ARM_D18 has less than two pins in PCB net list file.2 i f( P E6 H5 @+ Q" q! A/ K% F/ Q
Net ARM_D19 has less than two pins in PCB net list file. * j6 p \! t) W3 C- i- ^9 CNet ARM_D20 has less than two pins in PCB net list file. ' ]% V1 ^8 z& f; [ I9 i- C/ l9 }Net ARM_D21 has less than two pins in PCB net list file.$ O9 y( b- p7 T
Net ARM_D22 has less than two pins in PCB net list file.$ w. }4 V: Q9 }8 J1 B" `
Net ARM_D23 has less than two pins in PCB net list file.6 M: _9 ^" y: d
Net ARM_D24 has less than two pins in PCB net list file.4 y4 f# T$ {9 C h+ A
Net ARM_D25 has less than two pins in PCB net list file.$ ]: g/ I# ?) p
Net ARM_D26 has less than two pins in PCB net list file.* O$ M- N% }' e! p$ q; c
Net ARM_D27 has less than two pins in PCB net list file. 9 ^6 S/ l( l" t9 W2 qNet ARM_D28 has less than two pins in PCB net list file. ' z9 l7 {. o% G5 \Net ARM_D29 has less than two pins in PCB net list file. e7 C9 D" S3 e" S2 ]6 CNet ARM_D30 has less than two pins in PCB net list file. : j. j# G$ i# |. a1 NNet ARM_D31 has less than two pins in PCB net list file. 8 w! z: l% l0 `! A4 n" n4 I3 u; e这个是总线上的 1 }4 h. `6 `$ _- }还有个错误 5 P7 t- K# U4 YSchematic Connectivity Errors# g- ?3 {% H" z8 p& g3 }$ L
------------------------------ K+ L8 d$ p7 D5 |
Dangling Connections with a Net Name ) j7 _; T$ K9 ]0 NAIN1+' O7 u; R w$ n1 `6 y
AD(MAX125) X3250 Y3850 % R5 Q) Q) I" R7 K7 FAD(MAX125) X13450 Y7550 0 H. i0 m5 G5 z+ V( z2 j6 E, r这个可以忽略不管吗?是不是非要用OFF PAGE的方式 我是用导线悬空定义了导线网络名而已
