TL1543单片机源程序与proteus仿真7 w0 {& `1 n5 n) X3 H ~3 T
I/ s: m3 f1 [# G
4 R8 g3 T2 z6 i" x: t. W- g
# c) {! Q% a( v! u4 X. Q8 x$ q5 ]4 t- c1 T
TL1543单片机源程序:& T- m+ ^; D1 s3 A3 |. ?
#include <REGX51.H>
* T" R# Z9 v P3 F2 E. w4 ~/ I0 Q& ?; M7 c
% k) x& d. g, E, j" k) q% y: W
#define uchar unsigned char
# v6 A, Q/ m' a# H& s; ]+ T#define uint unsigned int9 W1 V9 a8 S% @& d- K" Y' b% r
#define timer0_count 0xfc18. I) D0 z8 D1 `
#define addo (5/1023.0)
2 E1 X, `* |( c( x#include<intrins.h>1 x% @3 j4 P( T
#include<absacc.h>) |; f# C2 W( o4 t$ T
4 I0 o( G* k8 d
7 n3 R% I8 D( i2 O- s #define uchar unsigned char$ d& \6 R' u- e F; p8 y$ K2 k3 @: R
#define uint unsigned int6 Z- U: M. ]3 |, E2 O/ Q
#define SPI_CLK P3_0
' ^8 |; q; Y6 N H/ v5 u#define SPI_DATA P3_10 X, x4 y! G0 L+ H$ `& B! H' M
#define CS_DA P3_24 y5 N: W& A3 Y1 z1 x
uint sec; @" I% N$ F6 B
, w( F4 O, g$ x* W+ }6 u& B' y
; k/ R/ f1 @- y p) M+ ?: y. q% }7 C7 }, b
0 F8 @6 T5 i* Z9 o; T U, z# Z" f' f' z. y4 S6 m: ]2 {9 b7 k; _
sbit DIN = P1^0;
v8 Z* O. _: Z7 u9 D0 j) psbit CLK = P1^1;5 Z$ Z3 ^& D k
sbit CS = P1^2;+ I$ l- M+ P* Q( @% v
sbit SDO = P1^3;- t0 i7 {- q7 I3 I+ F' z* W
sbit ADDR = P1^4;) B7 J, g9 H& r2 C4 x) n, M
sbit EOC = P1^5;
# t' b0 w, k, [& g) a3 U }sbit SCLK = P1^6;
/ _8 f5 ^1 D" C* o- v) usbit SCS = P1^7;
i" p+ A) T% U#define DQ P3_7
7 M/ c) V1 ]9 p* o$ h* e* L#define SPI_CLK P3_0
9 B- S0 ~- Z% k2 q4 G2 k#define SPI_DATA P3_1
2 b! M& k6 w* X4 I/ L% [#define CS_DA P3_2
3 e5 F1 G7 p0 K8 G, }: Y unsigned int k;
3 v' Y' h+ V( v2 Q0 T `5 r9 ~# L% o" Y5 M8 E6 Q1 y
1 L+ W) w( Y& m$ N
unsigned int temp;
/ e7 _# D0 n* ]3 J/ a$ X5 munsigned char sine;
3 @3 a1 J8 d5 e, ]4 ?unsigned char code dispbitcode[]={0xFE,0xFD,0xFB,0xF7};
- g, @2 s, ~9 H; o+ qunsigned char code dispcode[]={ 0x3F,/*0*/2 [9 X6 O0 ~* j8 m! h+ l9 W
0x06,/*1*/
/ K( m7 |" x7 n1 O2 E 0x5B,/*2*/
1 Y) D3 g( ]0 _7 ]! {% [ 0x4F,/*3*/
8 M9 \7 \4 h% A* l 0x66,/*4*/
. ?7 u" k+ |5 L' \ 0x6D,/*5*/
' d; H `5 C8 T- h1 A! J0 ? 0x7D,/*6*/1 P! n( w/ o6 f# R3 m
0x07,/*7*/
4 r- o" O7 R: |* O( B9 v7 L 0x7F,/*8*/
3 _# Z* r/ @2 P9 c% G 0x6F,/*9*/ P9 d) b4 o- ^- t
0x40
3 Z* g$ n9 F* c1 Y0 k! r. x}; 7 U6 {3 ^% C7 |1 L3 }; F0 c
unsigned char buff[]={1,2,0,0};) @" F6 [: k1 }5 {* f
//延时1ms子程序( J7 c# Q& T" T
unsigned char wei[]={0x01,0x02,0x03,0x04};
% f) B! B5 a! Q+ H; [ void delay(uint t)
( A* ?' L, @9 j: R: N0 P{9 i- L. B7 J3 {! x4 a7 b
uint i;
8 B- a9 l2 q4 M' H7 X+ k while(t--)
& F) X' O$ e; T6 D {for (i=0;i<125;i++);}5 B. L. |% l2 |. J& \) ^: k
2 b7 o. Q9 m" c3 \1 e) J6 }7 J) Q0 h# ^
. O% j8 B7 a% `8 g/ r4 g# I( n0 T( N2 k
- L4 ~, {( T4 _. Z- d5 h- c, }$ R; r; l! P2 A$ e
void WriteByte(uchar dat)' B9 d y9 f( e' `
9 `% R' ]8 p1 w/ D# Q1 ~ uchar i;
5 Z9 q* [5 t9 l3 {/ A8 @ for(i=0;i<8;i++)
0 T% W+ G, M3 u3 V/ `0 A4 k6 ^" b' S {
7 O: _5 o! _$ d2 e DIN = ((dat<<i)&0x80)?1:0;
& o1 x! g$ H& e0 m4 p$ c CLK = 0;
, }+ G- W4 z/ X; ? _nop_();7 M8 I6 \5 ~6 w V0 P
CLK = 1;
# a o3 A& \, x0 N1 l _nop_();
( E% q0 t, t- _5 ?, Y/ F" Z9 _ }( h+ @" A# Z! ~5 s% o; E
. i( Y& N6 F7 }/ {: f& `$ R8 uuint TLC1542_READ(uchar addr)' ~+ t+ ?; d( T( k v6 R( }, H
' S0 f# t, \6 l/ F, C# g# Z: x" h uchar i;. ]1 ]: x5 q) [% }6 @' @
uint temp = 0;% I6 }2 B8 L. o$ S
SCS = 1;
/ K1 m* y8 c w9 V+ o SCLK = 0;
: L/ b/ {- I; V
- y6 t) V) j/ k- W5 M! C7 j) |8 C! e7 }9 S
SCS = 0;" E6 b2 g5 h' Q; K8 ]+ s: t6 D7 H
_nop_();_nop_();_nop_();: F( S+ x0 \+ u9 {6 f1 C
for(i=0;i<4;i++)5 P* u7 T% X- N+ ?% l3 x, b
W* v- T( j0 R6 U3 J4 J) u ADDR = ((addr<<i)&0x80)?1:0;
* R9 V* W. m2 @( o |2 \ SCLK = 0;
! M ]8 I% G: G# l _nop_();
/ T! J" t7 {" C SCLK = 1;% b" C- |. K5 ?; v. ?( F
_nop_();& o( T" q$ {! W7 \+ {" X& J2 ~: I$ V( r
}8 K6 v, G/ Y+ `3 i
SCLK = 0;
$ b0 V$ U) d z% T, L1 { for(i=0;i<6;i++)
/ Q" J, l% }- P, ^" l+ N3 { {
# q9 z7 F5 e+ y* y) K/ B SCLK = 1;
2 W0 J% e( e. N$ A _nop_();
$ A0 E6 J3 r! \3 l8 }/ X* T SCLK = 0;
7 |' A+ O% ~4 e _nop_();
) {& u# r' i9 X% J }
* ?+ W" X! E4 y while(EOC==0);
7 z# A+ a- M* ^( v- E SDO = 1;, k" P M" r1 x& D" R: m& S
for(i=0;i<10;i++)1 E1 U8 P* b2 [+ n1 L& V, E" K1 g- F
{$ h2 t2 t9 l6 G, @4 j! s
temp <<= 1;* {. b' h; T$ u7 ~/ h6 u
if(SDO==1)
5 y c6 F" T' t {
6 Z; |9 K7 z0 | temp |= 0x01;! u' |, k6 w3 `* n- [; I
}( a9 Z& p, x5 d$ o/ Q( Q
SCLK = 1;
9 v, r* ?' m6 z7 A# |2 P3 }2 @ _nop_();7 t5 Z9 A7 k* T0 X I* _4 F: s2 ]1 ^( @
SCLK = 0;) \; ], A" ~' T; C# e
_nop_();
: y, P- p$ b7 a* D0 b: ~, Q }" L ]9 m5 l# g. ~) X
SCS = 1;9 v( L5 h& ?9 X @5 D
return temp;
# P2 G4 A8 B2 o}
, Y3 E$ e* ^2 `) N. W' R: V void tt1ms(uint z)% b0 T/ D1 f0 _/ ?5 O& g0 e( g
{* v% W( w7 | ~9 \
uint x,y;
2 }6 V; m" v1 i& i( t) S" f- U for(x=z;z>0;z--), L/ F& S: l+ N" A3 x
for(y=110;y>0;y--)
( _2 f# Y- y E! m. s ;
% C. I0 i# { {/ J) K}( W. z+ ?% Z2 @- k5 \# |2 u
void disp()2 |/ E; f; X9 @
5 t6 q3 E( z1 M2 a* s
) W) u0 b: L& z
* S5 f, b* J1 T4 l- n E4 B+ |
3 a. R7 T+ N( E+ x
" w2 S/ v8 D" R8 u
) p N/ W( k) N, C
- v8 g. x6 S% c1 E2 p! u+ F for(k=0;k<4;k++)
% h/ {- S. F0 D' c" Y { buff[0]=temp%10;% A2 @- Y j- T' J2 L/ c* Q
buff[1]=temp%100/10;
& @9 L; x; c" n3 b/ _3 ` buff[2]=temp%1000/100;
" T' k! S i. v( Y4 E buff[3]=(temp/1000);( D1 w5 v) S9 ?: u; U( c
delay(7);; u6 T5 g" Z1 n4 x
if(k==3)
9 G. V% L* t" k, ]2 [$ A {P0_7=1;
( s7 ^" X( m4 Z, U& a1 s; @ U# G delay(3);
; D& R+ B0 R( m; z! ? e$ O P0=0; }
* }7 j. I# a* L3 r# m4 B+ s5 P' d) E * r5 B# Z+ W& E: \
P2=0XFF;
1 ~) q3 n) b; z. U* w+ e% A/ H P0=dispcode[buff[k]];' j. F2 G: O* x
P2=dispbitcode[k];0 ?2 }0 @: b) d5 X/ ^% |6 K) q
2 E( l# e$ L/ Z) G, o6 P4 m / ]' q* B* R. P2 y6 {
}4 O) {- R, L$ T8 u8 H7 Q b5 ?
}$ K0 D1 j4 D" t1 X
$ Z5 c7 M M. H5 c/ r1 \. L
2 v N4 h, k7 t$ W
8 m7 P3 q/ ^$ R$ ?
1 s8 L( V7 O+ r% c6 g& s- T# |1 _# m6 G# g; N) e
! C2 I& j7 K1 q( B- J
void da5615(uint da)0 J4 @* P+ l4 u3 P# k7 y
: D" x# a$ r q8 Q+ \ B; r/ P
$ d* P( ?3 ]7 I. R+ D: k
{- @/ A/ S. r# `; y s9 Q
uchar i;
/ Y. I1 L0 n. t) \8 N& zda<<=6; q& S1 K) p/ {. g# e
' K' c& I% i- t: X" F) u* h4 a. B6 ^2 F. r4 H' E: s6 w
' {. i O$ Q% k; q2 e. |; M n% I8 K) h4 n3 n+ t) [
, w7 F0 w% p2 a5 G/ Z3 C" n8 ?/ X6 Q6 q. g2 b9 w
CS_DA=0;
! H2 K- u7 x5 n( F5 HSPI_CLK=0;
& B/ E( z+ ]0 |, W, F' r; d9 {+ Y, a5 |' S
: |$ d7 n i' L( X
3 P# u" Q- W4 y0 D& _1 Y: Z- W
- f) G" B8 d2 o6 W& P: R' g8 |" a& i4 P# J
5 k/ O' A; u3 jfor (i=0;i<12;i++)
+ H9 T6 |, l' C# N" P{6 h' w4 C* K5 `+ d Q
SPI_DATA=(bit)(da&0x8000);5 p+ H* {6 m& U$ T
SPI_CLK=1;, ]8 B( A* D; {8 ^8 ]( o a+ d }* P0 [
da<<=1;/ U) q3 k F+ I3 K2 D1 W' j5 r
SPI_CLK=0;( I# o. U) p, E; z& b+ c
}6 z+ z- o+ F6 O; \! l- i% l
T7 `6 Q8 Z' e( G, G1 R
7 n( X, m. ^5 E
4 a$ A* U$ y3 O0 U) k3 d& X
6 v2 r( a# ?/ R/ h8 y" O! l" G
3 b( B' N& |- g; g% M/ H! J
: U/ q8 C7 c1 I. r8 ]4 j
CS_DA=1;8 |, t+ |+ p8 ^9 O' e$ j
SPI_CLK=0;
& B& o$ J1 _ W$ a, D7 Hfor (i=0;i<12;i++);; K/ u, u( j' O; h, {0 P2 g/ l
, c6 W4 P+ Q. @* m1 N2 F4 V! u0 F' ^9 i3 Z! b5 a
2 C' w1 a9 k* `% _/ h" ]
void tlc5615a( )
. e! [6 |" L/ h( L1 r{
: ^& K" ?6 `+ T0 q) R( _' k 9 f- [* t! J% ~
if(P2_6==0)
% C8 R* d. { J }- h { delay(4);# p$ l7 |6 d$ h% G7 o
if(P2_6==0)
4 r7 J% h4 [, x- Y! l ! \, D, Y8 W& u& y0 E6 ^& B
{ sec++;
4 A# B$ M) r$ z+ l$ p
. ]: K0 R' k4 Q3 a. j/ B9 D6 S% N/ n c
) x/ s- K7 ]. u: T# k9 f ?) \
8 Y: H1 I8 k) N5 M( i }
( t0 ]! Q3 w# ]. c! Z: \. N }' A# R: M4 J* h) y# ^
# j. E, F2 t/ l0 E: {* M* I: b2 M% d, p- G3 X
if(P2_7==0)
k, P, e$ V$ L: u3 s { delay(4); h6 @, C8 u, t8 m
if(P2_7==0)2 i5 V7 h; a% S1 x# V# q7 X
# Y. P# l: S) I: h! A { sec--;3 s5 H! @* q3 C7 s5 o. o. H3 U( _
if(sec==-1)
" E8 h5 S$ F+ p' Q {sec=0xff; }, c9 H' `3 Q$ y. x ^1 c
( Q1 E3 x3 ~2 o+ j5 v+ V
# L5 a0 _- {) z9 K( c! G
2 ^# H$ a' W# j4 N: D- b
6 o; A3 }* P3 h2 Q# d/ S' g" M }; |5 z5 x' U8 y6 J
2 U# ]+ I, x/ n- Dda5615(sec);+ t& g0 r" d) v- z
7 r) h- p3 q; |
5 L! X% e0 Y. n S8 m- W( h, j* J7 A: ^+ \4 j- Z! T
7 d' y+ i# N0 Q6 E1 _4 K
void main()2 [$ m$ R6 I v% O
{ sec=0x9f;
4 f g! v/ V4 O6 `; F) l while(1)
9 a+ Z, m/ ^5 W4 W& o7 x- m {5 o/ R. F* E. l
4 Y# o4 k% |3 o& C+ G
1 g5 z3 p' ^/ y, ^5 A1 G, m2 _" P, N. G' y2 F/ W6 p( E- l
…………限于本文篇幅 余下代码请从论坛下载附件…………
/ ] D- S5 f8 V- ]3 r2 J$ a3 Y 6 }2 J2 X$ h% O
! ?1 Z1 K V5 b! H: p
. G5 \' ]6 d5 [" s" T |
