群里的朋友,EMMC芯片,我们之前使用江波龙的NCEMAD7B,没有规格书,程序是V4.0,我们是用全志的平台R16,现在芯片用的NCEMAD9D,是5.1的EMMC芯片,硬件连接上多了H6,T5接地,其他的没有变化?是不是软件也要升级?[17:52:27.355] workmode = 16' O+ _ }6 a6 b# B
[17:52:27.355] [ 5.115]NB1 : enter phy init6 E. ~* t N$ f {: b3 J
[17:52:27.355] [ 5.119]nand_physic_init
; S6 o' k; z: U[17:52:27.355] [ 5.121]Reset NDFC start 0 0
( J* V& Q9 L$ {6 G" w8 O( A1 a[17:52:27.355] [ 5.124]Reset NDFC end 0 09 N' ?- f" h% P6 a/ j. r: x
[17:52:27.355] [ 5.127]nand not support! channel 0 chip 0: f0 f0 f0 f0 f0 f0 f0 f0
/ u" }, t7 C/ z1 ^, y [ Z[17:52:27.355] [ 5.134]nand not support! channel 0 chip 1: f0 f0 f0 f0 f0 f0 f0 f0
1 |: N+ E% j* _$ F6 ^[17:52:27.355] [ 5.140]nand not support! channel 0 chip 2: f0 f0 f0 f0 f0 f0 f0 f0
. z7 q( E% }+ c$ [1 \[17:52:27.355] [ 5.147]nand not support! channel 0 chip 3: f0 f0 f0 f0 f0 f0 f0 f02 B( B5 R8 s+ ~' E7 K& x! R
[17:52:27.355] [ 5.153] no nand found !: A2 C: W V$ l! q1 c
[17:52:27.355] [ 5.156]nand_physic_init nand_build_nsi error
3 h: M) ^: r5 U9 C o[17:52:27.355] [ 5.160]nand_physic_init error -10 n3 Z1 ~ z \+ I5 r
[17:52:27.355] NB1 : nand phy init fail
1 s) s& Y' H( ?- @0 ^: X6 q[17:52:27.355] [ 5.166]NB1 : enter phy Exit
( {( t( H7 T. ?8 j) {$ C' o/ g[17:52:27.355] [ 5.169]nand_physic_exit" k, M' C8 b6 n7 c6 H, |
[17:52:27.355] try nand fail
1 A+ S+ F9 D. w' i4 ~; N; z) e+ y9 e[17:52:27.355] [ 5.173][mmc]: mmc driver ver 2014-11-25 17:03:00
% w4 `, U u' Z% q# @) V3 x[17:52:27.355] [ 5.178][mmc]: get sdc_phy_wipe fail.
- l3 }- L, C$ q9 b[17:52:27.355] [ 5.182][mmc]: get sdc0 sdc_erase fail.; X7 i/ F; _) p. ~# A. A( D
[17:52:27.355] [ 5.186][mmc]: get sdc_2xmode ok, val = 1
5 v _, k- \+ G& k9 z5 \[17:52:27.355] [ 5.190][mmc]: get sdc_ddrmode fail used = 0. L7 l/ I; }& }# U0 z+ u
[17:52:27.355] [ 5.194][mmc]: get sdc_f_max fail,use default 50000000Hz
9 k/ |7 M A6 z- C* Y[17:52:27.355] [ 5.200][mmc]: get card_line ok, card_line = 40 C- T7 I) i9 }" R" G" W% @. o- O
[17:52:27.355] [ 5.204][mmc]: get sdc_ex_dly_used fail,use default
# N% }: W1 g' y; D1 @: k9 k `* D[17:52:27.355] [ 5.209][mmc]: SUNXI SD/MMC: 2( R8 p& x% u/ F& b
[17:52:27.355] [ 5.223][mmc]: *Try SD card 2*
4 V; n( H6 y5 R' }, a) c[17:52:27.390] [ 5.226][mmc]: mmc 2 cmd 8 err 100
( ?3 I3 a% h' z6 h K[17:52:27.390] [ 5.232][mmc]: mmc send if cond failed
2 K% l7 b. x+ L4 Z) x0 I[17:52:27.390] [ 5.236][mmc]: mmc 2 cmd 55 err 100
7 |3 B# i) L- r+ x3 s. H s[17:52:27.390] [ 5.241][mmc]: send app cmd failed9 G/ b m' I! p: N- p
[17:52:27.390] [ 5.244][mmc]: *Try MMC card 2*
% S1 z) w3 }* u( U[17:52:27.390] [ 5.268][mmc]: Invalid ext_csd revision 8
9 H. g) z; I% t) o5 F[17:52:27.406] [ 5.283][mmc]: unrecognised EXT_CSD revision 89 n- ?/ I" i+ n; ]4 a" s2 {
[17:52:27.434] [ 5.288][mmc]: decode ext_csd failed) S* U$ k% k8 D
[17:52:27.434] [ 5.310][mmc]: CID 0x88010344 0x39443038 0x47246d01 0x8523a575
; m& F* }- p" D1 ?, ]$ \8 A. O[17:52:27.510] [ 5.315][mmc]: MMC ver 4.01 K* N0 E9 H4 z' @" C8 S
[17:52:27.510] [ 5.318][mmc]: mmc clk 50000000
`7 C; M) d* r; f% Z5 H# G, o, P3 y4 \[17:52:27.510] [ 5.321][mmc]: SD/MMC Card: 4bit, capacity: 7396MB
K" r h s+ m+ [[17:52:27.510] [ 5.326][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB& f. i$ G" z! q _# Z7 n" W
[17:52:27.510] [ 5.332][mmc]: ***SD/MMC 2 init OK!!!***2 w0 k; D9 b! J8 z I+ d
[17:52:27.510] [ 5.337][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte
3 O& }' u6 r2 b[17:52:27.510] [ 5.342][mmc]: secure_feature 0x55! X, p+ G) g" ~4 S2 n
[17:52:27.510] [ 5.346][mmc]: secure_removal_type 0x9
+ l( Z* x9 N( \. Z* x; E# y$ `) k[17:52:27.510] read flash error4 U0 X5 b' r2 b3 T& w) _/ z
[17:52:27.510] out of usb burn from boot: not boot mode) i8 ~( b' M- z' U& t9 r! x+ h- b: q
[17:52:27.510] In: serial
; G/ _6 K1 m3 }[17:52:27.510] Out: serial' [) W* K3 q; }2 l
[17:52:27.510] Err: serial
2 }% e2 D. V& i$ m# ]( ^[17:52:27.510] --------fastboot partitions--------
, m2 U( }+ l; f) @* X5 [$ R[17:52:27.510] mbr not exist8 b# I2 G( t6 H/ \7 l' }, ?/ L
[17:52:27.510] [ 5.364]Hit any key to stop autoboot: 0 4 ?5 o _* [9 f) z$ P5 j2 N
[17:52:27.510] work mode=0x10% A, h' k; _9 N
[17:52:27.526] run usb efex0 v: w& |1 d/ L2 l( x* B
[17:52:27.526] buf queue page size = 65536$ a, p" f7 Z. m6 F
[17:52:27.526] delay time 2500
; L/ L3 k( F9 k, g! a[17:52:27.558] usb init ok$ \1 Y$ |7 B6 @0 {% _6 {
[17:52:30.089] set address 0xb
5 ^0 _6 A: u3 a* C# y[17:52:30.440] SUNXI_EFEX_ERASE_TAG3 f" X; y( \) ~- U( U
[17:52:30.861] erase_flag = 0x18 P x5 k2 P# Z1 _1 Q( b. E
[17:52:30.861] FEX_CMD_fes_verify_status
2 h4 r, f+ k6 _+ i[17:52:30.861] FEX_CMD_fes_verify last err=05 z3 I- B) X& G! V- R
[17:52:30.861] the 0 mbr table is ok
( s1 y8 @! f/ a5 |[17:52:30.861] the 1 mbr table is ok
9 f) [' [) g- Z! y5 ]% H- M: Z[17:52:30.861] the 2 mbr table is ok
$ h$ o2 y+ _8 l* _! w7 w[17:52:30.861] the 3 mbr table is ok
! K* N3 L, Y8 b; s" n1 j$ O5 ], B[17:52:30.861] *************MBR DUMP***************6 G1 T1 H9 |; f; n" n- C
[17:52:30.861] total mbr part 11) o$ c% _1 M" Y6 B5 q
[17:52:30.861]
4 o) g0 U6 `; g6 b/ e& p4 v[17:52:30.861] part[0] name :bootloader
* `& t2 _ _! I7 M. Z[17:52:30.861] part[0] classname ISK
/ p' y! |# I: e2 e( o! U[17:52:30.861] part[0] addrlo :0x8000 D) n( I# p l+ Y0 }9 W* |, Y
[17:52:30.861] part[0] lenlo :0x10000- ~; x0 {% H6 S4 k! D3 T B" p
[17:52:30.861] part[0] user_type :327688 J' z1 M# F7 Y
[17:52:30.861] part[0] keydata :02 W7 m% G5 t7 x5 K
[17:52:30.861] part[0] ro :0
* J# Q( P+ o8 S4 L1 |# d. S' _[17:52:30.861]
- }' Q0 }" ^" T1 t0 x) G[17:52:30.861] part[1] name :env% D+ ^" {2 C3 m$ [4 d
[17:52:30.861] part[1] classname ISK
, m4 b. T/ b/ v[17:52:30.861] part[1] addrlo :0x180000 G5 z0 a& r, ]2 f
[17:52:30.861] part[1] lenlo :0x8000( s U2 j, g2 G* R/ r; p$ C- ?
[17:52:30.861] part[1] user_type :32768
8 @) j$ Y0 i: ?' u' I$ G! p% q& E[17:52:30.861] part[1] keydata :0( ^. [1 h/ U6 \! Z7 S
[17:52:30.861] part[1] ro :0$ S8 J3 E! ~* h5 t' i1 d' f4 O0 \
[17:52:30.861]
" P1 ^, K, F# Q; O* c; `/ K[17:52:30.861] part[2] name :boot
- ]- k5 V6 F. u; M1 e! s! T[17:52:30.861] part[2] classname ISK
& w, t1 `% G: }* X[17:52:30.861] part[2] addrlo :0x20000* c" O z* }1 u+ e% G* z( T
[17:52:30.861] part[2] lenlo :0x8000
3 x5 z! f+ _8 t8 M6 E[17:52:30.861] part[2] user_type :32768
7 ?/ f$ l( c, M( d[17:52:30.861] part[2] keydata :0
7 n5 A# q, \- t0 p[17:52:30.861] part[2] ro :0
) G, {# `& \/ k1 g' b( r[17:52:30.861] ' o O) S+ P; @& V
[17:52:30.861] part[3] name :system
. A0 {/ w' ]9 o6 \4 w" T[17:52:30.861] part[3] classname :DISK
' E* j( \4 I5 Y: P- H5 J[17:52:30.861] part[3] addrlo :0x28000" a5 m" L6 L; \+ M& U
[17:52:30.861] part[3] lenlo :0x200000( \4 N( Z4 g& s. k) t. C# }. _
[17:52:30.861] part[3] user_type :32768: U5 E) O+ Q/ i2 h0 C6 F
[17:52:30.861] part[3] keydata :0 h. Z/ W6 {4 O$ p
[17:52:30.861] part[3] ro :0
/ Q6 R2 a: ]8 E3 _0 [" }[17:52:30.861]
. O- `& e$ q/ d[17:52:30.861] part[4] name :misc/ U9 ~1 W' h, R
[17:52:30.861] part[4] classname :DISK c* k6 @6 T c( @9 P2 H* g
[17:52:30.861] part[4] addrlo :0x2280000 q3 d8 w2 e$ G; g; x$ X5 p. g
[17:52:30.861] part[4] lenlo :0x8000
r/ A( z' Z8 B: f( z[17:52:30.861] part[4] user_type :32768$ ?& s y& `; P/ D9 { W3 p
[17:52:30.861] part[4] keydata :0! L' G. v2 ?1 q% D# N5 r* i" `4 h
[17:52:30.861] part[4] ro :01 C, G/ C" G! F; o) T
[17:52:30.861]
5 ^ a7 y9 k* J6 r% X! S1 i2 q[17:52:30.861] part[5] name :recovery
3 \( o! I2 W) K* c[17:52:30.861] part[5] classname :DISK
: ^% r4 z4 z0 X[17:52:30.861] part[5] addrlo :0x2300001 Y1 R: A# v- z
[17:52:30.861] part[5] lenlo :0x10000
8 ?* p% j# \' z+ ^. C[17:52:30.861] part[5] user_type :32768
. w, j Q) {# q. [[17:52:30.861] part[5] keydata :04 U& ^" p) t* a% Q$ @* `
[17:52:30.861] part[5] ro :00 }. g$ [# e) W
[17:52:30.861]
1 O/ G" u' F7 ~- k- w- r[17:52:30.861] part[6] name :cache
* n0 I" R. m$ H[17:52:30.861] part[6] classname :DISK
( A' j( o# c* y[17:52:30.861] part[6] addrlo :0x240000" W# i) [4 G9 m: B+ F! T
[17:52:30.861] part[6] lenlo :0x180000
& k# J8 g9 p" W, F3 k8 b$ o5 u( d/ Z[17:52:30.861] part[6] user_type :32768
Z" K: ]' O2 X1 [[17:52:30.861] part[6] keydata :03 h* o# I8 A) N- S- P2 s5 U
[17:52:30.861] part[6] ro :0
! l: Q4 G; t3 u: G) B& w9 [[17:52:30.861] " g; Q% O3 F) b0 {4 l+ `! k0 x
[17:52:30.861] part[7] name :metadata; V4 d% X! _# Z4 t( @
[17:52:30.861] part[7] classname :DISK5 k! M# b; i n) S, c
[17:52:30.861] part[7] addrlo :0x3c0000
" n9 H% U7 f$ e$ J ?* i# @4 C[17:52:30.861] part[7] lenlo :0x8000
% b% |1 N/ z' L4 \; ?[17:52:30.861] part[7] user_type :327688 S6 J& x' h2 U; r
[17:52:30.861] part[7] keydata :0$ X; \. a( |8 X$ L2 N( {( D( z
[17:52:30.861] part[7] ro :0! _' v0 T' ]4 y; _7 ^7 ?- c
[17:52:30.861]
' y+ G) q2 ^) u[17:52:30.861] part[8] name :private
1 t: @4 b& a1 F1 ~# z: @+ m8 C" G[17:52:30.861] part[8] classname :DISK, S9 B8 l5 S% k0 ^2 F; |1 }6 k
[17:52:30.861] part[8] addrlo :0x3c8000# ]( d' r" L6 S
[17:52:30.861] part[8] lenlo :0x8000
# Y$ A2 y0 D# t, O. w[17:52:30.861] part[8] user_type :327687 d; a1 r" Z# k; R! {' B8 a
[17:52:30.861] part[8] keydata :1
- z) z4 w1 x( t1 y[17:52:30.861] part[8] ro :0
1 o; R( s: N! J[17:52:30.861] 7 s3 G/ h" `+ V7 }5 Z- ^
[17:52:30.861] part[9] name :alog" ~( F6 D g, N2 ~* O% R8 n4 B
[17:52:30.861] part[9] classname :DISK2 S2 l) {; o8 [
[17:52:30.861] part[9] addrlo :0x3d0000* ~ Y7 @ s% D2 c6 p' g
[17:52:30.861] part[9] lenlo :0x28000
) W# n' s3 f4 {9 b2 i[17:52:30.861] part[9] user_type :32768# o3 J9 T- L$ v8 f; @; K) J
[17:52:30.861] part[9] keydata :0$ M# {1 \: v8 H& i u1 D" g& w6 G# c
[17:52:30.861] part[9] ro :02 N' _ V2 t! r C" i; d: q) H
[17:52:30.861] 8 _! k( P9 L) F7 h
[17:52:30.861] part[10] name :UDISK
0 @$ K* x& l' |* F9 @! b[17:52:30.861] part[10] classname :DISK/ K3 R0 }, m) j" Q3 ~
[17:52:30.861] part[10] addrlo :0x3f8000; p; L/ {2 m, E2 B: v7 `2 b' N
[17:52:30.861] part[10] lenlo :0x0
% N/ B. h/ V9 @/ D }1 t+ H[17:52:30.861] part[10] user_type :33024* j7 H1 Q0 J' h* x6 r/ t
[17:52:30.861] part[10] keydata :0
" x. ]0 h6 b: ?. n& Y. \[17:52:30.861] part[10] ro :0
" }9 F) T7 d9 o7 d$ N, H& ^) E[17:52:30.861]
6 K* A6 n1 {3 T[17:52:30.861] total part: 121 G* Z# ]0 x0 Q& ~1 U$ a
[17:52:30.861] mbr 0, 8000, 8000) p3 ^6 `- J1 Q' N& h( D' ^& Y
[17:52:30.861] bootloader 1, 10000, 80000 L6 n! o8 J6 g
[17:52:30.861] env 2, 8000, 8000
6 [* Y T* l& \, E: v[17:52:30.861] boot 3, 8000, 8000
/ E$ p- C% t+ `6 P+ f+ _1 P0 }[17:52:30.861] system 4, 200000, 8000
+ y# ?, I8 e0 s( z k) ]; o[17:52:30.861] misc 5, 8000, 8000- z8 z+ C. I; M3 S! b1 G
[17:52:30.861] recovery 6, 10000, 8000
! h7 w4 V! H0 o/ y d[17:52:30.861] cache 7, 180000, 8000: M$ Y- o. V- E& x _
[17:52:30.861] metadata 8, 8000, 8000* J+ B3 T. }8 O
[17:52:30.861] private 9, 8000, 8000
7 n: ^" Q# d( I6 A[17:52:30.861] alog 10, 28000, 8000
; d% j! \1 i$ V& C( c, i/ r[17:52:30.861] UDISK 11, 0, 8100
' g0 @; [. g3 ?+ a4 x" [8 m& I[17:52:30.861] do need erase flash8 A4 e/ Q# v1 D4 Z: u5 k
[17:52:30.861] private part exist
, t' r- s S) X6 u[17:52:30.861] the 0 mbr table is ok
$ _' @4 A- t8 l[17:52:30.861] the 1 mbr table is ok
! K3 R* c- l k" s[17:52:30.861] the 2 mbr table is ok
5 u7 z* l" a" P; B( J6 p[17:52:30.861] the 3 mbr table is ok
( z$ c w( f) f9 J( i# r3 ][17:52:30.861] *************MBR DUMP***************
3 B" w( A3 f) Q8 U0 e' Z- V[17:52:30.861] total mbr part 11
( f' U! }/ _9 E% W8 T# J) K[17:52:30.861] ! f& J/ e1 ~/ [1 d4 `; {
4 f$ t5 ?' [' h( s) j[17:52:30.861] part[0] classname :DISK3 L+ C2 |2 Z% ]3 ]1 N8 I
[17:52:30.861] part[0] addrlo :0x80000 M6 V$ h! A, h% P; @
[17:52:30.861] part[0] lenlo :0x100007 x) s9 [* G4 q8 K8 i
4 L' V6 H1 k1 S& ^8 Q$ f[17:52:30.861] part[0] keydata :0& J$ b* t* K! p$ `4 Y3 H1 a
% ?! g, A1 l* k[17:52:30.861] 8 Q; e: a$ F/ Q- B. \1 i; |
% c" B5 o, H( s* b- Q( T7 o- p( w[17:52:30.861] part[1] classname :DISK1 F" h! V7 L2 S* C; C5 J
[17:52:30.861] part[1] addrlo :0x180008 v7 L U9 g% t
! s0 l$ r/ E, [- A2 s0 e[17:52:30.861] part[1] user_type :32768! v8 u$ g3 h, q; a7 l6 g {9 `
; F0 \$ ?- g. n, o. ?/ k* l `[17:52:30.861] part[1] ro :0
* Q3 y+ R; A% u7 j[17:52:30.861]
8 B- n/ [# v, G( y, _3 q) x# e+ j, `[17:52:30.861] part[2] name :boot, {6 A$ Y4 e6 U9 W) L. Q' C
[17:52:30.861] part[2] classname :DISK
; S' @9 R+ A0 n[17:52:30.861] part[2] addrlo :0x20000
! K; O; X9 M6 _2 Y+ b% _2 E[17:52:30.861] part[2] lenlo :0x8000
7 E. k0 H* a4 r8 V0 g2 \[17:52:30.861] part[2] user_type :32768$ w) m8 |3 O/ U, p- H3 J
[17:52:30.861] part[2] keydata :06 t8 c/ m! P* c! P- a- K2 o: X
[17:52:30.861] part[2] ro :0, B; \" y1 a4 J: }0 n
[17:52:30.861] : J, `8 ^, e" F" }8 O, i' a* b! C- m
[17:52:30.861] part[3] name :system; I, P$ ?* |2 r( l( B, r
) }/ N: `# b/ ?* H[17:52:30.861] part[3] addrlo :0x28000: y' p+ T0 Q x" y4 ?. i+ e( O
[17:52:30.861] part[3] lenlo :0x2000005 C. e( @: h* @: h. o
[17:52:30.861] part[3] user_type :327684 G" l! x& A+ L x# G% u3 s4 G) J+ x
. J; D' D; A5 V[17:52:30.861] part[3] ro :0& z" {0 e4 m5 v0 A E
[17:52:30.861]
" B" G% i4 k* }: M# `; l[17:52:30.861] part[4] name :misc
6 N8 {, O+ V) d" r[17:52:30.861] part[4] classname :DISK
% o3 N" R- T: w# F4 F4 F[17:52:30.861] part[4] addrlo :0x228000
8 q5 [* B$ t# w$ n[17:52:30.861] part[4] lenlo :0x8000) ]* [" B; G1 }& K8 I" @
[17:52:30.861] part[4] user_type :32768* d5 C: D* z* J* P
6 d1 b, Q. H) C: { q6 A9 {8 F[17:52:30.861] part[4] ro :0
0 R8 r; {- C9 J _- e[17:52:30.861] A2 |! I# B/ L+ h% G) j5 c5 ?
# _ B0 T+ T9 L/ D[17:52:30.861] part[5] classname :DISK( N& w; n0 N0 s& [* I5 G3 z% F `% Q [
[17:52:30.861] part[5] addrlo :0x2300002 l. i/ P7 ]9 m8 J' L
[17:52:30.861] part[5] lenlo :0x100008 |7 Z# ?- T. D0 Q* Y
[17:52:30.861] part[5] user_type :32768! U& _) E2 c! I% I0 X: i) ^
$ u( q$ _+ ^& m2 D+ g |+ D[17:52:30.861] part[5] ro :00 k B. p1 N, @% p* x
[17:52:30.861]
8 ^" ?* Q* ] ]3 x: @[17:52:30.861] part[6] name :cache
}' G) F$ T9 A, y2 c[17:52:30.861] part[6] classname :DISK0 C$ K0 G' G: r: O) c5 W# c
6 | Q% n8 W5 S( k) u7 V[17:52:30.861] part[6] lenlo :0x180000
: i6 W0 S- a- g2 ][17:52:30.861] part[6] user_type :327689 C4 x* S. \3 [ k8 e7 v0 A; i( A
! \( H& [* J. h1 \! T. C1 R[17:52:30.861] part[6] ro :0) z- J% `* [ ?0 `7 r' m2 d. g: |
[17:52:30.861]
) R! i: R9 q) @7 w+ d8 y- m+ {[17:52:30.861] part[7] name :metadata' _' I" [" {6 N0 g9 _" V
[17:52:30.967] part[7] classname :DISK3 E- _3 K1 W$ `4 w& K
[17:52:30.967] part[7] addrlo :0x3c0000' a# D$ i. W" G6 s8 O' |+ S
[17:52:30.967] part[7] lenlo :0x8000 b; ]) x; N, M# }6 c8 d, j
[17:52:30.967] part[7] user_type :32768
- [/ L3 w: H! X8 Q[17:52:30.967] part[7] keydata :0
9 f+ G ?/ w, A s[17:52:30.967] part[7] ro :0
% m; k- f/ T. p* k z& v# R[17:52:30.967] + J$ {( f$ E! H& V: m$ |' W( e1 g
[17:52:30.967] part[8] name :private
, _) P5 g' Y0 X9 W1 h6 f9 s6 d[17:52:30.967] part[8] classname :DISK0 d# ^ Q+ v- I" g7 y
[17:52:30.967] part[8] addrlo :0x3c8000; t/ A _' @' B& L4 `- t( ~, q
[17:52:30.967] part[8] lenlo :0x8000' x _+ S \8 D% N
[17:52:30.967] part[8] user_type :327686 T1 {: B# T/ @
[17:52:30.967] part[8] keydata :1
# u# F! F& E$ }/ \8 N9 p8 h" d[17:52:30.967] part[8] ro :0( U* h3 V4 i( Y
[17:52:30.967]
1 Q* Q: h; W$ P% ~6 L+ i[17:52:30.967] part[9] name :alog
3 H* T' h' j- G1 V/ D[17:52:30.967] part[9] classname :DISK
C9 f/ g- P, N4 u[17:52:30.967] part[9] addrlo :0x3d0000
1 `( f8 Y# `' g. `% U[17:52:30.967] part[9] lenlo :0x28000
( e" Y8 o( K! ? @: C8 m+ ~8 h4 M[17:52:30.967] part[9] user_type :32768- O9 R% U9 S c
[17:52:30.967] part[9] keydata :0
( F/ F, {' W3 L: d- v. j( W[17:52:30.967] part[9] ro :0
- r' a/ b9 d# l B( w& Z0 V[17:52:30.967]
, b( w) c9 o9 U% e, k9 z[17:52:30.967] part[10] name :UDISK& T5 o' A+ t* ]# H
[17:52:30.967] part[10] classname :DISK6 N6 S2 K( s m7 |; {* y. K- |- |
[17:52:30.967] part[10] addrlo :0x3f8000( M7 ^9 w" j; \9 D% e Y! Z+ i
[17:52:30.967] part[10] lenlo :0x0
; u1 B1 p0 _4 Z. d[17:52:30.967] part[10] user_type :33024
( N$ a8 [$ I3 F* ]) y1 s, M[17:52:30.967] part[10] keydata :0
; G9 v/ ]& G, V# c3 m7 d[17:52:30.967] part[10] ro :0
# K+ a. E! F$ L[17:52:30.967] ' z- [) o3 U, r/ G& }* H
[17:52:30.967] begin to store data
0 D+ u- l; O# i5 t[17:52:30.967] part name bootloader9 R1 D7 P+ S, b' v. D" c
[17:52:30.967] keydata = 0x0+ y* z+ F* C5 ?0 f/ f# y: J9 |2 D
[17:52:30.967] part name env5 C! @( W( J& h1 S9 n
[17:52:30.967] keydata = 0x0+ E. r, V3 s6 K
* U& F. Y6 q3 _8 i[17:52:30.967] keydata = 0x0( C+ r# P) d5 {% o* d8 i
[17:52:30.967] part name system! s, `( x* b2 S& l
2 _) p3 V, d+ A* n$ r1 \" ?0 S# X5 m[17:52:30.967] part name misc: f& I% i, I+ E" [
[17:52:30.967] keydata = 0x0 U& f9 q3 F' F/ R: m; P+ W
[17:52:30.967] part name recovery, y7 `( O: e" U# v2 S, h
8 B8 j1 q& o% M$ g7 p8 z2 I J[17:52:30.967] part name cache
) i2 r# c' N, }; i+ {[17:52:30.967] keydata = 0x0. U/ H; L; i. m5 k- d3 g1 g9 H$ |8 t
[17:52:30.967] part name metadata
1 |6 F: I2 U# i[17:52:30.967] keydata = 0x0
9 a. u R V5 v' r0 c g. W[17:52:30.967] part name private
1 X0 `4 J# N) G* f# W/ x( n1 h[17:52:30.967] keydata = 0x1# @4 q9 N, B/ z& z
[17:52:30.967] find keypart private
# @$ @% m/ A1 H[17:52:30.967] keypart read start: 0x3c8000, sectors 0x8000
# E; C: Y- t9 o[17:52:30.967] keypart part private read end: 0x3c8000, sectors 0x8000% L; J/ ?: q! }% b t
[17:52:31.683] part name alog
9 e& d- I4 O# J9 P8 a[17:52:31.683] keydata = 0x0
& B& `4 m. o, J% r" s( d[17:52:31.683] part name UDISK) X' }9 C7 B3 _, o$ ^
[17:52:31.683] keydata = 0x0* q( I2 Y0 w0 r: \
[17:52:31.683] need_erase_flag = 1) ]7 m1 a8 q! V+ `# Q0 }% o" O
[17:52:31.683] begin to erase
+ l7 G* `; Z# W G" N[17:52:31.683] [ 9.537][mmc]: mmc start mass pro boot part...4 X, n, L; ]* ^% {5 T/ {
[17:52:31.683] [ 9.584][mmc]: mmc start write user part after write boot part...0 |' c+ z, t0 q' C9 c, L4 n
[17:52:31.756] erase boot0, size:32k, write 0x00* [8 t% b. a5 e+ H
[17:52:31.756] erase env part* q6 L* t6 X# T( Y3 b0 B- Q
[17:52:31.756] [ 9.598][mmc]: erase from: 139264, to: 172031, cnt: 32768, erase_group: 1024
5 f, m( H5 T3 Z1 U) R/ i[17:52:31.756] [ 9.606][mmc]: unrecognised EXT_CSD revision 8" \/ {9 b' H6 n
[17:52:31.756] [ 9.610][mmc]: decode ext_csd failed {* [$ V2 Z2 c/ Q! `" o. Z
[17:52:31.756] [ 9.633][mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x1c52 us ! ^1 a* [* p% X# Z3 {
[17:52:31.823] [ 9.639][mmc]: calculate timeout failed9 Z- N" l! E8 A7 [7 S/ u* K
[17:52:31.823] [ 9.643][mmc]: Do erase failed!
2 c1 j- s( v3 `' e: d6 v: u[17:52:31.823] [ 9.646][mmc]: erase failed, range 139264 - 172032 # j; J v0 ^* T8 y" M
[17:52:31.823] [ 9.651][mmc]: mmc_mmc_erase: erase emmc fail!# V1 a3 K1 w6 m+ z. h0 u9 p
[17:52:31.823] [ 9.656][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
( C, @/ i& s7 R$ O( a2 l$ k[17:52:31.823] [ 9.662][mmc]: --0: from139264 nr32768 ' K( C6 D5 H& C! m
[17:52:31.823] write zeros-0: from 0x22000 to 0x29fff- ~% K, y5 y% y- r
[17:52:31.823] [ 9.670][mmc]: mmc start mass pro boot part...
5 y% e! F2 S( ?$ q% H0 A& _# F[17:52:31.823] [ 9.674][mmc]: boot0 start address 139264
1 O6 i w7 [ _: Q0 _$ |& g1 |[17:52:31.823] erase boot part* t( Y9 f6 z: \; `1 v l7 M
[17:52:32.539] [ 10.407][mmc]: erase from: 172032, to: 204799, cnt: 32768, erase_group: 1024+ F: p, e( Y4 x/ v u/ X8 A7 k
[17:52:32.566] [ 10.415][mmc]: unrecognised EXT_CSD revision 8 E) J2 J" P, d u9 |
[17:52:32.566] [ 10.420][mmc]: decode ext_csd failed
8 J4 ?6 P7 G1 E+ L[17:52:32.566] [ 10.443][mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x1c50 us
2 U2 [! g8 A1 `( z9 m9 P- p4 s[17:52:32.633] [ 10.449][mmc]: calculate timeout failed% M0 d0 A& D3 e" _0 {. I) F
[17:52:32.633] [ 10.453][mmc]: Do erase failed!
% [5 S- l" E" }! o% E; I% [4 O, a[17:52:32.633] [ 10.456][mmc]: erase failed, range 172032 - 204800
( |3 S, S# R8 P, P$ M9 P[17:52:32.633] [ 10.461][mmc]: mmc_mmc_erase: erase emmc fail!. s1 {, c/ [% e! q
[17:52:32.633] [ 10.466][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
: y9 w1 y5 A0 ^% p, T$ d[17:52:32.633] [ 10.472][mmc]: --0: from172032 nr32768
6 `6 k, ~4 ~4 c! _[17:52:32.633] write zeros-0: from 0x2a000 to 0x31fff
/ x& J# [9 x+ ]2 b( V1 o[17:52:32.633] [ 10.479][mmc]: mmc start mass pro boot part...
7 p" b* A6 \7 L+ C[17:52:32.633] [ 10.484][mmc]: boot0 start address 172032( S0 z6 i- d5 @$ [1 j
[17:52:32.633] erase system part( z6 T5 A( H9 w
[17:52:33.349] [ 11.218][mmc]: erase from: 204800, to: 2301951, cnt: 2097152, erase_group: 1024
: I# ^- K4 V9 |5 F0 H) ^/ @[17:52:33.376] [ 11.226][mmc]: unrecognised EXT_CSD revision 8' g0 b: g/ s' i" D( t
[17:52:33.376] [ 11.230][mmc]: decode ext_csd failed
! V( e& f0 r7 g) L9 W( ^[17:52:33.376] [ 12.360][mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x65809 us
8 v0 ~5 w, w1 V" Y/ I[17:52:34.549] [ 12.366][mmc]: calculate timeout failed! X# t! K1 m- x, V2 j7 \; t
[17:52:34.549] [ 12.370][mmc]: Do erase failed! i+ Q9 k9 ?" }2 y; u- Q
[17:52:34.549] [ 12.373][mmc]: erase failed, range 204800 - 2301952
' J3 m/ A! D. ^! y[17:52:34.549] [ 12.378][mmc]: mmc_mmc_erase: erase emmc fail!+ r. r" f1 e7 @6 Z7 e" K( e
[17:52:34.549] [ 12.383][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!7 B3 d3 T) y$ M: @% Z1 k% _
[17:52:34.549] [ 12.389][mmc]: --0: from204800 nr2097152
$ ~% ~1 |+ b( t k7 H6 b' a[17:52:34.549] write zeros-0: from 0x32000 to 0x231fff1 S3 }+ ]" p, u6 M6 M
[17:52:34.549] [ 12.396][mmc]: mmc start mass pro boot part..., _* v- H! E. Y" }% B0 ^# u- j
[17:52:34.549] [ 12.401][mmc]: boot0 start address 204800. a' ^3 k( V4 [0 s$ D! r
[17:52:34.549]
- {( z# j) y( X5 o. E* _/ { k/ m% Y# e5 @$ ]. Y5 ~
