查看: 226|回复: 1
16×16点阵(滚动显示)proteus仿真原理图和单片机源代码
发表于 2018-12-3 08:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
16×16点阵(滚动显示)proteus仿真原理图和单片机源代码: a7 g1 r# I6 Y/ Y) Z$ Q
$ a4 E% Y& S6 i4 t3 \; c
5 `) [; b. _8 a; o单片机源代码:
7 y2 v. x! K  n  ]- b2 W2 h$ U# K  y#include <reg52.h>
% E! Y) [) t$ K2 y$ j) x0 B# ?2 ?+ |) v" g0 h8 c4 i
#define int8 unsigned char
9 _* \1 B- J& |% v+ ^8 l, O#define int16 unsigned int
& C8 Z. y5 r7 ~+ q#define int32 unsigned long4 P+ g1 Y, i$ X1 {
* n5 C# k  Q4 s3 U
int8 flag;9 m& L$ c; i! k& s) }! z7 J. \( f
int8 n;% P$ |3 |) I/ a0 K% q* k4 _$ H& r
int8 code table[][32]={
" E) a( ]- o  X8 p2 D; o                          {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/* "  " */
' N& ~' _8 W( Q- c  f$ X! F% B! w9 v
/ S! }9 u  `; e7 K' q
                          {0x04,0x28,0x08,0x24,0x32,0x22,0xC2,0x21,0xC2,0x26,0x34,0x38,0x04,0x04,0x08,0x18,0x30,0xF0,0xC0,0x17,0x60,0x10,0x18,0x10,0x0C,0x14,0x06,0x18,0x04,0x10,0x00,0x00},/*"欢",0*/, z' x1 s- [1 P; h6 N3 _; v
                          {0x02,0x02,0x04,0x82,0xF8,0x73,0x04,0x20,0x02,0x00,0xE2,0x3F,0x42,0x20,0x82,0x40,0x02,0x40,0xFA,0x3F,0x02,0x20,0x42,0x20,0x22,0x20,0xC2,0x3F,0x02,0x00,0x00,0x00},/*"迎",1*/5 I' i# {+ v' q- }& B# o  S" U
                          {0x00,0x01,0x04,0x02,0x1C,0x0C,0xC0,0x3F,0x1C,0xC0,0x02,0x09,0x02,0x16,0x92,0x60,0x4A,0x20,0x82,0x2F,0x02,0x20,0x0E,0x24,0x00,0x22,0x90,0x31,0x0C,0x20,0x00,0x00},/*"您",2*/
  c# v- p4 J& [% Y  o; b. M                          {0x44,0x10,0x44,0x14,0x88,0x54,0x88,0x54,0xD0,0x5F,0x30,0x50,0x60,0x50,0xFE,0x7F,0x40,0x50,0x20,0x90,0xB0,0x9F,0x98,0x92,0x8C,0x94,0x88,0x34,0x80,0x11,0x00,0x00},/*"乘",3*/8 {) U0 \8 o) j
                          {0x82,0x00,0x02,0x01,0x22,0x06,0x22,0x38,0x22,0x04,0x22,0x03,0x22,0x00,0xFE,0xFF,0xA2,0x00,0x22,0x01,0x22,0x02,0x22,0x3C,0x22,0x02,0x02,0x01,0x02,0x00,0x00,0x00},/*"坐",4*/
4 @6 q) G2 M1 i5 o4 ?4 |                          {0x02,0x00,0x0C,0x00,0xF0,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0xA0,0x00,0x60,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00},/*"广",5*/
( Z* |, r- h! j2 O. W( @" ^2 S( h                          {0x80,0x00,0x01,0x07,0x06,0x00,0x18,0x00,0xE0,0xFF,0x00,0x04,0x00,0x03,0x00,0x00,0xFE,0x7F,0x00,0x08,0x00,0x06,0x80,0x01,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00},/*"州",6*/
6 S- M2 v  v( U3 g3 L3 U. P1 Y7 g                          {0x00,0x00,0x04,0x20,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x20,0x04,0x00,0x00,0x00},/*"三",7*/
- u; m- H, s7 v/ L) r# S6 M$ k                          {0x20,0x08,0x20,0x86,0x7F,0x60,0x80,0x0F,0x00,0x04,0x00,0x1A,0x00,0xEA,0x00,0x2A,0x00,0x2A,0x00,0x2A,0x00,0x2A,0xF0,0x2B,0x0C,0x28,0x02,0x20,0x0F,0x00,0x00,0x00},/*"汽",8*/$ n; K% b% k5 G/ h
                          {0x00,0x00,0x80,0x00,0x04,0x01,0x0E,0x02,0x14,0x0C,0x24,0x70,0xC4,0x21,0x8C,0x00,0x08,0x00,0x08,0x70,0x28,0x08,0x1E,0x06,0x0C,0x03,0x80,0x01,0x00,0x01,0x00,0x00},/*"公",9*/
8 M- L0 d2 {, P7 T. o+ c' i                          {0x00,0x00,0x00,0x08,0xF8,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0xF0,0x49,0x00,0x48,0x04,0x40,0x02,0x40,0xFC,0x7F,0x00,0x00,0x00,0x00},/*"司",10*/
6 K& F8 }7 i2 S4 h% y3 W                          {0x00,0x00,0x80,0x00,0x04,0x01,0x0E,0x02,0x14,0x0C,0x24,0x70,0xC4,0x21,0x8C,0x00,0x08,0x00,0x08,0x70,0x28,0x08,0x1E,0x06,0x0C,0x03,0x80,0x01,0x00,0x01,0x00,0x00},/*"公",11*/
& x; p4 O. ]+ p8 t                          {0x40,0x00,0x40,0x08,0x41,0x08,0x42,0x08,0x4C,0x08,0xF8,0x7F,0x50,0x08,0x40,0x08,0x40,0x08,0x60,0x08,0xD0,0x7F,0x4C,0x08,0x47,0x08,0x42,0x08,0x40,0x00,0x00,0x00},/*"共",12*/
# b0 Q  W4 n, Q9 _/ F3 E                          {0x20,0x08,0x20,0x86,0x7F,0x60,0x80,0x0F,0x00,0x04,0x00,0x1A,0x00,0xEA,0x00,0x2A,0x00,0x2A,0x00,0x2A,0x00,0x2A,0xF0,0x2B,0x0C,0x28,0x02,0x20,0x0F,0x00,0x00,0x00},/*"汽",13*/
/ p0 @2 K6 _" O# M$ ?6 g                          {0x20,0x00,0x20,0x20,0x20,0x21,0x20,0x23,0x20,0x25,0x20,0x39,0x20,0xE1,0x20,0x21,0xFF,0x2F,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x00,0x00,0x00},/*"车",14*/
+ l, \) i# H# c& l4 q& K5 \0 k9 p                          {0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",15*/& J7 ^& s% V5 q- K) L
                          {0x00,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0x05,0x00,0xFE,0x80,0x05,0x60,0x04,0x10,0x04,0x0C,0x04,0x06,0x04,0x03,0x04,0x02,0x04,0x00,0x00},/*"大",16*/+ J( f' |$ {2 e% @4 n% C, `8 [
                          {0x00,0x02,0x40,0x0C,0x40,0x08,0x40,0x48,0x40,0x3A,0x40,0x2A,0x42,0x0A,0x41,0x8A,0xFE,0x7A,0x40,0x2B,0x40,0x0A,0x40,0x18,0x40,0xEA,0x40,0x4C,0x40,0x08,0x00,0x00},/*"学",17*/
2 b" ~7 D+ E: h% Z                          {0x20,0x08,0x30,0x08,0xE0,0xFF,0x42,0x08,0x4C,0x08,0xF0,0x1F,0x10,0x12,0x1A,0x12,0xF2,0x13,0x04,0x10,0xC8,0xFF,0x30,0x10,0xCC,0x50,0x02,0x37,0x1C,0x12,0x00,0x00},/*"城",18*/* E  l; N8 Z/ m5 _- _6 E
                          {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0E,0x14,0x10,0x24,0x10,0x44,0x10,0x84,0x11,0x0C,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"2",0*/- m3 O/ e9 m9 ?) K' k& l
                          {0x04,0x02,0x44,0x06,0xC4,0x1A,0x48,0xE3,0x48,0x46,0x48,0x00,0x04,0x09,0x04,0x09,0x08,0x09,0xC8,0xFF,0x30,0x09,0x28,0x49,0x44,0x39,0x02,0x29,0x1F,0x01,0x00,0x00},/*"线",19*/0 g8 b: R2 }( ^! j6 B0 m
                          {0x00,0x02,0x02,0x42,0x04,0x42,0x08,0x42,0x30,0x42,0xC0,0x7F,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0xFE,0x7F,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x00},/*"开",20*/
$ P8 d9 F' h1 e5 }' O7 z' C                          {0x40,0x04,0x80,0x08,0x00,0x11,0xFF,0xEF,0x00,0x44,0x02,0x10,0x82,0x10,0x82,0x10,0x82,0x90,0xFE,0x7F,0x82,0x50,0x82,0x10,0x82,0x10,0x82,0x10,0x02,0x10,0x00,0x00},/*"往",21*// N1 ^0 R6 g3 J6 @: P9 c
                          {0x00,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0x05,0x00,0xFE,0x80,0x05,0x60,0x04,0x10,0x04,0x0C,0x04,0x06,0x04,0x03,0x04,0x02,0x04,0x00,0x00},/*"大",22*/8 u9 N8 ~$ \. w0 q/ r; H: o
                          {0x00,0x02,0x40,0x0C,0x40,0x08,0x40,0x48,0x40,0x3A,0x40,0x2A,0x42,0x0A,0x41,0x8A,0xFE,0x7A,0x40,0x2B,0x40,0x0A,0x40,0x18,0x40,0xEA,0x40,0x4C,0x40,0x08,0x00,0x00},/*"学",23*/! L+ B  k5 k2 V; b" @0 ]. H7 C! g5 i
                          {0x20,0x08,0x30,0x08,0xE0,0xFF,0x42,0x08,0x4C,0x08,0xF0,0x1F,0x10,0x12,0x1A,0x12,0xF2,0x13,0x04,0x10,0xC8,0xFF,0x30,0x10,0xCC,0x50,0x02,0x37,0x1C,0x12,0x00,0x00},/*"城",24*/
' x$ @  X! I7 a; U* D( G& V0 v                          {0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",25*/
$ d0 V0 H$ A7 ?3 z  _: F/ C6 }                          {0x00,0x02,0x00,0x42,0x00,0x32,0xFE,0x23,0x04,0x00,0x08,0x44,0xFF,0x55,0x50,0x55,0x50,0x55,0x50,0xFD,0x52,0x55,0x51,0x55,0xFE,0x55,0x00,0x44,0x00,0x04,0x00,0x00},/*"请",26*/1 p% G5 v* @( F6 Q
                          {0x00,0x01,0x04,0x02,0x1C,0x0C,0xC0,0x3F,0x1C,0xC0,0x02,0x09,0x02,0x16,0x92,0x60,0x4A,0x20,0x82,0x2F,0x02,0x20,0x0E,0x24,0x00,0x22,0x90,0x31,0x0C,0x20,0x00,0x00},/*"您",27*/
$ [7 A/ c& o' M/ W  `6 r4 L                          {0x82,0x00,0x02,0x01,0x22,0x06,0x22,0x38,0x22,0x04,0x22,0x03,0x22,0x00,0xFE,0xFF,0xA2,0x00,0x22,0x01,0x22,0x02,0x22,0x3C,0x22,0x02,0x02,0x01,0x02,0x00,0x00,0x00},/*"坐",28*/
4 p2 z4 l. k* }- j- d* }. J                          {0x01,0x08,0xC2,0x08,0x44,0x0F,0x28,0xF8,0x30,0x08,0xCE,0x0F,0x04,0x01,0x00,0x41,0x02,0x41,0x01,0x41,0xFE,0x4F,0x00,0x51,0x00,0x61,0x00,0x41,0x00,0x01,0x00,0x00},/*"好",29*/
' d! W; i( E9 Z2 O                          {0x42,0x08,0x81,0x08,0xFE,0xFF,0x00,0x09,0x01,0x0A,0x01,0x01,0x02,0x11,0x0C,0x11,0x30,0x11,0xC0,0xFF,0x30,0x11,0x08,0x11,0x06,0x11,0x03,0x11,0x02,0x01,0x00,0x00},/*"扶",30*/1 Q8 p$ e% |) ~: ^- V
                          {0x20,0x08,0xC0,0x48,0x00,0x4B,0xFF,0x7F,0x00,0x89,0x9C,0x88,0x00,0x10,0xBC,0x2A,0x82,0xCA,0xC2,0x4A,0xB2,0x5A,0x82,0x6A,0xAE,0x0A,0x90,0x0F,0x0C,0x00,0x00,0x00},/*"稳",31*/+ D5 \2 z' n2 x. }
                          {0x00,0x00,0x00,0x00,0x00,0x00,0xFA,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",32*/
2 T. J+ d7 j; S6 Y& a
& H% `/ J5 V5 P0 e9 p9 L                          {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}/* "  " */: d, S8 d) b3 _/ G$ Q- p+ {
7 f0 B' b% ]( S& V" r" l, L( |& Q8 s7 y: D* e
void delay(void);
: s2 n: s" H- K2 a; g; ?# Aint16 offset;
7 J) M7 I6 c. d0 Z( ?; q
3 Q( e* P; q2 C  [( svoid main(void), Z, N0 `8 J- l5 o. y, u/ ?- }9 j
{0 j7 Y0 e2 {5 G  I& ?, Z) c
    int8 i;" i* b9 z3 T3 L% L2 ^
    int8 *p;- l1 j- }/ a6 I# j, o, x5 `) I
    flag=0x10;
# C+ s+ u. k9 {: E+ {3 T5 S0 I    n=0;# o  E2 O# W; q- i
    TMOD=0x01;
9 ~8 F1 I( O: }    TH0=0xb1;
# {6 [  i' z9 J# f! \6 d0 s    TL0=0xe0;, m+ w/ {5 G) Q0 F) ^( L7 g6 z
    ET0=1;, d" I/ v7 O6 K2 G1 N9 [: \* ?$ J
    EA=1;
. C0 _& p( S$ u& j/ ~: a% p1 l+ h    TR0=1;4 b( V0 B% `" J7 r' z
( m( M# d* u/ Q8 r
    p=&table[0][0];
! p% b! `3 r1 o; q5 w  }0 O. S1 u5 e+ X& _- P6 Y* @7 ~5 `
    while (1)7 l3 E2 i6 M: y- F3 ^1 L" o
    {3 ]- J2 b4 I6 }0 ?8 k4 J4 B' J& U
        for (i=0;i<8;i++)    //显示左半边屏幕
* M8 r! U' A: C0 N( p3 h  ?        {
: d5 j/ L! j! ^* a# f6 G8 N            P0=*(p+offset+2*i);% @  a6 \( M# T- t/ G  \5 P- ?
            P2=i|0x08;    //P2.4=0,P2.3=1 选中U2, 输出扫描码给U6$ [* \; _( p4 W( N& ~8 k4 G
            delay();
  U* u7 ]% d( l" n0 g+ F3 U1 e( `/ P5 g6 ]5 g: {( \% r
            P0=*(p+offset+2*i+1);
8 e, D( _/ x8 x4 A              P2=i|0x10;   //P2.4=1,P2.3=0 选中U3, 输出扫描码给U7
: i% p* Y/ {" C" H: I& y8 T6 v            delay();/ Y& u# C1 w9 M- f# T5 g$ y* U
1 O8 U% Z/ H2 t; W5 |1 ^$ z% C        for (i=8;i<16;i++)     //显示右半边屏幕% O, x8 g+ i" V# ~3 {) `5 ]
" h6 w! Q+ Y0 A: V            P0=*(p+offset+2*i);+ z3 c4 @+ k% }7 C/ d
             P2=(i-8)|0x20;   //P2.5=1 P2.4=0, P2.3=0 选中U4,输出扫描码U8* I# K! s/ o/ K4 b$ r4 {
            delay();
) b& V; O* [0 U& Y2 E0 F
! n$ S& n* X. O  r+ J9 Q            P0=*(p+offset+2*i+1);% @  v% f( c& M& p
             P2=(i-8)|0x40;   //P2.6=1 P2.5=0, P2.4=0 选中U5,输出扫描码U9
6 u" b8 B1 E. f) D" m            delay();
3 S9 y* e& g" D( Y3 f        }
; [5 _, A4 x) M+ U    }
0 Z' U  v* e+ g; d}5 O5 z% f, `; \6 P- t. ~) F
8 \: z: x+ S% \$ H- {$ W" n" t- M
8 ]. x& ^, j' |% P/ uvoid delay(void)- l' ?6 F2 R+ e
{4 \0 G0 B" [, O5 b5 G( {* N; {" J" U
    int16 i;
' b% [; f, ?+ c# j2 V; L7 _    for (i=0;i<50;i++), `; S6 I0 r" t6 u( y. J1 h
        ;* \. y- X& \4 z( n+ s  q& v
' O  ]: [& i5 q. a
7 G. B! y# E7 R5 U" S6 _
- z' i* _7 G( l4 D( [7 e# Svoid timer0() interrupt 1 using 3
5 z$ E  ?* ~8 x+ o: A. T{
0 P8 ?: [2 L8 j# c) B7 P4 U    TF0=0;+ [% C: p) ?0 A& V6 h7 V; l
    TH0=0xb1;6 K- P) G8 f) l2 g0 A! Z& j
: w% Q4 ?, }* v3 Z. [  H5 `# Z…………限于本文篇幅 余下代码请从论坛下载附件…………" D( S6 v2 I/ e  K
游客,如果您要查看本帖隐藏内容请回复
" z! I# Z7 }: F
- s0 m1 I* q* s" ]3 ]8 |; y- k# R' ?
发表于 2018-12-3 10:13 | 只看该作者
学习中 学习楼主的分享
GMT+8, 2025-7-22 07:13 , Processed in 0.140625 second(s), 26 queries , Gzip On.
