ds18b20温度测量1602显示0 h# S o- d) J, B9 s
) o7 `1 |8 Q. G( R V7 ~
1 h! \% m; {6 X; O1 F7 X#include<reg52.h> //包含reg52.h库文件+ I1 Y# F/ H) [% T5 k) g1 B
#include<math.h> //包含绝对值函数
) w. W7 x: g- e- \#define uint unsigned int //宏定义uint0 M6 Q& g2 k3 R7 O# \
#define uchar unsigned char //宏定义uchar/ m- |, I7 K6 z3 [+ e1 S8 C4 `
sbit lcden=P3^4; //液晶使能端
: k* `3 o' u7 q p) ^! v, ?/ Xsbit lcdrs=P3^5; //液晶数据命令选择端选择写数据还是写命令
- b, Y t/ f5 L( O: A! D, L; Tsbit DQ = P1^0; //通过DQ口读取温度值
+ u4 l2 ]/ a) C' N- b//sbit s1=P3^0; //选择按键
5 W$ D5 s: z( ?. e) J% Z" k y* t, n% \//sbit s2=P3^1; //加按键6 C# j( Y8 e) X+ Y! `3 K8 |# ? {8 Z
//sbit s3=P3^2; //减按键
W* d+ b0 q/ p% V- b6 n+ ^* g* E//sbit D1=P1^2;
7 X3 {: N2 C. C8 f7 e( B//sbit D2=P1^3;
9 |' L0 O6 i& \8 l% Puchar temp_value,num,fig,s1num,figh,figl,t; //设置全局无符号字符型变量/ H+ ^4 \) I. b0 b6 M
char h,l; //设置全局有符号字符型变量
0 E+ v5 u [8 y) Dvoid delay(uint z); //申明延时程序
" x3 ]' h3 k/ D" E2 Yvoid init(); //申明LCD初始化程序; j7 I: ~* K6 g/ Q3 {6 a) A8 a) o
void write_com(uchar com); //申明写命令程序
1 Y, o. O- Z2 i5 z( ?void write_data(uchar date); //申明写数据程序
; k, z+ d, u% {' L+ z, y//void keyscan(); //申明按键扫描程序( c& z0 m" K2 Z+ ?; Q, J
//void write_hl(uchar add,char date); //申明设置的最高低温度值在LCD上显示程序5 u' b; f1 N1 y l
void write_temp_value(uchar add,char date); //申明温度值在LCD上显示程序( _4 z4 ]! X5 h4 B# v
void delay_18B20(unsigned int i); //申明延时程序
6 x/ w( I; |5 @2 w5 Y3 g4 C" avoid Init_DS18B20(void); //申明DS18B20初始化程序8 s# G1 B6 B: a$ @" T5 l
unsigned char ReadOneChar(void); //申明ds18b20读一个字节
- P; P/ }7 _+ a8 Yvoid WriteOneChar(uchar dat); //申明ds18b20读一个字节
4 [& X9 {4 I2 f$ l, qvoid ReadTemp(void); //申明读取ds18b20当前温度4 }. F% f x9 C% ?) F- z/ h- c- A* ?% O( n
//void comp();
/ A+ I/ ]. r5 a# y5 W4 l3 Yvoid main()
' V- F+ [0 z4 Q( D3 q( K p{ init(); //LCD初始化7 p$ L) T: L4 [- c% t( ^4 A: [8 i
Init_DS18B20(); //DS18B20初始化, T2 g/ T# v! C* R) ?" u
while(1) //大循环
( b: p- m R( Q' Z: `7 B2 | { //if(s1==0||s1num<=1)
/ z9 I; X- C0 m/ U4 b, O3 I! b+ g //{// keyscan(); //按键扫描
' ~7 E1 l8 w0 b+ _% n8 Z // }
, `4 k$ o/ s/ r4 X3 x; i, n7 A2 l// else{3 O: }- ~" h$ v5 D; f* ~/ f7 u, r7 ~
ReadTemp(); //读取温度值
! S) K; k3 e2 K write_temp_value(0,temp_value); //LCD显示温度值' L2 E. S" g& A( u8 z
# g; ~: L, ?3 R7 V0 P, l // comp(); : z$ F) V, E5 y- }
# e7 t5 q) m1 Q3 S I w}: k* s+ f+ G" \" S+ X
void delay(uint z) //延时程序
) K# s/ C+ e/ N3 M. V2 S3 C{$ g& F$ y2 R, s% Q& F' Q$ Z' S
uint x,y;: X# I7 }7 Y; m! v" F% u
for(x=z;x>0;x--)% L! W; y0 A! N' Y8 G: X
for(y=110;y>0;y--);
* {- L. O& g: x% }7 \% x$ J}0 q( R& i! [' R$ i+ H. L
; P U; T4 V4 t" F" G" J5 s! Dvoid init() //LCD初始化程序& f( v6 c( o8 H' v+ Z1 D
{ lcden=0;, d# p* G4 e: @' |0 E* s5 D4 r
write_com(0x38); //设置16x2 显示5x7 点阵,8 位数据接口# |& }$ x: @3 y" n: d$ S$ ^2 I3 t$ S
write_com(0x0c); //设置开始显示不显示光标
0 J! l7 F* w: N, x5 j write_com(0x06); //写一个字符后地址指针加1
s7 c5 a4 n4 a( Q( g7 t write_com(0x01); //显示清零数据指针清零
0 T+ G+ o1 c0 \" v write_com(0x80+11); //将数据指针第一行第一个字处,
6 O+ r# R. d) a7 q0 P $ ^1 @9 N7 ~' h
/* write_com(0x80+9); //定义当前指针位置7 n4 I* P+ `/ s% F- a: Z
write_data('H'); //写入
t3 k* k5 M7 \9 D write_data(':'); //写入9 w0 u+ j3 p" A4 [3 I2 x
write_data('+'); //写入7 V( }1 y6 W0 y* R/ P# v7 _
write_data('5'); //写入- F, R0 e e0 I8 Q5 l
write_data('0'); //写入* G1 V( V% `; t( @7 q5 F
write_data(0xdf); //写入°9 |' s9 D2 w: H9 X: ?
write_data('C'); //写入C
B u" ~$ O/ J; ?% u1 { z3 F3 H; j& | write_com(0x80+9+0x40); //定义当前指针位置4 u0 z" @, Q* ?2 { [
write_data('L'); //写入& P+ q# e5 w1 z: }6 U/ R, w
write_data(':'); //写入4 i( O3 [* ]. ]. Z/ V6 q
write_data('-'); //写入
( C- R/ I9 O( M, J1 f8 X) S write_data('1'); //写入( {3 V; e' A6 Z& U( I- N: F4 h3 Z
write_data('0'); //写入! \/ m# |) Z$ k: D; v$ ^
write_data(0xdf); //写入°$ r5 B, K" n3 a' {
write_data('C'); //写入C */
3 l& R: n2 q+ C+ r// h=0x32;
8 w! E" r6 B2 e; k: s0 H9 ]// l=0-0x0a; //h=45
R' y" z2 e9 R5 q, a// D1=1;
6 t; C; A, q4 x3 o% ~// D2=1;
( }" p/ ~5 m! N9 s0 _9 {% \$ m// figh=0; //给正确初始值,便于上电比较 G U- d: R A1 ^
// figl=1; //给正确初始值,便于上电比较 : N' x5 | T9 I
. T C: l9 Q6 }, Y3 k# c# B+ i, rvoid write_com(uchar com) //写命令程序
4 B/ R2 k$ i; e{ lcdrs=0; //设置为写入命令/ Y1 C5 ~( j* C( o3 U
P0=com; //将命令赋给P0 口, |# }# o3 U3 h9 X+ ~6 G5 @. h
delay(5); //延时
6 z$ @' U# E! M7 h lcden=1; //打开LCD使能,输入一个高脉冲& x: e4 U5 Q0 [ r1 u+ n% N
delay(5); //延时9 t4 G' j& W) Y1 p
lcden=0; //置低完成高脉冲
; E! _) n5 H5 }/ @}: d0 N4 {8 o8 ^; S
void write_data(uchar date) //写数据程序7 E6 {6 Q* m" I# d& [- `
{ lcdrs=1; //设置为写入数据0 s3 E2 m0 N! ?& v8 L
P0=date; //将数据赋给P0 口1 E8 }; e- S+ d, V( v
delay(5); //延时
* x6 L* M; \. B7 W lcden=1; //打开LCD使能,输入一个高脉冲
0 ^8 e0 h- l/ \: w. d3 A delay(5); //延时, U$ N8 m: I8 Z- y5 u; C2 V( K0 a" b
lcden=0; //置低完成高脉冲- R- A( Z8 i; E0 p
& ~) j* |2 ]: ~& ?" d, F4 V' d2 W Rvoid write_temp_value(uchar add,char date) //读取的温度值在LCD上显示程序4 s& N& N: l$ u C. g% m, V
{ uchar bai,shi,ge;
' @3 g9 f0 f* g" y2 J bai=date/100;5 Q1 L& y0 Z- H
shi=date%100/10; # |% _4 A; I3 h. E# L2 B
ge=date%10; //分离出百,十,个位数" `7 m/ D: }1 U8 N! Z
if((bai|shi)==0) //如果百十都等于0
0 ^" Z5 w: l+ d' w shi=0x70; //十赋值0x70,以便十位写入空字符,write_data(0x30+shi),参考1602字符图形码
; e6 L( V8 D& u& q if(bai==0)
- W z' h: a) M) w' T) Q. N bai=0x70;; |8 G5 f, C y) D
write_com(0x80+11+add); //设置当前光标位置,准备写数据
2 n) P M+ B6 @" ~: x
1 ^4 t; z" D8 x if(fig==0&&shi!=0x70) //如果温度为负且十位不等于0(如果十位等于0,shi=0x70)
# m; C! s5 I$ A7 W { write_data('-'); //在百位写入负号1 t" z% n. R( h' o/ i
write_data(0x30+shi); //写入十位数据5 U" w* n: v! D5 |$ m8 K
}& F7 k& x [7 E( l, z- A
if(fig==0&&shi==0x70) //如果温度为负且百十位都等于0
, ?+ i1 V2 D0 L6 o { write_data(0x30+0x70); //在百位写入一个空字符
. s0 `- M9 m- L) q! v1 h write_data('-'); //在十位写入负号" _5 p" T: k( R+ Q+ `. c& \
}& N. K" n, Z4 G$ ?# K2 i
if(fig==1)write_data(0x30+bai); //温度正,写入百位数据
: g/ x3 V& L: I" h) ?2 G if(fig==1)write_data(0x30+shi); //温度正,写入十位数据, o6 g5 h$ G6 z% o/ I. J1 @. \, b
write_data(0x30+ge); //写入个位数据, E9 X- N O4 t" Z; O7 |" {
- _+ _" R# X' \; @8 z$ `. T write_data('C'); //写入C
8 q5 ]- a2 y6 e* ?& Q
' s: p. `" s: b, P% U8 T}2 y/ A- Q& T% O# ?4 o* O
/*void write_hl(uchar add,char date) //设置的高低温度值在LCD上显示程序4 V1 i2 }5 w( c
{ uchar bai,shi,ge;
0 w7 b3 Z$ P# T2 u) B0 }/ r bai=date/100;& c: o4 Q# a! h
shi=date%100/10; 1 Q* F+ ~" Y, _1 b& d
) E) I: H6 ^8 `- I; F+ L6 E write_com(0x80+add); //设置当前光标位置,准备写数据
* G9 _/ C9 z5 J, z1 w, K9 ]5 S + `, u, ], [! c0 k7 m- V# O0 k
if(t==1&&shi!=0) //如果温度为负且十位不等于0(如果十位等于0,shi=0x70) 负数:百位第1种情况,写-. m! \" r; @- p
{ write_data('-');} //在百位写入负号0 t) E; e+ U& {2 X3 a( u
if(t==1&&shi==0) //如果温度为负且百十位都等于0 负数:百位第2种情况,写空
/ i, \1 T6 d% X, [ { write_data(0x30+0x70); //在百位写入一个空字符
, u* ]/ H' C' L, E6 X9 D5 r4 L ` write_data('-'); //在十位写入负号 负数:十位第1种情况,写-3 o9 J8 [ @$ R9 Q4 c6 \" {
+ T, v3 _& L- }. }6 z: v if(t==1&&shi!=0) //如果温度为负且十不等于0 负数:十位第2种情况,写数
% X8 O8 h. a- J* P {write_data(0x30+shi);} //在十位写入数据7 x7 c5 r* ^7 m j
if(t==0&&bai==0&&shi!=0) //否则温度为正,如果bai=0且shi!=0 正数:百位第1种情况,写+
2 f2 C2 [( W. n; E. q, H) @+ }6 G% | {write_data('+');} //在百位写入+
' s) Q; Y/ l, ]0 ?, e* c3 B8 [, d if(t==0&&bai==0&&shi==0) //否则温度为正,如果bai=0且shi=0 正数:百位第2种情况,写空+ m9 `' Y h3 F: r8 D
{write_data(0x30+0x70);} //在百位写入一个空字符
( t8 s9 B2 ^+ y( f if(t==0&&bai!=0)
( p" D5 r# y5 a0 W& t {write_data(0x30+bai);} //否则百位为正不等于0,写入百位数 正数:百位第3种情况,写数- ^! }, [; ?' q; P, ]% p* g
if(t==0&&bai==0&&shi==0&&ge!=0) //如果百十等于0,个不等于0 正数:十位第1种情况,写+3 R$ k! A0 \+ P C1 Z; o$ ]
{write_data('+');} //在十位写入+2 m8 U A3 e) l$ j3 x& w
if(t==0&&bai==0&&shi==0&&ge==0) //如果百十个都等于0
_7 T( e( w6 |% M# b3 T {write_data(' ');} //在十位写入空字符 正数:十位第2种情况,写空7 [0 n* ^3 s1 J% F4 M
if(t==0&&shi!=0) 4 t; G" l4 u7 l A
{write_data(0x30+shi);} //在十位写入数 正数:十位第3种情况,写数
$ E4 b6 V# _- \ write_data(0x30+ge); //写入个位数据
[9 F' s* R. _2 f8 U} */
& C$ B. r; G1 Y) ~5 i/***********ds18b20子程序*************************/
7 T# [6 C* h2 j+ I8 i: v! r/***********ds18b20延迟子函数(晶振12MHz )*******/
2 E) J1 K# U* \: E8 C) V1 A2 U u- ?void delay_18B20(unsigned int i)
# }2 Q! N/ T* ?) f% i* i8 _8 k5 r{
7 a! [$ A u1 U" M1 r while(i--);
; V8 g9 L( }, `}
( ~$ O. b# v* d# {" h' G2 W1 f0 j/**********ds18b20初始化函数**********************/
" K1 Z& @ i" Tvoid Init_DS18B20(void)
0 g- @6 u U! A. H( h+ a{
$ d% b# S6 \0 Y" a: B unsigned char x=0;
- {1 x5 H8 F. Q" q9 v' ` DQ = 1; //DQ复位
9 n& H% L5 L2 K1 K" j; k delay_18B20(8); //稍做延时& H, n, X. H9 R! g0 }/ b* r, m$ {3 }
DQ = 0; //单片机将DQ拉低
. Y J' v% {- m _% P7 b delay_18B20(80); //精确延时 大于 480us$ Q4 M, p9 t% l" N! {
DQ = 1; //拉高总线' U9 B) i& s) z) f9 R
delay_18B20(14);
- w# q$ [4 F( v) T" w1 A1 M% e x=DQ; //稍做延时后 如果x=0则初始化成功 x=1则初始化失败+ Z! h/ I* \+ @: ~$ W, S3 L3 h
delay_18B20(20);4 M Q/ K% E9 h8 A
3 \( }0 g' b+ a, _7 a/***********ds18b20读一个字节**************/
8 g: O7 z f% W* Munsigned char ReadOneChar(void)
+ Y: H n+ }: ]( `! V{# [! l) c# h( u$ n3 ?1 V
uchar i=0;
! q& a; c i# O- {' k( I* i+ W uchar dat = 0;% a- k+ t* n7 }; B0 C
for (i=8;i>0;i--)7 j, q5 w% ^" ?7 G7 u
{9 Y$ }. q( G M3 Z9 W
DQ = 0; // 给脉冲信号% F: ]& [) q& W! E+ ]# w
dat>>=1;3 G \4 Z, E- e
DQ = 1; // 给脉冲信号 i; \4 `! p% i) y( g- S7 \( P
if(DQ)
7 o4 P( U6 e; R( G! c dat|=0x80;
0 s7 J! Z% q( e4 V delay_18B20(4);
- H2 Q% d; o) \5 e }
9 u3 d" a3 R$ A return(dat);! Q: K n) L% }- U; d# K
}: |* x, C4 \4 ^% P! F' O* c
/*************ds18b20写一个字节****************/ % G/ t& x/ _- N3 w8 G& ?3 S% `& t
void WriteOneChar(uchar dat). R- `, I1 |5 X- A8 n' p z! u* R
; P9 p* G$ T3 K6 a: }2 u unsigned char i=0;
+ r- O% j- J9 u( O4 H: A+ I6 g for (i=8; i>0; i--)
6 s; t& `4 _+ [' _0 n1 B. M {
% q& W0 t5 D6 C+ t DQ = 0;" ?3 @$ j! I# x+ R
DQ = dat&0x01;. f4 G7 u' i$ f9 M7 u
delay_18B20(5);
1 j2 [9 P. u$ T! G5 d; c; I DQ = 1;
$ M' z; d4 n: T8 J) M: p( O dat>>=1;
; Z: U. M3 }2 @ N5 H}0 u% v% i( r% v7 e0 h
; ]" w' W/ v$ H! }" w$ X5 X/**************读取ds18b20当前温度************/( E1 m5 p' p/ _/ g: d, x( R3 b
void ReadTemp(void)6 b, |: i9 d& T: y R" _4 i/ @
& {: j) o" a8 q+ |" e) { unsigned char a=0;
8 B* R& ]* M8 d4 D+ ?; ~9 G unsigned char b=0;
1 G* n" c0 ?1 V! I% ~# m, ?" h* t& Q unsigned char t=0;
5 H" o9 L; z. z Init_DS18B20();
) G: ]! Q, w# D; s3 h& K WriteOneChar(0xCC); // 跳过读序号列号的操作
" d4 i" L" W3 t; z2 k) S WriteOneChar(0x44); // 启动温度转换# ^# x5 }6 D# b4 U
delay_18B20(100); // this message is very important1 y+ ^4 Z3 M- G+ p f' Q
Init_DS18B20();
! t3 V. U4 r8 D3 s) z9 U3 \- J3 M WriteOneChar(0xCC); //跳过读序号列号的操作
9 W" O+ w! D# r1 W8 o4 ?. z' V WriteOneChar(0xBE); //读取温度寄存器等(共可读9个寄存器) 前两个就是温度
* Q: {1 u# T V5 e) z0 ?) _ delay_18B20(100);0 I+ I; \9 c& g1 L; Y. @5 I
a=ReadOneChar(); //读取温度值低位2 _1 z* S$ U4 e) d/ V9 s5 W
b=ReadOneChar(); //读取温度值高位
9 l1 F# |/ T2 V4 K; W7 G/ b// a=0xff; //测试无法读取-16度的问题
. c- o/ `! W( p3 y. ?, A// b=0xfe;; D. Q2 n* C* F6 O0 f8 k
temp_value=b<<4; //temp_value=b左移动4位 , 转换成10进制 ~( Y( y: ]$ F. W; I& m, C3 m
temp_value+=(a&0xf0)>>4; //temp_value=temp_value+((a&0xf0)>>4) 转换成10进制/ v2 k) }1 M, r
fig=0x01; //设置fig=1温度正
) L+ d* y9 D" |7 r# _" q. i% e if(temp_value>0x7f) //如果temp_value大于0x7f,即为负数区,参考DS18B20datasheet) V G! C- ]6 r- _
{fig=0; //设置fig=0温度负,以便判断显示* V( Q8 y# x. s5 C; c7 `' |/ p
a=~a+1; //将读取的温度转换成10进制数
0 V, r0 E' q* j* g$ c7 y9 d b=~b;
: x4 N5 w& L( I( F6 g temp_value=b<<4; //temp_value=b左移动4位 , 转换成10进制
8 N8 ^5 k; P4 Y! l+ U/ \3 g, Y temp_value+=(a&0xf0)>>4; //temp_value=temp_value+((a&0xf0)>>4) 转换成10进制
' ?( k. @/ \8 p( W5 y* A7 S: | } 8 J$ d9 m V0 K5 ]0 [
}0 I' B$ Z; y* r _" F$ O# H
/*void keyscan() //按键扫描6 ?) R9 Q z" O; `3 B
{ if(s1==0) //如果s1按下,执行下面程序% z, @0 r, E4 J, z, t4 c1 `
{ delay(5); // 延时一会4 Z+ ?3 G* E1 H7 J# d# v
if(s1==0) //如果s1确实按下,执行下面程序
8 @3 X9 L- s) s: o, c2 l { s1num++; //s1num自加1
1 m; h# T7 u8 x% j4 ]4 q* X while(!s1); //如果s1松开,执行下面程序,否则一直停在这5 K, \6 x# }" f$ Z! d5 R
if(s1num==1) //如果s1只按一次,执行下面
' Z3 H' g. R& _% u- p {
2 y! U; I; T3 \) Y( u9 h* B write_com(0x80+13); //设置当前指针位置$ g+ n8 X! k; y1 B( O/ G1 r
write_com(0x0f); //写入光标闪烁命令
4 y% f0 j: w' v1 J4 K) Q/ @" ~ z }/ z+ u1 f: u2 ?/ e3 T4 D1 b' l
if(s1num==2) //如果s1按2次,执行下面; Q- o$ j5 S ^* A: g* P
{& n$ a3 h1 J( K1 H3 x: A
write_com(0x80+0x40+13); //设置当前指针位置,光标闪: t- D. [/ k, Y S0 f9 {
/ z+ u# k2 b: w; d; b* I if(s1num==3) //如果s1按3次,执行下面* I) }* U- m1 P n5 C% O
{ s1num=0; //s1num清0
7 u6 \; }1 n9 I$ z) { write_com(0x0c); //写入光标不闪烁命令3 m) [$ I, S2 U6 f1 @ F$ M
} y' ?7 s# m" `, @
% U, k7 P& A0 {4 S h4 o }
1 {5 K2 v+ k, N: F% z2 j! O 7 p$ h9 a" x5 V; I+ M4 e2 L
if(s2==0) //如果s2按下,执行下面程序
! I/ P9 R3 ]. z& ~* B { delay(5); //延时5 c2 J' ]5 _4 F# q+ k, y1 x8 w
if(s2==0); //如果s2按下,执行下面程序
7 N! H# B' @; c, W: D { / D- N) x) O' @& j
while(!s2); //如果s2松开,执行下面程序,否则一直停在这
" z8 t" h E% E# y0 e* E/ p if(s1num==1) //如果光标在h的位置闪烁,执行下面程序1 @% Y( q' r; K- x
{ h++; //h加1
- v& i1 Q7 T' G+ R/ ~ if(h==127) //=127清0
0 G' I! ^" I( _8 h6 n h=0; 2 z9 k$ O e/ L4 d f; q5 `
figh=0; //设置figh=0,符号为正
! F6 A" X" o; g9 x t=figh; //赋值给t,以便液晶显示% F' T* r. P, o8 {8 y+ }$ M/ L
if(h<=-1) //如果h为负数, o' ]) Q2 m' L& p/ C; }7 \
{figh=1; //设置figh=0
) A- {& x: [3 |& I2 j t=figh; //赋值给t,以便液晶显示
% n% U* v9 d7 B6 C: ], x C6 L h=abs(h); //h取绝对值
7 e3 [ A" ^! z write_hl(11,h); //h写入LCD1 H. W9 h: `! r
h=0-h; //把h变回原来的负数7 ^. |' u3 Q+ ^7 T8 J$ V
( u6 P b& s# J, N. F" R else{write_hl(11,h);} //否则h写入LCD3 \* J% z# w' Y8 \# }+ I
write_com(0x80+13); //光标在温度值位置闪烁8 q: c4 g% a3 Y$ u
8 W: j% h! P5 L# c1 R% L if(s1num==2) //如果光标在l的位置闪烁,执行下面程序3 b% ~! ]! g" V j% f: w& U1 b
{ l++; / E; g" x4 S% ?6 \! Q2 D
if(l==127) 1 F7 V6 n! h. b5 ~( N8 y/ j
l=0;0 B6 \7 C# X' p# E5 o
figl=0;/ Y8 R& q, C2 ~
t=figl;4 p4 Q/ {) v. m& B
if(l<=-1)( l7 P! |% ^& G) C% X# R, S
{figl=1;
7 c' M' V; |0 {0 k t=figl;
2 y; X6 N2 K0 l) B( o- z( I( | l=abs(l);) _4 u8 s) Y, y9 J. m- B
write_hl(0x40+11,l);
r, C5 J" d+ T7 z8 p l=0-l;
3 `( B+ [; B9 M7 y" B3 E }3 p" w4 N1 k* P3 e# c8 N
else{write_hl(0x40+11,l);} 8 Y$ p# w2 a3 u+ j. u% E
6 _" _* U1 C/ V0 j: w6 P' t$ _ }
; Z3 j0 k8 B- p" | }
2 k: B0 n5 m0 x6 C [7 j, K }* T* E; X: V" }
if(s3==0) //如果s3按下,执行下面程序1 X2 _5 k& U h4 {! l% o# n2 q
{ delay(5); //延时% J' [# m5 Q4 V7 t% t8 s# j: g6 Z6 x
if(s3==0);9 t. y. K8 o( L# k( ~7 O
# M( T+ C) ?- B3 N9 D# F' \ while(!s3); //s3松开后,执行下面程序/ `7 l- v2 w5 E, S$ {4 ?
if(s1num==1) //如果光标在h的位置闪烁,执行下面程序. k4 d; c) a7 H" d2 q
{ h--; //h自减1: b, c, e+ P, ]: c6 ]) `
if(h==-55) //如果h=-55清0
& I- d1 ^; M: E3 U) }: i8 F0 | h=0;
( o( c: w$ e: P/ X+ ^$ j figh=0; //设置figh=0,温度值为正; ]( j' d) l& c! W5 ~
R3 e% V8 ], o3 } if(h<=-1) //如果h温度值为负数
1 B3 |5 ]4 K% r! u4 Y {figh=1; //设置figh=1, T' V: a. {. q
t=figh; //赋值给t,以便液晶显示6 Y! N- v! a% F& ] {) o
h=abs(h); //h取绝对值0 v" A0 ^/ B$ T/ n# o
write_hl(11,h); //h写入LCD3 H- W# A. X; b, ~+ C
h=0-h; //把h变回原来的负数; ^- S1 r" }% G( r9 U( z( _
/ j$ s! T( j. n5 |, z' F9 U5 ~ else{write_hl(11,h);} //否则h写入LCD
7 a8 B K8 g: P o, J# I write_com(0x80+13); //光标在温度值位置闪烁/ k# t- Y+ a& u
} : e1 p O( k0 i+ a/ \7 I
if(s1num==2)
$ r. f2 f$ M+ ?7 G3 ^( B" H; ] { l--;
5 Y3 g( ~" q2 k if(l==-55)
$ n3 f5 u( X* x% C# r4 w0 c( x& F h=0;" |7 C$ ? L& f0 _9 W4 y* b
figl=0;
C o$ m, S& F, o i5 _ t=figl;2 ]1 m7 V4 {0 Q) }5 j' d1 h2 ^
if(l<=-1)0 m I( {3 A3 h" t
{figl=1;
& a% _2 @+ Q! [! h t=figl;0 y0 ?* U4 V, q: r
l=abs(l);
0 m- d* Q8 c6 e9 h! B g) l6 r% ` write_hl(0x40+11,l);
2 J2 o) O p# k. Q. F0 e l=0-l;
) L9 q. q( F, q8 ^ i* p8 K& e }- \6 K/ D4 q% i4 F8 M e
else{write_hl(0x40+11,l);} & n; L, \0 L* Q0 B8 w1 t& h& B0 [
write_com(0x80+0x40+13);* X0 Z) x# Q% l+ v% x' r9 @
! ^! U# B& V& w" b; t6 F }
' S' r4 Y: }! U4 S; V- ]# j }
+ G7 x1 a" v9 T, o' Z} : j, K2 B+ @1 A1 E: w( i, o
void comp() //温度值报警程序
k, W' L" }/ c: E9 ]3 D7 ]- S{if(fig==1&&temp_value>=h) //如果读取温度值为正
8 g5 K. C: v- {D1=0;
$ W5 |: X+ W, Q8 ~+ ^; `if(fig==1&&temp_value<=h) //如果读取温度值为正: t9 S* n, c; t/ ? d
D1=1;* \1 W0 K& D4 H F% d
if(fig==0) //如果读取温度值为负( u) X* l, b) j
{ if(figh==0) //如果设置最高值温度值为正
, F- q. V+ W- ^% L D1=1; : V- d5 A! L0 ?5 J/ l
if(figh==1) //如果设置最高值温度值为负
# r$ l. I2 P* q7 U) a* M {h=abs(h);% S# ^# @2 @* p4 Y
if(temp_value<=h)
) m5 p% Y% i% m. r( }, C. v D1=0;) W! p, \7 t) i) D* R
if(temp_value>=h)+ s5 ^" a$ g1 z; E8 Y+ V; I
D1=1;
" I- z2 |& n; L, u0 X h=-h;
. n* ?9 D+ U8 F }
# {+ ^' r$ K1 J4 y5 n' D, N } . x6 e5 \! d4 R" z. R
if(fig==1&&temp_value<=l). x6 ?* c9 V8 ~( D" e% E
D2=0;
9 `5 }, g# V8 G) a' T2 S4 Jif(fig==1&&temp_value>=l)& v- |; D4 O8 x3 V# [6 e
D2=1; , R9 y2 {9 z' {* u
if(fig==0)8 O; G3 E6 O$ O
{ if(figl==0)
6 Y! G% l( @$ j. X& r# o+ L2 M D2=0;
! H" C9 {' q) z: r if(figl==1)
' W4 J; l# x$ B; T* ?$ ?+ Q {l=abs(l);
8 h) ~7 e. H! j+ @- }' K2 @7 G if(temp_value>=l)
' M% T R' a: J& j+ q& ~% |- K D2=0;
* }( {5 C" C$ L; N6 D if(temp_value<=l)
' ^& Q+ x4 M3 X% b q D2=1;
& D0 p1 O; b2 T' ~ l=-l;
! n$ _0 V: R' D8 H# K4 n9 I }; s: j/ g, A8 D) P" U6 M1 J% P
$ R$ A7 G j* O! E; d5 F}*/
# d% o2 n3 i0 y2 z' n5 X. f
" X7 i* t$ n2 h& X+ J9 c3 Q+ t3 G
0 X+ K0 }$ F: z* D/ y6 t4 |4 p7 o
4 K# W4 g4 i# s- a |
