FILE NAME DESCRIPTION FILE TYPE
' X: Z* u7 p9 P/ M3 M4 w/ |------------------------------------------------------------------------------------------------------------------------------ J: t8 L3 k" w! l
PCB MANUFACTURING FILES: k3 V7 `6 l$ w7 e4 L. I' b
L1.SPL LAYER 1 COMPONENT SIDE/POSITIVE EXT. GERBER
, [+ w* c+ G& u& v' ?L2.SPL LAYER 2 SOLDER SIDE/POSITIVE EXT. GERBER
) u4 @) Q! N$ v3 n9 S0 zSTOPCOMP.SPL SOLDER MASK COMPONENT SIDE/NEGATIVE EXT. GERBER
- O7 a5 r. ]/ k' x HSTOPSOLD.SPL SOLDER MASK SOLDER SIDE/NEGATIVE EXT. GERBER, n0 d$ l# y+ R, i! m6 A: S
SILKCOMP.SPL SILKSCREEN COMPONENT SIDE/POSITIVE EXT. GERBER0 M* G e" y- j& _0 q, e( L9 s
SILKSOLD.SPL SILKSCREEN SOLDER SIDE/POSITIVE EXT. GERBER( x$ t0 |: R" _" l ^* X6 Z
GERBER.REP DRILL and NC DRILL REPORT ASCII
9 b: k5 y6 h# |DRILL.SPL DRILL/MECHANICAL DRAWING EXT. GERBER
8 w/ L6 t) k6 C8 m TNCDRILL.SPL NC DRILL THROUGH HOLE EXCELLON
5 H4 d" ~7 S- SEXT_GERBER.USR PCB PHOTOPLOTTER DEFINITION FILE ASCII
4 D- }5 r- a* i2 \ j$ cCNC.USR NC DRILL DEVICE FILE ASCII
& e# m% @6 W! O! Z# C" b" G b ]PCB ASSEMBLY FILES:
, M M v3 O* ]( I+ K3 fCC1100EM_868_915MHz_purchase_list_2_2.xls PART LIST ASCII
7 O4 S2 ~3 \! f8 r, b% ^- FP&P_COMP.REP PICK AND PLACE COORDINATES, COMPONENT SIDE ASCII. i. u; ^* Q/ j) l, x% J
P&P_SOLD.REP PICK AND PLACE COORDINATES, SOLDER SIDE ASCII
* u8 @# }7 w* j" y2 HPASTCOMP.SPL SOLDER PASTE COMPONENT SIDE EXT. GERBER+ V' l9 Q4 j- i5 d
PASTSOLD.SPL SOLDER PASTE SOLDER SIDE EXT. GERBER& a. K$ E+ l0 N4 b0 F4 A/ r6 `
ASSYCOMP.SPL ASSEMBLY DRAWING COMPONENT SIDE EXT. GERBER% n) E4 m |4 y _- ]; ?& N, W
ASSYSOLD.SPL ASSEMBLY DRAWING SOLDER SIDE EXT. GERBER
$ k7 W( T) |+ S4 j$ x5 X; h; `PDF FILES:" L! w2 P( r: z6 z3 [
CC1101EM_868_915MHz_SCHEMATIC_2_2.PDF Circuit Diagram
/ Y% x4 [( O* z' A BCC1101EM_868_915MHz_LAYOUT_2_1.PDF Layout Diagram
7 g- r* Y9 J$ {CADSTAR FILES:
$ j( D$ r. y# b2 ?8 K$ ]; fCC1101EM_868_915MHz_2_2.SCM Cadstar Schematic file! m0 C8 @. F9 D+ O; K1 ~
CC1101EM_868_915MHz_2_2.CSA Cadstar Shematic archive: w: b( s. z; ~/ j
CC1101EM_868_915MHz_2_1.PCB Cadstar Layout file; u+ D) \& p: |' p7 |
CC1101EM_868_915MHz_2_1.CPA Cadstar PCB archive
) |' ?" F. |0 P* j% }7 yREADME_1_0.TXT THIS FILE ASCII |
