这个是学习51过程中非常经典的一些程序,AD09原理图与pcb,非常适合初学者
4 W5 K+ ^9 p/ ]: Q, ^& ~4 q#include <STC12C5A60S2.H>
, \0 W3 P2 W F" h/ W6 Z2 [6 F' K9 z: Z. [8 t" `" v
: _, c" X P6 K! R6 {0 Q( b) osbit K_OUT4 = P2^7;
x' q' ~. x1 d f1 q2 e' ?" ~sbit K_OUT3 = P2^6;
; @9 Y2 i) I3 J2 v! zsbit K_OUT2 = P2^5;
2 q& @" C: c2 t, z3 T7 o* \) `sbit K_OUT1 = P2^4;
" `" |: S7 G2 n) d! X
1 ~; ]& N0 H0 y5 e( b0 {0 c4 n" N" e( R8 ], o% Q1 ?2 K
sbit K_IN1 = P2^0;
F; u# n w. `6 C: F2 q' a( n/ }: xsbit K_IN2 = P2^1;
7 r( |4 {. L$ E7 [sbit K_IN3 = P2^2;) S$ G! l8 E2 t3 {- Y `0 L3 N6 i
sbit K_IN4 = P2^3;
2 L7 z' P( t) I/ B0 T7 t) z8 e- e Q' n/ b0 F3 j
6 q U$ d' j$ n, j2 m1 I" H6 `5 b
bit KeySta = 1;
, N: E: s& N0 J, ^# a( _5 w" v; [8 _- Y$ S. `) f& O$ Z
( l1 _ H+ P& Y# i" l
void UART_Sent(char dat);
9 U! }8 u( k0 p% m
" Z7 U7 s# I- P# L
4 a& X. c1 F9 v' avoid main()
0 h: I8 b3 A- |9 P- ^4 S{
! @# g) Q9 b* o3 u6 O! ^ bit backup = 1;3 O# p, A- b' G* T- j
unsigned char cnt = 0;
5 K+ w8 x* \ m/ Q( A. C8 A" p K_OUT4 = 0;
9 Y8 S8 F2 A! c ]6 O+ W) j K_IN1 = 1;7 c& a ] \! g9 g! _; k( t
EA=1;; A( {# H4 d: R( K6 t% T
, ~9 D4 l( H2 R$ I /*第一步:设置串口工作模式*/& K% q+ w0 w+ S
SM0 = 0;
5 L# v- h4 }1 l# n; j$ y" t8 u) q SM1 = 1;9 s3 w- q# r' @
/*第二步:设置波特率发生器*/5 p3 u& n7 }5 |9 m
AUXR |= (1 << 0); //选择:独立波特率发生器
. a5 o4 T! O8 j w. r" F i5 S0 x' ] AUXR |= (1 << 2); //每一个时钟计数一次
+ U3 A P7 F6 _- e/ F BRT = 0xE6;( X2 u+ _) f/ q! B" C4 ]. d/ y6 i) m
AUXR |= (1 << 4); //开启独立波特率发生器( [1 |; t$ F( F; y: k! E3 t
TMOD = 0x01; //使用定时器0的模式1:即16位计数器,优点:可装载的值较多,计时可较长1 Y* M7 n, d8 Y
TH0 = 0xF8;0 v# B0 Y) j$ F& {8 Q1 q! x
TL0 = 0xCD;
4 _6 _* B" `' Y8 h: t7 j8 F9 v+ ] ET0=1;
: t7 c- f5 Z* u# s8 i TR0=1;: v+ J0 c2 I, k2 z
" b6 a& |8 U4 T/ @' w# ^0 o( ?8 w7 e& L' T
0 A! K; Q# `2 m+ L2 _
' n/ q% Q3 E" y
while(1)
! p) L& M9 l! w* L3 O7 D- D* n { 4 ^" b) c) O1 }; c) e' S
if(KeySta != backup)" b6 |, C1 U( }) L! w
! Q3 h7 ~% W1 A4 N. r) |2 g if(backup == 0)
5 B" E; z8 ]3 c6 R {+ V2 {! y0 i) Q2 g& w- x
cnt++;
. y9 L$ x# Y3 `/ w) g6 M if(cnt >= 10)
2 d, n- _% L. q$ {. u9 M- d9 G7 w {5 L* O m! W4 [$ T$ `$ F/ q
cnt = 0;6 U3 `/ _# z- y& ~ t- a0 {# V Z
}+ K0 O: J7 C- `0 n, L. d
UART_Sent(cnt+48);
, n7 E: i7 T9 n5 {6 Z }
4 L; S7 c: e! b( x9 s/ j+ U backup = KeySta;! ?! }3 z6 X3 E
} ! c$ O; C s0 U& h9 t6 F
1 V4 g0 G( R. s; R/ b2 c}) g5 P6 S$ U% P; D4 E9 _
% I4 M/ w# _5 W2 T
! A, O+ y. Y, ~; i) |% wvoid UART_Sent(char dat)
}$ i/ L1 D4 U/ N+ W{ 1 W. Z! z: ]$ `5 p$ B1 g
, n! k6 @6 g3 Z | g
3 u/ }, `6 U0 [; O SBUF=dat;) X7 C( l! a4 q- A- _# ]2 Z& j5 ^
while(!TI);
$ u* P9 l0 h3 w TI=0;
2 u7 G9 C0 N# o- Q8 ]; ]' V H}
% p$ y. r J3 `# [- l: |4 S! P( m8 p O/ T3 i
# v& Y8 O$ h$ U3 N2 x1 J
void timer_0() interrupt 1
" V4 O) W; _# p( N- a: E, E{
" R; n2 H/ D6 P! x& j; @ } static unsigned char keybuf =0xff;
( p( i/ | ?' f1 L2 O* `* ^" @( ]) @0 z/ w1 Q1 j& q- _
4 C; H9 `/ S' } TH0 = 0xF8;
6 h# _1 [ ?- t; g TL0 = 0xCD;) k/ k5 w0 t' F9 i, ]1 E8 N
9 D# _- _! y5 S( ~/ h
; C* H4 s% p; B8 F8 X6 B0 a+ a
5 }- P! c% n: u0 ?+ L keybuf = (keybuf <<1) |K_IN1;
- a0 J, d9 c* u: L y! _! v- ] if(keybuf == 0x00)
. g2 s. Y/ I/ |; M/ e2 n+ P {' F8 u; o0 W% g5 O! |$ x3 ^( F
KeySta = 0;
2 \) b3 s4 }. |& H. H0 ^ }
9 h: W4 J& }1 `/ _. l else if(keybuf == 0xFF)
& R1 S8 g9 m1 h0 k9 g( m, ?+ Z {' b9 H0 ^8 X+ o0 b
KeySta = 1;; E* k0 Y! [: b. g# Q
}! h6 n3 G& s% `" t
else
* N8 X: n: T- H; q1 d {
- {# y; h% w- y }& E8 Z) @: {+ k( P' U
( Z6 j1 x: K! M# h x8 g) o3 j8 R8 X- s/ q, O5 J' [+ c: {
; }+ ]+ h7 R5 R: F8 l; \; H+ Q
9 {- Z) s# j7 _/ o
5 B- I( L5 U0 l0 H4 x" J, }
6 X3 w8 R$ [, r8 F( W( n1 k# @5 _
/ S1 U2 p4 E# z8 r$ ~ |
