查看: 3067|回复: 3
寻求帮助啊 ,已经弄了几天了
发表于 2009-3-13 12:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用orcad生成的网表,但是导入到allegro总是有问题,我现把 一部分viewlog贴出来,希望
' m7 N3 V' G) B0 S# ?$ `高手帮我解决一下,*.dra,*.psm,*.txt, 以及*.pad我都放在我自己做的封装库里了,& L6 H( v" i/ R7 F) T: E/ i
这些文件的路径也设置正确了,为什么还是总有问题?8 P% e" M- l& i
$PACKAGES, J1 j4 k( S  J' i. n. A+ r6 U
!c0603! 0.1UF; C1
, S: @6 z( Y, o9 k$ {8 {7 l^- h% r: b5 u; k
ERROR(SPMHNI-88): Device file was parsed, errors were detected. Run netin in s~& [6 b5 A1 H) G  ~5 a) T
yntax check mode for detailed error report.7 g( |2 w% H- @) v; [  j4 U3 l' `
-------------------------------------------------------------------------------. M; u( O8 o5 q. I
!c0603! 0.1UF; C10' e# O9 O* v5 m* A! e& V
^- ?7 s. p( e- m0 p) n: ?6 H3 A, A" e
ERROR(SPMHNI-88): Device file was parsed, errors were detected. Run netin in s~+ C2 {$ d. ]- [/ t% ]
0 i- j1 P3 K& i: O' v% ~8 U-------------------------------------------------------------------------------
9 c3 x6 i; `7 d& |!c0603! 0.1UF; C11
: i# M/ D  i) k/ |3 t^. O' l  d% o, R  K: M
ERROR(SPMHNI-88): Device file was parsed, errors were detected. Run netin in s~& s$ P7 j, F1 q- Z$ e- H
yntax check mode for detailed error report.) T( a1 |5 ^4 z% t
ERROR(SPMHNI-114): Reference/function designator 'U1' not found, pin ignored.
, d9 i; R7 x7 O* [-------------------------------------------------------------------------------
& Y/ e' ^6 `+ C8 zDP; U1.5 U7.31
! m; t" }& Z) t+ l5 C, ?# A2 @^
: f* d" L4 c3 k% w8 v( KERROR(SPMHNI-114): Reference/function designator 'U1' not found, pin ignored.
! R7 f! Q& L9 y6 q5 g+ k9 ^-------------------------------------------------------------------------------
# D# f# t7 x( _% ]: SN43315; U1.3 R3.1
6 z# o, }! D) @; {5 x8 c2 L2 _^. \3 r3 o% x! K+ _; X+ h
& L4 y/ w2 U8 E3 P& e-------------------------------------------------------------------------------
" C. d7 a# {9 o" k- d% E0 rN43502; U1.9 C7.19 g4 X  q, T5 x) U1 K/ n! M
9 m# p; r' {1 D3 M. H7 h) YERROR(SPMHNI-114): Reference/function designator 'U1' not found, pin ignored.- e. u* S: `) X' M" C+ o$ b- U9 j2 H  ]
-------------------------------------------------------------------------------& e. A# W. `; |* W5 p5 K
^# ^( D  P& O1 T3 b# Z2 |
ERROR(SPMHNI-114): Reference/function designator 'C7' not found, pin ignored.
发表于 2009-3-13 16:11 | 只看该作者
什么格式的网表?
 楼主| 发表于 2009-3-13 17:34 | 只看该作者
2楼的,我是*.txt格式的网表,能帮我看看上面的viewlong里面到底是什么问题( a8 C! [* L  M! a# g
谢谢了
发表于 2009-3-13 20:51 | 只看该作者
能贴一部分网表格式么?
GMT+8, 2025-8-24 07:23 , Processed in 0.109375 second(s), 24 queries , Gzip On.
