查看: 331|回复: 1
正反转可控的步进电机仿真文件
发表于 2018-11-13 09:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
正反转可控的步进电机仿真文件
, h* Q! B, \' i* M8 q( l
! Z2 z; H/ {0 ?, N
0 V3 C/ }$ S2 N$ k$ x* _单片机源程序:, X) P0 Z8 v; s) G" A
/***************   writer:shopping.w   ******************/
( U2 i  j/ T* A0 P  H* V: e1 U" l#include <reg52.h>; `. F1 ?+ n- N! Y3 Q% o
#define uint unsigned int! k, ]" g( [1 h8 n! N8 b0 i, H
#define uchar unsigned char
, q7 D/ [( G4 e+ I2 U/ guchar code FFW[]=0 S% \0 i" h0 o6 T
{% U5 Q3 c" Z5 A: }+ A
         0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09
* e' p: S# Y; R5 A( y6 U};
" R6 N$ y. o: Q! t$ b
- Z! o. Q0 h+ J6 b  o1 |3 _$ R9 M
: u& K* |; u; |9 ^$ @: W* f) C
uchar code REV[]=# c. q. X6 G, |# p2 f
{- I, j2 |: @0 A$ N4 j) p
         0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x019 d/ |" ]2 g. L
};2 m* a+ C' A3 M4 r9 L: F
1 q; `4 A7 y3 x8 `& _) R
: Y% V5 G8 S* p2 t6 Q8 m0 M# p+ H
sbit K1 = P3^0;
7 e0 f  r  _; o' _% M4 u4 A, q% Csbit K2 = P3^1;* I; P! Q  u2 J$ ~& x
sbit K3 = P3^2;+ w4 W9 s# a: z# @; }1 X* g
' m! M. x+ X' e( j
- y$ P5 v- P& @3 G- Ivoid DelayMS(uint ms)5 ?$ G  O( z; U: n( ?% [) Z( R
{! s* O$ {! F# l& \+ I  D
         uchar i;
0 S- s6 h1 F' m' B0 {5 D. q" Z  P        while(ms--)" r7 s7 F+ X1 t& m
        {. _- {6 t1 t7 r* p7 F# W
                 for(i=0;i<120;i++);
0 G2 i+ K4 H+ h7 w/ y5 B6 D4 g" _8 m        }! u4 n( q0 Y4 h5 @* |" s
}) [* O1 H, V  Y1 A
0 t* [( G/ \& h0 D  a0 D% A
9 r; K4 n- g9 }; o' Svoid SETP_MOTOR_FFW(uchar n)
0 Q5 g# T7 i" W, J# n{& b1 i; U) _7 i
         uchar i,j;
+ t$ r* e  J8 f. R+ y$ c        for(i=0;i<5*n;i++)( i, i9 b. ], A$ B7 F
& u) R( K3 t( j9 @( S                 for(j=0;j<8;j++)6 i. G6 L. ~" z
% }- d, }% ~- H* |$ {6 A                         if(K3 == 0)        break;
. l3 k: l3 V- T2 C$ }6 F1 U                        P1 = FFW[j];3 N- l+ m) A5 l0 `; \" C1 m
                        DelayMS(25);/ f8 ^& y/ M2 H# n" p* D
                }6 V' y3 l/ q1 A1 O' _% N
# F9 ~2 I" \/ u' x3 k! u0 u! S}
2 S5 U4 S* p9 l, l* n- j  s* Y6 D- a4 [+ I
0 C0 q9 x4 r# Y- y+ \6 o" cvoid SETP_MOTOR_REV(uchar n)4 S) k* J, W0 T) |0 u
{* U4 B6 i& s. A! W5 |
         uchar i,j;
* Y' g9 D+ U- k        for(i=0;i<5*n;i++)
# q3 }* F$ q+ {        {
  }: D) r, d) I8 B                 for(j=0;j<8;j++)& ?) G: K& B! F+ N
                {' i7 ]  J5 C# F. n7 v( x
                         if(K3 == 0)        break;7 h, F% F4 o$ a) D( A* z7 q
                        P1 = REV[j];
; Z% _; ~: W+ [# Y                        DelayMS(25);
; U* S3 I4 ~8 ?, ~% J! ?! D! h                }  e* p6 D+ l' y5 {# k
        }4 D3 ?8 u: D  S
  O" z% I: d" c. p3 r2 Z1 K$ F3 I+ o$ N% d
; c) M0 q5 R2 C0 F" |+ o. N, Svoid main()
4 {( ^; z/ Z" |' K, o0 g0 p: q{! N/ A. K5 c' E$ M, R
         uchar N = 3;
( X! p' J& v% R2 o" ~! i7 S- n0 q# p        while(1)& C# ^# L* p, g3 K/ s$ h6 l
! u9 U. h! W  h. S' A                 if(K1 == 0)
2 `# ^1 t9 ~0 q" M                {
) q( x3 X2 K3 r# M4 O$ J2 s                         P0 = 0xfe;$ O7 a4 \0 T6 Z7 J" Q4 _
                        SETP_MOTOR_FFW(N);/ |2 k' V( R# C
                        if(K3 == 0) break;# H$ |* n4 g0 O( ^; x/ K8 Y
/ R4 {1 h9 K6 _6 a8 K1 ^# z7 V                else if(K2 == 0)" P" w  S$ l6 e) N% W1 A3 v
                {7 ^( N; ?) n4 R- y1 ?
                         P0 = 0xfd;7 a7 h7 V1 L1 ^# B! T6 [
                        SETP_MOTOR_REV(N);. C# j6 U+ R; u
                        if(K3 == 0) break;0 r/ d" s3 B3 w& x
  f+ D! R, @9 @# r! K) M                else
2 H4 D+ q/ G: @6 z& q5 x8 W                {, e% B$ r7 O( }
…………限于本文篇幅 余下代码请从论坛下载附件…………
/ T- l* \. T2 b7 i6 p. t( K# G
: x. d: F: `" t) @! O6 O
游客,如果您要查看本帖隐藏内容请回复
; a( @# r5 x: F: h  [/ s
GMT+8, 2025-7-22 06:49 , Processed in 0.125000 second(s), 26 queries , Gzip On.
