led胸牌 含原理图 源代码及proteus仿真
( h' W: M% o3 x程序简单,适合初学者,内附原理图代码等,用proteus8制作,用16*16点阵显示汉字。
, O- p5 f8 D1 f R
" L* L& G" d, ^0 d# U! vproteus8仿真原理图:
5 j; h; H K' b* B; O& W) ]
| 单片机源程序如下:
0 w3 S7 S% \5 f+ O& i" o& A4 v6 B/ e3 M, g: R$ c1 S# R* x
#include
0 g% x5 h1 k8 L#include% a) w! w$ n% ]. B; c+ J
#define uchar unsigned char 7 w) y' ^+ w& i3 X
#define uint unsigned int
* A/ n3 e- o: L2 I8 r/ Muchar code col[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};//列控制数组 . o8 R. A& `( Q! u B5 w
uchar code row[][32]={ //字模 + `/ F: _ ~, o! T4 r' D/ |$ h- B
# S4 _' C, J! i{0x40,0x00,0x80,0x00,0xFE,0x7F,0x02,0x40,0x81,0x20,0x80,0x00,0x80,0x00,0xFE,0x3F,
' v0 j6 p' }4 y* }* ]8 K8 J0xC0,0x01,0xA0,0x02,0x90,0x04,0x88,0x08,0x84,0x10,0x83,0x60,0x80,0x00,0x80,0x00},/*"宋",0*/
0 z/ [2 \. t: P3 r4 f" h8 ^/ ]' E- k% h7 @4 E
{0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFF,0x7F,0x80,0x00, % s, S W9 h' W0 l1 b
0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x00,0x00},/*"士",0*/ 8 \+ N2 M: z s( x1 K$ a5 G
, B* w l6 x9 Q/ i
{0x20,0x04,0x20,0x08,0x20,0x08,0x20,0x00,0xFF,0x7F,0x20,0x01,0x20,0x11,0x20,0x11,8 R0 j7 Q0 v8 N% y$ b) n' b
0x20,0x09,0x10,0x05,0x10,0x03,0x08,0x41,0x88,0x41,0x44,0x41,0x22,0x7E,0x01,0x00},/*"龙",0*/" n* g) j. r$ S
" o# {* j- c% M1 Q2 K" a) m9 n
{0x20,0x00,0x70,0x00,0x1E,0x00,0x10,0x3E,0x10,0x22,0xFF,0x22,0x10,0x22,0x18,0x22," N3 e% m7 g$ K+ _& J& l: s" W- @
0x38,0x22,0x54,0x22,0x54,0x22,0x12,0x22,0x11,0x3E,0x10,0x22,0x10,0x00,0x10,0x00},/*"和",0*/7 w5 Y g* K4 k9 i
/ g; x- `! ~$ E# a( e9 [{0x08,0x00,0x10,0x3E,0xFF,0x22,0x00,0x12,0x7E,0x12,0x42,0x0A,0x7E,0x12,0x00,0x12,
# R' o' d/ V- n- w v7 `8 }2 L( M' x0x7E,0x22,0x20,0x22,0x10,0x22,0xF0,0x16,0x1F,0x0A,0x10,0x02,0x14,0x02,0x08,0x02},/*"郭",0*/7 h" O6 `" ~/ W
: [" ?3 H6 i+ J7 ~. C$ P2 t{0x08,0x02,0x08,0x02,0xFC,0x7E,0x14,0x09,0xA2,0x10,0x01,0x0F,0xFC,0x00,0x80,0x00,0 ^* Z' I; R \3 f& I1 S
0x80,0x00,0xFF,0x7F,0x80,0x00,0x40,0x01,0x20,0x02,0x10,0x04,0x0C,0x18,0x03,0x60},/*"笑",0*/6 O7 h9 B e9 m8 p* } ?, w
6 K2 D' K" [9 d: J# s& ]. E" c' Z{0x08,0x02,0x08,0x02,0xFC,0x7E,0x14,0x09,0xA2,0x10,0x01,0x0F,0xFC,0x00,0x80,0x00,
# u/ N7 \& C% u; f3 B3 Y* D0x80,0x00,0xFF,0x7F,0x80,0x00,0x40,0x01,0x20,0x02,0x10,0x04,0x0C,0x18,0x03,0x60},/*"笑",0*/
# t9 g1 G# W2 A8 n! f% c1 X: W8 t/ \) \+ w
{0x20,0x20,0x24,0x20,0x24,0x20,0xFC,0x25,0x22,0x24,0x20,0x24,0xFF,0x27,0x20,0x24,
4 L4 F: A: p9 W7 Z* a0x20,0x24,0xFC,0x25,0x24,0x25,0x24,0x25,0x64,0x21,0xA4,0x20,0x20,0x28,0x20,0x10},/*"制",0*/
) R7 Q2 p2 d' l. U' }& F! l2 A5 F, C: J# F
{0x90,0x00,0x90,0x00,0x90,0x00,0x88,0x7F,0x48,0x01,0x4C,0x01,0x2C,0x01,0x0A,0x1F,4 d: ~$ X$ T9 M% t
0x09,0x01,0x08,0x01,0x08,0x01,0x08,0x3F,0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01},/*"作",0*/8 R' z- P' @ U, g+ P: W/ [9 G% t
. P/ {4 ?* |, }1 X! Y) `3 @! R% P- Q4 T
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
" ^, R5 f& ^, [0 u0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x0C,0x00,0x08,0x00,0x04,0x00,0x00,0x00},/*",",0*/8 { s8 }' U s# L, Y! E: ~
I, E( e! Z1 M% U/ y{0x80,0x10,0x42,0x10,0xE4,0x11,0x24,0x11,0xE0,0x7D,0x20,0x11,0xE7,0x11,0x24,0x13,5 a8 M- D- Q( m* ^9 w- v# ?0 o F
0x24,0x15,0xF4,0x15,0x84,0x11,0x54,0x11,0x2C,0x11,0x14,0x11,0x40,0x15,0x80,0x08},/*"谢",0*/0 G! c4 W6 x$ {3 _( n W6 x# g
g9 x+ R0 f6 z( z$ O{0x80,0x10,0x42,0x10,0xE4,0x11,0x24,0x11,0xE0,0x7D,0x20,0x11,0xE7,0x11,0x24,0x13,: y4 }4 @4 U$ F' H: m
6 E% a. r1 R+ K, C, `! P+ g, p4 m' z" O" a5 |0 W
{0x00,0x00,0x80,0x3F,0x80,0x20,0xBF,0x20,0xA0,0x24,0xA0,0x24,0x92,0x24,0x94,0x24,
' b' i& Q. v; |0x88,0x24,0x88,0x2A,0x14,0x0A,0x24,0x09,0x22,0x09,0x81,0x48,0x40,0x48,0x20,0x70},/*"观",0*/
2 f# b8 o% t2 a
7 C! b- [- _2 b. h. J3 Y! j6 S2 g9 ~{0x00,0x1F,0xFE,0x00,0x80,0x00,0xFC,0x1F,0x40,0x00,0xFF,0x7F,0x20,0x00,0x10,0x00 ,3 I7 v- `1 }3 V
0xF8,0x0F,0x14,0x08,0xF2,0x0F,0x11,0x08,0xF0,0x0F,0x10,0x08,0xF0,0x0F,0x10,0x08},/*"看",0*/
" ?, `- _* X8 y. H# V' `8 q* } x* X2 m/ P8 _! }, t
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,9 U. \0 L! |3 Z, e1 W/ t
0x00,0x00,0x00,0x00,0x18,0x00,0x24,0x00,0x24,0x00,0x18,0x00,0x00,0x00,0x00,0x00},/*"。",0*/
& y$ l& k2 D8 P3 }};
' b% L7 Q) p0 M% n: |& q0 J8 T1 M7 j4 m1 [3 w+ a3 `8 J
void delayms(uint t) //延时函数
7 L6 V$ o" f( p: F{9 z. t" H7 i( e6 t1 f, R
uint x,y;0 r. Y- X; w9 Y1 _; f& ]
for(x=t;x>0;x--)
, m& k' C% T. d% Q for(y=124;y>0;y--);) i) u/ m: K [4 G: V1 y
} - X; j$ s$ K0 l7 n+ Q9 G, e2 B
' ^: D1 x, {" Q+ @" r: F7 D9 @void display(uint n) //显示函数
3 @ D4 F4 G4 k( _; y" M{
5 ~# c1 c9 r3 c% X' F4 W; } uint i,j;
3 z- C: L+ d* Z/ @ for(j=0;j<12;j++) " x; z( E; E i. l; c: K
for(i=0;i<16;i++)+ e; |" L1 V2 t) O ^4 R5 p9 l; H' ~
( q" ~0 j& U# Q! b) s4 P P2=col;
% u4 I1 y6 t1 Q+ V& \% L2 d! z P0=row[n][2*i];/ N' P1 e- x7 k! ~, [6 y
P1=row[n][2*i+1];( b, {% Q! `& z: T A9 R1 Y
delayms(3);
9 Z, Z2 l. L6 P3 U }
! Z2 p! O A' g- w' d3 ^0 S6 ]0 d}
2 n* ^; h- W- U' o" d/ H# g# e4 P4 e% m: m! c
void main() //主函数
" n2 p* A; P" C R2 N# g{
; d: ?0 y4 @: ^# y2 {P3=0;
5 g3 Z& l+ M# M9 O% u* \5 Q( l! {while(1)
; |+ b, O& b ~& y{5 k# a" V9 u! e- t- c) ?5 T6 _
P3=0;if(P3!=0){display(0);delayms(50);}else break;
' e6 [7 f( z- W# `$ B" Y% Z" R P3=0;if(P3!=0){display(1);delayms(50);}else break; . C" T9 I4 F$ c/ O* e* ]
P3=0;if(P3!=0){display(2);delayms(50);}else break;
1 V( p. _) G4 D+ u P3=0;if(P3!=0){display(3);delayms(50);}else break; * K9 F- z) s% H
P3=0;if(P3!=0){display(4);delayms(50);}else break; 6 C) G# w& q, D. t) S/ @6 x
P3=0;if(P3!=0){display(5);delayms(50);}else break;. j& u8 a0 Q* k0 k# b, P6 g" j
P3=0;if(P3!=0){display(6);delayms(50);}else break; ( Y+ h: n$ ?. J3 m: x
5 \5 v: {' Y4 B% B* ?! s5 ]/ K# x0 r$ j4 @
…………限于本文篇幅 余下代码请从论坛下载附件…………
1 u) B) f+ T: q6 I/ W
( w. F" |1 h8 w! }& n, ]; M' W* w2 c/ O |
