查看: 390|回复: 1
投影仪控制系统
    2019-11-19 15:19
    发表于 2018-11-2 10:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    投影仪控制系统
    1 d" Q  ~0 b9 U6 D# M- Q
    6 A/ M6 d8 i+ H3 [; y3 H, e
    这是一个投影仪控制系统,通过此程序可以控制投影仪实现各种图像的投影,方便简单
    * e- i) ^- r8 J0 z+ [+ Y* _
    . o5 Q- n3 \/ M4 o8 \9 B投影仪控制系统\circuit\project.ddb
    6 c5 U0 ]8 D% Z8 J/ m9 T  ..............\.ode\intercomm\ARM_boot\api_mem.c
    9 {' s% a. ^+ e1 P+ s) r  ..............\....\.........\........\api_mem.h% X6 y4 b  e7 P" Z5 g- m
      ..............\....\.........\........\arm_boot.cmd6 @- v" P# }  {* N" i  r
      ..............\....\.........\........\arm_boot.h
    ) _" y' Z. \7 h9 {- m' a  ..............\....\.........\........\arm_boot_be.paf4 `( U" b. v& ?
      ..............\....\.........\........\arm_boot_be.pjt
    / c2 R& w5 |5 b& F' D  ..............\....\.........\........\arm_boot_le.paf
    - H  B4 }9 Z; \5 j  ..............\....\.........\........\arm_boot_le.pjt
    - ^* }2 c7 W9 a- c$ b. H  ..............\....\.........\........\arm_boot_le_flash.map( y/ S, W  {- A  T% T! l; Z& h
      ..............\....\.........\........\arm_boot_le_flash.out% x2 j) P7 w0 A5 @
      ..............\....\.........\........\cc_build_Debug.log! w. v- O! L7 R
      ..............\....\.........\........\Debug\api_mem.obj" @- E8 o7 [! |! t5 e0 v: ?
      ..............\....\.........\........\.....\introutines.obj
    " K- j1 b6 k  h9 m% ]$ ~; U3 f  ..............\....\.........\........\.....\intvectors_le_flash.obj' o. X% K+ B! c7 I) G- Z
      ..............\....\.........\........\.....\load.obj* k) Z$ N3 p8 y9 k9 W7 U
      ..............\....\.........\........\.....\main.obj
    : v6 `, L' S8 I& N0 i* c) U  ..............\....\.........\........\.....\orionpll.obj) t$ X  Q$ W4 X3 }; ~; d0 N/ R
      ..............\....\.........\........\Debug.lkf
    ; _& }4 q' c& r+ R; W  ..............\....\.........\........\Debug.lkv
    . I" ?9 F7 m" O5 h+ {  ..............\....\.........\........\DSP_boot_code.h0 h/ W3 o8 i3 J% r  z9 }
      ..............\....\.........\........\dsp_proj_code.h
    3 o8 ?2 z* ?$ K! K8 c- R! s  ..............\....\.........\........\dsp_proj_data.h# S" S$ w/ R5 m. N' A
      ..............\....\.........\........\introutines.c: m" H7 _! Z% ?. W
      ..............\....\.........\........\intvectors_be_flash.c
    / O( m8 W2 I) w. Q  ..............\....\.........\........\intvectors_le_flash.c6 G, Q. H/ K& N9 ^9 K3 y" x0 T7 {( {3 {
      ..............\....\.........\........\load.c" P! `( Q8 |* o, I; y
      ..............\....\.........\........\main.c
    % X. M+ p: F' u  ..............\....\.........\........\orionpll.c
    $ ?& V7 v' f8 Y9 r( A( i' `! e  ..............\....\.........\config\c5471_be_flashlow.ccs
    1 f3 c! P* f6 o: s: u: C9 T1 z7 T  ..............\....\.........\......\c5471_be_ramlow.ccs
    + L) P) O# S8 H8 p6 q* k  ..............\....\.........\......\c5471_le_flashlow.ccs
      l* M4 z5 s+ ~+ i( r) X0 [5 G  ..............\....\.........\......\c5471_le_ramlow.ccs
    - m: a" u* ^+ |0 f/ U/ O2 \  ..............\....\.........\dsp_boot\cc_build_Debug.log
    9 b/ w! g& [% L! T' V1 V+ j* z  ..............\....\.........\........\Debug\dsp_boot.lst
    5 ~+ b" B6 h1 O  {  ..............\....\.........\........\.....\dsp_boot.obj' E  E) b$ [+ `( w7 B7 ?
    0 M2 T5 Q/ Z. `  G; x3 V$ G  ..............\....\.........\........\Debug.lkv3 g: |% N5 ~) B; H0 ~: x. b
      ..............\....\.........\........\dsp_boot.cmd
    # c4 S8 R% [; U6 ~# r, u% G  ..............\....\.........\........\dsp_boot.inc
    $ X1 ?" z% \7 W* b/ O( V( V; X  ..............\....\.........\........\dsp_boot.map
    0 }1 e* T" }* L7 `  ..............\....\.........\........\dsp_boot.out- d8 N+ b8 N0 B2 e5 l
      ..............\....\.........\........\dsp_boot.paf, Y' B9 x5 p) g! H6 D0 d1 ^
      ..............\....\.........\........\dsp_boot.pjt
    9 W' L3 u0 v8 L4 V) C5 _) ~  ..............\....\.........\........\dsp_boot.s54
    5 Y% d; m2 f, e' F  ..............\....\.........\........\dsp_boot_code.h
    * q5 t+ M! D' t9 a) u1 O1 K  ..............\....\.........\....proj\cc_build_Debug.log
    6 V  x, O3 p& I: P. i  ..............\....\.........\........\Debug\intvect.obj: g; N/ i. }8 w- u  x7 E, ~
    2 N9 k; J% u, l- L  ..............\....\.........\........\Debug.lkf6 \$ g: ~) q) `9 G
      ..............\....\.........\........\Debug.lkv; Y! ^2 j% G6 Z$ h1 b  Y" L  y
      ..............\....\.........\........\dsp_proj.cmd9 S% ^) a; t# J
      ..............\....\.........\........\dsp_proj.out( c# k& M' l1 h- ~( O2 C, {" N/ @
      ..............\....\.........\........\dsp_proj.paf' m- P6 ]2 r# T- ?
      ..............\....\.........\........\dsp_proj.pjt' b2 D2 c. \2 y  ]5 ~7 x) F
    : X2 a- e* Z$ Y$ N  ..............\....\.........\........\dsp_proj_data.h6 u/ u- d; _6 y( h( h4 T1 V
      ..............\....\.........\........\intvect.s54
    ! e9 i) _3 k6 D# c9 \2 b  ..............\....\.........\........\main.c8 ~7 Y2 F3 @- ~- Z1 c
      ..............\....\.........\gel\c5471_be_flashlow_mcu.gel
      ?# z$ ^5 C# }  ..............\....\.........\...\c5471_be_ramlow_mcu.gel  a" C+ E- }. L1 X3 J" _
      ..............\....\.........\...\c5471_dsp.gel# C' ~' ^1 Y( p
      ..............\....\.........\...\c5471_le_flashlow_mcu.gel8 a4 ^# [3 G8 D) H1 n& e7 p, r
      ..............\....\.........\...\c5471_le_ramlow_mcu.gel1 R$ N, [8 O* I. ?' u+ d! X
      ..............\....\.........\out2boot\out2boot.c/ h. G: ^) i; ]: V# W0 ?
      ..............\....\.........\........\out2boot.dsp- u4 i5 A4 ]4 s1 M( v6 j
      ..............\....\.........\........\out2boot.dsw
    6 G3 k1 K! ~% w1 B  ..............\....\.........\........\out2boot.exe
    ' P! q7 R  P5 h7 S: }7 l4 u" J  ..............\....\tms320vc547xbootloader\arm_boot\arm_boot.cmd
    . @/ b0 K! o7 {  ..............\....\......................\........\arm_boot.h
    : l8 R  U1 h# Z  ..............\....\......................\........\arm_boot_be.paf2 |& {( T) d& f3 @2 \
      ..............\....\......................\........\arm_boot_be.pjt
    3 G& K- F. _0 K" W3 d  ..............\....\......................\........\arm_boot_be_flash.map
    4 `: o- p# f5 y  ..............\....\......................\........\arm_boot_be_flash.out9 t+ K- ^& Q, P, Z5 d' [: y
      ..............\....\......................\........\arm_boot_le.paf. A# [+ ~* F% ]  G9 I
      ..............\....\......................\........\arm_boot_le.pjt
    # @. t2 |" K$ u7 }  ..............\....\......................\........\arm_boot_le_flash.map( Y; O0 P* K+ B- J
      ..............\....\......................\........\arm_boot_le_flash.out8 U" Q. R# m8 J. w' r8 z
      ..............\....\......................\........\cc_build_Debug.log
    ' Z) M' s, l  \8 m% b  ..............\....\......................\........\Debug\introutines.obj
    # t  B& {8 V- ]2 ^1 D  ..............\....\......................\........\.....\intvectors_be_flash.obj7 E: Z: ]: B/ {6 w% g( S
      ..............\....\......................\........\.....\intvectors_le_flash.obj
    " {9 z$ _3 U! j1 }( n  ..............\....\......................\........\.....\load.obj
    # [  w# m7 Z. r% J  ..............\....\......................\........\.....\main.obj+ @( e# l& f8 ~4 z8 R0 t; i
      ..............\....\......................\........\.....\orionpll.obj
      `* ]" Z% b1 S" [; g8 q  ..............\....\......................\........\Debug.lkf
    1 J  K' ~( K( t: ?  ..............\....\......................\........\Debug.lkv
    / Z! T, D& s. P& @8 I% k  ..............\....\......................\........\dsp_boot_code.h" b+ G3 I. q7 R- o& [
      ..............\....\......................\........\dsp_proj_code.h
    / n" R. i7 s9 i* J2 Q3 \2 f) O  ..............\....\......................\........\dsp_proj_data.h2 A2 y) M. b1 ]4 i/ {9 K3 [
      ..............\....\......................\........\introutines.c
    $ R# @; k* U$ D, w# G- f! i$ o  ..............\....\......................\........\intvectors_be_flash.c
    2 r0 H' q  H5 A% r, g- h/ J9 ]  ..............\....\......................\........\intvectors_le_flash.c
    2 C0 }6 b7 Y5 o: o  ..............\....\......................\........\load.c5 j0 i. G0 B7 }# u4 T: }
      ..............\....\......................\........\logfile.rtd
    9 o3 c# t+ m' R. Q  J  ..............\....\......................\........\main.c  |; H: s. S1 v) G) r
      ..............\....\......................\........\orionpll.c
    . w+ B: S3 [5 O  ..............\....\......................\config\c5471_be_flashlow.ccs
    & J: V) z2 l" P* b' F  ..............\....\......................\......\c5471_be_ramlow.ccs
    6 ?0 Y  f; U2 P+ i! U0 N. m9 E  ..............\....\......................\......\c5471_le_flashlow.ccs
    游客,如果您要查看本帖隐藏内容请回复
    , d7 m! \' l: l3 g7 k# k, H
    GMT+8, 2025-8-21 13:38 , Processed in 0.125000 second(s), 26 queries , Gzip On.
