带有红外检测 温度检测 语音播报的 多功能PC小键盘设计- _# `4 W( t/ L, ]( I# y
duogongnengpcxiaojianpan\多功能PC小键盘-参考电路、程序\CW工程_Keyboard\bin\Full_Chip_Simulation.abs0 b$ S" d/ x. q. b$ }$ x
........................\.............................\...............\...\Full_Chip_Simulation.abs.glo
8 B+ v; I. J; l0 q7 u' [( N7 T ........................\.............................\...............\...\Full_Chip_Simulation.abs.s19) q: o+ t( i! E
........................\.............................\...............\...\Full_Chip_Simulation.map. z( f2 m2 q0 }( N5 z- Y# \1 f
........................\.............................\...............\...\P&E_Multilink_CyclonePro.abs
' X: G( k4 C* H1 R7 ]* ~/ j# i9 o ........................\.............................\...............\...\P&E_Multilink_CyclonePro.abs.glo
& X6 H2 n* P+ R6 t ........................\.............................\...............\...\P&E_Multilink_CyclonePro.abs.s19
p4 b# D' O* ]: B7 ^+ D7 D2 k8 B ........................\.............................\...............\...\P&E_Multilink_CyclonePro.map
" F: q. R' J0 S8 |- |3 i ........................\.............................\...............\...\TBDML.abs
: B$ _, i. K) L5 Q1 z3 Y6 C ........................\.............................\...............\...\TBDML.abs.glo; D5 E' N, B9 [3 ~' K7 u, ?+ t
........................\.............................\...............\...\TBDML.abs.s19' N' @+ w% b, Q- w" q& x9 ^
........................\.............................\...............\...\TBDML.map) w) b, z. ?4 {
........................\.............................\...............\cmd\Full_Chip_Simulation_Postload.cmd/ N( j3 g1 O) u4 J1 d+ { h& Y7 c
........................\.............................\...............\...\Full_Chip_Simulation_Preload.cmd
3 k0 I4 U; s- O3 p- h" R ........................\.............................\...............\...\Full_Chip_Simulation_Reset.cmd
6 p" V; @4 H. Q8 b( d( M0 D; Y8 u ........................\.............................\...............\...\Full_Chip_Simulation_SetCPU.cmd/ }$ q$ E) Q* }6 x
........................\.............................\...............\...\Full_Chip_Simulation_Startup.cmd4 `" C R! l s9 R/ o' C$ A( m: r
........................\.............................\...............\...\P&E_Multilink_CyclonePro_Erase_unsecure_hcs12.cmd
1 E% R" C$ I/ ^$ ^ ........................\.............................\...............\...\P&E_Multilink_CyclonePro_Postload.cmd
) j( Z& p( N0 ~. [, C ........................\.............................\...............\...\P&E_Multilink_CyclonePro_Preload.cmd5 [, V+ v% P% K& |6 v
........................\.............................\...............\...\P&E_Multilink_CyclonePro_Reset.cmd
! T* ~+ V) A5 j ........................\.............................\...............\...\P&E_Multilink_CyclonePro_Startup.cmd
' G6 z' K& a$ Q9 h" I; g. @# v ........................\.............................\...............\...\P&E_Multilink_CyclonePro_Vppoff.cmd
! O3 J+ U4 z% O& n* N# V0 y ........................\.............................\...............\...\P&E_Multilink_CyclonePro_Vppon.cmd
1 w% i4 @' I5 S+ _4 C ........................\.............................\...............\...\TBDML_Erase_unsecure_hcs12.cmd
; g6 E) W# g+ i3 t/ X% }" T% N ........................\.............................\...............\...\TBDML_Postload.cmd% I7 X! v* g X
........................\.............................\...............\...\TBDML_Preload.cmd; @/ @8 p* A C1 L/ u3 S2 T' ~
........................\.............................\...............\...\TBDML_Reset.cmd! y( ?) }0 _: \7 f8 |
........................\.............................\...............\...\TBDML_Startup.cmd, Z/ I, B+ I H% w
........................\.............................\...............\...\TBDML_Vppoff.cmd
( i; p/ f) W9 j ........................\.............................\...............\...\TBDML_Vppon.cmd/ O8 |3 @( h5 M- H
........................\.............................\...............\C_Layout.hwl
! ^8 Q% }: A5 b- @3 ]+ L ........................\.............................\...............\Default.mem( u e6 h6 S) j: W
........................\.............................\...............\Full_Chip_Simulation.ini! Y# s9 L- ~& o k
........................\.............................\...............\P&E_Multilink_CyclonePro.ini& o; T- h0 O$ C1 p% ^
........................\.............................\...............\prm\burner.bbl
0 U, S0 G& a0 n- c! r" e' n; _% @ T ........................\.............................\...............\...\Full_Chip_Simulation_linker.prm+ u7 S* ?. l) m- w/ \4 L
........................\.............................\...............\...\P&E_Multilink_CyclonePro_linker.prm
0 w) v! w# I& }+ J5 f5 R0 C( {9 b- h ........................\.............................\...............\...\TBDML_linker.prm3 ?7 N3 ~: g" ]. p6 u1 m
........................\.............................\...............\ps2_transl.mcp7 l4 q7 V8 L$ U
........................\.............................\...............\.........._Data\CWSettingsWindows.stg
. L: e; D u0 t# h. L8 Y ........................\.............................\...............\...............\Full_Chip_Simulation\ObjectCode\datapage.c.o9 W! _: u* N c( S" F2 m
........................\.............................\...............\...............\....................\..........\main.c.o* L2 Q) Y4 a7 e# }% B
........................\.............................\...............\...............\....................\..........\mc9s12xdt512.c.o0 e/ ]' E3 [* L' n8 d, R
........................\.............................\...............\...............\....................\..........\Start12.c.o
! Q+ ?+ T+ a! I8 D$ F ........................\.............................\...............\...............\....................\TargetDataWindows.tdt: M5 [4 u; b& Z8 h1 M8 c* h
........................\.............................\...............\...............\P&E_Multilink_CyclonePro\ObjectCode\datapage.c.o
7 v r; ?4 Q, Z: Z ........................\.............................\...............\...............\........................\..........\main.c.o& S& X" J' o5 j# r c+ s& P
........................\.............................\...............\...............\........................\..........\mc9s12xdt512.c.o
3 D% K( H5 Z1 {4 A ........................\.............................\...............\...............\........................\..........\Start12.c.o
2 j1 ~ V1 o5 w1 r3 H! v, O; N ........................\.............................\...............\...............\........................\TargetDataWindows.tdt
7 I/ |. p' s2 J' P3 K& Z4 s ........................\.............................\...............\...............\TBDML\ObjectCode\datapage.c.o4 J) b `- h, O H+ n
........................\.............................\...............\...............\.....\..........\main.c.o
( W* J9 ]: w* K ........................\.............................\...............\...............\.....\..........\mc9s12xdt512.c.o
9 k# {% |9 n5 o6 z0 S ........................\.............................\...............\...............\.....\..........\Start12.c.o* r5 k$ V, Q3 e; E6 V! Z. m# `1 a
........................\.............................\...............\...............\.....\TargetDataWindows.tdt
1 ]: R# b+ s, ?- d$ J ........................\.............................\...............\readme.txt; p- N5 I% w8 M( g$ `" e5 D8 R
........................\.............................\...............\Sources\datapage.c) x; t2 W ~1 x F8 G/ Z$ q% z8 H
........................\.............................\...............\.......\main.c, @; i5 r, g# K! p* |: }# ]; k
........................\.............................\...............\.......\Start12.c
4 l Y4 F6 s! W3 r ........................\.............................\...............\TBDML.ini
1 J. S6 L1 \& X! J6 Q5 T& I ........................\.............................\...............\tips.txt. v" g! y6 R+ f! m
........................\.............................\...............\voice.h
' |0 b0 p+ @0 c* O8 a ........................\.............................\Keyboard.SchDocPreview
m1 }5 H# \+ u: {. x ........................\.............................\History\Keyboard.~(1).SchDoc.Zip
# M) C1 [, Y p' U ........................\.............................\.......\原理图.~(1).SchDoc.Zip7 z, q: e. {+ x* B3 W6 K. Z! r2 L
........................\.............................\Keyboard.SchDoc1 w3 J# @, q3 Y2 ^. N. f
........................\.............................\原理图.SchDoc$ x& L8 M2 p: F1 Z
........................\.............................\CW工程_Keyboard\ps2_transl_Data\Full_Chip_Simulation\ObjectCode# E! r: e: W/ }; r; p. h% [5 L
........................\.............................\...............\...............\P&E_Multilink_CyclonePro\ObjectCode# ?3 G# A9 i. q4 G- A
) z! a$ X% I6 F4 K# H ........................\.............................\...............\...............\Full_Chip_Simulation
: T6 k0 T3 k2 i, j# G; k ........................\.............................\...............\...............\P&E_Multilink_CyclonePro
" v. v& @, m, N3 O( N5 J2 k ........................\.............................\...............\...............\TBDML
$ O" K/ a* ?# l0 V% u B4 P ........................\.............................\...............\bin5 D s6 m4 Z1 q0 q- Z/ h+ b' O5 j
) M# U% ?. }& P$ Z. U ........................\.............................\...............\prm' }' l- q4 Q" [- `6 s
........................\.............................\...............\ps2_transl_Data
9 V% k' o8 d, g/ n ........................\.............................\...............\Sources
, O' V* f+ @5 q( L3 P6 |% _ ........................\.............................\CW工程_Keyboard& s l1 p# ?! d- p
, h O, N5 b% v4 t# {; { ........................\多功能PC小键盘-参考电路、程序) k! {, t5 q/ J# ]& d( E) M) j4 V
1 l# Y0 u/ C1 {6 w
