NRF905开发资料包,各种NRF905的资料和快速上手例程0 s9 ^$ s# L) W; C: t
905_Quick_dev\Antenna\Loop_18x10mm_400ohm.zip
- X. I- Z. |& o4 p6 q/ T .............\.......\Loop_25x15mm_400ohm.zip
5 |6 m2 d l1 @: |) y1 ^ .............\.......\Loop_35x20mm_400ohm.zip
, i+ o* _; a, H2 U8 t( ^ .............\.......\Loop_95x95mm_868MHz.zip% h. z$ j1 ]) X- n/ f
.............\.......\Loop_95x95mm_915MHz.zip
; ~- F/ ^( Q" Y$ V5 B. E .............\.......\README.TXT& J) k8 S. y4 E5 I8 K, v/ Q* h
.............\DATABOOK\applicationnotesallnRFn.pdf2 I4 L6 @6 A' P5 M( ^, s. q$ c6 ?* ^
.............\........\nAN900-04-nRF905_RF_and_antenna_layout_rev2_1.pdf
: Y! y, q+ i1 q/ ?9 b: Q. x+ j* A .............\........\nAN900-04_nRF905_RF_and_antenna_layout_rev1_0.pdf, o9 q% a4 d' k: X! {
.............\........\nRF905 CN1.0.PDF+ S# `9 }4 B& K8 N3 [2 x
.............\........\nRF905rev1_2.pdf( P3 `: h3 `" B
.............\........\nRF905_rev1_0.pdf
$ F, i' h/ a& p8 l* M .............\........\nRF905_rev1_1.pdf8 l/ Z+ G4 F! `. ]. ^. `
.............\........\nRF905_rev1_4.pdf, }5 }6 S- Q/ ^3 D, l3 J9 x
.............\.ev_sch\905_dev.pdf" M1 O& T4 w# B" Z. B# N
.............\nRF905快速开发系统使用手册.pdf$ _2 H) z' N! W* M2 v
.............\PCB\PCB_nRF905_diff_0603_1-0.zip r. Y+ |: S0 p3 M& |
.............\...\PCB_nRF905_single_netw_0603_1-0.zip
. b& z H5 i. D6 G* J .............\...\README.TXT
$ `5 w' ]- W) @. Y& H: I .............\...lib\Nordic_nRF_PCB_protel-98.lib/ U$ n% R) R& h$ P& s
.............\RF_Sch\905.pdf* ^/ C. j8 Z# E* x* Y5 f
.............\sourcecode for 89LV51\C51.zip
& [1 }! ~4 j) Z9 H" h1 q: n .............\.....................\Readme.txt- R. \$ M z6 r" x: s5 g
.............\.....................\source code.pdf4 J {5 U: R5 U k+ f
.............\.....................\STARTUP.A51# m& _( j8 l& b3 h" s1 L
.............\.....................\STARTUP.LST, _+ @! o! L0 U3 q# l
.............\.....................\STARTUP.OBJ
: d8 f2 Y! W: D$ z7 O9 Q .............\.....................\T905; e8 L5 Q8 f J+ m) x/ B* Y( X
.............\.....................\T905.C0 [8 a! k& k. w* A
.............\.....................\T905.HEX
. J1 y7 I9 A' _ .............\.....................\T905.LNP; |% f) V0 i9 v, w+ G. e
.............\.....................\T905.LST
" e) m- f3 M0 z .............\.....................\T905.M51) m6 E- f e% C- ~- n. S6 u9 @
.............\.....................\T905.OBJ
! U% [! ], s9 ?3 h7 `$ j .............\.....................\t905.Opt- ~0 [/ x( A$ [+ j
.............\.....................\T905.PLG+ v: n' [/ a& k4 L9 n
.............\.....................\t905.Uv20 B" D+ c6 C+ J( y, i5 C* J! V
.............\.....................\t905_Opt.Bak& v) M' p& c, m
.............\.....................\t905_Uv2.Bak5 g4 T5 ~7 Z! Y$ p
.............\串口工具\portexpert.zip# C0 r1 ^% j1 i! l6 ~
.............\........\README.TXT
% b% l; z- ?3 F, ] .............\........\SCOMMV22.ZIP
' z2 o" \4 W1 u8 S! B5 {7 v .............\请用Acrobat Reader5.0中文版浏览.txt
- o% C0 _/ n7 \5 V .............\Antenna) q4 W+ V; X- L. I1 ?0 \9 `
.............\DATABOOK( ~( a, L: s( R0 J" B- t+ P( Q
.............\Dev_sch
5 B8 Z. D! l$ H .............\PCB6 |$ I5 ?2 h- ?3 A, u( j- ^
.............\PCBlib
9 S- ]5 P! B9 }3 g# G$ U- R .............\RF_Sch# g+ \8 O- _- g, z6 e* Z6 Y- z# c" E
2 E, r. g; c+ R' {; {8 J6 o .............\串口工具3 G3 Z3 B5 v0 P4 k; W( E
* ]. B4 s/ w1 D& t6 _ |
