非常经典的英文天线基础入门教程。 Antenna Basics/ I, i" E, g& ~! C3 B4 t+ `+ t4 p2 o
Introduction& I1 Q6 O: l; B8 d/ F
Antennas are a very important component of communication systems. By definition, an antenna is a device used to transform an RF signal, traveling on a conductor, into an electromagnetic wave in free space. Antennas demonstrate a property known as reciprocity, which means that an antenna will maintain the same characteristics regardless if it is transmitting or receiving. Most antennas are resonant devices, which operate efficiently over a relatively narrow frequency band. An antenna must be tuned to the same frequency band of the radio system to which it is connected, otherwise the reception and the transmission will be impaired. When a signal is fed into an antenna, the antenna will emit radiation distributed in space in a certain way. A graphical representation of the relative distribution of the radiated power in space is called a radiation pattern.8 Z) m6 T b: \/ I8 J) F
1 o- e. S8 K+ }$ Q+ d6 f5 @- z
8 L) d& G3 U' A# q% _( K |
