This Getting Started guide is written for HFSS users who are using the Floquet port feature in version 11 for the first time. This guide leads you step-by-step through creating,solving, and analyzing the results of models that use a Floquet port. 1. Introduction! S* f/ g' a$ l& ~2 q9 c9 d% x% V
Floquet Ports in HFSS . . . . . . . . . . . . . . . . . . . . 1-25 S. X3 t. R$ v# @8 h5 \
2. Antenna Array* ?4 T# O, ~! ~7 I+ b0 `
Array antenna tutorial example . . . . . . . . . . . . . 2-2
/ n0 h% G; E+ p: {7 @Create the Unit Cell Model . . . . . . . . . . . . . . . . . 2-4
/ e( F$ X. }' s0 TAssign the Master and Slave Boundaries . . . . . 2-59 _7 n, n. {1 K7 _
Assign the Wave Port . . . . . . . . . . . . . . . . . . . 2-6, ?8 l. r% P% ^
Assign the Floquet Port . . . . . . . . . . . . . . . . . . . 2-89 |9 d8 h+ ^' [6 C. m
Create the Project Variables . . . . . . . . . . . . . . 2-10
) \0 i( Y( K; R- n+ A& U% G; h, sSetup the Analysis . . . . . . . . . . . . . . . . . . . . . . . 2-11: Y9 U! E' m5 {' |* t) h
Run Analysis and View Results . . . . . . . . . . . . . 2-12
( b# a. z, I$ X- B' fParametric Sweep of Scan Angle . . . . . . . . . . . 2-13# r" n2 w, t; T* C5 L
Prepare the Modes for the Parametric Sweep 2-14
; M# U3 t8 _2 [Viewing the Results of the Parametric Sweep 2-17; K" T0 v+ O# v" v M
3. Frequency Selective SuRFace Model
/ ]7 f( X9 |0 d. s5 }, PFrequency Selective Surface Example . . . . . . . 3-2
8 a7 [' H, l, u: w. n+ W1 ZCreate the Unit Cell Model . . . . . . . . . . . . . . . . . 3-4# |. w$ s M0 ?0 q! f% U! D
Create the Rhombic Object . . . . . . . . . . . . . . . 3-4
' _; R) `6 A uCreate the Aperture Object . . . . . . . . . . . . . . . 3-5
7 r; c. X. ^- zMove the Aperture to the Rhomboid . . . . . . . . 3-6
8 k& m6 {& h3 _* G; k. N5 d! v1 `Assign the Master and Slave Boundaries . . . . . 3-74 s" |& L7 {/ `3 x2 D0 ]
Assign the Perfect E Boundary . . . . . . . . . . . . 3-94 u1 M/ H+ d. g% z
Assign the Floquet Ports . . . . . . . . . . . . . . . . . 3-9! K! _1 A/ d" ~2 G: A
Setup the Analysis . . . . . . . . . . . . . . . . . . . . . . . 3-11, o" |$ n% L. y9 w
Setup the Sweep . . . . . . . . . . . . . . . . . . . . . . . . 3-12
: p' h {6 h/ U- c7 |9 h1 ?Viewing the Results . . . . . . . . . . . . . . . . . . . . . . 3-13* x) h) j7 F- P5 }1 [
4 R7 X- W h; J# ?/ p/ m1 C4 K
" I1 Y. m- k! A4 c. O& X; s8 ?% {( m |
