ERROR: Unable to issue shapes for padstack C4_5TH3_2 - layer problems
7 r; a: X8 k7 p& K, t: W- SERROR: Unable to issue shapes for padstack R0_25X1_55 - layer problems
% N' H9 J6 B+ H( h: pERROR: Unable to issue shapes for padstack R2_05X7_55 - layer problems
& M: h% d" W7 bERROR: Unable to issue shapes for padstack VIA0805_via - layer problems
1 \. J5 ?6 H* a7 i1 R3 q( UERROR: Unable to issue shapes for padstack C1_3TH0_7 - layer problems4 @) D, o$ o. M+ r( G% F9 S) D
ERROR: Unable to issue shapes for padstack C1_4TH0_89 - layer problems
* C+ H3 }7 G" Y0 HERROR: Unable to issue shapes for padstack C1_5TH1 - layer problems( x8 @: k( z- }- N4 K, q
ERROR: Unable to issue shapes for padstack R0_5_1_2 - layer problems
2 B A/ G; z; h; N# f' w' }$ ]& [" x' aERROR: Unable to issue shapes for padstack VIA045025_via - layer problems D0 B( O. X5 H0 Q3 E
ERROR: Unable to issue shapes for padstack VIA0402_via - layer problems
; `4 i% @, G( G# v/ U0 c9 tERROR: Unable to issue shapes for padstack VIA0805_via - layer problems' d" O Q9 a: O8 B$ C/ M+ O% n3 m {
ERROR: Unable to issue shapes for padstack VIA0603_via - layer problems
S3 C/ z% E5 a" D" u4 @& J1 ]9 Y0 rERROR: Unable to issue shapes for padstack VIA0704_via - layer problems/ O' c' v' ^; q9 v/ y% D' I
WARNING: Could not find placement outline for symbol 'JH_4X2_2MM' - using bounding box
; ^% w& y) K/ }& E8 JWARNING: Could not find placement outline for symbol 'USB_DX4R205JJA' - using bounding box
0 M0 \2 [* V' g. @WARNING: Could not find placement outline for symbol 'USB_DX4R205JJA' - using bounding box
) V& V2 E. h- O1 A. bWARNING: Could not find placement outline for symbol 'USB_UB1112C-4K5-4F' - using bounding box
2 N6 J1 J, b$ e! o' A+ c UWARNING: Could not find placement outline for symbol 'SWTT_ST-1114A' - using bounding box8 e# H3 J# k. k+ _! S5 f/ S! V
WARNING: Could not find placement outline for symbol 'SWTT_ST-1114A' - using bounding box7 U) V4 E- Q; ?7 [- G: T
WARNING: Could not find placement outline for symbol 'MX25L25645GM2' - using bounding box8 t9 | ]. k- E7 ? g* I* K+ C5 o
WARNING: Could not find placement outline for symbol 'JH_1X3_2P54M' - using bounding box' H2 Q/ ]- y8 W4 u3 `
WARNING: layer OUTER_LAYERS not found in layer table. Check the Allegro cross-section!
8 W- R! d7 }( K6 }& c4 Y, R; iWARNING: layer internal_pad_def not found in layer table. Check the Allegro cross-section!% m3 p% ]9 H$ u2 c- |
WARNING: layer ~TSM not found in layer table. Check the Allegro cross-section!! \" g# |) ~" X! `9 X$ ?* D* l5 G
WARNING: layer ~BSM not found in layer table. Check the Allegro cross-section!" C4 l' m2 J3 {1 b+ e% y
WARNING: layer ~TPM not found in layer table. Check the Allegro cross-section!
: i; r1 T7 U$ ~1 X: j' NWARNING: layer ~BPM not found in layer table. Check the Allegro cross-section!
3 S, m* P& W* P8 [; t5 ^% V" r% wWARNING: layer ~TFM not found in layer table. Check the Allegro cross-section!" d+ M: X2 d9 O. G
WARNING: layer ~BFM not found in layer table. Check the Allegro cross-section!- h# F; U: }+ u1 L$ c
WARNING: layer ~ALV not found in layer table. Check the Allegro cross-section! |
