查看: 3434|回复: 0
请教一个skill问题,感谢。(已解决)
发表于 2018-9-1 20:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人想做一个sikll 检查花焊盘线宽的skill,但是通过如下代码,无法获得花焊盘上的 themal reliefs,请教原因,
axlCmdRegister("test",'test)
defun(test ()
        axlShapeDynamicUpdate(nil nil)
        axlClearSelSet()
        axlSetFindFilter(?enabled list("noall" "DYNTHEMALS") ?onButtons list("ALL"))
        axlAddSelectBox(list(30:30 3200:3600))
        println(length(axlGetSelSet()))   ;返回的数量为 0
        axlShowObject(axlGetSelSet())
官方文档上关于 axlSetFindFilter 的选项 说明如下,不知道位置我的代码不起作用
"DYNTHEMALS" Enable selection of themal reliefs generated by dynamic shapes.
                       Only applicable to ?enabled. By default, you should not select
                       these if you plan on modifying the objects since the dynamic
                       shape will just re-generate them. You should only access them
                       for read-only purposes.
GMT+8, 2025-9-10 18:59 , Processed in 0.109375 second(s), 24 queries , Gzip On.
