贴片三极管上的印字与真实名称的对照表
, ]# Z, m2 c: w8 }1 q1 Y4 a7 M2 V4 P4 D' n; h( ~9 \3 [
印字 器件 厂商 类型 封装 器件用途及参数
) C% ^ I# a2 Z; K1 l-28 PDTA114WU Phi N SOT323 pnp dtr9 w9 z! o& ^$ ~1 u3 }6 B" ^, C9 S' F
-24 PDTC114TU Phi N SOT323 npn dtr R1 10k
6 r$ s \* A4 J! G0 b3 u-23 PDTA114TU Phi N SOT323 pnp dtr R1 10k 9 R' e7 q7 n+ D7 b2 @4 o
-20 PDTC114WU Phi N SOT323 npn dtr
* c) Y3 N6 U" f( b5 v-6 PMSS3906 Phi N SOT323 2N3906 G1 H8 a. d. G
-4 PMSS3904 Phi N SOT323 2N3904
' k' P% \4 J* w6 M1 y0 2SC3603 Nec CX SOT173 Npn RF fT 7GHz
3 Y9 \; n, ?% j1 @, _! A+ m) B" Y1 Gali-1 MC AZ SOT89 DC-8GHz MMIC amp 12dB gain
5 {& N9 j; d Y3 l1 2SC3587 Nec CX - npn RF fT10GHz' D! s8 r2 H& u/ W
1 BA277 Phi I SOD523 VHF Tuner band switch diode3 ^& i% C3 ^0 `6 n3 d
2 BST82 Phi M - n-ch mosfet 80V 175mA
8 i; N: H4 d! V7 P$ y% P5 Q2 MRF5711L Mot X SOT143 npn RF MRF571
" w6 j1 I/ {0 b; Z2 DTCC114T Roh N - 50V 100mA npn sw + 10k base res 1 q; y7 w/ L6 P) I( H2 E
2 Gali-2 MC AZ SOT89 DC-8GHz MMIC amp 16dB gain
& z M* l) \4 h3 |- ]0 k4 i+ `0 R7 G2 BAT62-02W Sie I SCD80 BAT16 schottky diode
/ v1 u: ]. F8 C% e2 2SC3604 Nec CX - npn RF fT8GHz [email=12dB@2GHz]12dB@2GHz[/email]
: h8 {: C6 D3 Q6 ]# U: u% n( ]2 s7 _3 Gali-3 MC AZ SOT89 DC-3GHz MMIC amp 22dB gain J; S: O" l! q H3 ?
3 DTC143TE Roh N EMT3 npn dtr R1 4k7 50V 100mA
- { R5 K: ^6 G0 B- [3 DTC143TUA Roh N SC70 npn dtr R1 4k7 50V 100mA
) H% Z+ _- T8 m8 h/ ~" C# s3 DTC143TKA Roh N SC59 npn dtr R1 4k7 50V 100mA
9 Z# Q6 D( q) ?5 L3 BAT60A Sie I SOD323 10V 3A sw schottky+ W/ U/ j8 D& v1 m' Y
3 BAT62-02W Sie I SCD80 -
$ M5 a& t' P: d0 z9 o. {4 DTC114TCA Roh N SOT23 npn dtr R1 10k 50V 100mA
# W/ y% X7 r& b' N1 \4 DTC114TE Roh N EMT3 npn dtr R1 10k 50V 100mA % a2 O( K0 p2 R( F
4 DTC114TUA Roh N SC70 npn dtr R1 10k 50V 100mA , F$ H l: l" u" O5 ?8 l
4 DTC114TKA Roh N SC59 npn dtr R1 10k 50V 100mA # r' a) I. e+ H9 v
4 MRF5211L Mot X SOT143 pnp RF MRF521
3 f' B) F( d( E4 Gali-4 MC AZ SOT89 DC-4GHz MMIC amp 17.5 dBm * i* Q4 q+ |$ m( l% p( _
4 BB664 Sie I SCD80 Varicap 42-2.5pF. E& c! l# u0 L4 X8 {9 b" j4 U
5 SSTPAD5 Sil J - PAD-5 5pA leakage diode
. g N0 x, ?* ]6 l" o3 R2 H5 Gali-4 MC AZ SOT89 DC-4GHz MMIC amp 18 dBm o/p9 ~+ a: E8 D/ n9 ]% o& H1 Y
5 DTC124TE Roh N EMT3 npn dtr R1 22k 50V 100mA 4 y2 {! T# Z% S5 U" g1 t: p: Z3 a
5 DTC124TUA Roh N SC70 npn dtr R1 22k 50V 100mA ; n ?+ h; d- _. ?4 H
5 DTC124TKA Roh N SC59 npn dtr R1 22k 50V 100mA # w& N3 x5 Y5 b( |; v+ } D
6 Gali-6 MC AZ SOT89 DC-4GHz MMIC amp 115 dBm o/p! o/ c4 U4 i0 X- E
6 DTC144TE Roh N EMT3 npn dtr R1 47k 50V 100mA
8 v( U( H9 \' _4 j/ y6 DTC144TUA Roh N SC70 npn dtr R1 47k 50V 100mA 1 E0 p8 D+ h2 @% u; w \7 h
6 DTC144TKA Roh N SC59 npn dtr R1 47k 50V 100mA
! G7 t( { G2 i& e; ^9 DTC115TUA Roh N SC70 npn dtr R2 100k 50V 100mA
e% m+ a' C6 b2 O" K9 DTC115TKA Roh N SC59 npn dtr R2 100k 50V 100mA
9 Y0 }& K& v$ ^3 G: [0 t9 BC849 Mot N SOT23 BC 549B
5 P7 y& P$ l1 `5 j8 V2 [8 n0 t10 SSTPAD10 Sil J - PAD-10 10pA leakage diode
+ d# O. F7 @" f- g6 w10 MRF9411L Mot X SOT143 npn Rf 8GHz MRF941; o4 z8 g8 f# P4 R4 a
11 SO2369R SGS R SOT23R 2N2369
" i8 r, n5 @6 N% r11 MRF9511L Mot X SOT143 npn RF 8GHz MRF9517 d8 W/ y! h" K, }+ X2 K& n( H
11 MUN5311DW1 Mot DP SOT363 npn/pnp dtr 10k+10k6 \5 T; O* A2 K6 R
11 PDTA114EU Phi N SOT416 pnp dtr/ h! M: r! G& V$ Y7 k
12 MUN5312DW1 Mot DP SOT363 npn/pnp dtr 22k+22k
7 |- j: O1 b, L6 j0 {9 Z! [12 DTA123EUA Rho N SC70 pnp dtr 2k2+2k2 50V 100ma( e' s+ b; n: T) E2 T& h0 ]5 Z5 N
12 DTA123EKA Rho N SC59 pnp dtr 2k2+2k2 res 50V 100ma
! N: W9 @) }' _5 d7 p& u4 o; c+ t13 DTA143EUA Rho N SC70 pnp dtr 4k7+4k7 50V 100ma0 g& o5 S7 a4 H! T
13 DTA143EKA Rho N SC59 pnp dtr 4k7+4k7 50V 100ma4 D( o( A. `9 c/ d+ A
13 DTA143ECA Rho N SOT23 pnp dtr 4k7+4k7 50V 100ma
" x( f) j4 n; Q0 H13 MA4CS103A M/A C SOT23 Schottky RF 20V 100mA
4 T) s3 _: p; K0 S9 M2 a% n13 MUN5313DW1 Mot DP SOT363 npn/pnp dtr 47k+47k9 `1 R5 x( _3 |
14 BAT114-099R Sie DQ - Quad Schottky crossover ring: f& S9 K- F: p' |2 T
14 DTA114EUA Roh N SC70 pnp dtr 10k + 10k9 t$ }% |& r+ A% D' Z
14 DTA114EKA Roh N SC59 pnp dtr 10k + 10k
- e; L. P( C; b: q' ?, m14 MUN5314DW1 Mot DP SOT363 npn/pnp dtr 10k R18 y5 d3 p v @0 [& A$ O
14 DTA114ECA Roh N SOT23 pnp dtr 10k + 10k
( u/ Q" |. P' T7 ~, s15 DTA124EUA Roh N SC70 pnp dtr 30V 50mA 22k+22k
, j# b, v- i; ~* c% w P15 DTA124EKA Roh N SC59 pnp dtr 30V 50mA 22k+22k
; _* _. ^2 O) |3 M; U15 DTA124ECA Roh N SOT23 pnp dtr 30V 50mA 22k+22k6 \6 h- O2 i$ h& w n' r: F
15 MUN5315DW1 Mot DP SOT363 npn/pnp dtr 10k R1 E- _8 r1 D/ N9 v& d" `
15 MMBT3960 Mot N - 2N3960
' X0 T$ u6 ]1 i B: w16 MUN5316DW1 Mot DP SOT363 npn/pnp dtr 4k7 R1
) y* o( A& r3 d+ X1 J16 DTA144EUA Roh N SC70 pnp dtr 30V 50mA 47k+47k
( c+ ?0 p( Z) J9 C/ Q16 DTA144EKA Roh N SC59 pnp dtr 30V 50mA 47k+47k
. B# M1 Z# ^2 @& `. B7 J18 BFP181T Tfk X - npn Rf fT 7.8GHz 10V 20mA
b% e g/ M6 D# N18 PDTC143ZK Phi N SOT346 npn dtr 4k7+47k/ @1 D) ?- N. O* u
19 PDTA143ZK Phi N SOT346 pnp dtr 4k7+47k
. U7 L' Z, O2 O- [4 b! F6 A/ s7 z19 DTA115EUA Rho N SC70 pnp dtr 100k+100k 50V 100ma) @5 d3 D R" _3 ]# ~2 U- [
19 DTA115EKA Rho N SC59 pnp dtr 100k+100k 50V 100ma! S: A+ a0 \: H# M' [3 {2 \7 [
20 SSTPAD20 Sil J - PAD-20 20pA leakage diode
' d' V; f) {$ ]; j9 ]20 MRF5811 Mot X SOT143 npn Rf fT 5GHz 0.2A: S, T% r3 |1 ], ?2 u1 f& e% E
21 Gali-21 MC AZ SOT89 DC-8GHz MMIC amp 14 dB gain
) r, u8 Q. k I22 MMBT4209 Nat N SOT23 pnp sw 850MHz 2N4209
) U9 w8 e: `" E: o22 DTC123EUA Rho N SC70 npn dtr 2k2+2k2 50V 100ma
. E, x3 I8 J0 w' [: c22 DTC123EKA Rho N SC59 npn dtr 2k2+2k2 50V 100ma
F' r& i: Z2 a5 I23 MMBT3646 Nat N SOT23 npn sw 350MHz 2N3646: [& N$ `0 f" C; t( B
23 DTC143EUA Roh N SC70 pnp dtr 50V 100mA 4k7+ 4k7+ q, f5 j* A ^4 g) @
23 DTC143EKA Roh N SC59 pnp dtr 50V 100mA 4k7+ 4k7
7 ?( \9 X5 F: ?24 MMBD2101 Nat C SOT23 Si diode 100V 200mA
: d1 d0 n6 X+ c7 ?4 p# C24 DTC114ECA Roh N SOT23 npn dtr 50V 100mA 10k + 10k) ^3 n( A2 g4 \2 U
24 DTC114EUA Roh N SC70 npn dtr 50V 100mA 10k + 10k7 i- y, T- d1 E) }0 ?
24 DTC114EKA Roh N SC59 npn dtr 50V 100mA 10k + 10k% a& V2 [* W; ]1 q
24 2SC5006 Nec N - npn RF fT 4.5GHz @3V 7mA
# T7 q9 M: t( T9 X( T25 MMBD2102 Nat K SOT23 Si diode 100V 200mA; Q2 T2 ^3 E0 v% M9 J: L/ o8 G+ j
25 DTC124ECA Roh N SOT23 npn dtr 50V 100mA 22k + 22k
, j }6 o$ }+ _8 S. p25 DTC124EKA Roh N SC59 npn dtr 50V 100mA 22k + 22k
& w8 X1 I$ j* H* @# Y$ N25 DTC124EUA Roh N SC70 npn dtr 50V 100mA 22k + 22k8 Y7 ^8 v. W. A6 b8 f/ f; i5 A
26 MMBD2103 Nat D SOT23 dual MMBD1201
/ C; y4 n2 t' e' t' {26 DTC144EKA Roh N SC59 npn dtr 50V 30mA 47k + 47k9 ]: ^( [$ Y7 Y& h s: H1 L
26 DTC144EUA Roh N SC70 npn dtr 50V 30mA 47k + 47k2 D s% ]. I% k( S8 y) W$ {- |. Z
27 MMBD2104 Nat B SOT23 dual cc MMBD1201: h2 J% @; `" \0 ^
28 BFP280T Tfk W - npn RF fT 7GHz 8V 10mA9 G. O! N# r: k+ r# ?0 ~' d5 c
28 MMBD2105 Nat A SOT23 dual ca MMBD1201# `/ S0 t0 \9 J$ |! }7 R
29 MMBD1401 Nat C SOT23 Si diode 200V 100mA
% I9 {: J( W& H8 f7 G3 m29 DTC115EE Roh N EMT3 npn dtr 100k +100k 50V 20mA
, _# |* v1 ^0 }/ m1 U29 DTC115EUA Roh N SC70 npn dtr 100k +100k 50V 20mA
+ k$ G1 H4 H" Z" a! M) j7 A9 E29 DTC115EKA Roh N SC59 npn dtr 100k +100k 50V 20mA
$ x. F: l/ ]$ \9 V }' s# I0 f30 MUN5330DW1 Mot DP SOT363 npn/pnp dtr 1k0+1k0
+ c3 i: f+ b( d) Y6 N* `31 MUN5331DW1 Mot DP SOT363 npn/pnp dtr 2k2+2k2
7 f+ [0 D/ H* U: z* d+ n( L- s31 MMBD1402 Nat K SOT23 Si diode 200V 100mA
$ |+ i$ @5 g1 a7 h! ?32 MUN5332DW1 Mot DP SOT363 npn/pnp dtr 4k7+4k7
7 h6 x: O W* Y! F: W* h32 MMBD1403 Nat D SOT23 dual Si diode 200V 100mA
5 A# w4 v/ @) n, M- L& \4 H. U32 BAT32 Sie CS - 18GHz zero-bias schottky: p* ~& b; ^' _' t. d% j7 N
33 MUN5333DW1 Mot DP SOT363 npn/pnp dtr 4k7+47k
! f m+ k1 I$ j6 n7 [# V8 u33 DTA143XE Roh N EMT3 pnp dtr 4k7+10k 50V 100mA
) j% z9 T% Y7 E9 f1 g+ ~33 DTA143XUA Roh N SC70 pnp sw 4k7+10k bias res 50V 100mA
" E6 M$ a7 D( J: p( }% d* b8 l0 X33 DTA143XKA Roh N SC59 pnp sw 4k7+10k bias res 50V 100mA
- ~; U2 I' n* j; j8 W7 E33 MMBD1404 Nat B SOT23 dual cc Si diode 200V 100mA
3 o( ~. l4 p1 |5 `9 g; Q33 Gali-33 MC AZ SOT89 DC-4GHz MMIC amp 19dB gain3 z- `! {: z# y& f
34 MUN5334DW1 Mot DP SOT363 npn/pnp dtr 22k+47k
9 A- @0 C- |; M& ]34 MMBD1405 Nat A SOT23 dual ca Si diode 200V 100mA3 H* G$ L: f0 Z8 o
34 2SC5007 Nec N - npn RF fT 7GHz @3V 7mA
# C, M9 o" _6 |( r8 W35 MUN5335DW1 Mot DP SOT363 npn/pnp dtr 2k2+47k
8 ^. L9 U3 I/ u' F35 DTA124XE Roh N EMT3 pnp dtr 22k+47k 50V 50mA
- n! a1 `4 C q, v7 ]35 DTA124XUA Roh N SC70 pnp dtr 22k+47k 50V 50mA
% n$ F `! B6 U/ N% v- I2 ], @35 DTA124XKA Roh N SC59 pnp dtr 22k+47k 50V 50mA/ Q: T Q1 ~* v9 N
41 BAT14-115S Sie CS SOT173 40GHz schottky diode
3 F. U ^! P: G5 }$ R) O41 BAT14-115R Sie CZ SOT173 40GHz schottky ring quad- x: A8 I3 [* }3 G+ P* K
42 BAT14-025S Sie CS SOT173 4GHz schottky diode
& P# _$ n' T( V4 C42 BAT14-025R Sie CZ SOT173 4GHz schottky ring quad
7 ]- _ G4 K) E9 j% Y, E1 o% y3 @* Z43 BAS40 Sie C SOT23 schottky diode 40V 100mA' ^7 J; I9 L- N& ]
43 DTA143EE Mot N SOT416 pnp dtr 4k7 + 4k7
V/ H0 h8 G) ?6 w) f43 DTC143XE Roh N EMT3 npn dtr 4k7+10k 50V 100mA r( v; Y u2 ~3 F( D$ ]8 `1 ~+ ?6 \
43 DTC143XUA Roh N SC70 npn dtr 4k7+10k 50V 100mA( @6 e$ z0 Z& ^0 t
43 DTC143XKA Roh N SC59 npn dtr 4k7+10k 50V 100mA
2 a& j) A) N& p# G9 o$ s) ^44 BAS40-04 Sie D SOT23 dual series BAS40# N6 a* y! Q5 T0 M
44 BAS40-04W Sie D SOT323 dual series BAS40
% M* f& W, Z" d, x2 V# {4 p4 S44 2SC5009 Nec N - npn RF fT 12GHz @3V 5mA& p/ z, Y; }4 w) G5 {' V' u
45 BAS40-05 Sie A SOT23 dual ca BAS40
/ L6 S9 i" j1 ?; r" `. I45 BAS40-05W Sie A SOT323 dual ca BAS40
. z# ]2 p5 B, w% F2 O45 BAT14-055S Sie CS SOT173 8GHz schottky diode
/ r, w2 [ m3 s* o, O45 BAT14-055R Sie CZ SOT173 8GHz schottky ring quad& h' y2 G# N, s v q R
45 DTC124XE Roh N EMT3 npn dtr 22k+47k 50V 50mA' e' w' p; ?& \1 v% e7 S, P
45 DTC124XUA Roh N SC70 npn dtr 22k+47k 50V 50mA
6 }* Q9 y" W9 P+ G# c" i( @6 c45 DTC124XKA Roh N SC59 npn dtr 22k+47k 50V 50mA$ ^. a+ \& m9 Q% W) w- v
46 BAS40-06 Sie B SOT23 dual cc BAS40
& y$ C6 \) M c2 y4 R4 M' r46 BAS40-06W Sie B SOT323 dual cc BAS40
/ d9 C9 O% h9 q- q46 MBT3946DW Mot DP - 2N3904/2N3906 pair% O e9 g9 k8 _) w7 N
47 BAS40-07 Sie S SOT143 dual BAS40* R9 m0 G: s9 h+ D6 I
47 BAS40-07W Sie S SOT343 dual BAS40/ H/ L/ {3 J0 m& K
49 BAT14-095S Sie CS SOT173 18GHz shottky diode) q( M5 d1 c( X; z
49 BAT14-095R Sie CZ SOT173 18GHz schottky ring quad
& B3 h4 g& i' ^; |. k50 SSTPAD50 Sil J - PAD-50 50pA leakage diode 4 m( E! C- K7 @) V, q t& ?/ @
51 BAT15-115S Sie CS SOT173 40GHz schottky diode* n5 b8 E6 `1 L" c, C2 T
51 BAT15-115R Sie CZ SOT173 40GHz schottky ring quad4 @/ p f; \: a; r4 F) H) V
52 BAT15-025S Sie CS SOT173 4GHz schottky diode
0 t- y' E! x) s* a7 q52 BAT15-025R Sie CZ SOT173 4GHz schottky ring quad
- y" E; H; A7 [* [2 a% c* [52 Gali-52 MC AZ SOT89 DC-2GHz MMIC amp 23 dB gain2 Y. W& g9 t9 I+ S; ^1 \
52 BAS52-02V Inf I SC79 Schottky diode 45V 750mA2 G: B: d; X1 L
52 DTA123YE Roh N EMT3 pnp dtr 2k2 +10k 50V 100mA6 T4 p) y7 C0 Y5 `- k% M, t# a
52 DTA123YUA Roh N SC70 pnp dtr 2k2 +10k 50V 100mA8 v. B$ \9 J5 j7 h+ t: c
52 DTA123YKA Roh N SC59 pnp dtr 2k2 +10k 50V 100mA
; n; e ]& b2 F% c w54 DTA114YE Roh N EMT3 pnp dtr 10k + 47k 50V 100mA9 S/ v. e% L4 F% S
54 DTA114YUA Roh N SC70 pnp dtr 10k + 47k 50V 100mA/ v1 @' `& J r# }4 z. g P
54 DTA114YKA Roh N SC59 pnp dtr 10k + 47k 50V 100mA/ w; V: U- m8 R; J: g" w$ G& m$ @9 {: ^4 Q. K
55 BAT15-055S Sie CS SOT173 8GHz schottky diode" g: W& l+ [$ L8 p3 V
55 BAT15-055R Sie CZ SOT173 8GHz schottky ring quad
+ S; D/ W9 ? |- r0 F& T55 Gali-55 MC AZ SOT89 DC-4GHz MMIC amp 21 dB gain& t8 w# {6 A8 H1 E
57 BFQ57 Sie CX SOT173 npn 6.5GHz 16V/35mA+ R" j$ |4 x- {4 z% S5 W
58 BFQ58 Sie CX SOT173 npn 6.5GHz 16V/30mA
/ C7 y! d3 w; Q6 \ s59 BAT15-095S Sie CS SOT173 18GHz schottky diode
/ ?0 E& ` z! Q, O' A59 BAT15-095R Sie CZ SOT173 18GHz schottky ring quad
& }* o& \& p0 i/ N62 DTC123YE Roh N EMT3 npn dtr 2k2 +10k 50V 100mA
1 E1 P1 C' K$ g. T62 DTC123YUA Roh N SC70 npn dtr 2k2 +10k 50V 100mA
3 ~/ c0 X' ]3 a* z8 z1 F62 DTC123YKA Roh N SC59 npn dtr 2k2 +10k 50V 100mA+ S- p- q3 S' w
64 DTC114YE Roh N EMT3 npn dtr 10k + 47k 50V 100mA% m7 I" ~ F: G* p9 K
64 DTC114YUA Roh N SC70 npn dtr 10k + 47k 50V 100mA' ]/ I. ~$ c: ^% N, b
64 DTC114YKA Roh N SC59 npn dtr 10k + 47k 50V 100mA( y m1 I, K" S: k/ Z
67 BFP67 Tfk X - npn Rf fT 7.5GHz 10V 50mA2 l- I/ M7 X/ ^0 L0 x
69 DTA114YE Mot N SOT416 pnp dtr 10k +47k
/ H3 D6 m+ G9 d# z3 E1 ?, w) z% f69 DTC115EE Roh N EMT3 npn dtr 100k+100k 50V 20mA+ H4 }" C' z4 I, `- m
69 DTC115EUA Roh N SC70 npn dtr 100k+100k 50V 20mA
+ s; t7 a4 m$ u: T3 f2 `) M69 DTC115EKA Roh N SC59 npn dtr 100k+100k 50V 20mA5 ^ P& f! k) O
70 BFQ70 Sie CX SOT173 npn fT 5.2GHz 15V 35mA
* v& U3 n! _7 |0 Y( `5 c9 J0 j71 BFQ71 Sie CX SOT173 npn fT 5.2GHz 15V 30mA7 g- N6 I, L: P
72 BFQ72 Sie CX SOT173 npn fT 5.1GHz 15V 50mA( o) ~! w$ u; j9 a* \& Z* U
72 2N7002 Sil M SOT23 n-ch mosfet 60V 170mA% L% P; ]+ ^( R5 }' U0 S! X* y! V4 D
73 MA4CS101A M/A C SOT23 schottky diode 70V 50mA
/ N( h1 C# m8 I9 o73 BFQ73 Sie CX SOT173 npn fT 4.9GHz 15V 75mA, ~3 V8 c. r3 j' p( k% x$ w9 V% e& E. B1 ~
73 2SC5004 Nec N - npn RF 5GHz @5V 5mA4 p- J m! p7 d2 N0 `
74 BFQ74 Sie CX SOT173 npn fT 6GHz 16V 35mA# L6 B9 q& v8 k y' e, ]: |7 u1 C
74 MA4CS101B M/A D SOT23 dual series MA4CS101A (73)2 c$ {* A0 @6 s8 m, o9 [9 E1 A
74 DTA114WE Rho N EMT3 pnp dtr 10k + 4k7 50V 100mA
, }, G, t! Y& e$ p1 |) ~4 d$ `74 DTA114WUA Rho N SC70 pnp dtr 10k + 4k7 50V 100mA" O; s J2 D7 O
74 DTA114WKA Rho N SC59 pnp dtr 10k + 4k7 50V 100mA
; d% @* {& d. a L/ C74 2SC5005 Nec N - npn RF 5.5GHz @5V 5mA) Y4 g. ]9 C a; x) G- M, l
75 BFQ75 Sie CX SOT173 pnp fT 5GHz 12V 50mA
/ w% Q, }5 D7 o, d1 I* c; }5 i- I76 BFQ76 Sie CX SOT173 pnp fT 5GHz 15V 30mA. ~3 o2 J8 f* i3 R& H8 C
76 DTA144WE Rho N EMT3 pnp dtr 47k + 22k 50V 30mA
) P2 _8 ~ f- j3 W% w! l8 s6 l76 DTA144WUA Rho N SC70 pnp dtr 47k + 22k 50V 30mA
9 |# z, h' @; s3 S( ~76 DTA144WKA Rho N SC59 pnp dtr 47k + 22k 50V 30mA9 k3 A# T" a% M4 b1 T7 J: f3 o/ c
77 MA4CS101E M/A S SOT143 dual MA4CS101A (73)
7 ?" E) Z+ a. E5 }" m77 BFQ77 Sie CX SOT173 npn fT 7GHz 15V 20mA) J! h6 s( @6 r& K- ~" W( O
78 MMBT4258 Nat N SOT23 pnp sw fT 700MHz" Q7 D% _5 t: A+ a; D" _3 T5 n
81 SO2369AR SGS R SOT23R 2N2369A ' f' g4 z& x3 |
81 ZMV831BV2 Zet I SOD523 28V hyperabrupt varicap 15pF @2V
; A1 @4 G# F6 l" ~82 2SC5009 Nec N - npn RF fT 12GHz @ 3V 5mA
3 A# a, d4 q+ M; z82 ZMV832BV2 Zet I SOD523 28V hyperabrupt varicap 22pF @2V9 w, b8 m' ?# m6 ]7 w' w+ {* {
83 MMBT4400 Nat N - npn 2N4400
1 T$ ?6 l7 E H" o1 X+ X83 2SC5010 Nec N - npn RF fT 12GHz 3V 10mA
* v D2 p3 k8 Q2 o; ~# {83 MA4CS102A M/A C SOT23 schottky diode 8V 30mA$ l9 U2 [6 A3 P% {1 ^$ p
84 MA4CS102B M/A D SOT23 dual ser schottky diode 8V 30mA
. m% W4 F1 o* l% n84 DTC114WE Rho N EMT3 npn dtr 10k + 4k7 50V 100mA
0 M7 Q, F3 C3 j9 h84 DTC114WUA Rho N SC70 npn dtr 10k + 4k7 50V 100mA
$ q5 L9 ~ q L: o84 DTC114WKA Rho N SC59 npn dtr 10k + 4k7 50V 100mA* |; M* Z4 m' e- G
85 MMBD1701 Nat C - Fast Si diode 30V 50mA! D: H# `4 q6 J
85 MA4CS102A M/A B SOT23 dual cc schottky diode 8V 30mA- I$ T) h" i" c7 I6 v' |) L
86 MMBD1702 Nat K - Fast Si diode 30V 50mA( s3 X% J# @- p5 i5 h: `/ T' a
86 DTC144WE Rho N EMT3 npn dtr 47k + 22k 50V 30mA
$ L8 `0 t4 R6 e' }/ R/ x4 [5 b6 L86 DTC144WUA Rho N SC70 npn dtr 47k + 22k 50V 30mA% Y X* i' z; J! ^6 O
86 DTC144WKA Rho N SC59 npn dtr 47k + 22k 50V 30mA. x+ Y( K( v0 S3 ?
87 MMBD1703 Nat D - dual ser MMBD1701
: [2 s% [) f# ~87 MA4CS102A M/A S SOT143 dual schottky diode 8V 30mA! O3 W5 h1 D) h+ L
88 MMBD1704 Nat B - dual cc MMBD1701
$ c7 I8 Q3 K/ X! v89 MMBD1705 Nat A - dual ca MMBD17019 n; ?* Q& a9 j6 I2 F2 J3 N- c
91 ZV931V2 Zet I SOD523 4-13.5pF hyperabrupt varicap3 b. D a9 ^4 x; ~; s1 P6 G$ A( d
91 DTA113TKA Roh N SC59 pnp dtr R11k0 50V 100mA
# h5 {% J$ L' P; n1 f- D0 l92 ZV932V2 Zet I SOD523 5.5-17pF hyperabrupt varicap
1 k- r S" e: E( v% F: D8 B93 ZV933V2 Zet I SOD523 12-42pF hyperabrupt varicap
2 d4 e* R7 @7 @93 DTA143TE Roh N EMT3 pnp dtr R1 4k7 50V 100mA3 D! D9 U! p* q! T4 s m
93 DTA143TUA Roh N SC70 pnp dtr R1 4k7 50V 100mA, U3 H, J+ ?6 ~) O. H# |* }/ g7 j
93 DTA143TKA Roh N SC59 pnp dtr R1 4k7 50V 100mA
( O4 T* ^1 }4 Q% H# B3 d, J. \( L7 l# Q% a94 DTA114TE Roh N EMT3 pnp dtr R1 10k 50V 100mA* r, ?) {" C* {2 E, n+ u, r9 z
94 DTA114TUA Roh N SC70 pnp dtr R1 10k 50V 100mA [, S2 b6 i# R; |6 m* A
94 DTA114TKA Roh N SC59 pnp dtr R1 10k 50V 100mA
3 B7 s/ y( m% M+ w# y9 x1 k95 DTA124TE Roh N EMT3 pnp dtr R1 22k 50V 100mA7 a( I6 v l, M
95 DTA124TCA Roh N SOT23 pnp dtr R1 22k 50V 100mA- Q& b, g( A- Q, q) Q0 l
95 DTA124TKA Roh N SC59 pnp dtr R1 22k 50V 100mA% P8 K {+ L) O6 @+ O; S, `
96 DTA144TE Roh N EMT3 pnp dtr R1 47k 50V 100mA
- I& H( v% p6 y5 _. e5 q+ b. D96 DTA144TUA Roh N SC70 pnp dtr R1 47k 50V 100mA/ x$ `8 o1 E/ T8 [
96 DTA144TKA Roh N SC59 pnp dtr R1 47k 50V 100mA
* y9 {3 a0 v9 u7 s! A6 M: T. z m1 Q' S99 DTA115TE Roh N EMT3 pnp dtr R1 100k 50V 100mA& g: J* m. v$ I
99 DTA115TUA Roh N SC70 pnp dtr R1 100k 50V 100mA
M/ ]0 ?! ^5 i4 ~5 y' G99 DTA115TKA Roh N SC59 pnp dtr R1 100k 50V 100mA( u9 H; T; ]. N! `2 w+ I p8 O
100 SSTPAD100 Sil J SOT23 PAD-100 100pA leakage diode: ~. N9 N2 ^- i% v
101 PZM10NB1 Phi C SOT346 10V 0.3W zener* `1 F7 h, A- H, X
102 PZM10NB2 Phi C SOT346 10V 0.3W zener: I! p8 v) M1 A; S; G
103 PZM10NB3 Phi C SOT346 10V 0.3W zener
2 E( k2 x) v9 T, \# B n# v111 PZM11NB1 Phi C SOT346 11V 0.3W zener
6 d$ n; H2 C) A111 DTA113ZUA Roh N SC70 pnp dtr 1k+10k 50V 100mA
( d, _: ?- o8 ~! t2 N7 S112 PZM11NB2 Phi C SOT346 11V 0.3W zener% ^' i( W" v+ X8 ~0 I. l
113 PZM11NB3 Phi C SOT346 11V 0.3W zener* g8 ^' i7 r0 V3 C+ \
113 DTA143ZUA Roh N SC70 pnp dtr 4k7+47k 50V 100mA# `) K. g4 z1 G0 ~0 l( E3 e
121 PZM12NB1 Phi C SOT346 12V 0.3W zener: w5 a1 y' Z: G( f4 i
121 DTC113ZUA Roh N SC70 npn dtr 1k+10k 50V 100mA
, a4 B Y; y2 h122 PZM12NB2 Phi C SOT346 12V 0.3W zener
. l: d( N: _2 j9 w+ x123 PZM12NB3 Phi C SOT346 12V 0.3W zener
) x4 D" W6 m, H0 D* m; ]; G" r7 W123 DTC143ZUA Roh N SC70 npn dtr 4k7+47k 50V 100mA; N+ {, y: _' g
131 PZM13NB1 Phi C SOT346 13V 0.3W zener
% o% I5 a7 H; }3 h8 q132 PZM13NB2 Phi C SOT346 13V 0.3W zener$ R {, K/ j/ S* l# s
132 DTA123JUA Roh N SC70 pnp dtr 2k2+47k 50V 100mA# q. ]- b; b, t, J+ N# d+ G
133 PZM13NB3 Phi C SOT346 13V 0.3W zener
2 \+ T' f+ W7 t9 b$ _142 DTA123JUA Roh N SC70 npn dtr 2k2+47k 50V 100mA- c6 F9 J/ Y) f+ t- M) V5 E
151 PZM15NB1 Phi C SOT346 15V 0.3W zener
7 m+ ?& s5 H; j! d- v152 PZM15NB2 Phi C SOT346 15V 0.3W zener
* z. ^ N- o# G+ P4 [153 PZM15NB3 Phi C SOT346 15V 0.3W zener
8 U* t: C; U/ d. y% T ~# ]156 DTA144VUA Roh N SC70 pnp dtr 47k+10k 50V 100mA
* N ]1 ^/ v* C! G0 \161 PZM16NB1 Phi C SOT346 16V 0.3W zener
$ S V+ ~5 ~) _3 S162 PZM16NB2 Phi C SOT346 16V 0.3W zener' w6 ` V' _! E7 u
163 PZM16NB3 Phi C SOT346 16V 0.3W zener( ~# P9 q8 _6 Z0 ]+ L
166 DTC144VUA Roh N SC70 npn dtr 47k+10k 50V 100mA
, o/ }! G$ W0 u8 [; u179 FMMT5179 Zet N - 2N5179, t4 _9 q/ V& a4 l5 R) I$ Q: m( O; a
181 PZM18NB1 Phi C SOT346 18V 0.3W zener
0 b- h0 o/ y' p182 PZM18NB2 Phi C SOT346 18V 0.3W zener
8 u& w0 J! G- ?9 _+ [! L* r; |7 \183 PZM18NB3 Phi C SOT346 18V 0.3W zener
" d$ y; _8 y4 U4 _/ T200 SSTPAD200 Sil J - PAD-200 200pA leakage diode3 u. ]0 }1 d) d b
201 PZM20NB1 Phi C SOT346 20V 300mW Zener
) P6 ~# ]; k+ t+ U- E7 l202 PZM20NB2 Phi C SOT346 20V 300mW Zener( z- Q8 s7 a% ^' a
203 PZM20NB3 Phi C SOT346 20V 300mW Zener
+ s* N) \9 _; u+ }' F! W221 PZM22NB1 Phi C SOT346 22V 300mW Zener $ P3 i9 E9 P' E4 @- V9 V
222 PZM22NB2 Phi C SOT346 22V 300mW Zener
1 d: b7 L8 N4 Q9 p1 e3 ?* z223 PZM22NB3 Phi C SOT346 22V 300mW Zener' q6 R5 |0 Z3 l' K T; n
241 PZM24NB Phi C SOT346 24V 300mW Zener
5 X& d; }7 t: X0 ^6 y242 PZM24NB Phi C SOT346 24V 300mW Zener 1 I! w. P! C' d: m6 n* h6 M4 f
243 PZM20NB Phi C SOT346 24V 300mW Zener
6 p+ D$ d# O. \4 g3 x271 PZM2.7NB1 Phi C SOT346 2.7V 300mW Zener
) U8 b) a* J. X, f272 PZM2.7NB2 Phi C SOT346 2.7V 300mW Zener
3 d# f3 z6 N* x7 D9 v301 FDV301N Fch M SOT23 n-ch 'digital' fet 25V 0.22A9 W# e& Y* F9 u$ \( z
302 FDV302P Fch M SOT23 p-ch 'digital' fet 25V 0.13A
# L/ {% F( V4 X- M& J4 A& {7 w303 FDV303N Fch M SOT23 n-ch 'digital' fet 25V 0.68A
# t( G, ^+ \+ h* o3 a304 FDV304P Fch M SOT23 p-ch 'digital' fet 25V 0.46A
! g2 N0 I: k1 r9 _1 D2 p, U331 NDS331N Fch M SOT23 n-ch mosfet 1.3A 20V
0 Z) b; S6 F7 G V* M7 ^331 PZM3.3NB1 Phi C SOT346 3.3V 300mW zener
* y" f6 a8 Z0 p3 [2 g# w332 PZM3.3NB2 Phi C SOT346 3.3V 300mW zener- y, x5 b: `2 b3 K
332 NDS332N Fch M SOT23 "p-ch mosfet 0.4A, 1A pk, 20V"
9 E Y n/ T4 {: a! F. f335 NDS335N Fch M SOT23 "n-ch mosfet 70 mA, 1.7A pk, 20V"
1 B3 R+ ~$ ^2 g6 _; }; M336 NDS336N Fch M SOT23 "p-ch mosfet 0.27A, 1.2A pk, 20V"
1 @' A" L6 ]* K7 T2 t; S337 NDS337N Fch M SOT23 "n-ch mosfet 50 mA, 2.5A pk 20V"
6 E! t& l" M' x338 NDS338N Fch M SOT23 "p-ch mosfet 0.13A, 1.6Apk 20V"
( l: ^# F/ c* }0 w340 FDV340P Fch M SOT23 p-ch mosfet 20V 70 mA
5 h9 @+ i6 ?, j0 F0 p351 NDS351N Fch M SOT23 n-ch mosfet 1.1A 30V- h$ F4 W/ @( ~: I
352 NDS352N Fch M SOT23 p-ch mosfet 0.5A 20V
7 x# ]0 N7 X, G1 t! r355 NDS355N Fch M SOT23 "n-ch mosfet 0.1A, 1.6A pk 30V"
^. {0 L- P/ q( e8 s356 NDS356N Fch M SOT23 "p-ch mosfet 0.3A, 1.1A pk 20V"
~$ l6 \4 I! b3 ^" x+ y& |357 NDS357N Fch M SOT23 n-ch mosfet 2.5Apk 30V
! d1 m9 F8 {% U1 k$ Z; F5 O1 B358 NDS358N Fch M SOT23 "p-ch mosfet 0.2A, 1.6A pk 30V"8 e4 `: I2 K; b6 z( F1 v
358 FDN358N Fch M SOT23 p-ch mosfet 0.2A 1.6A pk 30V, f" c8 x1 b h( D1 F6 K# F @! q
360 FDN360P Fch M SOT23 "p-ch mosfet 80mA, 2a PK, 30V"
7 ~' C* F5 a# T) @. ]2 o" A, S, m! m361 PZM3.6NB1 Phi C SOT346 3.6V 300mW Zener
$ f8 w0 M! I b, T362 PZM3.3NB2 Phi C SOT346 3.6V 300mW Zener
2 N; N( ^ i5 z3 k) n391 PZM3.9NB1 Phi C SOT346 3.9V 300mW Zener' U, w; l# p# T
392 PZM3.9NB2 Phi C SOT346 3.9V 300mW Zener) f0 P8 `2 E( T$ x
413 FMMT413 Zet N SOT23 npn avalanche 150v 0.1A+ \/ c* g5 d2 |* a# d4 n' l
415 FMMT415 Zet N SOT23 npn avalanche 260v 0.1A
z( P, b" M. l( M( T417 FMMT417 Zet N SOT23 npn avalanche 320v 0.1A
: q0 s9 [/ [$ P8 q! ?% T% D431 PZM4.3NB1 Phi C SOT346 4.3V 0.3W zener' j. l# r0 a, Q
432 PZM4.3NB2 Phi C SOT346 4.3V 0.3W zener0 P$ p; r4 _- u; P' \+ x
433 PZM4.3NB3 Phi C SOT346 4.3V 0.3W zener
! g) A3 E- T) V! V. \% e; z449 FMMT449 Zet N SOT23 npn 50V 1A low Vce sat( S9 w7 S4 k0 w# z' \6 F& U" c1 M, S/ W
451 FMMT451 Zet N SOT23 npn 60V 1A
- Z& ], G- w/ S8 S; f$ r455 FMMT455 Zet N SOT23 NPN 140V 1A! Z. i0 ^9 \# X6 t
458 FMMT458 Zet N SOT23 npn 400V 0.4A7 F# K1 m( L2 h- a
471 PZM4.7NB1 Phi C SOT346 4.7V 0.3W zener3 a! R7 s d1 G5 N% {6 f! e7 W. ^# i P
472 PZM4.7NB2 Phi C SOT346 4.7V 0.3W zener# ~3 S, u* i& h/ P/ k
473 PZM4.7NB3 Phi C SOT346 4.7V 0.3W zener" F j' W/ N( W. l0 w
491 FMMT491 Zet N SOT23 ZTX 450/4516 ^# G" d0 {1 ~9 V
493 FMMT493 Zet N SOT23 ZTX 453
Y, f7 ]) y, L- D494 FMMT494 Zet N SOT23 npn 120V 1A + O. }3 v4 y# d2 s& G
495 FMMT495 Zet N SOT23 npn 170V 1A7 X1 l# G+ ?. n4 |
497 FMMT497 Zet N SOT23 npn 300V 0.5A
6 t3 N! ]6 C/ w- L( g500 SSTPAD500 Sil J PAD-500 500pA leakage diode
( J- |8 U$ z0 P; t8 f% }- @/ t511 PZM5.1NB1 Phi C SOT346 5.1V 0.3W zener2 ]4 @# e8 D" x- G$ k( r
512 PZM5.1NB2 Phi C SOT346 5.1V 0.3W zener
' |" O+ S3 S, H513 PZM5.1NB3 Phi C SOT346 5.1V 0.3W zener
1 z8 `( l" { Y! n558 FMMT558 Zet N SOT23 pnp 400V 0.15A# C0 h3 m# g2 k5 y0 }6 G% D
561 PZM5.1NB1 Phi C SOT346 5.6V 0.3W zener
, \" K1 T i' U562 PZM5.1NB2 Phi C SOT346 5.6V 0.3W zener# c* E- {! d/ T3 ~" N; W
563 PZM5.1NB3 Phi C SOT346 5.6V 0.3W zener
I1 a" I5 z. J, |+ B/ a589 FMMT589 Zet N SOT23 pnp 30V 1A
9 G1 y/ `' Y' B593 FMMT593 Zet N SOT23 ZTX 553( A+ b. Z3 `+ Y I: I0 r! `
605 NDS0605 Fch M SOT23 P-ch mosfet 60V 180mA9 Z2 k) a, o7 l6 q4 [
605 NDS0605 Fch M - p-ch sw mosfet 60V
5 E: x7 l) k; N9 T610 NDS0610 Fch M - p-ch sw mosfet 60V
% @8 W6 D9 I" z3 y7 x/ W' O614 FMMT614 Zet N SOT23 sw * x$ v7 M8 [8 n ~. j3 _
617 FMMT617 Zet N SOT23 npn sw 15V 3A
( ~ S5 [$ Q7 H" \7 d- h/ I Q618 FMMT618 Zet N SOT23 npn sw 20V 2.5A
4 y7 N }& w: _- p- p619 FMMT619 Zet N SOT23 npn sw 50V 2A$ r) |# J. I/ `3 \$ F1 t8 H8 F7 s
621 PZM6.2NB1 Phi C SOT346 6.2V 0.3W zener
3 X9 F% d( |( z/ v622 PZM6.2NB2 Phi C SOT346 6.2V 0.3W zener
$ r1 y4 K6 ? Y7 w, p& `, Z' z623 PZM6.2NB3 Phi C SOT346 6.2V 0.3W zener
/ q& R9 j6 a; @624 FMMT624 Zet N SOT23 -+ M. b6 L4 [: Y' S. i$ m
625 FMMT625 Zet N SOT23 - I. V. B5 P% ` {7 w, T
634 FMMT634 Zet N SOT23 100V 0.9A darlington npn
+ k; ? @0 |; Q6 L651 PZT651 Mot N SOT223 npn 60V 1A8 E8 J& z+ n: B% R! s( l8 ?1 @
681 PZM6.8NB1 Phi C SOT346 6.8V 0.3W zener
% z: {4 A0 C8 {. {682 PZM6.8NB2 Phi C SOT346 6.8V 0.3W zener
1 n, r0 u7 C9 J" }2 G Z* H683 PZM6.8NB1 Phi C SOT346 6.8V 0.3W zener p& }5 N7 z9 ~* T. A2 G
701 2N7001 Mot M SOT23 n-ch mosfet, Y& u1 J' v7 r- [5 T4 j
702 2N7002 Mot M SOT23 n-ch mosfet 60V 0.11A
9 r& U* U4 m2 ~/ M( T/ h703 2N7003 Mot M SOT23 n-ch mosfet! D( u6 s0 k! B- j
712 NDS7002A Nat M SOT23 n-ch mosfet 60V 0.28A8 C4 e8 G6 }) w+ J7 _/ X
717 FMMT717 Zet N SOT23 pnp sw 0.625W 2.5A 12V# j5 S8 s" u4 l* n
718 FMMT718 Zet N SOT23 pnp sw 0.625W 1.5A 20V
3 D" Y% v: N( t' Y720 FMMT720 Zet N SOT23 pnp sw 0.625W 1.5A
1 j! y! [, v$ ^6 F) h3 x722 FMMT722 Zet N SOT23 pnp sw+ e7 N$ M7 `. u% q3 U
723 FMMT723 Zet N SOT23 pnp sw
, l7 F9 }2 G+ N7 i7 w: M A: M730 FMMT730 Zet N SOT23 ZTX550/5515 w6 b- J+ {9 I/ S! U
751 PZM7.5NB1 Phi C SOT346 7.5V 0.3W zener
3 v8 ~0 S6 }' j; d' d752 PZM7.5NB2 Phi C SOT346 7.5V 0.3W zener; L) n$ K9 Z: [" _3 u
753 PZM7.5NB3 Phi C SOT346 7.5V 0.3W zener8 S5 t0 ~4 C% ]2 r
821 PZM8.2NB1 Phi C SOT23 8.2V 0.3W zener7 R% [" v, d K: y, M
822 PZM8.2NB2 Phi C SOT23 8.2V 0.3W zener
' t9 |* F, n* H' e% z822 S822T Tfk X - npn RF fT 5.2GHz 6V 8mA
, s! B2 N( m$ Q% Z- R# ~( ]823 PZM8.2NB3 Phi C SOT23 8.2V 0.3W zener$ ]: W" Z( Z: v, E* N. P- @$ W
852 S852T Tfk N SOT23 npn RF fT 5.2GHz 6V 8mA
& X( ~7 a; K% Q" W2 _. g# |5 R887 S887T Tfk W SOT143 n-ch dg uhf mosfet2 N* A* J# w! J
888 S888T Tfk W SOT142 n-ch dg uhf mosfet' W" g( G3 w8 N Q, u7 @/ ~
911 PZM9.1NB1 Phi C SOT346 9.1V 0.3W zener' X. O$ y* N8 i/ S; l& `" t7 a) P
912 PZM9.1NB2 Phi C SOT346 9.1V 0.3W zener' q) t1 s7 _) h& I5 e5 \9 f
913 PZM9.1NB3 Phi C SOT346 9.1V 0.3W zener! e" N7 G1 I8 K0 y9 s
05F TSDF1205R Tfk WQ - fT12GHz npn 4V 5mA # J- A7 F4 w# ]6 W& W" s
0A MUN5111DW1 Mot DO SOT363 dual pnp dtr 10k+10k
* Y4 l; O0 x8 g2 H) b( z" i7 ~0A DTC125TUA Roh N SC70 npn dtr R2 100k 50V 100mA * ^9 @" ] d9 t# {9 o. e
0A DTC125TKA Roh N SC59 npn dtr R2 100k 50V 100mA ) d! e( O1 Z6 Y2 [
0B MUN5112DW1 Mot DO SOT363 dual pnp dtr 22k+22k * d8 j/ E+ T' R
0C MUN5113DW1 Mot DO SOT363 dual pnp dtr 47k+47k
" \8 W4 ^# j0 T+ c5 Z; R3 o0D MUN5114DW1 Mot DO SOT363 dual pnp dtr 10k+47k ^) u' ~* m3 q- |& [
0E MUN5115DW1 Mot DO SOT363 dual pnp dtr R1 10k
, [2 n5 A1 ^; {) C; b0F MUN5116DW1 Mot DO SOT363 dual pnp dtr R1 4k7 7 z4 Q9 @- _; `: {# \6 S
0G MUN5130DW1 Mot DO SOT363 dual pnp dtr 1k0+1k0
f% J- z4 l3 P% ^; a4 T0H MUN5131DW1 Mot DO SOT363 dual pnp dtr 2k2+2k2 + ^8 y# N- U0 ]3 ^: \! `& p
0J MUN5132DW1 Mot DO SOT363 dual pnp dtr 4k7+4k7 % M. f8 m1 h4 c T
0K MUN5133DW1 Mot DO SOT363 dual pnp dtr 4k7+47k
8 W5 H0 A$ a9 @( Y' l7 A: J* L0L MUN5134DW1 Mot DO SOT363 dual pnp dtr 22k+47k 8 `$ s0 \4 N6 k1 T" }7 m+ o+ r
0M MUN5135DW1 Mot DO SOT363 dual pnp dtr 2k2+47k
* y( n4 C" b2 A$ }* k1 (red) BB669 Sie I SOD323 56-2.7 pF varicap
6 `$ f' K8 F) A$ @10A PZM10NB2A Phi A SOT346 dual ca 10V 0.3W zener& t3 }6 q) X9 G% k: r" R& M9 i
10V PZM10NB Phi C SOT346 10V 0.3W zener
1 X% [% F/ z' K; \10Y BZV49-C10 Phi O SOT89 10V 1W zener
; s+ ~2 Y" x1 l; c9 S# p11A PZM11NB2A Phi A SOT346 dual ca 11V 0.3W zener
8 h. N' r4 t4 K- P" h5 v0 p11A MMBD1501A Nat C SOT23 Si diode 200V 100mA
# M5 o1 ^. ]2 B( ~% a( W7 G1 Q11V PZM11NB Phi C SOT346 11V 0.3W zener; L) G j: P1 @5 P; I8 q- f8 Q* y- B
11Y BZV49-C11 Phi O SOT89 11V 1W zener
% |, b" r7 @6 w! d12A MMBD1502A Nat K SOT23 Si diode 200V 100mA% f; V, I8 K' u) S* ^% E
12A PZM12NB2A Phi A SOT346 dual ca 12V 0.3W zener0 O$ |. s6 @; n
12E ZC2812E Zet D SOT23 dual series RF schottky15V 20mA: |% n* W; b, m! N
12V PZM12NB Phi C SOT346 12V 0.3W zener
( t9 U8 a6 M* G! j* i12Y BZV49-C12 Phi O SOT89 12V 1W zener* k2 r0 g! ]$ e! }6 v
13A MMBD1503A Nat D SOT23 dual Si diode 200V 100mA
# p* @- p" i- K8 X) w13A PZM13NB2A Phi A SOT346 dual ca 13V 0.3W zener
6 w% Q5 j- E5 G4 c13E ZC2813E Zet A SOT23 dual ca RF schottky15V 20mA/ T$ ], x0 a6 ]' k) _9 l# f
13s BAS125 Sie C SOT23 Schottky sw 24V 100mA& [/ X" f% p6 } I) o7 {" ?
13s BAS125W Sie C SOT323 Schottky sw 24V 100mA
0 R; O' E' U0 ~. T13t BC846BPN Phi N SOT363 BC546B
9 F$ z8 V; }. Q13V PZM13NB Phi C SOT346 13V 0.3W zener/ v }0 Q. w3 }
13Y BZV49-C13 Phi O SOT89 13V 1W zener' D5 H, A& g: p! Y1 j
14A MMBD1504A Nat B - dual cc Si diode 200V 100mA3 J; X' h2 W5 e
14s BAS125-04 Sie D SOT23 Dual series Schottky 25V 100mA
4 {% ~$ }8 ]$ `8 ?14s BAS125-04W Sie D SOT323 Dual series Schottky 25V 100mA5 D- w5 I0 w- W1 d- j1 A; D' W
15A MMBD1505A Nat A - dual ca Si diode 200V 100mA0 T6 J/ |( t9 Z+ k. D" X. m
15A PZM15NB2A Phi A SOT346 dual ca 15V 0.3W zener1 ^; T: \' x2 t! R5 u }
15s BAS125-05 Sie B SOT23 dual cc Schottky 25V 100mA
. O1 Z H4 E7 N1 f) [% S$ u4 `- [15s BAS125-05W Sie B SOT323 dual cc Schottky 25V 100mA
; X/ G8 i! n. I15V PZM15NB Phi C SOT346 15V 0.3W zener: Z4 }6 o( J2 ^) \1 [" I
15Y BZV49-C15 Phi O SOT89 15V 1W zener
* s+ j3 Z; e0 Z$ o3 E% k16s BAS125-06 Sie A SOT23 dual ca Schottky 25V 100mA7 Z" H) n; \2 Q' l& d
16s BAS125-06W Sie A SOT323 dual ca Schottky 25V 100mA
- P# e) `" u3 j16V PZM16NB Phi C SOT346 16V 0.3W zener
9 l2 R! V& n* I2 }1 Q16Y BZV49-C16 Phi O SOT89 16V 1W zener) n. D6 z6 I* Q( J! f' v7 w
17s BAS125-07 Sie S SOT143 dual Schottky 25V 100mA6 Z' ?$ i2 c) B' _6 s4 z2 g
17s BAS125-07W Sie S SOT343 dual Schottky 25V 100mA/ _1 _0 _# ?, c; i' Y3 A
18V PZM18NB Phi C SOT346 18V 0.3W zener
# a7 Y- a0 J# A2 X# }* c18Y BZV49-C18 Phi O SOT89 18V 1W zener, w o! X0 r( ~
1A BC846A Phi N SOT23 BC546A; n; N& e ~# I, I6 F1 P% s y
1A BC846AT Phi N SOT416 BC546A$ }7 ?2 x/ ?- e V% i, C
1A FMMT3904 Zet N SOT23 2N3904
- z6 B6 y9 k( ?+ f, D9 C1A MMBT3904 Mot N SOT23 2N3904
6 v+ V% B. g, G0 U+ I, d1A IRLML2402 IR F SOT23 n-ch mosfet 20V 0.9A
& n& }+ Y. X. p2 F-1A PMST3904 Phi N SOT323 2N3904$ `5 r) `6 M* T* s0 Z8 x2 k
1A- BC846AW Phi N SOT323 BC546A
& v6 m8 z( X- B0 q; K1AM MMBT3904L Mot N SOT23 2N3904! C3 U8 ~. z; N1 K2 D3 `
1Ap BC846A Phi N SOT23 BC546A+ ~7 j% J7 Z+ _5 g8 L1 ~
1At BC846A Phi N SOT23 BC546A
" B6 x( x" p% m* Q( t- ~1At BC846AW Phi N SOT323 BC546A3 i3 q* a7 \ N. m0 w3 h
1B BC846B Phi N SOT23 BC546B
, \1 K* j$ V5 q0 g3 Y9 D1B BC846BT Phi N SOT416 BC546B
) a2 c$ [% _4 W& ^; l. B1B FMMT2222 Zet N SOT23 2N22221 c" I6 z+ i: u ]
1B MMBT2222 Mot N SOT23 2N2222
3 a2 x+ T2 p& `9 M1 Y8 [4 }1B IRLML2803 IR F SOT23 n-ch mosfet 30V 0.9A
- n9 a! M& Y/ Z' u2 c) R* W, `-1B PMST2222 Phi N SOT323 2N2222& O& k) y& X5 r% ?6 q/ t% B
1B- BC846BW Phi N SOT323 BC546B- F: S! \% ^( \3 \
1Bp BC846B Phi N SOT23 BC546B3 F4 C2 y, W# e; j5 @4 _
1Bs BC817UPN Sie N SC74 -
2 P- q' b1 S! I/ |1Bt BC846B Phi N SOT23 BC546B
1 m, M$ B, f" W1 }3 \0 Y1Bt BC846BW Phi N SOT323 BC546B5 a0 f2 v9 t( j/ t3 l, S# p& b( O
1C FMMT-A20 Zet N SOT23 MPSA20
: I2 y v q1 x# _; G1C MMBTA20L Mot N SOT23 MPS3904
! [& P& h3 p$ l6 U0 }7 P1C IRLML6302 IR F SOT23 p-ch mosfet 20V 0.6A, J9 y. h. X! _& _4 U, e4 h
1Cp BAP50-05 Phi B SOT23 dual cc GP RF pin diode9 ]3 }5 x7 `0 h" q
1Cs BC847S Sie - SOT363 BC457
2 c% V/ E' p* I$ Z; C9 @1D MMBTA42 Mot N SOT23 MPSA42 300V npn
; I2 Y5 ?" S6 ^- ]* x1D IRLML5103 IR F SOT23 p-ch mosfet 30V 0.6A) x/ Y0 l0 ~# x/ y
1D- BC846W Phi N SOT323 BC456, v; ]# l) ?& t! I
1DN 2SC4083 Roh N - npn 11V 3.2GHz TV tuners
! h4 w) S' K7 ~6 a0 S1Dp BC846 Phi N SOT23 BC456. |6 V: ^, P# }6 x
1DR MSD1328R Mot N SOT346 npn gp 25V 500mA5 F$ F; ?, H8 W
1Ds BC846U Sie N SC74 BC456
7 G: U% M' `6 ^& q1Ds BC846U Sie - SOT363 BC456
$ K7 ^! A2 M! a2 I' j1Dt BC846 Phi N SOT23 BC456$ v7 V" S, _8 `9 ?& {
1Dt BC846W Phi N SOT323 BC456; [/ F0 V7 |. q4 i
1E BC847A Phi N SOT23 BC547A0 _, }7 @* d; m% y3 t
1E BC847AT Phi N SOT416 BC547A% p7 F& p Q& @
1E FMMT-A43 Zet N - MPSA43
& \5 g# g; _* ^; t+ f1E MMBTA43 Mot N SOT23 MPSA43 200V npn/ @/ n6 F+ p% g7 V0 i$ j: j2 e
1E- BC847A Phi N SOT323 BC547A3 k) _4 ]9 s4 h5 o3 E X
1EN 2SC4084 Roh N - npn 20V 2.0GHz TV tuners' h4 C, x) S3 U" M% I
1Ep BC847A Phi N SOT23 BC547A
: E% X2 ~- \4 }$ N6 i0 w1ER BC847AR Phi R SOT23R BC547A" Q0 X1 \% C1 q5 N, n
1Es BC847A Sie N SOT23 BC457( n/ t" o1 @9 M
1Es BC847AW Sie N SOT323 BC457, J1 @* q) W! M* z! p1 k
1Et BC847A Phi N SOT23 BC547A
' \+ t5 D8 _; G% \2 l4 w5 L; U* ^1Et BC847A Phi N SOT323 BC547A
! _$ t8 x: p+ t N1F BC847B Phi N SOT23 BC547B, Y) j6 Q, v0 \0 i6 x$ ?6 A
1F BC847BT Phi N SOT416 BC547B0 o( i9 Z y& w" i
1F MMBT5550 Mot N SOT23 2N5550 140V npn$ w& u6 [5 y/ s2 A8 b0 L
1F- BC847BW Phi N SOT323 BC547B
* W: j, O5 N! E$ I+ f6 O1Fp BC847B Phi N SOT23 BC547B M* ] i+ [" |/ i4 R6 g
1FR BC847BR Phi R SOT23R BC547B
: X# O/ t; Z4 N1Fs BC847B Sie N SOT23 BC547B
+ @) d) {) ]4 H4 b0 C2 a+ ?1Fs BC847BT Sie N SC75 BC547B7 o8 m1 _1 Z! J
1Fs BC847BW Sie N SOT323 BC547B# k& [3 r' U+ b5 c1 v, h
1Ft BC847B Phi N SOT23 BC547B
" w0 Y [& f. y* N Q x0 N1Ft BC847BW Phi N SOT323 BC547B
: u* l8 Y5 {) w, t! U: x! ^1FZ FMBT5550 Zet N SOT23 2N5550 140V npn% k# K( A0 t+ q7 G5 s! J7 f
1G BC847C Phi N SOT23 BC547C
% q2 X+ h q% Z' T* h4 k% z1G BC847CT Phi N SOT416 BC547C
/ k9 K8 p7 Q7 T* D& g8 O1G FMMT-A06 Zet N SOT23 MPSA064 N0 W6 Q, b: i. [5 T: S
1G MMBTA06 Mot N SOT23 MPSA06
9 ]7 X7 m; e& A- O1 I1G- BC847CW Phi N SOT323 BC547C
: s6 L1 Q& g [2 S, e1GM MMBTA06 Mot N SOT23 MPSA06( f3 M t7 h$ N
1Gp BC847C Phi N SOT23 BC547C
2 y% x' w) v% g, A9 N$ w' D( c* b1GR BC847CR Phi R SOT23R BC547C
9 m7 i! P- @- Z. K1Gs BC847C Sie N SOT23 BC547C( r2 Z7 L4 j4 y# m5 N
1Gs BC847CW Sie N SOT323 BC547C+ w3 R0 ^+ u& q; K: K+ S, V
1Gt BC847CW Phi N SOT323 BC547C) d, I+ ?% O% D. C: U* N
1GT SOA06 SGS N SOT23 MPSA06
: N9 y! E0 J4 Z1 ]# }+ h4 w5 P1H FMMT-A05 Zet N - MPSA05
, l" }& ?: N# z. a0 P7 T1H MMBTA05 Mot N SOT23 MPSA058 [' r* ~0 O( V2 W
1H- BC847W Phi N SOT323 BC547
* O1 P# ?+ l: _1Hp BC847 Phi N SOT23 BC547
a/ c8 H: A9 m7 V/ ^# M1Ht BC847 Phi N SOT23 BC547
# u% K8 E1 N; @" m$ S1Ht BC847W Phi N SOT323 BC547
' _7 @1 k8 u7 w; o) c' _1HT SOA05 SGS N SOT23 MPSA05& J8 B* t/ D/ J- Z
1J BC848A Phi N SOT23 BC548A
1 W+ u7 d% c; T' k) r- h W5 n- D7 y1J FMMT2369 Zet N SOT23 2N2369
9 l2 G0 e, W8 d9 B1J MMBT2369 Mot N SOT23 MPS2369
% ?$ Q( v2 S" b, H8 c% s1 }1JA MMBT2369A Mot N SOT23 MPS2369A
9 N/ j" Q7 r( @5 A! `8 \6 `: Q; v1Jp BCV61A Phi VQ SOT143 npn current mirror hFe 180( J( |9 Y- o/ a4 ~0 V# z* U
1JR BC848AR Phi R SOT23R BC548A
% w' m3 m( E* j1Js BC848A Sie N SOT23 BC548A
$ |" _$ \9 G6 m0 P: \2 T1Js BC848AW Sie N SOT323 BC548A) _$ I0 Z0 S- |8 j% F @) ]
1Js BCV61A Sie VQ SOT143 npn current mirror hFe 180. ?8 Z" w& a3 q, j) H8 K
1JZ BC848A Zet N SOT23 BC548A
W) D* K8 a1 @1 s5 u1K BC848B ITT N SOT23 BC548B$ [7 L& O; I9 ` p7 M! t
1K MMBT6428 Mot N SOT23 MPSA18 50V+ d9 r* v3 N9 x; R8 X& O% d$ B
1K FMMT4400 Zet N SOT23 2N4400
8 u5 q3 \, b8 E+ V* d) z" P! K' @ m$ \1KM MMBT6428L Mot N SOT23 MPSA18 50V6 j8 f, u# x9 j% P* V
1Kp BC848B Phi N SOT23 BC548B$ T4 K3 V4 C3 G' L5 z$ S
1Kp BCV61B Phi VQ SOT143B npn current mirror hFe 290. K, B+ \# R0 F4 Z' t [
1KR BC848BR Phi R SOT23R BC548B, Z, J* d: X" z9 h1 Q
1Ks BC848B Sie N SOT23 BC548B- T) I2 m3 X( g& ]3 D. S8 |; |: O
1Ks BC848BW Sie N SOT323 BC548B
: O& {2 ] d. f, c3 O; L4 B7 w1Ks BCV61B Sie VQ SOT143B npn current mirror hFe 290
3 t7 l/ b; b7 b6 {4 U1KZ FMMT4400 Zet N SOT23 2N4400
) t7 E0 \6 m8 [3 Q v1L BC848C ITT N SOT23 BC548C
3 w1 I5 Q( C# R( }# w( x; d& [1L MMBT6429 Mot N - MPSA18 45V. m; J( p6 v5 X5 z9 y, D: }0 m
1L FMMT4401 Zet N - 2N4401" q/ q0 c5 e( a4 m/ S# {7 Y+ |3 |
1L BCV61C Sie VQ SOT143B npn current mirror hFe 520
3 X) [1 Q& K7 i- \1Lp BC848C Phi N SOT23 BC548C
- d5 I3 H C' q% ]1Lp BCV61C Phi VQ SOT143B npn current mirror hFe 520; f7 v% x" E4 n: b* ]
1LR BC848CR Phi R SOT23R BC548C
# e. V; Q8 g4 }4 `7 @" @1Ls BC848C Sie N SOT23 BC548C D6 z3 [. G# W1 U) j
1Ls BC848CW Sie N SOT323 BC548C5 h# M* f+ y# h& Q" v
1M MMBTA13 Mot N SOT23 MPSA13 darlington
' a" \3 } d8 F3 K- k' T1M FMMT-A13 Zet N SOT23 MPSA13
' h9 w9 g& r) I( ]2 j1Mp BC848 Phi N SOT23 BC548- [- C9 Q& P |/ c7 S: i' W
1Mp BCV61 Phi VQ SOT143B npn current mirror/ | c( X( r+ N# {
1N FMMT-A14 Zet N SOT23 MPSA14
4 w+ y/ P8 s0 t1 c" G1N MMBTA14 Mot N SOT23 MPSA14 darlington
5 E S/ X$ T2 Q: y7 ?! d1 p/ s/ w5 m1N5 ZTX11N15DF Zet N SOT23 npn 15V 3A low saturation V% @* X2 S! Z$ B3 g5 o5 B, m
1P FMMT2222A Zet N - 2N2222A+ p, g6 l7 W5 ^& A+ I- E3 z
1P MMBT2222A Mot N SOT23 2N2222A
) ?; ^" B) g- `8 H9 K, ?. o1P BC847PN Sie DI - pnp/npn separate pair gp AF1 J( o/ I) g" T, J
1Q MMBT5088 Mot N SOT23 MPSA18 Vce 30V
. D- R' r' I% |/ i( L5 p1R MMBT5089 Mot N SOT23 MPSA18 Vce 25V- ~3 k( y$ S( F: b6 J: I, d/ I. B" @
1S MMBT2369A Nat N SOT23 2N2369A 500MHz sw npn
( l- l) N8 [4 b7 m: Y7 W1S MSC3130 Mot H SOT346 npn RF fT 1.4GHz 10V! A; k+ V# I/ Q3 }
1T MMBT3960A Mot N - 2N3960A
2 u( o) s. t/ L8 @4 v; P1U MMBT2484L Mot N SOT23 MPSA18
6 O1 N5 Z7 }/ K4 Q% z/ l5 o1V MMBT6427 Mot H SOT23 2N6426/7 darlington npn8 i6 U0 @1 t) R" [0 s8 ]9 s6 _
1V- BF820W Phi N SOT323 npn 300V 50mA BF420" f% t% \! |3 g
1Vp BF820 Phi N SOT23 npn 300V 50mA BF4200 }% H4 q" C+ D6 w6 V- z
1Vt BF820 Phi N SOT23 npn 300V 50mA BF420
" o$ Q& V/ w$ l2 ?" R0 v2 c1Vt BF820W Phi N SOT323 npn 300V 50mA BF420, n& O! u) m: u, y
1W FMMT3903 Zet N SOT23 2N39035 I' | y( S! p
1W - BF822W Phi N SOT323 pnp 300V 50mA BF421
! R6 X# t# ]" o. O+ Z1W t BF822W Phi N SOT323 pnp 300V 50mA BF421
1 G& |2 X; V, t, ]' i$ t1Wp BF821 Phi N SOT23 pnp 300V 50mA BF421
. }7 j- a) L- ?7 \$ l! e4 Y1Wt BF821 Phi N SOT23 pnp 300V 50mA BF421
0 g" T; @5 J! a/ T" [& Z5 t3 ^$ l8 C1X MMBT930L Mot N SOT23 MPS39040 ^6 I& R6 u- E6 m' x; B9 Y
1Xp BF822 Phi N SOT23 npn 250V 50mA BF4226 D) j" s. r2 K8 }4 v% j
1Xt BF822 Phi N SOT23 npn 250V 50mA BF422$ \3 s- a! F; r1 ` g# k
1Y MMBT3903 Mot N SOT23 2N39032 g6 |- P9 T: m, b* O* V' A( j
1Yp BF823 Phi N SOT23 pnp 250V 50mA BF423( W5 q, z; {$ X) G
1Yt BF823 Phi N SOT23 pnp 250V 50mA BF423* v2 m2 I2 c6 y6 T9 h3 p9 r$ p% ]& z
1Z BAS70-06 Zet A SOT23 dual RF CA schottky diode 0 _: y v1 o/ a0 T# w: e
1Z MMBT6517 Mot N SOT23 2N6517 npn Vce 350V- R- s- L s. a! e# E' t
2 (blue) BAR64-03W Sie I SOD323 pin diode8 x0 G6 ~2 p. R8 V2 F4 c4 i: A
2 (white) BB439 Sie I SOD323 29-5 pF varicap
7 {/ b: L) h- l. a20F TSDF1220 Tfk X SOT143 fT 12GHz npn 6V 20mA8 I3 \$ y& @8 \) i, Z% \
20V PZM20NB Phi C SOT346 20V 300mW zener
$ E6 d* H1 ^) t$ |20Y BZV49-C20 Phi O SOT89 20V 1W zener
1 g+ A/ d: i# C. A" A22V PZM22NB Phi C SOT346 22V 300mW zener! h: @7 Z, K7 B- y
22Y BZV49-C22 Phi O SOT89 22V 1W zener4 M* |( R# K+ i* {
24V PZM24NB Phi C SOT346 24V 300mW Zener
6 |$ ^) m6 d8 t4 o24Y BZV49-C24 Phi O SOT89 24V 1W zener
! G# Z7 X$ i+ D8 W q$ T, [27V PZM27NB Phi C SOT346 27V 300mW Zener
! q; b% u- |% ]3 s2 R# b27Y BZV49-C27 Phi O SOT89 27V 1W zener
. b- ]! N% I- f2A MMBT3906L Mot N SOT23 2N39067 X- N# w" K6 l4 \9 i8 X' ^1 c
2A MMBT3906W Mot N SOT323 2N39068 r1 q* Q$ Z) x7 n
2A FMMT3906 Zet N SOT23 2N3906
) s8 c0 ]1 Z4 W9 e' l* `2A4 PZM2.4NB2A Phi A SOT346 dual 2.4V cc Zener; n+ [2 t) W- m2 [
2A7 PZM2.7NB2A Phi A SOT346 dual 2.7V cc Zener
+ v8 I" B6 m: F$ N* W; {3 I2B BC849B ITT N SOT23 BC549B
3 @& c0 g5 ?7 X2B FMMT2907 Zet N SOT23 2N2907
9 F5 x1 [7 q* r' G [# q3 J2B MMBT2907 Mot N SOT23 MPS2907" Y! C8 V1 A5 O9 |
2B- BC849BW Phi N SOT323 BC549B5 v' H+ n: A7 ?& o' ^
2Bp BC849B Phi N SOT23 BC549B3 r, l! \4 M- |: k% Q4 J4 }7 L
2BR BC849BR Phi R SOT23R BC549B
+ E# \; X) h, @! |- m! M+ P( w( ~2Bs BC849B Sie N SOT23 BC549B0 U% l2 E! ]! A( S% {
2Bs BC849BW Sie N SOT323 BC549B
) _: }6 G& Y- f" X& a8 q1 F' _; K2Bt BC849BW Phi N SOT323 BC549B7 A9 u+ w: G( N" @; ~
2BZ FMMT2907 Zet N SOT23 2N29076 k5 o- P1 [6 |
2C BC849C ITT N SOT23 BC549C. |& n6 H* z. l% H
2C MMBTA70 Mot N SOT23 MPSA70
; A& w4 j5 {$ H) p' L F* d( `; t2C- BC849CW Phi N SOT323 BC549C2 F2 z2 J8 N4 m0 q9 H2 `$ ~
2Cp BC849C Phi N SOT23 BC549C
% @% O: T3 l$ u1 }7 t2CR BC849CR Phi R SOT23R BC549C
" I! n5 C. C; {* P. E9 ~ R2Cs BC849C Sie N SOT23 BC549C- R$ b, H- T9 I# O6 l. J: ~
2Cs BC849CW Sie N SOT323 BC549C
! e( y: m( J, ] g" g- z2Ct BC849C Phi N SOT23 BC549C
# i( v* }2 n; S2Ct BC849CW Phi N SOT323 BC549C
- B$ ^* Z) N% O2CZ FMMTA70 Zet N SOT23 MPSA70
& ]8 C. s3 y* C) N o K2 u7 v2D MMBTA92 Mot N SOT23 MPSA92 pnp Vce 300V
+ G0 Y+ Y2 N K h ?2E MMBTA93 Mot N SOT23 MPSA93 pnp Vce 200V
$ Z0 C+ n2 g2 Z2E FMMT-A93 Zet N SOT23 MPSA933 e7 I& ?0 R; J/ P
2F BC850B ITT N SOT23 BC550B$ V' \( K$ M( e, q
2F FMMT2907A Zet N SOT23 2N2907A% e5 w. M1 D" _8 A' F: u, i. u" t
2F MMBT2907A Mot N SOT23 MPS2907A
# O8 F) B C. h3 v* j2F MMBT2907AW Mot N SOT323 MPS2907A
- s2 o+ F; G7 e, ^! V2F- BC850BW Phi N SOT323 BC550B
F. e- ~9 F" h1 T9 ^( j+ C! ?2Fp BC850B Phi N SOT23 BC550B% p3 x0 P, C2 U8 x
2FR BC850BR Phi R SOT23R BC550B
: G" X5 Q" o+ D0 C2Fs BC850B Sie N SOT23 BC550B: w. d0 Z7 F9 x
2Fs BC850BW Sie N SOT323 BC550B
4 L/ I9 n# [- @) W& T+ Y2Ft BC850B Phi N SOT23 BC550B2 l& [/ E9 b% k( b& T z+ \
2Ft BC850BW Phi N SOT323 BC550B
' R0 j0 T8 [) w2G BC850C ITT N SOT23 BC550C7 ]' z1 D$ r6 @) |# a
2G FMMT-A56 Zet N SOT23 MPSA56) g+ M" G& Z* f+ l
2G MMBTA56 Mot N SOT23 MPSA56
2 \' i9 @/ {, S E- C" p1 O$ f2G- BC850CW Phi N SOT323 BC550C/ `4 ` J: T6 ]- ?) B+ M4 N
2GM MMBTA56 Mot N SOT23 MPSA564 p& p' i$ A7 q$ L% ]
2Gp BC850C Phi N SOT23 BC550C/ s/ m# s+ G x8 e
2GR BC850CR Phi R SOT23R BC550C
% } i' d+ E+ O4 C2 C2Gs BC850C Sie N SOT23 BC550C' r* i; v2 ^8 }' ]/ F5 [
2Gt BC850C Phi N SOT323 BC550C
" m Y6 V* O4 h. d" i j2Gt BC850CW Phi N SOT323 BC550C5 y: M# U! ?0 B
2GT SOA56 SGS N SOT23 MPSA56
' K8 Z! k0 |) Y! ~& ?5 i2H FMMT-A55 Zet N SOT23 MPSA55
V( T) q# V6 F0 K$ p* p2H MMBTA55 Mot N SOT23 MPSA55
; N3 ~3 u( H* E6 f# c* [0 E, @5 C6 `2HT SOA55 SGS N SOT23 MPSA55
8 D, m! W A O& o; _: g! Q2J MMBT3640 Mot N SOT23 MPS3640 pnp sw- ~& M3 R. p, P4 K2 I
2K FMMT4402 Zet N SOT23 2N44021 N3 {5 P3 i' i. J& k
2K MMBT8598 Mot N - 2N4125 pnp 60V
5 n* R Q6 Q5 ?! ^! J2 b2L MMBT5401 Mot N SOT23 2N5401 pnp 150V
9 G- ~: m: e- ^3 N+ }; F: W2L FMMT4403 Zet N SOT23 2N4403% f" ?6 o" {! c9 N
2M FMMT5087 Zet N SOT23 2N5087
8 P' A+ Y& W3 H" E8 K9 u& G2M MMBT404 Mot N SOT23 pnp-chopper 24V 150mA1 I6 `, w0 I- u: I
2N MMBT404A Mot N SOT23 pnp-chopper 35V 150mA, s6 N: s; Y8 }, N9 t' J
2N0 ZXT11N20DF Zet N SOT23 npn 20V 2.5A low sat switch' ?0 D3 G" N% X# h {
2P FMMT2222R Zet R SOT23R 2N2222- i! e3 M3 W' B
2P MMBT5086 Mot N SOT23 2N5086
" [ D. |# e; m1 s7 P$ U: Z! V: X2Q MMBT5087 Mot N SOT23 2N5087
! C; O0 A& H* s. ]2 z% H/ x2R HSMS-8102 HP Z SOT23 10-14GHz schottky mixer pair8 m1 |! G& [ t5 h1 Y) h
2T SO4403 SGS N SOT23 2N4403) E. l# @# q7 e9 S
2T MMBT4403 Mot N SOT23 2N4403
$ ~9 Q4 h' M' I2T HT2 Zet N SOT23 pnp 80V 100mA
x6 Z* J# i, e% U- `) B2U MMBTA63 Mot N SOT23 MPSA63 darlington/ l; E9 y3 A9 I: x3 @
2V MMBTA64 Mot N SOT23 MPSA64 darlington5 [ c A: f; j
2V4 PZM2.4NB Phi C SOT346 2.4V 300mW Zener' r) y% a, N5 v: D
2V7 PZM2.7NB Phi C SOT346 2.7V 300mW Zener; p( I/ _; l# X ]
2W FMMT3905 Zet N SOT23 2N3905
$ ]/ [. R+ w5 S, l( `2W MMBT8599 Mot N - 2N4125 Vce 80V pnp
7 X( U) F0 |. o7 G' j8 j2X SO4401 SGS N SOT23 2N44017 ^4 s& W* |) e) f; }6 P0 ~) F
2X MMBT4401 Mot N SOT23 2N4401
) b" T# H7 G# G/ J6 g5 ~2Y4 BZV49-C2V4 Phi O SOT89 2.4V 1W zener
3 n$ D( [+ |3 T4 z3 @$ O2Y7 BZV49-C2V7 Phi O SOT89 2.7V 1W zener
$ f0 Z6 Y. R1 ^2Z MMBT6520 Mot N SOT23 2N6520 pnp Vce 350V% c) x) L/ W, f6 }( h! t( |
2Z BAS70-04 Zet D SOT23 dual series RF schottky 70V 15mA2 ]9 k( S" `8 ~
2Z5 BAS70-05 Zet B SOT23 dual cc RF Schottky 70V 15mA$ f/ i! |' r6 S9 ^/ P
30V PZM30NB1 Phi C SOT346 30V 300mW zener
$ ^/ z8 w; |( O* w) [9 c5 L# x& X30Y BZV49-C30 Phi O SOT89 30V 1W zener
: e8 ~# _8 W; v7 f/ U5 J7 z+ @33V PZM33NB1 Phi C SOT346 33 300mW zener
$ b: c% O; ?! g. N8 G# i( \33Y BZV49-C33 Phi O SOT89 33V 1W zener
: G0 w! y( g% U# F9 ~7 A1 h) x# ^36V PZM36NB1 Phi C SOT346 36V 300mW Zener
- d' o# q2 F. H/ q8 k; [/ c' x36Y BZV49-C36 Phi O SOT89 36V 1W zener% ?6 V; [' @$ y/ G9 t+ e! G
39V PZM39NB1 Phi C SOT346 39V 300mW Zener! E, A9 ?- l2 r0 ^+ r7 ]2 s) D
39Y BZV49-C39 Phi O SOT89 39V 1W zener( Q: G a- R* H2 {, N! V
3A BC856A ITT N SOT23 BC556A6 c# d2 g1 A1 m2 t+ z+ ]% {
3A BC856AT Phi N SOT416 BC556A b3 s! r5 x+ \, m8 N) `
3A MMBTH24 Mot N SOT23 VHF mixer npn fT 600MHz8 z* r) F( H8 ?+ E4 k5 [
3A- BC856AW Phi N SOT323 BC556A6 {/ N( e* L, C Q# v
3A0 PZM3.0NB2A Phi C SOT346 dual 3.0V Zener
5 ~/ D+ |- o# w3A3 PZM3.3NB2A Phi C SOT346 dual 3.3V Zener
4 ~; M( p: \: r8 r3A6 PZM3.6NB2A Phi C SOT346 dual 3.6V Zener
, p! W$ o* l" Z, w. v! Q3A9 PZM3.9NB2A Phi C SOT346 dual 3.9V Zener
* U0 C. F1 c( N, [% G3Ap BC856A Phi N SOT23 BC556A2 g2 u& C$ ?) M% j9 N7 n% C6 G
3AR BC856AR Phi R SOT23R BC556A
! P$ j0 g( n! U3As BC856A Sie N SOT23 BC556A
% j0 Q0 w: U! h) B3At BC856A Phi N SOT23 BC556A
' E0 Y. c, m4 P q H8 Y3 j3At BC856AW Phi N SOT323 BC556A
, W" ?: p6 g# g3B BC856B ITT N SOT23 BC556B
; c6 G! R% x2 K6 H( u/ b3B BC856BT Phi N SOT416 BC556B5 j9 w- p( y4 w8 d. B
3B FMMT918 Zet N SOT23 2N918
1 z) d( q- B* |. J$ |3B MMBT918 Mot N SOT23 2N918
( Y3 h1 T- k/ E- v$ d- \3B- BC856BW Phi N SOT323 BC556B
/ Y) ~) S5 ]) _. g) G1 ~3Bp BC856B Phi N SOT23 BC556B
7 d; K* e1 D! n& Q0 {' P+ e) i3BR BC856BR Phi R SOT23 BC556B
, {$ e' p [9 r$ \" k5 C3Bs BC856B Sie N SOT23 BC556B
) {$ {% k" _7 t3Bt BC856B Phi N SOT23 BC556B
2 D6 I( R, e* u5 W3 C) S# _3Bt BC856BW Phi N SOT323 BC556B* ?' i- B6 ], I! W
3C FMMTA20R Zet R SOT23R MPSA20
: D3 H. P! B; B6 P. K+ P3C BC857 Sie DO - pnp separate pair gp AF
2 \6 o: j- `6 S3 H3D BC856 Phi N SOT23 BC556 hfe 75 min
$ B+ J' f ^6 j' `' p! e3D MMBTH81L Mot N SOT23 UHF pnp fT 600MHz
8 e" K# z }2 X8 c- ?3D BC856S Sie DO - pnp separate pair gp AF
5 c4 C9 K( E9 v3D- BC856W Phi N SOT323 BC556 hfe 75 min1 i' S6 {* i* @2 q$ I# ^2 ?( Q3 E6 Y$ u" ?
3Dp BC856 Phi N SOT23 BC556 hfe 75 min$ a# Z& r$ s; l: t
3Dt BC856 Phi N SOT23 BC556 hfe 75 min6 H4 W# S* c8 z0 C8 m
3Dt BC856W Phi N SOT323 BC556 hfe 75 min$ \$ }: s8 Q7 ]2 M
3E BC857A Phi N SOT23 BC557A
+ i9 C4 t1 D: e: |! H) o+ U3E BC857AT Phi N SOT416 BC557A
7 x9 Y+ m. e; p9 r" S3E MMBTH10 Mot N SOT23 MPSH10 fT 650MHz& H$ l/ C2 O/ D
3E FMMT-A42 Zet N SOT23 MPSA42
7 v. b; ?6 N: d5 I2 j% m6 V/ }& |3E- BC857A Phi N SOT323 BC557A# I4 H$ f6 }4 s+ F0 v) N+ A4 O) R
3EM MMBTH10L Mot N SOT23 VHF amp 650MHz fT
C. K( [1 Q( \: F4 V3Ep BC857A Phi N SOT23 BC557A: w' O, J$ ~( K. U9 ^, k- }
3ER BC857AR Phi R SOT23R BC557A" G% d* V: i" s; ^
3Et BC857A Phi N SOT23 BC557A
0 }5 u& U* s5 {5 h) \: j3Et BC857A Phi N SOT323 BC557A
# r1 b- ?9 {4 F$ ~4 g3EZ FMMTH10 Zet N SOT23 npn fT 650MHz9 r3 w7 J- n8 g5 J
3F BC857B Phi N SOT23 BC557B
+ S) l8 A" q. W/ a/ @6 ?1 r3F BC857BT Phi N SOT416 BC557B
8 [5 {) T4 ^$ B3 _. Q* k+ P: v" q3F- BC857BW Phi N SOT323 BC557B
8 q ~- C( e' ^( A) U8 d3Fp BC857B Phi N SOT23 BC557B0 j" D8 Z9 A) @ n; A8 _$ u L
3FR BC857BR Phi R SOT23R BC557B3 H( U/ o! l z7 f
3Fs BC857B Sie N SOT23 BC557B
. d9 V3 Q# F1 q) m" N0 X3Ft BC857B Phi N SOT23 BC557B
; A6 [! g" m" j$ w, Z3Ft BC857BW Phi N SOT323 BC557B% l ?# v, h' y7 b1 {. h
3Ft BC857BS Phi N SOT363 BC557B- } I/ w& V1 F
3G BC857C Phi N SOT23 BC557C
8 `& P7 N2 F% \1 ]3 v3G BC857C Phi N SOT23 BC557C
, P" ~% r. U+ `! u( p6 n; N' t( c3G MMBTH11 NS N SOT23 -
1 h, r5 |) \( q3G MGSF3454X Mot DK TSOP6 n-ch enh tmosfet 1.75A* B6 O J$ B' L% e b4 e
3G- BC857CW Phi N SOT323 BC557C1 s. E- S/ u# Q; T0 G' r+ S- ]
3Gp BC857C Phi N SOT23 BC557C* J5 V) R+ E$ N* G
3GR BC857CR Phi R SOT23R BC557CR: ^' j8 A( p& q: p2 ~5 E0 `8 V
3Gs BC857C Sie N SOT23 BC557C
2 |+ r7 A m! Y) F5 ?$ W1 \! {3Gt BC857C Phi N SOT23 BC557C
7 t5 p1 o$ r o3Gt BC857CW Phi N SOT323 BC557C
6 S: L" ?7 r9 f& k1 B/ O- r3H MMBTH30 NS N SOT23 -, _- h( f& s3 l6 I3 j" G
3H- BC857CW Phi N SOT323 BC557' N m! J! d4 Q& ^. Y9 u. b& `8 y( A
3Hp BC857C Phi N SOT23 BC557. C6 v2 g, B/ ]' `- ?
3Ht BC857C Phi N SOT23 BC5571 l" i! R0 S& \
3Ht BC857CW Phi N SOT323 BC557
4 [) G" v% }" A2 t3J MMBTH69 Mot N SOT23 pnp UHF fT 2GHz/ X3 h# A9 u/ B; T
3J BC858A Phi N SOT23 BC558A$ o" G/ U8 }& Z! v' Q j4 T
3Jp BCV62A Phi VQ SOT143 pnp current mirror hFe 180
! F9 p) H9 L6 B% ^1 ^! g8 P% s$ ~' n3JR BC858AR Phi R SOT23R BC558A
+ t& E: ?7 {$ r+ A- V3Js BC858A Sie N SOT23 BC558A
: k+ d" M$ v, o4 x3Js BCV62A Sie VQ SOT143 pnp current mirror hFe 180! D3 \) o' D. r
3K BC858B Phi N SOT23 BC558B
0 i, I. o5 r9 V0 ~3Kp BCV62B Phi VQ SOT143 npn current mirror hFe 290
1 {: P& Z& g5 T4 b4 c0 s3KR BC858BR Phi R SOT23R BC558B! ?" i) L' r3 E
3Ks BCV62B Sie VQ SOT143 npn current mirror hFe 290
( q# D2 s. z; E# \. _3L BC858C Phi N SOT23 BC558C
- v9 }& [7 Q9 z" o3Lp BCV62C Phi VQ SOT143 pnp current mirror hFe 520" h" I: l. L6 f* e$ q0 t. v
3LR BC858CR Phi R SOT23R BC558C/ G1 ?& r( R4 X x
3Ls BCV62C Sie VQ SOT143 pnp current mirror hFe 520
) q: {7 w! w* D, h+ J; H3M BC858 Phi N SOT23 BC558
3 d8 O3 h. B% Y* e1 l3M FMMT5087R Zet R SOT23R 2N5087 BC322
/ g8 R! L$ j2 Y6 C1 X1 H3Mp BCV62 Phi VQ SOT143 pnp current mirror
3 ~6 Y) J1 ^% v! d3Ms BCV62 Sie VQ SOT143 pnp current mirror
' u6 r+ M6 F4 N& d3N MMBT4402 Nat N SOT23 2N4402 pnp g1 j7 ?/ p# o0 Q# L" W, f
3P FMT2222AR Zet R SOT23R 2N2222A
, r4 L' i! K8 m" J; {( ]3R MMBT5571 Nat N SOT23 pnp sw 850MHz
* `3 a* c% o m9 @+ ?/ I3 m5 T2 D7 @3S MMBT5551 Nat N SOT23 npn 160V
9 s. T0 o0 d) m9 `5 Y: o: d: I3T HT3 Zet N SOT23 npn 80V 100mA
$ x. m! `. p& ]3V0 PZM3.0NB Phi C SOT346 3.0V 300mW Zener
" h: U8 K2 z# M' Q3V3 PZM3.3NB Phi C SOT346 3.3V 300mW Zener
& C- _2 L0 J1 l) R5 @9 `3V6 PZM3.6NB Phi C SOT346 3.6V 300mW Zener- O7 |/ I3 ]/ J. Y4 X) C1 B' |
3V9 PZM3.9NB Phi C SOT346 3.9V 300mW Zener
* p, |0 t/ m9 o& O3W FMMT-A12 Zet N - MPSA12
+ |) W8 N4 P. h$ C; v B* D3Y3 BZV49-C3V3 Phi O SOT89 3.3V 1W zener$ n7 N5 B" D3 M7 f, }% w/ e- L
3Y6 BZV49-C3V6 Phi O SOT89 3.6V 1W zener
3 _' I. @8 l; G1 `. v) y! N% E3Y9 BZV49-C3V9 Phi O SOT89 3.9V 1W zener
' B( c* t" E5 T, o) g4 (red) BB57-03W Sie I SOD323 Varicap
4 r: q1 B1 U0 M0 i+ |4 (white) BAS140W Sie I SOD323 40V 120mA sw schottky& X9 J; d1 D% C# c/ M
4 (yellow) BB644 Sie I SOD323 Varicap 42-2.5pF
5 K+ v- Z) p) z* {8 n/ U- t6 A2 F41A FMMT491A Zet N SOT23 npn 40v 1A max
4 C2 \! R* k/ I, Q6 W. M7 ?41D BAT14-115D Sie CY SOT173 40GHz schottky dual
4 n K3 l; K# l/ P42D BAT14-025D Sie CY SOT173 4GHz schottky dual
9 P+ O4 K4 P: R7 D43V PZM43NB Phi C SOT346 43V 0.3W zener
! u6 Y, A" Q- W6 K43Y BZV49-C43 Phi O SOT89 43V 1W zener
& A8 Z7 Z( T- _. w+ g: t2 ?45D BAT14-055D Sie CY SOT173 8GHz schottky dual
( o7 C4 o# u/ t8 o1 d47V PZM47NB Phi C SOT346 47V 0.3W zener z$ k( n& r( h/ S' z% m8 i
47Y BZV49-C47 Phi O SOT89 47V 1W zener9 \/ e) R$ C' e
49D BAT14-095D Sie CY SOT173 18GHz schottky dual
4 C, D' s* Q6 N! e) W% Z7 m4A MMBV109 Mot C SOT23 MV209 varicap
/ O8 k( Z8 |# e/ P4A FMMV109 Zet C SOT23 MV209 varicap; \# |, A+ H# e+ P ^/ d
4A HD3A Zet C - 75V 100mA sw diode
) d- ~6 v# F0 H y# [- k4A BC859A ITT N SOT23 BC559A- d2 y) V$ C9 L
4A3 PZM4.3NB2A Phi A SOT346 dual ca 4.3V Zener
% m* |/ u; f( Z* `+ B K4A7 PZM4.7NB2A Phi A SOT346 dual ca 4.7V Zener6 Z1 l; d+ R8 p; t7 v& E! p* d( r
4Ap BC859A Phi N SOT23 BC559A) y4 x. h' V* \! J* Z O
4AR BC859AR Phi R SOT23R BC559A- _" y' R# n( O) |# H4 b0 j
4As BC859AW Sie N SOT323 BC559A
) P% `8 E5 N, d8 e! W4As BC859A Sie N SOT23 BC559A
+ v I/ f* U; i3 R& b4B MMBV432 Mot B - dual cc varicap 1.5-45pF# q( r5 ?. E- s; i# X6 x) ]' O8 q
4B BC859B ITT N SOT23 BC559B: J2 h7 M* |& h/ L' C
4B- BC859BW Phi N SOT323 BC559B h K5 l: y# Y l
4Bp BC859B Phi N SOT23 BC559B! Q# V0 M8 F Z( Z4 w, k+ R
4BR BC859BR Phi R SOT23R BC559B
; u$ V2 a/ G( k8 v! q4Bs BC859B Sie N SOT23 BC559B$ m0 R+ E/ A, ~6 ]/ u% \( M; f: @$ n
4Bs BC859BW Sie N SOT323 BC559B
6 N" Z$ T4 C! Q, z4Bt BC859B Phi N SOT23 BC559B$ M1 s7 x. ]6 O+ t4 e
4Bt BC859BW Phi N SOT323 BC559B# k' ~0 l0 p. G6 N
4C BC859C ITT N SOT23 BC559C
, t1 B' b9 K3 v0 u6 i+ P4C MMVB3102 Mot C SOT23 varicap 6-35pF
: q0 G5 i3 h7 K- A7 N( g4C BC859C Phi N SOT23 BC559C
. A# B- E: {/ f9 B6 M. A {/ N4C- BC859CW Phi N SOT323 BC559C, |2 I$ F8 W' H3 J
4Cp BC859C Phi N SOT23 BC559C
1 G3 b9 g6 P9 N8 W/ d2 W9 H5 f4CR BC859CR Phi R SOT23R BC559C2 p) ^& K0 g5 Z, ^/ l/ _
4Cs BC859C Sie N SOT23 BC559C
, ^! z/ T" K% A* w4Cs BC859CW Sie N SOT323 BC559C
{$ H6 c3 q, F. E! o0 d4Ct BC859C Phi N SOT23 BC559C
! V" G, r l2 l4Ct BC859CW Phi N SOT323 BC559C
5 _: J# x0 U; D3 A) Q8 D) o4D BC859B Phi N SOT23 BC559B/ _) B0 C, M0 q
4D MMBV3401 Mot C SOT23 VHF pin diode: h8 M8 S9 d3 L; K! A7 e) N
4D HD3A Zet C SOT23 sw diode 75V 100mA( H1 X9 ?$ N, `' ]5 ^
4D- BC859W Phi N SOT323 BC559B
4 { n0 k8 A& H9 L* ?2 [% W4Dt BC859W Phi N SOT323 BC559B
) t; Y0 F2 U: ~* o" G/ T4E BC860A Phi N SOT23 BC560A5 {6 a; d4 q# P
4E FMMT-A92 Zet N SOT23 MPSA92' B1 o# ]$ W3 O, b
4E MMBV105G Mot C SOT23 MV105 varicap
3 ]' U& v5 ~5 D* P, j4ER BC860AR Phi R SOT23R BC560A
- a4 j; q$ M }& T0 D- T; I) I4F MMBD353 Mot Z SOT23 dual MBD101, _# g8 _2 H( n9 A ^$ S7 K
4F BC860B Phi N SOT23 BC560B+ x* R# t% f0 f6 N( J
4F Gali-4F MC AZ SOT89 DC-4GHz MMIC amp 15 dBm o/p
( A7 v: d: R3 Y' Z0 [& |4 E4F- BC860BW Phi N SOT323 BC560B
# ~8 x- h* p) R4Fp BC860B Phi N SOT23 BC560B5 l$ ?, @! \/ p6 N$ x5 x# B8 G
4FR BC860BR Phi R SOT23 BC560B
' Y% q& X( M+ e4Fs BC860B Sie N SOT23 BC560B
; {$ R) K8 ~, i/ c) a, C4Fs BC860BW Sie N SOT323 BC560B
2 Z8 n" {( Q# m, y! \! T4Ft BC860B Phi N SOT23 BC560B
+ u: {0 o( N6 m0 T4 U4Ft BC860BW Phi N SOT323 BC560B
4 W1 R) P% a8 b9 h' H& S4G MMBV2101 Mot C SOT23 MV2101 varicap4 a8 }; N. G$ l
4G BC860C Phi N SOT23 BC560C
3 J( P$ D1 V* ~' e" Y3 L% k c4G- BC860CW Phi N SOT323 BC560C% y4 H" j0 e- _
4Gp BC860C Phi N SOT23 BC560C5 w2 t' E# M! u
4GR BC860CR Phi R SOT23 BC560CR$ b# H4 a& C- |' j9 g1 h# W
4Gs BC860C Sie N SOT23 BC560C
; H. J- G5 e3 p E( Z/ u- J5 C4Gs BC860CW Sie N SOT323 BC560C
7 r) X7 z6 c$ c# u! }. j, K4Gt BC860C Phi N SOT23 BC560C$ u. v8 I* t% I0 E0 l4 `) t, ?
4Gt BC860CW Phi N SOT323 BC560C
1 ^" h# P! q! |6 X0 h) ^# \8 k" E4H MMBV2103 Mot C SOT23 MV2103 varicap6 I8 [6 y: P& S2 Y
4H- BC860W Phi N SOT323 BC560* l1 w" A: E( K6 { ^# M
4Hp BC860 Phi N SOT23 BC560
. p9 O4 r/ B i4Ht BC860W Phi N SOT323 BC560
4 z- M5 {3 a' Z4J FMMT38A Zet N SOT23 BCX38A& ^) o9 o% m7 n: _+ S* \: V
4J MMBV2109 Mot C SOT23 MV2109 varicap
9 v, |, h9 J3 \! |: a, ^/ G, `4K BAP64-04 Phi D - dual series 3GHz pin diode
2 o- h& r3 C1 N0 [( Q& Z6 t# ~- H9 _' H4K MMSB3000 Mot I SOD123 Si diode 30V 0.2A9 ^4 r& F) {, w6 v9 Q7 f
4L BAP50-04 Phi D - dual series GP RF pin diode' H0 \( y4 U' k: E
4M MMBD101 Mot C SOT23 MBD101 schottky diode
( W' J6 C. z+ N; X: ^6 I: @4Ms BAT240A Sie EQ SOT143 dual schottky 250V 0.4A
; E B+ M; q- l4R MMBV3700 Mot C SOT23 200V vhf pin diode3 S, O' M8 s7 w! M, y* l3 j
4S MMBD201 Mot C SOT23 MBD201& P; Y4 S. U N$ X( C/ r0 s
4T MMBD301 Mot C SOT23 MBD301 UHF schottky diode; r( D, q& E* O/ O; p4 s' U$ v4 s# P
4U MMBV2105 Mot C SOT23 MV2105 varicap
6 b3 K2 X/ b7 L* k4 ^: d4V MMBV2106 Mot C SOT23 MV2106 varicap$ J3 I3 S: V6 k
4V BCW65AR Zet R SOT23R npn 32V 0.8A
) \6 E& z( S. Z! b& L6 W4V3 PZM4.3NB Phi C SOT346 4.3V 0.3W zener
$ X. T F! E3 z4V7 PZM4.7NB Phi C SOT346 4.7V 0.3W zener6 H' \: m }3 ~; ]; P
4W MMBV2107 Mot C SOT23 MV2107 varicap
9 p% i }% l1 c3 b4W BCW67AR Zet R SOT23R pnp 32V 0.8A
8 h7 e3 |! x5 j2 ^. }, S4X MMBV2108 Mot C SOT23 MV2108 varicap: V' h8 J* t6 V& \8 N% S1 x
4Y MMBV2102 Mot C SOT23 MV2102 varicap; E* q" y' w/ l* w- K' [. r
4Y3 BZV49-C4V3 Phi O SOT89 4.3V 1W zener- l$ b E( t+ @+ t+ m# x* b
4Y7 BZV49-C4V7 Phi O SOT89 4.7V 1W zener
, q' R' \2 J$ }5 G, F* v& p* x4Z MMBV2104 Mot C SOT23 MV2104 varicap
; M2 D: d# ?' L# f2 M5 (red) BBY57-03W Sie I SOD323 varicap
; w# X" u3 @2 [6 T( I' W5 (white) BAT60B Sie I 10V 3A sw Schottky
& L) I& o0 t b51D BAT15-115D Sie CY SOT173 40GHz schottky dual
) T& b6 C( R1 V/ p# ?# J51V PZM51NB Phi C SOT346 51V 0.3W zener( o! b$ {" j% {4 y
51Y BZV49-C51 Phi O SOT89 51V 1W zener/ ~( ^! C1 U" H2 Z3 D* O6 b
52D BAT15-025D Sie CY SOT173 4GHz schottky dual2 E5 Y+ z; V: R j
53s BAT17 Sie C SOT23 schottky diode 4V 100mA& i+ p# H0 t4 G, q3 b: v* @& G$ b
54s BAT17-04 Sie D SOT23 dual series BAT17
" O0 H4 B! a' U7 n! T0 X54s BAT17-04W Sie D SOT323 dual series BAT17
' S" A7 y7 h- r! y- E, e h55D BAT15-055D Sie CY SOT173 8GHz schottky dual2 C( r& L. ^& @+ i& ~! ^/ P
55s BAT17-05 Sie A SOT23 dual ca BAT17 M$ @5 S/ X, @
55s BAT17-05W Sie A SOT323 dual ca BAT17
& x0 I( I# }" f" a+ Q! A2 e, R56s BAT17-06 Sie B SOT23 dual cc BAT17
. p' ?6 S$ f" ~+ `- B. l- c q( Y56s BAT17-06W Sie B SOT323 dual cc BAT172 p. Z& @. V2 P" l$ o& k- W
56V PZM56NB Phi C SOT346 56V 0.3W zener
" e+ T+ v! A* `/ n) b& C56Y BZV49-C56 Phi O SOT89 56V 1W zener& r5 J1 e& Z% W$ ]) g
57s BAT17-07 Sie S SOT143 dual BAT17* e. M: o& q" h$ a! P8 t: Q, \
59D BAT15-095D Sie CY SOT173 18GHz schottky dual. c) o4 w& S% u- I+ Q3 U
5A BC807-16 Phi N SOT23 BC327-16
) t1 o* }/ e( q( K+ B5 M0 o. V5A BSS123 Mot M SOT23 n-ch tmosfet Vds 100V
" A6 u$ C3 f1 e1 c$ @+ o ^: B5A MMBD6050 Mot C SOT23 sw diode 70V 0.2A
% s% h" p+ }4 g, V5A FMMD6050 Zet C SOT23 sw diode 70V 100mA
! T1 _' n6 S. I3 k; @9 Z5A- BC807-16W Phi N SOT323 BC327-16
4 W/ Y! ]/ c# H- v& S5A1 PZM5.1NB2A Phi A SOT346 dual ca 5.1V 0.3W zener
/ N) V$ {) j& q8 Z4 b! o5A6 PZM5.6NB2A Phi A SOT346 dual ca 5.6V 0.3W zener; q6 W+ I o" Q2 `* \! G0 H x( o
5Ap BC807-16 Phi N SOT23 BC327-16 $ u+ w: D7 B# d" m2 ]4 p
5AR BC807-16R Phi R SOT23R BC327-16- @0 e& k' h9 a/ F
5As BC807-16 Sie N SOT23 BC327-16/ C1 _( i* B7 z
5As BC807-16W Sie N SOT323 BC327-16 n' y! k. j$ Q: h V
5At BC807-16 Phi N SOT23 BC327-16 ; Q4 h* q( B: {* e% v
5At BC807-16W Phi N SOT323 BC327-16
* j* @) P* t: C( i2 B; h8 a1 o5 q/ b5B MMBT4123 Mot N SOT23 2N4123
+ X5 \& P- x# D) |9 m5B BC807-25 SGS N SOT23 BC327-25 : e* X" }+ d4 J& Q3 w+ Y! v! e
5B MMBD6100 Mot B SOT23 cc dual diode 70V 0.2A
+ M) [7 y/ g- v( n5B FMMD6100 Zet B SOT23 cc dual diode 70V 0.2A. f# ^6 n, O7 _/ ]
5B- BC807-25W Phi N SOT323 BC327-25 ( k2 n1 S3 Q6 F* u0 Q) p
5BM MMBD6100 Mot B SOT23 cc dual diode 70V 0.2A
* @; a9 c! i" w' ?# O+ K5Bp BC807-25 Phi N SOT23 BC327-25
- v: {( t# l$ ]9 l5BR BC807-25R Phi R SOT23R BC327-25$ \5 o/ f5 K8 b4 ^
5Bs BC807-25 Sie N SOT23 BC327-25 . h: V) @+ h! x( Y
5Bs BC807-25W Sie N SOT323 BC327-25 $ s# L3 y4 S' \! F$ c1 ?6 E( h) E2 K
5Bs BC807-25U Sie N SC74 BC327-25
4 W# m M; U ?6 o2 ] X5Bt BC807-25 Phi N SOT23 BC327-25
/ r9 i8 m3 A- ~) N4 l7 T" f# |5Bt BC807-25W Phi N SOT323 BC327-25 5 z. Z& _9 s1 `* a
5C BC807-40 SGS N SOT23 BC327-40
- h1 E' r: X% W L% v5C MMBD7000 Mot D SOT23 2 ser diodes 100V 0.2A8 o( z0 p" w' E) ~) Y$ C0 K
5C FMMD7000 Zet D SOT23 2 ser diodes 70V 200mA$ b9 O! `" @. G# X
5C- BC807-40W Phi N SOT323 BC327-40
) a5 C3 N; Z$ s- o6 F4 Y7 Q5Cp BC807-40 Phi N SOT23 BC327-40
% u) p! O* ]! d$ g5CR BC807-40R Phi R SOT23E BC327-40$ U% i; \' \7 C* U/ ?/ g
5Cs BC807-40 Sie N SOT23 BC327-40/ N& W9 z: G- s* R. g
5Cs BC807-40W Sie N SOT323 BC327-40) A, t% B2 \# \+ U% F/ ?/ d
5Ct BC807-40 Phi N SOT23 BC327-40
6 N6 s0 C2 [- G2 x3 h6 u% \5 q5 E# X5Ct BC807-40W Phi N SOT323 BC327-40
, d( `3 @' K, ^$ L5 f. Z5D FMMD914 Zet C SOT23 1N914# f* l5 Y T; S0 W6 v2 g* ], @$ ]
5D MMBD914 Mot C SOT23 1N914( G. V* g: H8 b. n. ~
5D MMSD914 Mot I SOD123 1N914$ |, W/ x3 c+ ^1 |0 V# ]/ F
5D HD2A Zet B dual cc HD2 75V 100mA- h2 H& z4 O# Q6 J9 s4 O! V0 d0 }
5D- BC807W Phi N SOT323 BC327 . f% i5 f4 t6 p9 ]0 F3 @, U' }
5Dp BC807 Phi N SOT23 BC327
8 F0 [' P( O% f5Dt BC807 Phi N SOT23 BC327
/ Y$ L, d: M( f/ {5Dt BC807W Phi N SOT323 BC327
~# R7 w3 S0 j1 u5E BC808-16 Phi N SOT23 BC328-166 R8 Z! T2 [* {0 _; L
5E FMMT-A43R Zet R SOT23R MPSA43
% A" k2 k9 K4 d j) {; l6 N5E BC808-16 Phi N SOT23 BC328-16
- w& b6 o" @0 p, {' p5ER BC808-16R Phi R SOT23R BC328-166 u. |: _2 r7 A. k, ~
5Es BC808-16 Sie N SOT23 BC328-165 j$ c% t/ A4 j* V2 H; v. K
5Es BC808-16W Sie N SOT323 BC328-16
. j# N4 ^' m5 T& r5F BC808-25 Phi N SOT23 BC328-25) h- N" p) X1 h# ~1 C! V6 U
5F MMBD501 Mot C SOT23 MBD501 hot carrier diode& k D. G4 M- A6 W
5F Gali-5F MC AZ SOT89 DC-4GHz MMIC amp 20 dB gain
- B5 F/ `0 A' A( m9 M+ p5FR BC808-25R Phi R SOT23R BC328-25
# {4 q6 \# d. k* V4 k% r) t' ^5Fs BC808-25 Sie N SOT23 BC328-25) s% Q5 i4 d$ \" h6 m1 z
5Fs BC808-25W Sie N SOT323 BC328-25
( ~: P& B% a; ?& |6 \8 t5G BC808-40 Phi N SOT23 BC328-40
" R$ i. }' M; _3 K1 r1 Q5G MMBD353 Mot D dual series MBD101
# \, e# N) c6 N/ [5GR BC808-40R Phi R SOT23R BC328-40- e4 Y9 s; U) @4 d7 E9 n7 {
5Gs BC808-40 Sie N SOT23 BC328-40) I2 V, G! E0 p& E
5Gs BC808-40W Sie N SOT323 BC328-40
9 o( r( i7 c4 I' E5H MMBD701 Mot C SOT23 MBD701 UHF schottky diode0 r+ U2 Y0 K# K/ o
5H MMBD4148 Nat C SOT23 1N4148
6 e* {2 }; w0 a" G0 H5Hp BC808 Phi N SOT23 BC328$ c8 C E5 l9 u1 \, ^( M& j
5HZ BC808 Zet N SOT23 BC3281 ~+ }" \/ [: {& x% r* W% g1 P. ?
5I MMSD4148 Mot C 1N4148 X5 T' }4 Z. R7 E9 y" [9 o
5J FMMT38B Zet N BCX38B
) L8 x: e& s7 ]% E, C5K MMBV809 Mot C SOT23 Hyperabrupt varicap
( R. Y7 s2 L& G) Y5Kp BAP64-05 Phi B dual cc 3GHz RF pin diode
5 A/ A: }1 H, ^! X! N% V5L MMBV609 Mot B SOT23 dual cc Hyperabrupt varicap
) R( Y1 |3 f6 p: T2 f) n2 M5N MMBD452L Mot D SOT23 series UHF schottky diodes
! S9 V, B, z) l# H5 [/ I5P FMMT2907AR Zet R SOT23R 2N2907A* n$ x( {( e7 s* c1 b+ Y) t
5T BCW66GR Sie R SOT23R npn 45V 0.8A 350mW( W+ H6 g1 {" R
5V BCW65BR Zet R SOT23R npn 32V 0.8A
: l* W7 N. f4 s* S7 G* e5V1 PZM5.1NB Phi C SOT346 5.1V 0.3W zener7 k! T2 g' q7 j) M, v4 C& h
5V6 PZM5.6NB Phi C SOT346 5.6V 0.3W zener4 x( v( T* A& L) Z L, O
5W BCW67BR Zet R SOT23R pnp 32V 0.8A
" n$ o( k8 e2 `/ W9 Q5Y1 BZV49-C5V1 Phi O SOT89 5.1V 1W zener
3 n# f. t5 k G5Y6 BZV49-C5V6 Phi O SOT89 5.6V 1W zener3 G4 j7 `$ f3 o. G
6 (red) BBY56-03W Sie I SOD323 varicap. _; L9 \& {) W
60s BAR60 Sie QQ SOT143 3 pin diodes
1 |% n p7 X* M/ L4 A61A MMBF4117 Nat F - n-ch jfet ultra low i/p Ig
0 H, O/ I. m& l. l3 l61A MMBF4119 Nat F - n-ch jfet ultra low i/p Ig! D- o' i# U6 }+ Y+ [0 g& K
61C MMBF4118 Nat F - n-ch jfet ultra low i/p Ig: q/ r2 n4 K$ h6 h7 Z0 y
61J MMBF4091 Nat F - n-ch jfet sw/chopper
6 \/ v2 C X/ n' ~( N, O0 R: I61K MMBF4092 Nat F - n-ch jfet sw/chopper) ]$ _. F; f- |# B- t* _; ? ]
61L MMBF4093 Nat F - n-ch jfet sw/chopper6 W, @% S" ]: S3 D
61M MMBF4859 Nat F - n-ch jfet sw/chopper
( q& a+ M# S+ B9 J61N MMBF5514 Nat F - p-ch jfet sw/chopper
5 \4 g% ^0 G. M+ [/ C5 `- _ \61P MMBF5115 Nat F - p-ch jfet sw/chopper
: r# V G& @% D. f& U7 M* [% ]61Q MMBF5516 Nat F - p-ch jfet sw/chopper. u# f/ l R+ @ q) F' s
61s BAR61 Sie PQ SOT143 3 pin diodes pi atten
- r1 h! J w7 y! X5 q1 J61S MMBF5458 Nat F - n-ch jfet gp 2N5458. L( x6 _) w" v! @, M7 m
61T MMBF5459 Nat F - n-ch jfet gp 2N5459: J+ n: m v2 ^6 ^- I5 L
61U MMBF5461 Nat F - p-ch jfet gp 2N54612 n7 f* e9 i ]5 h4 N% u9 j" M
61V MMBF5462 Nat F - p-ch jfet gp 2N54629 H7 z8 D5 `' M: D& M$ l
62P MMBFJ201 Nat F - n-ch jfet gp J2011 f4 h9 z2 v: o& O6 y* l
62Q MMBFJ202 Nat F - n-ch jfet gp J202: r1 _/ C+ Z& o( q8 Y0 u' e8 L' G( ^
62R MMBFJ203 Nat F - n-ch jfet gp J2031 `3 _ }1 A* D! Z6 X& D
62S MMBFJ270 Nat F - p-ch jfet gp J270
# I' Y1 s$ E4 A: ~( y8 B62T MMBFJ271 Nat F - p-ch jfet gp J2715 M0 A7 E n0 [' F2 k" ^6 S
62V PZM62NB1 Phi C SOT346 62V 0.3W zener
. S/ p' r f& ~4 A62Y BZV49-C62 Phi O SOT89 62V 1W zener
Y- d$ b7 b! y) y% k3 P! u3 E63Q MMBFJ304 Nat F - n-ch jfet vhf J304
) s: S ^* [! R63s BAT64 Sie C SOT23 Schottky 40V 250mA gp
+ x3 p- z; x z3 O63s BAT64W Sie C SOT323 Schottky 40V 250mA gp
, ^8 X0 q0 o# O& C: D2 _! w64s BAT64-04 Sie D SOT23 dual ser gp Schottky 40V 250mA5 Q. N( Q/ B1 h$ S5 R6 B" T5 n
64s BAT64-04W Sie D SOT323 dual ser gp Schottky 40V 250mA5 e* z" b6 ~. |4 p$ j8 t* H
65s BAT64-05 Sie B SOT23 dual cc gp Schottky 40V 250mA1 S: [* x# Z9 @7 X, ?
65s BAT64-05W Sie B SOT323 dual cc gp Schottky 40V 250mA
, Z2 p9 X6 ]9 K0 e8 \1 D! [66s BAT64-06 Sie A SOT23 dual ca gp Schottky 40V 250mA
% ]4 |7 w& z7 a6 ~) m$ C66s BAT64-06W Sie A SOT323 dual ca gp Schottky 40V 250mA
0 W1 M3 h; G2 Q ~) |67R BFP67R Tfk WQ - npn Rf fT 7.5GHz 10V 50mA
4 f( ^# f+ t. u67s BAT64-07 Sie S SOT143 dual gp Schottky 40V 250mA
) E. A. }5 |8 i) c& k2 [67s BAT64-07W Sie S SOT343 dual gp Schottky 40V 250mA( x3 |! ?! X, [
68V PZM68NB1 Phi C SOT346 68V 0.3W zener. \% l( N" d' ]" Z
68Y BZV49-C68 Phi O SOT89 68V 1W zener
, E: z8 k. q/ L' _9 J6 D6A MMBF4416 Mot F SOT23 2N4416 n-ch vhf jfet
2 v# z) _& p4 n" k6A MUN2111 Mot N SOT23 pnp dtr with 10k+10k
$ k5 x, W8 M& R1 b8 c6A MUN5111 Mot N SOT323 pnp dtr with 10k+10k X P7 R$ j0 \* ?4 m
6A BC817-16 Phi N SOT23 BC337-16
7 `$ f0 @: J6 k2 c' x& j b v6A- BC817-16W Phi N SOT323 BC337-16
' `- p& q9 J- N; R' q* ~- a6A2 PZM6.2NB2A Phi A SOT346 dual ca 6.2V 0.3W zener
: t) W3 I% l( q" J. D- K6A8 PZM6.8NB2A Phi A SOT346 dual ca 6.8V 0.3W zener- Y6 o* X( W- m; Q( q
6Ap BC817-16W Phi N SOT23 BC337-16
4 H# U Q0 V. {3 ]& U6AR BC817-16R Phi R SOT23 BC337-16/ c9 H" x+ r, D( F {/ i2 x
6As BC817-16 Sie N SOT23 BC337-16 : ?2 e$ {1 z M5 e
6As BC817-16 Sie N SOT323 BC337-16
/ u0 ^; a1 c3 j6 ]! F6At BC817-16 Phi N SOT23 BC337-16 ( n/ ]- k1 M* h6 @
6At BC817-16W Phi N SOT323 BC337-16 % i4 _* Y- F( [ i
6AZ BC817-16 Zet N SOT23 BC337-16 " E6 B5 N, H; x+ e
6B MMBF5484 Mot F SOT23 n-ch jfet 2N5484. h4 e3 x/ x' E+ v
6B BC817-25 Phi N SOT23 BC337-25 - u" C. A% l4 ?6 O# r+ i: m6 a
6B MUN2112 Mot N SOT23 pnp dtr 22k+22k
+ \& `3 I( t( |2 D% d) E; G; y) B4 h6B MUN5112 Mot N SOT323 MUN2112
* {2 r0 G6 I/ F1 Y6B- BC817-25W Phi N SOT323 BC337-25
0 T' b* Y+ f( w' e' P6Bp BC817-25 Phi N SOT23 BC337-25
2 |. C2 F0 h* c6BR BC817-25R Phi R SOT23R BC337-25
% N* L: K0 i/ T) h6Bs BC817-25 Sie N SOT23 BC337-25 2 I( K& K4 { f/ v
6Bs BC817-25W Sie N SOT323 BC337-25 : g- c' H. Y0 ]9 ^: t
6Bt BC817-25 Phi N SOT23 BC337-25
1 f+ f5 w! F/ L: q" _6Bt BC817-25W Phi N SOT323 BC337-25
+ F8 f Y; ]4 Q! m- s* ?; C6BZ BC817-25 Zet N SOT23 BC337-25
& E2 n6 {( B+ p a6C BC817-40 Phi N SOT23 BC337-408 U" `; F7 A5 ~- \1 G! P' B: s' a
6C MMBFU310 Mot F SOT23 n-ch jfet U3106 b1 \2 x- `% a% _0 x
6C MUN2113 Mot N SOT23 pnp dtr 47k+47k ! t3 G, q& n$ B( f$ f4 N
6C MUN5113 Mot N SOT323 MUN2113 J4 d* ^4 d( ~) k1 h
6C- BC817-40W Phi N SOT323 BC337-40 : A B# R% J7 C3 E" ?- J G9 J+ K$ |
6Cp BC817-40 Phi N SOT23 BC337-40
( ]% F* Q. a( M0 D; J6CR BC817-40R Phi R SOT23R BC337-40% }, e4 R1 o) G( e5 w
6Cs BC817-40 Sie N SOT23 BC337-40
9 s V% O, N1 p/ b6Cs BC817-40W Sie N SOT323 BC337-40* |! I" }- E5 C9 t4 u
6Ct BC817-40 Phi N SOT23 BC337-40 & N7 `: e3 U$ ~" \. Z9 s {3 X6 |
6Ct BC817-40W Phi N SOT323 BC337-40 m9 j: T7 T& W0 U
6CZ BC817-40 Zet N SOT23 BC337-40 ' Z& I y) Y& I& y
6D MMBF5457 Mot F SOT23 2N5457 n-ch jfet
5 ]0 |. A7 a: h: W; p0 `( _9 N6D MUN2114 Mot N SOT23 pnp dtr 10k+47k
7 x7 O0 E8 d, U9 X, p6D MUN5114 Mot N SOT323 MUN21141) x) I6 N3 O* B, }1 @
6D- BC817W Phi N SOT323 BC337 ( J3 Z+ D5 J- |; e, ^
6Dp BC817 Phi N SOT23 BC337 . o" |1 ^$ |! P( Y; g7 `
6Dt BC817 Phi N SOT23 BC337
$ X7 L" ~3 p9 ?/ K* i6Dt BC817W Phi N SOT323 BC337 ( H+ K3 K. x. j- P& K
6DZ BC817 Zet N SOT23 BC337
& }2 `5 G8 A! m# x6E FMMT-A93R Zet R SOT23R MPSA93" ^0 S- @8 T! v; k
6E MMBF5460 Mot F SOT23 p-ch jfet 2N5460
6 S: n+ [' }' R& w; ^; J6E BC818-16 Phi N SOT23 BC338-16
9 H1 }( ~: j F6E MUN2115 Mot N SOT23 pnp dtr R1 10k
6 \: [0 z* k8 E- s6E MUN5115 Mot N SOT323 MUN2115; k4 a" S3 q0 q/ `+ \
6ER BC818-16R Phi R SOT23 BC338-167 D* T% S- e2 Z. Q6 D' G
6Es BC818-16 Sie N SOT23 BC338-16; H' x) x1 p/ q% r. k- o
6Es BC818-16W Sie N SOT323 BC338-16: U" \: v+ ?. E/ _ M
6EZ BC818-16 Zet N SOT23 BC338-16
/ ` c z7 B1 g7 L* ~, b9 w6F MMBF4860 Mot F SOT23 2N4860 n-ch jfet
# N. }/ _9 q, ~ Z6F BC818-25 Phi N SOT23 BC338-25
, f. r4 r, L A* |, A, I6F MUN2116 Mot N SOT23 pnp dtr R1 4k7 & o" n: w) |+ s5 f0 @, C) M& H A
6F MUN5116 Mot N SOT323 MUN2116
8 [2 b# J8 W K0 `$ G/ v6F Gali-6F MC AZ SOT89 DC-4GHz MMIC amp 12 dB gain8 o. V$ @ a2 Z- n, f
6FR BC818-25R Phi R SOT23R BC338-25
$ Q" G- I: {+ q, a3 j& g L% l# {2 G$ D6Fs BC818-25 Sie N SOT23 BC338-25, |: L7 U [! s9 q. g" F
6Fs BC818-25W Sie N SOT323 BC338-25
- k5 z: D# ~# v9 B4 ~; E+ r6FZ BC818-25 Zet N SOT23 BC338-25: c: L# W, A# i; z H: v
6G BC818-40 Phi N SOT23 BC338-40
3 E9 S7 }8 x- v _! M6G MMBF4393 Mot F SOT23 n-ch jfet 2N4393
2 Z2 i: M/ y) J9 \; a' u6G MUN2130 Mot N SOT23 pnp dtr 1k0+1k0 6 O4 G c2 [2 L% v1 E3 P0 }" h
6G MUN5130 Mot N SOT323 "ial"">MUN2130 "2 t6 u5 d, O0 }5 z
6GR BC818-40R Phi R SOT23 BC338-40
8 x+ }3 c* U+ \( {6Gs BC818-40 Sie N SOT23 BC338-40
, n l& [* _4 Q8 i3 G6Gs BC818-40W Sie N SOT323 BC338-40
& ? N! N# C3 B6 M" Y, _# _- b$ o) y6GZ BC818-40 Zet N SOT23 BC338-40
1 l' q4 ~1 o0 h( S6H MMBF5486 Mot F SOT23 n-ch jfet 2N5486
% ^4 e, _0 W, J. v1 J6H MUN2131 Mot N SOT23 pnp dtr 2k2 +2k2 ; \9 k; T0 L9 r. c+ b0 @
6H MUN5131 Mot N SOT323 MUN2121
8 M3 M$ G4 b2 ~/ x2 R4 O; O2 p& ?& l6Hp BC818 Phi N SOT23 BC338
6 M l2 K8 W9 m/ g+ S9 v3 b8 [) p6HZ BC818 Zet N SOT23 BC338) j1 w' ?3 ~: W6 R' [5 m/ @
6J MMBF4391 Mot F SOT23 n-ch jfet 2N4391, q" S/ u% H5 k- N
6J MUN2132 Mot N SOT23 pnp dtr 4k7+ 4k7# @% i8 \' [' _
6J MUN5132 Mot N SOT323 MUN2132' }) X8 g1 v0 q! x! y) {6 C: O
6K MMBF4932 Mot F SOT23 n-ch jfet 2N49323 ?9 Q. c# E, d3 k
6K MUN2133 Mot N SOT23 pnp dtr 4k7+ 47k2 ]# [8 i' p3 Y. o6 c* G) N* r. M
6K MUN5133 Mot N SOT323 MUN2133( s# W g. G; k: |4 C8 e9 w
6L MMBF5459 Mot F SOT23 n-ch jfet 2N5459+ E E& a& l% b" k4 m3 d
6L MUN2134 Mot N SOT23 pnp dtr 22k+47k 7 Z- z: x( a( u# g) X" @6 F3 j
6L MUN5134 Mot N SOT323 MUN2134
* F. }5 c! X! q6M MMBF5485 Nat F SOT23 n-ch jfet vhf 2N54853 z" t2 ?# V/ S7 e
6N MMBF4861 Nat F SOT23 n-ch jfet sw/chopper
1 Q4 {5 e0 n% c+ m+ F4 z6P MMBFJ111 Nat F - J111 n-ch jfet
/ W% T* F7 j& e0 _6P BCX71HR Phi R SOT23R BCX79
9 L* L" T i# u( V& Q9 w' R6P MMBFJ113 Nat F - J113 n-ch jfet' _( }3 Y# e* g3 Z
6Q MMBFJ305 Nat F - n-chjfet vhf J305
* h9 W' H; i4 ]2 ^5 M6R MMBFJ112 Nat F - J112 n-chjfet
7 @2 r3 f3 V, X/ M5 X7 e+ m' {6S MMBFJ176 Nat F - J176 n-ch jfet
' Y9 d- S6 _( ~6 ]$ o5 b6S MMSD71 Mot C - gp Si diode# m, v6 Q Z4 v, K8 P
6T BCW68GR Sie R - pnp 45V 0.8A 350mW S4 M# x' ?7 U% L5 X0 e ~
6T MMBFJ310 Mot F SOT23 uhf n-ch jfet J310
& `' M$ y4 C- R! }* v" L0 f% |& M6U MMBFJ309 Nat F SOT23 uhf n-ch jfet J309
1 x) H- e$ C* d% o v5 o6V BCW65CR Zet R SOT23R npn 32V 0.8A
1 S9 \) I. p8 e0 C7 s, b6V MMBFJ174 Nat F - J174 p-ch jfet sw/chopper
& R' _4 t: b& H$ m! A1 \6V2 PZM6.2NB Phi C SOT346 6.2V 0.3W zener
$ _! l0 z! \4 Y+ i7 I% y6V8 PZM6.8NB Phi C SOT346 6.8V 0.3W zener' y- j9 c8 o) ]5 X" u
6W BCW67CR Zet R SOT23R pnp32V 0.8A! x/ J n- d$ x5 ~1 u( j9 q' H2 N5 j
6W MMBFJ175 Mot F SOT23 J175 p-ch jfet
2 i8 z0 y, N8 Q6X MMBFJ174 Nat F - J174 p-ch jfet sw/chopper
- I Q T' M9 |# G+ E9 R- t6Y MMBFJ177 Mot F SOT23 J177 p-ch jfet
; N& r1 J1 h( \* v+ l. ^6Y2 BZV49-C6V2 Phi O SOT89 6.2V 1W zener
5 B& \/ H7 B. a' Z6 Q6Y8 BZV49-C6V8 Phi O SOT89 6.8V 1W zener
$ S- q g9 X0 W6Z MMBF170 Mot M SOT23 tmosfet n-ch Vds 60V1 Z: N* @+ Z; Q, e% `# D
7 (white) BBY55-02W Sie I SCD80 UHF Varicap% i( o0 |4 ?# R6 U3 h
73- BAS70W Phi C SOT323 schottky diode 70V 50mA) b; J6 f4 B1 o
73p BAS70 Phi C SOT23 schottky diode 70V 50mA3 c# ]. U: r% \7 |5 Z) \
73s BAS70 Sie C SOT23 schottky diode 70V 50mA
# M0 _- ?. q; B+ L73S BFQ73S Sie CX SOT173 npn fT 5.3GHz 15V 100mA8 ^: [5 A% \: |& x/ N# d; u
73t BAS70 Phi C SOT23 schottky diode 70V 50mA6 X x0 B$ a4 F, U0 @7 n0 z, Q
73t BAS70W Phi C SOT323 schottky diode 70V 50mA' f- N+ i) t+ v( q* t( C; n6 I
74p BAS70-04 Phi D SOT23 dual series BAS70# P& U8 R0 S, r
74s BAS70-04 Sie D SOT23 dual series BAS70
! d# D% I1 o. E5 l! s74t BAS70-04 Phi D SOT23 dual series BAS70 t" B& t3 M L5 j
74t BAS70-04W Phi D SOT323 dual series BAS70
0 H& F. E+ G4 q7 `- [/ X3 L5 o3 c74t BAS70-04W Phi D SOT323 dual series BAS70
, f. h/ A* \2 |1 k; v+ J/ e3 Q75- BAS70-05W Phi B SOT323 dual cc BAS70; c* p _" F; p. r& R% d$ z
75p BAS70-05 Phi B SOT23 dual cc BAS70! ~4 I: [& W/ @* Y) y
75s BAS70-05 Sie B SOT23 dual cc BAS700 P" c, \( X9 O
75s BAS70-05W Sie B SOT323 dual cc BAS70
3 h; d# g& `+ ^! ^# J: \$ a75t BAS70-05W Phi B SOT323 dual cc BAS70
& B2 X: {% z/ y3 ?75t BAS70-05 Phi B SOT23 dual cc BAS703 W" A( O, f6 ?$ H
75Y BZV49-C75 Phi O SOT89 75V 1W zener
9 t$ h2 [0 U2 H/ P76- BAS70-06W Phi A SOT323 dual ca BAS70
+ q2 G. h- @, m/ y0 W" V: [76p BAS70-06 Phi A SOT23 dual ca BAS705 }$ g* K1 F7 a6 R0 g, p3 V9 j
76s BAS70-06 Sie A SOT23 dual ca BAS70
" W/ J4 L" J% l/ b& G S3 O76t BAS70-06 Phi A SOT23 dual ca BAS70
7 S+ A) d$ e. W, F76t BAS70-06W Phi A SOT323 dual ca BAS70# ~2 Y' [' @. i8 D! {% Q3 I
77s BAS70-07 Sie S SOT143 dual BAS70
# f9 I! A } t$ `% E5 y3 b77s BAS70-07 Sie S SOT343 dual BAS70
# O, ~7 T% l0 a3 L: F& I1 x8 x+ y5 Q7A MMBR901 Mot N SOT23 npn RF MRF901- z) L) F+ l! R2 |8 A6 z' q5 ]" N
7A MUN5211DW1 Mot DN SOT363 dual npn dtr 10k+10k
' P% A3 N- r/ \5 s' ^) d7A5 PZM7.5NB2A Phi A SOT346 dual ca 7.5V 0.3W zener1 G3 N$ X5 m T* `. q) Z# {/ O
7B MMBR920 Mot N SOT23 npn RF ?MRF920/ A7 L8 F# ~' S; m/ B$ ^7 M
7B MUN5212DW1 Mot DN SOT363 dual npn dtr 22k+22k% [7 g( \; n5 J, ^) S1 u
7C MMBR930 Mot N SOT23 npn RF ?MRF930$ s; v1 _( K" O V! c! i
7C MUN5213DW1 Mot DN SOT363 dual npn dtr 47k+47k
4 V2 M$ r8 n4 v2 u$ ]+ X$ J$ X) Q! Y7D MMBR931 Mot N SOT23 npn RF ?MRF931
" }7 I; n& F! Z+ [/ B7D HD4A Zet A - ca dual HD3A
: a. s1 I2 }& J) ]6 H( _7D MUN5214DW1 Mot DN SOT363 dual npn dtr 10k+47k
6 R0 S8 u% r% x6 e! b4 O. J0 c* q7E FMMT-A42R Zet R - MPSA42% D& Q. ^- R0 |
7E MMBR2060 Mot N - npn RF fT 1GHz Vce 30V 50mA" X7 Q0 a# s8 d. C" o8 P
7E MUN5215DW1 Mot DN SOT363 dual npn 10k base res3 o8 z' M9 x' a
7F MMBR4957 Mot N - npn RF fT 1.2GHz 30V 30mA
7 V0 ~' T: N: h' l7F MUN5211DW1 Mot DN SOT363 dual npn dtr R1 4k7
( B2 `* p" V7 ?6 O# {5 s. W. _* I7G MMBR5031 Mot N SOT23 npn RF fT 1GHz 10V 20mA
, R" [. L& O% p* ~# E- G7G MUN5230DW1 Mot DN SOT363 dual npn dtr 1k0+1k0
. @8 A' `$ V! ~' z: }7H MMBR5179 Mot N SOT23 npn RF 2N5179/BFY90
3 H; J2 B; y6 s G, a7H MUN5231DW1 Mot DN SOT363 dual npn dtr 2k2+2k2
! L9 y' V* D, \" j1 E% m& M7J FMMT38C Zet N SOT23 BCX38C
2 l6 d) X: D3 |6 |7J MUN5232DW1 Mot DN SOT363 dual npn dtr 4k7+4k7( |" q3 l& j: p
7K MMBR2857 Mot N - npn RF fT 1GHz Vce 15V 40mA
. [# [9 G7 F$ F1 d. T* S7K MUN5233DW1 Mot DN SOT363 dual npn dtr 4k7+47k bias
5 z+ ~% w3 n) V9 \7L MUN5234DW1 Mot DN SOT3636 dual npn dtr 22k+47k bias
I0 G% ~4 A# ?( m7M MUN5235DW1 Mot DN SOT363 dual npn dtr 2k2+47k bias
* D4 D& F0 h' j. T7M MMBR521L Mot N SOT23 pnp RF MRF5213 S2 ~+ s( k7 x
7M BCW66HR Zet R SOT23R npn 45V 0.8A' Q1 m. G5 V! h$ V1 k- }
7N MMBR941BL Mot N SOT23 npn RF fT 8GHx MRF941- ^0 R9 o* C, T7 @) i+ U" g) S4 @
7N BCW68HR Zet R SOT23 pnp 45V 0.8A
0 E( ` N& L) q. }" m8 Z' f7P BCW66FR SGS R SOT23R npn 45V 0.8A 350mW
- Y; M! ~$ R, J3 C, J. ? k1 D7P MMBR911L Mot N SOT23 npn RF fT 6GHz MRF911) n% V' J. X/ q/ C8 _
7R MMBR536 Mot N - npn RF MRF536+ g3 _& s1 c( d
7T BCW68FR Zet R SOT23R pnp 45V 0.8A
& P9 w4 ^: M( l" F z7V5 PZM7.5NB Phi C SOT346 7.5V 0.3W zener
8 t7 I: p; Y/ o7X MMBR571L Mot N SOT23 npn RF fT 8GHz MRF571' |# ]6 ]* g- ~4 R* I
7Y MMBR941L Mot N SOT23 npn RF fT 8GHz MRF941
6 d" l+ n# r/ o$ _7Y5 BZV49-C7V5 Phi O SOT89 7.5V 1W zener
; c6 B4 X8 N3 G: \: V9 G5 w7Z MMBR951L Mot N SOT23 npn RF fT7.5GHz MRF951
. _% A7 C: o: D1 B+ P& K8 (yellow) BBY58-03W Sie I SOD323 varicap
0 r K* S0 f5 O7 ?: V# f, p81A MMBZ5250B Mot C SOT23 20V zener 0.225W ?: a9 \3 [ F
81A PMBZ5250B Phi C SOT23 20V zener 0.225W1 B5 K, T# H9 t. s
81B MMBZ5251B Mot C SOT23 22V zener 0.225W
" S9 {: H( w' I. B/ g* Q" C! b81B PMBZ5251B Phi C SOT23 22V zener 0.225W
* S( h5 f# l4 ~: I) M+ b0 U81C MMBZ5252B Mot C SOT23 24V zener 0.225W4 J$ S* f) b+ ~# W! i t5 w
81C PMBZ5252B Phi C SOT23 24V zener 0.225W' A; Z# t" S. c; `! J: x3 I3 \# E1 a
81D MMBZ5253B Mot C SOT23 25V zener 0.225W5 }5 P% @3 `. f8 A8 l
81D PMBZ5253B Phi C SOT23 25V zener 0.225W L5 x- Q0 i" v: ?; _7 `
81E MMBZ5254B Mot C SOT23 27V zener 0.225W
$ @; o4 B# T, z* J. S81E PMBZ5254B Mot C SOT23 27V zener 0.225W
$ K4 s h& W- i% G+ O: [4 [4 v7 u81F MMBZ5255B Mot C SOT23 28V zener 0.225W3 |" O1 L, D3 E& ?6 f$ [
81F PMBZ5255B Sie C SOT23 28V zener 0.225W" k# W* ~. |7 ?6 U
81G MMBZ5256B Mot C SOT23 30V zener 0.225W
* u! z, e( ]8 I8 u( i81G PMBZ5256B Phi C SOT23 30V zener 0.225W
/ g7 Q+ Y8 u9 f! Q' f81H MMBZ5257B Mot C SOT23 33V zener 0.225W9 X1 ?7 m M( q9 E% g3 z/ |
81H PMBZ5257B Phi C SOT23 33V zener 0.225W
1 u8 h* S8 ~: g' l82P BFP182T Tfk X - npn RF fT 7.5GHz 10V 35mA0 K" c3 s" W) i6 x7 B
83P BFP183T Tfk X - npn RF fT 7.4GHz 10V 65mA
+ d* w) u3 g/ C u' i83s BAT68 Sie C SOT23 gp Schottky 8V 130mA
( [- w+ C, ]" X+ D/ O83s BAT68W Sie C SOT323 gp Schottky 8V 130mA% m' L: l# x4 Y& c
84s BAT68-04 Sie D SOT23 dual ser gp Schottky 8V 130mA& C* Q" r) x" O e% N
84s BAT68-04W Sie D SOT323 dual ser gp Schottky 8V 130mA' G5 b! G$ H7 h% Q: ]4 r% F
85s BAT68-05 Sie B SOT23 gp dual cc Schottky 8V 130mA
9 ~4 J$ c8 |; B9 Y% z) o3 G1 q85s BAT68-05W Sie B SOT323 gp dual cc Schottky 8V 130mA
5 k9 z+ x5 `4 E4 R9 N4 E) w86s BAT68-06 Sie A SOT23 gp dual ca Schottky 8V 130mA) I# A3 F1 `: e- Y" E. Z% Z! T: k4 ?& m
86s BAT68-06W Sie A SOT323 gp dual ca Schottky 8V 130mA
2 y* a& Y" K9 |% J4 V87s BAT68-07 Sie S SOT143 gp dual schottky 8V 130mA' g: M4 A% i; h; l; S2 |3 t
8A NJM78L02A NJR KQ SOT89 78L 2.0V 0.1A regulator) d8 j$ U$ T" }" r; ~
8A MMBZ5226B Mot C SOT23 3.3V zener 0.225W
; @0 G# O7 C, D. s8A MUN2211 Mot N SOT23 npn dtr 10k +10k
; ~) F' s- O# d0 N3 G8A MUN5211 Mot N SOT323 npn dtr 10k +10k( a+ G, N2 a6 ?: m* \; o: ^. b" I
8A2 PZM8.2NB2A Phi C SOT23 dual ca 8.2V 0.3W zener
! p k! b+ T1 j. o; ?$ c8B NJM78L03A NJR KQ SOT89 78L 3.0V 0.1A regulator
9 u1 l: U3 b; |/ m; G" n8B MMBZ5227B Mot C SOT23 3.6V zener 0.225W
7 s/ p f, f/ O8B MUN2212 Mot N SOT23 npn dtr 22k+22k
6 H0 S! c, }$ J4 f- I0 k8B MUN5212 Mot N SOT323 npn dtr 22k+22k X' j$ g% I2 d+ l
8C NJM78L05A NJR KQ SOT89 78L 5.0V 0.1A regulator
' ]( C% s3 I% a8C MMBZ5228B Mot C SOT23 3.9V zener 0.225W6 g9 r/ k& H: K, u9 {0 E0 x: ^
8C MUN2213 Mot N SOT23 npn dtr 47k + 47k
$ C0 a6 |0 ?/ y" f8C MUN5213 Mot N SOT323 npn dtr 47k + 47k
- f- s6 e4 p7 V9 s- j8D MUN2214 Mot N SOT23 npn dtr 10k + 47k7 G# H- M$ m' X' I
8D MUN5214 Mot N SOT323 MUN22146 g" f7 K7 w& v! x. n" \( \ o9 f
8E NJM78L06A NJR KQ SOT89 78L 6.0V 0.1A regulator0 }% Z1 q/ F9 Y2 C N5 Z: m
8E FMMT-A92R Zet R SOT23R MPSA926 e$ _9 Q' K, x- X
8E MMBZ5230B Mot C SOT23 4.7V zener 0.225W
" E. ^( O, b' Y3 p+ _8E MUN2215 Mot N SOT23 npn dtr R1 10k
) s' ?8 D6 [$ o$ f J8E MUN5215 Mot N SOT323 npn dtr R1 10k
9 p7 [# D% l. Z# s6 Z4 m: r8F NJM78L07A NJR KQ SOT89 78L 7.0V 0.1A regulator
( U' o) s) `$ F9 m8F MMBZ5231B Mot C SOT23 5.1V zener 0.225W' K* o5 t4 C9 b* }% G
8F MUN2216 Mot N SOT23 npn dtr R1 4k7
- O H+ p, s) T7 _8F MUN5216 Mot N SOT323 MUN22166 U4 x$ z V0 d6 p+ [' ~& H! Y! t
8G NJM78L08A NJR KQ SOT89 78L 8.0V 0.1A regulator
5 t% n) m* d, k8G MMBZ5232B Mot C SOT23 5.6V zener 0.225W F3 x/ x9 s, l
8G MUN2230 Mot N SOT23 npn dtr 1k0+1k0! C; a, W" L! \8 q; }
8G MUN5230 Mot N SOT323 npn dtr 1k0+1k0- ?/ H6 ^ j2 o" i0 {
8H NJM78L09A NJR KQ SOT89 78L 9.0V 0.1A regulator9 Q6 `$ U' i1 [0 S6 x" d z
8H MMBZ5233B Mot C SOT23 6.0V zener 0.225W
. s! u* d' p G6 d7 F' j. o8H MUN2231 Mot N SOT23 npn dtr 2k2+2k2 w' b$ w7 t% B& x6 P5 G/ z8 j
8H MUN5231 Mot N SOT323 npn dtr 2k2+2k2+ G8 h" c/ U6 u8 ]4 S& ]1 i
8J NJM78L10A NJR KQ SOT89 78L 10V 0.1A regulator
! }0 P7 l @6 ]- H8J MMBZ5234B Mot C SOT23 6.2V zener 0.225W0 I! ~8 W" \* y4 @) j+ T
8J MUN2232 Mot N SOT23 npn dtr 4k7+ 4k7/ k/ o f; @$ ?9 Z! u: |6 }7 r
8J MUN5232 Mot N SOT323 npn dtr 4k7+ 4k7, m9 k/ Y1 ]& C. }' g
8K NJM78L12A NJR KQ SOT89 78L 12V 0.1A regulator
8 x8 A. C/ L D# d9 H2 L' ]8K MMBZ5235B Mot C SOT23 6.8V zener 0.225W
- b6 F/ `, b+ a8K MUN2233 Mot N SOT23 npn dtr 4k7+ 47k' E. F; L& [0 {/ _
8K MUN5233 Mot N SOT323 npn dtr 4k7+ 47k
0 M+ Y, B6 o j8L NJM78L15A NJR KQ SOT89 78L 15V 0.1A regulator
: r# D t# m1 D" j8L MMBZ5236B Mot C SOT23 7.5V zener 0.225W
% `7 v+ W; [* r: S) p1 R+ W8L MUN2234 Mot N SOT23 npn dtr 22k + 47k
, |+ d" Q: a9 S0 c8 x8L MUN5234 Mot N SOT323 npn dtr 22k + 47k
) l6 F. r7 f; I! a8M NJM78L18A NJR KQ SOT89 78L 18V 0.1A regulator* X/ B/ B" R1 d
8M MMBZ5237B Mot C SOT23 8.2V zener 0.225W
: M6 F$ U. L$ Q. I8N NJM78L20A NJR KQ SOT89 78L 20V 0.1A regulator3 P4 r4 w$ a) c) b/ W8 I, j
8N MMBZ5238B Mot C SOT23 8.7V zener 0.225W% e& r$ A# v' g+ Z% e, B
8P NJM78L24A NJR KQ SOT89 78L 24V 0.1A regulator+ O2 Z5 N2 G( b$ g% K2 n
8P MMBZ5239B Mot C SOT23 9.1V zener 0.225W1 Q( e) q" U7 [6 Z! v# n4 H/ {
8Q MMBZ5240B Mot C SOT23 10V zener 0.225W3 ?6 T6 ~- W! O, w, ^
8R MMBZ5241B Mot C SOT23 11V zener 0.225W. n* C' G' S, Q" B' i7 }2 ~5 Q
8S MMBZ5242B Mot C SOT23 12V zener 0.225W. Q. ?9 D/ O n; K; x; O9 w+ M' U- y
8T MMBZ5243B Mot C SOT23 13V zener 0.225W
9 g/ B/ o& w! B- O% V- @9 B8U MMBZ5244B Mot C SOT23 14V zener 0.225W
; C ]& o# M. f0 X8V MMBZ5245B Mot C SOT23 15V zener 0.225W
& S/ T. O5 F2 _. y9 z/ Z8V2 PZM8.2NB Phi C SOT23 8.2V 0.3W zener& G' C3 x" w6 f$ ?3 C+ j' B4 X% `
8W MMBZ5246B Mot C SOT23 16V zener 0.225W" Y) T# V9 T* [$ i; _1 Y
8X MMBZ5247B Mot C SOT23 17V zener 0.225W% {( r/ q: l" K. |' T' O' s
8Y MMBZ5248B Mot C SOT23 18V zener 0.225W
. J7 G1 Y+ I* g) ^, h3 l+ \7 l8Y2 BZV49-C8V2 Phi O SOT89 8.2V 1W zener
, l; ?6 \7 C* o; |) u3 \9 i# d& _: [8Z NJM78L62A NJR KQ SOT89 78L 6.2V 0.1A regulator
) h$ e; X5 v* s n9 M0 _+ l8Z MMBZ5249B Mot C SOT23 19V zener 0.225W F: R; E% \* C; t
91A FMMT730A Zet N SOT23 pnp 40V 1A 0.5W fT 150 MHz
$ d6 l; ~" \. [92V BFP92A Tfk W - npn RF 6GHz 16V 30mA
' _( B# v4 J+ f/ {( u9A FMMT2369AR Zet R SOT23 2N2369A$ y2 U" R/ |% \6 E
9A DTA125TUA Roh N SC70 pnp dtr R1 200k 50V 100mA
! K' M1 D$ N& K; E) f5 ^7 K4 r9A DTA125TKA Roh N SC59 pnp dtr R1 200k 50V 100mA% c! H! v( U, [/ T
9A PLVA650A Phi C SOT23 5.0V avalanche reg diode. p' |* u4 V$ z7 Y! M" _' r6 V4 F9 Y
9A1 PZM9.1NB2A Phi A SOT346 dual ca 9.1V 0.3W zener. Z, s+ V& w" B8 I
9B NJM79L03UA NJR KQR SOT89 79L reg 3.0V 0.1A; D& C) s! t3 c) K& p( B* w0 R
9B PLVA653A Phi C SOT23 5.3V avalanche reg diode
% R9 o; \& n9 _# ?- G1 r9C NJM79L05UA NJR KQR SOT89 79L reg 5.0V 0.1A% d( g& [9 ]% t
9C PLVA656A Phi C SOT23 5.6V avalanche reg diode; B3 I0 e3 J- Y# h' P+ b
9D PLVA659A Phi C SOT23 5.9V avalanche reg diode) E2 Y8 d$ ]0 t: i! F; V
9E NJM79L06UA NJR KQR SOT89 79L reg 6.0V 0.1A
6 r+ G+ Q$ }# q' N( Z9E PLVA662A Phi C SOT23 6.2V avalanche reg diode
% I4 N1 i6 i* x9 N( r' E! T9F PLVA665A Phi C SOT23 6.5V avalanche reg diode5 E5 b i h$ I% S0 p, s* h
9G NJM79L08UA NJR KQR SOT89 79L reg 8.0V 0.1A
4 q( e5 c# p, y( z9G PLVA668A Phi C SOT23 6.8V avalanche reg diode
; P- I* M W, W7 i+ t: \' H9H NJM79L09UA NJR KQR SOT89 79L reg 9.0V 0.1A
' J4 o( _, t) j, Z' L$ v. e( d9J PLVA2650A Phi A SOT23 dual ca 5.0V reg diode( A( D3 s) y, O3 _( _
9K NJM79L12UA NJR KQR SOT89 79L reg 12V 0.1A
: T- V6 `' H: N" M h8 F9K PLVA2653A Phi A SOT23 dual ca 5.3V reg diode1 ~- f/ M5 B. B
9L NJM79L15UA NJR KQR SOT89 79L reg 15V 0.1A7 i3 \5 N9 u7 m9 p
9L PLVA2656A Phi A SOT23 >dual 5.60V reg diode
. A, J" m4 f( v5 Z {8 t9 @ \& Y9M NJM79L18UA NJR KQR SOT89 79L reg 18V 0.1A
0 X, u! Y3 b6 e a3 t9 p, {9M PLVA2659A Phi A SOT23 dual ca 5.9V reg diode
0 v$ U$ i2 N6 G, `% q/ O9N PLVA2662A Phi A SOT23 dual ca 6.2V reg diode/ _; P$ @6 h6 A5 I6 |1 S3 Y
9O PLVA2665A Phi A SOT23 dual ca 6.5V reg diode4 C1 U3 L9 p8 W0 k. C
9P NJM79L24UA NJR KQR SOT89 79L reg 24V 0.1A* Y+ U( f/ X j+ i* n& d
9P PLVA2668A Phi A SOT23 dual ca 6.8V reg diode
2 {6 \6 K) ^7 C: k; R( M( M* ]. m9P BCX70HR Zet R SOT23 BCX70H5 m9 g! Q* o9 J; a* m7 o) C. N
9R FMMT2369R Zet R SOT23 2N2369, E( n3 d" i D$ O
9V1 PZM9.1NB Phi C SOT346 9.1V 0.3W zener+ ]( k: }' |" f. T4 ]
9Y1 BZV49-C9V1 Phi O SOT89 9.1V 1W zener X! y9 R3 ?3 f
A MRF947 Mot N SOT323 npn RF 8 GHz8 u) @, F; W4 e4 s$ p3 d, ^( v+ O3 y
A BA892 Sie I SCD80 35V 100mA pin / I4 {; I6 c% H8 p, ?
A 1SS355 Roh I USM 100V 50mA sw & T7 O) ]/ c" r6 a: P! d
A0 HSMS-2800 HP C SOT23 HP2800 schottky9 E/ C5 T: V! O" o9 x
A0 HSMS-280B HP C SOT323 HP2800 schottky
$ M' i7 j: R& e$ \: s3 Z% YA03 VAM-03 MC AQ - modamp MAR 3 Similar3 l: D3 ~; I! {* i5 s7 Z
A06 VAM-06 MC AQ - modamp MAR 6 Similar
+ s( Y1 k$ m9 A( \ {A07 VAM-07 MC AQ - modamp MAR 7 Similar, K: j' d! t5 ]; Y/ k( h: z: f
A1 HSMS-2801 HP K - HP2800 schottky
. B; V4 j0 y1 b5 oA1 BAW56W Phi A SOT323 dual ca BAW62 (1N4148), n# b6 `5 Z5 d8 Y
A1 BAW56 Phi A SOT23 dual ca BAW62 (1N4148)4 Y) q2 s+ k1 e( h; K" V9 B
7 D2 G0 g* l; N; ?( ?5 W' O: v ~% iA11 MMBD1501A Fch C SOT23 180V 200mA diode
# b9 b2 F3 S/ n7 m8 {; _A13 MMBD1503A Fch D SOT23 180V 200mA dual diode series
4 K" u5 l, i1 N, ^1 R1 o. ~A14 MMBD1504A Fch B SOT23 180V 200mA dual diode cc
1 d" l4 C) o+ ]+ \A15 MMBD1505A Fch A SOT23 180V 200mA dual diode ca
; R$ {2 l& B. b; OA16 ZC934A Zet C SOT23 25-95pF hyperabrupt varicap ! }' t# M, _; w* P$ C! E
A17 ZC933A Zet C SOT23 12-42pF hyperabrupt varicap $ q6 h. r- k: {# y T
A1p BAW56 Phi A SOT23 dual ca BAW62 (1N4148)
" @% I0 ]$ Z( H' p; E& DA1s BAW56W Sie A SOT323 dual ca BAW62 (1N4148)" z4 G! @' m" H
A1s BAW56 Sie A SOT23 dual ca BAW62 (1N4148)% ?8 x, h. [. i4 E' v* S
A1s BAW56U Sie A SC74 dual ca BAW62 (1N4148)) s+ U- E5 ?+ T3 H4 G5 G; l
A1t BAW56T Phi A SOT416 dual ca BAW62 (1N4148)
( [1 U, J8 F& `7 H# LA1t BAW56S Phi SOT363 dual ca BAW62 (1N4148)% x: V) u% b, `9 O. ~
A1X MBAW56 Mot A - ditto+ T, q" J g! B$ D9 k: b
A2 HSMS-2802 HP D SOT23 dual HP2800
0 g- N2 A' _+ A F1 t5 JA2 HSMS-280C HP D SOT323 dual HP28002 u% Q% b: |# q4 J2 I
A2 BAT18 Phi C SOT23 BA482" R$ J) B" b4 L0 f. ~' g( B
A2 MMBD2836 Mot A SOT23 dual ca sw diode 75V
6 m& Z, M' i5 ?2 ^4 _/ ?A2 CFY30 Sie CQ SOT143 n-ch GaAsfet 6 GHz
* _% K+ V( h+ o; `' s' V2 OA2 MBT3906DW1 Mot DO SOT363 dual 2N3906 v, J) s! @$ O6 I
A22 BAS21 Phi C SOD27 BAV21: y4 \5 ^- _& L
A2s BAT18 Sie C SOT23 BA482
4 ?# ?8 x& |; P+ M/ y7 TA2X MMBD2836 Mot A SOT23 dual ca sw 75V 100mA 15ns8 B- Q& z' C- c
A3 BAP64-03 Phi I SOD323 3 GHz pin diode
# [# @8 l3 M% [9 d9 ]- Y* NA3 HSMS-2803 HP D SOT23 HP2800 ser pair
. l$ H4 }- O; I" Z$ y+ U! O- {A3 MMBD1005 Mot A SOT23 dual ca Si diode low leakage
0 ^7 M% _ x0 }, r) uA3 BAS16 Zet C - Si sw 75V 100mA% J# z# V, g( K" i: M" v
A3 BAT17 Phi C SOT23 BA481) z8 ~. a4 P2 z) H
A3 MBT3906DW Mot N SOT363 dual 2N3906
8 R( Z1 a& e$ x; }; G R2 RA3p BAT17 Phi C SOT23 BA4818 b' w1 [- `$ V; _9 `% C- O
A3t BAT17 Phi C SOT23 BA481- @0 A m- N5 o( ?% w6 ^3 c
A3X MMBD2835 Mot A SOT23 dual ca sw 35V 100mA 15nS
) t' _/ l6 E5 |' A) EA4 HSMS-2804 HP B SOT23 dual cc HP2800 schottky& K6 {3 U! e* L( u* L+ v6 S
A4 BAV70W Phi B SOT323 dual cc BAW62
5 Z8 u {/ P$ {A4p BAV70 Phi B SOT23 dual cc BAW62
* G$ x" Q, {: e. Q% aA4s BAV70W Sie B SOT323 dual cc BAW62: q9 Q3 U Q( s% u+ r4 V b- ~/ x
A4s BAV70 Sie B SOT23 dual cc BAW62
$ [2 N" V6 Q9 y$ P; H1 e0 Q0 VA4s BAV70T Sie B SOT416 dual cc BAW62
( w$ q. n3 T9 q( y2 {/ iA4s BAV70U Sie B SC74 dual cc BAW62
7 s s# `; v" Q! y( B2 CA4t BAV70 Phi B SOT23 dual cc BAW62+ Y% }# _2 I- @& [8 Y
A4t BAV70 Phi B SOT363 dual cc BAW62
, g a/ U# \7 F" WA4X MBAV70 Mot B - ditto
/ i9 v/ j& v0 b; F4 AA5 BAP51-03 Phi I SOD323 GP RF pin diode
: R9 j+ i3 k; e) F8 L* z2 }A5 HSMS-2805 HP S SOT143 dual HP2800 schottky
# T1 F4 E+ m! l$ o6 b/ m7 l+ w/ [A5 MMBD1010 Mot B SOT23 dual cc Si diodes
& v% Y, k) D; O7 v9 E5 y* uA5 MMBD2837 Mot B SOT23 dual cc diodes 30V 150mA
, b% t" ^" m1 \% u: X" q% _A51 BRY62 Phi - SOT143 -) z" k2 S) j; n$ Q
A5p BRY61 Phi - SOT143 -5 A5 w' h; A; i: n
A5t BRY61 Phi - SOT143 -
% p+ h5 i& z0 q3 M8 G0 WA6 BAS16W Phi C SOT323 BAW62 (1N4148)/ M- l2 Z( H' i5 P/ I
A6 BAS16T Phi C SOT416 BAW62 (1N4148)
8 d$ h8 o3 p3 H: S1 Z0 p+ MA6 BAS216 Phi I SOD110 BAW62 (1N4148)6 s; a& u9 A" |. F5 d7 L& m! r5 ~
A6 MMBD2836 Mot B SOT23 dual sw diode cc 75V3 _: i3 f9 ?) B3 P |8 a# }3 @
A6A MMUN2111 Mot N SOT23 pnp dtr 10k+10k
2 ?: @( v9 H4 T3 }A6B MMUN2112 Mot N SOT23 pnp dtr 22k+22k3 u! p. B" C( [, H$ k) J* u+ L" z
A6C MMUN2113 Mot N SOT23 pnp dtr 47k+47k% C& r, }' r. V* T7 e( ~& @% E
A6D MMUN2114 Mot N SOT23 pnp dtr 100k+100k
. |0 P3 z3 c7 j6 V, O3 qA6E MMUN2115 Mot N SOT23 pnp dtr R1 10k
3 s$ n Y$ w. m0 W8 J0 IA6F MMUN2116 Mot N SOT23 pnp dtr R1 4k78 Y9 N2 {5 d8 ^! ]" U- [; s
A6G MMUN2130 Mot N SOT23 pnp dtr 1k0+1k0
8 a7 w% G* A! k1 k4 t. k; \. jA6H MMUN2131 Mot N SOT23 pnp dtr 2k2+2k2% h; ^* d" s/ u- t4 g/ `
A6J MMUN2132 Mot N SOT23 pnp dtr 4k7+4k7/ z* ^# K% R- g% @0 Z* n
A6K MMUN2133 Mot N SOT23 pnp dtr 4k7+47k
+ F; Y( W7 q3 q5 Q) P: u; gA6L MMUN2134 Mot N SOT23 pnp dtr 22k+47k
: A7 C3 H! |$ F; S+ q0 y( PA6p BAS16 Phi C SOT23 BAW62 (1N4148)
1 S8 f \( V" f" ~$ }' VA6p BAS316 Phi I SOD323 BAW62 (1N4148)! q" a# G/ I' {% I% T: L
A6s BAS16W Sie C SOT323 BAW62 (1N4148)
. G+ c+ z9 z5 y5 f: [8 JA6s BAS16 Sie C SOT23 BAW62 (1N4148)( J+ W/ q* q* z
A6s BAS16U Sie C SC74 BAW62 (1N4148)+ K8 {0 G3 C; z6 T, o' i0 D4 o+ d
A6t BAS16 Phi C SOT23 BAW62 (1N4148)
0 B0 `0 T+ b0 x4 T! N0 ]A6X MMBD2838 Mot B SOT23 dual sw 50V 100mA9 ^% z! D6 v; M8 h4 A& I
A7 BAV99W Phi D SOT323 dual ser BAW92
4 c. m& f8 ]. S. bA7 BAV99 Phi D SOT23 dual ser BAW92
1 M( q' l4 @, G$ ^A7 HSMS-2807 HP RQ SOT143 HP2800 ring quad$ q/ _6 T: q9 w5 \
A7s BAV99 Sie D SOT23 dual ser BAW92+ P' o' i. T/ P" a4 y$ X. l9 K5 V
A7s BAV99W Sie D SOT323 dual ser BAW92
) i( E, g/ f0 {+ a8 c1 z3 ?, q& nA7s BAV99T Sie D SC75 dual ser BAW924 s6 \2 t8 q# ]& Z+ z
A7s BAV99U Sie D SC74 dual ser BAW92! V: O& S. ]! e% P, y
A8 HSMS-2808 HP BQ SOT143 HP2800 bridge quad% I7 U B$ C: q: J K
A8 BAP50-03 Phi I SOD323 GP RF pin diode3 ~3 g& K+ l' \$ d- }4 L) N3 g
A8 BAS19 Phi C SOT23 BAV19" W5 @$ [9 M& m; n9 B! o2 B) f. H f
A8 SI2308DS Sil M SOT23 "N-ch mosfet, 60V 0.1A"
: g) G3 b5 n8 J, ], e iA81 BAS20 Phi C SOT23 BAV20( B+ Y7 ~1 u% [* s W" u( X( H2 P
A82 BAS21 Phi C SOT23 BAV21) t: K9 s' l4 `" `) R7 s) w$ J# Y
A8A MMUN2211 Mot N SOT23 npn dtr 10k +10k
+ i2 J/ |9 L0 d" V- P8 cA8B MMUN2212 Mot N SOT23 npn dtr 22k +22k
; h1 U9 y- d& T* P3 ~A8C MMUN2213 Mot N SOT23 npn dtr 47k+47k& ]$ f' z: W* P" ` {) K5 L1 _- C
A8D MMUN2214 Mot N SOT23 npn dtr 100k+100k
; @. u' f" M6 E4 y2 U( W! c" j& b* |A8E MMUN2215 Mot N SOT23 npn dtr R1 10k
% I! z+ A! ~: U& l% H0 k& xA8F MMUN2216 Mot N SOT23 npn dtr R1 4k7
+ @/ K$ p, V7 W, [+ P; I9 lA8G MMUN2230 Mot N SOT23 npn dtr 1k0 +1k0; r% ~5 g. l* w$ J9 z' q r0 @* x
A8H MMUN2231 Mot N SOT23 npn dtr 2k2+2k2
4 J: W; v& m' S9 `4 e7 t! C0 gA8J MMUN2232 Mot N SOT23 npn dtr 4k7+4k7/ m: i' A5 G) e. S, s
A8K MMUN2233 Mot N SOT23 npn dtr 4k7+47k
9 H; U( N2 B5 c3 I9 B; KA8L MMUN2234 Mot N SOT23 npn dtr 22k+47k
g" G6 P4 v3 }, v7 P, z1 g( J9 Z% }A9 SI2309DS Sil M SOT23 "P-ch mosfet, 60V 0.1A"9 a' F" S* S/ E) l! M4 N6 v) R5 ~& Y# p
A91 BAS17 Phi C SOT23 BA314
$ u, ~* U( Q8 l# i( `: Y+ S" O7 hAA BCX51 Sie P SOT89 pnp 45V audio comp BCX54
; j7 o O9 M+ |AA BCW60A TT N SOT23 BCY58-vii
# Q% Y" ^: ~. h) C; U! SAA ZMV829A Zet I SOD323 varicap hyperabrupt 28V [email=8.2pF@2V]8.2pF@2V[/email]
: X7 p1 I; T" g0 `5 I* n8 x8 E2 dAAA MMBF4856 Mot F SOT23 2N4856 n-ch chopper jfet; c& M5 Q% d* g4 u3 c7 l
AAAA MAX809LXR MAX ZB SOT23 microproc -ve reset gen 5.0V
1 o! |0 A- p; `. ^5 w8 G+ v* C) rAAAX MAX2470 MAX DT SOT23-6 VCO Buffer Amplifiers+ l; l ~0 F5 w* {# L3 z) L
AAAY MAX2471 MAX DT SOT23-6 VCO Buffer Amplifiers
3 f* ^" E6 s2 S9 kAAG MMBR951AL Mot N SOT23 npn RF 8GHz5 l, E5 I* u% ^ E
AAH MAX6326_R22-T Max ZB SC70 microproc -ve reset gen 2.200V
" X# l2 e" p1 AAAI MAX6327_R22-T Max ZB SC70 microproc +ve reset gen 2.200V x3 H* I1 d) {$ Q
AAJ MAX6328_R22-T Max ZB SC70 microproc -ve reset gen 2.200V
$ r3 o% K h8 ]: z$ B' eAAK MAX6410BS33-T Max UC4 UCSP-4 "Volt. Detect. (3.300 V / Push-Pull,Active-High)"
0 m3 [; N# i3 s. J& s# [8 FAAL MAX6410BS34-T Max UC4 UCSP-4 "Volt. Detect. (3.400 V / Push-Pull,Active-High)"
* [+ }- C+ I+ z) }3 OAAM MAX6410BS35-T Max UC4 UCSP-4 "Volt. Detect. (3.500 V / Push-Pull,Active-High)"/ O' @7 x( o! u4 n% M4 G& Q
AAN MAX6410BS36-T Max UC4 UCSP-4 "Volt. Detect. (3.600 V / Push-Pull,Active-High)"/ Q& _: X, X8 [
AAN MAX809LXR Max ZB SC70 microproc -ve reset gen 5.0V- D' \ R5 M* s0 w+ L
AAO MAX6410BS37-T Max UC4 UCSP-4 "Volt. Detect. (3.700 V / Push-Pull,Active-High)"2 J) k( D0 ~6 N
AAO MAX809MXR Max ZB SC70 microproc -ve reset gen 5.0V4 e" S8 L! `/ d5 J+ b+ k" s
AAP MAX6410BS38-T Max UC4 UCSP-4 "Volt. Detect. (3.800 V / Push-Pull,Active-High)": A7 O# [0 k4 u q" C
AAP MAX809TXR Max ZB SC70 microproc -ve reset gen 3.3V8 g. ^: ~( a$ M# O0 ]( V% M
AAQ MAX6410BS39-T Max UC4 UCSP-4 "Volt. Detect. (3.900 V / Push-Pull,Active-High)"( t! w0 z; d; Z: s- u0 a: h
AAQ MAX809SXR Max ZB SC70 microproc -ve reset gen 3.3V; N. o' _9 {' p( e/ `
AAR MAX6410BS40-T Max UC4 UCSP-4 "Volt. Detect. (4.000 V / Push-Pull,Active-High)"
2 F; q- L% c" Y* OAAR MAX809RXR Max ZB SC70 microproc -ve reset gen 3.0V
. L/ g# N8 N. I: I$ rAAs BCW60A Sie N SOT23 BCY58-vii
% U. p3 `0 o+ z3 K9 h. w8 Y' aAAS MAX6410BS41-T Max UC4 UCSP-4 "Volt. Detect. (4.100 V / Push-Pull,Active-High)"
2 u E( h/ h% h7 f g6 N, nAAS MAX803ZXR Max ZB SC70 microproc -ve reset gen 2.5V7 f/ ?. B5 |: v N) c
AAT MAX6410BS42-T Max UC4 UCSP-4 "Volt. Detect. (4.200 V / Push-Pull,Active-High)"
# y K* C" X, M( } }, Z9 y) VAAT MAX810LXR Max ZB SC70 microproc +ve reset gen 5.0V4 Z/ a- ]; C3 F
AAU MAX6410BS43-T Max UC4 UCSP-4 "Volt. Detect. (4.300 V / Push-Pull,Active-High)"
7 m& X. V/ @' \% d) F SAAU MAX810MXR Max ZB SC70 microproc +-ve reset gen 5.0V, r5 _% a/ Y* e0 o; S1 x0 _
AAV MAX6410BS44-T Max UC4 UCSP-4 "Volt. Detect. (4.380 V / Push-Pull,Active-High)"% |1 s+ U8 R0 Z
AAV MAX810TXR Max ZB SC70 microproc +ve reset gen 3.3V# s. Z3 q! p3 A j% X; F
AAW MAX6410BS45-T Max UC4 UCSP-4 "Volt. Detect. (4.500 V / Push-Pull,Active-High)"# ^( _) y; t: O$ A' d9 i' Q0 s
AAW MAX810RXR Max ZB SC70 microproc +ve reset gen 3.0V
7 I( n+ ]# e! p5 Q1 b& o: fAAX MAX6410BS46-T Max UC4 UCSP-4 "Volt. Detect. (4.630 V / Push-Pull,Active-High)"! @$ V8 A6 A" z
AAX MAX810SXR Max ZB SC70 microproc +ve reset gen 3.3V! {4 ]& v- M$ h- o8 ^3 i7 I' r4 W$ q
AAY MAX6411BS33-T Max UC4 UCSP-4 "Volt. Detect. (3.300 V/Open Drain,Active-Low)"
/ B, T9 Y$ m) o: h# xAAY MAX810ZXR Max ZB SC70 microproc +ve reset gen 2.5V4 u. w3 ^+ J! U. k" Z
AAZ MAX6411BS34-T Max UC4 UCSP-4 "Volt. Detect. (3.400 V/Open Drain,Active-Low)"
' X: ~3 q9 u4 W( h; aAAZ MAX803LXR Max ZB SC70 microproc -ve reset gen 5.0V- |9 W( I4 D$ P8 p. U
AB BCW60B ITT N SOT23 BCY58-viii
6 Z) T" ^" m6 ^# w! {AB ZMV830A Zet I SOD323 varicap hyperabrupt 28V [email=10pF@2V]10pF@2V[/email]4 O- f3 g u" y( Z& v% ^* y
ABA MAX6411BS35-T Max UC4 UCSP-4 "Volt. Detect. (3.500 V/Open Drain,Active-Low)"
; Y& o6 b& [6 nABA MAX803TXR Max ZB SC70 microproc -ve reset gen 5.0V" q- a; j: X, Z
ABAA MAX809MXR Max ZB SOT23 microproc -ve reset gen 5.0V& i) X `0 q7 b* `# x. m- ^; q1 a: C1 I
ABB MAX6411BS36-T Max UC4 UCSP-4 "Volt. Detect. (3.600 V/Open Drain,Active-Low)"# g( p" ^) P2 z5 [' i: r$ e9 D! l
ABB MAX803MXR Max ZB SC70 microproc -ve reset gen 3.3V) t: s% l) B* @4 h
ABC MAX6411BS37-T Max UC4 UCSP-4 "Volt. Detect. (3.700 V/Open Drain,Active-Low)"9 J5 {, b$ M2 M; {5 \) ~* F. }! a9 p+ l
ABC MAX803SXR Max ZB SC70 microproc -ve reset gen 3.3V
" _7 ^$ G4 q4 iABD MAX6411BS38-T Max UC4 UCSP-4 "Volt. Detect. (3.800 V/Open Drain,Active-Low)"
8 E; R' Q4 `4 X' T% LABD MAX803RXR Max ZB SC70 microproc -ve reset gen 3.0V
7 M; n7 J7 j9 Z+ c, L% ]/ A5 d! KABE MAX6411BS39-T Max UC4 UCSP-4 "Volt. Detect. (3.900 V/Open Drain,Active-Low)"
6 V4 E( a6 s: L) cABE MAX803ZXR Max ZB SC70 microproc -ve reset gen 2.5V' m0 w6 F) R" ]
ABF MAX6411BS40-T Max UC4 UCSP-4 "Volt. Detect. (4.000 V/Open Drain,Active-Low)"
( `- G- I8 n$ q( z8 gABF LM4041AIX3-1.2 Max L SC70 1.225V 0.1% shunt V ref
& ?$ W# i1 \- i% ^$ [ABG MAX6411BS41-T Max UC4 UCSP-4 "Volt. Detect. (4.100 V/Open Drain,Active-Low)"
- K# S: c$ W, ~0 {0 ]ABG LM4041BIX3-1.2 Max L SC70 1.225V 0.2% shunt V ref2 C p a# K% y K2 F
ABH MAX6411BS42-T Max UC4 UCSP-4 "Volt. Detect. (4.200 V/Open Drain,Active-Low)"- B- b- [% j& p3 c+ B
ABH LM4041DIX3-1.2 Max L SC70 1.225V 0.5% shunt V ref" O" q% ^( K7 ~" t. I% u
ABI MAX6411BS43-T Max UC4 UCSP-4 "Volt. Detect. (4.300 V/Open Drain,Active-Low)"
5 X0 O9 U; n- [! P! i+ } a: eABI LM4041DIX3-1.2 Max L SC70 1.225V 1.5% shunt V ref
* F# ~* H- h0 q% @- U# }ABJ MAX6411BS44-T Max UC4 UCSP-4 "Volt. Detect. (4.380 V/Open Drain,Active-Low)"
. ?6 z2 l) n. V r tABJ LM4040AIX3-2.1 Max L SC70 2.048V 0.1% shunt V ref
. d9 v7 E1 B: H* R0 FABK MAX6411BS45-T Max UC4 UCSP-4 "Volt. Detect. (4.500 V/Open Drain,Active-Low)"
4 U3 N+ l# x7 {9 {& rABK LM4040BIX3-2.1 Max L SC70 2.048V 0.2% shunt V ref3 H6 t' e' O0 a$ C
ABL MAX6411BS46-T Max UC4 UCSP-4 "Volt. Detect. (4.640 V/Open Drain,Active-Low)"
. h+ j4 z% D6 w$ `0 x* `ABL LM4040CIX3-2.1 Max L SC70 2.048V 0.5% shunt V ref1 B' a+ }* L) ?. _% G" {9 m
ABM LM4040DIX3-2.1 Max L SC70 2.048V 1% shunt V ref0 S! f# l s `2 z/ {
ABN LM4040AIX3-2.5 Max L SC70 2.5001% shunt V ref
Q' Y* x' x* R$ [! C2 G$ E1 OABO LM4040BIX3-2.5 Max L SC70 2.500V 0.2% shunt V ref2 o% E) Z" S9 `- X
ABp BCW60B Phi N SOT23 BCY58-viii
- H( ?6 g' Q3 k5 _ABP LM4040CIX3-2.5 Max L SC70 2.500V 0.5% shunt V ref. V) C m% V' |; H
ABQ LM4040DIX3-2.5 Max L SC70 2.500V 1% shunt V ref$ c1 D5 @6 \& I
ABR LM4040AIX3-3.0 Max L SC70 3.000V 0.1% shunt V ref
" ] l1 i. R$ r, vABs BCW60B Sie N SOT23 BCY58-viii
* U; `3 @# h8 K% @8 xABS LM4040BIX3-3.0 Max L SC70 3.000V 0.2% shunt V ref, ?& z7 h3 w& a8 h5 [8 N7 }
ABt BCW60B Phi N SOT23 BCY58-viii
# B% e/ }; `3 L6 D$ MABT LM4040CIX3-3.0 Max L SC70 3.000V 0.5% shunt V ref
% v, M) q" U9 XABU LM4040DIX3-3.0 Max L SC70 3.000V 1% shunt V ref0 J% ^# u) M* w1 J' Y; W9 B
ABV LM4040AIX3-4.1 Max L SC70 4.096V 0.1% shunt V ref9 J0 D; s) R k& k0 P9 O. U9 f
ABW LM4040BIX3-4.1 Max L SC70 4.096V 0.2% shunt V ref
" V& L% O+ B4 o4 x8 U7 {6 cABX LM4040CIX3-4.1 Max L SC70 4.096V 0.5% shunt V ref
' w8 E( U: U- a+ |, yABY LM4040DIX3-4.1 Max L SC70 4.096V 1% shunt V ref
5 }- _- t6 F* t" O+ _& ]ABZ LM4040AIX3-5.0 Max L SC70 5.000V 0.1% shunt V ref5 i6 V) ^9 C# q% |" u
AC BCX51-100 Sie P SOT89 45V pnp audio hfe 100# m$ P. I0 p/ I
AC BCX51-10 Phi P SOT89 45V pnp audio hfe 100& |6 K$ Y4 u- q" z* f: q) z$ j
AC BCW60C Phi N SOT23 BCY58-ix
! J, t" |2 u7 X' d3 m* b) n; _AC ZMV831A Zet I SOD323 varicap hyperabrupt 28V [email=15pF@2V]15pF@2V[/email]7 A- j p, ?8 T% f4 T/ C4 r
ACA LM4040BIX3-5.0 Max L SC70 5.000V 0.2% shunt V ref
1 q7 A m8 A6 ?1 s# c7 N* kACAA MAX809TXR Max ZB SOT23 microproc -ve reset gen 3.3V
9 _$ ?) Z1 k ~* j" t. f9 DACB LM4040CIX3-5.0 Max L SC70 5.000V 0.5% shunt V ref
4 M. W5 W% R8 }6 w" ~6 F3 XACC LM4040DIX3-5.0 Max L SC70 5.000V 1% shunt V ref1 M0 e N7 M; ~
ACE MAX6326_R31-T Max ZB SC70 microproc -ve reset gen 3.080V i- q) K: r( j, A
ACF MAX6347_R46-T Max ZB SC70 microproc +ve reset gen 4.630V
B$ M4 I3 }: vACH MAX6326_R23-T Max ZB SC70 microproc -ve reset gen 2.320V
, l7 t6 ^& {- F% L: ^ACI MAX6326_R26-T Max ZB SC70 microproc -ve reset gen 2.630V
% U% z: M0 M0 P# k4 S2 @* H7 OACJ MAX6328_R26-T Max ZB SC70 microproc -ve reset gen 2.630V
x* t$ W6 X0 oACK MAX6346_R44-T Max ZB SC70 microproc -ve reset gen 4.380V) o1 I- O& Z: A9 j0 o' r1 a- N
ACL MAX6347_R44-T Max ZB SC70 microproc +ve reset gen 4.380V( ~6 I+ I9 V; }$ \
ACM MAX6348_R46-T Max ZB SC70 microproc -ve reset gen 4.630V. y5 Q7 H, F% @" e
ACN MAX6348_R44-T Max ZB SC70 microproc -ve reset gen 4.380V
. Z8 K3 K" |( D4 c! h2 Q5 aACO MAX6346_R46-T Max ZB SC70 microproc -ve reset gen 4.630V8 l$ e; m9 Q7 h
ACp BCW60C Phi N SOT23 BCY58-ix
8 |1 x/ q# ~. @7 D" VACP MAX6326_R29-T Max ZB SC70 microproc -ve reset gen 2.930V
( S* k& n6 k% l: F( } k; @ACQ MAX6327_R23-T Max ZB SC70 microproc +ve reset gen 2.320V
/ C4 \5 T, a- m& |6 h0 I" B+ JACR MAX6327_R26-T Max ZB SC70 microproc +ve reset gen 2.630V" X) o L& v5 i; _8 c
ACs BCW60C Sie N SOT23 BCY58-ix6 A% ^, L6 B/ h% Y; f
ACS MAX6327_R29-T Max ZB SC70 microproc +ve reset gen 2.930V
. L+ e* g5 C! i1 KACt BCW60C Phi N SOT23 BCY58-ix5 m9 a6 ?" }) \+ a
ACT MAX6327_R31-T Max ZB SC70 microproc +ve reset gen 3.080V5 e2 W% T$ F+ k& t
ACU MAX6328_R23-T Max ZB SC70 microproc -ve reset gen 2.320V
* G0 X" J2 Q. q6 ]4 ZACV MAX6328_R29-T Max ZB SC70 microproc -ve reset gen 2.930V6 A# e7 o$ t _* M
ACW MAX6326_R31-T Max ZB SC70 microproc -ve reset gen 3.080V' k; n: g. \4 I6 Z( O
AD BCX51-160 Sie P SOT89 45V pnp audio hfe 160
6 @% x/ T) R; D4 Y e: z% e9 GAD BCX51-16 Phi P SOT89 45V pnp audio hfe 1602 F& c( E2 D, R' t- h: y
AD BCW60D Phi N SOT23 BCY58-x( |% r/ J# L, B8 S) _+ p7 [
AD ZMV832A Zet I SOD323 varicap hyperabrupt 28V [email=22pF@2V]22pF@2V[/email]
8 ?7 H& _: j+ F4 r3 y/ FADAA MAX809SXR Max ZB SOT23 microproc -ve reset gen 3.3V1 b3 r0 y' p5 r
ADN 2SC3838K Roh N - npn 11V 3.2GHz TV tuners
- E/ l5 b$ K$ I2 |ADp BCW60D Phi N SOT23 BCY58-x* s4 j F2 b4 ^5 f
ADs BCW60D Sie N SOT23 BCY58-x# q9 j8 W) u9 p# k6 f" a, p
ADt BCW60D Ph N SOT23 BCY58-x
4 G' E" a; c: K" Y9 e1 ]7 TADW MAX6406BS22-T Max UC4 UCSP-4 "Volt. Detect. (2.200 V / Push-Pull, Active-Low)"8 o9 D3 [- U6 ]5 P
ADX MAX6406BS23-T Max UC4 UCSP-4 "Volt. Detect. (2.320 V / Push-Pull, Active-Low)" d: C0 M0 J6 q3 z5 d
ADY MAX6406BS24-T Max UC4 UCSP-4 "Volt. Detect. (2.400 V / Push-Pull, Active-Low)"+ t- _4 k1 `9 N M- f
ADZ MAX6406BS25-T Max UC4 UCSP-4 "Volt. Detect. (2.500 V / Push-Pull, Active-Low)"4 M# Z- Q% O9 U- X
AE BCX52 Sie P SOT89 pnp 60V audio comp BCX55! [, @# z! I) o2 A; U
AE ZMV833A Zet I SOD323 varicap hyperabrupt 28V [email=33pF@2V]33pF@2V[/email]& s i; O) F w: p9 {# M2 L+ E& X
AEA MAX6406BS26-T MAX UC4 UCSP-4 "Volt. Detect. (2.630 V / Push-Pull, Active-Low)"
3 p1 g) X* p$ c v+ Y2 [' TAEB MAX6406BS27-T MAX UC4 UCSP-4 "Volt. Detect. (2.700 V / Push-Pull, Active-Low)"8 h8 I! [/ F& \" u1 h. R8 O' s- N! q
AEC MAX6406BS28-T MAX UC4 UCSP-4 "Volt. Detect. (2.800 V / Push-Pull, Active-Low)"
8 U' D( X) }, j5 v- MAED MAX6406BS29-T MAX UC4 UCSP-4 "Volt. Detect. (2.930 V / Push-Pull, Active-Low)"
# Y" ]3 ? L8 Y! u1 z) ^# DAEE MAX6406BS30-T MAX UC4 UCSP-4 "Volt. Detect. (3.000 V / Push-Pull, Active-Low)"
' ~/ A/ m* b6 B0 F# Y8 DAEF MAX6406BS31-T MAX UC4 UCSP-4 "Volt. Detect. (3.080 V / Push-Pull, Active-Low)"3 \# o* E+ M$ P+ U& Q. K9 o( `) m
AEG MAX6407BS22-T MAX UC4 UCSP-4 "Volt. Detect. (2.200 V / Push-Pull, Active-High)") `- ]1 I: @- x. t4 X5 b
AEH MAX6407BS23-T MAX UC4 UCSP-4 "Volt. Detect. (2.300 V / Push-Pull, Active-High)"
) O! ]" w2 f; t0 XAEI MAX6407BS24-T MAX UC4 UCSP-4 "Volt. Detect. (2.400 V / Push-Pull, Active-High)"
7 r V4 |, Q5 \, o; VAEJ MAX6407BS25-T MAX UC4 UCSP-4 "Volt. Detect. (2.500 V / Push-Pull, Active-High)"
* A, w$ P6 o4 @9 BAEK MAX6407BS26-T MAX UC4 UCSP-4 "Volt. Detect. (2.630 V / Push-Pull, Active-High)"
3 e) c( O& C' e" l3 |4 O5 G0 RAEL MAX6407BS27-T MAX UC4 UCSP-4 "Volt. Detect. (2.700 V / Push-Pull, Active-High)"
7 T/ t, U5 f+ P( U9 LAEM MAX6407BS28-T MAX UC4 UCSP-4 "Volt. Detect. (2.800 V / Push-Pull, Active-High)"
& d* s5 m+ ~8 W# V( V4 T! @! QAEN MAX6407BS29-T MAX UC4 UCSP-4 "Volt. Detect. (2.930 V / Push-Pull, Active-High)"
8 `! @( l- Z* ]7 i& f0 T( {AEN 2SC3839K Roh N - npn 20V 2.0GHz TV tuners7 o0 x" g! C% w% Y
AEO MAX6407BS30-T Max UC4 UCSP-4 "Volt. Detect. (3.000 V / Push-Pull,Active-High)"" M6 |/ u$ G" q
AEP MAX6407BS31-T Max UC4 UCSP-4 "Volt. Detect. (3.000 V / Push-Pull,Active-High)"
& y+ U1 d" T- g1 WAEQ MAX6408BS22-T Max UC4 UCSP-4 "Volt. Detect. (2.200 V/Open Drain,Active-Low)"
' U9 q$ a N; u& }AER MAX6408BS23-T Max UC4 UCSP-4 "Volt. Detect. (2.320 V/Open Drain,Active-Low)"
, ?$ M; q. s3 n/ h4 X% x2 gAES MAX6408BS24-T Max UC4 UCSP-4 "Volt. Detect. (2.400 V/Open Drain,Active-Low)"
) X% K; y. V9 wAET MAX6408BS25-T Max UC4 UCSP-4 "Volt. Detect. (2.500 V/Open Drain,Active-Low)"
# j2 [; x- q# tAEU MAX6408BS26-T Max UC4 UCSP-4 "Volt. Detect. (2.630 V/Open Drain,Active-Low)"* S! b: @1 |1 G' J) o; L+ i
AEV MAX6408BS27-T Max UC4 UCSP-4 "Volt. Detect. (2.700 V/Open Drain,Active-Low)"
+ ~# F; q2 ]- y. {; z/ C5 ~AEW MAX6138AEXR12-T Max L SC70-3 Shunt Voltage Ref. (output 1.2205 V / 0.1%)7 I8 J( D6 z/ y
AEW MAX6408BS28-T Max UC4 SC70-3 "Volt. Detect. (2.800 V/Open Drain,Active-Low)"5 [6 w, E7 w2 q$ }1 M6 e! k/ {" s, ]$ v
AEX MAX6138BEXR12-T Max L SC70-3 Shunt Voltage Ref. (output 1.2205 V / 0.2%)
- u; {* H+ r) l; u& N, _AEX MAX6408BS29-T Max UC4 UCSP-4 "Volt. Detect. (2.930 V/Open Drain,Active-Low)"' L% r3 s6 @. m- ~2 q7 t! a2 ^
AEY MAX6138CEXR12-T Max L SC70-3 Shunt Voltage Ref. (output 1.2205 V / 0.5%)
7 N: x% b; w' a" g6 s" r: iAEY MAX6408BS30-T Max UC4 UCSP-4 "Volt. Detect. (3.000 V/Open Drain,Active-Low)"6 `# i! J( d( j6 y# t) [
AEZ MAX6408BS31-T Max UC4 UCSP-4 "Volt. Detect. (3.080 V/Open Drain,Active-Low)"# q' m1 G( `9 R9 i! s/ Z6 i! y4 K2 D
AF ZMV834A Zet I SOD323 varicap hyperabrupt 28V [email=47pF@2V]47pF@2V[/email]8 x2 V6 V. e3 q( G1 {% s$ z
AFA MAX6138AEXR21-T Max L SC70-3 Shunt Voltage Ref. (output 2.0480 V / 0.1%)$ [* t# x& t" d4 o% [3 w
AFA MAX6409BS33-T Max - UCSP-4 "Volt. Detect. (3.300 V / Push-Pull, Active-Low)"
7 N* `1 N: ~" T+ w% @7 k6 N; U! DAFAA MAX809RXR Max ZB SOT23 microproc -ve reset gen 3.0V2 a& x8 }- D! y4 N% d! G' l( _
AFB MAX6138BEXR21-T Max L SC70-3 Shunt Voltage Ref. (output 2.0480 V / 0.2%)
4 L P5 h# \" ~$ _AFB MAX6409BS34-T Max UC4 UCSP-4 "Volt. Detect. (3.400 V / Push-Pull, Active-Low)"' f" S6 ]5 a! p/ O9 Q8 X
AFC MAX6138CEXR21-T Max L SC70-3 Shunt Voltage Ref. (output 2.0480 V / 0.5%): @/ s5 Q h7 K' K
AFC MAX6409BS35-T Max UC4 UCSP-4 "Volt. Detect. (3.500 V / Push-Pull, Active-Low)"$ M0 {9 m. o& e, N! _
AFD MAX6409BS36-T Max UC4 UCSP-4 "Volt. Detect. (3.600 V / Push-Pull, Active-Low)"
& g' C0 v) J0 d( U7 \AFE MAX6138AEXR25-T Max L SC70-3 Shunt Voltage Ref. (output 2.5000 V / 0.1%)
2 o: F/ u* |8 j' v% _( mAFE MAX6409BS37-T Max UC4 UCSP-4 "Volt. Detect. (3.700 V / Push-Pull, Active-Low)"
+ z: y& m0 T7 e/ F; S# ~AFF MAX6138BEXR25-T Max L SC70-3 Shunt Voltage Ref. (output 2.5000 V / 0.2%)4 U1 q/ f: l3 `1 ^/ d0 ^% _
AFF MAX6409BS38-T Max UC4 UCSP-4 "Volt. Detect. (3.800 V / Push-Pull, Active-Low)"
9 u; Z- f$ z$ R5 RAFG MAX6138CEXR25-T Max L SC70-3 Shunt Voltage Ref. (output 2.5000 V / 0.5%)2 Y% u* |; |* D( L* \
AFG MAX6409BS39-T Max UC4 UCSP-4 "Volt. Detect. (3.900 V / Push-Pull, Active-Low)"+ ~" V& I" S' v& T9 c0 c
AFH MAX6409BS40-T Max UC4 UCSP-4 "Volt. Detect. (4.000 V / Push-Pull, Active-Low)"
$ K4 z8 b- Y* u+ LAFI MAX6138AEXR30-T Max L SC70-3 Shunt Voltage Ref. (output 3.0000 V / 0.1%)
/ w6 e" g8 o8 I, h' FAFI MAX6409BS41-T Max UC4 UCSP-4 "Volt. Detect. (4.100 V / Push-Pull, Active-Low)"
' G$ b+ A I4 {. E: D/ BAFJ MAX6138BEXR30-T Max L SC70-3 Shunt Voltage Ref. (output 3.0000 V / 0.2%)
4 |9 m; b/ `3 B) ]AFJ MAX6409BS42-T Max UC4 UCSP-4 "Volt. Detect. (4.200 V / Push-Pull, Active-Low)"
! B0 _8 }: w3 O( y, B; hAFK MAX6138CEXR30-T Max L SC70-3 Shunt Voltage Ref. (output 3.0000 V / 0.5%)1 n/ G% m* I# M
AFK MAX6409BS43-T Max UC4 UCSP-4 "Volt. Detect. (4.300 V / Push-Pull, Active-Low)"/ I9 m E% u5 b; }
AFL MAX6409BS44-T Max UC4 UCSP-4 "Volt. Detect. (4.380 V / Push-Pull, Active-Low)"7 t; A0 W4 D: y6 e3 Z. `
AFM MAX6138AEXR41-T Max L SC70-3 Shunt Voltage Ref. (output 4.0960 V / 0.1%)( K6 S5 t. i2 {3 _; o9 \
AFM MAX6409BS45-T Max UC4 UCSP-4 "Volt. Detect. (4.500 V / Push-Pull, Active-Low)"
M V$ `. e. r7 V6 s* XAFN MAX6138BEXR41-T Max L SC70-3 Shunt Voltage Ref. (output 4.0960 V / 0.2%)
. J( r6 [8 |, {- A: h F( eAFN MAX6409BS46-T Max UC4 UCSP-4 "Volt. Detect. (4.630 V / Push-Pull, Active-Low)"
1 t; L" J% t8 Q6 xAFO MAX6138CEXR41-T Max L SC70-3 Shunt Voltage Ref. (output 4.0960 V / 0.5%)
( V9 t q& Q* \( xAFQ MAX6138AEXR50-T Max L SC70-3 Shunt Voltage Ref. (output 5.0000 V / 0.1%)8 \& f* D" F3 @ @" u
AFR MAX6138BEXR50-T Max L SC70-3 Shunt Voltage Ref. (output 5.0000 V / 0.2%)
) g" |( v$ D) K# IAFs BCW60FF Sie N SOT23 BCY58
3 v/ R5 S5 |: h2 D' h `2 } LAFS MAX6138CEXR50-T Max L SC70-3 Shunt Voltage Ref. (output 5.0000 V / 0.5%)
/ o, Q. c" q- g' E/ d' }/ uAG ZMV835A Zet I SOD323 varicap hyperabrupt 28V [email=68pF@2V]68pF@2V[/email]
' h: m8 \/ S0 i9 I) x. F! wAG BCX70G Phi N SOT23 BCY59-vii BC107
8 A* I0 |9 y9 Z% }& Y- M% iAG BCX52-10 Sie P SOT89 60V pnp BCX52 hfe 100) t& F! d* I3 `( Y
AGAA MAX810LXR Max ZB SOT23 microproc +ve reset gen 5.0V
4 j# c; G) h; ?$ l% @5 T, Z' zAGp BCX70G Phi N SOT23 BCY59-vii BC107( l4 U& ^ E* ?0 [
AGs BCX70G Sie N SOT23 BCY59-vii BC1079 J" X* ~4 |! S
AGt BCX70G Phi N SOT23 BCY59-vii BC107' o2 m. K! Q0 }2 D; }; ~
AH BCX70H Phi N SOT23 BCY59-viii BC107B
8 \% v4 s, T5 h. Y/ y! k! JAH BCP53 Mot P SOT223 pnp amp 80V 150mA
+ v! J- ?7 M* KAH BCX53 Sie P SOT89 pnp 80V audio comp BCX56( R! C2 S5 c3 q, d) q2 T0 B- Q
AH ZMV930 Zet I SOD323 2.9-8.3pF hyperabrupt varicap3 |/ p3 w! Z! j$ P Z
AHAA MAX810MXR Max ZB SOT23 microproc +-ve reset gen 5.0V7 e/ b' B2 R& W3 V
AHp BCX70H Phi N SOT23 BCY59-viii BC107B! s. |$ J% o* [# w- E/ v
AHs BCX70H Sie N SOT23 BCY59-viii BC107B. {7 f6 m; s! \ U" ]8 B
AHt BCX70H Phi N SOT23 BCY59-viii BC107B
: F9 K0 ]4 \& L( WAJ BCX70J Phi N SOT23 BCY59-ix BC1074 g9 a" v1 m& Y, g
AJ ZMV931 Zet I SOD323 4 -13.5pF hyperabrupt varicap, | l8 l2 f8 N4 Y9 m" P8 E& i
AJ s BCX70J Sie N SOT23 BCY59-ix BC107: ^0 n- ]# L( ?" F) w
AJAA MAX810TXR MAX ZB SOT23 microproc +ve reset gen 3.3V7 B# r( Y; d: G) S
AJp BCX70J Phi N SOT23 BCY59-ix BC1076 e, n2 D/ h; S& i" |' \/ E
AJt BCX70J Phi N SOT23 BCY59-ix BC107
* w% {! i' y) D9 qAK BCX70K Phi N SOT23 BCY59-x BC107% d4 }2 s3 X6 ?' l/ g8 o2 ^
AK ZMV932 Zet I SOD323 5.5-17pF hyperabrupt varicap
f0 V0 _2 u; p4 o ~9 R0 r# fAK BCX53-10 Sie P SOT89 pnp 80V BCX53 hfe 100: W0 w, |+ K0 X( h5 }
AKAA MAX810SXR MAX ZB SOT23 microproc +ve reset gen 3.3V
! f0 j6 K: D K& B7 ~AKp BCX70K Phi N SOT23 BCY59-x BC107
{# M' w4 M7 o: iAKp BCX70K Phi N SOT23 BCY59-x BC107" D, `* S) Y6 x. I
AKs BCX70K Sie N SOT23 BCY59-x BC107
% e7 a: ?0 |3 Z: ?AL BCX53-16 Sie P SOT89 80V pnp BCX53 hfe 100
% a# R/ ^% e* K6 m5 g* HAL MMBTA55L Mot N SOT23 pnp 25V (MPSA55)
7 O5 |0 a) {/ E+ m" ^AL ZMV933 Zet I SOD323 12-42pF hyperabrupt varicap
" J1 w3 h4 x nALAA MAX810SXR MAX ZB SOT23 microproc +ve reset gen 3.0V" V9 U6 @9 L2 O/ e5 ~) k
ALs BFP405 Sie MQ SOT343 -8 i/ n8 s" b( b' m3 b7 v1 g
AM MMBT3904W Mot N SOT323 2N3904
8 C8 s, K7 m ?AM BCX52-16 Sie P SOT89 pnp 60V BCX52 hfe 160
% E0 I h5 `) b9 H4 ^: GAM BSS64 Mot N SOT23 npn 80V 0.1A fT 60MHz
+ O) y* L8 Q; H$ n! h6 L; @AM ZMV933A Zet I SOD323 12-42pF hyperabrupt varicap
9 r9 E; a a9 O: ^: jAMp BSS64 Phi N SOT23 npn 80V 0.1A fT 60MHz* K/ b, w+ m* Z: N
AMs BFP420 Sie MQ SOT343 npn fT 25GHz 4.5V 35mA5 V# u( h/ y) \8 L
AMs BSS64 Sie N SOT23 npn 80V 0.1A fT 60MHz6 j) }5 o* i. Z. d
AMt BSS64 Phi N SOT23 npn 80V 0.1A fT 60MHz
: N3 E" `* v) [* t) y) v2 JAN BCW60FN Sie N SOT23 gp npn 35V 0.2A, U U4 G5 e( e( J9 C( q* ?
AN ZMV934 Zet I SOD323 25-95pF hyperabrupt varicap) y9 ]0 [" e$ v- q
ANs BFP450 Sie MQ SOT343 npn fT 25GHz 4.5V 100mA l! r/ P1 O5 n3 J$ [. \5 t& Z' ^
AO BCW60AR ITT R SOT23R BCY58-vii" O& M5 R% u# Q( ~: Z K- l
AO ZMV934A Zet I SOD323 25-95pF hyperabrupt varicap# X1 g2 w& b# R" \
AP BCW60BR ITT R SOT23R BCY58-viii
) h9 ?% j! a8 _( u$ A/ BAPs BFP520 Sie MQ SOT343 npn fT 40GHz 2.5V 40mA
* D) H9 i; L# e# Y- a6 JA-Q 2PD1820AQ Phi N SOT323 gp sw amp 50V npn hfe 85-170
6 g6 }# k1 D, u0 b( U! YA-Q 2PD1820AR Phi N SOT323 gp sw amp 50V npn hfe 120-2407 ?" e- N& S4 c0 a- {
AR BCW60CR ITT R SOT23R BCY58-ix, o2 h( `" f, |" u$ p( t5 h! ]
AR MSD709R Mot N - pnp gp 25V
2 u% |, W: b8 o2 j; `4 o9 {AR1 BSR40 Phi P SOT89 npn 70V 1A 1.35W hfe 40-120
$ i. C6 a c. F% m4 L1 x4 B+ ]AR2 BSR41 Phi P SOT89 npn 70V 1A 1.35W hfe 100-3006 U2 ?) z7 X e$ f$ x0 @
AR3 BSR42 Phi P SOT89 npn 90V 1A 1.35W hfe 40-120' Q. J& p- `' Z. d7 V$ ^3 E
AR4 BSR43 Phi P SOT89 npn 90V 1A 1.35W hfe 100-300/ a( b I' E+ z/ U0 }4 F6 {
AS BCW60DR ITT R SOT23R BCY58-x
1 N& E2 c2 v7 VAS MSD709S Mot N - pnp gp 25V, a2 L( Y9 z |. J% c) t3 p7 h! C- r
A-S 2PD1820AS Phi N SOT323 gp sw amp 50V npn hfe 170-340$ @% f7 b F; D4 D1 h
AS1 BST50 Mot P SOT89 npn darlington 0.5A 60V
$ Y/ R! w2 R- VAS2 BST51 Mot P SOT89 npn darlington 0.5A 80V5 t3 ?3 {! }' C5 Q/ H! p
AS3 BST52 Mot P SOT89 npn darlington 0.5A 90V& W: k( A! y$ c, ?4 F
AS3 BSP52 Mot P SOT223 npn darlington 0.5A hfe 2000
1 c& `! e' C% d7 s* Q$ e# R$ _+ MASs BAT18-05 Sie B SOT23 dual BAT18 RF pin
" _, f1 J- K& K1 W; J7 _AtQ 2PD1820AQ Phi N SOT323 gp sw amp 50V npn hfe 85-170
. m' v2 C7 v- S* z, q: P+ S" AAtQ 2PD1820AR Phi N SOT323 gp sw amp 50V npn hfe 120-240- `. o" R2 x! g) O
AtS 2PD1820AS Phi N SOT323 gp sw amp 50V npn hfe 170-3403 s' s3 f3 ^ Y1 c
ATs BAT18-06 Sie A SOT23 dual ca BAT18 RF pin1 p/ R$ u+ e; i# p. g
ATs BFP540 Sie MQ SOT343 npn microwave
" D" L: p. R. f! @ c1 KAU BCW60GR ITT R SOT23R BCY58; \- P" Y( b" r9 a
AUs BAT18-04 Sie D SOT23 dual BAT18 RF pin1 }7 T# ]$ W! g9 G" i# x* M4 L6 I
AV DAN212K Roh C - 80V 100mA sw
0 |; I4 t- ~( w# F" ] @AW BCW60HR ITT R SOT23R BCY589 \$ S1 t! F8 ^0 \* ~7 Y' V- t
AX BCX70JR ITT R SOT23R BCY59-ix
( m$ u3 }+ c0 L/ ~3 S6 P4 pAY BCX70KR ITT R SOT23R BCY59-x \( m) `. ?/ a) r' R
AY MMBD1000 Mot C SOT23 Si sw diode 30V 0.2A, A5 V5 F- p+ R) Z
B MRF957 Mot N SOT323 npn RF fT 9GHz
5 \; d7 E3 `! G' H+ v0 [! y2 LB BAS16-03W Sie I SOD323 Varicap 18pF 1V% O: k" _3 f6 L) T4 t9 ~
B BB555 Sie I SCD80 Varicap 18pF 1V6 A0 U0 ]5 U1 I9 h. E% ?
B0 BZX399C4V3 Phi I SOD323 4.3V 0.3W zener
5 q! W, ~( R* XB0 HSMS-2810 HP C SOT23 HP2810 schottky
7 u* X! g* N0 h" m+ j5 U+ x! DB0 HSMS-281B HP C SOT323 HP2810 schottky7 ~) ]6 S3 g! ~' d4 s
B08 SST6908 Sil ZQ - 2N6908 prot n-ch jfet
* H1 g% |' ] S& u6 c. T6 pB09 SST6909 Sil ZQ - 2N6909 prot n-ch jfet) f- [3 g! F5 m' S- q* a
B1 BZX399C1V8 Phi I SOD323 1.8V 0.3W zener$ _# n9 A/ Y* t) t% W5 Q" a/ D
B1 HSMS-2811 HP K SOT23 HP2811 schottky
+ a% _7 ]0 N. w; {; f7 K, @0 cB1 BAS40 Mot C SOT23 schottky sw diode
p% l) ^4 u: C5 X4 h9 ]! k; TB10 SST6910 Sil ZQ - 2N6910 prot n-ch jfet
2 {& h" Y/ C4 y; `8 t# |* }* y4 WB2 BZX399C2V0 Phi I SOD323 2.0V 0.3W zener1 m* ^' m1 y9 \
B2 BSV52 Phi N SOT23 BSX20 12V fT 400MHz sw, E% `8 G9 T& h& w
B2 HSMS-2812 HP D SOT23 dual HP2810 schottky
& ~8 S4 m8 N3 [" ?B2 HSMS-281C HP D SOT323 dual HP2810 schottky- V/ D* y) g* X
B26 BF570 Phi SOT23 -& D( t& s6 s9 ^# y
B2p BSV52 Phi N SOT23 BSX20 12V fT 400MHz sw; n; G. y+ j% M1 R! g [1 _
B2t BSV52 Phi N SOT23 BSX20 12V fT 400MHz sw3 b3 J% n! A& e; w# u( G
B3 BZX399C2V2 Phi I SOD323 2.2V 0.3W zener
* g: P) e# ]7 tB3 HSMS-2813 HP A SOT23 dual ca HP2810 schottky
7 |7 q) y: k8 X9 D2 t2 ~B3 MMBD717L Mot A SOT323 dual ca schottky
1 D- i5 l. b0 d$ C8 [" V# \B4 BZX399C2V4 Phi I SOD323 2.4V 0.3W zener+ d- F. y1 z3 a
B4 BSV52R Phi R SOT23R BSX20
. r( Y: A7 ~: A+ fB4 HSMS-2814 HP B SOT23 dual cc HP2810 schottky
( q2 I7 v$ K: D0 s6 WB5 BZX399C2V7 Phi I SOD323 2.7V 0.3W zener
3 s3 b" {" B b6 J2 tB5 HSMS-2815 HP S SOT143 dual HP2810 schottky
7 E; v) C+ O* e, \5 QB6 BZX399C3V0 Phi I SOD323 3.0V 0.3W zener
' O! Z5 H1 U7 K8 S8 bB6 BAT54A Mot A SOT23 dual ca 30V schottky5 J7 Q& S# }" F$ _. G; D
B7 BZX399C3V3 Phi I SOD323 3.3V 0.3W zener+ O* Z3 C8 k' s3 z# h! Q; I; l
B7 HSMS-2817 HP RQ SOT143 HP2810 ring quad
. U: O: {& `9 P2 I" z3 f t+ ~B8 BZX399C3V6 Phi I SOD323 3.6V 0.3W zener
' R8 V' `4 r" j# g3 e# XB8 HSMS-2818 HP BQ SOT143 HP2810 bridge quad
3 Q5 c8 f5 `5 yB9 BZX399C3V9 Phi I SOD323 3.9V 0.3W zener0 n$ g: H P. B0 g
B9 2SC4617 Mot N SC90 npn gp
2 @; a7 P# G. S+ s; gBA BCX54 Sie P SOT89 npn AF 45V comp BCX51+ |5 N# M( {8 r; ~' ^# f+ {
BA BCW61A Phi N SOT23 BCY78-vii+ m& v$ V$ O" ]% J. }
BA DAN217 Roh D - 80V 100mA dual
' V, z7 b( O* ?2 t8 @+ dBA BZX399C4V7 Phi I SOD323 4.7V 0.3W zener
2 p ^8 C, g. N' N% m7 |BAp BCW61A Phi N SOT23 BCY78-vii. r2 W Q% v1 K8 X
BAt BCW61A Phi N SOT23 BCY78-vii
/ b0 s8 {; R% n8 }BB BCW61B Phi N SOT23 BCY78-viii: F2 Y; W$ r% D* |5 }
BB BAR81 Sie NQ SOT143 Dual pin shunt switch& j! h) d# l$ _2 r K) b2 G! h# {
BB BZX399C5V1 Phi I SOD323 5.1V 0.3W zener/ X S) v$ A- C1 D
BBp BCW61B Phi N SOT23 BCY78-viii A+ n! P, ~0 z) Q1 v3 [
BBs BCW61B Sie N SOT23 BCY78-viii1 {+ {" M) h+ a& l Y0 Y1 I) @
BBs BAR81W Sie NQ SOT343 Dual pin shunt switch. _1 G' p/ z# A2 q3 Z5 t0 s
BBt BCW61B Phi N SOT23 BCY78-viii6 M6 D1 d G e- ~
BC BCW61C Phi N SOT23 BCY78-ix
* w. b! \& S$ r! vBC BCX54-10 Sie Phi P SOT89 npn hfe100
3 i0 K& c9 @8 u5 \3 X" ]BC BZX399C5V6 Phi I SOD323 5.6V 0.3W zener7 i' c) h3 `3 J: x7 [
BCp BCW61C Phi N SOT23 BCY78-ix
% j1 I9 e* n! l+ M: oBCs BCW61C Sie N SOT23 BCY78-ix# ~3 C$ m" X4 Q6 Z
BCt BCW61C Phi N SOT23 BCY78-ix
0 l7 o" w+ l1 ?) G- ^0 a/ [BD BCW61D Phi N SOT23 BCY78-x
- T1 S8 L/ d* B5 ?# ]BD BCX54-16 Sie P SOT89 npn hfe160 comp BCX51-16
& m: q, t# t$ o9 p1 r* l9 UBD BZX399C6V2 Phi I SOD323 6.2V 0.3W zener
) }' c+ }! G- T# KBD ZHCS400 Zet E SOT23 40V 0.4A schottky diode. D5 ~; F, L" x0 H1 w: r
BDp BCW61D Phi N SOT23 BCY78-x
# {' F7 H3 K/ |9 t' e- SBDs BCW61D Sie N SOT23 BCY78-x
1 u j# u5 Y' U, HBDt BCW61D Phi N SOT23 BCY78-x
! C7 J1 p+ ]! \0 v8 aBE BAS70 Mot C SOT23 schottky sw diode
$ h$ L' |$ D' ]5 O$ _BE BCX55 Sie P SOT89 npn AF 60V comp BCX52
6 R2 V( U" t: o v3 s$ d( ^BE BZX399C6V8 Phi I SOD323 6.8V 0.3W zener
/ ], U( e# t' m6 F% W8 A/ mBF BCW61FF Sie N SOT23 low noise BCW616 }+ a5 N' b$ ~7 u, e) y
BF BZX399C7V5 Phi I SOD323 7.5V 0.3W zener
# q K5 k4 z# S7 X ABG BCX71G Phi N SOT23 BCY79-vii# A4 b: I6 _1 q9 B1 ^9 I1 w9 A$ n/ f
BG BCX55-10 Sie Phi P SOT89 npn hfe 100: H! z; l+ J' W, B
BG BZX399C8V2 Phi I SOD323 8.2V 0.3W zener$ }) A+ |' j$ @( o6 A
BGp BCX71G Phi N SOT23 BCY79-vii _: \' n9 u* I; {" C( r' ]" j
BGs BCX71G Sie N SOT23 BCY79-vii
# w0 [' V. ?; ^! F; s- B9 U- jBGt BCX71G Phi N SOT23 BCY79-vii
G1 z6 _" b# |BH BCP56 Mot P SOT223 npn amp 80V 150mA3 W6 f3 ~9 n; }: M: L0 ]
BH BCX56 Sie P SOT89 npn AF 80V. x( M$ q, R) i7 Q
BH BZX399C9V1 Phi I SOD323 9.1V 0.3W zener i( W3 _" Z$ B4 N5 _! |
BH BCX71H Phi N SOT23 BCY79-viii% R1 i& ]. f3 Q4 b
BHp BCX71H Phi N SOT23 BCY79-viii* U9 d# n4 \: y' Q7 N- }
BHs BCX71H Sie N SOT23 BCY79-viii2 e$ q) n/ h Q
BHt BCX71H Phi N SOT23 BCY79-viii9 D% r: d3 X: a+ c8 s% ]/ l& g4 ~, c M
BJ BCX71J Phi N SOT23 BCY79-ix
; O" U& ?- ~# K2 ]0 m& T+ C( VBJ BZX399C10 Phi I SOD323 10V 0.3W zener' C3 K l5 i% Z Q$ ~9 K
BJp BCX71J Phi N SOT23 BCY79-ix' n& l2 u) K/ f5 F% n3 p1 ~6 t
BJs BCX71J Sie N SOT23 BCY79-ix; X" p2 j. ~8 ~( @; k
BJt BCX71J Phi N SOT23 BCY79-ix
) m2 q6 j5 Z: _3 C# |, mBK BCP56-10 Mot P SOT223 npn amp 80V 150mA. `+ v7 t( S: v
BK BCX71K Phi N SOT23 BCY79
6 W2 l- X7 y3 I+ Q1 W% {3 MBK BCX56-10 Sie P SOT89 npn hfe 100
9 @$ W' p' H' w: l+ S. UBK BZX399C11 Phi I SOD323 11V 0.3W zener8 ^& D7 m# Y; a$ b( q
BKp BCX71K Phi N SOT23 BCY79
3 t; S: p! Z$ |& SBKs BCX71K Sie N SOT23 BCY795 k6 h) H/ { A& ^6 q; W. S
BKt BCX71K Phi N SOT23 BCY795 @8 s5 K7 K& G8 J. F( y
BL MBD54DW Mot DL SOT363 2x schottky detector diodes+ f% l' t0 ~% { q& r5 }
BL BCP56-16 Mot P SOT223 npn amp 80V 150mA5 A& n; q2 o) l& _* e4 L8 ~" h
BL BCX56-16 Sie P SOT89 npn hfe 160
; L' g H$ r6 ^- z4 YBL BZX399C12 Phi I SOD323 12V 0.3W zener
! c$ l# Q8 w0 F9 e/ h# i5 J* UBL BGA310 Sie GQ SOT143 MMIC amp 9dB @1GHz
" l& V( V S3 U' _BLs BGA420 Sie HQ SOT343 MMIC amp 13 dB @1.8GHz
8 i6 {( b. n+ k8 Q- `, n' |! oBM BSS63L Mot N SOT23 100v pnp comp BSS64
6 j8 B/ b1 {% U8 j0 iBM BCX55-16 Sie P SOT89 npn hfe 160 d9 r% B7 d5 v( L
BM BGA312 Sie GQ SOT143 MMIC amp 11dB @1GHz3 k( _( q) h6 E6 h( ?
BM BZX399C13 Phi I SOD323 13V 0.3W zener
# Z6 O! m/ u8 }* a# ~BMp BSS63 Phi N SOT23 100v pnp comp BSS64! \! }, s; ^5 ^, n8 }$ ]2 D! K
BMs BG427 Sie HQ SOT343 MMIC amp 18 dB @1.8GHz8 X! z$ R% }3 l* G& R( s
BMt BSS63 Phi N SOT23 100v pnp comp BSS64
R2 L$ k, y2 q( L& r+ qBN BZX399C15 Phi I SOD323 15V 0.3W zener) B2 h1 I0 g# Z/ p* G9 }
BN BGA318 Sie GQ SOT143 MMIC amp 16dB @1GHz
0 }# q3 k; p9 H( e8 Z8 lBNs BCW61FN Sie N SOT23 low noise BCW61 b- |! y/ `! R5 P: f Z
BO BCW61AR Phi N SOT23 "BCX78, BCY78-vii"
. h6 z6 h, `: @# T5 uBP BCW61BR Phi N SOT23 BCY78-viii* l- t. H+ Y; w/ p, s8 P
BP BZX399C16 Phi I SOD323 16V 0.3W zener
; O6 |" k& Q4 K5 X3 k, C$ UBQ BZX399C18 Phi I SOD323 18V 0.3W zener in SOD323, A$ G4 E% v$ H* o& `! ?
BQ 2PB709AQ Phi N SC-59 PNP 45V 0.1A hfe 160-260' y5 U: M# ^) [8 e g
BR BCW61CR Phi N SOT23 BCY78-ix" n+ {; q& D( s8 l4 m$ U+ R3 `, P0 o
BR 2SC2412K Roh N - npn 50V 150mA min hfe 180
7 P, x) o, z7 Y% j$ \& O9 C' n8 y- ~BR 2SC4081 Roh N UMT 2SC2412K above; V u% e; ^9 T0 |
BR 2SC4617 Roh N EM3 2SC2412K above
" ?* O5 [8 S. K9 f# p# z7 r ABR MSB1218A Mot N SOT323 gp pnp 45V
( r; O' ~/ T1 ^; w9 f# i& E0 P3 KBR BZX399C20 Phi I SOD323 20V 0.3W zener" F) Y& T) _( M
BR 2PB709AR Phi N SC-59 pnp45V 0.1A hfe 210-3406 |; W* n: A. S; Z3 c
BR1 BSR30 Phi P SOT89 pnp 70V 1A 1.35W hfe 40-120
/ W9 n* q( T' |( }$ YBR2 BSR31 Phi P SOT89 pnp 70V 1A 1.35W hfe 100-300
( ?5 g7 m4 F* \/ g+ CBR4 BSR33 Phi P SOT89 pnp 90V 1A 1.35W hfe 100-300
6 g7 j8 x$ {0 u! x H! q- X7 P6 ` M* zBS BCW61DR Phi R SOT23 BCY78-x7 J. K4 V+ p( e: W" P2 Z5 a
BS BZX399C22 Phi I SOD323 22V 0.3W zener! W$ R7 q R( q4 l5 d w
BS 2PB709AS Phi N SC-59 pnp 45V 0.1A hfe 290-460
" m; G' B; n+ L% h# NBS1 BST60 Mot P SOT89 pnp darlington 0.5A 60V
2 R0 o5 T6 o; N$ IBS2 BST61 Mot P SOT89 pnp darlington 0.5A 80V
f% x C, o1 I4 R- U TBS3 BST62 Mot P SOT89 pnp darlington 0.5A 90V& D: Y* h; H0 W6 a6 c! D: x
BS3 BSP62 Mot P SOT89 pnp darlington 0.5A hfe 2000
' L4 X+ L D4 M- ]/ Z' u! g0 jBT BZX399C24 Phi I SOD323 24V 0.3W zener
e6 Z* ?6 F8 S, y+ WBT2 BSP16 Mot P SOT223 pnp –300V 1A# Y! P, v4 ~( i. o0 g* j
BT2 BST16 Phi P SOT89 pnp –300V 1A( c& ]: e% _3 n6 k' J6 z
BU BCX71GR Phi N SOT23 BCX79-vii9 ~( j- N. `6 u5 U8 i2 ?" r5 j6 V
BU BZX399C27 Phi I SOD323 27V 0.3W zener
* P$ I$ s/ D" \" C CBV BZX399C30 Phi I SOD323 30V 0.3W zener
! @5 d3 P! [1 e1 Y# d) j( `BW BCW71HR Phi N SOT23R BCX79-viii
* L6 B u3 z8 JBW BZX399C33 Phi I SOD323 33V 0.3W zener# ~: R; l M# v/ s
BX BCW71JR Phi N SOT23R BCX79-ix
, t3 `7 J: k' s' R# @; sBX BZX399C36 Phi I SOD323 36V 0.3W zener
, v6 p) I6 q. Z7 ~BY BCW71KR Phi N SOT23R BCX79-x
* }& E0 N3 n7 o* GBY BZX399C39 Phi I SOD323 39V 0.3W zener
" G$ u @4 E4 w0 t1 C& |6 |9 }" I( x0 VBZ BZX399C43 Phi I SOD323 43V 0.3W zener
% U7 j) Y/ Q$ B) \- T J! YC BB565 Sie I SCD80 uhf varicap 2-20pF ; r( `: E6 \- ?' I
C KV1832E Tok I URD uhf varicap 4-17pf ; `$ q0 G: W S& t
C white BAT165 Sie I - 40V 750mA sw Schottky) O' o4 |1 ?) Q0 P- E% ^8 Y! i
C0 HSMS-2820 HP C SOT23 HP2835 schottky
K2 U* z8 {% K; qC0 HSMS-282B HP C SOT323 HP2835 schottky
: C5 d% w3 t8 G" W7 n$ O6 wC1 HSMS-2821 HP K SOT23 HP2835 schottky
" g2 [: m/ B& Z2 U: IC1 BCW29 Phi N SOT23 BC178A( T- x# i! }3 l# Z2 u+ z* T
C1 BFQ51C Phi CX SOT173 pnp BFR90A complement
& g; [) h3 k2 p h8 U2 X. z! {8 qC11 SST111 Sil F SOT23 J111 n-ch fet$ ?' W4 i7 j2 D! J; G) d% _
C12 SST112 Sil F SOT23 J112 n-ch fet/ I; [( v z" X3 n9 ?4 Y8 d( E. ~
C13 SST113 Sil F SOT23 J113 n-ch fet& A/ @0 Y( `, n6 a4 I
C1p BCW29 Phi N SOT23 BC178A, Y9 z K& c0 X
C1t BCW29 Phi N SOT23 BC178A
' V% R: c8 b" S# V: ^6 K. N, p; zC2 BCW30 Phi N SOT23 BC178B2 v' a P$ ^& Q9 q) `9 c* p' q
C2 BFQ32C Phi CX SOT173 pnp 4.5GHz 15V 100mA
8 x& n5 B' I2 [3 SC2 HSMS-2822 HP D SOT23 dual HP2835 schottky ) c8 ?8 o# w: x+ n+ h c( {
C2 HSMS-282C HP D SOT323 dual HP2835 schottky
) m5 A& e$ t2 Q' d/ M7 a; vC2 SST112 Tem F SOT23 J112 analog sw n-ch jfet
/ j8 Y7 H. B' n' u" VC2A ZDC833A Zet B SOT23 dual cc 28V varicap 15pF @2V
0 V N2 j' l+ l, N% ?C2p BCW30 Phi N SOT23 BC178B8 x( Q7 J0 ^* W4 w9 }$ }# s
C2t BCW30 Phi N SOT23 BC178B% t+ w$ n$ f1 d& H9 Y2 R' ?2 S
C3 HSMS-2823 HP A SOT23 dual HP2835 schottky
& M. t \2 E' G0 ^, _C3 BFQ23C Phi CX SOT173 pnp complement BFP91A) K( _" ]6 m* S: Q# Q
C3 SMBT4126 Sie N - 2N41261 s7 T3 ?6 w3 R8 v! T0 M
C3 SST113 Tem F SOT23 J113 analog sw jfet$ W' I* }9 m4 _+ M, S5 Q
C38 SST5638 Sil F SOT23 2N5638
, T% G o" c. N7 y8 H) m& v ~C39 SST5639 Sil F SOT23 2N5639
$ P' _( w3 L/ y, A4 l0 yC4 BCW29R Phi R SOT23R BC178A' t' x7 C$ D) \/ x3 l" I, \
C4 HSMS-2824 HP B SOT23 dual HP2835 schottky
; W! M2 O4 a* H9 qC40 SST5640 Sil F SOT23 2N5640
$ j" z) E* A! JC41 SST4091 Sil F SOT23 2N40916 R$ u1 P- ?/ |) O
C42 SST4092 Sil F SOT23 2N4092, l; g# w7 O% G; h
C43 SST4093 Sil F SOT23 2N4093; O$ ]8 U w. R
C5 MMBA811C5 Mot N - 2N5086 pnp hfe 135-2703 X5 f# g4 X$ ]! c: A& N, G
C5 BCW30R Phi R SOT23R BC178B
: w$ E$ T1 n: \C5 HSMS-2825 HP S SOT143 dual HP2835 schottky
) x" c, F+ o% t Q( y9 gC56 SST4856 Sil F SOT23 2N48568 y( i: t* I1 W
C57 SST4857 Sil F SOT23 2N4857, |2 @9 Q u+ V* g
C58 SST4858 Sil F SOT23 2N4858+ h4 P- D) f7 O2 e. j; N3 L
C59 SST4859 Sil F SOT23 2N4859
/ U3 v" |% H- U. bC5A ZDC834A Zet B SOT23 dual cc 28V varicap 47pF @2V
4 s r: H% }: u. A- x& J2 O, wC6 MMBA811C6 Mot N - 2N5086 pnp hfe 200-4002 a: L6 c B4 ^: ~% C# z
C60 SST4860 Sil F SOT23 2N4860* {, A3 W1 J- m$ p4 c2 n
C61 SST4861 Sil F SOT23 2N4861$ t+ u4 y" [$ s3 ~0 Q
C7 MMBA811C7 Mot N - 2N5086 pnp hfe 300-600
* G$ d3 K( u2 k3 h8 bC7 HSMS-2827 HP RQ SOT143 HP2835 ring quad2 s4 G' I- u' ~- i
C8 HSMS-2828 HP BQ SOT143 HP2835 bridge quad: [% ~" E' h, U+ l
C8 BCF30 SGS N SOT23 BC559B
/ e6 l" g C# G: }! a6 q& TC8 MMBA811C8 Mot N - 2N5086 pnp hfe 450-900
4 F2 c* K8 L I3 m3 N0 t( RC91 SST4391 Sil F SOT23 2N4391) H" n4 \5 y' I% G* n/ E
C92 SST4392 Sil F SOT23 2N4392
. B) D# D) M$ J3 IC93 SST4393 Sil F SOT23 2N4393
: _* q T1 N$ y8 | ICA BCW61AR Phi R SOT23R BCY78-vii
: P+ i! n7 m2 a7 U- y) SCA BCP68 Mot P SOT223 20V 1A npn0 ]8 Y6 F! V/ I- F
CA ZMV829B Zet I SOD323 varicap hyperab 28V [email=8.2pF@2V]8.2pF@2V[/email]
$ F) E6 _" k Y5 P z5 jCB BCX68-10 Sie P SOT89 npn AF 20V 2A hfe 100) y2 `! E3 l- H x% u7 `
CB BCW61BR Phi R SOT23R BCY78-viii& m% o% z# Q2 m# A8 M9 s' v
CB ZMV830B Zet I SOD323 varicap hyperabrupt 28V [email=10pF@2V]10pF@2V[/email]9 ]7 X% h% B& ?7 W3 _
CC BCW61CR Phi R SOT23R BCY78-ix
' x3 u, F# C: f# b% Z! `CC BCX68-16 Sie P SOT89 npn AF 20V 2A hfe 160
0 I5 U r4 w# u" p* ?4 g. LCC ZMV831B Zet I SOD323 varicap hyperabrupt 28V [email=15pF@2V]15pF@2V[/email]
4 Z3 C+ t+ L2 |6 b kCC ZMDC831B Zet B SOT323 dual cc ZMV831B (above)+ j; F; v+ \: k/ ]0 ^
CD BCW61DR Phi R SOT23R BCY78-x- P) A8 Q& h5 M* a @' G) F
CD BCX68-25 Sie P SOT89 npn AF 20V 2A hfe 250; \# e' s$ F' p1 e
CD ZMV832B Zet I SOD323 varicap hyperabrupt 28V [email=22pF@2V]22pF@2V[/email]
- m5 p' Y ]8 }% L/ { h* v0 J5 @CD ZMDC832B Zet B SOT323 dual cc ZMV832B (above)* }0 X& `4 G/ s8 k9 F5 u$ h
CDs BSS81B Sie N SOT23 npn sw 35V 0.8A
5 I; ?( V' T7 m/ C4 ^CE BCP69 Mot P SOT223 20V 1A pnp
" h* O, a2 G( g# F9 oCE ZMV833B Zet I SOD323 varicap hyperabrupt 28V [email=33pF@2V]33pF@2V[/email]( ?/ Q$ @& E" b) e, a4 L
CEs BSS79B Sie N SOT23 npn 40V 0.8A hfe 40-120/ z& i0 p! o- n2 |
CF BSS79C Sie N SOT23 npn 40V 0.8A hfe 100 min
; Q2 G6 t" D* G# i9 i3 J8 ]; d9 d! n4 zCF BCX69-10 Sie P SOT89 pnp AF 20V 2A hfe 100
) w' J1 x; c; p$ _/ @CF ZMV834B Zet I SOD323 varicap hyperabrupt 28V [email=47pF@2V]47pF@2V[/email]
( m. H/ q) O) q$ @ oCG BCX71GR Phi R SOT23R BCY79-vii/ o$ |+ w" K5 j( C8 K0 a
CG BCX69-16 Sie P SOT89 pnp AF 20V 2A hfe 1606 { B4 N) [1 e$ V5 X7 y' c0 M& H$ F
CG ZMV835B Zet I SOD323 varicap hyperabrupt 28V [email=68pF@2V]68pF@2V[/email]
* M5 X$ O( A m9 n' I X, F" MCGs BSS81C Sie N SOT23 npn sw 35V 1A
' ]! P0 B) g) Y" i+ R/ F. e5 [CH BSS82BL Mot N SOT23 pnp 60V
9 W3 I: j, E( Y; qCH BCX69-25 Sie N SOT89 pnp AF 20V 2A hfe 2502 V: A/ T; ~: M) N. ]* v8 Y
CHs BSS80B Sie N SOT23 pnp 40V 0.8A hfe 40-120
* Z3 `" g- J& J. D: k. fCJs BSS80C Sie N SOT23 pnp 40V 0.8A hfe 100 min& q( O; ?. ]- s0 }2 o/ y
CK BCX71JR Phi R SOT23R BCY79-viii
% g3 S- E! u0 P4 aCLs BSS82B Sie N SOT23 pnp 60V 0.8A hfe 40-120
$ Q9 X5 ^- Q' z+ Q+ e; `' ~1 X2 bCMs BSS82C Sie N SOT23 pnp 60V 0.8A hfe 100 min% U) I0 D) [0 m
CQ 2SC2411K Roh N - npn darlington
! R0 z- x; R" tCQ MSD710Q Mot N SOT346 pnp gp 25V 150mA" \/ g, D% Z! I1 Q+ D7 s
CR MSD701R Mot N SOT346 pnp gp 25V 150mA2 v) Z8 J- {9 W$ g3 _1 X
D BB659 Sie I SCD80 2-38p varicap: H; R6 A" H! b- {. M* T
D BAS21-03W Sie I SOD323 - V: ~& e, E$ l+ r
D 1SS376 Roh I USM 300V 50mA sw! O/ f( v0 V* a. _3 v8 Q7 |) b
D MRF577 Mot N SOT323 npn RF fT 7GHz1 D. N% U. {* S e9 K2 x/ P
D0 HSMP-3800 HP C SOT23 HP3800 pin atten diode
& {- ~9 U8 K! @0 qD1 BCW31 Phi N SOT23 BC108A4 a* ?! h4 K6 u9 G, ]
D1 HSMP-3801 HP K - HP3800 pin atten diode I: g% Y9 m# R. |
D1 SST211 Tem XQ - n-ch mosfet 30V 1nS
y: m/ u# H {$ P% l' G" T) b/ dD11 SST211 Sil XQ - n-ch mosfet sw
; w( A" X! i n6 b6 SD11 SST215 Sil XQ - n-ch mosfet sw! ]3 | r5 O2 [! v: s+ Y
D13 SST213 Sil XQ - n-ch mosfet sw8 U# n: S+ Q0 Q7 m. A* N j+ N
D1p BCW31 Phi N SOT23 BC108A
3 P* l1 |9 O" E- z/ JD1t BCW31 Phi N SOT23 BC108A A9 c i; q; o
D2 BCW32 Phi N SOT23 BC108B/ d6 E* u- d: H' a
D2 HSMP-3802 HP D - dual HP3800 pin atten diode
$ k* _! ~4 t0 G7 [D2p BCW32 Phi N SOT23 BC108B
0 E! x8 j7 F+ b# T! h( XD2t BCW32 Phi N SOT23 BC108B; T# N5 p8 q, E( j T. A
D3 BCW33 Phi N SOT23 BC108C, n5 w& \: N( Z
D3B RB420D Roh C - 25V 100mA schottky
" `2 l/ l* T: q" i0 iD3E RB411D Roh C SOT23 20V 500mA schottky
& f1 {, p2 H4 Y% r+ ?$ N# iD3J RB420D Roh C - 25V 100mA schottky% S& R o6 C1 V `. _* \0 g$ e# D
D3L RB706D-40 Roh B - dual 45V 30mA schottky
n1 m0 C% ^- ?6 F2 Y k [: z* b9 PD3p BCW33 Phi N SOT23 BC108C. T2 {, X7 ~1 w# ~' b" M5 W* _' b+ k
D3t BCW33 Phi N SOT23 BC108C: m/ ]1 O0 ^; E& |) r
D4 BCW31R Phi R SOT23R BC108A$ L, y9 G( v0 u& m
D4 HSMP-3804 HP B SOT23 dual cc HP3800 pin atten diode; b' X2 y/ V( Y% u
D5 SST215 Tem XQ - n-ch mosfet 20V 1nS6 ~# q- {* Y* d& K$ Y
D5 BCW32R Phi R SOT23R BC108B
) b8 n3 m( p5 V/ \9 ED58 FLLD261 Zet B SOT23 low leakage dual cc Si diode) n: r+ O+ }9 L+ c- ~
D6 BCW33R Phi R SOT23R BC108C
3 ?) K2 [2 |: c" T! HD6 MMBC1622D6 Mot N - MPS3904 hfe 200-400; @0 M" z5 A# K% k, h5 o. S
D63 FLLD263 Zet A SOT23 low leakage dual ca Si diode# Y1 _/ h9 g$ R" M+ I
D7 MMBC1622D7 Mot N - MPS3904 hfe 300-600
2 L2 u& D6 Z8 C' @' H, MD76 BAR18J SGS I SOD232 schottky 70V 15mA3 d9 p3 [# H$ X! A
D76 BAR18 SGS C SOT23 schottky 70V 30mA9 B! W3 X' o; `2 F* J. D- J
D7p BCF32 Phi N SOT23 -
* P7 p5 J( o1 ^5 ?1 ]) `# _! gD7t BCF32 Phi N SOT23 -# U3 f1 O/ t) \; n7 A: ~ V
D85 BAT17DS SGS D - 2xBA481* F8 u) s. F$ E5 e Y
D86 BAT54J ST I SOD232 schottky 30V 300mA" ]9 V- C% s* G( a
D86 BAT54 ST C SOT23 schottky 30V 300mA7 A) U5 t& F: z. s
D87 BAT54C ST B SOT23 dual cc schottky 30V 300mA3 j# A* g( ^* h" A, v, `4 ]
D88 BAT54S ST D SOT23 dual series schottky 30V 300mA
, |& U- H( J, VD8p BCF33 Phi N SOT23 BC146/03
5 r3 E! |; e2 h2 F: a1 t& [D94 BAR42 SGS C SOT23 schottky 30V 100mA
. J0 P0 q& [. R. U, E- {D95 BAR43 SGS C SOT23 schottky 30V 100mA, p: I- M3 S/ R; F6 k4 G2 P/ i- B
D96 BAS70-04 SGS D SOT23 2xBAR18. Z- m/ j2 I; S. m9 z
D97 BAS70-05 SGS B SOT23 2xBAR18* N/ U& A; p6 p( Y
D98 BAS70-06 SGS A SOT23 2xBAR18
* I0 M- A, P: R" V3 WDA BCW67A SGS N SOT23 pnp 32V 0.8A hfe 100 min
! _8 `" @! g" {2 _# KDA BF622 Sie P SOT89 npn 250V video o/p
! h6 I8 [. w C8 ~+ CDA5 BAR43S SGS D SOT23 2xBAR43
+ t3 P( A. h3 b+ S6 ?5 f/ R$ PDB BCW67B SGS N SOT23 pnp 32V 0.8A hfe 160 min
1 O/ C; {0 d2 X& ^* y; ]DB BF623 Sie P SOT89 pnp 250V video o/p
5 ?0 G+ b5 [' G- O5 Z( oDB1 BAR43A SGS A SOT23 2xBAR43# x' ~0 E9 H8 n8 V' i- E+ n
DB2 BAR43C SGS B SOT23 2xBAR43- V5 \1 g5 ~: m% M$ `; H% v, n
DC BCW67C SGS N SOT23 pnp 32V 0.8A hfe 250 min
! R6 m' v& n4 Q; n# t. w* d, aDC BF720 Mot P SOT223 npn 1.5W 300V9 K4 I# Z' V& x
DC BFN20 Sie P SOT89 npn video o/p 300V comp BFN213 h; a# p, X. ]: U8 ^5 a
DD BFN16 Sie P SOT89 npn video o/p 250V comp BFN174 I9 K- F. @ G L8 k, [
DE BFN18 Sie P SOT89 npn video o/p 300Vcomp BFN19( w4 `, P9 T9 {9 p# N2 B3 P5 k: A
DF BCW68F SGS N SOT23 pnp 45V 0.8A hfe 100 min
, I8 W7 k: W. f WDF BF721 Mot P SOT223 pnp 1.5W 300V
+ d- U: G/ v, z* s; W8 ^DF BFN21 Sie P SOT89 pnp 300V video o/p comp BFN201 h1 J3 i. j; Q$ F
DG BCW68G SGS N SOT23 pnp 45V 0.8A hfe 160 min |! T: x# |0 @. G4 h% e6 c" ^+ P7 G
DG BFN17 Sie P SOT89 pnp video o/p 250V comp BFN16. H8 J2 E/ s' u
DH BCW68H SGS N SOT23 pnp 45V 0.8A hfe 250 min
4 Z _+ n2 Y" T2 H! U* J; {DH BCW68G Mot N SOT23 pnp 45V 0.8A hfe 160 min
$ V8 i) h! ]' x( r% J4 w. lDH MMBD2000 Mot C SOT323 Si sw diode 20V 0.2A SOT3239 c9 x( Z" Q5 Z; C9 S' E
DH BFN19 Sie P SOT89 pnp video o/p 300V comp BFN18
1 }8 P8 Q2 M. ?* c' o& K7 [9 LDK BCX42 Sie N SOT23 gp audio pnp 125V comp BCX41" b, m$ }0 `# U% u' @: K
DP MMBD2010 Mot B SOT323 dual cc MMBD2000 3 u% v" j8 L8 w9 K- X' N' x# ], p
DQ 2P710AQ Phi N SOT346 gp pnp hfe 85-170
* I1 k: p* B% H0 k C/ _/ dDR 2P710AR Phi N SOT346 gp pnp hfe 120-240
9 b- q: I, \% gDS 2P710AS Phi N SOT346 gp pnp hfe 170-3409 i8 ]) R1 o1 c
DT BCW67AR SGS R SOT23R pnp 32V 0.8A hfe 100 min ]; B: z: n) N' T: b9 r" }
DU BCW67BR SGS R SOT23R pnp 32V 0.8A hfe 160 min
" L5 p( T4 R9 ^! S/ b6 b& c8 Q; iDW BCW67CR SGS R SOT23R pnp 32V 0.8A hfe 250 min
: F# x6 i) H; ~# K/ B9 @DX BCW68FR SGS R SOT23R pnp 45V 0.8A hfe 100 min# J& I9 ]% B4 n' n
DY BCW68GR SGS R SOT23R pnp 45V 0.8A hfe 160 min% t$ H% E- i# ~. w$ A
DZ BCW68HR SGS R SOT23R pnp 45V 0.8A hfe 250 min
; H/ p& S6 Y) Ye BAT64-02W Sie I SCD80 -
) E* @5 T+ _# _# S' J1 k' }& sE 1SS780 Roh I USM 40V 100mA lo leakage 3 r7 e( ^5 A- c9 B d
E BB689 Sie I SCD80 2-55pF varicap1 _; g+ F3 D# j' l( D
E0 HSMP-3810 HP C SOT23 HP3810 pin atten diode4 O. M9 N! ^3 D8 X# Y; p
E0 HSMP-381B HP C SOT323 HP3810 pin atten diode3 _$ Z p; v8 A9 y
E01 DTDG14EP Roh P SOT89 "npn dtr 60V 1A R2 10k, + c to b zener "3 G5 |' @& ]/ p$ Q' r
E02 DTDG23YP Roh P SOT89 "npn dtr 60V 1A 2k2+ 10k, + c to b zener "
- y7 n3 r' U1 R2 y- B! P% TE1 HSMP-3811 HP K SOT23 HP3810 pin atten diode
! ?7 Y1 q2 I8 Q0 eE11 DTA113ZE Roh N EMT3 pnp dtr 1k0 + 10k 50V 100mA
/ j6 e3 I# I+ a7 r9 i. H* ME11 DTA113ZKA Roh N SC59 pnp dtr 1k0 + 10k 50V 100mA
" R2 X$ S9 a1 N- h% sE13 DTA143ZE Roh N EMT3 pnp dtr 4k7 + 47k 50V 100mA
) V/ U, ~; ^. S2 I5 h8 h* hE13 DTA143ZKA Roh N SC59 pnp dtr 4k7 + 47k 50V 100mA
! a# b4 M2 _& p0 b" y- _E1p BFS17 Phi N SOT23 BFY90 BFW92 {% }" x- j3 D/ B
E1p BFS17W Phi N SOT323 BFY90 BFW92% I% L f5 w5 o
E2 BFS17A Phi N SOT23 npn RF 3GHz 25mA
1 ], B; D0 p9 OE2 BAL99 Zet C - sw diode 75V 100mA8 V5 c, O+ h' _9 L6 o
E2 HSMP-3812 HP D SOT23 dual series HP3810 pin atten diode
. j" n/ T# L2 {" i9 X9 LE23 DTC143ZCA Roh N SOT23 npn dtr 4k7 + 47k 50V 100mA
& `/ J' F" ~' h' I% [E23 DTC143ZE Roh N EMT3 npn dtr 4k7 + 47k 50V 100mA
5 r2 R. f6 w; g! V |5 R8 E4 Q. O& {E23 DTC143ZKA Roh N SC59 npn dtr 4k7 + 47k 50V 100mA0 u% u% l3 }$ C' u. h& W2 L
E3 BAR99 Zet C - sw diode 75V 100mA
4 o7 p; H3 w/ a# ZE3 HSMP-3813 HP A SOT23 dual HP3810 pin atten diode) Q1 g- P1 `2 Y" t3 Y( i
E32 DTA123JE Roh N EMT3 pnp dtr 2k2 + 47k 50V 100mA
% q' [; n; h8 p. S' b) x5 |6 A0 aE32 DTA123JKA Roh N SC59 pnp dtr 2k2 + 47k 50V 100mA* F I! p, Y$ n9 v3 f( X
E4 BFS17R Phi R - BFY90 BFW928 ?; |% @( X! j/ k A
E4 HSMP-3814 HP B SOT23 dual cc HP3810 pin atten diode
4 H" G; H: b) y8 m/ }& b @% \E42 DTC123JE Roh N EMT3 npn dtr 2k2 + 47k 50V 100mA" n' r0 F$ d' n: G
E42 DTC123JKA Roh N SC59 npn dtr 2k2 + 47k 50V 100mA6 s2 }+ [) N# c5 T
E5 BFS17AR Tfk R - npn rf 3 GHz 25mA
0 [& p, F3 X" C* T; d/ fE56 DTA144VKA Roh N SC59 pnp dtr 47k + 10k 50V 100mA
% \# _* s T4 w* T* r4 T2 DE6 ZC2800E Zet C - HP28008 C+ m1 G: ^" y& o8 A' b% M
E66 DTC144VKA Roh N SC59 npn dtr 47k + 10k 50V 100mA- q& B/ q. }. r" h- J
E8 ZC2811E Zet C - HP2811
2 P5 v( v+ K/ J( IE9 ZC5800E Zet C - HP5800' f2 X `6 e' `* ]( n* |4 l( \
EAs BCW65A Sie N SOT23 npn 32V 800mA hfe 100 min, F5 w1 ^+ T+ l1 L) {8 {/ n2 ]7 u
EB HSMP-4810 HP J SOT23 0.5-3GHz pin 2 cathode connections8 [5 ^/ e& K! C5 a) R$ |
EB MSC1022-B Mot H - pnp RF 150MHz fT 20V
' i4 }5 ?: f- ^$ fEBs BCW65B Sie N SOT23 npn 32V 800mA hfe 160 min& K7 d! j6 U) N" O
EC MSC1022-C Mot H - pnp RF 150MHz fT 20V
4 Y5 I0 P" q" V3 ^ECs BCW65C Sie N SOT23 npn 32V 800mA hfe 250 min
- d2 v* B8 g" d" X3 nED BCV28 Sie P SOT89 pnp darlington 30V 0.8A comp BCV29+ g7 a/ \' b4 ?: p
EE BCV48 Sie P SOT89 pnp darlington 60V 0.8A comp BCV49
7 Q$ T) M9 R+ |9 DEF BCV29 Sie P SOT89 npn darlington 30V 0.8A comp BCV28$ \5 I5 x4 @' m' G$ ~
EF BCW66F Sie N SOT23 npn 45V 800mA hfe 100 min
/ s9 v( S$ ?- S0 \# J* \5 U, qEG BCV49 Sie P SOT89 npn darlington 60V 0.8A comp BCV481 Q$ e) W+ p+ D4 W
EGs BCW66G Sie N SOT23 npn 45V 800mA hfe 160 min# C* q! m: h* A2 j0 R5 S+ M
EHAA MAX6326_R22-T Max ZB SOT23 microproc -ve reset gen 2.200V8 J Z) r* S6 g
EHs BCW66H Sie N SOT23 npn 45V 800mA hfe 240 min
" j" W9 _2 V1 k) M7 q2 ?: ^EIAA MAX6327_R22-T Max ZB SOT23 microproc +ve reset gen 2.200V% Q: U7 |% x% U
EJAA MAX6328_R22-T Max ZB SOT23 microproc -ve reset gen 2.200V0 ?4 G, C1 W/ j% C$ i# H
EKs BCX41 Sie N SOT23 gp npn 125V 1A comp BCX42' C, g5 w4 ~* s- n6 J# E$ Q! M2 @
ET BCW65AR Sie R SOT23R npn 32V 800mA hfe 100 min( _7 }! _( x( I; q
EU BCW65BR Sie R SOT23R npn 32V 800mA hfe 160 min
: ~# E& U9 F3 r2 CEW BCW65CR Sie R SOT23R npn 32V 800mA hfe 240 min
% ~" J$ \3 }: Y4 bEWAA MAX6326_R23-T Max ZB SOT23 microproc -ve reset gen 2.320V
2 ~9 d/ v% I5 E/ c. X/ VEX BCW65FR Sie R SOT23R npn 45V 800mA hfe 100 min4 m. ]6 _1 |( k( P5 v/ e) u" R
EXAA MAX6326_R24-T Max ZB SOT23 microproc -ve reset gen 2.400V
" [: j, t0 v( W- A( v; r$ H" e2 REY BCW65GR Sie R SOT23R npn 45V 800mA hfe 160 min2 m, d- F: L* Q
EYAA MAX6326_R25-T Max ZB SOT23 microproc -ve reset gen 2.500V( a0 d' ~9 U/ J+ f# D
EZ BCW65HR Sie R SOT23R npn 45V 800mA hfe 240 min
( V2 k1 H1 L, w) e. l: ]+ gEZAA MAX6326_R26-T Max ZB SOT23 microproc -ve reset gen 2.630V
- K4 N8 N, E0 V% y% s! Bf BAS20-02W Sie I SCD80 -( z2 C) a* [4 D7 m
F KV1831E Tok I URD uhf varicap 2.5-22pf
0 B2 O- x0 q; p! W# c2 ]8 m. b+ {: C6 gF MRF927 Mot N SOT323 npn RF fT 8GHz. P% }# L4 X8 @, q2 f$ G
F0 HSMP-3820 HP C SOT23 35V RF pin sw diode
9 `% Q3 \+ |# S( e3 a- T2 UF02 DTD123TK Roh N SC59 npn dtr R1 2k2 40V 100mA
. h. Z( ]* g# J% s4 [9 |8 J% G( RF03 DTD143TK Roh N SC59 npn dtr R1 4k7 40V 100mA
9 R" `% L) K: B$ `- W( AF05 TSDF1205 Tfk X - fT 12GHz npn RF 4V 12mA
9 S7 |' P$ O$ o% {/ [- N3 @F1 HSMP-3821 HP K SOT23 35V RF pin sw diode
7 s8 B( j% M+ z% c) xF1 BFS18 Phi N SOT23 BF4959 M+ \/ e( q- | W7 j
F1 MMBC1009F1 Mot N - RF npn fT 150MHz hfe30-60
0 F/ q1 f% R# p6 u" YF11 DTB113EK Roh N SC59 pnp dtr 1k + 1k 50V 500mA
$ x3 \/ j$ h p, WF12 DTB123EK Roh N SC59 pnp dtr 2k2 + 2k2 50V 500mA* J( B: g. A* B* d
F13 DTB143EC Roh N SOT23 pnp dtr 4k7+ 4k7 50V 500mA
% o0 N5 U9 ]4 R: [+ f2 N* dF13 DTB143EK Roh N SC59 pnp dtr 4k7+ 4k7 50V 500mA
( j# c* |+ D. X( _/ }' P: {6 n4 _/ mF14 DTB114EK Roh N SC59 pnp dtr 10k + 10k 50V 500mA
! h/ i+ D6 _# K$ l& XF2 HSMP-3822 HP D SOT23 dual series HP3820 pin sw diode/ G7 B: T2 g3 y
F2 BFS19 SGS N SOT23 BF184 BF494* S9 A0 \& V4 O% @( Z
F20 TSDF1220 Tfk X - fT 12GHz npn 6V 20mA; G R- `& Y$ s4 x% \1 f
F21 DTD113EK Roh N SC59 npn dtr 1k + 1k 50V 500mA
- C0 O3 r- V: x( C& nF22 DTD123EK Roh N SC59 npn dtr 2k2 + 2k2 50V 500mA
3 @. ], N* E% sF23 DTD143EC Roh N SOT23 npn dtr 4k7 + 4k7 50V 500mA# p9 r1 k) {/ C% }+ N) h# V
F23 DTD143EK Roh N SC59 npn dtr 4k7 + 4k7 50V 500mA7 w6 }: U1 W/ F! L: N0 d- @) T" X
F24 DTD114EK Roh N SC59 npn dtr 10k + 10k 50V 500mA9 a- I- o& B% M7 G) _
F2p BFS19 Phi N SOT23 BF184 BF494) J8 i/ V( O) j+ S
F2t BFS19 Phi N SOT23 BF184 BF494
# U) [5 H$ o* i. N( ]F3 MMBC1009F3 Mot N - RF npn fT150MHz hfe60-120* ~5 U+ v+ H5 J& O: s; X5 U
F4 BFS18R Phi N - BF495
8 a: z' M0 Q' Q4 D% r2 s+ iF4 HSMP-3824 HP B SOT23 dual cc HP3820 pin sw diode7 Z6 q/ W" k; M) |' W6 O" E
F5 BFS19R Phi N - BF184 BF494
9 B+ W( o9 p. z5 c+ r9 L2 ?F52 DTB123YC Roh N SOT23 pnp dtr 2k2 + 10k 50V 100mA* H9 _- \6 y( [( p( `
F52 DTB123YK Roh N SC59 pnp dtr 2k2 + 10k 50V 100mA
" J$ C6 o; O0 e% x7 k6 R ?F62 DTD123YK Roh N SC59 npn dtr 2k2 + 10k 50V 100mA
; m4 X5 E0 c6 L1 F; i5 e& R7 UF8p BF824 Phi N SOT23 -
4 i- V: y8 {( kF8t BF824 Phi N SOT23 -) P$ o8 d, N! u4 X% i$ s" v
F8t BF824W Phi N SOT323 -
+ N j2 V9 _% XF92 DTB123TK Roh N SC59 pnp dtr R1 2k2 40V 100mA
6 ^6 a- P3 B8 S; L: Q! u& _: w) N$ CF93 DTB143TK Roh N SC59 pnp dtr R1 4k7 40V 100mA
2 q% t2 e: S, P! uF94 DTB114TK Roh N SC59 pnp dtr R110k 40V 100mA* x' A- [: I- [; B1 Z
FA HSMP-4820 HP B SOT23 0.5-3GHz cc pin dual anode0 Q0 `5 ]: P6 w* e7 E. f* M
FA BFQ17 Phi P SOT89 npn RF 1.5GHz 300mA8 a: x- ?6 C! R8 q" z1 {8 D) U
FA BFP81 Sie X - BFQ691 O6 O9 n/ s% W+ t: Q6 `4 R+ t
FA BFQ19 Phi P SOT89 npn RF Ft 5.5GHz 100mA' Q( M G: r* a8 s6 u8 ^" e/ D& `/ t
FAAA MAX6326_R27-T Max ZB SOT23 microproc -ve reset gen 2.700V
4 U; J1 p, K" H+ D* IFB BFP17 Sie X BFW92
- J" h3 E* p- S% BFBAA MAX6328_R31-T Max ZB SOT23 microproc -ve reset gen 2.800V
# t" V, r4 I/ c" i4 C- L. pFC BFQ64 Sie P - BFT98T- b9 H; E, w) n' E- a6 H( }' k. z) q
FC BFP29 Sie X - BFT97$ n2 l% B; Q6 k: A) f. u
FCAA MAX6326_R29-T Max ZB SOT23 microproc -ve reset gen 2.930V: P* |) o" n h8 c3 f9 S9 L& {
FD BCV26 SGS N SOT23 pnp darlington
& n8 H# I% y$ g3 j1 q4 r E. S9 E( LFD BFQ17P Sie P SOT89 BFW16A7 h, G+ T! L6 ~
FD BFP35A Sie X - BFR34A# ^" V0 @8 W4 O' m% X e! G- x2 h
FDAA MAX6326_R31-T Max ZB SOT23 microproc -ve reset gen 3.080V; M3 y+ X; }# `9 c9 u
FDp BCV26 Phi N SOT23 pnp darlington
x* U2 Y: L8 R; J( C. }7 oFDt BCV26 Phi N SOT23 pnp darlington # W0 j' m/ n* I3 h* e" P2 ^6 J2 Q
FE BCV46 SGS N SOT23 pnp darlington
1 `4 i/ T& R. a! V* u$ o% \FE BFP93A Sie X SOT143 BFR91A
* s# ?1 j; m% t! O/ o7 u3 Y# ZFEAA MAX6326_R30-T Max ZB SOT23 microproc -ve reset gen 3.000V& i8 d: U8 r; v) ?; P/ p
FEp BCV46 Phi N SOT23 pnp darlington ( Q8 t* a {" j
FEs BFQ19P Sie P SOT89 BFR96
( c/ g/ q: Q6 R2 J1 DFEt BCV46 Phi N SOT23 pnp darlington & e+ F B9 k3 _1 R- H- n. n
FF BCV27 SGS N SOT23 npn darlington
' q4 x% S3 \$ H5 _9 G) ]# l# lFF BBY65-02V Inf I SC79 hyperabrupt varicap 2.7-30pF# s/ b- }, z0 R
FFAA MAX6327_R23-T Max ZB SOT23 microproc +ve reset gen 2.320V% j% \4 n, {$ L( ?; c
FFMA MAX6327_R31-T Max ZB SOT23 microproc +ve reset gen 3.080V
4 M9 K8 I# q9 ^4 Z( CFFNA MAX6327_R30-T Max ZB SOT23 microproc +ve reset gen 3.000V
7 X3 \" y) {, | S: ~: uFFp BCV27 Phi N SOT23 npn darlington
. D! }! D+ _: {& c7 N/ V8 QFFt BCV27 Phi N SOT23 npn darlington
- H; w% L# o6 A9 y( B1 ^FG BCV47 Phi N SOT23 npn darlington; s9 y5 Z' `/ u; G8 f3 t" C
FG BFQ19S Sie P SOT89 BFR96S: ^. L* J$ ~( i
FGAA MAX6327_R24-T Max ZB SOT23 microproc +ve reset gen 2.400V
, o4 @0 E1 Z& n9 `5 e" [FGp BCV47 Phi N SOT23 npn darlington ( G4 K, [7 N& o8 N; l- f" l) F
FGt BCV47 Phi N SOT23 npn darlington
% G* k0 K) I A1 r7 M; jFHAA MAX6327_R25-T Max ZB SOT23 microproc +ve reset gen 2.500V
5 A) X3 D4 L6 b! h; NFHs BFN24 Sie N SOT23 npn 250V comp to BFN25 + z, s7 w* _6 d n
FIAA MAX6327_R26-T Max ZB SOT23 microproc +ve reset gen 2.630V0 h# c( X5 M: a6 `/ D3 K1 R
FJ BFN26 Sie N SOT23 npn 300V comp to BFN27 1 o! p2 a+ J: ~ w1 m% Q
FJAA MAX6327_R27-T Max ZB SOT23 microproc +ve reset gen 2.700V
$ i( b- E5 A' Z4 t9 a' x/ f9 qFK BFN25 Sie N SOT23 pnp 250V comp to BFN24
# G/ i1 b: W, y/ d& ?; b, [( H+ nFKAA MAX6327_R28-T Max ZB SOT23 microproc +ve reset gen 2.800V6 X- B8 M5 n/ z B1 n, Y
FL BFN27 Sie N SOT23 pnp 300V comp to BFN26
`( I8 H7 e: z s& J1 dFLAA MAX6327_R29-T Max ZB SOT23 microproc +ve reset gen 2.930V' }/ l- x/ W- o& ~6 M
FOAA MAX6328_R23-T Max ZB SOT23 microproc -ve reset gen 2.320V
: t& d* h& h5 oFPAA MAX6328_R24-T Max ZB SOT23 microproc -ve reset gen 2.400V
8 z @$ q7 U9 O( {" z( B+ i6 nF-Q 2PA1576Q Phi N SOT323 gp pnp SC70 hfe 120-2708 k: y1 c% T, ~# @# H8 Y
FQAA MAX6328_R25-T Max ZB SOT23 microproc -ve reset gen 2.500V8 c+ M7 {2 ^9 i
FR 2SA1037AK Roh N - hfe [email=150@1ma]150@1ma[/email] preamp pnp+ r- f) ? z- c) C' G
FR 2SA1576A Roh N UMT see 2SA1037K above
, v: m% d1 g* A0 g# YFR 2SA1774 Roh N EM3 see 2SA1037K above
; s, x6 w( W) O# a6 IF-R 2PA1576R Phi N SOT323 gp pnp hfe 180-390% U1 `7 ~9 K% Y% W: q
FRAA MAX6328_R26-T Max ZB SOT23 microproc -ve reset gen 2.630V J4 \0 |2 @$ P" u
F-S 2PA1576S Phi N SOT323 gp pnp hfe 270-560( N# D, E- F, S2 \
FSAA MAX6328_R27-T Max ZB SOT23 microproc -ve reset gen 2.700V
; W! a5 U" Y* B! E! }2 SFTAA MAX6328_R28-T Max ZB SOT23 microproc -ve reset gen 2.800V* D" S8 V e0 ^, m( a/ F
FtQ 2PA1576Q Phi N SOT323 gp pnp SC70 hfe 120-270% n4 w7 l q: Q
FtR 2PA1576R Phi N SOT323 gp pnp hfe 180-390
) F) \0 p. I: m8 ?) f7 k6 V: G; |FtS 2PA1576S Phi N SOT323 gp pnp hfe 270-5606 j' T/ w1 ?5 m" [/ V
FUAA MAX6328_R29-T Max ZB SOT23 microproc -ve reset gen 2.930V
" e2 x' P* w# e' R _8 JFVAA MAX6328_R31-T Max ZB SOT23 microproc -ve reset gen 3.080V
* G; z, |3 N4 ? eFWAA MAX6328_R30-T Max ZB SOT23 microproc -ve reset gen 3.000V* P) U& O5 u- h3 x
FZAP MAX6012A Max ZC SOT23 precision reference 1.247V
3 {; l& M0 z4 I& ^- AFZAQ MAX6025A Max ZC SOT23 precision reference 2.500V
, s3 x7 m+ J; [# T# l, w4 tFZAR MAX6041A Max ZC SOT23 precision reference 4.096V' [+ [' R: w( M* @$ i8 c- M) n
FZAS MAX6045A Max ZC SOT23 precision reference 4.500V& W! A7 P* g% T! B% _& q ~
FZAT MAX6050A Max ZC SOT23 precision reference 5.000V
8 Z L: s2 D( _1 b3 t. P" dFZAU MAX6021A Max ZC SOT23 precision reference 2.048V
3 S$ b( ~' w* w0 o5 J+ i* O+ z2 ~FZAV MAX6346_R33-T Max ZB SOT23 micrproc -ve reset gen 3.300V+ D0 K" G' }$ x" [: { j
FZAW MAX6346_R34-T Max ZB SOT23 micrproc -ve reset gen 3.400V
& Q1 O. J) k8 O( v+ E3 K5 NFZAX MAX6346_R35-T Max ZB SOT23 micrproc -ve reset gen 3.500V
! S% ~8 |6 a8 b9 P( ^* _5 JFZAY MAX6346_R36-T Max ZB SOT23 micrproc -ve reset gen 3.600V4 J6 i! s' j& H& n
FZAZ MAX6346_R37-T Max ZB SOT23 micrproc -ve reset gen 3.700V: V9 B e$ `$ L2 P) e, |: T
FZBA MAX6346_R38-T Max ZB SOT23 micrproc -ve reset gen 3.800V4 d0 M! z' J# @ } Y. g
FZBB MAX6346_R39-T Max ZB SOT23 micrproc -ve reset gen 3.900V0 D$ L' j. z* ^ d8 y
FZBC MAX6346_R40-T Max ZB SOT23 micrproc -ve reset gen 4.0800V. f. K9 W' W: h' G0 \ r1 W
FZBD MAX6346_R41-T Max ZB SOT23 micrproc -ve reset gen 4.100V R% B, n' F) }) d
FZBE MAX6346_R42-T Max ZB SOT23 micrproc -ve reset gen 4.200V
! a& e# s& ~& [8 N4 k |FZBF MAX6346_R43-T Max ZB SOT23 micrproc -ve reset gen 4.300V% T* K$ O9 i4 O1 B+ G# b
FZBG MAX6346_R44-T Max ZB SOT23 micrproc -ve reset gen 4.380V
# P8 E( I7 Z2 c v4 O7 X% nFZBH MAX6346_R45-T Max ZB SOT23 micrproc -ve reset gen 4.500V k4 u/ r$ y% F) z$ a1 O: R3 v
FZBI MAX6346_R46-T Max ZB SOT23 micrproc -ve reset gen 4.630V
* ]( U4 Z2 |2 B) aFZBJ MAX6347_R33-T Max ZB SOT23 micrproc +ve reset gen 3.300V+ ~5 E7 S0 X+ d% P: Z4 n- |% o
FZBK MAX6347_R34-T Max ZB SOT23 micrproc +ve reset gen 3.400V! E: L4 F5 R( c! |% H9 @; X
FZBL MAX6347_R35-T Max ZB SOT23 micrproc +ve reset gen 3.500V5 ?/ V' A/ S/ S# |* _! D: J
FZBM MAX6347_R36-T Max ZB SOT23 micrproc +ve reset gen 3.600V1 `3 u! K9 K! F" I
FZBN MAX6347_R37-T Max ZB SOT23 micrproc +-ve reset gen 3.700V: N5 T" R9 G6 _4 p4 |6 [+ s
FZBO MAX6347_R38-T Max ZB SOT23 micrproc +ve reset gen 3.800V8 @& m% g9 f) O: Q7 J$ G! `! R
FZBP MAX6347_R39-T Max ZB SOT23 micrproc +ve reset gen 3.900V
0 l- w" N; @* \1 ]$ h6 `6 rFZBQ MAX6347_R40-T Max ZB SOT23 micrproc +ve reset gen 4.0800V/ `" `5 D P8 A0 S, R: C
FZBR MAX6347_R41-T Max ZB SOT23 micrproc +-ve reset gen 4.100V
" O/ s7 q9 u& f! X2 c4 lFZBS MAX6347_R42-T Max ZB SOT23 micrproc +ve reset gen 4.200V
8 y/ u6 a R) j, E/ ]( s6 e9 ZFZBT MAX6347_R43-T Max ZB SOT23 micrproc +ve reset gen 4.300V- O6 I3 Y# H' u( L' [3 r
FZBU MAX6347_R44-T Max ZB SOT23 micrproc +-ve reset gen 4.380V9 |6 g$ {( N5 L. r
FZBV MAX6347_R45-T Max ZB SOT23 micrproc +ve reset gen 4.500V
0 s4 N' g0 j o/ j& k! ^FZBW MAX6347_R46-T Max ZB SOT23 micrproc +-ve reset gen 4.630V1 j; v! N) U) x7 W) A* q, J
FZBX MAX6348_R33-T Max ZB SOT23 microproc -ve reset gen 3.300V$ I1 L9 b5 n) ?! J, Z$ p. b
FZBY MAX6348_R34-T Max ZB SOT23 microproc -ve reset gen 3.400V3 G! Y& S! N' ^% u
FZBZ MAX6348_R35-T Max ZB SOT23 microproc -ve reset gen 3.500V4 _7 I& b7 y. {- x
FZCA MAX6348_R36-T Max ZB SOT23 microproc -ve reset gen 3.600V/ a: x( {2 v8 b, D, [/ P
FZCB MAX6348_R37-T Max ZB SOT23 microproc -ve reset gen 3.700V. v, R5 a# M# [2 D I5 U0 v. I
FZCC MAX6348_R38T Max ZB SOT23 microproc -ve reset gen 3.800V
* {( D: c! _# o% J9 w# mFZCD MAX6348_R39-T Max ZB SOT23 microproc -ve reset gen 3.900V
4 s4 q5 J) [. s5 R( p3 B# v, zFZCE MAX6348_R40-T Max ZB SOT23 microproc -ve reset gen 4.000V# G- M5 u3 D+ D3 H% J5 J( U$ X
FZCF MAX6348_R41-T Max ZB SOT23 microproc -ve reset gen 4.100V
9 q& l: P2 m& h4 ?* |* o" b. eFZCG MAX6348_R42T Max ZB SOT23 microproc -ve reset gen 4.200V' A$ L2 m& I: \9 E8 i9 h2 e
FZCH MAX6348_R43-T Max ZB SOT23 microproc -ve reset gen 4.380V6 z: \/ i0 h+ V! C V4 j
FZCI MAX6348_R44-T Max ZB SOT23 microproc -ve reset gen 4.400V
/ k H( L; }# nFZCJ MAX6348_R45-T Max ZB SOT23 microproc -ve reset gen 4.500V
9 c) ]( A; {$ Y! [FZCK MAX6348_R46-T Max ZB SOT23 microproc -ve reset gen 4.600V0 G' e5 U5 v% r$ U% A9 v
FZCW MAZ6001UR Max ZC SOT23 1.250V V reference. u- ?) M( q. v2 g( i3 P
FZCX MAZ6002UR Max L SOT23 2.500V V reference5 M7 L& x. t0 }* l/ u4 r# z7 P
FZCY MAZ6004UR Max L SOT23 4.096V V reference
2 u4 a% I, `* WFZCZ MAZ6005UR Max L SOT23 5.000V V reference
: o% q% ?# i9 V! x5 S( YFZDA MAX6012B Max ZC SOT23 precision reference 1.247V6 D9 [- Z0 W: T: o5 `) f
FZDB MAX6025B Max ZC SOT23 precision reference 2.500V
9 ] W/ F4 j$ }6 {8 ?0 WFZDC MAX6041B Max ZC SOT23 precision reference 4.096V
( R& A: t+ g* k8 ] J8 xFZDD MAX6045B Max ZC SOT23 precision reference 4.500V
' m; q6 I! _& ^5 hFZdE MAX6050B Max ZC SOT23 precision reference 5.000V# f! m! w" l9 I+ E/ Y+ X' ~; x
FZDF MAX6021B Max ZC SOT23 precision reference 2.047V6 ^6 `, a2 O4 f% o# g! U
FZDK MAZ6003UR Max L SOT23 3.000V V reference7 q0 S5 {( k3 n
FZDW MAX6030A Max ZC SOT23 precision reference 3.000V
! L* Y( |' `6 a. zFZDX MAX6012B Max ZC SOT23 precision reference 3.000V& ?- f5 v! ?+ `* w$ x
FZEB LM4041AIM3-1.2 Max L SOT23 1.225V 0.1% shunt V ref w$ i0 P, u: l0 w5 \# p6 t
FZEC LM4041BIM3-1.2 Max L SOT23 1.225V 0.2% shunt V ref0 @1 A: V) y: R. V6 Q
FZED LM4041DIM3-1.2 Max L SOT23 1.225V 0.5% shunt V ref
( R/ c/ j8 E6 M* f$ ^FZEE LM4041DIM3-1.2 Max L SOT23 1.225V 1.5% shunt V ref( b/ H0 N8 L8 X2 g
FZEF LM4040A IM3-2.1 Max L SOT23 2.048V shunt reference 0.1%
( h6 T. L) I! a9 [FZEG LM4040B IM3-2.1 Max L SOT23 2.048V shunt reference 0.2 %
( \$ @% c3 ?7 B: I. {) r, G7 P0 qFZEH LM4040C IM3-2.1 Max L SOT23 2.048V shunt reference 0.5%. a$ I6 d; L4 l9 J& ]
FZEI LM4040D IM3-2.1 Max L SOT23 2.048V shunt reference 1.0%: l# `! r. ]6 @1 `, e& I3 c0 z
FZEJ LM4040A IM3-2.5 Max L SOT23 2.500V shunt reference 0.1%' R. C: c( ~- a" E# N; }( c# P+ f
FZEK LM4040B IM3-2.5 Max L SOT23 2.500V shunt reference 0.2 %/ R, n f7 y) S, O7 V/ S
FZEL LM4040C IM3-2.5 Max L SOT23 2.500V shunt reference 0.5%- Y- k- V% T, Y2 c/ m7 _ I
FZEM LM4040D IM3-2.5 Max L SOT23 2.500V shunt reference 1.0%, Y0 m; L0 W; x" J. k: u
FZEN LM4040A IM3-3.0 Max L SOT23 3.000V shunt reference 0.1%
* x) L9 s+ O- e; }0 s [* [4 O5 [' fFZEO LM4040B IM3-3.0 Max L SOT23 3.000V shunt reference 0.2 %, I- p7 _ }. z1 K
FZEP LM4040C IM3-3.0 Max L SOT23 3.000V shunt reference 0.5%
2 r' |6 F& L2 V' ~' `8 Q5 ?FZEQ LM4040D IM3-3.0 Max L SOT23 3.000V shunt reference 1.0%* ?2 u- ] U1 H. W2 R
FZER LM4040A IM3-4.1 Max L SOT23 4.096V shunt reference 0.1%
5 P2 A( A7 ~1 k3 ^: F# T. ?FZES LM4040B IM3-4.1 Max L SOT23 4.096V shunt reference 0.2 %
- \4 @/ c0 Y0 g& eFZET LM4040C IM3-4.1 Max L SOT23 4.096V shunt reference 0.5%" |; S+ u# z7 w1 j1 t# o
FZEU LM4040DIM3-4.1 Max L SOT23 4.096V shunt reference 1.0%$ L) w" K7 o% `: d' m, _+ L
FZEV LM4040A IM3-5.0 Max L SOT23 5.000V shunt reference 0.1%
2 a( u7 c5 k, y$ v* L: o ?FZEW LM4040B IM3-5.0 Max L SOT23 5.000V shunt reference 0.2 %
( l; Z0 ^* ^1 ?+ U% m2 S0 t$ d* V# KFZEX LM4040C IM3-5.0 Max L SOT23 5.000V shunt reference 0.5%
& T" e) v. c) o+ J XFZEY LM4040D IM3-5.0 Max L SOT23 5.000V shunt reference 1.0%
& G- J# X2 e5 K/ kFZEZ MAZ803LUR Max ZB SOT23 "microproc -ve reset gen, 5.0V"2 H& O, k8 Z. ~* ~% m! b2 |3 C
FZFA MAZ803MUR Max ZB SOT23 "microproc -ve reset gen, 5.0V"
, v5 R/ r+ I I7 d V& {FZFB MAZ803TUR Max ZB SOT23 "microproc -ve reset gen, 3.3V"
Z& s: a! |# F1 t% N5 L: wFZFC MAZ803SUR Max ZB SOT23 "microproc -ve reset gen, 3.3V"' M2 w3 I- k% z/ F% C) f
FZFD MAZ803RUR Max ZB SOT23 "microproc -ve reset gen, 3.0V"
9 U8 f7 W3 ~) U \6 P0 Y5 s6 ]4 ]FZGH MAZ6006AUR Max L SOT23 1.250V 0.2% shunt V reference
, e0 b& H7 Y. f0 p% aFZGI MAZ6006BUR Max L SOT23 1.250V 0.5% shunt V reference
' I" K H8 F7 k' i4 B5 l4 r5 FFZGJ MAZ6006CUR Max L SOT23 1.250V 1.0% shunt V reference; n2 E' u3 }! C* L
FZGK MAZ6007AUR Max L SOT23 2.480V 0.2% shunt V reference
. H; a' b7 E5 v+ H1 n" pFZGL MAZ6007BUR Max L SOT23 2.480V 0.5% shunt V reference
( U3 u1 K9 A7 Q" k. y1 QFZGM MAZ6007CUR Max L SOT23 2.480V 1.0% shunt V reference
3 |# _+ h* [, r: g z0 v" @FZGN MAZ6008AUR Max L SOT23 2.500V 0.2% shunt V reference
9 p* q) E J0 U- A; H! t9 `FZGO MAZ6008BUR Max L SOT23 2.500V 0.5% shunt V reference7 |+ Y u+ T$ I8 P! M$ \1 ]
FZGP MAZ6008CUR Max L SOT23 2.500V 1.0% shunt V reference
. Y y$ m% G9 j' V7 mFZGQ MAZ6009AUR Max L SOT23 3.000V 0.2% shunt V reference
* |4 Z# F" E# X/ b$ A. oFZGR MAZ6009BUR Max L SOT23 3.000V 0.5% shunt V reference& L! E5 L' L( F! W2 z, S+ l
FZGS MAZ6009CUR Max L SOT23 3.000V 1.0% shunt V reference
. L' g% L0 b8 a% g) L1 G/ |! yG BAR63-02W Sie I SCD80 RF pin to 3GHz f; m* D( Y2 x) x+ V7 f5 |' A
G BAR63-03W Sie I SOD323 RF pin to 3GHz
$ K( R% a+ s) ^G KV1181E Tok I URD uhf varicap 2-16pF
) Q) K/ r; s/ K, a' U }- hG MRF947A Mot N SOT323 npn RF 8GHz7 a, a: n& f) R' N9 x) z1 B- m6 e
G0 HSMP-3890 HP C SOT23 HP3890 pin sw diode " V5 r+ }' |5 M1 J6 P& [
G0 HSMP-389B HP C SOT323 HP3890 pin sw diode 0 d5 J6 z: G. y- S
G08 DTD133HKA Roh N SC59 npn dtr 3k3+10k 50V 500mA
" t' @& j& r) s" L( e' MG1 BFS20 Phi N SOT23 BF1991 H0 ?5 J1 E. y: d, v/ ]; l
G1 BFS20 Phi N SOT23 BF1991 a! M1 E. [7 w! R! O4 p& S
G1 MMBT5551 Mot N SOT23 2N5551 npn Vce 140V
) o! j' x$ \, m6 s; I; b* j4 f$ HG11 DTB113ZKA Roh N SC59 pnp dtr 1k0 +10k 50V 500mA/ a! u- S( r' n+ f1 o$ g9 T) C
G1E BC847A Rho N SOT23 BC547A
& C1 B7 q: \9 {; [, L' @" wG1F BC847B Rho N SOT23 BC547B
+ t$ t3 @5 g3 N1 Q# i M5 fG1G BC847C Rho N SOT23 BC547C
: e- Q* g a S5 I# OG1J BC848A Rho N SOT23 BC548A
t! Z- b7 m9 y% GG1K BC848B Rho N SC70 BC548B
/ ~; n+ b2 g* T! I5 I+ eG1K BC848B Rho N SOT23 BC548B
0 Q$ D1 J; O0 O4 @$ XG1L BC848C Rho N SOT23 BC548C
" o! f% W% F6 `3 u* m- RG1p BFS20 Phi N SOT23 BF1992 ^9 X4 e0 V2 e
G1t HSMP-3891 HP K SOT23 HP3890 pin sw diode! S* T; E3 A/ J' F. P. b, ?* p" J
G2 HSMP-3892 HP D SOT23 dual ser HP3890 pin sw diode3 m& T) z2 ^3 g/ X3 X: z
G2 CGY50 Sie IQ SOT143 GaAs MMIC amp
/ [# u9 K/ s6 e9 X# V+ ^G21 DTD113ZKA Roh N SC59 npn dtr 1k0 +10k 50V 500mA% j! X6 K8 v' S) W
G3 HSMP-3893 HP A SOT23 dual HP3890 pin sw diode
5 i# d( I$ d qG3 BAR63 Sie C SOT23 single 3GHz pin
8 j5 v* }9 s8 D5 kG3C DTB122JK Roh N SC59 pnp dtr 220R + 470R 50V 500mA$ S! j! p) g( j D) ^
G3E BC857A Roh N SOT23 BC557A
7 b s/ E. T" I$ W% s9 h0 w cG3F BC857B Roh N SOT23 BC557B0 m" m0 f* q2 p7 ^* b
G3J BC858A Roh N SOT23 BC558A) ]' y! }& \ w+ A! u7 K
G3K BC858B Roh N SOT23 BC558B- u: V1 t- Y! x9 } u9 G
G3K BC858B Roh N SC70 BC558B; B$ w5 Q3 V$ n6 C
G3L BC858C Roh N SOT23 BC558C( o9 T& n* Q) t4 k/ i. h6 \
G4 BFS20R Phi N SOT23 BF199
- u+ Q# [. z5 E; fG4 HSMP-3894 HP B SOT23 dual HP3890 pin sw diode8 d2 e% Y& H7 u1 R# @ [
G4 BAR63-04 Sie D SOT23 dual series 3GHz pin 6 Q7 n2 `; L/ w- b
G4C DTD122JK Roh N SC59 npn dtr 220R + 470R 50V 500mA
: g$ B. j/ n. N! X( ~$ [+ @G4s BAR63-04W Sie D SOT323 dual series 3GHz pin k: f/ @' C/ A+ B7 M7 \+ U
G5 HSMP-3895 HP S SOT143 dual HP3890 pin sw diode
% s! P4 r$ C7 vG5 BAR63-05 Sie B SOT23 dual cc 3GHz pin
' P1 `- u+ M/ Z4 @. O0 n) _; bG5B BC807-25 Roh N SOT23 BC327-25
1 Y _8 a8 A9 {* F6 ~G5s BAR63-05W Sie B SOT323 dual cc 3GHz pin & ?9 J# ]+ Q$ [2 H: ~& ], E1 e
G6 BAR63-06 Sie A SOT23 dual ca 3GHz pin + a/ v O- W1 N4 y
G6A BC817-16 Roh N - BC337-166 d" n: |+ m' d* Z. ^8 G
G6B BC817-25 Roh N SOT23 BC337-25( \( K' q( }6 f6 M* s9 W
G6s BAR63-06W Sie A SOT323 dual ca 3GHz pin
/ `% m. c0 k7 v- I/ D- FG7 BF579 Tfk N - BF979 pnp uhf fT 1.75GHz
Y) a1 E. v# r, s' b( r6 ^& GG98 DTB133HKA Roh N SC59 pnp dtr 3k3+10k 50V 500mA
: C) G' [% o5 I8 o, B( IGA HSMP-4890 HP B SOT23 0.5-3GHzdual cc pin limiter
2 C; [, l) t2 V) L, B- p% _$ IGA BAW78A Sie LQ SOT89 50V1A sw diode
7 @/ {+ Q$ S7 f+ ?# Y7 WGAB BCW60B Rho N SOT23 BCY58-viii % u. U O! m( T9 q5 O
GAC BCW60C Rho N SOT23 BCY58-ix
0 _- ?% C# t( E9 L2 VGAD BCW60D Rho N SOT23 BCY58-x
3 c6 `" Y& @; E3 \GAH BCX70H Rho N SOT23 BCY59-viii BC107B! a% Z2 |! d, B
GAJ BCX70J Rho N SOT23 BCY59-ix BC107
v+ ?6 U; h9 r+ \+ z9 J, P" s; UGAK BCX70K Rho N SOT23 BCY59-x BC107; `/ ]7 m( c9 M8 @* N+ S% D& u
GB BAW78B Sie LQ SOT89 100V 1A sw diode , A2 L6 q. }3 N1 X) B
GBB BCW61B Rho N SOT23 BCY78-viii1 y' N" t; A0 I1 G1 `: Q
GBC BCW61C Rho N SOT23 BCY78-ix
+ p) [! A8 Y+ |0 |# l3 w# zGBG BCX71G Rho N SOT23 BCY79-vii
: L2 G9 f" t/ {* T8 GGBH BCX71H Rho N SOT23 BCY79-viii
- G2 ?& X; l6 ?2 D3 M: q: @9 sGBJ BCX71J Rho N SOT23 BCY79-ix7 ]) d$ ]5 M. r* r
GC BAW78C Sie LQ SOT89 200V 1A sw diode % ^0 P* P$ I4 b/ H1 F5 P% r
GC1 BCW29 Roh N SOT23 BC178A
% W* J1 r% `$ s+ c" z2 I* uGC2 BCW30 Roh N SOT23 BC178B
3 X% h# q7 s* @GD BAW78D Sie LQ SOT89 400V 1A sw diode! G8 R) ? R4 J, W4 Y0 f7 ~: D# Z& Y
GD1 BCW31 Roh N SOT23 BC108C
7 W3 }- y- e/ u, j1 N( rGD2 BCW32 Roh N SOT23 BC108B
- x4 {" j' ~5 j8 x, @GD3 BCW33 Roh N SOT23 BC108A; Z( E- N, Y1 b1 t; }4 j- M2 |
GE BFR35AP Sie N SOT23 BFR34A
5 P p1 C$ m( w6 n5 ^( z# v9 EGE BAW79A Sie JQ SOT89 dual cc 50V 1A switch diodes
+ @% U' J7 w; n) {GEC BCW65C Rho N SOT23 npn 32V 800mA hfe 250 min; `+ u7 i& |" y# @
GF BFR92P Sie N SOT23 BFR90
( t% ?- a( v- }" g% o3 |GF BAW79B Sie JQ SOT89 dual cc 100V 1A switch diodes 9 G* S# `; g, {, ]4 f
GG BF579R Tfk R - BF979 pnp uhf fT1.75GHz: p! r1 n' W# @
GG BFR93P Sie N SOT23 BFR91A
7 u+ ^, P& V! b: r% WGG BAW79C Sie JQ SOT89 dual cc 200V 1A switch diodes + ^3 m( Y& j+ n X0 t( ^
GH BAW79D Sie JQ SOT89 dual cc 400V 1A switch diodes
2 Y# J: B5 I3 f/ ^6 fGH1 BCW69 Roh N SOT23 BC177A
1 v- f7 S6 \2 n# }GH2 BCW70 Roh N SOT23 BC177B' f+ M1 p! m* \/ z, v4 Y
GK1 BCW71 Roh N SOT23 BC107A* Z! _. f) u x% q! u- b
GK2 BCW72 Roh N SOT23 BC107B ZXT300" J. F3 h0 h% \7 G; e. Y" S3 T
GLP MMBT1010 Mot N SOT23 pnp 15V hfe 300-600 @100mA
" h. X0 Z0 X5 wGLP MMBT1010 Mot N SOT346 pnp 15V hfe 300-600 @100mA
' [ N( `) k, v* N) aGMA BFS17 Roh N SOT23 BFW92
: a# m! i, w0 DGT1 BCX17 Roh N SOT23 BC3279 |( K1 W( v' [$ N2 T0 a
GT2 BCX18 Roh N SOT23 BC328' \ _$ D' r/ I6 i5 J# ^6 K$ j
GU1 BCX19 Roh N SOT23 BC337
I- {8 E2 G. U# h$ h g; qGU2 BCX20 Roh N SOT23 BC3383 Y# s* E+ ]( h) G" l
H MRF947B Mot N SOT323 npn RF 8GHz
$ {8 B8 \- x+ I( [# g a1 Y. vH BB659C Sie I SCD80 2.5-39 pF varicap in : F+ U4 ?& \% f5 B" q+ q8 n! S
H BBY51-03W Sie I SOD323 3-5 pF varicap in / F. E; d2 o) v
5 U- T- ]" P0 o' aH BB659C Sie I SCD80 2.5-39 pF varicap in
: \: r5 ?2 e# E; dH BBY51-03W Sie I SOD323 3-5 pF varicap in
- {' c8 U0 X- R$ b$ t. @H02 DTC323TU Rho N SC70 "npn dtr 15V 0.6A, R1 2k2 , for muting "- ~8 d, r0 q+ L* v5 m- X
H02 DTC323TU Rho N SC70 "npn dtr 15V 0.6A, R1 2k2 , for muting "9 V% W6 T# W: M0 `' H5 f3 f
H04 DTC323TU Rho N SC70 "npn dtr 15V 0.6A, R1 10k , for muting "! J; s2 @* _+ W& |3 |6 n B! _
H04 DTC323TU Rho N SC70 "npn dtr 15V 0.6A, R1 10k , for muting " M3 \0 K( d: }
H1 BCW69 Phi N SOT23 BC177A $ p1 h. O2 F6 {7 B' [2 m" L. k% t
H1 BCW69 Phi N SOT23 BC177A # g9 p* O# ?/ o1 {7 i F
H11 UMH11TN Roh DI - npn/pnpdtr pair 10k+10k
?+ w6 R3 o: i3 B7 kH11 UMH11TN Roh DI - npn/pnpdtr pair 10k+10k
- F7 K/ |% D9 Z' T* JH16 SST4416 Sil F - 2N4416 n-ch jfet8 Q# V5 e3 l, @+ q
H16 SST4416 Sil F - 2N4416 n-ch jfet( j( g9 T. z; Q0 _& H9 u/ j: E
H1p BCW69 Phi N SOT23 BC177A
9 P7 n8 q, R, t. O+ M4 V0 L2 L3 xH1p BCW69 Phi N SOT23 BC177A 4 N7 w+ {7 b+ S* S/ w0 ]% k
H1t BCW69 Phi N SOT23 BC177A $ D5 w) F9 K" }& a) M
6 w7 Q5 h+ a0 @- yH2 BCW70 Phi N SOT23 BC177B
7 S& @" b5 g% D8 @3 q/ lH2 BCW70 Phi N SOT23 BC177B 9 z# I6 k* U, ]7 k2 N
H27 DTC323TU Rho N SC70 "npn dtr 15V 0.6A, R1 6k8 , for muting"& a# X$ J+ F# N: C
H27 DTC323TU Rho N SC70 "npn dtr 15V 0.6A, R1 6k8 , for muting"( c1 W; H7 S& K0 G
H2p BCW70 Phi N SOT23 BC177B # r0 y# I' w6 b7 o t( a
H2p BCW70 Phi N SOT23 BC177B 6 d7 k# Q2 w _2 u
H2t BCW70 Phi N SOT23 BC177B
, |; P4 {% n3 q z7 hH2t BCW70 Phi N SOT23 BC177B & j' _/ F$ p1 x& O5 a4 F
H3 BCW89 Phi N SOT23 BC556
& H& M3 X% X6 v) @H3 BCW89 Phi N SOT23 BC556
1 B0 e6 Q* v8 L: g+ @H31 BCW89R Phi N SOT23R BC556 `6 L% m3 L$ D
H31 BCW89R Phi N SOT23R BC5563 M5 j+ Y6 _9 A6 N0 q1 B
H3p BCW89 Phi N SOT23 BC556 $ V9 V, e' I/ T% U/ B" H, E7 K
* F2 S% f% m oH3t BCW89 Phi N SOT23 BC556
! y2 w: |" }5 |7 ]4 J6 Z0 m" U) ZH3t BCW89 Phi N SOT23 BC556 ! _. [6 M- d, k: d7 j
H4 BCW69R Phi R SOT23R BC177A
. o; m |2 h( K- _5 J' `) ]1 l3 D3 w' GH4 BCW69R Phi R SOT23R BC177A
9 j# m1 Q. a; ?* x- N' K- j9 FH5 BCW70R Phi R SOT23R BC177B
' J6 w6 Y: y. g, J6 }H5 MBD770DW Mot DL - Dual UHF schottky diode" E, `8 I+ z8 z' }; G8 X
7 N# D8 O/ b3 A+ q) n4 k9 QH5 MBD770DW Mot DL - Dual UHF schottky diode
% j: z# U2 P/ z1 d$ RH6 BCW89R Phi R SOT23R BC556
* k) t8 U0 v& ?H6 BCW89R Phi R SOT23R BC5567 X, j5 S# q9 @& {; B l
H84 SST5484 Sil F SOT23 2N5484' j! A2 K; V. E2 `
4 r! @1 _! M: h3 |' [8 [H85 SST5485 Sil F SOT23 2N54859 H# _/ I: R3 b# {+ P" R4 i N2 ~
+ j& [# j/ w1 u7 W: w2 iH86 SST5486 Sil F SOT23 2N5486" ]3 |/ O X$ h# X( l' f, [
H86 SST5486 Sil F SOT23 2N54860 ?6 @+ z# Q+ ?+ C
HB BFN22 SGS P SOT23 npn Vce 250V% Z: o; ~- |8 c4 ^" |8 T5 t
% \+ s2 H/ W1 N$ t0 g }* r' `HC BFN23 SGS P SOT23 pnp Vce 250V: F/ d$ }! s' Z5 c
3 R0 O; e9 _' T% VHG CFY77-08 Sie DM - 20GHz HEMT 0.8dB nf+ l+ H5 b a/ K! K& T- l1 ~3 t
HG CFY77-08 Sie DM - 20GHz HEMT 0.8dB nf2 Z" j7 l+ `- J9 L6 M* t( z' E
HH CFY77-10 Sie DM - 20GHz HEMT 1.0 dB nf
3 s3 h ?5 {- O1 y+ qHH BBY51-07 Sie S SOT143 dual varicap like BBY51% O: p0 ?& O z$ z7 k& {
HH CFY77-10 Sie DM - 20GHz HEMT 1.0 dB nf/ x0 Y1 o" J2 ~2 f3 ?3 f! u
HH BBY51-07 Sie S SOT143 dual varicap like BBY519 {6 Q! F- Y: R+ a. M
HQ 2SA1036K Roh N - pnp 500mA driver
" Q' T+ W4 k" e2 T( _6 XHQ 2SA1036K Roh N - pnp 500mA driver" A) H8 `7 N. m) V2 j
J0 HSMS-2840 HP C SOT23 schottky diode& t A* l4 x; n+ r, p
J01 SO2906R - N - 2N2906- u D9 i* X1 ^9 Y5 q9 `8 }& ?! `* V
J03 SO2907AR - R - 2N2907A9 w- ]- j- f. j* H( S3 Y$ s$ U
J05 SO2907R - R - 2N2907
+ V9 E* M. Z" _+ F0 `' S) |- ^" i5 D ^J1 HSMS-2841 HP K SOT23 schottky diode5 |9 k+ @. U8 T0 l k
J1 ZC830 Zet C ZC820 varicaps" v7 ?9 d/ Z: p) u& [( W
J1 BSS138L Mot M SOT23 n-ch enh TMOS fet& g' @% }( X8 d1 f* N" A0 {
J12 SO2906AR - R - 2N2906A
7 D$ T# ?& c" Q/ pJ1A ZC830A Zet C SOT23 varicap hyperabrupt 28V [email=10pF@2V]10pF@2V[/email]
7 O% N$ ?1 e) F' }5 pJ1B ZC830B Zet C SOT23 varicap hyperabrupt 28V [email=10pF@2V]10pF@2V[/email]2 x+ X% d+ }$ A1 d
J2 ZC833 Zet C SOT23 ZC823( K) P5 r/ E! J9 G4 E- T' p, }
J2A ZC833A Zet C SOT23 varicap hyperabrupt 28V [email=33pF@2V]33pF@2V[/email]0 E6 B$ m7 V* j0 X. ^; [0 j/ ~
J2B ZC833B Zet C SOT23 varicap hyperabrupt 28V [email=33pF@2V]33pF@2V[/email]! _! j% p( K% |" @
J3 ZC831 Zet C SOT23 ZC821* u! J+ s+ p0 B& L( X% U
J32 SO5400R SGS R - 2N5400
$ D4 ?. l4 m% FJ33 SO5401R SGS R - 2N5401
/ W) X* J4 J6 [. p+ uJ39 SO692R SGS - - pnp Vce 300V! @3 y5 | q8 q1 ~
J3A ZC831A Zet C SOT23 varicap hyperabrupt 28V [email=15pF@2V]15pF@2V[/email]
; t9 n1 O, j* M, ]+ b4 ^J3B ZC831B Zet C SOT23 varicap hyperabrupt 28V [email=15pF@2V]15pF@2V[/email]
* W; f; t( y/ t" \5 n+ `J3D MSB81T1 Mot - vhf pnp fT 0.6GHz
. R6 V( t$ G% u& H1 O; h' eJ4 ZC832 Zet C SOT23 ZC823
$ K) k/ {0 j7 ^9 m: iJ4A MBV109 Mot C SOT23 29pF VHF varicap diode * e8 A$ K; M2 z2 {6 M
J4A ZC832A Zet C SOT23 varicap hyperabrupt 28V [email=22pF@2V]22pF@2V[/email]+ g$ s# C9 @5 F3 K
J4B ZC832B Zet C SOT23 varicap hyperabrupt 28V [email=22pF@2V]22pF@2V[/email]) ~. |9 Z# F6 a& d U$ O
J5 ZC834 Zet C SOT23 ZC824
' g6 a; Q+ `3 ?J5A ZC834A Zet C SOT23 varicap hyperabrupt 28V [email=47pF@2V]47pF@2V[/email]
) B% V/ Q, K, h0 y; UJ5B ZC834B Zet C SOT23 varicap hyperabrupt 28V [email=47pF@2V]47pF@2V[/email]) D7 B( p5 `. U4 t, L& D
J6 M1MA174 Mot C - gp Si diode 100V
; h7 r! p0 @$ `+ d; U0 _J6 ZC835 Zet C SOT23 ZC825
$ L4 U( O* [6 i, w( S5 b1 {" ^J6A ZC835A Zet C SOT23 varicap hyperabrupt 28V [email=68pF@2V]68pF@2V[/email]+ l$ o% i. V: Q: i/ [# Y9 L
J6B ZC835B Zet C SOT23 varicap hyperabrupt 28V [email=68pF@2V]68pF@2V[/email]1 @/ U S! U: d' Q: X* E5 h
J7 ZC836 Zet C SOT23 ZC8262 g$ y; c3 r! J/ e
J7A ZC830A Zet C SOT23 varicap hyperabrupt 28V [email=100pF@2V]100pF@2V[/email]* R8 b3 o& d; N% w% P. p5 f( M
J7B ZC830B Zet C SOT23 varicap hyperabrupt 28V [email=100pF@2V]100pF@2V[/email], T8 B7 {8 }7 }0 u0 I, m2 }
J8 BCX71JR Phi R SOT23R BCY79-ix. h2 C, v) w. J' ?2 k" n: C
J9A ZC829A Zet I SOT23 varicap hyperabrupt 28V [email=8.2pF@2V]8.2pF@2V[/email]" C: o$ W* [% i: ]3 ~- X- t
J9B ZC829B Zet I SOT23 varicap hyperabrupt 28V [email=8.2pF@2V]8.2pF@2V[/email]$ m2 f: C& A! L8 Y+ l2 e
JA BAV74 Zet B SOT23 dual diode cc 50V 0.1A/ N6 E7 a1 y" T5 H8 V4 E
JA BAV74 Mot B SOT23 dual sw diodes% t% O6 w' s& U
JBs BAR74 Sie C SOT23 fast sw diode 50V 0.25A
7 K- y) u. ?+ w3 S7 T4 dJCs BAL74 Sie V SOT23 fast sw diode 50V 0.25A
* }( P9 ] u1 }$ Q+ jJFs BAL99 Sie V SOT23 fast sw diode 70V 0.25A& H) n. ^$ ]4 C8 |% I! Q. u; _
JG BAR99 Sie E - fast sw diode 70V 0.25A- M; w4 N$ ?6 q ~
JKs BF1009 Sie W SOT143 biased n-ch dg mosfet 1GHz 9V
2 ? D b, i5 U2 `" y- J. ]JL MRF949 Mot N SOT323 npn RF fT 9GHz
' V Q- }5 Y3 Z" O0 s7 `2 M( u; KJLs BF1009S Sie W SOT143 biased n-ch dg mosfet 1GHz 9V
5 W7 b/ O6 X" ~& _1 @JPs BAS19 Sie C SOT23 120V 250mA fast sw diode' A' ?/ d4 F+ d
JPs BAW101 Sie S SOT143 pair isolated 300V sw diodes
2 L' F8 C8 l- ? S# UJRs BAS20 Sie C SOT23 150V 250mA fast sw diode& f [( O7 I! B" ~
JS BAW100 Sie Y SOT143 dual isolated fast sw diodes
; m9 E7 M9 D) ]% u/ TJSs BAS21 Sie C SOT143 200V 250mA fast sw diode' o! F) r6 X- I- _2 W, b q9 X2 a5 @
JTs BAS28 Sie S SOT143 dual isolated fast sw diodes
; I8 b, B0 h+ ?/ E. z8 hJTs BAS28W Sie FQ SOT343 dual isolated fast sw diodes
+ f {0 ]; l% |% q \% DJV BAS116 Sie C SOT23 250V 75mA Ir 5nA# ^. Q) H$ A l
JX BAV170 Mot B SOT23 dual cc Si diode low Ir( t* a, _- h8 c! p! P$ e0 I/ @
JY BAV199 Mot D SOT23 dual series Si diode low Ir
7 s" X. r! D* k7 qJZ BAW156 Mot A SOT23 dual ca Si diode low Ir: b! j7 [& K4 ^
K BAT68-03W Sie I SOD323 BAT68 Schottky
/ u8 [ S$ c) N8 x3 |/ ] jK BBY52-02W Sie I SCD80 UHF varicap 1.75-1.25pF ; A! }0 T) Y; \+ Z) Y$ d
K MRF917 Mot N SOT323 npn RF fT 6GHz
" x/ Z4 f* w q5 J& bK0 HSMP-3830 HP C SOT23 gp pin diode HP3830
: Z+ N; Y0 I- n6 |3 d$ n% E( qK1 HSMP-3831 HP K SOT23 gp pin diode HP3830
2 c8 j/ u; Y# I* HK1 BCW71 Phi N SOT23 BC107A
! s B! v; F2 e/ Q0 e/ i: S# BK14 DTA114GE Roh N EMT3 pnp dtr 50V 100mA R2 10k , @; J3 `" Z( f3 P# u# \
K14 DTA114GUA Roh N SC70 pnp dtr 50V 100mA R2 10k
4 @( e! t% |; O/ e2 ]K14 DTA114GKA Roh N SC59 pnp dtr 50V 100mA R2 10k * L( ]+ }) n' S* ]% I3 Q [, B
K15 DTA124GKA Roh N SC59 pnp dtr 50V 50mA R2 22k
3 r1 j" ]' H& J7 F/ w' X9 |1 UK16 DTA144GUA Roh N SC70 npn dtr 50V 100mA R2 47k . G- s% s! R; q5 @+ B
K16 DTA144GKA Roh N SC59 npn dtr 50V 100mA R2 47k , z! p9 J, E/ O! H h
K19 DTA115GUA Roh N SC70 npn dtr 50V 100mA R2 100k N! r2 p2 r0 T4 }% G% I
K19 DTA115GKA Roh N SC59 npn dtr 50V 100mA R2 100k 8 `5 T" i7 M+ ~; D4 [; V% @
K1p BCW71 Phi N SOT23 BC107A ( m! O( ?/ y! f% k, c) S% U5 e( B
K1t BCW71 Phi N SOT23 BC107A" g/ P9 W& L$ m/ s! G5 ]/ z
K2 BCW72 Phi N SOT23 BC107B ZXT300 ) r3 L8 A( I# M" k
K2 HSMP-3832 HP D SOT23 dual HP3830 pin diode
, [3 I; ]8 D v- Y$ o9 s' `K24 DTC114GUA Roh N SC70 npn dtr 50V 100mA R2 22k4 ?# t l) s, ^5 ?
K24 DTC114GKA Roh N SC59 npn dtr 50V 100mA R2 22k
3 I& t b u r- b% h3 }K25 DTA124GUA Roh N SC70 pnp dtr 50V 50mA R2 22k
- K% j/ E! V2 Y& a& ]) }K25 DTA124GKA Roh N SC59 pnp dtr 50V 50mA R2 22k ; b2 W0 {: v7 I; `1 }
K26 DTC144GE Roh N EMT3 npn dtr 50V 100mA R2 47k
; e: Y+ ]1 Y j* {K26 DTC144GUA Roh N SC70 npn dtr 50V 100mA R2 47k
' s! s. A$ K( r" E2 m- JK26 DTC144GKA Roh N SC59 npn dtr 50V 100mA R2 47k
' x4 `4 ?; \5 _8 wK29 DTC115GUA Roh N SC70 npn dtr 50V 100mA R2 100k/ N& T, f8 T4 Q1 }4 ~3 V' F, f
K29 DTC115GKA Roh N SC59 npn dtr 50V 100mA R2 100k
! k( o( |" N8 H" U! q4 iK2p BCW72 Phi N SOT23 BC107B ZXT300; C# I( D4 O$ ?. k8 _
K2t BCW72 Phi N SOT23 BC107B ZXT300 . d3 o0 {. Z9 L. }; h
K3 HSMP-3833 HP A SOT23 dual HP3830 pin diode
6 S/ B) j! ] H V9 d$ O' ~* bK3 BCW81 Phi N SOT23 npn 50V 0.1A 0.2W hfe 420
2 ~1 E2 n7 A( z' W4 K; `' ]K31 BCW81R Phi R - npn 50V 0.1A 0.2W hfe 420
! c% j. t% q; }6 F1 [K3p BCW81 Phi N SOT23 npn 50V 0.1A 0.2W hfe 420 / }2 \& q! M8 b! c/ z! N2 U
K3t BCW81 Phi N SOT23 npn 50V 0.1A 0.2W hfe 420
+ s5 n- E! ^9 V, `; IK4 BCW71R Phi R SOT23R BC107A8 z, @3 R3 L, o5 b' M: n1 u
K4 HSMP-3834 HP B SOT23 dual HP3830 pin diode4 t0 P# [' X0 M, E( _
K5 BCW72R Phi R SOT23R BC107B ZTX300; R8 {9 N: x0 Q: t+ ]) G2 u8 Z: w2 R2 a
K6 BCV71R Phi R SOT23R BC546A) a; C) e+ p* ]! M* F
K7 BCV71 Phi N SOT23 BC546A
2 q3 w% W, | w/ ]- EK7p BCV71 Phi N SOT23 BC546A
. S- w( H$ @$ _4 G4 sK7t BCV71 Phi N SOT23 BC546A
8 b) L6 d+ P4 C% P& uK8 BCV72 Phi N SOT23 BC546B $ F) } l' G* I5 l4 Q
K8p BCV72 Phi N SOT23 BC546B
; B+ T, l: z! F# d! q5 o/ DK8t BCV72 Phi N SOT23 BC546B
) f. S) l w6 h ?4 X! k( x' qK9 BCV72R Phi R SOT23R BC546B2 w& H+ e! {7 o1 v3 a
KB MMBT8099L Mot N SOT23 npn 80V gp
P; h" X3 r' k) kKC BFQ29P Sie N - BFT66
% S- v( C6 g9 Z. {1 h' w( xKM BST80 Phi T - VN10 b7 ]' O) y; b( l. j' x
KN BST84 Phi T - Nch VMOS 200V 0.25A
5 Q2 M- F {- Q0 |) XKO BST86 Phi T - nch VMOS 180V 0.3A5 [% y% k. S | x& H/ q
L BAT62-03W Sie I SOD323 BAT62 schottky detector/ ?4 Q& \- j/ X; L
L BBY53-02W Sie I SCD80 varicap 5.3-2.2 pF
6 f: w7 Z2 _; h% F0 D% Z+ h8 iL0 HSMP-386B HP C SOT323 gp RF pin diode / k* p6 B) \2 ^5 Q. Z1 N* \
L0 HSMP-3860 HP C SOT23 dual series pin diode 6 A1 |! S# z3 |+ Q9 B$ D
L0 BAT721S Phi C SOT23 dual series 40V 200mA schottky
6 T: M5 A8 n( @! b5 P! t5 JL05 ZLLS500 Zet C SOT23 schottky 40V 0.7A low leakage high temp
5 }) r: r; c$ G, C+ C& cL1 BSS65 Zet N - pnp 12V 0.1A 400MHz sw
- S( O) ]' h$ p( L5 n* m: T6 JL10 ZLLS1000 Zet C SOT23 schottky 40V 1.1A low leakage high temp
- I, s9 s" O2 Q) b3 CL14 DTB114GK Rho N SC59 "pnp dtr 0.5A, R2 10k "0 w# i7 d! u Y0 q; I( F: w
L14 DTD114GK Rho N SC59 "npn dtr 0.5A, R2 10k ") |# w1 M* ~2 v/ @
L2 HSMP-3862 HP D SOT23 dual RF pin diode
! e* z; n, q9 o) o% N6 u3 G4 E7 t; J% yL2 BSS69 Zet N - pnp 40V 0.1A 200MHz sw; d+ Q3 i T* Z
L20 BAS29 Nat C SOT23 Si diode 120V 50mA
; d( _1 k* x# O4 D- h& O9 |L21 BAS31 Nat D SOT23 dual BAS29 diodes# w/ o* ?. f/ |
L22 BAS35 Nat A SOT23 dual BAS29 diodes
- a1 V/ V& k* J5 c- ]' `4 fL3 BSS70 Zet N - pnp 40V 0.1A 200MHz sw6 P K+ X9 g. J$ c u: _6 B
L3 MMBC1623L3 Mot N - npn 40V gp
+ i( {, n( v+ G, z4 SL3 HSMP-3863 HP A SOT23 ca gp RF pin diode
9 L+ n, b3 Y) b" {8 F/ Z8 z2 JL30 BAV23 Phi S SOT143 dual 200V 225mA diodes
! Q1 q3 q' n7 U+ R) pL4 HSMP-3864 HP B SOT23 cc gp RF pin diode2 I5 }& }7 q) K
L4 BAT54W Phi C SOT323 BAT85 schottky2 ~( e% @) @ M0 p1 R! I
L4 MMBC1623L4 Mot N - npn 40V gp& q+ o3 L: z2 R* R8 V0 u
L41 BAT74 Phi S SOT143 2x BAT85
5 u# |; W! f& c4 z4 \( JL42p BAT54A Phi A SOT23 dual c anode schottky
9 Y& @3 T5 G: U# r7 J( ?L43p BAT54C Phi B SOT23 dual c cathode schottky
7 K$ k: ^* W! K! w$ E" LL44p BAT54S Phi D SOT23 dual series schottky- R- L+ {+ X' I o8 T
L4p BAT54 Phi C SOT23 BAT85 schottky
( k% \( `) U: i5 AL4Z BAT54 Zet C SOT23 BAT85 schottky
, l3 \: w ^7 ?- G/ c7 xL5 BSS65R Zet R - pnp 12V 0.1A 400MHz sw: b: M$ r$ u5 T
L5 MMBC1623L5 Mot N - MPS3904 hfe 135-270; C7 m0 p- o) I# h3 x3 [- m& O. |
L51 BAS56 Phi S SOT143 dual 60V 200mA diodes
& b5 o, f. s% y0 ]' q# c0 E% Y' ZL6 BAR17 Sie C - pin diode
; l9 j9 Q W$ vL6 BSS69R Zet N - pnp 40V 0.1A 200MHz sw
# X3 X. l& n) @5 d! j; s) ~ YL6 MMBC1623L6 Mot N - MPS3904 hfe 200-400
! j& g! } p- g: u: e" pL7 BSS70R Zet N - pnp 40V 0.1A 200MHz sw- m5 F: K0 X' o# K( l$ _% J
L7 MMBC1623L7 Mot N - MPS3904 hfe 300-600
$ X- a$ M8 e4 \+ ~9 X& _/ ]L7 BAR14-1 Sie D - dual pin 100mA max
( ]) M1 ]9 j* Y, A- RL8 BAT721A Phi A SOT23 dual c anode 40V 200mA schottky
& X, u; X d; s& WL8 BAR15-1 Sie A - dual pin 100mA max
# c" E( b- Y6 G4 ]L9 BAT721C Phi B SOT23 dual c cathode 40V 200mA schottky
) Z* X% a) K6 d. `% RL9 BAR16-1 Sie B - dual pin 100mA max: m9 e7 M. Q/ O1 U
LAp BF550 Phi N SOT23 pnp 40V 25mA
9 _3 ^/ o+ c5 {LB S525T Tfk G - n-ch vhf mosfet 200MHz
: j8 ~. @2 W F9 T6 x, RLBs BF999 Sie G SOT23 n-ch vhf mosfet 300MHz6 N, p: a3 X) G0 N, a' e
LDs BF543 Sie G SOT23 n-ch vhf mosfet 300MHz
0 a) A2 ?! D- r# fLEs BF660 Sie N SOT23 BF606A pnp vhf osc fT 800MHz* l" X i4 O# _' _
LGs BF775A Sie N SOT23 npn RF fT 5.6GHz for IF amp
, D& l4 a" L: s, j3 `& x- TLH BF569R Tfk R - BF970 pnp RF: ?2 O0 L6 g1 k' C$ H! q
LHs BF569 Sie N SOT23 BF970 pnp RF
+ I; l1 _" n6 ?% `LKs BF799 Sie N SOT23 BF959. p f6 K: w' | k9 n
LKs BF799W Sie N SOT323 BF959
% q) D( C; y; {& ^LKs BF799 Sie N SOT23 BF959
: e) |: |, j4 t9 TLKs BF799W Sie N SOT323 BF9591 ]. v/ G9 j; Z% m
LM BST120 Phi T - p-ch DMOSfet 60V 0.3A
! {) W( D5 C' p9 f% T/ rLN BST122 Phi T - p-ch DMOSfet 50V 0.25A4 m5 W5 D$ b: K- d l7 Q6 K
LOs BF775 Sie N SOT23 BFQ69
1 h$ U% B$ h) }LOs BF775W Sie N SOT323 BFQ69# F8 r9 e! t( U. A. ?- e
LRs BF517 Sie T SOT23 BF763 2.5 GHz
2 @% j; x5 Q- l4 DLSs BF770A Sie N SOT23 "npn low noise RF, Ft 6GHz"
$ C1 ~! J+ j4 x- iM BAR64-02W Sie I SCD80 pin diode4 i6 |2 K/ J- [2 [6 t3 N1 K
M BAR65-07 Sie S SOT143 dual pin diode
0 f8 H% o5 \# b; E# T# qM (blue) BAR65-03W Sie I SOD323 pin diode
7 i {5 U: a; \. U/ q0 sM (white) BBY55-03W Sie I SOD323 5.4-2.3pF varicap in
# L1 f. \ X8 ?M08 PMBFJ308 Phi F SOT23 VHF n-ch JFET J308
% A/ A+ m. E/ l j8 C: \3 _M09 PMBFJ309 Phi F SOT23 VHF n-ch JFET J309
* a# J0 X( O1 j" F5 {# mM1 BFR30 Phi F SOT23 BFW11 BF245) @ [7 R4 q1 b0 \. u
M10 PMBFJ310 Phi F SOT23 VHF n-ch JFET J310$ b6 J: ~% H, l" R
M10 PMBFJ310 Phi F SOT23 J310 n-ch jfet
: q' `$ E# K5 o* MM1B MMBT2222L Mot N SOT23 2N2222
- P6 \+ v6 y. w2 tM1E MMBTA43L Mot N SOT23 MPSA43 200V Vce npn
! t" s: e. k2 ]9 `/ Y/ b/ CM1F MMBT5550L Mot N SOT23 2N5550 npn 140V
2 u1 d' J" _; F6 `M1J MMBT2369L Mot N SOT23 2N2369A6 |+ q! O: n" p
M2 BFR31 Phi F SOT23 BFW12 BF2456 `: v; f0 h9 }: U
M2B MMBT2907L Mot N SOT23 2N2907 pnp gp/ Q2 x- q7 P' i6 i. B
M2C MMBTA70L Mot N SOT23 gp pnp MPSA70; a& v# M0 w5 l; I- I, V
M3 BFT46 Phi F SOT23 n-ch fet gp low level amp; f' b4 c+ A% E5 f
M3 MMBA812M3 Mot N - 2N5086 hfe 60-120 pnp N" c9 a# O. b
M31 BSD20 Phi XQ - n-ch depl sw mosfet 10V
- n5 Q5 _& ~! k7 u0 E4 {M32 BSD22 Phi XQ - n-ch depl sw mosfet 20V
0 L O( G, Y ]* @/ _M3A MMBTH24L Mot N SOT23 npn VHF amp 400MHz fT 30V
& Q4 y6 F/ F" J- D' \7 BM3B MMBT918L Mot N SOT23 2N918 UHF amp' K: ^6 g" T# x H! r
M3J MMBTH69L Mot N SOT23 pnp VHF amp 2GHz fT 15V
2 @) ~6 j# O% D9 q8 EM4 BSR56 Phi F - 2N4856 n-ch fet m/ Y5 l9 o: d! ^* o6 S. K
M4 MBD110DW Mot DL SOT363 dual UHF schottky
9 b5 D( ~8 u3 N+ k8 AM4A MMBV109 Mot C SOT323 Hyperabrupt varicap
- |$ G* O/ p3 s( e9 `5 g' UM4B MMBV432 Mot B SOT23 dual cc varicap 45pF/2V: V, m, x, K5 n' v m
M4C MMBV3102 Mot C SOT23 Hyperabrupt varicap
* w' T( h0 b& k4 t q( Y* N7 SM4E MMBV105G Mot C SOT23 Hyperabrupt varicap9 w' i# e% O- |( {* j3 t3 n
M4F MMBD353 Mot D SOT23 dual MBD101 in series/ `; _6 Q# c- P
M4G MMBV2101 Mot C SOT23 varicap 6.8pF MV2101; }2 u f- U: D2 f' ~# Z
M5 BSR57 Phi F - 2N5457 n-ch fet" _& G( [7 X' o
M5 MMBA812M5 Mot N - 2N5086 hfe 135-270 pnp7 A( ~* S9 d$ D2 `) I* l8 ~# i
M5 MMBD352W Mot Z SOT323 2x MBD101 in series 7 F' A2 _# H' u1 k
M56 BF1100 Phi W SOT143 dg mosfet 14V 30mA 0.2W
4 L7 T a0 o) ]4 bM57 BF1100R Phi UQ SOT143R dg mosfet 14V 30mA 0.2W
; G$ w% [1 R; N4 v: g1 l4 c( NM5C MMBD7000 Mot D SOT23 100V 2x series sw diodes, O, |4 W$ k9 D( P/ X9 _: U
M6 BSR58 Phi F SOT23 2N4858 n-ch fet9 v/ M5 T% P7 `' K! X
M6 MMBA812M6 Mot N - 2N5086 hfe 200-400 pnp" T, J1 G% @, P, v+ e
M6 BSS66 Zet N - npn 40V 0.1A sw fT 250MHz
+ F3 Y7 g: A3 M: B8 r) S$ Z6 \M6A MMBF4416 Mot F SOT23 2N4416 n-ch rf jfet
: ^; ~0 }* C$ `! }: OM6B MMBF5484 Mot F SOT23 2N5484 n-ch rf jfet
' r& [- i% v+ y5 s/ ^* iM6C MMBFU310 Mot F SOT23 U310 n-ch rf jfet) i+ p/ A8 Y2 @# b) K; v
M6E MMBF5460 Mot F SOT23 2N5460 n-ch rf jfet
0 I; X1 d* H" ~& _3 |! sM6H MMBD354 Mot A SOT23 dual MBD101 cc; A0 y4 s8 ~* k5 ?1 S8 O) n6 j
M7 BSS67 Zet N - npn 40V 0.1A sw fT 300MHz/ B2 I' |6 c6 o( x2 m
M7 MMBA812M7 Mot N - 2N5086 hfe 300-600 pnp
/ V- D: g/ G% G2 N3 `M74 BSS83 Phi XQ - n-ch enh sw mosfet
4 T6 u: O; @! p0 g0 KM8 BSS66R Zet R - npn 40V 0.1A sw fT 250MHz
% d9 F9 Q$ g/ N* |- L5 p. n, DM8 BSH103 Phi M SOT23 n-ch 50V 0.11A mosfet
4 z% L* B% c L9 k9 }9 [: TM89 BF989 Phi K - BF9602 w3 ]2 v1 f+ s6 K$ q6 [& i
M8p BSN20 Phi M SOT23 n-ch 50V 0.11A mosfet) H2 y5 F; A3 I) m$ f( Z) k6 | {
M9 BSS67R Zet R - npn 40V 0.1A sw fT 300MHz/ y. v0 c0 D6 q. q5 w8 }
M90 BF990 Phi W - BF9802 a# m8 c9 m4 X4 T8 W$ N
M91 BF991 Phi W - BF981- }1 R6 v6 i6 l% A8 U
M92 BF992 Phi W - BF982% Z6 x: X( L3 ]3 a4 E7 d
M94 BF994 Phi W - BF964; u% I- d) P( b( T; k, _1 x
M96 BF996 Phi W - BF966
- p( K- l' J- d- X, }M97 BFR101A - - - -+ P# P% r; ]& h. k3 i ~& E
M98 BFR101B - - - -3 D! ] \$ m- q& K/ g3 c) d! |
MA M1MA151AT Mot E SOT346 40V 100mA sw diode
/ S3 L. J0 E8 D" d- dMA MBT3904DW1 Mot DN SOT363 dual 2N39045 @; q- L, {" R7 U0 f& I$ ~
MA M1MA152AT Mot E SOT346 80V 100mA sw diode
4 ]+ A- q& u* }$ j$ b gMA BFS17 - N SOT23 BFW92# G2 K# Q- i0 U* m4 s! U8 ^
MB BF995 Sie W - n-ch vhf dg mosfet BF961
; T1 u' W6 l" h& UMB MBT3904DW9 Mot - - dual 2N3904" d2 Y5 h+ [! T" ]# \/ l9 T
MC ZVN3306F Zet M SOT23 n-ch mosfet 60V 150mA
" A# X. y% _( H! DMCs BFS17P Sie N SOT23 BFW92
& {6 n( `6 A0 PMCs BFS17PW Sie N SOT323 BFW92$ S3 C( ^6 t8 y# h d
MF ZVN3310F Zet M SOT23 n-ch mosfet 100V 100mA) O- _+ I: p1 w8 V) \6 {! u
MG BF994S Tfk W - BF964 n-ch dg vhf mosfet
3 K; d1 \9 g6 w6 h, TMH BF996S Tfk W - BF966 n-ch dg vhf mosfet
; }) I( U5 X) A" U9 y9 c3 WMH M1MA141KT Mot C SOT323 40V 100mA sw diode 8 k, \ u" ~6 \" o X1 D8 |
MH M1MA151KT Mot C SOT346 40V 100mA sw diode
" ~/ k2 H/ {6 G2 X) ^- vMI M1MA142KT Mot C SOT323 80V 100mA sw diode
; I% f. y. J7 T, G2 d$ }. m1 _( UMI M1MA152KT Mot C SOT346 80V 100mA sw diode& d1 l8 x* H0 c4 V' x% n3 s5 j x+ u' o# |
ML ZVP3306F Zet M SOT23 p-ch mosfet 60V 90mA
. R! n5 b' g6 [/ S. r' hMN M1MA141WA Mot A SOT323 d diode ca 40V 100mA
, ?! N0 G8 x6 C/ v* F- o- m6 v- ~9 }& yMN M1MA151WA Mot A SOT346 d diode ca 40V 100mA
( ~# J7 @4 x: @2 Y" v. i V# _9 RMO M1MA142W Mot A SOT323 d diode ca 80V 100mA3 J4 n) {" {" _ O
MO M1MA152W Mot A SOT346 d diode ca 80V 100mA . V; u% O# U$ }; B7 p9 C
MOR BF998R Tfk UQ SOT143R n-ch vhf dg mosfet BF988+ e' R! l5 F$ j+ v2 H6 M
MOs BF998 Sie W SOT143 n-ch vhf dg mosfet BF988
, q4 Y* v7 b. c& k7 lMR BF998W Sie UQ SOT343 n-ch vhf dg mosfet BF988 * O) {/ v$ i! X) `
MR ZVP3310F Zet M SOT23 p-ch mosfet 100V 75mA
) |6 t+ [' s6 F. W+ p q9 Z2 d& BMS CF739 Sie W - dg GaAsfet 2GHz
0 U0 P% M& z1 ~5 D5 J7 j$ t UMT M1MA141WK Mot B SOT323 dual diode cc 40V 100mA
# s" d' w) s. k* dMT M1MA151WK Mot B SOT346 dual diode cc 40V 100mA # l. x# t9 k4 H/ w, s' C3 ?
MU M1MA142WK Mot B SOT323 dual diode cc 80V 100mA
; o& H) s; a! I+ ~' j/ h$ XMU M1MA152WK Mot B SOT346 dual diode cc 80V 100mA
; a& w" w+ x! V1 SMU ZVN3320F Zet M SOT23 n-ch mosfet 200V 60mA3 d l; E! ?4 |1 k9 u
MX CF750 Sie U - "biased dg GaAsfet, 3-6V"
5 u2 I( `6 f1 I W1 e, y0 d) bMY VN10LF Zet M SOT23 n-ch mosfet 60V 150mA
: P, R# W1 C+ F, W6 i X7 P2 C' f1 i4 oMY BF1012 Sie W - n-ch dg mosfet 1GHz 12V
+ e, O$ |9 G2 D! t/ g( x! PMZ ZVN4106F Zet M SOT23 n-ch mosfet 60V 200mA; x; _1 J" C" E
MZ BF1005 Sie W - n-ch dg mosfet 1GHz 5V7 [# T9 T' e, j$ d
N DAN202K Roh B - 80V 100mA dual diode
7 Y; @) b5 H, M7 d6 f$ d7 P. T. QN0 TN0200T Nat M SOT23 n-ch mosfet 0.6A Id
2 G+ @' t" i" o, K( d1 g: TN05 SO2484 SGS N - 2N2484
$ Q! d4 i. [' h) Y: NN08 SO930 SGS N - 2N930
% }, g2 o B: q# S. Y4 FN1 MMBT100 Nat N - npn gp sw 500mA
! g C4 e4 m" i4 g$ iN1 MMBF201N Mot M SOT23 n-ch tmosfet 20V 0.3A Id$ m4 O7 Q6 X2 E) @
N1 MRF571 Mot N SOT416 8 GHz 40mA npn RF t0 `( h8 k8 m' _. {2 Z
N1 TN0201T Tem M SOT23 n-ch mosfet 0.3A Id 0.2W
- C8 E$ ~, |6 M8 y/ w- N; A2 h! r! zN10 SO918 SGS N - 2N918" H( q" M0 l5 T" s% J( D; g- g
N11 SO2369 SGS N - 2N23695 Y6 Q9 C6 w$ o3 Q$ t: `
N12 SO2221 SGS N - 2N2221
1 l/ T Q( C W' \5 M8 yN13 SO2222 SGS N - 2N22227 g" A2 b* e! A6 i5 ?
N18 SO1711 SGS N - 2N1711
% w$ M w/ q0 v9 gN2 MGSF1N02LT1 Mot M SOT23 "n-ch mosfet, 20V 85mA"
' E: |: v/ T# J0 \5 [, l, f2 bN2 MMBC1653N2 Mot N - npn 130V 50mA hfe 50-130
# Z5 ?3 x/ x$ F5 t3 a7 s) k/ l7 xN2 BFS520 Phi N SOT323 npn RF 9GHz 70mA( i6 s: q- o: K3 X- h, L
N20 SO2222A SGS N - 2N2222A
; d& K. m' S: X8 KN27 SO1893 SGS N - 2N1893, b4 K. X3 [, a6 ^6 P; e8 W9 R
N28 BFR520 Phi N SOT23 npn RF 9GHz 70mA- S, p$ j2 r4 r. g
N29 BFR540 Phi N SOT23 npn RF 9GHz 120mA% K* s' n1 g, Y7 m/ S" }% ]9 y
N3 MMBC1653N3 Mot N - npn 130V 50mA hfe 100-220/ q# L! M% s, |- J, v2 G
N3 MGSF1N03L Mot M SOT23 n-ch TMOS mosfet 30V 0.75A: C$ L( t$ v: V. S+ F% j
N30 BFR505 Phi N SOT23 npn RF 9GHz 15V 18mA. C+ t5 K K& L& H# E. ~8 x- i- H
N33 BFG505 Phi TQ SOT143 npn RF 9GHz 15V 18mA
, ~, R) J$ G' s+ w* h8 [N36 BFG520 Phi X SOT143 npn RF 9GHz 70mA
8 {, t2 K! [. i8 |$ T8 D- rN37 BFG540 Phi X SOT143 npn RF 9GHz 120mA
, e7 S; j ^) RN38 BFG590 Phi TQ SOT143 npn RF 5GHz 15V 0.2A. o8 c% _- D7 m+ J
N39 BFG505X Phi X - npn RF 9GHz 15V 18mA8 N5 q8 F* m1 _* R
N4 MMBC1653N4 Mot N - npn 130V 50mA hfe 150-330
; |" Y: O# s$ J9 oN44 BFG590X Phi X - npn RF 5GHz 15V 0.2A; a# F% t+ M7 D2 p
N5 MMBC1654N5 Mot N - npn 160V 50mA hfe 50-1302 }! C5 d( |; L& D9 }
N54 SO2221A SGS N - 2N2221A) @1 | J' I% y! ~5 E' M
N6 MMBC1653N6 Mot N - npn 160V 50mA hfe 100-220
5 {! J d/ N& {$ ^" o9 C; j+ YN6 BFS25A Phi N SOT323 npn RF 5GHz 6.5mA 32 mW7 L9 S/ [, W* h' _; c* q* [8 V
N7 MMBC1653N7 Mot N - npn 160V 50mA hfe 150-330
, l0 n2 @+ o! ?! e+ o$ c. B; kN70 BFG10 Phi TQ SOT143 npn 8V 250mA 1.8GHz pwr amp! O0 U% Q0 N4 G: K* q& |7 d7 E
N71 SO3904 SGS N - 2N3904
) R4 |4 _) S2 pN71 BFG10X Phi X - 8V 250mA 1.8GHz pwr amp
2 a4 a c' \5 A; ]: R% r BN72 BFG11 Phi TQ SOT143 8V 400mA 1.8GHz pwr amp
6 T2 H9 A4 S; k! C* DN72 SO3903 SGS N - 2N3903
6 K* B4 G$ `- M/ N1 MN73 BFG11X Phi X - 8V 400mA 1.8GHz pwr amp# ]5 V- J! [9 A$ W( ^
N79 SO5550 SGS N - 2N5550
_& a' z M3 W+ D+ AN80 SO5551 SGS N - 2N5551
! U( v) R- b, w, S8 {! ON81 SO2369A SGS N - 2N2369A$ V" A/ Q, v6 H
N9 DAN222 Mot B SOT416 dual cc si diode 6 s% Y6 B; n6 ^
N91 SO642 SGS N - npn Vce 300V
9 F0 O( p" x m: d$ |N94 SO517 SGS N - npn darlington2 ~+ j9 D/ a$ r, Y
NA CFY35-20 Sie DM - 10GHz GaAsfet" k# X4 H) b7 ]( Y! e) i
NB CFY35-23 Sie DM - 10GHz GaAsfet W, @4 q/ E+ d4 i5 { d4 V
NY BF1012s Sie W - n-ch dg mosfet 1GHz 12V
# y) }, `- l* {. Z( |NZ MGSF1N02L Mot M - n-ch TMOS FET+ V% j- [! u/ h) \0 N
O (white) BAT14-03W Sie I SOD323 RF Schottky 4V 90mA b2 l r7 |8 e& `' A ^
O05 SO2484R SGS R - 2N2484/ e! X! S" F3 R. ]& k
O08 SO930R SGS R - 2N930
2 v4 C1 x+ n8 G4 e' f# RO10 SO918R SGS R - 2N918 ]7 Y1 Q% m( J1 d2 N6 c
O12 SO2221R SGS R - 2N2221
- c+ L$ [9 E0 J( j5 mO13 SO2222R SGS R - 2N2222
+ \; j5 \$ i( |O2 BST82 Phi M SOT23 n-ch mosfet 80V 175mA# [" T3 B* B) t' d
O20 SO2222AR SGS R - 2N2222A
5 N, R) L$ s4 u% ~3 }3 |+ B8 s# ZO27 SO1893R SGS R - 2N18937 O0 c( i5 ?, |2 M
O54 SO2221AR SGS R - 2N2221A
8 S8 Y7 G3 g5 RO79 SO5550R SGS R - 2N5550/ X6 v& L0 R" R2 A1 K: P
O80 SO5551R SGS R - 2N5551
" K# u. _: N, u* i7 z9 O5 d( b# \O91 SO642R SGS R - npn Vce 300V
* I* [+ n9 C. i4 F# }. O5 \P KV1841E Tok I URD uhf varicap 7-15pF0 M8 u" i7 @# m7 d! Y
P DAP202K Roh A - 80V 100mA dual
6 j* F H& L- O1 QP (white) BAT15-03W Sie I SOD323 RF Schottky 4V 100mA
% \' i: p7 ?% g# Q' |) S0 `; |P0 BFP90A Phi CX SOT173 BFG90A
, v) t; R9 |$ a/ W: y" C" CP0 TP0101T Tem M SOT23 p-ch mosfet 0.5A 12V ]! j) ]. v- D V% S* O" ?
P0 HSMS-285B HP C SOT323 zero-bias schottky diode uW det
a4 U% A m+ I kP0 HSMS-2850 HP C SOT23 zero-bias schottky diode uW det& B7 Z2 Y1 a# a" h1 Q& c+ W
p01 PDTA143ET Phi N SOT23 pnp dtr 4k7+4k7
" I5 t' z4 Q7 r5 P& MP01 SO2906 SGS N - 2N2906$ ?9 Q ~' j& l6 m
P01 SST201 Sil F SOT23 J201 n-ch fet, H; d+ p& @! a$ I( G
p02 PDTC143ET Phi N SOT23 npn 4k7+4k7 bias res
8 U' _6 J9 B0 J( L# RP02 SST202 Sil F SOT23 J202 n-ch fet
O9 V5 T5 S4 gP03 SO2907A SGS N - 2N2907A r3 D9 O: @! O# `! N: F& S
P03 SST203 Sil F SOT23 J203 n-ch fet
+ Q) n9 l( D+ E! ^9 D& [P04 SST204 Sil F SOT23 J204 n-ch fet
* \2 v9 m) d3 v9 B |+ I7 uP05 SO2907 SGS N - 2N2907
$ {0 I( n* N$ z1 a& L5 e0 qP06 SO2894 SGS N - 2N2894
6 ]: x4 N# v) n8 }( AP1 BFP91A Phi CX SOT173 BFG91A+ `# E9 e8 ^: H4 ?- K8 H2 g
P1 SST201 Tem F SOT23 J201 n-ch jfet5 _" w% P2 E: o6 N1 y9 K$ g+ g
P1 BFR92 Phi N SOT23 BFR90
. C" i& f; Y2 s- M% fp11 PDTA114TT Phi N SOT23 pnp dtr: K. m% S) k$ ^' q4 p2 ~# t. _
p12 PDTC114TT Phi N SOT23 npn dtr0 T* {6 m# }! R4 ^$ b
P12 SO2906A SGS N - 2N2906A
( A4 U$ g, V3 l8 T" w; @p16 PDTC114ET Phi N SOT23 npn dtr
9 l( L2 k! Q' V4 u( wp17 PDTC124ET Phi N SOT23 npn dtr4 b) k6 i2 t9 @+ `
p18 PDTC143ZT Phi N SOT23 npn dtr 4k7+47k. J: x/ [+ U. |4 V+ l! L
p19 PDTA143ZT Phi N SOT23 pnp dtr 4k7+47k( P7 `4 e$ _$ K+ J
p1A PMMT3904 Phi N SOT23 2N3904
, T& h* F& I' y: g0 [ g3 `' Ap1A PXT3904 Phi N SOT89 2N3904$ O- H2 N1 L- O4 O, y/ T
p1B PMBT2222 Phi N SOT23 2N2222$ w: Z% b& D) K1 o6 l
p1D PMBTA42 Phi N SOT23 MPSA42 300V npn
% Y5 v, J1 z5 A" ^7 ^" Yp1D PXTA42 Phi N SOT89 MPSA42 300V npn
- ^! _ t+ D) A x# X, { x' t$ PP1D PZTA42 Mot P - MPSA42 10mA 300V npn1 J4 A% m- Z$ X" ?
P1D PZTA42 Mot P - MPSA42 300V npn
% o" Z, t- ^3 K1 s' \p1F PMBT5550 Phi N SOT23 2N5550 140V npn
8 h* m. d! b9 c0 CP1F PZT2222A Mot P - 2N2222A sw npn& a7 G. A' S8 f3 O$ |$ Q
p1G PMMTA06 Phi N SOT23 MPSA069 _9 R) A, ^" l# C3 }
p1J PMBT2369 Phi N SOT23 2N2369& x& a2 @! ~) o# c* z
p1K PMBT6428 Phi N SOT23 MPSA18 50V7 G8 N8 u7 Z& Z9 S
p1L PMBT6429 Phi N SOT23 MPSA18 45V
) w( c9 n: M6 {7 T: |. a1 ?) ap1M PXTA13 Phi N SOT89 MPSA13 darlington
5 A+ L( R& [ l5 G) |p1M PMBTA13 Phi N SOT23 MPSA13 darlington
W n- N; V; F% mp1N PMBTA14 Mot N SOT23 MPSA14 darlington
u2 u9 p; j& t5 a) s* Kp1N PXTA14 Mot N SOT89 MPSA14 darlington
2 p1 K+ A9 C, S3 s! T! VP1N PZTA14 Mot P - MPSA14 darlington% e( `8 [, T0 B3 d% A% M
P1N PZTA14 Mot P - npn darlington MPSA14
- n M- f6 k2 @- v- V2 C# ?: I5 hp1P PMBT2222A Phi N SOT23 2N2222A
; {! d) r+ h: }' K Kp1P PXT2222A Phi N SOT89 2N2222A" W! _6 u& Y; u
p1Q PMBT5088 Phi N SOT23 MPSA18 Vce 30V$ H% n0 I8 Q9 j: k8 \2 c
P2 BFR92A Phi N SOT23 BFR90A3 A/ A) u! u/ J' W- ?6 t
P2 HSMSM-285C HP D SOT323 dual series HSMS-285B z/ _# k1 U5 z- Q
P2 HSMSM-2852 HP D SOT23 dual series HSMS-285B
2 c ^; p \( M D uP25 SO3906 SGS N - 2N3906
4 B6 J+ l* p# [/ N" F2 ~) N7 }P26 SO3905 SGS N - 2N3905
; c$ E. w- e6 T) [3 ]p2A PMBT3906 Phi N SOT23 2N3906( D# x0 B/ i8 s8 G. b
p2A PXT3906 Phi O SOT89 2N3906" \' p) j8 r; y! o: S
p2B PMBT2907 Phi N SOT23 2N2907- r' E) y. y& {" W8 }
p2D PMBTA92 Phi N SOT23 MPSA92 pnp Vce 300V
0 ?3 L1 h1 D4 J6 j+ K6 _. op2D PXTA92 Phi O SOT89 MPSA92 pnp Vce 300V
9 i8 P1 D, X( A2 M$ E7 d8 \) O5 UP2D PZTA92 Mot P - MPSA92 300V pnp) W6 `, I' K6 G
p2F PMBT2907A Phi N SOT23 2N2907A% V5 ^* x+ j7 c# \. j$ r9 S
p2F PXT2907A Phi O SOT89 2N2907A) _9 Y2 C: e+ {9 b8 m6 V
P2F PZT2907A Mot P - 2N2907A sw pnp
' d8 G3 t% {+ f3 v% N$ vp2G PMBTA56 Phi N SOT23 MPSA56( j k( i' C6 i0 J3 h3 A
p2L PMBT5401 Phi N SOT23 2N5401 pnp 150V
; ?$ A5 ~+ Q2 G; k! X' z" t; uP2p BFR92AW Phi N SOT323 BFR90A3 h* B/ ~5 |3 \( T9 o! s- p
p2T PMBT4403 Phi N SOT23 2N44038 X& ?1 c8 b3 V7 T* i
p2T PXT4403 Phi O SOT89 2N44038 W, c3 W; `- W; z* E. p7 o
p2V PXTA64 Phi O SOT89 MPSA64 darlington
' Y+ v$ N% A2 X; `! u- d1 \. y8 oP2V PZTA64 Mot P - MPSA64 darlington# S6 {) R9 l( K9 S
p2X PMBT4401 Phi N SOT23 2N4401
' T' _+ t) h( t- V4 Tp2X PxT4401 Phi O SOT89 2N4401( }, T" ]$ d# O# c2 x
P3 MMBF2202P Mot M SOT23 p-ch TMOSfet 0.3A 20V
9 [0 a3 L, P! [6 f, d5 f8 uP3 TP0202T Tem M - p-ch mosfet 0.3A 20V
' h1 W$ u6 N9 f! A( R3 c# Vp31 PDTA143XT Phi N SOT23 pnp dtr 4k7+10k
( `) f' D# S- I) K8 `, b8 Gp32 PDTC143XT Phi N SOT23 pnp dtr 4k7+10k6 `5 o6 V" x& W& M: [/ {% @9 b
P32 SO5400 SGS N - 2N5400: ^4 Y3 d$ f; E
P33 SO5401 SGS N - 2N5401
6 B' {( |7 T5 B, d3 a, z! sP38 SST4338 Sil F SOT23 2N4338
3 U) g* {6 W6 U$ p( Q4 uP39 SST4339 Sil F - 2N4339
" I9 P* R4 n; {0 UP39 SO692 SGS - pnp Vce 300V
3 S- p0 b- Q- r3 @0 b- P& D# WP4 BFR92R Phi R SOT23R BFR90' n6 ^) g. |# A
P40 SST4340 Sil F SOT23 2N43406 R2 X f( x9 |0 D) ?
P41 SST4341 Sil F SOT23 2N43419 F" d) L2 |# v8 W, P8 r a0 _8 |: }
P5 BFR92AR Phi R SOT23R BFR90A) r0 D' F, C% _. m
P5 FMMT2369A Zet N - 2N2369A
9 `# w/ l) @6 B8 \P5 HSMSM-2855 HP S SOT143 separate pair HSMS-2850
8 X1 ?: S3 c4 gP57 SST5457 Sil F SOT23 2N5457
) t/ Y) l% E; w, [' u0 f1 KP58 SST5458 Sil F SOT23 2N5458% _/ `3 D' f* e2 N# n1 R6 a1 B
P59 SST5459 Sil F SOT23 2N5459# o/ i" I. \4 b/ L
P6 BFP96 Phi CX SOT173 BFG965 g' Y. X! ?' L: Z3 M/ ]% d
P60 SST5460 Sil F SOT23 2N5460
! }% D# G4 l) M. \; c* B+ U+ ?P61 SST5461 Sil F SOT23 2N5461
% ~# w: K: |' X% s0 v7 {# D( D* uP62 SST5462 Sil F SOT23 2N5462. h& U+ {# S& Y) G
P63 SST5463 Sil F SOT23 2N5463
. S& L C; l( cP64 SST5464 Sil F SOT23 2N5464' q/ S. p' p$ P. F2 A+ x& D4 ?' q
P65 SST5465 Sil F SOT23 2N54652 |# P0 R) l3 ^$ [9 {
p6G PMBF4393 Phi F SOT23 n-ch jfet 2N43936 M4 ?# e2 v7 Z: [+ y
p6J MMBF4391 Phi F SOT23 n-ch jfet 2N4391
# F- [2 O9 T$ W+ b2 [, Ep6K MMBF4932 Phi F SOT23 n-ch jfet 2N4932
: s8 _* L' ]) o, k. }' bp6S PMBFJ176 Phi F - J176 n-ch jfet
; I+ l ]. @6 ?. |p6W PMBFJ175 Phi F SOT23 J175 p-ch jfet$ U) n- B$ R+ `+ t# @: O: ?) o9 P
p6X PMBFJ174 Phi F - J174 p-ch jfet sw/chopper
9 {! ^% @2 o( H) o3 op6Y PMBFJ177 Phi F SOT23 J177 p-ch jfet6 O; H$ m3 d7 T% M1 u" z& G
P8A FLLD258 Zet B SOT23 low leakage dual ca Si diode
c" D6 N! `, k* w/ d6 [P9 BCX70KR Phi R SOT23R BCY59-x b6 j9 i# B/ I/ n$ u
P9 DAP222 Mot A SOT416 dual ca sw diode
4 r5 H, Z u3 M+ w. A5 m! E7 OPC MGSF1P02L Mot M SOT23 p ch enh tmosfet3 O% A) c6 N/ ?9 Q; s& p1 r
PD BSS84L Mot M SOT23 p-ch enh tmosfet
: b8 ] D a. VpG3 PMST5551 Phi N SOT323 2N55514 _% m# A6 ^+ D, ~- ^
PH2 SST4302 Sil F SOT23 2N4302
$ |/ ]' T+ Z0 N& b0 CPH3 SST4303 Sil F SOT23 2N4303) R4 N+ X& ~' \& x8 T8 c" e/ g
PH4 SST4304 Sil F SOT23 2N43048 |* O9 @% O! A# R$ J: ]1 C
pJ1 BSH101 Phi M SOT23 n-ch 60V 0.7A mosfet
6 Y, r' }8 [1 B% p1 [pJ2 BSH102 Phi M SOT23 n-ch 30V 1A mosfet
% ]' b' S& y0 \pJ3 BSH103 Phi M SOT23 n-ch 30V 0.8A mosfet
* K! o5 j J& i* u5 a) y+ U' I0 TPL BB149A Phi I SOD323 2-18pF varicap
3 q- P+ ^" p! e2 N1 t$ F3 [8 yPOs BAR64 Sie C SOT23 single 200V RF pin% Y, p! C7 y9 i8 V' o1 A: n
PPs BAR64-04 Sie D SOT23 dual series 200V RF pin p1 R' r; i: N! Y1 X- o( c
PPs BAR64-04W Sie D SOT323 dual series 200V RF pin
# {6 N( B; g$ J4 y5 _/ a5 ?" i3 zPRs BAR64-05 Sie B SOT23 dual cc 200V RF pin G2 L9 K) [& q
PRs BAR64-05W Sie B SOT323 dual cc 200V RF pin5 z5 E8 B( x" M, X1 u; ]7 \
PSs BAR64-06 Sie A SOT23 dual ca 200V RF pin- _2 Y. m2 z& r! x0 G% k
PSs BAR64-06W Sie A SOT323 dual ca 200V RF pin
$ L9 X8 t$ U, W JQ3 MMBC1321Q3 Mot N - npn VHF amp fT 0.6GHz% o1 w$ D# a# W/ C u$ ?! r
Q4 MMBC1321Q4 Mot N - npn VHF amp fT 0.6GHz$ F4 M4 ?$ a1 H) F4 _2 A2 b2 i6 N5 V3 g! G
Q5 MMBC1321Q5 Mot N - npn VHF amp fT 0.6GHz
! |8 G0 W+ P5 D9 x( U# eQQ 2SC4536 Nec P - npn RF fT 5.7GHz 2W hFE 40-80
% D2 |8 f2 n7 [+ Q+ @QR 2SC4536 Nec P - npn RF fT 5.7GHz 2W hFE 60-120
1 Z( g2 y4 W1 N' G7 \" E: ^QS 2SC4536 Nec P - npn RF fT 5.7GHz 2W hFE 100-2007 r9 \7 ]( s3 z6 c: o/ |0 L
R BA895 Sie I SCD80 - . ]) E. Q* ]- g6 C* _) T
R BA585 Sie I SOD123 pin diode 50mA max # L+ D7 P- v7 A* G5 Q" l1 @
R (white) BA595 Sie I SOD323 UHF pin diode 50mA max 9 y' e6 f& H% h- q1 g5 @$ k
R (yellow) BA597 Sie I SOD323 UHF pin diode 100mA max 4 o0 n W3 k& [
R1 UMT4401 Rho N SC70 2N4401
# J7 a+ L3 H8 e# }+ PR1 BFR93 SGS N SOT23 BFR91
+ T$ x; ?" P% IR1 HSMS-8101 HP K SOT23 10-14GHz schottky mixer . q0 g6 L! O0 Z" l& ?: T
R13 2SC4885 Nec WQ SOT143 npn RF fT 3.5GHz ; K2 H6 n* n4 _
R1A SST3904 Rho N SOT23 2N3904
$ a6 ?) A4 O& }R1A UMT3904 Rho N SC70 2N39049 V: x& [$ N( n4 l, L N7 v4 R/ Y
R1A MMST3904 Rho N SC59 2N3904
- M' z" L- S& G# I% X; U; uR1G SSTA06 Rho N SOT23 MPSA06
0 W5 S/ Q% W2 l F3 {R1G MMSTA06 Rho N SC59 MPSA06
2 m+ O6 b [: k R5 QR1H SSTA05 Rho N SOT23 MPSA05$ i7 `8 ^/ n2 g" K7 |
R1J SST6427 Rho N SOT23 -
9 U [( B& {9 r0 o' l( C# VR1K MMST6428 Rho N SC59 -* E1 Z5 K4 q( z1 f3 n. q" l9 ^9 N
R1M SSTA13 Rho N SOT23 MPSA13
+ s0 |, H; i$ _# R! uR1M MMSTA13 Rho N SC59 MPSA135 b8 a, c/ K# G4 X# X* r: z/ R4 A
R1N SSTA14 Rho N SOT23 MPSA14' X. |0 ^, y! _9 k7 k
R1N MMSTA14 Rho N SC59 MPSA14
) y+ V1 ~( T( }( O& _0 ?5 m( a/ gR1O MMST5088 Rho N SC59 2N5088& D- H6 r* ^. t& r. s* a
R1P SST2222A Rho N SOT23 2N2222A
8 k* z7 n6 G: I9 m, I, sR1P UMT2222A Rho N SC70 2N2222A* m* N* O7 q& d' A w$ Y) q7 N
R1P MMST2222A Rho N SC59 2N2222A
; c" `. F7 w o& bR2 BFR93A Phi N SOT23 BFR91A ; q" i! g; r5 R9 H! R
R2 2SC2351P Nec N SOT23 npn RF fT 4.5 GHz hfe 40-120
" b3 y% h; b/ `" i zR2 2SC4225 Nec N SOT323 npn RF fT 4GHz hfe 40-120 ) `7 E" b5 z# A1 W& e% e; a) ~
R22 2SC3356 Nec N SOT23 npn RF fT 7GHz 20V 0.2W
9 ~& g' m S% R; D* a$ Q/ ~R23 2SC3356Q Nec N SOT23 npn RF fT 7GHz hfe 50-100
3 K9 Q& w: R2 B& I! RR23 2SC4226 Nec N SOT323 npn RF fT 4.5 GHz hfe 40-80
- I- f8 i2 g; U9 tR24 2SC3356R Nec N SOT23 npn RF fT 7GHz hfe 80-160 " L, V% k: t1 H
R24 2SC4226 Nec N SOT323 npn RF fT 4.5 GHz hfe 70-140
0 G& _8 L$ W2 g* X qR25 2SC3356S Nec N SOT23 npn RF fT 7GHz hfe 125-250 1 W: }' `" P& p- A$ ^$ ~
R25 2SC4226 Nec N SOT323 npn RF fT 4.5 GHz hfe 125-250
2 ]( d+ |. E0 T2 ?R26 2SC4093Q Nec WQ SOT143 npn RF fT 6.5 GHz hfe 50-100
/ Q4 Q0 ~- ~6 iR26 2SC5011Q Nec WQ SOT343 npn RF fT 6.5 GHz hfe 50-100 3 p4 \5 d- X+ v9 ?0 c
R27 2SC4093R Nec WQ SOT143 npn RF fT 6.5 GHz hfe 80-160 * {2 p S% q( {7 D" x: r/ t% D
R27 2SC5011R Nec WQ SOT343 npn RF fT 6.5 GHz hfe 80-160 8 P5 |/ U) C. g! R
R28 2SC4093S Nec WQ SOT143 npn RF fT 6.5 GHz hfe 125-250
4 f# P: g: n6 }" ?2 m" f4 }R28 2SC5011S Nec WQ SOT343 npn RF fT 6.5 GHz hfe 125-250
( w6 s9 p( |' |, q: FR2A SST3906 Rho N SOT23 2N3906
, ?, k/ M0 o8 c9 u4 CR2A UMT3906 Rho N SC70 2N3906# v: Q! _! E, C) \) P
R2A MMST3906 Rho N SC59 2N3906
- j9 r& q. m/ BR2B MMST2907 Rho N SC59 2N2907
7 @! r4 R- B) j3 Z5 h: dR2F SST2907A Rho N SOT23 2N2907A4 }& Y0 @2 W+ K- c+ L/ A
R2F UMT2907A Rho N SC70 2N2907A
0 h' K3 R, X0 h; IR2F MMST2907A Rho N SC59 2N2907A- G) E- p# l" ?! r
R2G SSTA56 Rho N SOT23 MPSA56
: R! D; f+ `; V* D: _R2G MMSTA56 Rho N SC59 MPSA56# y8 ]$ ]& h8 D: b0 O
R2K MMST8598 Rho N SC59 -, Z8 n$ X% a& f2 ^ x( G0 i
R2O MMST5087 Rho N SC59 -
2 I6 p1 ~& b3 O$ G3 h8 `/ M. cR2P MMST5086 Rho N SC59 - \) w$ Q3 V! }
R2T SST4403 Rho N SOT23 2N4403) @' }: C1 U# V/ q
R2T UMT4403 Rho N SC70 2N4403
6 j* ?! x4 y5 w! a- o4 aR2T MMST4403 Rho N SC59 2N4403
/ I2 o2 ]4 Q$ y1 v3 p" k) N* ~; t( VR2V MMSTA64 Rho N SC59 MPSA64$ X* k" ]$ h( \, P, x6 F! z
R2X SST4401 Rho N SCOT23 2N4401% W5 q; Z. n0 }! L3 [! d. b: F
R2X MMST4401 Rho N SC59 2N4401
3 z; O" C; H+ F% G1 s& cR3 2SC2351Q Nec N SOT23 npn RF fT 4.5 GHz hfe 100-200
; {0 Q4 ^0 O- a. mR3 2SC4225 Nec N SOT323 npn RF fT 4GHz hfe 100-200 8 P* i. [+ @! ]* f c% w
R32 2SC3583 Nec N SOT23 npn RF fT 9GHz @ 20mA 3 z0 ?# x" ]! W1 A: _, _) z
R33 2SC3583Q Nec N SOT23 npn RF fT 9GHz hfe 50-100
' h$ F: n. [* r. }* w: HR33 2SC4227 Nec N SOT323 npn RF fT 7 GHz hfe 40-90 3 f8 W* W- T7 [1 R2 a0 v, N# ?3 I
R34 2SC3583R Nec N SOT23 npn RF fT 9GHz hfe 80-160 3 }& R; m. }' c+ B4 A6 a( Y4 }
R34 2SC4227 Nec N SOT323 npn RF fT 7 GHz hfe 70-150
% e, L2 i7 N6 h- E! pR35 2SC3583S Nec N SOT23 npn RF fT 9GHz hfe 125-250 4 b2 I9 w" D' G4 r8 d
R35 2SC4227 Nec N SOT323 npn RF fT 7 GHz hfe 110-240
# G3 i" W$ z# N" BR36 2SC4094Q Nec WQ SOT143 npn RF fT 9GHz hfe 50-100 0 }! ?9 v( H. F. l H+ {
R36 2SC5012 Nec WQ SOT343 npn RF fT 9GHz hfe 50-100 . G! T9 E g( @# ?
R37 2SC4094R Nec WQ SOT143 npn RF fT 9GHz hfe 80-160
; q }0 r) s1 x: ZR37 2SC5012 Nec WQ SOT343 2SC4094 but min-mold pkg
8 _" ^" c( ~- `- E. ]7 ]' cR38 2SC4094S Nec WQ SOT143 npn RF fT 9GHz hfe 125-250
6 i3 _! c6 s. p1 n' i4 x/ xR38 2SC5012 Nec WQ SOT343 npn RF fT 9GHz hfe 125-250 8 ~7 X. h) P/ N: A, g
R3B SST918 Rho N SOT23 2N918
# ~- K9 y, }0 r7 V* v* t3 PR3B MMST918 Rho N SC59 2N9188 @7 Z V9 F1 \' o$ u4 n! _
R4 BFR93R Tfk R - BFR91
* O- v& c. Q C% j' [R4 2SC4092 Nec WQ SOT143 npn RF fT 6GHz hfe 40-120
3 G1 B% D! K+ P/ z$ s' ]9 O% s, [4 aR42 2SC3585 Nec N SOT23 npn RF fT 10GHz @ 10mA / J, k: R( i9 j) a8 |; o1 g
R43 2SC3585Q Nec N SOT23 npn RF l fT 10GHz hfe 50-100
. j- M: l1 h' K8 _0 c# H! k5 X& W+ ]. fR43 2SC4228 Nec N SOT323 npn RF fT 8.5GHz hfe 50-100
; u# u) i) b2 L+ v! MR44 2SC3585R Nec N SOT23 npn RFfT 10GHz hfe 80-160 " d. N3 o* Z1 W& K8 r( S/ o/ k
R44 2SC4228 Nec N SOT323 npn RF fT 8.5GHz hfe 80-160 $ M6 [/ J4 y5 ^5 X
R45 2SC3585S Nec N SOT23 npn RF fT 10GHz hfe 125-250 4 c0 g, {1 B/ Z( w) L6 r
R45 2SC4228 Nec N SOT323 npn RF fT 8.5GHz hfe 125-250
) Z7 L, T2 H! d0 W8 ]1 r1 |5 {* RR46 2SC4095Q Nec WQ SOT143 npn fT10GHz
# z# v% z3 n4 p4 E( h! YR46 2SC5013Q Nec WQ SOT343 npn fT10GHz
% I$ [2 K+ J* Z3 n- K- PR47 2SC4095R Nec WQ SOT143 npn fT10GHz
! @& V& I( C+ O+ Q1 o" gR47 2SC5013R Nec WQ SOT343 npn fT10GHz * m* I6 d/ C% {2 D- V) I( O
R48 2SC4095S Nec WQ SOT143 npn fT10GHz
" |7 u l: S" u' y! Q/ L [7 A3 lR48 2SC5013S Nec WQ SOT343 npn fT10GHz
! y& P h3 S! b: V" j7 WR5 HSMS-8205 HP S SOT143 separate pair HSMS-8101 3 Q2 P' ^) X0 ]* z, | }5 k x% j# `
R5 BFR93AR SGS R SOT23R BFR91A $ _: O0 l8 O% h( G# E$ r S Y
R5 2SC4092 Nec WQ SOT143 npn RF fT 6GHz hfe 100-200
& t1 K1 l! w6 }8 t9 P, a5 zR62 2SC3663 Nec N SOT23 npn RF fT 4GHz @1mA 7 p0 K3 u8 g- c: r" Z( l0 t
R64 2SC4091 Nec WQ - npn RF fT 4GHz @1mA
8 s! f" T7 y6 I7 KR66 2SC4091Q Nec WQ SOT143 npn RF fT 4GHz hfe 50-100
! ]9 S6 t, y% [( q$ j& |5 h+ h' |R67 2SC4091R Nec WQ SOT143 npn RF fT 4GHz hfe 80-160# n3 I) q: H) E/ s T/ N3 F
R68 2SC4091S Nec WQ SOT143 npn RF fT 4GHz hfe 125-2500 s, y, ^+ }, Q( d
R6A 2SC4187 Nec N SOT323 npn RF fT 4GHz hfe 50-100 " F) I% e/ |$ i* ~5 z4 B
R6B 2SC4187 Nec N SOT323 npn RF fT 4GHz hfe 80-160 1 m1 d1 v2 B0 l. S9 @; |& S" U
R6C 2SC4187 Nec N SOT323 npn RF fT 4GHz hfe 125-250 : L1 G6 g! l t/ q4 x0 K
R7 HSMS-8207 HP RQ SOT145 HSMS-8101 ring quad mixer
: ` V6 _# [ t- y! U& kR7 BFR106 Phi N SOT23 BFR96S
7 Y/ j3 `/ ~+ X# x* wR8 BFG93A Sie TQ SOT143 BFG90
' s; {5 d b; VR97 SSTIS97 Rho N SOT23 TIS97
- j4 c6 E9 L* T& XRA BFQ81 Sie N SOT23 BFQ69 npn fT 5.8GHz - I# M! Z' M# }! h1 s" i
RAs BF772 Sie X SOT143 npn RF TV tuners 5 G6 c7 l9 ^1 b% A( q, t! [
RAT SSTA28 Rho N SOT23 MPSA28
& j m' j2 }; P( z% @+ _RAT MMSTA28 Rho N SC59 MPSA28
e* c* v0 @& g" lRAV MMST8908 Rho N SC59 -
: u2 I/ s, L$ XRB MSC1621 Mot H - npn sw 20V 200MHz
0 W* ~% A/ N' A% ^( z& t( vRBR SST6838 Rho N SOT23 -& W i8 }1 T E$ v
RBs BF771 Sie N SOT23 npn RF fT 8GHz . o4 C/ y3 D8 c8 T2 U! o7 o
RBs BF771W Sie N SOT323 npn RF fT 8GHz 4 E, d! K0 b6 l4 N3 D
RCs BFP193 Sie X SOT143 BFQ82 npn fT 8GHz . j! J' a* T% f0 ~' B# Q
RCs BFP193W Sie WQ SOT343 BFQ82 npn fT 8GHz
/ b( Q: ?9 U: O& |RCs BFR193 Sie N SOT23 BFQ82 npn fT 8GHz
& P* W+ d" X5 s5 y- FRCs BFR193T Sie N SC75 BFQ82 npn fT 8GHz 9 V$ C; ?" X F. G! \5 |+ q& M
RDs BFP180 Sie X SOT143 npn RF 8V 4mA fT 7GHz . K8 }" W0 h8 y$ l
RDs BFP180W Sie WQ SOT343 npn RF 8V 4mA fT 7GHz
0 {% i. i& l# ~6 G2 I: SRDs BFR180 Sie N SOT23 npn RF 8V 4mA fT 7GHz / F2 v+ z4 K( G$ v( N5 @' u; ^; ]5 a$ J
RDs BFR180W Sie N SOT323 npn RF 8V 4mA fT 7GHz
1 `* j+ Q H, U7 S( s u) n1 z5 nRE 2SC3357 Nec P SOT89 npn RF 1.2W fT 6.5GHz
8 o& H( r3 M6 w% E3 ~) ?/ d; YREs BFS480 Sie DJ SOT363 dual RF npn fT 7GHz / M. e- Y7 `, w: M
REs BFR280 Sie N SOT23 npn RF 8V 8mA fT 7.5GHz
( `6 c+ G n/ I% }! b; W; rREs BFR280W Sie N SOT323 npn RF 8V 8mA fT 7.5GHz ) }* ~! ]/ g# b7 J. m+ p4 I7 l
REs BFP280 Sie X SOT143 npn RF 8V 8mA fT 7.5GHz " ?4 p6 e" _/ C6 p' s
REs BFP280W Sie WQ SOT343 npn RF 8V 8mA fT 7.5GHz
: c ?& J7 _4 GRF 2SC3357 Nec P SOT89 npn RF 1.2W fT 6.5GHz - j% K3 l( r5 D' r4 e B2 K0 {
RFQ SST6839 Rho N SOT23 -
. \) [0 b$ O1 R; ?- B0 v Z% H8 kRFs BFR181 Sie N SOT23 npn RF 12V 20mA fT 8GHz
" H. r5 b# R+ x% `6 rRFs BFP181 Sie X SOT143 npn RF 12V 20mA fT 8GHz
9 Y$ s1 C3 i- C' Q8 U: g. {RFs BFP181W Sie WQ SOT343 npn RF 12V 20mA fT 8GHz
! u6 X0 g0 }5 |( \; k" NRFs BFS481 Sie DJ SOT363 Dual BFR181
9 \6 e* D2 f3 K! Y2 _RGs BFR182 Sie N SOT23 npn RF12V 35mA fT 8GHz _; M5 P' f8 D+ M, J: e, [' i/ Q
RGs BFR182W Sie N SOT323 npn RF12V 35mA fT 8GHz
' u1 x7 E8 b0 Q6 Z aRGs BFP182 Sie X SOT143 npn RF12V 35mA fT 8GHz 1 D$ F `: f2 u' k4 {" ^
RGs BFP182W Sie WQ SOT343 npn RF12V 35mA fT 8GHz
/ g# m$ ]% {: URGs BFR182T Sie N SC75 npn RF12V 35mA fT 8GHz ! e. A/ p( f3 @! U9 z, D
RGs BFS482 Sie DJ SOT363 Dual BFR182 $ ]* u* j9 X0 s
RH 2SC3357 Nec P SOT89 npn RF 1.2W fT 6.5GHz
: Y/ M3 p/ {0 T2 Q" LRHs BFR183 Sie N SOT23 npn RF 12V 65mA fT 8GHz
; b! d: E7 o* DRHs BFR183W Sie N SOT323 npn RF 12V 65mA fT 8GHz - r+ ~1 H/ y: U- s% o) f6 Q
RHs BFR183T Sie N SC75 npn RF 12V 65mA fT 8GHz
/ \ B& L& M( D. c. m$ MRHs BFP183 Sie X SOT143 npn RF 12V 65mA fT 8GHz
# ?2 \* H' f2 B' G( bRHs BFP183W Sie WQ SOT343 npn RF 12V 65mA fT 8GHz 5 z z6 Z, @+ X1 y
RHs BFS483 Sie DJ SOT363 Dual BFR183 npn RF
; b3 u6 L& E6 U- oRIs BFP196 Sie X SOT143 pnp RF 12V 100mA Ft 7.5GHz - l( `& d% [' e! T" g2 t) C/ j
RK 2SC3357 Nec P SOT89 npn RF 1.2W fT 6.5GHz
. E" M) }+ V6 F; ~RKM RK7002 Rho - SOT23 -
# `6 V( h0 \6 w6 e r/ RRKs BFP194 Sie X SOT143 pnp RF 15V 100mA Ft 5GHz : e" R, Q$ e* c/ }* {
RKs BFR194 Sie N SOT233 pnp RF 15V 100mA Ft 5GHz 5 l6 [; O% {6 @0 [7 o5 C
RR BBY59-02V Inf I SC79 hyperabrupt varicap 7-28pF
6 c+ o: X; P7 B. aRR BFR93P Sie N SOT23 BFR91
, T' S0 f- ]( J' l) e, rRVZ MMST4126 Rho N SC59 2N4126
- m& ?2 C8 H# W7 N+ _2 c+ N# |RW BFR194 Sie N - pnp RF amp 1.5GHz ! d6 ]( ~) |9 J6 H1 Z
RZC SST4124 Rho N SOT23 2N4124
' x4 X) m6 s: D# q1 \# aRZC MMST4124 Rho N SC59 2N4124 ; L2 o5 U* u# C
S BB811 Sie I - 9.8pF @ 1V 30V max. s! n, N y9 ]
S BAP64-02 Phi I SOD523 3GHz pin diode1 T2 |3 _% T% n/ S3 ~1 `% F! t
S (blue) BA592 Sie I SOD323 BA282
% y: i0 U" E7 h+ q, AS (red) BB640 Sie I SOD323 70-3pF varicap! ~/ E6 P% V; i) ]: i0 y
S (white) BB535 Sie I SOD323 18-2pF varicap1 d( J& f* Y( a
S (yellow) BB639 Sie I SOD323 39-2.7pF varicap; R- q" z4 z4 I& I6 s
S0 HSMP-3880 HP C SOT23 pin sw diode3 z' k6 k+ j/ E$ I* v; n
S1 HSMP-3881 HP K SOT23 pin sw diode0 p0 ] U" X0 o4 [) ^: i
S1 BBY31 Phi C SOT23 BB405 a4 u. r' l. i8 j
S12 BBY39 Phi B SOT23 2x BBY317 B' _ u. `7 g# g
S14 SST5114 Sil F SOT23 2N5114
0 F- z! X+ i" V: k; _2 T) [- o \S15 SST5115 Sil F SOT23 2N51151 S; [) Z: @, ?( X" C
S16 SST5116 Sil F SOT23 2N51166 z6 }0 E/ G ~3 D J/ s5 x% S% \/ j+ f
S16 ZHCS1006 Zet E SOT23 60V 1A schottky diode
) p9 R0 |9 a- z' X8 rS1A S1A Fch I DO214 1N4001* @( S- z) O2 x) s; j4 N
S1B S1B Fch I DO214 1N40028 K) O8 z; S+ \8 s
S1D S1D Fch I DO214 1N4003
/ [/ [& s* S% y; k' BS1G S1G Fch I DO214 1N4004, K2 K+ ?& m' p8 G E. J) O7 s
S1J S1J Fch I DO214 1N4005
. E6 c5 r: j9 |& w1 z" uS2 BBY40 Phi C SOT23 BB809
7 K" ?+ i4 B- t! LS2 BFQ31 Zet N - npn vhf 15V 0.1A% t! R0 F" u, K+ C5 v
S3 BFQ31R Zet R - npn vhf 15V 0.1A, F1 c1 Q8 {! H+ Z6 m, w, |1 H
S3 BBY51 Sie B SOT23 dual cc varicap x' X2 m! K4 w& g/ y8 m
S4 BFQ31A Zet N - npn vhf 15V 0.1A
& V3 t) o- L2 O( j7 @! S! qS5 BFQ31AR Zet R - npn vhf 15V 0.1A% {/ Z& |! f( P( e2 M
S5 BBY52 Sie B SOT23 dual cc varicap+ }+ e# K8 R# C' s e4 i5 J2 w4 U
S5 BAT15-099 Sie NQ SOT143 Dual BAT15 schottky
" ~% P9 t% U" N) ^S56 ZHCS506 Zet E SOT23 60V 0.5A schottky diode) l- A& C5 S! T$ w( ?$ `. f
S6 BAT15-099R Sie DQ - Ring quad BAT15 schottky% ` g! u2 e4 k# y. q, `$ f
S6 BF510 Phi G - BF410A
. {; o+ B. T% ^/ h* G0 eS7 BF511 Phi G - BF410B) T" E8 [4 F. }# w! V
S7 SST177 Tem F SOT23 J177 p-ch analog sw jfet$ {3 \$ p6 i; l
S7 BAT114-099 Sie NQ SOT143 Dual schottky
: Q( r" l# u9 ]$ i; y6 W7 j* V+ sS70 SST270 Sil F SOT23 J270 p-ch jfet) |, |' |1 o% V
S71 SST271 Sil F SOT23 J271 p-ch jfet) [1 E8 I3 b8 _! K b1 U2 I6 j7 @
S74 SST174 Sil F SOT23 J174 p-ch fet
" d2 E' c0 ?1 X1 \9 BS75 SST175 Sil F SOT23 J175 p-ch fet3 L/ ~. k7 h5 F
S76 SST176 Sil F SOT23 J176 p-ch fet5 v. w+ q+ @: T6 Q
S76 ZHCS756 Zet E SOT23 60V 0.75A schottky diode
9 e* M! Y& Q7 Q8 z) u- q W6 sS77 SST177 Sil F SOT23 J177 p-ch fet9 E! ^* W1 i3 z& }
S7s BBY53-05 Sie B SOT23 dual cc varicap% P8 \/ h8 z: y& U* v7 Y6 n; V) a
S7s BBY53-05W Sie B SOT323 dual cc varicap
8 ^' |. d: K( o% I! M! ]S8 BF512 Phi G BF410C. Y' c# U3 H$ s x
S8 BAT14-099 Sie NQ SOT143 Dual schottky: Q7 r8 x# M4 T+ d
S9 BAT14-099R Sie DQ - Quad crossover ring schottky
. H! ~/ k/ O+ I# zS9 BF513 Phi G - BF410D
" z! N' V' {, @* ?/ VSA BSS123 Sie M SOT23 n-ch mosfet 100V 0.17A
: K: x- y; c4 GSD BSS284 Sie M SOT23 p-ch mosfet 50V 0.13A2 e7 P9 ^4 A* G w2 C- K1 d0 J: p- e
SE 2SC4703 Nec P - npn RF 1.8W fT 6GHz
# z/ c" V4 l% L4 Z7 @SF 2SC4703 Nec P - npn RF 1.8W fT 6GHz0 K% H9 L% x) @+ |. T0 P i
SFs BB804 Sie A SOT23 dual 45-26pF cc VHF varicap& t! P; h; q( b* I! p7 ^/ |
SH 2SC4703 Nec P - npn RF 1.8W fT 6GHz
: T8 Q( U8 K6 f' S* c4 rSH2 BB814 Sie A SOT23 dual 45-20pF cc varicap
5 b& n; B; K/ M5 i- T" w6 N6 I5 aSM BB914 Sie B SOT23 dual varicap for FM radio& ]% E6 e$ [8 o; p3 z$ V- Q* q
SP BSS84 Sie M SOT23 p-ch mosfet 50V 0.13A; l# n. k: |( B: l4 O
SR BSS131 Sie M SOT23 n-ch mosfet 240V 0.1A
9 u- S1 H: _- @ k: nSS BSS138 Sie M SOT23 n-ch mosfet 50V 0.22A
- A: f* |) |/ d. h$ G9 U6 X5 g( z, vsSG SN7002 Sie M SOT23 n-ch mosfet 60V 0.19A/ r4 q) J- Z/ B
ST BSS139 Sie M SOT23 n-ch dep mosfet 250V 0.04A! F1 x! j Q- o( z0 q+ I8 }+ K
T BB515 Sie I SOD323 varicap 17.7pf @ 1V 30V max
$ x8 P* R7 ]7 f0 E- Z' ?9 Q. K+ GT BAR67-02W Sie I SCD80 -
4 B. B9 T$ p4 ^$ K" JT0 TP0601T Tem M - p-ch mosfet 60V 0.12A! f: Y0 p: k* B* ~! K
T0 HSMS-2860 HP C SOT23 zero bias schottky diode/ l. p4 s q. |. @6 R% t# G4 A
T0 HSMS-286B HP C SOT323 zero bias schottky diode
7 {6 d1 h J/ M2 x0 M6 \t01 PDTA143ET Phi N SOT23 pnp dtr 4k7+4k7
, w& J7 E' r _( l- B9 |t02 PDTC143ET Phi N SOT23 npn 4k7+4k7 bias res E7 ?0 ?+ m- R2 T
t04 PMBS3904 Phi N SOT23 2N3904 8 B# Q% U4 l! i' n, c
t06 PMBS3906 Phi N SOT23 2N39063 k; A# `$ F8 q. m4 z; P
T1 BCX17 Phi N SOT23 BC327
x( i5 [. ?: R, S% @4 G$ j& NT1 IMT1A Roh DA - 2 x 2SA1037AK pnp
2 S2 z. t1 I3 y3 mT1 BSS63 Mot N SOT23 pnp 100V 0.1A% N4 `1 v1 c+ p3 D
t11 PDTA114TT Phi N SOT23 pnp dtr- |* o+ N3 J! o# g* f
t12 PDTC114TT Phi N SOT23 npn dtr
# l/ A$ C H. p L6 bt16 PDTC114EU Phi N SOT323 npn dtr
( k" H5 @4 q6 c+ v5 [t17 PDTC124EU Phi N SOT323 npn dtr5 s+ f1 h# }& o
t18 PDTC143ZT Phi N SOT23 npn dtr 4k7+47k9 q& y' C& n0 E
t19 PDTA143ZT Phi N SOT23 pnp dtr 4k7+47k
3 ^; G2 x$ X& ]; Y3 }" lt1A PMMT3904 Phi N SOT23 2N3904
/ b- w1 q; R; L7 ~5 `: L! [$ q: zt1A PMST3904 Phi N SOT323 2N3904
) d% D8 C6 q) P! m) s( w& o+ N, bt1B PMBT2222 Phi N SOT23 2N2222
# |1 |' k# T2 k+ u. e5 D8 I0 {t1B PMST2222 Phi N SOT233 2N2222% e1 M7 v4 N6 ?$ V- S
t1D PMBTA42 Phi N SOT23 MPSA42 300V npn) i' b) P1 M/ U8 z; c# C
t1D PMSTA42 Phi N SOT323 MPSA42 300V npn
: L8 ~6 o4 R7 p0 Ct1E PMBTA43 Mot N SOT23 MPSA43 200V npn9 q7 O* C" m; E. W7 ]* J4 u
t1E PMSTA43 Mot N SOT323 MPSA43 200V npn s) m' F0 i+ ~& f4 {4 {
t1F PMBT5550 Phi N SOT23 2N5550 140V npn0 }% e! a7 Q. d1 e
t1F PMST5550 Phi N SOT323 2N5550 140V npn! F( ], Q- M, y; ? r! E* f
t1G PMMTA06 Phi N SOT23 MPSA06# T0 S9 ?7 g6 o! a3 {
t1G PMMTA06 Phi N SOT323 MPSA06
2 h1 x1 p6 t4 U4 a3 S) xt1H MMBTA05 Phi N SOT323 MPSA05
" u- Z' F) z, |$ st1J PMBT2369 Phi N SOT23 2N2369
; m% f. h# Z q2 i6 b/ zt1J PMBT2369 Phi N SOT323 2N2369
8 l8 {& z6 v3 M# o6 c8 Ht1K PMBT6428 Phi N SOT23 MPSA18 50V
% s/ A4 X' R3 e! Q3 j ?4 St1K PMBT6428 Phi N SOT323 MPSA18 50V' A$ s; l! M4 {6 D% P( W+ p
t1L PMBT6429 Phi N SOT23 MPSA18 45V; `4 q% @0 v6 G. I# ~) T
t1L PMBT6429 Phi N SOT323 MPSA18 45V
% y& w% e: e9 y( x- ^t1M PMBTA13 Phi N SOT23 MPSA13 darlington
1 H$ l7 m: S1 U$ s( {t1N PMBTA14 Mot N SOT23 MPSA14 darlington
* z; @& d* u7 I% ?2 L, @+ Z: Ct1P PMBT2222A Phi N SOT23 2N2222A
; n0 v8 u5 _) B) v St1P PMST2222A Phi N SOT323 2N2222A! x: _0 a9 ^) x" H; I; J
T1p BCX17 Phi N SOT23 BC327
% X0 H! l8 d4 N: Q- b; n, gt1Q PMBT5088 Phi N SOT23 MPSA18 Vce 30V& C- {. Q6 ~) }* e6 m* |% C) O1 A
t1Q PMST5088 Phi N SOT323 MPSA18 Vce 30V
4 O: P, o; L0 X5 A- o% j9 |t1R PMST5089 Phi N SOT323 MPSA18 Vce 25V
, W$ y' v" N: xT1t BCX17 Phi N SOT23 BC327$ O6 Z2 f1 y5 y7 g) A3 A6 {
T2 BCX18 Phi N SOT23 BC328
+ [8 ^7 e- F" f- W" z6 F+ nT2 IMT2A Roh DB - 2 x 2SA1037AK pnp
4 P) W2 ~# k2 f V5 E3 `2 g; B& FT2 HSMS-286C HP D SOT323 dual series HSMS-286B! _/ _: v5 H, j
T2 HSMS-2862 HP D SOT23 dual series HSMS-286B
+ l7 _0 k) B9 d3 l, ft23 PDTA114TU Phi N SOT323 pnp dtr R1 10k& V" j- H5 M0 S0 y l) m' a
t24 PDTC114TU Phi N SOT323 npn dtr R1 10k) H3 l+ u1 i/ b) F6 N u7 a" @4 }
t2A PMBT3906 Phi N SOT23 2N3906
$ e* `' [4 g6 j% Lt2A PMST3906 Phi N SOT323 2N3906- n( H# ~ A4 D* h6 _
t2B PMBT2907 Phi N SOT23 2N2907: ^# o* g: G( x4 H' b
t2D PMBTA92 Phi N SOT23 MPSA92 pnp Vce 300V
# }$ s, g |* t+ z; dt2D PMSTA92 Phi N SOT323 MPSA92 pnp Vce 300V
' \) t& _- s7 B( a) y' ot2E PMBTA93 Phi N SOT23 MPSA93 pnp Vce 200V8 @. U- [+ ~; n1 E& |$ p; ~2 J
t2E PMSTA93 Phi N SOT323 MPSA93 pnp Vce 200V8 m$ z, ?6 R) b3 j
t2F PMBT2907A Phi N SOT23 2N2907A
% }& v' q) I- c' u8 M, r( L1 ^t2F PMBT2907A Phi N SOT323 2N2907A
1 T ]) e C% _( W* C1 t/ Qt2G PMBTA56 Phi N SOT23 MPSA56( U# N6 j0 m! z3 `& M9 l
t2G PMSTA56 Phi N SOT323 MPSA56$ q* R0 p# N- \7 W7 b- f7 Z& j- x
t2H PMBTA55 Phi N SOT23 MPSA555 y+ D& Y5 q# I- E4 F6 b2 s% I( d( B
t2H PMSTA55 Phi N SOT323 MPSA55" p8 b9 h: N. Z U. K- [
t2L PMBT5401 Phi N SOT23 2N5401 pnp 150V
- K/ u4 y* v+ Y7 _$ Tt2L PMST5401 Phi N SOT323 2N5401 pnp 150V. \" z# ?( R+ }. `# v( @
T2p BCX18 Phi N SOT23 BC328
. D7 b- d; _+ t1 C' V/ U7 Ht2T PMBT4403 Phi N SOT23 2N4403) U* y: j/ T# g4 |: Q4 ]# ]1 c
t2T PMST4403 Phi N SOT323 2N4403: U7 C, z, J/ i" w2 Y- l# o0 C
T2t BCX18 Phi N SOT23 BC3284 C2 C* k9 m/ B* }' j* H
t2U PMBTA63 Phi N SOT23 MPSA63 darlington; B& t5 r; w3 P! }8 A& R
t2V PMBTA64 Phi H SOT23 MPSA64 darlington3 O# E5 L: L$ ^5 {* \% Y
t2X PMBT4401 Phi N SOT23 2N4401
( T7 B; @0 ?% u Mt2X PMST4401 Phi N SOT323 2N4401
: ~$ k2 [: i! d1 X. @5 j( eT3 BSS63 Phi N SOT23 BSS68
% r7 [3 L) z, ST3 HSMS-286E HP A SOT323 ca dual HSMS-286B: \* b8 e$ M) k- }
T3 HSMS-2863 HP A SOT23 ca dual HSMS-286B. j0 w2 w; z* K/ e/ |2 B- |
t31 PDTA143XT Phi N SOT23 pnp dtr4k7+10k
! Q5 S( \9 n U! `t32 PDTC143XT Phi N SOT23 pnp dtr 4k7+10ks
* G7 a% u, m( G/ eT32 2SC4182 Nec N SOT23 npn RF fT 1.1GHz @3V hfe 60-105
W: f6 J% X4 pT33 2SC4182 Nec N SOT23 npn RF fT 1.1GHz @3V hfe 85-150
0 Z8 w6 z9 _9 u. n i8 k* O; t+ {T34 2SC4182 Nec N SOT23 npn RF fT 1.1GHz @3V hfe 120-220/ t; X3 T+ Y5 u z# A5 D
T4 BCX17R Phi R SOT23R BC327
" E; ~/ T# j, Y. X: OT4 HSMS-286F HP B SOT323 cc dual HSMS-286B! Q% v+ i5 d+ z' d$ F$ Y- i- i7 {
T4 HSMS-2864 HP B SOT23 cc dual HSMS-286B3 ?0 A* U& r5 b8 B! i7 z0 B
T4 MBD330DW Mot DL SOT363 dual UHF schottky diode6 @6 W- g, c4 w
T42 2SC3545P Nec N - npn RF fT 2GHz hfe 50-100' c0 S( p- X! l9 A3 C" ^5 g
T42 2SC4184 Nec N SOT323 npn RF fT1.8GHz hfe 40-80: V, h$ Y1 Z1 F$ D
T43 2SC3545Q Nec N - UHF osc/mix fT 2GHz hfe 70-1406 G) z' p' O5 L3 U7 i
T43 2SC4184 Nec N SOT323 npn fT1.8GHz hfe 60-1203 i7 n+ Z! s& ^( x" M+ o' Y5 Q
T44 2SC3545R Nec N - npn RF fT 2GHz hfe 120-250( Z- Y7 G' A/ E' D: ?8 T7 P' z& ?
T44 2SC4184 Nec N SOT323 npn RF fT1.8GHz hfe 100-2004 ~3 Y' V# f* O/ H
T5 HSMS-2865 HP S SOT143 separate dual HSMS-286B' v e$ x" S$ ?* d
T5 BCX18R Phi R SOT23R BC328
6 t( R: B# g' G3 i6 pT6 BSS63R Phi R SOT23R BSS683 K- @; G3 Y2 Q/ W! R
T62 2SC3841P Nec N SOT23 npn RF fT 4GHz hfe 40-800 G* b- w$ ^+ G1 l
T62 2SC4186 Nec N SOT323 npn RF fT 4GHz hfe 40-80
# [9 @' H) R/ s( r* N* G0 MT63 2SC3841Q Nec N SOT23 npn RF fT 4GHz hfe 60-120
, `7 q s' T) H% |T63 2SC4186 Nec N SOT323 npn RF fT 4GHz hfe 60-120
9 N! q: k _4 p7 {9 K1 AT64 2SC3841R Nec N SOT23 npn RF fT 4GHz hfe 100-200
& y1 L" L1 y1 ^5 n7 b9 P5 GT64 2SC4186 Nec N SOT323 npn RF fT 4GHz hfe 100-200
% n& ]- |$ Q( [3 t4 z) oT7 BSR15 SGS N SOT23 2N2907% Z+ f, a$ t7 {
T71 BSR15R SGS R SOT23R 2N2907
. l+ |7 F+ G. z) s, M( XT72 2SC4568 Nec N SOT23 npn RF ft 5.5GHz hfe 40-805 k5 o% q0 `9 V7 _. N/ Y
T72 2SC4570 Nec N SOT323 npn RF ft 5.5GHz hfe 40-80
8 z" f$ \" t) HT73 2SC4568 Nec N SOT23 npn RF ft 5.5GHz hfe 60-120' W) V0 h' g/ B0 n! |
T73 2SC4570 Nec N SOT323 npn RF ft 5.5GHz hfe 60-1209 N: ~; F, x. ]3 g
T74 2SC4568 Nec N SOT23 npn RF ft 5.5GHz hfe 100-200
: M: E# l* M( o, \5 K! i# yT74 2SC4570 Nec N SOT323 npn RF ft 5.5GHz hfe 100-2000 E6 V" v7 }* e9 s3 b- q
T75 2SC4569 Nec N SOT23 npn RF fT 5GHz hfe 40-80
7 X. u! E2 H3 J: x# sT75 2SC4571 Nec N SOT323 npn RF fT 5GHz hfe 40-80
; ?" \% V' V: M9 J& ~T76 2SC4569 Nec N SOT23 npn RF fT 5GHz hfe 60-120
' e+ {/ w6 c# @$ \0 lT76 2SC4571 Nec N SOT323 npn RF fT 5GHz hfe 60-120
1 B9 k4 X5 {2 l% A" Y0 y1 a" y6 `T76 2SC4571 Nec N SOT323 npn RF fT 5GHz hfe 100-200
- S5 Q0 t7 w" D- \0 MT77 2SC4569 Nec N SOT23 npn RF fT 5GHz hfe 100-2008 b h9 r; A6 _0 b
T78 2SC5507 Nec WQ SOT343 npn RF fT 25GHz 3V 10mA
! L0 Q' D, S5 h" p8 uT79 2SC5508 Nec WQ SOT343 npn RF fT 25GHz 3V 30mA
. V2 }+ G9 M3 o6 @9 V4 VT7p BSR15 Phi N SOT23 2N29073 w* P& W/ q, y e l& {9 p! h, Q
T7t BSR15 Phi N SOT23 2N2907
% e/ R: U3 b# E0 v2 F2 D2 BT8 BSR16 SGS N SOT23 2N2907A
2 a: t9 J& E8 S" l! `/ E1 s+ aT80 2SC5507 Nec WQ SOT343 npn RF fT 17GHz 3V 90mA
( K) x7 v- M+ s; x$ K9 j1 n8 f7 sT81 BSR16R SGS R SOT23R 2N2907A
: S6 B+ j) d0 b2 v; O) m$ e# K* gT82 2SC4954 Nec N SOT23 npn RF fT12GHz @3V 5mA5 k, a& C5 ~6 }
T82 2SC4956 Nec WQ SOT143 npn RF fT 12GHz @3V 5mA
* M$ O; {7 R1 p0 U; kT82 2SC4958 Nec N SOT323 npn RF fT 12GHz @3V 5mA; f# J2 D0 D9 K" I- e
T82 2SC5014 Nec WQ SOT343 npn RF fT 12GHz @3V 5mA( t' @' ]" `4 y$ u
T83 2SC4955 Nec N SOT23 npn RF fT 12GHz @3V 10mA
$ x0 ]& C( }% b( i9 x6 zT83 2SC4957 Nec WQ SOT143 npn RF fT 12GHz @3V 10mA# U) k/ c2 w5 H0 y8 N" H
T83 2SC4959 Nec N SOT323 npn RF fT 12GHz @3V 10mA
' h( a. J5 v/ }' F& CT83 2SC5015 Nec WQ SOT343 npn RF fT 12GHz @3V 10mA
9 @4 z7 [. k0 j- e `T84 2SC5177 Nec N SOT23 npn RF fT 13GHz @2V 7mA5 x8 H: y1 r# \4 {: q" b
T84 2SC5179 Nec N SOT323 npn RF fT 13GHz @2V 7mA- V6 Y: F) [7 e) {
T84 2SC5178 Nec WQ SOT143 npn RF fT 13GHz @2V 7mA. q0 T9 G( Y. O3 d. V7 b
T84 2SC5180 Nec WQ SOT343 npn RF fT 13GHz @2V 7mA
3 _. _: U# c: p8 {0 V7 [9 {# WT86 2SC5182 Nec N SOT23 npn RF fT 12GHz @2V 20mA1 x7 o3 O4 s2 Q' B4 A% h
T86 2SC5183 Nec WQ SOT143 npn RF fT 12GHz @2V 20mA
$ r! S W# p" e" V- X: [* rT86 2SC5184 Nec N SOT323 npn RF fT 12GHz @2V 20mA! X0 R- A+ M& i( D: G
T86 2SC5183 Nec WQ SOT343 npn RF fT 12GHz @2V 20mA
9 S' a0 [$ q, BT88 2SC5191 Nec N SOT23 npn RF fT 8.5GHz @3V 20mA/ F0 w; ^& G* i9 K
T88 2SC5192 Nec WQ SOT143 npn RF fT 8.5GHz @3V 20mA
& y$ z* v' d: o: n- @T88 2SC5193 Nec N SOT323 npn RF fT 8.5GHz @3V 20mA0 U% R* z- n' A3 F1 t# _( N4 B
T88 2SC5193 Nec WQ SOT343 npn RF fT 8.5GHz @3V 20mA
" M C( E; Q' Y% W- sT89 2SC5288 Nec WQ SOT143 npn RF/ [9 o. z6 Z+ W8 k% L
T8p BSR16 Phi N SOT23 2N2907A7 s; c' W9 ]" Y/ W5 K% U3 o |
T8t BSR16 Phi N SOT23 2N2907A
0 f/ v# T& A4 Z7 Z) X5 @6 l0 IT90 2SC5289 Nec WQ SOT143 npn RF
% V/ G% C: m& g/ K7 dT92 BSR18A Fch N SOT23 2N39042 A; u6 I3 N% F, ~
T92 2SA1977 Nec N SOT23 pnp RF fT 8.5GHz
( ?, V# C3 ~- T5 m* a( ?$ H' ~) oT92P BSR18A Phi N SOT23 2N3904" k" i3 j* e, Y
T93 2SA1978 Nec N SOT23 pnp RF fT 8.5GHz
0 z0 N( X! D) K: F/ y# W& iTA 2SC5431EB Nec N SC59 npn RF fT 4.3GHz 12V 60mA
' j( {5 z5 s) E- H% jTB 2SC5431FB Nec N SC59 npn RF fT 4.3GHz 12V 60mA$ | {: L% K4 P* ^6 u c
TC 2SC5432EB Nec N SC59 npn RF fT 4.5GHz 12V 100mA0 u/ {# w+ A3 g7 q8 i4 ^+ N
TD 2SC5432FB Nec N SC59 npn RF fT 4.5GHz 12V 100mA8 z1 c+ n, }5 x: ?- |4 e# `
TE 2SC5433EB Nec N SC59 npn RF fT 7GHz 10V 65mA
+ T F6 ~ O' h9 I: h$ t l. gTF 2SC5433FB Nec N SC59 npn RF fT 7GHz 10V 65mA) h, V( J0 ^ e& N6 W1 W
TFX BAL99 Mot V SOT23 switching diode
- ]. Y- n- |/ Z( e% N* ntG1 PMBT5551 Phi N SOT23 2N5551 npn Vce 140V1 r2 @- E+ N4 j
tG1 PMST5551 Phi N SOT323 2N5551 npn Vce 140V, a6 G. l5 J, T4 K9 ^
TH 2SC5434EB Nec N SC59 npn RF fT 8GHz 10V 35mA2 z4 S% q6 ?* X$ V1 R
TJ 2SC5434FB Nec N SC59 npn RF fT 8GHz 10V 35mA" K9 R& ^& v( O7 w
TK 2SC5435EB Nec N SC59 npn RF fT 12GHz 9V 30mA( u5 L8 \6 S0 j5 I- V1 }
TL 2SC5435FB Nec N SC59 npn RF fT 12GHz 9V 30mA0 v9 B* q$ q3 j3 j1 y
TN 2SC5436EB Nec N SC59 npn RF fT 14GHz 5V 30mA% j# I( k# i- p0 g& }* [6 A
TP 2SC5436FB Nec N SC59 npn RF fT 14GHz 5V 30mA
. \' e4 f. w! j/ b, P; v* e# J2 nTS 2SC5437EB Nec N SC59 npn RF fT 9.5GHz 9V 50mA
- b, M9 c0 c& e& B6 f& u/ PTT 2SC5437FB Nec N SC59 npn RF fT 9.5GHz 9V 50mA. ]3 C2 g/ R; T. _$ g
TV 2SC5599 Nec N SC-70 npn RF fT 5GHz 5.5V 5mA# h4 D/ ~7 G. ~ b+ `( y
TV 2SC5600 Nec N SC-59 npn RF fT 5GHz 5.5V 15mA
2 c7 V1 h2 H! p2 ?& Q1 HTV MMBF112L Mot F SOT23 RF jfet0 |% X+ S+ l4 |1 V4 |
TW 2SC5602 Nec N SC-70 npn RF fT 13.5GHz 6V 5mA0 V( L( b6 `" \1 P, J4 F
TW 2SC5603 Nec N SC-59 npn RF fT 13.5GHz 6V 15mA+ K9 n' U2 c/ W ?. T& s) d
U BB545 Sie I SOD323 20-2pF varicap
/ J' H3 b# c; E6 t/ _6 [; aU1 BCX19 Mot N SOT23 BC3374 a, j# q0 P+ s9 Z" L2 Z/ u* ~# _
U1 BGX50A Sie BQ SOT143 quad ring Si sw diodes
3 F8 x) i6 n( F2 o4 _( [U16 2SC4183 Nec N - npn RF 5V fT1GHz hFE 60-120
, e7 u3 W" O2 z& Z" w4 X3 ~4 XU17 2SC4183 Nec N - npn RF 5V fT1GHz hFE 90-180
3 D/ V2 _) X9 q& H" Q9 J) G+ m2 gU18 2SC4183 Nec N - npn RF 5V fT1GHz hFE 120-240
) Q- Z% g( [% Q* T% mU1A 3SK230A Nec UQ SOT143 dg RF mosfet2 s1 n0 r7 \. s& I
U1B 3SK230B Nec UQ SOT143 dg RF mosfet) J$ {/ B: K0 S& r
U1C 3SK231C Nec UQ SOT143 dg RF mosfet5 ~4 o+ k8 i3 K1 k
U1D 3SK231D Nec UQ SOT143 dg RF mosfet8 e; x9 v6 D" j- c. K
U1E 3SK252E Nec UQ SOT143 dg RF mosfet
) C/ \) k. [# ^7 `U1E 3SK254E Nec UQ SOT343 dg RF mosfet
& _! C; f2 g( m( j( [/ f# }, sU1G 3SK253G Nec UQ SOT143 dg RF mosfet
\& t; J$ B) i: l2 H, y2 YU1G 3SK255G Nec UQ SOT343 dg RF mosfet
5 O9 h U% Z: q- D' xU1p BCX19 Phi N SOT23 BC3373 f* E5 _ m( o! z# P4 n r, g# P
U1t BCX19 Phi N SOT23 BC337
" R. j9 H/ e" t! Q) j9 T% TU2 BCX20 Phi N SOT23 BC338
' X* S5 l6 z$ u% cU21 2SC4185 Nec N - npn RF 10V fT2.4GHz hFE 40-805 N! G1 Y. K7 u+ O5 s3 B0 C
U22 2SC4185 Nec N - npn RF 10V fT2.4GHz hFE 60-120
$ s! i! w' [( M5 WU23 2SC4185 Nec N - npn RF 10V fT2.4GHz hFE 90-180
$ B+ | Q! |% y# e, G$ Y- _/ y0 p: XU2t BCX20 Phi N SOT23 BC338
i- l6 B+ S) x' j: }& nU3 BSS64 Phi N SOT23 120V 0.25A 0.2W4 _- f. C7 G! Z9 l0 C/ s
U4 BCX19R Phi R SOT23R BC337
1 f) L+ K3 f! \) e8 FU5 BCX20R Phi R SOT23R BC338% p' T! x0 K9 @0 Z9 }1 b
U55 3SK134B Nec UQ SOT143 dg mosfet
. z) b& _( [7 K3 l( IU55 3SK245 Nec UQ SOT343 dg mosfet
9 r z! u6 f+ k A& b# m, wU56 3SK134B Nec UQ SOT143 dg mosfet
1 h2 @# p& w6 Q/ z; w0 y dU56 3SK245 Nec UQ SOT343 dg mosfet
- z8 L2 J' }& Y! |6 t% R$ lU6 BSS64R Phi R SOT23R 120V 0.25A 0.2W. @2 ^4 Y' u9 n3 o1 l/ O
U65 3SK135A Nec UQ SOT143 dg mosfet( @8 N* F& C+ G$ q
U66 3SK135A Nec UQ SOT143 dg mosfet
; V3 j5 y* l4 T8 b' I1 s6 RU7 BSR13 SGS N SOT23 2N2222
4 v T' P7 J! s/ V! |U71 BSR13R SGS R SOT23R 2N2222
+ p# T3 O+ W8 n4 z/ H" {% V2 HU71 3SK177 Nec UQ SOT143 dg GaAsfet Idss 5-15mA
0 Q6 [" N9 L% M0 ?& U' QU71 3SK299 Nec UQ SOT343 dg GaAsfet Idss 5-15mA
, a1 s! r+ ]$ ~5 g, P& {U72 3SK177 Nec UQ SOT143 dg GaAsfet Idss10-25mA. H( ^. K# z6 [3 U2 C$ T. Q4 Q
U72 3SK299 Nec UQ SOT343 dg GaAsfet Idss 10-25mA2 O4 x6 L5 z1 a2 X
U73 3SK177 Nec UQ SOT143 dg GaAsfet Idss 20-35mA E2 l* A8 ~1 X( x
U73 3SK299 Nec UQ SOT343 dg GaAsfet Idss 20-35mA& q3 m2 W; m; R9 w; Z3 s
U74 3SK177 Nec UQ SOT143 dg GaAsfet Idss 30-40mA
$ \* c' W; ^# y8 |5 kU74 3SK299 Nec UQ SOT343 dg GaAsfet Idss 30-40mA
7 ]* x4 { X5 Y* N& oU76 3SK206 Nec UQ SOT143 dg GaAsfet Idss 10-25mA O3 u* ^1 x' V. N0 k9 o
U77 3SK206 Nec UQ SOT143 dg GaAsfet Idss 20-35mA& u, t5 o& p" y0 W& U
U78 3SK206 Nec UQ SOT143 dg GaAsfet Idss 30-50mA
" c7 O. s' T( s" k0 Z* {8 jU79 3SK206 Nec UQ SOT143 dg GaAsfet Idss 45-80mA+ I, i+ f4 Q5 E/ w
U7p BSR13 Phi N SOT23 2N2222
$ C4 S" O1 |6 ]+ gU7t BSR13 Phi N SOT23 2N2222* j) U+ c2 v$ \
U8 BSR14 SGS N SOT23 2N2222A: A5 `0 n+ |8 m) y7 r8 c6 I2 A0 f
U81 BSR14R SGS R SOT23R 2N2222A
8 @9 {$ R7 f F: a8 tU87 3SK176A Nec UQ SOT143 dg mosfet
( F# {& Z+ B, L8 M8 yU88 3SK176A Nec UQ SOT143 dg mosfet2 B6 p+ p3 w0 q8 |
U8p BSR14 Phi N SOT23 2N2222A( z2 v3 _( h8 D
U8t BSR14 Phi N SOT23 2N2222A8 N0 k' b. v0 C8 F4 t$ |
U90 3SK223 Nec UQ SOT143 dg mosfet& J. L. l4 }" t: [
U90 3SK243 Nec UQ SOT343 dg mosfet6 A4 a. E7 q4 k- x; o x
U91 3SK223 Nec UQ SOT143 dg mosfet
0 Q$ N0 |+ @2 @/ N, UU91 3SK243 Nec UQ SOT143 dg mosfet
3 b7 z. c: [# Q( L; N* QU92 BSR17A Fch N SOT23 2N3904' ?# p- E9 }' I6 R6 X) ?" l$ c& w
U92p BSR17A Phi N SOT23 2N3904
( N% ?2 \7 B- O# z R0 eU94 3SK224D Nec UQ SOT143 dg mosfet/ i- L, h, }1 O
U94 3SK244D Nec UQ SOT343 dg mosfet8 r7 r8 ^7 h, _, o0 G7 x% y+ l! R$ p
U95 3SK224E Nec UQ SOT143 dg mosfet! @3 P3 e& S4 j, U" h* {; x+ W
U95 3SK244E Nec UQ SOT143 dg mosfet8 d% ]! K! j4 @! Q) g
UB 2SB852K Roh N - pnp darlington comp 2SD1383K
+ Z- _# L7 }7 u' UUC MSC2404-C Mot H - npn RF 450MHz fT 20V$ y0 D0 u0 \- A2 j5 o
V01 VN50300T Sil M - n-ch enh mosfet 500V 22mA( T' i/ ~+ `0 Q7 ~3 O$ e
V02 VN0605T Sil M - n-ch enh mosfet 60V/0.18A8 x* |' o8 E' A3 D1 w
V04 VN45350T Sil M - n-ch enh mosfet 450V 20mA/ U$ V; k! T2 s8 w* y4 m: x
V1 MRF959 Mot N SC75 npn RF fT 9GHz- r' c, K k7 l7 ~* j
V11 3SK131 Nec UQ SOT143 dg VHF mosfet
7 ?$ s; H+ N; T% c2 O5 Q* u3 ?V11 3SK242 Nec UQ SOT343 dg VHF mosfet
2 p! u$ s- W- {0 u, pV12 3SK131 Nec UQ SOT143 dg VHF mosfet6 _) d* q% l2 p" _' t# A" @
V12 3SK242 Nec UQ SOT343 dg VHF mosfet
A! s' D/ ?$ }/ A) G* eV13 3SK131 Nec UQ SOT143 dg VHF mosfet
: U) ?9 H- Y, u) ~& QV13 ZC932 Zet C SOT23 5 - 17pF hyperabrupt varicap* Y+ O# L9 D j5 e* T _" D* S
V13 3SK242 Nec UQ SOT343 dg VHF mosfet
9 u5 x" F8 }) n0 Y" xV14 ZC931 Zet C SOT23 4 -13.5pF hyperabrupt varicap
" e0 G H+ i. k# |, ]% ?# k# ~V15 ZC930 Zet C SOT23 3 - 9pF hyperabrupt varicap
- ~: ]0 h. z7 S# p/ X& ?7 G0 ?V16 ZC934 Zet C SOT23 25 - 95pF hyperabrupt varicap
; ?" h- u8 z. u- LV17 ZC933 Zet C SOT23 12 - 42pF hyperabrupt varicap! s0 V( ~! `. B' _
V1p BFT25 Phi N SOT23 npn RF 5V 6.5mA 2.3GHz
3 O$ |1 V; Y0 O4 T IV2 BFQ67 Tfk N - npn RF fT 7.5 GHz 50mA
. W8 d- e( |; n# N# PV21 3SK222 Nec UQ SOT143 dg VHF mosfet) E7 |* H2 S0 Z3 r5 w L
V21 3SK246 Nec UQ SOT343 dg VHF mosfet) H: A( G' p4 C7 Y5 ^
V22 3SK222 Nec UQ SOT143 dg VHF mosfet# u6 O" s6 X7 v* [# Y8 T
V22 3SK246 Nec UQ SOT343 dg VHF mosfet" _3 w3 h. Q' j# M. t
V3 BFG67 Phi X SOT143 npn RF fT 8GHz 50mA. C+ l& i8 f3 {5 K
V5 BFG197 Phi X SOT143 npn RF 7.5GHz 100mA
/ x8 i/ z' m: H5 K& s' J- JV50 VP0610T Sil M - p-ch enh mosfet -60V 120mA
+ S# \' M* z, M3 B( t: sVB MSC2295-B Mot H - npn RF 150MHz fT 20V
% D+ x4 ^, V S, @VC MSC2295-C Mot H - npn RF 150MHz fT 20V
3 A5 f1 T0 G' M1 w5 w3 |2 CW0F TSDF1205RW Tfk WQ SOT343 12GHz npn 5mA 4V
2 V5 ~+ o! F( i% e% LW18 BFP181TW Tfk X - npn RF fT 7.8GHz 10V 20mA8 X4 ] w. W; N2 H+ j) y% Z
W18 BFP181TRW Tfk WQ - npn RF fT 7.8GHz 10V 20mA
9 a" r$ Y' w2 q) N$ Z$ iW1s BFT92 Sie N SOT23 BFQ51/BFQ76
$ J% r" C( c- |* ~W1s BCR10PN Sie DP SOT363 pnp/npn dig 0.1A 10k+10k& ~+ y; n, [# L3 r
W2 TSDF1220RW Tfk WQ SOT343 12GHz npn 6V 20mA
" g0 h4 |5 ~$ N2 G6 J7 W ~; YW22 S822TW Tfk X - npn rf fT 5.2 GHz 6V 8mA , c e1 p, r0 J$ S3 x8 g
W22 S822TRW Tfk WQ - npn rf fT 5.2 GHz 6V 8mA - f3 ?2 K* V1 G' a F! E' }
W28 BFP280TRW Tfk WQ - npn rf fT 7 GHz 8V 10mA , v6 F$ H7 G& U3 q
W28 BFP280TW Tfk X - npn rf fT 7 GHz 8V 10mA
* p4 i, v/ }/ ^. p& P) xW3 BZX84-C2V4 Phi C SOT23 0.3W zener 2.4V±5% X/ I! D. `. Y
W4 BZX84-C2V7 Phi C SOT23 0.3W zener 2.7V±5%
( {2 S9 F7 `) Q0 U. o" Y7 LW5 BZX84-C3V0 Phi C SOT23 0.3W zener 3.0V±5%4 y5 D8 D. P$ a2 U: O" k
W52 S852TW Tfk X - npn rf fT 5.2 GHz 6V 8mA + k) {4 G/ v1 H6 h' F
W6 BZX84-C3V3 Phi C SOT23 0.3W zener 3.3V±5%1 n1 c6 |: b' O! {/ x1 f0 I( d; \
W67 BFP67W Tfk X - npn rf fT 7.5 GHz 10V 50mA( c* `2 Q4 P R+ G
W7 BZX84-C3V6 Phi C SOT23 0.3W zener 3.6V±5%
* f: w/ Z U$ w9 d5 @W8 BZX84-C3V9 Phi C SOT23 0.3W zener 3.9V±5%, G; a( U( Z$ r4 r% S
W8 BZV49C3V9 Zet O SOT89 1W zener 3.9V±5%
$ Z+ i9 L/ r; h0 g6 w: cW82 BFP182TRW Tfk WQ - npn rf fT 7.5 GHz 10V 35mA 0 U& U9 m9 S, `7 N" R$ _. x
W82 BFP182TW Tfk X - npn rf fT 7.5 GHz 10V 35mA , n, R8 s A& D, \5 q% v! p2 N
W83 BFP183TRW Tfk WQ - npn rf fT 7.4 GHz 10V 65mA 7 B) R; S. j: T; D; [
W83 BFP183T Tfk X - npn rf fT 7.4 GHz 10V 65mA
( P" o+ O& I; fW9 BZX84-C4V3 Phi C SOT23 0.3W zener 4.3V±5%
[9 \1 s; z# X7 p: y& AW9 BZV49C4V3 Zet O SOT89 1W zener 4.3V±5%/ w' ?. N4 l4 ]1 v j( V; y
W92 BFP92AW Tfk X SOT343 npn rf fT 6 GHz 15V 30mA
. M/ \% l; ^+ hWB 2SD1383K Roh N - npn darlington comp 2SB852K: A0 Z/ g' o5 W5 v$ G0 f7 j
WCs BCR133 Sie N SOT23 npn dig 50V 0.1A 10k+10k3 U% t9 L6 E, I
WCs BCR133T Sie N SC75 npn dig 50V 0.1A 10k+10k
~6 A% F m0 X8 o# M; zWCs BCR133U Sie N SOT457 npn dig 50V 0.1A 10k+10k3 k! b/ {' j7 P4 A, N6 U# n# y& d
WCs BCR133W Sie N SOT323 npn dig 50V 0.1A 10k+10k
( Z' T( J9 u ]8 W7 j' [6 @/ IWCs BCR133S Sie DN SOT363 dual BCR1330 `8 c2 S% A( }
WDs BCR141 Sie N SOT23 npn 50V 0.1A dig 22k +22k+ g- c- }# `, z! }0 i! x# [( Y) e
WDs BCR141T Sie N SC75 npn 50V 0.1A dig 22k +22k: G R4 y7 z0 ]1 Y2 T: U
WDs BCR141W Sie N SOT323 npn 50V 0.1A dig 22k +22k
( d" F# g- P* y% k& ?/ WWDs BCR141S Sie DN SOT363 dual BCR141
( O! \1 S t: iWE1 BFS17W Tfk N - npn rf fT 2.1GHz SOT-323# P W3 L1 @7 p# k
WE2 BFS17AW Tfk N - npn rf fT 3.2GHz SOT-323" h Z$ U7 c ?4 d
WEs BCR148 Sie N SOT23 npn 50V 0.1A dig 47k +47k
: f+ t2 p- d6 f4 [' PWEs BCR148T Sie N SC75 npn 50V 0.1A dig 47k +47k, _8 d+ {$ G8 P6 i0 A5 p- |4 M o6 d U9 @
WEs BCR148U Sie N SOT457 npn 50V 0.1A dig 47k +47k! ~6 @4 M" t' M1 _# V) l7 w- I
WEs BCR148W Sie N SOT323 npn 50V 0.1A dig 47k +47k
3 t5 M L. w9 A8 A% iWEs BCR148S Sie DN SOT363 dual BCR148" n/ J2 k& `8 c2 d X) }
WF0 TSDF1205W Tfk X SOT343 12 GHz npn 5mA 4V
( E6 A/ A% ?; o' F8 Y; ZWF2 TSDF1220W Tfk X SOT343 12GHz npn 6V 20mA: R, C# [ K( @% d% a
WFE BFP93A Tfk X SOT343 BFP93A (FE) in 6GHz npn
. p- L5 ^; V$ l9 [& D( HWFs BCR08PN Sie DP SOT363 pnp/npn dig 0.1A 2k2+47k! Q0 Q) U6 u/ T$ D4 P! e
WFs BCR112 Sie N SOT23 npn dig 50V 0.1A 4k7+4k7* P& d% m$ E: ?) e! A
WGs BCR116 Sie N SOT23 npn dig 50V 0.1A 4k7+47k
$ U$ ?/ z3 N3 B( h# R+ kWGs BCR116W Sie N SOT323 npn dig 50V 0.1A 4k7+47k
4 ]( U! X A) D; q5 W9 }( w2 AWHs BCR108 Sie N SOT23 npn dig 50V 0.1A 2k2+47k5 _) P+ v9 b8 N- o
WHs BCR108T Sie N SC75 npn dig 50V 0.1A 2k2+47k3 Y; v( N9 i, W$ q( m5 u
WHs BCR108W Sie N SOT323 npn dig 50V 0.1A 2k2+47k" l! ^6 h. e. f
WHs BCR108S Sie DN SOT363 dual BCR108
8 c. o9 r( t# yWIs BCR158 Sie N SOT23 pnp dig 50V 0.1A 2k2+47k- J! ?2 X8 U; F/ W! B
WIs BCR158T Sie N SC75 pnp dig 50V 0.1A 2k2+47k9 p5 T/ w1 j+ W( X4 E4 \/ |
WIs BCR158W Sie N SOT323 pnp dig 50V 0.1A 2k2+47k
4 P5 e# I9 v5 }WJs BCR135 Sie N SOT23 npn dig 50V 0.1A 10k+47k: D" }) |% v7 N( ^8 V" ?. r0 W
WJs BCR135T Sie N SC75 npn dig 50V 0.1A 10k+47k
' g/ u9 A* v y, l5 _) p: ~3 U7 YWJs BCR135W Sie N SOT323 npn dig 50V 0.1A 10k+47k
. \, f# C8 V1 g% p5 _WJs BCR135S Sie DN SOT363 dual BCR135# j; j) u% {+ e- Y
WKs BCR119 Sie N SOT23 npn dig 50V 0.1A 4k7% B2 u' f# `8 ~$ Z: u' J5 x& O
WKs BCR119S Sie DN SOT363 npn dig 50V 0.1A 4k78 Z7 P' S$ r) [. B, n
WKs BCR119W Sie N SOT323 npn dig 50V 0.1A 4k79 W1 h0 ]8 d4 F& d( g. h6 |# d- [
WLs BCR146 Sie N SOT23 dual npn dig 50V 47k+22k
9 W/ R! q* c* Q4 O+ PWLs BCR146W Sie N SOT323 dual npn dig 50V 47k+22k# ?, v% B; b# J! O' X
WMO BF998RW Tfk UQ SOT343R vhf dg mosfet BF988
- l0 Q7 |& j9 eWMs BCR183 Sie N SOT23 pnp dig 50V 10k+10k* E! o/ b, q7 o0 b7 ~7 r: p
WMs BCR183W Sie N SOT323 pnp dig 50V 10k+10k
$ C4 h( ?0 G4 S# t4 V. xWMs BCR183T Sie N SC75 pnp dig 50V 10k+10k
7 F, j7 C) {- A3 C$ PWMs BCR183U Sie N SOT457 pnp dig 50V 10k+10k k; e( [( q b1 t
WMs BCR183S Sie DO SOT363 dual pnp dig 50V 10k+10k
, l* g/ W6 ?; O0 I0 z: E0 @8 z' h6 }* P1 BWNs BCR185 Sie N SOT23 pnp dig 50V 0.1A 10k+47k6 g/ p% @; ?' T$ t- A0 X: @
WNs BCR185U Sie N SOT457 pnp dig 50V 0.1A 10k+47k7 C+ z# Z% _9 v, U0 K, @
WNs BCR185W Sie N SOT323 pnp dig 50V 0.1A 10k+47k
( m0 K1 m. ?6 I+ FWNs BCR185S Sie DO SOT363 dual BCR185
' p; P9 e: `! b9 N7 d" DWO BZX284-B2V4 Phi I SOD110 0.4W zener 2.4V E24 ±2%
, s& R4 e* N; lWOs BCR191 Sie N SOT23 pnp dig 50V 0.1A 22k+22k7 ]. B/ K: `8 |# @
WOs BCR191W Sie N SOT323 pnp dig 50V 0.1A 22k+22k
6 O) F5 i8 d0 u6 U& U- x' z9 eWOs BCR191S Sie DO SOT363 dual BCR191
: J/ Q: @( [7 u+ A8 c7 f1 G; \# l. \WP BZX284-B2V7 Phi I SOD110 0.4W zener 2.7V E24 ±2% * F3 G1 W, H+ X5 O
WP2 BFR92A Tfk N SOT23 BRF90A * ^8 w5 A7 t. g" W, _$ _
WPs BCR192 Sie N SOT23 pnp dig 50V 0.1A 22k+47k) V& L6 c& P% {# u
WPs BCR192T Sie N SC75 pnp dig 50V 0.1A 22k+47k5 f3 u8 ^$ S& q2 p0 n
WPs BCR192W Sie N SOT323 pnp dig 50V 0.1A 22k+47k) a( k7 ~) @+ R+ E$ m1 O
WPs BCR22PN Sie DP SOT363 pnp/npn dig 0.1A 22k+22k
- n7 j& A' V# B# A( s. b$ WWQ BZX284-B3V0 Phi I SOD110 0.4W zener 3.0V E24 ±2% 8 b0 O# q5 d( g7 I0 Q- A' I) R1 G7 M
WR MSD602R Mot N SOT346 npn gp 25V 150mA s$ @; u# v5 F' I# q
WR BZX284-B3V3 Phi I SOD110 0.4W zener 3.3V E24 ±2%
6 {0 r+ _2 x8 U3 F$ k5 t) I$ eWR2 BFR93AW Tfk N - BFR91A ! F- ?9 V' Y8 v: U" C! Q$ ~ p
WRE BFR280TW Tfk N - npn RF fT 7.5GHz 7 a8 \% N& h- g" n8 t
WRF BFR181TW Tfk N - npn RF fT 7.8GHz
& f5 k+ f% b: g4 L7 a" pWRG BFR182TW Tfk N - npn RF fT 7GHz 0 i, G& Z- _+ X& j$ Q
WRH BFR183TW Tfk N - npn RF fT 7.4GHz 9 l) e+ E2 R' e; N# E- P* K" d
WRs BCR198 Sie N SOT23 pnp dig 50V 0.1A 47k+47k
' V. p p/ ]3 K" f% G7 QWRs BCR198W Sie NN SOT323 pnp dig 50V 0.1A 47k+47k
$ R) c& }* e. I r+ L4 M& f9 C+ wWRs BCR198S Sie D SOT363 dual BCR198
+ q6 ?; u8 X9 _$ k M: MWS BCR169 Sie N SOT23 pnp dig 50V 0.1A 4k7
7 u1 x( J# J) v0 ^* ^WS BCR169W Sie N SOT323 pnp dig 50V 0.1A 4k7
% w& A+ i2 D3 [0 ~3 sWS BCR169S Sie DO SOT363 dual BC169' U( Y \( O& z4 V( B7 V$ k
WS BZX284-B3V6 Phi I SOD110 0.4W zener 3.6V E24 ±2%
3 x. M* c! V( _2 J x" _. S" {WT BCR166 Sie N SOT23 pnp dig 50V 0.1A 4k7+47k6 \ y& p6 c. S) k& S8 `
WT BCR166W Sie N SOT323 pnp dig 50V 0.1A 4k7+47k3 O" ^; d$ \; {: p& S
WT BCR48PN Sie DP SOT363 pnp/npn dig npn 2x47k pnp 2k2+47k
6 l" Q$ G H2 P6 }0 m+ I& N+ U7 g1 aWT BZX284-B3V9 Phi I SOD110 0.4W zener 3.9V E24 ±2% & }% w2 m2 W4 k* ]3 C+ X; }
WU BCR162 Sie N SOT23 pnp dig 50V 0.1A 4k7+4k7
+ W2 @; R5 n: C5 b' R" q0 z8 D- ~WU BCR162T Sie N SC75 pnp dig 50V 0.1A 4k7+4k7
1 y( T9 b: g' I) \WU BCR35PN Sie DP SOT363 pnp/npn dig 0.1A 10k+47k
- [0 m b1 `) U0 n( W1 _4 tWU BZX284-B4V3 Phi I SOD110 0.4W zener 4.3V E24 ±2%, \8 N5 [; n7 b; A
WU MRF2947A Mot DG SOT363 dual MRF941 npn RF 9GHz3 K4 B8 r) C# Q
X (white) BB833 Sie I SOT323 9.3-0.75pF varicap
& c: z, h# G! G: J5 gX(yellow) BB835 Sie I SOT323 9.1-0.6pF varicap 3 M9 y8 B+ t( A/ K( K5 Q M
X1 BFT93 Sie N SOT23 BFQ23 BFQ75, d: r' G; x7 s4 _4 F
X1 IMX1 Roh DC - dual 2SC2412K npn% q% |+ y6 x6 t n2 j( g. G
X1 BZX84-C27 Phi C SOT23 0.3W zener 27V±5%
0 U4 k: r% @/ X& q X( Q4 @! M1 vX1p BFT93 Phi N SOT23 BFQ23 BFQ75
3 N$ G2 v: v ?X2 IMX2 Roh DD - dual 2SC2412K npn0 E( J( ~) s8 j4 K9 |9 l
X2 BZX99-C13 Phi C SOT23 13V 0.3W zener ±5%
, J' R1 `1 t. e" S0 GX2 BZX84-C30 Zet C SOT23 0.3W zener 30V±5%
# U' u$ \0 y" j: x& Q; p) z7 k; NX2 BZV49C30 Zet O SOT89 1W zener 30V±5%
) \. A/ [# \' s. e* ]7 Q; Y) x" ?9 U" dX3 BZX99-C15 Phi C SOT23 15V 0.3W zener ±5%
' i8 f: w# }1 D. v) [3 aX3 BZX84-C33 Zet C SOT23 0.3W zener 33V±5%: D7 p6 v, t( b6 m
X4 BFT93R Sie R SOT23R BFQ23 BFQ75
; T! @) P7 \# @+ |) h7 X# J/ D) uX4 BZX84-C36 Zet C SOT23 0.3W zener 36V±5%' ]! H! g% h0 ?0 } ^- |; v
X5 BZV49C39 Zet O SOT89 1W zener 39V±5%
; @/ q5 F/ k3 j, [X5 MMBV409G Mot C SOT23 Hyperabrupt varicap
# O1 y4 _( b. C7 f, C, h4 i8 gX6 BZV49C43 Zet O SOT89 1W zener 43V±5%: c1 e( J: M' V5 \. x1 v
X6 BZX84-C43 Zet C SOT23 0.3W zener 43V±5%
5 V" z0 q1 R( s: i0 AX7 BZX84-C47 Zet C SOT23 0.3W zener 47V±5%# p7 r% g( M2 w5 ?
XA BZX284-B7V5 Phi I SOD110 0.4W zener 7.5V E24 ±2% ; _6 q! u- x* t9 \# r
XA BZX99-C4V7 Phi C SOT23 4.7V 0.3W zener
3 }# D2 C6 s3 hXAs BCR503 Sie N SOT23 npn dtr 50V 0.5A 2k2 +2k2
) V9 |$ P2 P2 O6 h, u. D4 SXB BZX284-B8V2 Phi I SOD110 0.4W zener 8.2V E24 ±2%
4 R# d% \$ }* c: H" }, A0 yXB BZX99-C5V1 Phi C SOT23 5.1V 0.3W zener, L1 ^( n2 P; P9 G X7 Z. S- u4 B
XBs BCR553 Sie N SOT23 pnp dtr 50V 0.5A 2k2 +2k2# k+ O. i2 h+ h- _/ n j/ u
XC BZX284-B9V1 Phi I SOD110 0.4W zener 9.1V E24 ±2% , n, N9 ]! b3 p/ H
XC BZX99-C5V6 Phi C SOT23 5.6V 0.3W zener
: @. Y. ~' W2 N, D9 ^1 R4 zXCs BCR533 Sie N SOT23 npn dtr 50V 0.5A 10k + 10k
. }- \7 D3 L7 H9 {& `XD BZX284-B10 Phi I SOD110 0.4W zener 10V E24 ±2% 9 x' e; F. j+ X5 z/ Y9 T- v7 ^7 y
XD BZX99-C6V2 Phi C SOT23 6.2V 0.3W zener
! c( }4 I$ r O! E( cXDs BCR555 Sie N SOT23 pnp dtr 50V 0.5A 2k2 +10k
% _8 b( z- e: ]! ]! ? P: v! ~XE BZX284-B11 Phi I SOD110 0.4W zener 11V E24 ±2% ' H+ u. g, V. ^5 i" c3 [6 \( |
XE BZX99-C6V8 Phi C SOT23 6.8V 0.3W zener
: k* s/ J& A1 T- l OXF BZX284-B12 Phi I SOD110 0.4W zener 12V E24 ±2%
; d1 V1 z3 u- rXFs BCR512 Sie N SOT23 npn dtr 50V 0.5A 4k7+ 4k75 V, j+ e# o. i, I
XG BZX284-B13 Phi I SOD110 0.4W zener 13V E24 ±2% S( W+ B# L' U1 [4 y( Q: B) G' ~/ Q
XGs BCR523 Sie N SOT23 npn dtr 50V 0.5A 1k0 +10k% u# w& G/ T) ]2 u+ k
XH BZX284-B15 Phi I SOD110 0.4W zener 15V E24 ±2%
; j- V1 n9 y& a6 NXH MMSD701 Mot I SOD123 MMBD701
' [. ^0 o6 F. D/ J- ^- q ?/ wXHs BCR573 Sie N SOT23 pnp dtr 50V 0.5A 1k0 +10k
$ S; Q- O5 c0 [' z \, UXI BZX284-B16 Phi I SOD110 0.4W zener 16V E24 ±2% ; | \$ t# E' T, V6 S6 l0 h" e
XJ BZX284-B18 Phi I SOD110 0.4W zener 18V E24 ±2% / U5 a! e2 y/ U/ b
XK BZX284-B20 Phi I SOD110 0.4W zener 20V E24 ±2% 1 F4 d6 {1 Y+ R. Y' D9 w' f
XKs BCR519 Sie N SOT23 npn dtr 50V 0.5A R1 4k7& @' ~8 b+ g; Z) h/ U
XL BZX284-B22 Phi I SOD110 0.4W zener 22V E24 ±2%
n8 |: q$ s# }/ P" oXL BZX99-C2V4 Phi C SOT23 2.4V 0.3W zener 3 Z! J' Y* z6 D# @& E
XLs BCR569 Sie N SOT23 pnp dtr 50V 0.5A R1 4k7( D5 u# [# C( C( f( `. M# P5 X( Z
XM BZX284-B24 Phi I SOD110 0.4W zener 24V E24 ±2% $ w# R5 v/ R# }$ ^- s# u- R
XM BZX99-C2V7 Phi C SOT23 2.7V 0.3W zener
5 r, g8 z w/ z6 @8 i( EXMs BCR583 Sie N SOT23 pnp dtr 50V 0.5A 10k +10k* F; e9 l6 u$ C1 m- n9 R
XN BZX284-B27 Phi I SOD110 0.4W zener 27V E24 ±2% ' Q8 B$ G6 q) r
XN BZX99-C3V0 Phi C SOT23 3.0V 0.3W zener * u( z# t2 P* S
XO BZX284-B30 Phi I SOD110 0.4W zener 30V E24 ±2% 2 Q6 i' K4 S j! F6 G7 K
XP MMBD3000 Mot C SOT346 Si diode 30V 0.2A
5 x. D! [7 y8 A( X% r& u {9 c; YXP BZX284-B33 Phi I SOD110 0.4W zener 33V E24 ±2% " ~1 y8 G# U9 O
XP BZX99-C3V3 Phi C SOT23 3.3V 0.3W zener " L- K9 H* B# {! M! }8 s2 [
XQ MMBD3005 Mot A SOT346 dual ca MMBD3000 j" U& q, D# Q4 E6 A
XQ BZX284-B36 Phi I SOD110 0.4W zener 36V E24 ±2%
) G. D( u/ D) k% m; p f- xXQ 2PD602AQ Phi N SOT346 gp npn hfe 85-170 i; V) s a. l' N, b: i
XR BZX284-B39 Phi I SOD110 0.4W zener 39V E24 ±2% 5 S: m$ `& v c; @. F
XR BZX99-C3V6 Phi C SOT23 3.6V 0.3W zener 9 P; R7 ~5 k3 i6 I3 a8 R6 c
XR MRF2947RA Mot DH SOT363 dual MRF941 npn RF 9GHz; A) B) ]3 d6 |" D% T
XR 2PD602AR Phi N SOT346 gp npn hfe 120-2403 J5 V- Q+ a- i2 E9 e, L6 x
XS MMBD3010 Mot B SOT346 dual cc MMBD3000
7 B# A, r7 |6 Z0 o, t3 ZXS BZX284-B43 Phi I SOD110 0.4W zener 43V E24 ±2%
) l% K% ]$ `, o7 a' [$ z6 GXS BZX99-C3V9 Phi C SOT23 3.9V 0.3W zener
$ V% @2 \' N7 J+ ~! dXS 2PD602AS Phi N SOT346 gp npn hfe 170-340' {& ^. N( {/ |
XT BZX284-B47 Phi I SOD110 0.4W zener 47V E24 ±2% 7 u a% p+ ]- L; W' E$ b1 |8 x
XT MMSD301 Mot I SOD123 MBD301
. i& ^& Z, t7 t k; [3 d' `XT BZX99-C4V3 Phi C SOT23 4.3V 0.3W zener* _& a/ _4 N0 C. c4 }1 C$ L" A
XU BZX284-B51 Phi I SOD110 0.4W zener 51V E24 ±2%
, j1 V" k3 B) }XU MRF2947RA Mot DH - dual MRF941 npn RF 9GHz+ ?+ Z2 O* @6 I! N) I: L6 \" h
XU BZX99-C7V5 Phi C SOT23 7.5V 0.3W zener
, n- L) X& X+ T0 b* p: Y, nXUs BCR562 Sie N SOT23 pnp dtr 50V 0.5A 4k7+ 4k7$ J- f: [& v" j$ ^% Z1 [
XV BZX284-B56 Phi I SOD110 0.4W zener 56V E24 ±2%
, p& U) @1 v; I: x2 lXV BZX99-C8V2 Phi C SOT23 8.2V 0.3W zener 8 `" \8 S7 [. M/ ]
XVs BCR521 Sie N SOT23 npn dtr 50V 0.5A 1k0 +1k00 R# H5 P, Q% S: u4 r
XW BZX284-B62 Phi I SOD110 0.4W zener 62V E24 ±2%
: O' `1 K: A0 OXW BZX99-C9V1 Phi C SOT23 9.1V 0.3W zener
& w8 u3 h/ P% ^/ c4 w/ e% n9 qXWs BCR505 Sie N SOT23 npn dtr 50V 0.5A 2k2 +10k Y+ Y4 S9 |, s% O1 n$ A
XX BZX284-B68 Phi I SOD110 0.4W zener 68V E24 ±2%
1 ?( i6 i7 Z1 N P/ h0 M' yXX BZX99-C10 Phi C SOT23 10V 0.3W zener 0 [/ |. o, a8 V. M4 ^" w
XXs BCR571 Sie N SOT23 pnp dtr 50V 0.5A 1k0 +1k0
* B2 T! \0 F) l$ G% LXY BZX99-C11 Phi C SOT23 11V 0.3W zener
$ c2 @% }/ v% t' s" n& R" ?XY BZX284-B75 Phi I SOD110 0.4W zener 75V E24 ±2% $ g, W1 [5 N6 a0 E3 e' q
XZ BZX99-C12 Phi C SOT23 12V 0.3W zener 3 s4 J* {2 c3 P1 \: f
Y0s CGY121B Sie - - GaAs MMIC) y( e& [& Q4 e* T9 Q4 J/ M
Y1 BZX84-C11 Phi C SOT23 0.3W zener 11V±5%- ^$ d" |7 N4 s- u- P0 [8 Y
Y1 BZV49C11 Zet O SOT89 1W zener 11V ±5%. e; ^4 ~9 ?, Q3 i6 i6 ~
Y10 BZX84-C27 Phi C SOT23 0.3W zener 27V±5%
4 v% g& F( o" n4 gY11 BZX84-C30 Phi C SOT23 0.3W zener 30V±5%4 L& i* t# a9 h# t: n. y0 e) x
Y12 BZX84-C33 Phi C SOT23 0.3W zener 33V±5%
& b! g. L, S H# fY13 BZX84-C36 Phi C SOT23 0.3W zener 36V±5%
4 o# y& w: q; s) `5 ~Y14 BZX84-C39 Phi C SOT23 0.3W zener 39V±5%
, ?; v. \' ?' b O3 b" i% mY15 BZX84-C43 Phi C SOT23 0.3W zener 43V±5%
1 i8 u2 a+ X( B" qY16 BZX84-C47 Phi C SOT23 0.3W zener 47V±5%
7 @9 V* K. K& T# u3 P1 IY17 BZX84-C51 Phi C SOT23 0.3W zener 51V±5%; e% H+ K( P; B4 `
Y18 BZX84-C56 Phi C SOT23 0.3W zener 56V±5%( A: i2 ?& g5 x& q. u# \" p
Y19 BZX84-C62 Phi C SOT23 0.3W zener 62V±5%! b: K3 S7 O. g0 D* ~7 r B0 ~
Y1p BZX84-C11 Phi C SOT23 0.3W zener 11V±5%8 P! n6 l, P, I0 e/ L
Y2 CLY2 Sie DR MW6 3GHz GaAsfet 0.25W 3GHz
; t' i w" V) \+ X' [Y2 BZX84-C12 Phi C SOT23 0.3W zener 12V±5%
% U, {. N+ C3 }Y20 BZX84-C68 Phi C SOT23 0.3W zener 68V±5%
, J. G2 ?% _7 ?Y21 BZX84-C75 Phi C SOT23 0.3W zener 75V±5%
! c3 Q4 I% N. M. BY3 BZX84-C13 Phi C SOT23 0.3W zener 13V±5%
3 ]5 K3 p+ O3 r; d+ tY36 BZX84-C13V6 Phi C SOT23 0.3W zener 13.6V±5%; R: f+ i% z) A3 O/ r; J4 {' {
Y4 BZX84-C15 Phi C SOT23 0.3W zener 15V±5%/ B8 V8 N& D2 a% ?' Z
Y4 BZV49C15 Zet O SOT89 1W zener 15V ±5%
8 P6 c0 `3 G9 l) y" Q0 D ?% c3 uY5 BZX84-C16 Phi C SOT23 0.3W zener 16V±5%" T- {* _' @# O5 n# z
Y5 BZV49C16 Zet O SOT89 1W zener 16V ±5%
: Z. {3 M5 z' X* p! IY50 BZX84-A2V4 Phi C SOT23 0.3W zener 2.4V ±1%
. T. [8 F2 O3 _: R" _Y51 BZX84-A2V7 Phi C SOT23 0.3W zener 2.7V ±1%/ t9 r: V: ~* c: e/ K0 e( ~+ f3 g4 L
Y52 BZX84-A3V0 Phi C SOT23 0.3W zener 3.0V ±1%
3 n1 l! k* m) S- PY53 BZX84-A3V3 Phi C SOT23 0.3W zener 3.3V ±1%
. m0 ~: ]. p; R K z/ HY54 BZX84-A3V6 Phi C SOT23 0.3W zener 3.6V ±1%
, O% }9 N" q/ n; K$ X2 FY55 BZX84-A3V9 Phi C SOT23 0.3W zener 3.9V ±1%
+ B8 @3 B9 x6 K( _# A l: cY56 BZX84-A4V3 Phi C SOT23 0.3W zener 4.3V ±1%! A, N! T, Q& I) M b
Y57 BZX84-A4V7 Phi C SOT23 0.3W zener 4.7V ±1%; _! I* H/ Q4 e) D1 {* N
Y58 BZX84-A5V1 Phi C SOT23 0.3W zener 5.1V ±1%3 ^. m) ~" i/ ^( w* e$ N
Y59 BZX84-A5V6 Phi C SOT23 0.3W zener 5.6V ±1%7 y \' u! w- t9 K2 T7 |* A' I
Y5s CGY59 Sie DS SOT363 GaAs 0.9/1.8GHz preamp
% ]: [$ f! F5 M# x6 I: N% tY6 BZX84-C18 Phi C SOT23 0.3W zener 18V±5%: F$ T9 `! c2 o9 L
Y60 BZX84-A6V2 Phi C SOT23 0.3W zener 6.2V ±1%! p( l+ ]9 T& _
Y61 BZX84-A6V8 Phi C SOT23 0.3W zener 6.8V ±1%4 }3 g9 V# z T/ i* W
Y62 BZX84-A7V5 Phi C SOT23 0.3W zener 7.5V ±1%
2 e& P# E1 S* B- P( ~( V4 O9 [Y63 BZX84-A8V2 Phi C SOT23 0.3W zener 8.2V ±1%
* d: Q; \6 F n4 n/ j) y/ XY64 BZX84-A9V1 Phi C SOT23 0.3W zener 9.1V ±1%
- W! [# ~9 J& l% k1 f- sY65 BZX84-A10 Phi C SOT23 0.3W zener 10V ±1%
* n, X! Z2 ^1 [; nY66 BZX84-A11 Phi C SOT23 0.3W zener 11V ±1%2 R% h5 e: Q: _# A2 Z# u
Y67 BZX84-A12 Phi C SOT23 0.3W zener 12V ±1%+ H3 Q" G1 t; N( f, e# t" }
Y68 BZX84-A13 Phi C SOT23 0.3W zener 13V ±1%
7 B; A7 W- ^* e" \% o- ~/ c5 z7 d" wY69 BZX84-A15 Phi C SOT23 0.3W zener 15V ±1%5 w3 P. }6 n+ X" s' c( [3 b* d
Y6s CGY62 Sie DS MW6 GaAs MMIC ?+ J8 B5 c5 V& W
Y7 CGY60 Sie DS MW6 GaAs preamp MMIC 1.8GHz
3 g, y: X3 _8 \' g2 wY7 BZX84-C20 Phi C SOT23 0.3W zener 20V±5%
/ [: L$ b0 K( h! E! ]4 B* L& eY70 BZX84-A16 Phi C SOT23 0.3W zener 16V ±1%
& _4 H4 P3 E- @+ o' Q( P7 w( tY71 BZX84-A18 Phi C SOT23 0.3W zener 18V ±1%, ^1 ^( W6 ^" C S7 n# b
Y72 BZX84-A20 Phi C SOT23 0.3W zener 20V ±1%
1 E- l0 T- Z) T5 LY73 BZX84-A22 Phi C SOT23 0.3W zener 22V ±1%2 _0 s$ k/ r! r, ]! q- J
Y74 BZX84-A24 Phi C SOT23 0.3W zener 24V ±1%
, L- @) |; ~. I9 W gY75 BZX84-A27 Phi C SOT23 0.3W zener 27V ±1%
6 H: R& C! e; F4 X$ G- x! o" BY76 BZX84-A30 Phi C SOT23 0.3W zener 30V ±1%* w$ O! t% c: ?' P6 d0 [
Y77 BZX84-A33 Phi C SOT23 0.3W zener 33V ±1%) B' d" T" p( [# C' F
Y78 BZX84-A36 Phi C SOT23 0.3W zener 36V ±1%* A% i& \2 n8 z5 y" g& }1 p3 F
Y79 BZX84-A39 Phi C SOT23 0.3W zener 39V ±1%
/ R6 u+ g/ J+ v' X$ b) _Y8 CGY120 Sie - MW6 GaAs MMIC 2 W, H |6 q/ q
Y8 BZX84-C22 Phi C SOT23 0.3W zener 22V±5%+ A% T: E, ?& N! T4 [; }. l
Y8 BZV49C22 Zet O SOT89 1W zener 22V ±5%% m9 C. H- P1 ?
Y80 BZX84-A43 Phi C SOT23 0.3W zener 43V ±1%7 n. w/ y6 [: w# q
Y81 BZX84-A47 Phi C SOT23 0.3W zener 47V ±1%8 R: R8 [' `' x2 |) w
Y82 BZX84-A51 Phi C SOT23 0.3W zener 51V ±1%) `, v& W, l& x5 K! R5 p5 Q
Y83 BZX84-A56 Phi C SOT23 0.3W zener 56V ±1%
- x) E" o7 n3 }' y" CY84 BZX84-A62 Phi C SOT23 0.3W zener 62V ±1%
5 A) l" ~5 m- W$ H( N- aY85 BZX84-A68 Phi C SOT23 0.3W zener 68V ±1%
5 C, R; V& R9 @3 c* }5 mY86 BZX84-A75 Phi C SOT23 0.3W zener 75V ±1%' v% t' f. L7 l3 L) P
Y9 BZX84-C24 Phi C SOT23 0.3W zener 24V±5%' J: U- b8 H2 c( M; \3 M: t
Y9 BZV49C24 Zet O SOT89 1W zener 124V ±5%! i7 _9 V8 ]3 R/ s/ g9 k" q
Y9s CGY121A Sie - MW6 GaAs MMIC
3 k! m' ^/ T. y6 o T- f' WYBs BSS84 Inf M SOT23 p-ch mosfet 50V 0.13A% L/ L- V* E; J4 l1 Z
YO BZX284-C2V4 Phi I SOD110 0.4W zener 2.4V E12 ±5%
0 m3 v9 l9 Y0 r' ~+ nYP BZX284-C2V7 Phi I SOD110 0.4W zener 2.7V E12 ±5%
T4 `# n; |# {+ oYQ BZX284-C3V0 Phi I SOD110 0.4W zener 3.0V E12 ±5%
) R X6 ^( ]1 o0 b- J5 KYR MSD601R Mot N SOT346 npn gp 25V
2 n+ |& o) `2 G/ P, yYR BZX284-C3V3 Phi I SOD110 0.4W zener 3.3V E12 ±5%
* X+ Y3 W/ r8 y' ]& cYS MSD601S Mot N SOT346 npn gp 25V
5 |2 M2 m8 h$ k, G+ vYS BZX284-C3V6 Phi I SOD110 0.4W zener 3.6V E12 ±5%
~$ U# }: j( S/ H3 @YT BZX284-C3V9 Phi I SOD110 0.4W zener 3.9V E12 ±5%
/ V- Q$ F5 Z+ _1 bYU BZX284-C4V3 Phi I SOD110 0.4W zener 4.3V E12 ±5% $ t$ i* t5 U5 d3 M( b* q& G
YV BZX284-C4V7 Phi I SOD110 0.4W zener 4.7V E12 ±5% 7 l/ U" |9 n3 [
YW BZX284-C5V1 Phi I SOD110 0.4W zener 5.1V E12 ±5%
: t) n, N" h, |# B7 {YX BZX284-C5V6 Phi I SOD110 0.4W zener 5.6V E12 ±5% + v ^& a0 J3 h6 J; h( U# B) u
YY BZX284-C6V2 Phi I SOD110 0.4W zener 6.2V E12 ±5% ; j( i! N' Z! ], i1 h
YZ BZX284-C6V8 Phi I SOD110 0.4W zener 6.8V E12 ±5%
- q! Q0 [* r) \$ j( k: ?8 SZ0 SST310 Tem F SOT23 J310 n-ch jfet2 `+ e7 | C o' P. z
Z0 PDZ2.4B Phi I SOD323 2.4V 0.4W zener
1 C$ G& e( T0 ^; r8 z( t0 [7 wZ08 SST308 Sil F SOT23 J308 n-ch jfet- W' D1 h$ o/ H8 o5 a
Z09 SST309 Sil F SOT23 J309 n-ch jfet+ f: C) i2 t8 g+ x) O
Z1 BZX84-C4V7 Phi C SOT23 0.3W zener 4.7V- K1 E3 `5 q, O, Y/ \, X% Y( g
Z1 SSTJ211 Sil F SOT23 J211 n-ch jfet$ a/ y0 w p* N Q$ l
Z1 PDZ2.7B Phi I SOD323 2.7V 0.4W zener & v# G! s; F) {
Z1 IMZ1A Roh DE - "2SC2414 npn,2SA1037AK pnp"" @' q3 v! R' L7 _6 {2 Q
Z1 BZV49C4V7 Zet O SOT89 1W ±5% zener 4.7V1 I0 p5 m( o% @( O2 ^% Z
Z1 BZV49C10 Zet O SOT89 1W ±5% zener 10V
" @! d4 U7 ^; K: IZ10 SST310 Sil F SOT23 J310 n-ch jfet
3 w1 C& H3 _; XZ10 SST310 Sil F SOT23 J310 n-ch jfet5 @, [: ~' B0 h8 \
Z11 BZX84-C2V4 Phi C SOT23 0.3W zener 2.4V ±5%, M$ _5 P: a1 P& E; M
Z12 BZX84-C2V7 Phi C SOT23 0.3W zener 2.7V ±5%6 ?+ X" p( W6 U v
Z13 BZX84-C3V0 Phi C SOT23 0.3W zener 3.0V ±5%. ^' R+ v, D/ S$ F$ o- j# u+ o
Z14 BZX84-C3V3 Phi C SOT23 0.3W zener 3.3V ±5%7 L2 r1 r( K0 @7 j' q, {, c
Z15 BZX84-C3V6 Phi C SOT23 0.3W zener 3.6V ±5%
) | n& X$ c! Z% H7 yZ16 BZX84-C3V9 Phi C SOT23 0.3W zener 3.9V ±5%8 R8 K. U/ b. Z2 A$ H( ^
Z17 BZX84-C4V3 Phi C SOT23 0.3W zener 4.3V ±5%
) D( u0 [5 {8 PZ2 BZX84-C5V1 Phi C SOT23 0.3W zener 4.7V2 A/ b( ?! X5 z. u1 s
Z2 SSTJ212 Sil F SOT23 J212 n-ch jfet6 Q7 s9 I! H b, G$ {; t( H
Z2 IMZ2A Roh DF - "2SC2414 npn,2SA1037AK pnp": j8 d% d3 l. l' ~/ w+ u) S; L
Z2 PDZ3.0B Phi I SOD323 3.0V 0.4W zener8 L7 U4 M+ F3 A
Z2 BZV49C5V1 Zet O SOT89 1W ±5% zener 5.1V
9 O& g/ a5 ?$ {* ^Z21 DTC113ZE Rho N EMT3 npn dtr 1k0 + 10k 50V 100mA7 ]* K0 r, O3 U8 h" M. k
Z21 DTC113ZUA Rho N SC70 npn dtr 1k0 + 10k 50V 100mA
& `0 B& W; q: ~0 {Z21 DTC113ZKA Rho N SC59 npn dtr 1k0 + 10k 50V 100mA( W) K5 F- d( D- d; w* ` j
Z2U FMMTA63 Zet N SOT23 MPSA63
3 O3 O, P4 u3 Y/ kZ2V FMMTA64 Zet N SOT23 MPSA64" V2 U" @8 s* g! \5 |
Z3 BZX84-C5V6 Phi C SOT23 0.3W zener 5.6V
2 ^3 o F+ @( k4 s1 A6 }6 {Z3 PDZ3.3B Phi I SOD323 3.3V 0.4W zener
p$ D/ C" C" o- p1 v' R0 FZ3 2SK1078 Tos T SOT89 n-ch mosfet 60V 0.8A
8 [% V# [5 s; ?; r( E1 z$ J4 h( q1 xZ3 BZV49C5V6 Zet O SOT89 1W ±5% zener 5.6V
* ^4 F! z7 O! tZ4 BZX84-C6V2 Phi C SOT23 0.3W zener 6.2V; O6 V8 h ~7 s9 q: {6 Z% d
Z4 PDZ3.6B Phi I SOD323 3.6V 0.4W zener ! j2 |3 {3 m4 g: t$ [2 f- E
Z4 2SK1079 Tos T SOT89 n-ch mosfet 100V 0.6A
$ @* P% q, o! s1 L5 lZ4 BZV49C6V2 Zet O SOT89 1W ±5% zener 6.2V
$ _7 Y! Q( u% @' B# ~Z5 BZX84-C6V8 Phi C SOT23 0.3W zener 6.8V2 n( c; o' e6 s9 Z
Z5 PDZ3.9B Phi I SOD323 3.9V 0.4W zener
, I( J" A* f nZ5 2SK1717 Tos T SOT89 n-ch mosfet 60V 2A7 o% Q" t- g6 P4 R
Z5 BZV49C6V8 Zet O SOT89 1W ±5% zener 6.8V
; K# [+ n3 ?3 h2 w* d) Q( R$ J8 fZ50 BZX84-B2V4 Phi C SOT23 0.3W zener 2.4V ±2%
+ e& v7 x _1 ?7 T* j+ W1 d# vZ51 BZX84-B2V7 Phi C SOT23 0.3W zener 2.7V ±2%
5 q4 p2 }+ {/ `' t/ tZ52 BZX84-B3V0 Phi C SOT23 0.3W zener 3.0V ±2%
# b5 B8 u1 e+ @6 S; EZ53 BZX84-B3V3 Phi C SOT23 0.3W zener 3.3V ±2%- I+ K4 n: k @( @: F% J
Z54 BZX84-B3V6 Phi C SOT23 0.3W zener 3.6V ±2%
. M A% J' @ ?7 I7 SZ55 BZX84-B3V9 Phi C SOT23 0.3W zener 3.9V ±2%
9 J, g+ {+ E! [0 iZ56 BZX84-B4V3 Phi C SOT23 0.3W zener 4.3V ±2%
4 p+ G1 l8 y& p v& T2 z2 K0 qZ57 BZX84-B4V7 Phi C SOT23 0.3W zener 4.7V ±2%9 E+ w9 }$ y/ d; m
Z58 BZX84-B5V1 Phi C SOT23 0.3W zener 5.1V ±2%4 V( v6 A4 S+ ?) W9 j9 ~
Z59 BZX84-B5V6 Phi C SOT23 0.3W zener 5.6V ±2%% T* p/ l0 M1 K( _7 z
Z6 BZX84-C7V5 Phi C SOT23 0.3W zener 7.5V7 a$ Q, ^. X$ G! E! u' f; M0 @( t
Z6 PDZ4.3B Phi I SOD323 4.3V 0.4W zener
9 N) \! P; V6 s$ O. {) r" Y1 n% ZZ6 2SJ238 Tos T SOT89 p-ch mosfet 60V 1A
' x/ ?5 [9 B4 B8 {1 S- LZ6 BZV49C7V5 Zet O SOT89 1W ±5% zener 7.5V
6 v9 H0 J: |! P: oZ60 BZX84-B6V2 Phi C SOT23 0.3W zener 6.2V ±2%) z) a9 Q# G: _5 j
Z61 BZX84-B6V8 Phi C SOT23 0.3W zener 6.8V ±2%
. R( p* _6 k# P$ n; }) xZ62 BZX84-B7V5 Phi C SOT23 0.3W zener 7.5V ±2%& p5 l9 ?) a5 G6 N
Z63 BZX84-B8V2 Phi C SOT23 0.3W zener 8.2V ±2% N+ [0 c3 {+ o% _) j/ |
Z64 BZX84-B9V1 Phi C SOT23 0.3W zener 9.1V ±2%
6 i5 l5 a& P* [6 g' K4 iZ65 BZX84-B10 Phi C SOT23 0.3W zener 10V ±2%
- U K- g( c Z c& CZ66 BZX84-B11 Phi C SOT23 0.3W zener 11V ±2%
2 ]% n9 H i' h2 n0 a2 PZ67 BZX84-B12 Phi C SOT23 0.3W zener 12V ±2%& w+ v E! @: o' c- E1 I
Z68 BZX84-B13 Phi C SOT23 0.3W zener 13V ±2%
8 T% }+ t; C4 @* pZ69 BZX84-B15 Phi C SOT23 0.3W zener 15V ±2%
& x9 v$ {) O5 U# eZ7 BZX84-C8V2 Phi C SOT23 0.3W zener 8.2V: E$ L# W( B! q4 d
Z7 PDZ4.7B Phi I SOD323 4.7V 0.4W zener 0 O% H' K$ j% u" r. A
Z7 BZV49C8V2 Zet O SOT89 1W ±5% zener 8.2V
# r; O) S+ {- w+ Y3 b9 A( oZ70 BZX84-B16 Phi C SOT23 0.3W zener 16V ±2%
0 G- ] t# U% kZ71 BZX84-B18 Phi C SOT23 0.3W zener 18V ±2%$ k- a; e, c8 o4 o) _) s( u
Z72 BZX84-B20 Phi C SOT23 0.3W zener 20V ±2%
2 {# H& [' I+ B( n7 W6 ?Z73 BZX84-B22 Phi C SOT23 0.3W zener 22V ±2%. P- t1 Z+ f. p' l3 S" ]- A
Z74 BZX84-B24 Phi C SOT23 0.3W zener 24V ±2%
# D$ e4 x( Q7 r( R2 ?Z75 BZX84-B27 Phi C SOT23 0.3W zener 27V ±2%
8 y! L, ?- Y b8 u$ fZ76 BZX84-B30 Phi C SOT23 0.3W zener 30V ±2%
% c3 Z0 D2 Q! P% NZ77 BZX84-B33 Phi C SOT23 0.3W zener 33V ±2%
+ y1 P u5 `0 ]Z78 BZX84-B36 Phi C SOT23 0.3W zener 36V ±2%
; q; c& \5 j0 Q: yZ79 BZX84-B39 Phi C SOT23 0.3W zener 39V ±2%% N2 D% X5 K* D
Z8 BZX84-C9V1 Phi C SOT23 0.3W zener 9.1V
/ L7 }& H* ~1 U# N {Z8 PDZ5.1B Phi I SOD323 5.1V 0.4W zener
* V6 v4 |) H$ o+ RZ8 BZV49C9V1 Zet O SOT89 1W ±5% zener 9.1V
+ h: m# l2 `, Z* \# C5 R/ q- kZ80 BZX84-B43 Phi C SOT23 0.3W zener 43V ±2%; h0 \; g+ p* b) @6 C- q4 V9 R
Z81 BZX84-B47 Phi C SOT23 0.3W zener 47V ±2%' q% d/ q4 x9 }9 Z2 J' W' e. Z
Z82 BZX84-B51 Phi C SOT23 0.3W zener 51V ±2%7 p1 n* p& W3 J* B
Z83 BZX84-B56 Phi C SOT23 0.3W zener 56V ±2%
4 E( S! _1 a4 O7 o8 q% a" o9 qZ84 BZX84-B62 Phi C SOT23 0.3W zener 62V ±2%8 X, O' @, ?( ]; _+ x9 k: B
Z85 BZX84-B68 Phi C SOT23 0.3W zener 68V ±2%
( L3 q/ x: u+ KZ86 BZX84-B75 Phi C SOT23 0.3W zener 75V ±2%
0 q+ W( l- [: k% r$ Y0 l8 lZ9 BZX84-C10 Phi C SOT23 0.3W zener 10V
0 t9 }) x0 d6 W0 Z" bZ9 PDZ5.6B Phi I SOD323 5.6V 0.4W zener ) p. j; _5 y0 P/ w% V
ZA BZX284-C7V5 Phi I SOD110 0.4W zener 7.5V ±5% 4 o0 S% Z' a2 W. Q4 r
ZA PDZ6.2B Phi I SOD323 6.2V 0.4W zener
$ H3 d9 u) {8 X) f1 |( r( kZB FMMT4123 Zet N SOT23 2N4123/ l# w+ M7 I/ ?5 h- T. ~2 e$ k, @
ZB PDZ6.8B Phi I SOD323 6.8V 0.4W zener
0 F% e1 R; P& K+ `& d# `ZB BZX284-C8V2 Phi I SOD110 0.4W zener 8.2V ±5% Z2 } y; y: `* F/ W' ^/ a+ u
ZC FMMT4124 Zet N SOT23 2N4124) y( {/ e. n, A- Y, _
ZC BZX284-C9V1 Phi I SOD110 0.4W zener 9.1V ±5% s0 }- F B7 i0 U
ZC PDZ7.5B Phi I SOD323 7.5V 0.4W zener
& I. f6 z$ L ?ZD FMMT4125 Zet N SOT23 2N4125
4 e3 G$ p7 ^$ c: `# c$ V/ @ZD MMBT4125 Mot N SOT23 2N41256 B1 i/ j' ^+ u. f4 Y# _2 J, X
ZD BZX284-C10 Phi I SOD110 0.4W zener 10V ±5%
, W) G! L& y) K4 VZD PDZ8.2B Phi I SOD323 8.2V 0.4W zener " H \7 T* m" d3 |
ZE FMMT4126 Zet N SOT23 2N4126
# Y6 f7 w, x+ kZE MMBT4123 Nat N SOT23 2N4123/ o6 Y+ y) t$ C* Y) T* S7 M5 \
ZE BZX284-C11 Phi I SOD110 0.4W zener 11V ±5% $ V+ T& ~1 t- a, r1 l) U" I
ZE PDZ9.1B Phi I SOD323 9.1V 0.4W zener
8 l+ Y9 h0 e( e3 ?5 y# GZF BZX284-C12 Phi I SOD110 0.4W zener 12V ±5%
. p9 N9 ]3 V0 e# }/ j& y/ k! |ZF PDZ10B Phi I SOD323 10V 0.4W zener
" d7 M2 b' k6 K! k5 H& B7 XZG BZX284-C13 Phi I SOD110 0.4W zener 13V ±5%
$ K" H, a# l7 ?- l6 w- G3 LZG PDZ11B Phi I SOD323 11V 0.4W zener / J' u! w) P; A/ Y/ n1 o# ]; g
ZH BZX284-C15 Phi I SOD110 0.4W zener 15V ±5%
3 Y0 n' a% W; N- v' `ZH PDZ12B Phi I SOD323 12V 0.4W zener 9 r+ \' I; [) j- V8 |& F) @6 M
ZHK SM2Z5V1 STM I 2W SMD 5.1V 2W zener
7 M* _' c, Z4 `( G5 ^7 f/ a, O6 LZHL SM2Z5V6 STM I 2W SMD 5.6V 2W zener
0 g! L( G j* Z/ v; R! DZHW SM2Z12 STM I 2W SMD 12V 2W zener
! r! D4 Q, Z' i* p2 ?ZI BZX284-C16 Phi I SOD110 0.4W zener 16V ±5%& T! W' T* P. A3 h* q
ZJ BZX284-C18 Phi I SOD110 0.4W zener 18V ±5%
6 N) z, A/ ?2 u' W6 A8 r7 OZJ PDZ13B Phi I SOD323 13V 0.4W zener ' `# L3 R9 c& a9 s* G2 D' A
ZJF SM2Z18 STM I 2W SMD 18V 2W zener
' N$ X: ~/ l6 sZJQ SM2Z30 STM I 2W SMD 30V 2W zener
{2 R5 Q, J5 f/ K3 H& f8 G6 EZK BZX284-C20 Phi I SOD110 0.4W zener 20V ±5% : N: G3 _) x& t9 F9 R
ZK PDZ15B Phi I SOD323 15V 0.4W zener
# t% Z( ?/ J- U8 x- [# V! i5 P4 VZKR SM2Z150 STM I 2W SMD 150V 2W zener ; {9 f" x2 ^' p0 x+ I
ZL BZX284-C22 Phi I SOD110 0.4W zener 22V ±5%
( T- N: E2 [) @3 PZL PDZ16B Phi I SOD323 16V 0.4W zener
) Z3 n! }3 _2 { k: x; lZM BZX284-C24 Phi I SOD110 0.4W zener 24V ±5%
/ W. P" u. l! |8 jZM PDZ18B Phi I SOD323 18V 0.4W zener 6 g) L# Q Y- Y7 b% O( w
ZN BZX284-C27 Phi I SOD110 0.4W zener 27V ±5%
. e1 O$ V5 N+ b: k( ]- m* U( CZN PDZ20B Phi I SOD323 20V 0.4W zener
G) {3 ?3 N. E" w" C8 k" nZO BZX284-C30 Phi I SOD110 0.4W zener 30V ±5%
9 J5 c9 N- u) h+ J- t; }' Z) w* zZP BZX284-C33 Phi I SOD100 0.4W zener 33V ±5%
+ S) t" f' t7 ], V5 P7 WZP PDZ22B Phi I SOD323 22V 0.4W zener 9 l4 N) [ R0 |* e3 R% `; [
ZQ BZX284-C36 Phi I SOD110 0.4W zener 36V ±5%3 R# C ^. t& I+ M
ZQ PDZ24B Phi I SOD323 24V 0.4W zener
6 Y+ G. t7 ]) J% u; ?, |6 ^3 k- tZ-Q 2PC4081Q Phi N SOT323 gp npn hfe 120-2708 C; I* N" k; e- b8 I
ZR MSD1819A Mot N SOT323 npn gp 50V4 o4 ?, U8 ~6 ]+ A; m5 C
ZR BZX284-C39 Phi I SOD110 0.4W zener 39V ±5%. M, k+ v/ I6 f5 J6 e- [- p5 l7 x5 w
ZR PDZ27B Phi I SOD323 27V 0.4W zener1 t# Q* U4 c" q" |- z
Z-R 2PC4081R Phi N SOT323 gp npn hfe 180-390& E- Q* v; U" \3 _
ZS BZX284-C43 Phi I SOD110 0.4W zener 43V ±5%
. v W" P8 A' k7 o) lZS PDZ30B Phi I SOD323 30V 0.4W zener 3 J Q4 w$ \' x; r* E- K' p
Z-S 2PC4081S Phi N SOT323 gp npn hfe 270-560
8 x# a. D O6 X( D' ]! lZS1 ZHCS1000 Zet E SOT23 30V 1A schottky diode- _ e' h9 [1 ~* y
ZS1 ZHCS1000 Zet C SOT23 schottky 1A 30V
( n5 f9 n/ i, x9 o! jZS5 ZHCS500 Zet E SOT23 40V 0.5A schottky diode
/ E i L& @2 n3 X+ v+ D8 x% uZS7 ZHCS750 Zet E SOT23 30V 0.75A schottky diode
" @/ b* [( [, i V OZS7 ZHCS750 Zet C SOT23 schottky 0.75A 30V
" z2 t) ]+ x; iZT BZX284-C47 Phi I SOD110 0.4W zener 47V ±5% ( a4 m) G" I/ g/ l7 p; q
ZT PDZ33B Phi I SOD323 33V 0.4W zener $ ?- Q8 l3 T$ n, H* i) j
ZtQ 2PC4081Q Phi N SOT323 gp npn hfe 120-270
; z! ~* n" M8 V" `ZtR 2PC4081R Phi N SOT323 gp npn hfe 180-390" f! X3 D1 I9 L6 ~
ZtS 2PC4081S Phi N SOT323 gp npn hfe 270-560
2 ~% Q7 k! H, v2 F. h3 Z3 OZU BZX284-C51 Phi I SOD110 0.4W zener 51V ±5% 9 H1 K9 W: j; B- O, r
ZU PDZ36B Phi I SOD323 36V 0.4W zener o& J! ?& r: m4 ~1 h
ZV BZX284-C56 Phi I SOD110 0.4W zener 56V ±5%
9 x6 W. U- w4 A" L; MZW BZX284-C62 Phi I SOD110 0.4W zener 62V ±5%
8 i, h+ V; O3 T- ]4 j6 gZX BZX284-C68 Phi I SOD110 0.4W zener 68V ±5%
: _* S9 C* ~0 }2 e* X5 j8 HZY BZX284-C75 Phi I SOD110 0.4W zener 75V ±5% |
