本帖最后由 cplanxy 于 2018-4-29 08:50 编辑 9 p/ A) @! C+ p, M
, t2 U* V/ B. t v; K警告如下所示(我已红色高亮),请问哪位大侠有遇到过,如何解决,是否可以不care,谢谢!
) U; r. K- U1 E9 }3 k/ O
# t: H& }. C9 Q9 x" p4 C6 c================================================================. r( X5 [# T: v1 J; Y+ ` W
PROCESSING FILM < TOP >* P7 _% @, R4 @; q* n: M* M0 b
TO FILE < E:/TEMP/0428/SL2801_FPGA_SUB_V1_0/TOP.art > ...6 d0 j, s; n1 w
f6 l( u4 M" g5 @0 u2 m+ a+ e( h7 d5 A3 t: g; G
FILM PARAMETERS :
+ @# q, [# ?0 ~: Z- Q: P" W( ~* ]7 ^0 ^ ---------------------------------------------------------
1 y$ R$ g" u7 f0 f/ n- x4 @7 x( n" P Undefined line width 6.0
& r+ ^: ~$ Z8 T Mirror code NONE
( ~) w" Q% m0 L8 z3 O1 x" _# @ Rotate angle NONE
3 a* m; S; x; b Offset x: 0.0
* V5 |% }' }" b. I, w# G& n& U Offset y: 0.0
; N3 B' q0 O3 J. h7 z0 V7 [ Plot negative NO
* e9 D5 h% h. c+ m0 n Suppress unconnected internal pads NO
1 d5 x0 T! ? y; K: E Draw holes only NO5 p2 |1 X1 {, m9 Y" k; s4 }! V0 q
5 d1 l# u" j+ s# ~$ @
WARNING: 0 width line found at (150.0 1613.4)' u. t; ~; H3 \* w
... using undefined line width of 6.0
- P5 l3 Z1 B$ Y: o' O {- U; X/ O3 J3 H9 [ \7 T
WARNING: Multiple 0 width lines; all will be treated the same as the first." N" s* F/ w" U5 f
... using undefined line width of 6.0* D! T: j) Z; S0 r: X# h# A
# L( }+ G, h; X f0 y' T. ?
7 @, T3 j0 F; L8 H
7 h0 n/ \2 N' w) W
APERTURES USED:
& q5 m/ w% @/ p ---------------------------------------------------------
4 O; I5 @, s! c9 W5 S' m" e TYPE SIZE/NAME ROT MIRROR MODE 6 a0 v( M9 f, t- l7 K# Z
Q: p7 u/ l" M; ]! _ CIRCLE 0.00400 DARK
1 u# y/ A6 @6 u. q4 q" t CIRCLE 0.00450 DARK % f* r1 b0 u' B! _
CIRCLE 0.00600 DARK
. a6 V1 ?. ^8 L: X4 V5 p5 ]7 D CIRCLE 0.01000 DARK
' Y/ c8 u, u9 J# M CIRCLE 0.01300 DARK / u, I o4 t: p- F# w4 w
CIRCLE 0.01600 DARK G2 t# l9 I+ n) M6 }3 x
CIRCLE 0.02000 DARK c9 ?0 U. [% y Z/ ? S
CIRCLE 0.02800 DARK % C( @7 B7 B+ I
CIRCLE 0.03940 DARK
& V9 |( a0 g6 F1 ~5 k. K CIRCLE 0.04000 DARK 3 c/ u( K% _5 j1 [, N$ J# x7 u/ K
CIRCLE 0.04020 DARK " j3 E' s4 N# c& n8 L ?
CIRCLE 0.04720 DARK 7 F. v7 m% Q4 G1 ]1 H' X
CIRCLE 0.05510 DARK ! N X8 |; T+ M- t6 N
CIRCLE 0.05980 DARK # E2 I) R6 W/ H7 z) c) |$ f1 @* I
CIRCLE 0.06000 DARK % W5 L! x) I: L: K# I, B$ a/ T% X
CIRCLE 0.06300 DARK
5 |5 @+ w' A- T. A0 g6 T# F CIRCLE 0.07870 DARK
0 p l, Q2 T6 T$ ^% S* G3 }0 O) c CIRCLE 0.11810 DARK
% ^1 s: h, ~8 j |' G( y# d CIRCLE 0.25000 DARK
3 q$ w% Y& R; x0 `0 K" | SQUARE 0.06000 0.000 NO DARK
; S9 E6 o S9 s6 }5 h% o SQUARE 0.21260 0.000 NO DARK ' u! k' D5 a+ P q; \4 H
RECTANGLE 0.02600 x 0.02200 0.000 NO DARK
8 d. o% J/ w2 J; D! M: ?; a RECTANGLE 0.02600 x 0.02200 90.000 NO DARK ; C9 {/ ^& P9 L( V! V
RECTANGLE 0.02760 x 0.07870 90.000 NO DARK
4 L/ h, N% ^. }6 s" F5 | RECTANGLE 0.03740 x 0.01770 90.000 NO DARK
: p$ D: P: V' N5 c9 c6 u7 y$ s" m RECTANGLE 0.03940 x 0.03540 0.000 NO DARK
" U9 m8 q5 ^8 m RECTANGLE 0.03940 x 0.03540 90.000 NO DARK ; H4 b* p& z' c( v8 q$ r' P5 c
RECTANGLE 0.03940 x 0.03740 0.000 NO DARK
7 G- L/ ^% I( c+ M6 |4 g RECTANGLE 0.03940 x 0.03740 90.000 NO DARK 9 d+ i: O; x. c! [3 h) k
RECTANGLE 0.04720 x 0.01180 0.000 NO DARK
- D8 `% E& W9 [( j6 m2 Q RECTANGLE 0.04720 x 0.01180 90.000 NO DARK * o& K( t. b w8 A$ L9 U8 D
RECTANGLE 0.04720 x 0.05510 90.000 NO DARK ; j* D1 _5 K6 k6 O7 o
RECTANGLE 0.04720 x 0.08660 90.000 NO DARK 3 g, t. a2 q5 q# j
RECTANGLE 0.06300 x 0.01180 0.000 NO DARK
9 f; S' f$ r2 t# v RECTANGLE 0.07090 x 0.12600 90.000 NO DARK & C9 H/ J+ V) @5 y, ^ H
RECTANGLE 0.07870 x 0.01770 0.000 NO DARK ( o( ^# P3 O+ \1 R. J/ ~9 Q
RECTANGLE 0.07870 x 0.01970 0.000 NO DARK ; A* H9 x: |4 u, {3 u
RECTANGLE 0.07870 x 0.02170 0.000 NO DARK - z! F% g% L! I9 z' G# ?
RECTANGLE 0.07870 x 0.06690 90.000 NO DARK $ K$ d2 m! M6 L& A4 a& l( ]
RECTANGLE 0.14570 x 0.04330 0.000 NO DARK
6 D9 Y3 \' r Y# g# v0 `) _ RECTANGLE 0.14960 x 0.02200 0.000 NO DARK
! j# ]; P! m- q8 D RECTANGLE 0.17990 x 0.09490 90.000 NO DARK
5 b6 c; V7 t% V: ^. i) L; R* b* K RECTANGLE 0.18900 x 0.07090 90.000 NO DARK
) b2 l( z! f- N5 {3 k OBLONG 0.15000 x 0.09020 0.000 NO DARK
) S1 c" G6 D) A( Y3 b OBLONG 0.15000 x 0.09020 90.000 NO DARK ' c: a1 c) a1 M q) I
PAD SHAPE SRX0_85Y1_35R0_10 0.000 NO DARK % }0 p+ P0 T8 B2 }9 i
PAD SHAPE RECTX1_30Y0_325_CORNER0_1 0.000 NO DARK ! w: L2 {+ Z$ w* ^- P
PAD SHAPE RECTX2_30Y0_325_CORNER0_1 90.000 NO DARK
0 B; S# \: |! D2 k& h2 Z7 T PAD SHAPE SRX0_85Y1_35R0_10 90.000 NO DARK
6 W3 {% t% ~8 Y$ s) Q$ _+ u, k PAD SHAPE SRX1_75Y2_40R0_10 90.000 NO DARK
$ N; `2 l4 u2 C8 ~ l' p- h PAD SHAPE SRX1_75Y2_40R0_10 180.000 NO DARK - j& o0 P7 P6 O/ x7 ~
PAD SHAPE SRX1_27Y1_47R0_10 180.000 NO DARK ( _# k- j# O1 M- t
PAD SHAPE RECTX1_30Y0_325_CORNER0_1 180.000 NO DARK
' Y- F! A: }1 y PAD SHAPE RECTX2_30Y0_325_CORNER0_1 270.000 NO DARK
3 |: T' \8 z8 g# z: J3 k
/ w0 |* m; o) B$ a9 x3 ]% ?8 E TOP created with warnings0 K' g- ~# \9 x) w- ~
# H1 Y+ Z7 u% r& x
================================================================( N7 r: h% P# I$ [/ b6 k7 f
PROCESSING FILM < DRILL >6 Z, P' q" m t1 M" J; g
TO FILE < E:/TEMP/0428/SL2801_FPGA_SUB_V1_0/DRILL.art > ...
$ y0 [5 U0 r( a: _================================================================
8 Y* P5 z1 y$ r
* f4 q/ e" L3 X% K) [ FILM PARAMETERS :
1 R2 H& M/ O: X: A- t% u5 N ---------------------------------------------------------
$ ^$ V7 P5 U( K" @$ i- O/ n Undefined line width 6.03 _! g" _, F. o8 W+ [) U8 y/ X7 H+ n7 M
Mirror code NONE
( D: x0 q; q8 f% o2 k& Z- C Rotate angle NONE
* t0 f& u& c9 F5 ]& U2 s( P Offset x: 0.0' |! ]1 p" v# u* j& M% Z D
Offset y: 0.0
# m" j( m9 B0 y* O6 b4 X% D Plot negative NO
. R& y* p7 j) O) L Suppress unconnected internal pads NO3 p; m$ l' ]/ R, R3 ]# n. u! N
Draw holes only NO/ N0 n5 H1 U+ j& S# U, L+ G& n
' S! B. D2 b$ r) K
WARNING: text composed 0 width line found at (7436.5 3937.5)9 i' ?, u) l3 w9 q9 n
: f; W; E( a% H$ @; h1 {' _ ^! o7 [3 \ G8 k' j
WARNING: text having Multiple 0 width lines; all will be treated the same as the first.
9 _* G. n* ~( Y1 M ... using undefined line width of 6.0
* a( X4 x5 {) f3 X7 H
7 q% N( r8 c3 o5 X7 y( f; x8 |+ W2 w; a2 O+ q# _& X/ H
2 a1 s% W3 M9 D7 v8 R& R! L8 {
APERTURES USED:
% S" V9 t; B7 F. v' P S$ c ---------------------------------------------------------) w k4 A7 F( M% x# W
TYPE SIZE/NAME ROT MIRROR MODE 7 M0 u' | K0 Z5 r3 M; L( I0 D
---------------------------------------------------------! c, l. k( @" Y f3 g6 A6 F
CIRCLE 0.00600 DARK
$ R$ l7 B! J. P$ }: o
( Z" b. L& Y9 G' ]5 G) a DRILL created with warnings
1 d b* s/ r, n4 w A( u3 _- K- V3 \+ a0 y8 Z: h; L
- O j( d! T& T7 s
- t1 G r! S l$ S* Y2 `9 T
5 g1 @" [% J& L. P0 B. t; H! Q$ g, y5 P: T$ z8 I6 T' l
