查看: 391|回复: 0
求助————C6670连接仿真器
发表于 2018-4-23 09:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好,我在调试板卡时连不上仿真器,c6670与c6678级联模式,报错如下:1 w7 u9 g% \" V3 o$ P
IcePick_D: Error connecting to the target: (Error -233 @ 0x0) The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 5.0.681.0) 9 A- T' ?4 v! L" Z5 W% d& [
sysout输出正常,用的是wintech xds560v2仿真器,ccs是5.2版本。
9 _+ _; @8 ?2 s谢谢!!: Y5 g' t% |7 [( L/ _" _6 W
GMT+8, 2025-7-13 04:29 , Processed in 0.109375 second(s), 24 queries , Gzip On.
