本帖最后由 超級狗 于 2017-10-5 14:51 编辑 2 S+ A6 C4 _3 T- L/ |; g
8 K/ ^8 w% O' ?2 w# @凱登斯(Cadence)官網有人問類似的問題,官方答覆如下。
! b1 a$ F) @ z- G
- V$ n, Q- {# B/ \ C1 j L* ^, GUnable to place component using ICA" L) k& |1 D' U1 A$ c) l7 e3 M" M
8 t/ f# ]' P, b7 h9 D+ D
If you are still running 16.5, that is no longer a supported version.) h& y+ ~- Q" ]
* _% `4 {. S0 d+ K/ }) `
The ICA capability is at end of life, so access to it may be variable.- z; K( B3 x+ j) Q* @1 u q& A. u2 Y
* I/ c! ^- U: _6 q
You don't have a library named discrete configured through Place > Part, Add Library or [Part Library Directories] section in the Capture.ini file, that contains a graphical symbol named R.
/ Z% O$ s3 W& t* f6 a7 r; u* }' |0 A" k0 @' \
8 y. W9 R8 s# R; k5 ]0 p% B |
