查看: 1273|回复: 3
[Cadence Sigrity] Allegro sigrity PI和Power DC如何关联
发表于 2017-6-16 11:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
如题,求大神给解决一下:! Q  S3 W* x, h7 S) b9 l
关联时有错
关联时有错
发表于 2017-6-16 13:00 | 只看该作者
hi . can you search  file .env on dir .../share\pcb\text . find on line .../ASI/Update2  changes to /ASI/Update4
找不到这行注释  详情 回复 发表于 2017-6-19 17:41
 楼主| 发表于 2017-6-19 17:41 | 只看该作者
hdkh1989 发表于 2017-6-16 13:00
9 }$ ?/ t3 Y: Phi . can you search  file .env on dir .../share\pcb\text . find on line .../ASI/Update2  changes to  ...
3 H0 O. w/ C+ i找不到这行注释
Folder to Go: . / báo cáo này chia sẻ nội dung / PCB / văn bản tìm kiếm và Open File env sử dụng notepad hoặc wordpad Find Row. : SET sigrity_  详情 回复 发表于 2017-7-1 10:57
发表于 2017-7-1 10:57 | 只看该作者
, V0 Z* N( Y1 E. p
牛掰的狂猪 发表于 2017-6-19 17:41
% |& X4 }' Z) q* z找不到这行注释
" @( U( q) `; r8 Mgo to folder : <CDSROOT>/share/pcb/text/env search and open file env use notepad or wordpad . find row : SET sigrity_eda_dir = $ ALLEGRO_INSTALL_ROOT / ASI / Update2  change to SET sigrity_eda_dir = $ ALLEGRO_INSTALL_ROOT / ASI / Update4 . save  and close file . enjoy
: w/ k, R* W* C, J! Z& |! N5 ]! F
GMT+8, 2025-9-30 22:59 , Processed in 0.140625 second(s), 31 queries , Gzip On.
