查看: 3173|回复: 7
[HyperLynx] BRD 文件导入 Hyplynx 的问题
发表于 2017-6-14 17:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
allegro BRD 文件导入 Hyplynx 时,不成功,Log 如下:6 @9 n3 H% j* s! O7 U. |- `
* R' V" L( r1 ~8 R
Job Name         : D:\163& m; N& t- A9 H! r! k
Input File Name  : D:\163.brd& t- `' Q. a* p/ l* S
HYP File Name    : D:\163.hyp6 `3 G$ {* D- B( Z  G- v+ L
REF File Name    : D:\163.ref& S" I. \/ y; k7 f; R6 F
Log File Name    : D:\163.log8 m8 f, k3 [* w) J& J8 ]: X( h
Err File Name    : D:\163.err4 ~3 {8 P8 V# U9 S" S1 o# ~- N* _
Control File     : C:\mentorGraphics\padsVX.1.2\SDD_HOME\hyperlynx\control_hyp.txt8 Z5 I' N7 ?! a% e2 {% c* t- J
info : Extracting Allegro Board Database
8 ?2 a( Q5 [- Z& R& O+ X8 G3 kERROR: Could not run Cadance Allegro utility: extracta.3 a% X4 w! k. X8 ^
ERROR: mode argument is invalid.6 V) |0 }+ O  J
5 T8 g' M+ Y+ V) j8 [0 W
ERROR: Could not convert file 'D:\163.brd'
% _2 T5 x  Q. V# O8 ~6 |       to file '"D:\163.a_b"'.
& @7 X2 c! Q1 [' }* ]9 h  \
+ x0 l, X6 p" t0 L: E7 ~The Allegro-to-HyperLynx translator requires cadence's ASCII-out6 F. }0 |* B! _( J8 g! L
utility, EXTRACTA, as well as the Allegro directory structure.
. Z9 w7 R( U6 }) q/ _+ KThis can be found in any Allegro installation including the 9 c# S1 c( Y* d
Allegro Physical Viewer, which is available from Cadence.
% T4 u. p, a- m: w# e(The free download - Allegro FREE Physical Viewer - will not
3 @! M( I6 |6 h& lwork for this purpose.)6 w' k) ~# M( d9 P
2 I9 P- ^% A5 _; ]. W0 q
HyperLynx Online Help includes instructions for operation of a
& a' I8 {, {# h+ T4 I; OHyperLynx utility that works with Cadence's Extracta, and that can/ O" W+ @9 e6 V5 @, n4 }
be provided to your PCB service bureau.  This application is allegro2hyp;& E4 W9 h8 F4 @! T9 ^
and you can read more on this subject by navigating to 'Cadence Allegro6 X0 E$ E9 d2 _9 ?, E
Translator' topic in the HyperLynx Help system.5 B3 Q# I9 {  _( A6 t
info : Error with extraction8 ]* l* w5 C/ F! K& C  z1 v  B/ h
% Z! c& t4 U9 Z6 ~" z" w8 \2 j+ X求大师指点迷津,感谢
发表于 2017-6-15 23:40 | 只看该作者
allegro 17画的吧
发表于 2017-6-16 15:35 | 只看该作者
添加一个系统变量CDSROOT=C:\Cadence\SPB_17.2
发表于 2017-7-6 14:59 | 只看该作者
同樣問題 已設定系統變量仍無法轉檔
重装的系统  详情 回复 发表于 2017-7-10 14:04
 楼主| 发表于 2017-7-10 14:04 | 只看该作者
Shoumei 发表于 2017-7-6 14:59* B2 Z, b' i' n+ b# K
同樣問題 已設定系統變量仍無法轉檔
' I' i% d4 I+ Z! T1 w
重装的系统; J9 _; i5 R8 L: t
发表于 2017-10-31 10:48 | 只看该作者
楼主现在解决了吗,我遇到了同样的问题,一直没办法解决
发表于 2019-12-18 19:01 | 只看该作者
同问,有解决的吗,求分享。
GMT+8, 2025-9-30 19:27 , Processed in 0.140625 second(s), 24 queries , Gzip On.
