没有看到你12模块具体的情况,不好说。
) |6 t6 `1 T+ U, L" e# [1 o$ e从你的图看,12个模块已经OK啦。其它的可能不符合条件,请参考Help:
4 r2 `. W+ l2 j6 k0 X1 t2 The target components of copy destination must satisfy the following conditions: ( Z4 P# K: b: y7 k" R3 M
; M3 }% c: j: P; A5 @
n An unplaced component or off-board component
3 o# j# S* k/ e, I
2 x! k$ d3 E1 Kn A component having the same part name as that of an original component$ E( z9 @* D+ W
1 P1 }) u* T1 W ?$ x8 @1 A6 B2 L, pn A component having the same pin connection as that of an original component
2 [8 O& j+ ?6 ~2 d2 ]9 e) t' G- A- o: D2 ]; z
n A component without position lock.
& _" W) D9 M3 g/ O' i" r7 S O- [: y. E! g. j# `3 j N& j3 b: L) \3 d
n When a component is locked in angle, its angle is the same as that of the original one. C" H6 ?3 h. K2 a1 s0 {
( B: F0 ]( B7 g6 ~
n When a component is locked in placement, its placement side is the same as that of the original one.0 i* [; f/ k- q
4 D+ Y8 F& [* C. T: ]3 The original figures to be copied must satisfy the following conditions:
" ^$ x# I; z* |; Y
/ x0 d1 d) o8 [n A figure on the layer which is set to visible.$ d: N: O- z1 W
7 W4 x6 f, E& g* v4 O+ \n A figure on the active layer when Reference Active Layer is set to on.
' n# R: l4 G3 C; M& o, X4 O1 v5 D( f: O
n For vias, any layer among from-layer and to-layer of the via is the selected layer.
' N- x0 L o4 j6 F: t6 Z |
