TA的每日心情 | 开心 2022-9-8 15:14 |
签到天数: 12 天 [LV.3]偶尔看看II
L3 E0 t& Q1 G& Q' b/ d/ P# i/ i7 _; z0 ]7 t, F/ c
expedition pcb用着时,电脑死机,然后强制关机,再开机,pcb打不开了,原理图可以正常打开; w* x! K* i, k. N
大家有没有碰到过这个问题
; c5 G- \8 w1 z2 X
* i; p2 v3 Z1 Z9 L' PError: Unable to find padstack 'LVIA-0.1/0.25' for via range 9 to 10.# K! s9 J) M- n' s, Q7 q
Error: Unable to load design (文件路径\工程文件夹名\PCB\Work\Layout_Temp\LayoutDB.lyt). Padstack missing from Padstack partition. No padstack called "LVIA-0.1/0.25" defined for via layer range 9 - 10# ^5 j, K( ^1 \
如何解决,谢谢2 g; m; o/ _9 d4 p3 \( p. v# R
以下方法已经试过,但无效( ], [0 k" m8 t& G$ K2 Q4 N; {
Look under All programs for the mentor Graphics SDD - System Tool - iCDB Project Backup program.! o9 T x% z4 G* C1 a; f
Select the Project file and click OK.
2 v7 e; i+ W' r8 ~& q. N0 JUnder Project you have Clean Up, Create support package and Repair.
4 c, }/ f3 Z6 K" J% o * E% f8 H6 I9 H1 y
You can try to Clean Up or Repair the project.
# |/ b* A' ~4 _' ^ |
