Cypress EZ-USB FX3S
3 E/ {: W T) J, e$ B8 v4 U, z% w2 E- Integration: Full USB 3.0 Peripheral Controller with built-in PHY
- Storage Support: Support up to 2 memory cards- SD 3.0, eMMC 4.41, SDIO 3.0
- High-Performance: ARM9 with 512 kB RAM for data processing
- Connectivity: I2C, I2S, SPI and UART peripherals
- Flexibility: Configurable 16-bit 100 MHz GPIF II interface connects with any processor/sensor/ASIC/FPGA with parallel port
- Low Power: Low 1.2 V core and independent power domains
- Multitasking: 32 configurable endpoints
- Flexible Clock: Selectable XTAL input from 19.2, 26, 38.4 and 52 MHz
- Small Footprint: 10x10mm 121 ball 0.8mm pitch BGA package
: N l: x' t/ N 9 ]' b2 s8 e0 }8 p4 ~5 N
_+ Q, g- g1 \- Q
