------ Oversights/Warnings/Errors ------; T7 `% C9 E7 j$ A3 S& T. ?, h% Q
. y' a+ Z u$ n; W, a6 d. K
0 P/ B c: V5 p! n! e#1 ERROR(SPMHNI-176): Device library error detected.+ h/ ^1 t0 ?1 r
; J0 W) F f( o( c6 C" i5 i$ L# p5 r
ERROR(SPMHNI-190): Device problem 'R_17_RES-0603_200K[/5%'. Package property error: 'VALUE'='200KΩ/5%'. Illegal character(s) present in the name or value..
: ]( G0 s: S- y9 Y: v2 r, d9 P- w- G" f" a( v
ERROR(SPMHNI-170): Device 'R_17_RES-0603_200K[/5%' has library errors. Unable to transfer to allegro.
# ]( |$ L |( B# C4 ?) N% J% T0 U ~( T) K3 @
#2 ERROR(SPMHNI-176): Device library error detected.
1 V/ i: @) |( |( ], C' j( h' t8 h6 P: Q6 ]* j w
ERROR(SPMHNI-190): Device problem 'R_15_RES-0603_10K[/5%'. Package property error: 'VALUE'='10KΩ/5%'. Illegal character(s) present in the name or value..! q: E% x0 P0 D$ q$ H
7 o8 E# E8 }2 ?5 m N: h h
ERROR(SPMHNI-170): Device 'R_15_RES-0603_10K[/5%' has library errors. Unable to transfer to Allegro.3 U' M# @ r* R$ }- }" ]; t
8 B1 N- t, z: k! J7 O' S
#3 ERROR(SPMHNI-176): Device library error detected.) N" [2 E$ Q( _3 h
/ I7 v9 K5 l; [6 u- v
ERROR(SPMHNI-190): Device problem 'R_9_RES-1206_150K[/5%'. Package property error: 'VALUE'='150KΩ/5%'. Illegal character(s) present in the name or value..
: b3 m" ~* l8 W: W. X- F* I0 H% B1 C6 x8 Z! D: |7 }7 F6 M6 ?
ERROR(SPMHNI-170): Device 'R_9_RES-1206_150K[/5%' has library errors. Unable to transfer to Allegro.' e3 Z( n9 r% p# G- M
- l l; Z. g R; e#4 ERROR(SPMHNI-176): Device library error detected.2 A1 Y+ \& g- H9 Q
/ X1 {% Z9 O) n0 a
ERROR(SPMHNI-190): Device problem 'R_16_RES-0603_100K[/5%'. Package property error: 'VALUE'='100KΩ/5%'. Illegal character(s) present in the name or value..
: l- m& l5 S& R# [# A; \' d! `
, U. x9 y( X; ~7 o- ^ERROR(SPMHNI-170): Device 'R_16_RES-0603_100K[/5%' has library errors. Unable to transfer to Allegro.
/ Q! B+ h1 {+ r) G8 [" m
: K- l: ^% }" f#5 ERROR(SPMHNI-176): Device library error detected.
! g/ x% `' H* M2 g) y4 c5 J7 \+ @8 z
ERROR(SPMHNI-190): Device problem 'R_12_RES-0603_180K[/5%'. Package property error: 'VALUE'='180KΩ/5%'. Illegal character(s) present in the name or value..& X6 W! Y& O& d
- M8 U% _) E0 s% jERROR(SPMHNI-170): Device 'R_12_RES-0603_180K[/5%' has library errors. Unable to transfer to Allegro.
: r" A! X% v3 C3 V# ^' k5 u
# y7 \$ j. n- l+ c#6 ERROR(SPMHNI-176): Device library error detected.5 g$ g1 k# k- i% j+ D
( g1 C; p% I8 S- a5 Z, N1 p
ERROR(SPMHNI-190): Device problem 'R_7_RES-0603_1M[/5%'. Package property error: 'VALUE'='1MΩ/5%'. Illegal character(s) present in the name or value..0 L6 M9 r: H6 S n; J
! R0 t: J/ u3 w
ERROR(SPMHNI-170): Device 'R_7_RES-0603_1M[/5%' has library errors. Unable to transfer to Allegro.
0 A: m* D0 R+ O2 l: `$ S6 i: E5 J% t
#7 ERROR(SPMHNI-176): Device library error detected.1 X2 H N8 g2 l; I
0 @0 g5 G) \' E5 F: |3 s6 Y5 V& w
ERROR(SPMHNI-190): Device problem 'R_14_RES-0603_100K[/5%'. Package property error: 'VALUE'='100KΩ/5%'. Illegal character(s) present in the name or value..# B" f0 c/ h! T9 G+ v
`$ I u9 ]# h s% u5 z2 NERROR(SPMHNI-170): Device 'R_14_RES-0603_100K[/5%' has library errors. Unable to transfer to Allegro.
2 I% N4 l/ v% O4 B' k) {* L7 x' q
, l- S! r2 L* S( V: R; I- j#8 ERROR(SPMHNI-176): Device library error detected.
4 W: g8 @' \6 S x2 f
4 n/ ^ Y- s, z% j1 S. a8 t4 H6 B vERROR(SPMHNI-190): Device problem 'R_22_RES-0603_10K[/5%'. Package property error: 'VALUE'='10KΩ/5%'. Illegal character(s) present in the name or value..
0 L, `; N5 I5 e" n6 c, \* V
& x% P; W1 I8 f6 I' vERROR(SPMHNI-170): Device 'R_22_RES-0603_10K[/5%' has library errors. Unable to transfer to Allegro.
( Z- B: e. Z6 E" n$ S; P% i3 }/ {7 d
#9 ERROR(SPMHNI-176): Device library error detected.( b8 u# v. d1 F+ F/ b% ?
4 D& q) h; i8 ?* [/ y: NERROR(SPMHNI-190): Device problem 'R_24_RES-0603_0[/5%'. Package property error: 'VALUE'='0Ω/5%'. Illegal character(s) present in the name or value../ b- E9 R6 ~- \$ @1 T h+ {
% n. Q! D# {/ _( j. ^8 rERROR(SPMHNI-170): Device 'R_24_RES-0603_0[/5%' has library errors. Unable to transfer to Allegro.
' U9 ^1 g. j% d, j7 y/ \4 U0 ^; d" m" T: k4 U4 w$ ?. w, D7 B4 D
#10 ERROR(SPMHNI-176): Device library error detected.5 m( I; e+ S! ^6 Q
: I+ A: t! K) e; T' z
ERROR(SPMHNI-190): Device problem 'R_6_RES-0603_0[/5%'. Package property error: 'VALUE'='0Ω/5%'. Illegal character(s) present in the name or value..
0 g" i6 N x3 K4 r+ q
' B6 t* d" L* O2 j0 tERROR(SPMHNI-170): Device 'R_6_RES-0603_0[/5%' has library errors. Unable to transfer to Allegro.
) y" v9 D' U5 y5 K3 p7 T" J: J/ B& o6 f: O% T* ?
#11 ERROR(SPMHNI-176): Device library error detected.
# m; h, X2 u1 ] w5 v0 L0 M; p5 W9 g l, m- O
ERROR(SPMHNI-190): Device problem 'R_11_RES-0603_100K[/5%'. Package property error: 'VALUE'='100KΩ/5%'. Illegal character(s) present in the name or value..
1 J% V+ C% |+ {9 ~$ ~4 T/ f1 K9 o% r
4 H v% M, _: |& p, c. @ W9 ?ERROR(SPMHNI-170): Device 'R_11_RES-0603_100K[/5%' has library errors. Unable to transfer to Allegro.
* x, X3 X5 Y7 |* Q- u& G- Q8 a8 O! w/ m- ~5 t8 i
#12 ERROR(SPMHNI-176): Device library error detected.8 ~6 O9 d0 H$ T; j, v3 G1 O. j) c
. P: z8 p- l: G l# h0 `- ^ERROR(SPMHNI-190): Device problem 'R_21_RES-0603_100[/5%'. Package property error: 'VALUE'='100Ω/5%'. Illegal character(s) present in the name or value..
0 A# i! m! l# a% i' Y2 D0 _+ {* [2 ^6 Y/ Z2 f; s4 b3 P+ p
ERROR(SPMHNI-170): Device 'R_21_RES-0603_100[/5%' has library errors. Unable to transfer to Allegro.
5 ]+ Q, ]# s! D
/ t. p) t& F3 t' {& L#13 ERROR(SPMHNI-176): Device library error detected.
0 v8 d2 s9 v' R
4 f, m1 m4 R w, N4 xERROR(SPMHNI-190): Device problem 'R_20_RES-0603_100[/5%'. Package property error: 'VALUE'='100Ω/5%'. Illegal character(s) present in the name or value.." ]1 f) U8 w. V) c
4 |& z5 Z7 c/ x. T; H4 S3 E- eERROR(SPMHNI-170): Device 'R_20_RES-0603_100[/5%' has library errors. Unable to transfer to Allegro.
1 z! S! A2 ?+ }& |+ _$ \
1 i3 N0 d5 A6 k8 r#14 ERROR(SPMHNI-176): Device library error detected.
& B3 D) p3 ^+ m( r6 {
" J( r6 V- {: f0 GERROR(SPMHNI-190): Device problem 'R_5_RES-1206_51[/5%'. Package property error: 'VALUE'='51Ω/5%'. Illegal character(s) present in the name or value..6 M/ f7 y! r( T2 L9 t3 G
! y3 v9 v3 v% J& r6 I* o+ {1 NERROR(SPMHNI-170): Device 'R_5_RES-1206_51[/5%' has library errors. Unable to transfer to Allegro.3 x3 F ?( b+ s2 g- z; ^
% Z9 C4 V; z! B4 P# N+ l
#15 ERROR(SPMHNI-176): Device library error detected.$ G2 F2 Y- U: ?
3 u. {: C% P, ? L c5 aERROR(SPMHNI-190): Device problem 'R_23_RES-0603_0[/5%'. Package property error: 'VALUE'='0Ω/5%'. Illegal character(s) present in the name or value..5 r3 T( @" ?6 g( |
/ B* p4 ?1 {6 R% N: a
ERROR(SPMHNI-170): Device 'R_23_RES-0603_0[/5%' has library errors. Unable to transfer to Allegro.
. z5 |. h( V& z/ x8 a
1 m" N4 b8 K J* ^" Y#16 ERROR(SPMHNI-176): Device library error detected.
3 T/ A& A/ z; [- ?2 ]. ?: q) x5 P' D# O0 v6 q
ERROR(SPMHNI-190): Device problem 'R_25_RES-0603_0[/5%'. Package property error: 'VALUE'='0Ω/5%'. Illegal character(s) present in the name or value..! e! b6 p& H9 j4 R
! |9 c3 c, N7 M2 {, i8 ~ERROR(SPMHNI-170): Device 'R_25_RES-0603_0[/5%' has library errors. Unable to transfer to Allegro.
: ]* i/ p1 N6 q
; Q" D7 V; q, u9 g3 S9 K+ Y1 S5 U! V#17 ERROR(SPMHNI-176): Device library error detected.: D/ R! d6 S! ^; E9 D/ m' `
5 J( h1 i# Z9 o1 n3 gERROR(SPMHNI-190): Device problem 'R_19_RES-0603_200K[/1%'. Package property error: 'VALUE'='200KΩ/1%'. Illegal character(s) present in the name or value..- T" J& x& ]+ _
- W+ o; P- O/ [0 d7 K7 e1 z
ERROR(SPMHNI-170): Device 'R_19_RES-0603_200K[/1%' has library errors. Unable to transfer to Allegro.0 }! z8 z9 G$ u6 J
9 C! R1 B) B, E6 x- `
#18 ERROR(SPMHNI-176): Device library error detected.; x! Y H9 d4 Q3 S/ @0 E: `
: \* J& Z6 k' d9 ?5 g2 r: iERROR(SPMHNI-190): Device problem 'R_18_RES-0603_27K[/1%'. Package property error: 'VALUE'='27KΩ/1%'. Illegal character(s) present in the name or value..
. Z9 M; Q. T' \' F) p8 B' V, A" U1 i: [
ERROR(SPMHNI-170): Device 'R_18_RES-0603_27K[/1%' has library errors. Unable to transfer to Allegro.
% U& T+ V5 Z8 g7 H1 W* B# O3 p$ u( P
" O' p+ b' X" a- h" f l: J/ H#19 ERROR(SPMHNI-176): Device library error detected.
7 |# h9 ]7 h% P# U4 e# \
. P, A( C! I8 Z! _1 |ERROR(SPMHNI-190): Device problem 'R_26_RES-0603_100K[/5%'. Package property error: 'VALUE'='100KΩ/5%'. Illegal character(s) present in the name or value../ p+ c! g! Z8 @6 U8 T) u" V; s
, z9 ], c" ]9 O5 l! x. _2 A6 F
ERROR(SPMHNI-170): Device 'R_26_RES-0603_100K[/5%' has library errors. Unable to transfer to Allegro.# h5 o# {% {$ D, V
3 D* G4 c2 p. a3 p. O6 i# p
#20 ERROR(SPMHNI-176): Device library error detected.
- m: Z7 H8 F# v* n1 W& F& a# I; ^; Q8 f
ERROR(SPMHNI-190): Device problem 'R_8_RES-1206_150K[/5%'. Package property error: 'VALUE'='150KΩ/5%'. Illegal character(s) present in the name or value..
! p) v) _1 N: R' D z6 o
6 b# ?/ n2 p/ A& ]8 I; h2 OERROR(SPMHNI-170): Device 'R_8_RES-1206_150K[/5%' has library errors. Unable to transfer to Allegro.% W% Z" T2 V0 [" R$ g3 r1 e
: Q3 P+ b) Q* T3 r8 R o c O
#21 ERROR(SPMHNI-176): Device lib; ]4 o- e& [. u5 U. I- p& c Y
2 [* v. [8 P! C: ^4 K
g( {1 T. v: ?ERROR(SPMHNI-190): Device problem 'R_10_RES-1206_180K[/5%'. Package property error: 'VALUE'='180KΩ/5%'. Illegal character(s) present in the name or value..
; {5 E% H/ C0 s* c- }/ \% ^1 Z+ B- j; p4 X$ T# G- E! {- x, [7 I9 o. @
ERROR(SPMHNI-170): Device 'R_10_RES-1206_180K[/5%' has library errors. Unable to transfer to Allegro.. J7 X" @' J; H: D' L8 y
- [8 t, A7 e6 z2 {& U5 M! W------ Library Paths ------
) b" [+ x( x. _1 `* aMODULEPATH = C:/Users/q8941/AppData/Roaming/SPB_Data/symbol/package
/ |3 k" F/ f- W5 J* p8 G6 } .
/ P. T# j4 w, M/ |, }% b C:/cadence/SPB_17.2/share/local/pcb/modules 9 W, F3 _, a$ X7 d
; @& B/ e. r# k' x) v
PSMPATH = C:/Users/q8941/AppData/Roaming/SPB_Data/symbol/package
+ q W7 j2 F% E8 c . * ^. |# L- F4 v+ W5 X8 j
symbols
' l, F4 f& J0 u! M1 @3 J4 V; P ..
- k, R/ s F: V% d: F ../symbols
- L; ~ l; J5 }9 @- K7 t1 C$ s C:/Cadence/SPB_17.2/share/local/pcb/symbols
4 S9 i1 I: r5 D" q: A* E C:/Cadence/SPB_17.2/share/pcb/pcb_lib/symbols
! F; |- L3 n+ {' M C:/Cadence/SPB_17.2/share/pcb/allegrolib/symbols
) u" W/ g9 J) b$ J
+ }) Y t% M T& M& @PADPATH = C:/Users/q8941/AppData/Roaming/SPB_Data/symbol/package
- ?0 ]2 g7 F1 |/ n( g . ; Z9 V* }% s8 O7 Q* `3 i* h' e% z
symbols
0 V4 V8 @) d0 x- o" V .. 7 e. _+ C) y! O5 a1 H- |
../symbols
5 h! p* ^" Z- m. p4 j3 N6 {: | C:/Cadence/SPB_17.2/share/local/pcb/padstacks
# R& q, m0 Y2 x" S4 _' s9 k8 d- o5 k5 }% G C:/Cadence/SPB_17.2/share/pcb/pcb_lib/symbols
n8 ?5 P6 u. {: I* y6 P5 U C:/Cadence/SPB_17.2/share/pcb/allegrolib/symbols 3 l8 F. Y. v3 `# R1 r! E
6 B& Q' U+ `- R7 c: @& n
, L; A4 T. w% |* |------ Summary Statistics ------
9 y9 ~: b1 Q! l+ s- y" \7 A/ p- u" w) l) V
" W; o/ k* v* u5 s3 m* c( O#22 Run stopped because errors were detected
. M: N R9 x7 g: O1 T0 B3 |7 {/ ~" s N: X+ T7 S
netrev run on Mar 3 14:46:03 20170 z" H0 v, c/ @# @# N7 N+ T* S
DESIGN NAME : 'ORO-WRT1-R1'" c; G; `. A$ s+ M3 X& i
PACKAGING ON Mar 2 2016 00:37:24 l# R1 v+ n! ^. U B
; a9 t* {/ h3 j3 ~6 {, u+ B COMPILE 'logic': I$ G4 u1 k" h) { J# _/ J
CHECK_PIN_NAMES OFF& X) {2 v2 s* B u6 H
CROSS_REFERENCE OFF) g# q+ V2 F9 j* P, S
FEEDBACK OFF
: K- S# r4 t6 [0 @. X% L( y! {' K INCREMENTAL OFF
3 E) V' X7 J/ `, r7 J; C' |/ p, l INTERFACE_TYPE PHYSICAL! l- H! h* [1 v: p# d$ z* R" W" L) D" X
MAX_ERRORS 500
1 z, D$ N' y: j MERGE_MINIMUM 5
( `) p) K- |9 c. M$ Q4 E NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
$ x( X, X$ x8 V NET_NAME_LENGTH 24
1 C/ y1 e5 S* O8 d OVERSIGHTS ON
' b C, `5 y. I8 F REPLACE_CHECK OFF
+ j6 E) Z, p! f: U% @ SINGLE_NODE_NETS ON
( h/ u9 b4 A( N- l1 j) F" L SPLIT_MINIMUM 0
* @/ k: A0 Z" j& w2 z SUPPRESS 20; U4 o/ p% q# E; c3 L
WARNINGS ON5 K: D0 ^5 z- j" _
0 W/ o- R1 C2 g t1 e% J
22 errors detected
2 O k, K5 m6 o) c8 q, y1 [ No oversight detected
; L) f+ v$ }# C# [. [ No warning detected
& \; x+ B4 j# M6 r/ [
3 n" C& G9 [2 c. Lcpu time 0:00:13
2 y5 `" Q% ]& jelapsed time 0:00:00
7 [: V& p9 Y4 ?% O- x! c" x* F' P
4 P4 A# a1 @/ E; MINFO(ORCAP-32005): *** Done ***
. A: c( v" `* D' p
( T! A- B' ~4 z" ]$ F
2 }. [9 b. N v4 I2 d. u |
