About This Book
6 S. ]+ ^, k% b$ v6 C8 r. `This is not a book about how to use LabVIEW or even a book on learning digital$ r x1 S$ d, s' U' Q
signal processing (DSP). Instead it is more of a practical guide on how to enable
2 _' O' A' N; Y/ }, KLabVIEW to tackle some real-world DSP and communication problems. This
% b! t `5 l! B3 s9 `5 Z% s* ?book assumes that the reader has a good grasp of many of the complex issues4 i* w( K6 o! p2 o
encountered in DSP and digital communications and also is at least skilled
4 O& g. }5 N5 ]9 N' x$ benough in LabVIEW to build a VI. When necessary, the book will dive into the* k9 u: D0 G3 {+ I4 H
heart of signal processing topics and their implications will be explored. Certain6 o3 F2 [9 o4 b# C; N& d
topics will be explained in enough detail so that the reader will know there is
5 F" w- T; j6 p2 q8 ]0 c! Zno hand waving or mystery involved. This material is meant to bridge the gap
; D$ L. z3 M9 h }6 m4 o) M7 qbetween obtaining theoretical knowledge and actually exercising that knowledge.
( t8 m' u. P# w1 M- t# ILabVIEW provides us with an excellent set of tools for examining all sorts9 S6 M2 V3 l* X7 @3 O) r
of DSP and digital communication topics. Its graphical nature allows us to6 j1 g1 s6 ^( T
quickly and efficiently get to the core of a communication problem without all
& v4 }( l* [# Othe overhead that generally accompanies a digital communication system. This4 B, `# Q( w. [) C" t& P; F
book will start out at the beginning of the DSP realm—sampling a signal. The
( _# S/ A# ]$ d; @4 ?% n: [intermediate chapters will cover some basic building blocks and the final chapters0 z) H2 R3 y" @! J) _4 T& _9 ]
will put it all together as a digital communication system.
7 A B+ c* n: N, ?, AAlot of signal processing books start out describing what a discrete time
' {% C( }8 ~/ Rsequence is, the advantages of DSP over analog methods, and the like. This0 p. u A+ j1 \
book skips all that and assumes that you already know enough about DSP to
# F! T! H* o! r5 W m- o3 e3 P+ \6 dget started and you probably have some very good references regarding where
4 R7 s5 k4 z+ K; l8 C% ~- i5 R V! Zto go when you do not understand something. Instead this book focuses on
1 e2 b" X1 `; m8 u" _2 eputting that DSP knowledge to work using LabVIEW. Also, at the end of each/ C% L- J1 M1 D% E8 `7 ~9 A
chapter is a list of references for the specific topics covered in that chapter. Of! C2 d0 x& y& N: N3 {( f4 ^
course the reader is encouraged to look at those references for any concept that+ {+ G* [, t# E
is not quite clear. If your DSP is a little rusty, or if you are new to the topic, a
4 ~" h" o. k$ A# Z$ k/ K' ugood starting place would be to read Understanding Digital Signal Processing
2 G' P3 T& k) k1 eby Rick Lyons before moving to the more advanced texts such as Discrete-Time
P; w a; c4 SSignal Processing by Oppenheim and Schafer. The book by Lyons should give you% F5 ] F; r" M% t5 f$ W$ g$ Q- r$ f
a good intuitive feel for many complicated DSP subjects while the Oppenheim0 ^( G, o' F; @. _ n) O& A- f7 ]$ [+ r
and Schafer book will give you all the gory details on how and why.
8 M4 z8 d9 e. b& _.....
. S3 h% ^9 Z, m! u( ~ |
